This patchset adds support for LCD to the MX51 Soc using the IPUv3 graphic processor. This is a porting to U-Boot of the Linux driver developed and delivered by Freescale.
The patch adds the linux framebuffer header file. As several drivers are ported from Linux, it is easier to reuse the same structures already present in the kernel.
Signed-off-by: Stefano Babic sbabic@denx.de --- include/linux/fb.h | 616 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 616 insertions(+), 0 deletions(-) create mode 100644 include/linux/fb.h
diff --git a/include/linux/fb.h b/include/linux/fb.h new file mode 100644 index 0000000..0138e61 --- /dev/null +++ b/include/linux/fb.h @@ -0,0 +1,616 @@ +#ifndef _LINUX_FB_H +#define _LINUX_FB_H + +#include <linux/types.h> + +/* Definitions of frame buffers */ + +#define FB_MAX 32 /* sufficient for now */ + +#define FB_TYPE_PACKED_PIXELS 0 /* Packed Pixels */ + +#define FB_VISUAL_MONO01 0 /* Monochr. 1=Black 0=White */ +#define FB_VISUAL_MONO10 1 /* Monochr. 1=White 0=Black */ +#define FB_VISUAL_TRUECOLOR 2 /* True color */ +#define FB_VISUAL_PSEUDOCOLOR 3 /* Pseudo color (like atari) */ +#define FB_VISUAL_DIRECTCOLOR 4 /* Direct color */ +#define FB_VISUAL_STATIC_PSEUDOCOLOR 5 /* Pseudo color readonly */ + +#define FB_ACCEL_NONE 0 /* no hardware accelerator */ + +struct fb_fix_screeninfo { + char id[16]; /* identification string eg "TT Builtin" */ + unsigned long smem_start; /* Start of frame buffer mem */ + /* (physical address) */ + __u32 smem_len; /* Length of frame buffer mem */ + __u32 type; /* see FB_TYPE_* */ + __u32 type_aux; /* Interleave for interleaved Planes */ + __u32 visual; /* see FB_VISUAL_* */ + __u16 xpanstep; /* zero if no hardware panning */ + __u16 ypanstep; /* zero if no hardware panning */ + __u16 ywrapstep; /* zero if no hardware ywrap */ + __u32 line_length; /* length of a line in bytes */ + unsigned long mmio_start; /* Start of Memory Mapped I/O */ + /* (physical address) */ + __u32 mmio_len; /* Length of Memory Mapped I/O */ + __u32 accel; /* Indicate to driver which */ + /* specific chip/card we have */ + __u16 reserved[3]; /* Reserved for future compatibility */ +}; + +/* + * Interpretation of offset for color fields: All offsets are from the right, + * inside a "pixel" value, which is exactly 'bits_per_pixel' wide (means: you + * can use the offset as right argument to <<). A pixel afterwards is a bit + * stream and is written to video memory as that unmodified. + * + * For pseudocolor: offset and length should be the same for all color + * components. Offset specifies the position of the least significant bit + * of the pallette index in a pixel value. Length indicates the number + * of available palette entries (i.e. # of entries = 1 << length). + */ +struct fb_bitfield { + __u32 offset; /* beginning of bitfield */ + __u32 length; /* length of bitfield */ + __u32 msb_right; + +}; + +#define FB_NONSTD_HAM 1 /* Hold-And-Modify (HAM) */ +#define FB_NONSTD_REV_PIX_IN_B 2 /* order of pixels in each byte is reversed */ + +#define FB_ACTIVATE_NOW 0 /* set values immediately (or vbl)*/ +#define FB_ACTIVATE_NXTOPEN 1 /* activate on next open */ +#define FB_ACTIVATE_TEST 2 /* don't set, round up impossible */ +#define FB_ACTIVATE_MASK 15 + /* values */ +#define FB_ACTIVATE_VBL 16 /* activate values on next vbl */ +#define FB_CHANGE_CMAP_VBL 32 /* change colormap on vbl */ +#define FB_ACTIVATE_ALL 64 /* change all VCs on this fb */ +#define FB_ACTIVATE_FORCE 128 /* force apply even when no change*/ +#define FB_ACTIVATE_INV_MODE 256 /* invalidate videomode */ + +#define FB_SYNC_HOR_HIGH_ACT 1 /* horizontal sync high active */ +#define FB_SYNC_VERT_HIGH_ACT 2 /* vertical sync high active */ +#define FB_SYNC_EXT 4 /* external sync */ +#define FB_SYNC_COMP_HIGH_ACT 8 /* composite sync high active */ +#define FB_SYNC_BROADCAST 16 /* broadcast video timings */ + /* vtotal = 144d/288n/576i => PAL */ + /* vtotal = 121d/242n/484i => NTSC */ +#define FB_SYNC_ON_GREEN 32 /* sync on green */ + +#define FB_VMODE_NONINTERLACED 0 /* non interlaced */ +#define FB_VMODE_INTERLACED 1 /* interlaced */ +#define FB_VMODE_DOUBLE 2 /* double scan */ +#define FB_VMODE_ODD_FLD_FIRST 4 /* interlaced: top line first */ +#define FB_VMODE_MASK 255 + +#define FB_VMODE_YWRAP 256 /* ywrap instead of panning */ +#define FB_VMODE_SMOOTH_XPAN 512 /* smooth xpan possible (internally used) */ +#define FB_VMODE_CONUPDATE 512 /* don't update x/yoffset */ + +/* + * Display rotation support + */ +#define FB_ROTATE_UR 0 +#define FB_ROTATE_CW 1 +#define FB_ROTATE_UD 2 +#define FB_ROTATE_CCW 3 + +#define PICOS2KHZ(a) (1000000000UL/(a)) +#define KHZ2PICOS(a) (1000000000UL/(a)) + +struct fb_var_screeninfo { + __u32 xres; /* visible resolution */ + __u32 yres; + __u32 xres_virtual; /* virtual resolution */ + __u32 yres_virtual; + __u32 xoffset; /* offset from virtual to visible */ + __u32 yoffset; /* resolution */ + + __u32 bits_per_pixel; /* guess what */ + __u32 grayscale; /* != 0 Graylevels instead of colors */ + + struct fb_bitfield red; /* bitfield in fb mem if true color, */ + struct fb_bitfield green; /* else only length is significant */ + struct fb_bitfield blue; + struct fb_bitfield transp; /* transparency */ + + __u32 nonstd; /* != 0 Non standard pixel format */ + + __u32 activate; /* see FB_ACTIVATE_* */ + + __u32 height; /* height of picture in mm */ + __u32 width; /* width of picture in mm */ + + __u32 accel_flags; /* (OBSOLETE) see fb_info.flags */ + + /* Timing: All values in pixclocks, except pixclock (of course) */ + __u32 pixclock; /* pixel clock in ps (pico seconds) */ + __u32 left_margin; /* time from sync to picture */ + __u32 right_margin; /* time from picture to sync */ + __u32 upper_margin; /* time from sync to picture */ + __u32 lower_margin; + __u32 hsync_len; /* length of horizontal sync */ + __u32 vsync_len; /* length of vertical sync */ + __u32 sync; /* see FB_SYNC_* */ + __u32 vmode; /* see FB_VMODE_* */ + __u32 rotate; /* angle we rotate counter clockwise */ + __u32 reserved[5]; /* Reserved for future compatibility */ +}; + +struct fb_cmap { + __u32 start; /* First entry */ + __u32 len; /* Number of entries */ + __u16 *red; /* Red values */ + __u16 *green; + __u16 *blue; + __u16 *transp; /* transparency, can be NULL */ +}; + +struct fb_con2fbmap { + __u32 console; + __u32 framebuffer; +}; + +/* VESA Blanking Levels */ +#define VESA_NO_BLANKING 0 +#define VESA_VSYNC_SUSPEND 1 +#define VESA_HSYNC_SUSPEND 2 +#define VESA_POWERDOWN 3 + + +enum { + /* screen: unblanked, hsync: on, vsync: on */ + FB_BLANK_UNBLANK = VESA_NO_BLANKING, + + /* screen: blanked, hsync: on, vsync: on */ + FB_BLANK_NORMAL = VESA_NO_BLANKING + 1, + + /* screen: blanked, hsync: on, vsync: off */ + FB_BLANK_VSYNC_SUSPEND = VESA_VSYNC_SUSPEND + 1, + + /* screen: blanked, hsync: off, vsync: on */ + FB_BLANK_HSYNC_SUSPEND = VESA_HSYNC_SUSPEND + 1, + + /* screen: blanked, hsync: off, vsync: off */ + FB_BLANK_POWERDOWN = VESA_POWERDOWN + 1 +}; + +#define FB_VBLANK_VBLANKING 0x001 /* currently in a vertical blank */ +#define FB_VBLANK_HBLANKING 0x002 /* currently in a horizontal blank */ +#define FB_VBLANK_HAVE_VBLANK 0x004 /* vertical blanks can be detected */ +#define FB_VBLANK_HAVE_HBLANK 0x008 /* horizontal blanks can be detected */ +#define FB_VBLANK_HAVE_COUNT 0x010 /* global retrace counter is available */ +#define FB_VBLANK_HAVE_VCOUNT 0x020 /* the vcount field is valid */ +#define FB_VBLANK_HAVE_HCOUNT 0x040 /* the hcount field is valid */ +#define FB_VBLANK_VSYNCING 0x080 /* currently in a vsync */ +#define FB_VBLANK_HAVE_VSYNC 0x100 /* verical syncs can be detected */ + +struct fb_vblank { + __u32 flags; /* FB_VBLANK flags */ + __u32 count; /* counter of retraces since boot */ + __u32 vcount; /* current scanline position */ + __u32 hcount; /* current scandot position */ + __u32 reserved[4]; /* reserved for future compatibility */ +}; + +/* Internal HW accel */ +#define ROP_COPY 0 +#define ROP_XOR 1 + +struct fb_copyarea { + __u32 dx; + __u32 dy; + __u32 width; + __u32 height; + __u32 sx; + __u32 sy; +}; + +struct fb_fillrect { + __u32 dx; /* screen-relative */ + __u32 dy; + __u32 width; + __u32 height; + __u32 color; + __u32 rop; +}; + +struct fb_image { + __u32 dx; /* Where to place image */ + __u32 dy; + __u32 width; /* Size of image */ + __u32 height; + __u32 fg_color; /* Only used when a mono bitmap */ + __u32 bg_color; + __u8 depth; /* Depth of the image */ + const char *data; /* Pointer to image data */ + struct fb_cmap cmap; /* color map info */ +}; + +/* + * hardware cursor control + */ + +#define FB_CUR_SETIMAGE 0x01 +#define FB_CUR_SETPOS 0x02 +#define FB_CUR_SETHOT 0x04 +#define FB_CUR_SETCMAP 0x08 +#define FB_CUR_SETSHAPE 0x10 +#define FB_CUR_SETSIZE 0x20 +#define FB_CUR_SETALL 0xFF + +struct fbcurpos { + __u16 x, y; +}; + +struct fb_cursor { + __u16 set; /* what to set */ + __u16 enable; /* cursor on/off */ + __u16 rop; /* bitop operation */ + const char *mask; /* cursor mask bits */ + struct fbcurpos hot; /* cursor hot spot */ + struct fb_image image; /* Cursor image */ +}; + +#ifdef CONFIG_FB_BACKLIGHT +/* Settings for the generic backlight code */ +#define FB_BACKLIGHT_LEVELS 128 +#define FB_BACKLIGHT_MAX 0xFF +#endif + +#ifdef __KERNEL__ + +struct vm_area_struct; +struct fb_info; +struct device; +struct file; + +/* Definitions below are used in the parsed monitor specs */ +#define FB_DPMS_ACTIVE_OFF 1 +#define FB_DPMS_SUSPEND 2 +#define FB_DPMS_STANDBY 4 + +#define FB_DISP_DDI 1 +#define FB_DISP_ANA_700_300 2 +#define FB_DISP_ANA_714_286 4 +#define FB_DISP_ANA_1000_400 8 +#define FB_DISP_ANA_700_000 16 + +#define FB_DISP_MONO 32 +#define FB_DISP_RGB 64 +#define FB_DISP_MULTI 128 +#define FB_DISP_UNKNOWN 256 + +#define FB_SIGNAL_NONE 0 +#define FB_SIGNAL_BLANK_BLANK 1 +#define FB_SIGNAL_SEPARATE 2 +#define FB_SIGNAL_COMPOSITE 4 +#define FB_SIGNAL_SYNC_ON_GREEN 8 +#define FB_SIGNAL_SERRATION_ON 16 + +#define FB_MISC_PRIM_COLOR 1 +#define FB_MISC_1ST_DETAIL 2 /* First Detailed Timing is preferred */ +struct fb_chroma { + __u32 redx; /* in fraction of 1024 */ + __u32 greenx; + __u32 bluex; + __u32 whitex; + __u32 redy; + __u32 greeny; + __u32 bluey; + __u32 whitey; +}; + +struct fb_monspecs { + struct fb_chroma chroma; + struct fb_videomode *modedb; /* mode database */ + __u8 manufacturer[4]; /* Manufacturer */ + __u8 monitor[14]; /* Monitor String */ + __u8 serial_no[14]; /* Serial Number */ + __u8 ascii[14]; /* ? */ + __u32 modedb_len; /* mode database length */ + __u32 model; /* Monitor Model */ + __u32 serial; /* Serial Number - Integer */ + __u32 year; /* Year manufactured */ + __u32 week; /* Week Manufactured */ + __u32 hfmin; /* hfreq lower limit (Hz) */ + __u32 hfmax; /* hfreq upper limit (Hz) */ + __u32 dclkmin; /* pixelclock lower limit (Hz) */ + __u32 dclkmax; /* pixelclock upper limit (Hz) */ + __u16 input; /* display type - see FB_DISP_* */ + __u16 dpms; /* DPMS support - see FB_DPMS_ */ + __u16 signal; /* Signal Type - see FB_SIGNAL_* */ + __u16 vfmin; /* vfreq lower limit (Hz) */ + __u16 vfmax; /* vfreq upper limit (Hz) */ + __u16 gamma; /* Gamma - in fractions of 100 */ + __u16 gtf : 1; /* supports GTF */ + __u16 misc; /* Misc flags - see FB_MISC_* */ + __u8 version; /* EDID version... */ + __u8 revision; /* ...and revision */ + __u8 max_x; /* Maximum horizontal size (cm) */ + __u8 max_y; /* Maximum vertical size (cm) */ +}; + +struct fb_cmap_user { + __u32 start; /* First entry */ + __u32 len; /* Number of entries */ + __u16 *red; /* Red values */ + __u16 *green; + __u16 *blue; + __u16 *transp; /* transparency, can be NULL */ +}; + +struct fb_image_user { + __u32 dx; /* Where to place image */ + __u32 dy; + __u32 width; /* Size of image */ + __u32 height; + __u32 fg_color; /* Only used when a mono bitmap */ + __u32 bg_color; + __u8 depth; /* Depth of the image */ + const char *data; /* Pointer to image data */ + struct fb_cmap_user cmap; /* color map info */ +}; + +struct fb_cursor_user { + __u16 set; /* what to set */ + __u16 enable; /* cursor on/off */ + __u16 rop; /* bitop operation */ + const char *mask; /* cursor mask bits */ + struct fbcurpos hot; /* cursor hot spot */ + struct fb_image_user image; /* Cursor image */ +}; + +/* + * Register/unregister for framebuffer events + */ + +/* The resolution of the passed in fb_info about to change */ +#define FB_EVENT_MODE_CHANGE 0x01 +/* The display on this fb_info is beeing suspended, no access to the + * framebuffer is allowed any more after that call returns + */ +#define FB_EVENT_SUSPEND 0x02 +/* The display on this fb_info was resumed, you can restore the display + * if you own it + */ +#define FB_EVENT_RESUME 0x03 +/* An entry from the modelist was removed */ +#define FB_EVENT_MODE_DELETE 0x04 +/* A driver registered itself */ +#define FB_EVENT_FB_REGISTERED 0x05 +/* A driver unregistered itself */ +#define FB_EVENT_FB_UNREGISTERED 0x06 +/* CONSOLE-SPECIFIC: get console to framebuffer mapping */ +#define FB_EVENT_GET_CONSOLE_MAP 0x07 +/* CONSOLE-SPECIFIC: set console to framebuffer mapping */ +#define FB_EVENT_SET_CONSOLE_MAP 0x08 +/* A hardware display blank change occured */ +#define FB_EVENT_BLANK 0x09 +/* Private modelist is to be replaced */ +#define FB_EVENT_NEW_MODELIST 0x0A +/* The resolution of the passed in fb_info about to change and + all vc's should be changed */ +#define FB_EVENT_MODE_CHANGE_ALL 0x0B +/* A software display blank change occured */ +#define FB_EVENT_CONBLANK 0x0C +/* Get drawing requirements */ +#define FB_EVENT_GET_REQ 0x0D +/* Unbind from the console if possible */ +#define FB_EVENT_FB_UNBIND 0x0E + +struct fb_event { + struct fb_info *info; + void *data; +}; + +struct fb_blit_caps { + u32 x; + u32 y; + u32 len; + u32 flags; +}; + +/* + * Pixmap structure definition + * + * The purpose of this structure is to translate data + * from the hardware independent format of fbdev to what + * format the hardware needs. + */ + +#define FB_PIXMAP_DEFAULT 1 /* used internally by fbcon */ +#define FB_PIXMAP_SYSTEM 2 /* memory is in system RAM */ +#define FB_PIXMAP_IO 4 /* memory is iomapped */ +#define FB_PIXMAP_SYNC 256 /* set if GPU can DMA */ + +struct fb_pixmap { + u8 *addr; /* pointer to memory */ + u32 size; /* size of buffer in bytes */ + u32 offset; /* current offset to buffer */ + u32 buf_align; /* byte alignment of each bitmap */ + u32 scan_align; /* alignment per scanline */ + u32 access_align; /* alignment per read/write (bits) */ + u32 flags; /* see FB_PIXMAP_* */ + u32 blit_x; /* supported bit block dimensions (1-32)*/ + u32 blit_y; /* Format: blit_x = 1 << (width - 1) */ + /* blit_y = 1 << (height - 1) */ + /* if 0, will be set to 0xffffffff (all)*/ + /* access methods */ + void (*writeio)(struct fb_info *info, void *dst, void *src, unsigned int size); + void (*readio) (struct fb_info *info, void *dst, void *src, unsigned int size); +}; + +#ifdef CONFIG_FB_DEFERRED_IO +struct fb_deferred_io { + /* delay between mkwrite and deferred handler */ + unsigned long delay; + struct mutex lock; /* mutex that protects the page list */ + struct list_head pagelist; /* list of touched pages */ + /* callback */ + void (*deferred_io)(struct fb_info *info, struct list_head *pagelist); +}; +#endif + +/* FBINFO_* = fb_info.flags bit flags */ +#define FBINFO_MODULE 0x0001 /* Low-level driver is a module */ +#define FBINFO_HWACCEL_DISABLED 0x0002 + /* When FBINFO_HWACCEL_DISABLED is set: + * Hardware acceleration is turned off. Software implementations + * of required functions (copyarea(), fillrect(), and imageblit()) + * takes over; acceleration engine should be in a quiescent state */ + +/* hints */ +#define FBINFO_PARTIAL_PAN_OK 0x0040 /* otw use pan only for double-buffering */ +#define FBINFO_READS_FAST 0x0080 /* soft-copy faster than rendering */ + +/* + * A driver may set this flag to indicate that it does want a set_par to be + * called every time when fbcon_switch is executed. The advantage is that with + * this flag set you can really be sure that set_par is always called before + * any of the functions dependant on the correct hardware state or altering + * that state, even if you are using some broken X releases. The disadvantage + * is that it introduces unwanted delays to every console switch if set_par + * is slow. It is a good idea to try this flag in the drivers initialization + * code whenever there is a bug report related to switching between X and the + * framebuffer console. + */ +#define FBINFO_MISC_ALWAYS_SETPAR 0x40000 + +/* + * Host and GPU endianness differ. + */ +#define FBINFO_FOREIGN_ENDIAN 0x100000 +/* + * Big endian math. This is the same flags as above, but with different + * meaning, it is set by the fb subsystem depending FOREIGN_ENDIAN flag + * and host endianness. Drivers should not use this flag. + */ +#define FBINFO_BE_MATH 0x100000 + +struct fb_info { + int node; + int flags; + struct fb_var_screeninfo var; /* Current var */ + struct fb_fix_screeninfo fix; /* Current fix */ + struct fb_monspecs monspecs; /* Current Monitor specs */ + struct fb_pixmap pixmap; /* Image hardware mapper */ + struct fb_pixmap sprite; /* Cursor hardware mapper */ + struct fb_cmap cmap; /* Current cmap */ + struct list_head modelist; /* mode list */ + struct fb_videomode *mode; /* current mode */ + + char *screen_base; /* Virtual address */ + unsigned long screen_size; /* Amount of ioremapped VRAM or 0 */ + void *pseudo_palette; /* Fake palette of 16 colors */ +#define FBINFO_STATE_RUNNING 0 +#define FBINFO_STATE_SUSPENDED 1 + u32 state; /* Hardware state i.e suspend */ + void *fbcon_par; /* fbcon use-only private area */ + /* From here on everything is device dependent */ + void *par; +}; + +#define FBINFO_DEFAULT 0 + +#define FBINFO_FLAG_MODULE FBINFO_MODULE +#define FBINFO_FLAG_DEFAULT FBINFO_DEFAULT + +// This will go away +#if defined(__sparc__) + +/* We map all of our framebuffers such that big-endian accesses + * are what we want, so the following is sufficient. + */ + +// This will go away +#define fb_readb sbus_readb +#define fb_readw sbus_readw +#define fb_readl sbus_readl +#define fb_readq sbus_readq +#define fb_writeb sbus_writeb +#define fb_writew sbus_writew +#define fb_writel sbus_writel +#define fb_writeq sbus_writeq +#define fb_memset sbus_memset_io + +#elif defined(__i386__) || defined(__alpha__) || defined(__x86_64__) || defined(__hppa__) || defined(__sh__) || defined(__powerpc__) || defined(__avr32__) || defined(__bfin__) + +#define fb_readb __raw_readb +#define fb_readw __raw_readw +#define fb_readl __raw_readl +#define fb_readq __raw_readq +#define fb_writeb __raw_writeb +#define fb_writew __raw_writew +#define fb_writel __raw_writel +#define fb_writeq __raw_writeq +#define fb_memset memset_io + +#else + +#define fb_readb(addr) (*(volatile u8 *) (addr)) +#define fb_readw(addr) (*(volatile u16 *) (addr)) +#define fb_readl(addr) (*(volatile u32 *) (addr)) +#define fb_readq(addr) (*(volatile u64 *) (addr)) +#define fb_writeb(b,addr) (*(volatile u8 *) (addr) = (b)) +#define fb_writew(b,addr) (*(volatile u16 *) (addr) = (b)) +#define fb_writel(b,addr) (*(volatile u32 *) (addr) = (b)) +#define fb_writeq(b,addr) (*(volatile u64 *) (addr) = (b)) +#define fb_memset memset + +#endif + +#define FB_LEFT_POS(p, bpp) (fb_be_math(p) ? (32 - (bpp)) : 0) +#define FB_SHIFT_HIGH(p, val, bits) (fb_be_math(p) ? (val) >> (bits) : \ + (val) << (bits)) +#define FB_SHIFT_LOW(p, val, bits) (fb_be_math(p) ? (val) << (bits) : \ + (val) >> (bits)) +/* drivers/video/fbmon.c */ +#define FB_MAXTIMINGS 0 +#define FB_VSYNCTIMINGS 1 +#define FB_HSYNCTIMINGS 2 +#define FB_DCLKTIMINGS 3 +#define FB_IGNOREMON 0x100 + +#define FB_MODE_IS_UNKNOWN 0 +#define FB_MODE_IS_DETAILED 1 +#define FB_MODE_IS_STANDARD 2 +#define FB_MODE_IS_VESA 4 +#define FB_MODE_IS_CALCULATED 8 +#define FB_MODE_IS_FIRST 16 +#define FB_MODE_IS_FROM_VAR 32 + + +/* drivers/video/fbcmap.c */ + +extern int fb_alloc_cmap(struct fb_cmap *cmap, int len, int transp); +extern void fb_dealloc_cmap(struct fb_cmap *cmap); +extern int fb_copy_cmap(const struct fb_cmap *from, struct fb_cmap *to); +extern int fb_cmap_to_user(const struct fb_cmap *from, struct fb_cmap_user *to); +extern int fb_set_cmap(struct fb_cmap *cmap, struct fb_info *fb_info); +extern int fb_set_user_cmap(struct fb_cmap_user *cmap, struct fb_info *fb_info); +extern const struct fb_cmap *fb_default_cmap(int len); +extern void fb_invert_cmaps(void); + +struct fb_videomode { + const char *name; /* optional */ + u32 refresh; /* optional */ + u32 xres; + u32 yres; + u32 pixclock; + u32 left_margin; + u32 right_margin; + u32 upper_margin; + u32 lower_margin; + u32 hsync_len; + u32 vsync_len; + u32 sync; + u32 vmode; + u32 flag; +}; + +#endif /* __KERNEL__ */ + +#endif /* _LINUX_FB_H */
The patch is a porting of the IPU Linux driver developed by Freescale to have framebuffer functionalities in u-boot. Most features are dropped from the original driver and only LCD support is the goal of this porting.
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx51/crm_regs.h | 11 + drivers/video/ipu.h | 316 +++++++ drivers/video/ipu_common.c | 1181 +++++++++++++++++++++++++ drivers/video/ipu_disp.c | 1357 +++++++++++++++++++++++++++++ drivers/video/ipu_regs.h | 418 +++++++++ 5 files changed, 3283 insertions(+), 0 deletions(-) create mode 100644 drivers/video/ipu.h create mode 100644 drivers/video/ipu_common.c create mode 100644 drivers/video/ipu_disp.c create mode 100644 drivers/video/ipu_regs.h
diff --git a/arch/arm/include/asm/arch-mx51/crm_regs.h b/arch/arm/include/asm/arch-mx51/crm_regs.h index 14aa231..4ed8eb3 100644 --- a/arch/arm/include/asm/arch-mx51/crm_regs.h +++ b/arch/arm/include/asm/arch-mx51/crm_regs.h @@ -189,4 +189,15 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0 #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x7
+/* Define the bits in register CCDR */ +#define MXC_CCM_CCDR_IPU_HS_MASK (0x1 << 17) + +/* Define the bits in register CCGRx */ +#define MXC_CCM_CCGR_CG_MASK 0x3 + +#define MXC_CCM_CCGR5_CG5_OFFSET 10 + +/* Define the bits in register CLPCR */ +#define MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS (0x1 << 18) + #endif /* __ARCH_ARM_MACH_MX51_CRM_REGS_H__ */ diff --git a/drivers/video/ipu.h b/drivers/video/ipu.h new file mode 100644 index 0000000..30bef8f --- /dev/null +++ b/drivers/video/ipu.h @@ -0,0 +1,316 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_IPU_H__ +#define __ASM_ARCH_IPU_H__ + +#include <linux/types.h> + +typedef unsigned char bool; +#define true 1 +#define false 0 + +#define IDMA_CHAN_INVALID 0xFF +#define HIGH_RESOLUTION_WIDTH 1024 + +struct clk { + const char *name; + int id; + /* Source clock this clk depends on */ + struct clk *parent; + /* Secondary clock to enable/disable with this clock */ + struct clk *secondary; + /* Current clock rate */ + unsigned long rate; + /* Reference count of clock enable/disable */ + __s8 usecount; + /* Register bit position for clock's enable/disable control. */ + u8 enable_shift; + /* Register address for clock's enable/disable control. */ + void *enable_reg; + u32 flags; + /* Function ptr to recalculate the clock's rate based on parent + clock's rate */ + void (*recalc) (struct clk *); + /* Function ptr to set the clock to a new rate. The rate must match a + supported rate returned from round_rate. Leave blank if clock is not + programmable */ + int (*set_rate) (struct clk *, unsigned long); + /* Function ptr to round the requested clock rate to the nearest + supported rate that is less than or equal to the requested rate. */ + unsigned long (*round_rate) (struct clk *, unsigned long); + /* Function ptr to enable the clock. Leave blank if clock can not + be gated. */ + int (*enable) (struct clk *); + /* Function ptr to disable the clock. Leave blank if clock can not + be gated. */ + void (*disable) (struct clk *); + /* Function ptr to set the parent clock of the clock. */ + int (*set_parent) (struct clk *, struct clk *); +}; + +/* + * Enumeration of Synchronous (Memory-less) panel types + */ +typedef enum { + IPU_PANEL_SHARP_TFT, + IPU_PANEL_TFT, +} ipu_panel_t; + +/* IPU Pixel format definitions */ +#define fourcc(a, b, c, d)\ + (((__u32)(a)<<0)|((__u32)(b)<<8)|((__u32)(c)<<16)|((__u32)(d)<<24)) + +/* + * Pixel formats are defined with ASCII FOURCC code. The pixel format codes are + * the same used by V4L2 API. + */ + +#define IPU_PIX_FMT_GENERIC fourcc('I', 'P', 'U', '0') +#define IPU_PIX_FMT_GENERIC_32 fourcc('I', 'P', 'U', '1') +#define IPU_PIX_FMT_LVDS666 fourcc('L', 'V', 'D', '6') +#define IPU_PIX_FMT_LVDS888 fourcc('L', 'V', 'D', '8') + +#define IPU_PIX_FMT_RGB332 fourcc('R', 'G', 'B', '1') /*< 8 RGB-3-3-2 */ +#define IPU_PIX_FMT_RGB555 fourcc('R', 'G', 'B', 'O') /*< 16 RGB-5-5-5 */ +#define IPU_PIX_FMT_RGB565 fourcc('R', 'G', 'B', 'P') /*< 1 6 RGB-5-6-5 */ +#define IPU_PIX_FMT_RGB666 fourcc('R', 'G', 'B', '6') /*< 18 RGB-6-6-6 */ +#define IPU_PIX_FMT_BGR666 fourcc('B', 'G', 'R', '6') /*< 18 BGR-6-6-6 */ +#define IPU_PIX_FMT_BGR24 fourcc('B', 'G', 'R', '3') /*< 24 BGR-8-8-8 */ +#define IPU_PIX_FMT_RGB24 fourcc('R', 'G', 'B', '3') /*< 24 RGB-8-8-8 */ +#define IPU_PIX_FMT_BGR32 fourcc('B', 'G', 'R', '4') /*< 32 BGR-8-8-8-8 */ +#define IPU_PIX_FMT_BGRA32 fourcc('B', 'G', 'R', 'A') /*< 32 BGR-8-8-8-8 */ +#define IPU_PIX_FMT_RGB32 fourcc('R', 'G', 'B', '4') /*< 32 RGB-8-8-8-8 */ +#define IPU_PIX_FMT_RGBA32 fourcc('R', 'G', 'B', 'A') /*< 32 RGB-8-8-8-8 */ +#define IPU_PIX_FMT_ABGR32 fourcc('A', 'B', 'G', 'R') /*< 32 ABGR-8-8-8-8 */ + +/* YUV Interleaved Formats */ +#define IPU_PIX_FMT_YUYV fourcc('Y', 'U', 'Y', 'V') /*< 16 YUV 4:2:2 */ +#define IPU_PIX_FMT_UYVY fourcc('U', 'Y', 'V', 'Y') /*< 16 YUV 4:2:2 */ +#define IPU_PIX_FMT_Y41P fourcc('Y', '4', '1', 'P') /*< 12 YUV 4:1:1 */ +#define IPU_PIX_FMT_YUV444 fourcc('Y', '4', '4', '4') /*< 24 YUV 4:4:4 */ + +/* two planes -- one Y, one Cb + Cr interleaved */ +#define IPU_PIX_FMT_NV12 fourcc('N', 'V', '1', '2') /* 12 Y/CbCr 4:2:0 */ + +/* @} */ +/* @name YUV Planar Formats */ +/* @{ */ +#define IPU_PIX_FMT_GREY fourcc('G', 'R', 'E', 'Y') /*< 8 Greyscale */ +#define IPU_PIX_FMT_YVU410P fourcc('Y', 'V', 'U', '9') /*< 9 YVU 4:1:0 */ +#define IPU_PIX_FMT_YUV410P fourcc('Y', 'U', 'V', '9') /*< 9 YUV 4:1:0 */ +#define IPU_PIX_FMT_YVU420P fourcc('Y', 'V', '1', '2') /*< 12 YVU 4:2:0 */ +#define IPU_PIX_FMT_YUV420P fourcc('I', '4', '2', '0') /*< 12 YUV 4:2:0 */ +#define IPU_PIX_FMT_YUV420P2 fourcc('Y', 'U', '1', '2') /*< 12 YUV 4:2:0 */ +#define IPU_PIX_FMT_YVU422P fourcc('Y', 'V', '1', '6') /*< 16 YVU 4:2:2 */ +#define IPU_PIX_FMT_YUV422P fourcc('4', '2', '2', 'P') /*< 16 YUV 4:2:2 */ + +/* IPU Driver channels definitions. */ +/* Note these are different from IDMA channels */ +#define IPU_MAX_CH 32 +#define _MAKE_CHAN(num, v_in, g_in, a_in, out) \ + ((num << 24) | (v_in << 18) | (g_in << 12) | (a_in << 6) | out) +#define _MAKE_ALT_CHAN(ch) (ch | (IPU_MAX_CH << 24)) +#define IPU_CHAN_ID(ch) (ch >> 24) +#define IPU_CHAN_ALT(ch) (ch & 0x02000000) +#define IPU_CHAN_ALPHA_IN_DMA(ch) ((uint32_t) (ch >> 6) & 0x3F) +#define IPU_CHAN_GRAPH_IN_DMA(ch) ((uint32_t) (ch >> 12) & 0x3F) +#define IPU_CHAN_VIDEO_IN_DMA(ch) ((uint32_t) (ch >> 18) & 0x3F) +#define IPU_CHAN_OUT_DMA(ch) ((uint32_t) (ch & 0x3F)) +#define NO_DMA 0x3F +#define ALT 1 + +/* + * Enumeration of IPU logical channels. An IPU logical channel is defined as a + * combination of an input (memory to IPU), output (IPU to memory), and/or + * secondary input IDMA channels and in some cases an Image Converter task. + * Some channels consist of only an input or output. + */ +typedef enum { + CHAN_NONE = -1, + + MEM_DC_SYNC = _MAKE_CHAN(7, 28, NO_DMA, NO_DMA, NO_DMA), + MEM_DC_ASYNC = _MAKE_CHAN(8, 41, NO_DMA, NO_DMA, NO_DMA), + MEM_BG_SYNC = _MAKE_CHAN(9, 23, NO_DMA, 51, NO_DMA), + MEM_FG_SYNC = _MAKE_CHAN(10, 27, NO_DMA, 31, NO_DMA), + + MEM_BG_ASYNC0 = _MAKE_CHAN(11, 24, NO_DMA, 52, NO_DMA), + MEM_FG_ASYNC0 = _MAKE_CHAN(12, 29, NO_DMA, 33, NO_DMA), + MEM_BG_ASYNC1 = _MAKE_ALT_CHAN(MEM_BG_ASYNC0), + MEM_FG_ASYNC1 = _MAKE_ALT_CHAN(MEM_FG_ASYNC0), + + DIRECT_ASYNC0 = _MAKE_CHAN(13, NO_DMA, NO_DMA, NO_DMA, NO_DMA), + DIRECT_ASYNC1 = _MAKE_CHAN(14, NO_DMA, NO_DMA, NO_DMA, NO_DMA), + +} ipu_channel_t; + +/* + * Enumeration of types of buffers for a logical channel. + */ +typedef enum { + IPU_OUTPUT_BUFFER = 0, /*< Buffer for output from IPU */ + IPU_ALPHA_IN_BUFFER = 1, /*< Buffer for input to IPU */ + IPU_GRAPH_IN_BUFFER = 2, /*< Buffer for input to IPU */ + IPU_VIDEO_IN_BUFFER = 3, /*< Buffer for input to IPU */ + IPU_INPUT_BUFFER = IPU_VIDEO_IN_BUFFER, + IPU_SEC_INPUT_BUFFER = IPU_GRAPH_IN_BUFFER, +} ipu_buffer_t; + +#define IPU_PANEL_SERIAL 1 +#define IPU_PANEL_PARALLEL 2 + +struct ipu_channel { + u8 video_in_dma; + u8 alpha_in_dma; + u8 graph_in_dma; + u8 out_dma; +}; + +enum ipu_dmfc_type { + DMFC_NORMAL = 0, + DMFC_HIGH_RESOLUTION_DC, + DMFC_HIGH_RESOLUTION_DP, + DMFC_HIGH_RESOLUTION_ONLY_DP, +}; + + +/* + * Union of initialization parameters for a logical channel. + */ +typedef union { + struct { + uint32_t di; + bool interlaced; + } mem_dc_sync; + struct { + uint32_t temp; + } mem_sdc_fg; + struct { + uint32_t di; + bool interlaced; + uint32_t in_pixel_fmt; + uint32_t out_pixel_fmt; + bool alpha_chan_en; + } mem_dp_bg_sync; + struct { + uint32_t temp; + } mem_sdc_bg; + struct { + uint32_t di; + bool interlaced; + uint32_t in_pixel_fmt; + uint32_t out_pixel_fmt; + bool alpha_chan_en; + } mem_dp_fg_sync; +} ipu_channel_params_t; + +/* + * Bitfield of Display Interface signal polarities. + */ +typedef struct { + unsigned datamask_en:1; + unsigned ext_clk:1; + unsigned interlaced:1; + unsigned odd_field_first:1; + unsigned clksel_en:1; + unsigned clkidle_en:1; + unsigned data_pol:1; /* true = inverted */ + unsigned clk_pol:1; /* true = rising edge */ + unsigned enable_pol:1; + unsigned Hsync_pol:1; /* true = active high */ + unsigned Vsync_pol:1; +} ipu_di_signal_cfg_t; + +typedef enum { + RGB, + YCbCr, + YUV +} ipu_color_space_t; + +/* Common IPU API */ +int32_t ipu_init_channel(ipu_channel_t channel, ipu_channel_params_t *params); +void ipu_uninit_channel(ipu_channel_t channel); + +int32_t ipu_init_channel_buffer(ipu_channel_t channel, ipu_buffer_t type, + uint32_t pixel_fmt, + uint16_t width, uint16_t height, + uint32_t stride, + dma_addr_t phyaddr_0, dma_addr_t phyaddr_1, + uint32_t u_offset, uint32_t v_offset); + +int32_t ipu_update_channel_buffer(ipu_channel_t channel, ipu_buffer_t type, + uint32_t bufNum, dma_addr_t phyaddr); + +int32_t ipu_is_channel_busy(ipu_channel_t channel); +void ipu_clear_buffer_ready(ipu_channel_t channel, ipu_buffer_t type, + uint32_t bufNum); +int32_t ipu_enable_channel(ipu_channel_t channel); +int32_t ipu_disable_channel(ipu_channel_t channel); + +int32_t ipu_init_sync_panel(int disp, + uint32_t pixel_clk, + uint16_t width, uint16_t height, + uint32_t pixel_fmt, + uint16_t h_start_width, uint16_t h_sync_width, + uint16_t h_end_width, uint16_t v_start_width, + uint16_t v_sync_width, uint16_t v_end_width, + uint32_t v_to_h_sync, ipu_di_signal_cfg_t sig); + +int32_t ipu_disp_set_global_alpha(ipu_channel_t channel, bool enable, + uint8_t alpha); +int32_t ipu_disp_set_color_key(ipu_channel_t channel, bool enable, + uint32_t colorKey); + +uint32_t bytes_per_pixel(uint32_t fmt); + +void clk_enable(struct clk *clk); +void clk_disable(struct clk *clk); +u32 clk_get_rate(struct clk *clk); +int clk_set_rate(struct clk *clk, unsigned long rate); +long clk_round_rate(struct clk *clk, unsigned long rate); +int clk_set_parent(struct clk *clk, struct clk *parent); +int clk_get_usecount(struct clk *clk); +struct clk *clk_get_parent(struct clk *clk); + +void ipu_dump_registers(void); +int ipu_probe(void); + +void ipu_dmfc_init(int dmfc_type, int first); +void ipu_init_dc_mappings(void); +void ipu_dmfc_set_wait4eot(int dma_chan, int width); +void ipu_dc_init(int dc_chan, int di, bool interlaced); +void ipu_dc_uninit(int dc_chan); +void ipu_dp_dc_enable(ipu_channel_t channel); +int ipu_dp_init(ipu_channel_t channel, uint32_t in_pixel_fmt, + uint32_t out_pixel_fmt); +void ipu_dp_uninit(ipu_channel_t channel); +void ipu_dp_dc_disable(ipu_channel_t channel, bool swap); +ipu_color_space_t format_to_colorspace(uint32_t fmt); + +#endif diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c new file mode 100644 index 0000000..e153781 --- /dev/null +++ b/drivers/video/ipu_common.c @@ -0,0 +1,1181 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ +#include <common.h> +#include <linux/types.h> +#include <linux/err.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include "ipu.h" +#include "ipu_regs.h" + +extern struct mxc_ccm_reg *mxc_ccm; +extern u32 *ipu_cpmem_base; + +struct ipu_ch_param_word { + uint32_t data[5]; + uint32_t res[3]; +}; + +struct ipu_ch_param { + struct ipu_ch_param_word word[2]; +}; + +#define ipu_ch_param_addr(ch) (((struct ipu_ch_param *)ipu_cpmem_base) + (ch)) + +#define _param_word(base, w) \ + (((struct ipu_ch_param *)(base))->word[(w)].data) + +#define ipu_ch_param_set_field(base, w, bit, size, v) { \ + int i = (bit) / 32; \ + int off = (bit) % 32; \ + _param_word(base, w)[i] |= (v) << off; \ + if (((bit) + (size) - 1) / 32 > i) { \ + _param_word(base, w)[i + 1] |= (v) >> (off ? (32 - off) : 0); \ + } \ +} + +#define ipu_ch_param_mod_field(base, w, bit, size, v) { \ + int i = (bit) / 32; \ + int off = (bit) % 32; \ + u32 mask = (1UL << size) - 1; \ + u32 temp = _param_word(base, w)[i]; \ + temp &= ~(mask << off); \ + _param_word(base, w)[i] = temp | (v) << off; \ + if (((bit) + (size) - 1) / 32 > i) { \ + temp = _param_word(base, w)[i + 1]; \ + temp &= ~(mask >> (32 - off)); \ + _param_word(base, w)[i + 1] = \ + temp | ((v) >> (off ? (32 - off) : 0)); \ + } \ +} + +#define ipu_ch_param_read_field(base, w, bit, size) ({ \ + u32 temp2; \ + int i = (bit) / 32; \ + int off = (bit) % 32; \ + u32 mask = (1UL << size) - 1; \ + u32 temp1 = _param_word(base, w)[i]; \ + temp1 = mask & (temp1 >> off); \ + if (((bit)+(size) - 1) / 32 > i) { \ + temp2 = _param_word(base, w)[i + 1]; \ + temp2 &= mask >> (off ? (32 - off) : 0); \ + temp1 |= temp2 << (off ? (32 - off) : 0); \ + } \ + temp1; \ +}) + + +void clk_enable(struct clk *clk) +{ + if (clk) { + if (clk->usecount++ == 0) { + clk->enable(clk); + } + } +} + +void clk_disable(struct clk *clk) +{ + if (clk) { + if (!(--clk->usecount)) { + if (clk->disable) + clk->disable(clk); + } + } +} + +int clk_get_usecount(struct clk *clk) +{ + if (clk == NULL) + return 0; + + return clk->usecount; +} + +u32 clk_get_rate(struct clk *clk) +{ + if (!clk) + return 0; + + return clk->rate; +} + +struct clk *clk_get_parent(struct clk *clk) +{ + if (!clk) + return 0; + + return clk->parent; +} + +int clk_set_rate(struct clk *clk, unsigned long rate) +{ + if (clk && clk->set_rate) + clk->set_rate(clk, rate); + return clk->rate; +} + +long clk_round_rate(struct clk *clk, unsigned long rate) +{ + if (clk == NULL || !clk->round_rate) + return 0; + + return clk->round_rate(clk, rate); +} + +int clk_set_parent(struct clk *clk, struct clk *parent) +{ + clk->parent = parent; + if (clk->set_parent) + return clk->set_parent(clk, parent); + return 0; +} + +static int clk_ipu_enable(struct clk *clk) +{ + u32 reg; + + reg = __raw_readl(clk->enable_reg); + reg |= MXC_CCM_CCGR_CG_MASK << clk->enable_shift; + __raw_writel(reg, clk->enable_reg); + + /* Handshake with IPU when certain clock rates are changed. */ + reg = __raw_readl(&mxc_ccm->ccdr); + reg &= ~MXC_CCM_CCDR_IPU_HS_MASK; + __raw_writel(reg, &mxc_ccm->ccdr); + + /* Handshake with IPU when LPM is entered as its enabled. */ + reg = __raw_readl(&mxc_ccm->clpcr); + reg &= ~MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS; + __raw_writel(reg, &mxc_ccm->clpcr); + + return 0; +} + +static void clk_ipu_disable(struct clk *clk) +{ + u32 reg; + + reg = __raw_readl(clk->enable_reg); + reg &= ~(MXC_CCM_CCGR_CG_MASK << clk->enable_shift); + __raw_writel(reg, clk->enable_reg); + + /* No handshake with IPU whe dividers are changed + * as its not enabled. */ + reg = __raw_readl(&mxc_ccm->ccdr); + reg |= MXC_CCM_CCDR_IPU_HS_MASK; + __raw_writel(reg, &mxc_ccm->ccdr); + + /* No handshake with IPU when LPM is entered as its not enabled. */ + reg = __raw_readl(&mxc_ccm->clpcr); + reg |= MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS; + __raw_writel(reg, &mxc_ccm->clpcr); +} + + +static struct clk ipu_clk = { + .name = "ipu_clk", + .rate = 133000000, + .enable_reg = (u32 *)(MXC_CCM_BASE + + offsetof(struct mxc_ccm_reg, CCGR5)), + .enable_shift = MXC_CCM_CCGR5_CG5_OFFSET, + .enable = clk_ipu_enable, + .disable = clk_ipu_disable, + .usecount = 0, +}; + +/* Globals */ +struct clk *g_ipu_clk; +bool g_ipu_clk_enabled; +struct clk *g_di_clk[2]; +struct clk *g_pixel_clk[2]; +unsigned char g_dc_di_assignment[10]; +uint32_t g_channel_init_mask; +uint32_t g_channel_enable_mask; + +static int ipu_dc_use_count; +static int ipu_dp_use_count; +static int ipu_dmfc_use_count; +static int ipu_di_use_count[2]; + +u32 *ipu_cpmem_base; +u32 *ipu_dc_tmpl_reg; + +/* Static functions */ + +static inline void ipu_ch_param_set_high_priority(uint32_t ch) +{ + ipu_ch_param_mod_field(ipu_ch_param_addr(ch), 1, 93, 2, 1); +}; + +static inline uint32_t channel_2_dma(ipu_channel_t ch, ipu_buffer_t type) +{ + return ((uint32_t) ch >> (6 * type)) & 0x3F; +}; + +/* Either DP BG or DP FG can be graphic window */ +static inline int ipu_is_dp_graphic_chan(uint32_t dma_chan) +{ + return (dma_chan == 23 || dma_chan == 27); +} + +static inline int ipu_is_dmfc_chan(uint32_t dma_chan) +{ + return ((dma_chan >= 23) && (dma_chan <= 29)); +} + + +static inline void ipu_ch_param_set_buffer(uint32_t ch, int bufNum, + dma_addr_t phyaddr) +{ + ipu_ch_param_mod_field(ipu_ch_param_addr(ch), 1, 29 * bufNum, 29, + phyaddr / 8); +}; + +#define idma_is_valid(ch) (ch != NO_DMA) +#define idma_mask(ch) (idma_is_valid(ch) ? (1UL << (ch & 0x1F)) : 0) +#define idma_is_set(reg, dma) (__raw_readl(reg(dma)) & idma_mask(dma)) + +static void ipu_pixel_clk_recalc(struct clk *clk) +{ + u32 div = __raw_readl(DI_BS_CLKGEN0(clk->id)); + if (div == 0) + clk->rate = 0; + else + clk->rate = (clk->parent->rate * 16) / div; +} + +static unsigned long ipu_pixel_clk_round_rate(struct clk *clk, + unsigned long rate) +{ + u32 div, div1; + u32 tmp; + /* + * Calculate divider + * Fractional part is 4 bits, + * so simply multiply by 2^4 to get fractional part. + */ + tmp = (clk->parent->rate * 16); + div = tmp / rate; + + if (div < 0x10) /* Min DI disp clock divider is 1 */ + div = 0x10; + if (div & ~0xFEF) + div &= 0xFF8; + else { + div1 = div & 0xFE0; + if ((tmp/div1 - tmp/div) < rate / 4) + div = div1; + else + div &= 0xFF8; + } + return (clk->parent->rate * 16) / div; +} + +static int ipu_pixel_clk_set_rate(struct clk *clk, unsigned long rate) +{ + u32 div = (clk->parent->rate * 16) / rate; + + __raw_writel(div, DI_BS_CLKGEN0(clk->id)); + + /* Setup pixel clock timing */ + /* FIXME: needs to be more flexible */ + /* Down time is half of period */ + __raw_writel((div / 16) << 16, DI_BS_CLKGEN1(clk->id)); + + clk->rate = (clk->parent->rate * 16) / div; + return 0; +} + +static int ipu_pixel_clk_enable(struct clk *clk) +{ + u32 disp_gen = __raw_readl(IPU_DISP_GEN); + disp_gen |= clk->id ? DI1_COUNTER_RELEASE : DI0_COUNTER_RELEASE; + __raw_writel(disp_gen, IPU_DISP_GEN); + + return 0; +} + +static void ipu_pixel_clk_disable(struct clk *clk) +{ + u32 disp_gen = __raw_readl(IPU_DISP_GEN); + disp_gen &= clk->id ? ~DI1_COUNTER_RELEASE : ~DI0_COUNTER_RELEASE; + __raw_writel(disp_gen, IPU_DISP_GEN); + +} + +static int ipu_pixel_clk_set_parent(struct clk *clk, struct clk *parent) +{ + u32 di_gen = __raw_readl(DI_GENERAL(clk->id)); + + if (parent == g_ipu_clk) + di_gen &= ~DI_GEN_DI_CLK_EXT; + else if (!IS_ERR(g_di_clk[clk->id]) && parent == g_di_clk[clk->id]) + di_gen |= DI_GEN_DI_CLK_EXT; + else + return -EINVAL; + + __raw_writel(di_gen, DI_GENERAL(clk->id)); + ipu_pixel_clk_recalc(clk); + return 0; +} + +static struct clk pixel_clk[] = { + { + .name = "pixel_clk", + .id = 0, + .recalc = ipu_pixel_clk_recalc, + .set_rate = ipu_pixel_clk_set_rate, + .round_rate = ipu_pixel_clk_round_rate, + .set_parent = ipu_pixel_clk_set_parent, + .enable = ipu_pixel_clk_enable, + .disable = ipu_pixel_clk_disable, + .usecount = 0, + }, + { + .name = "pixel_clk", + .id = 1, + .recalc = ipu_pixel_clk_recalc, + .set_rate = ipu_pixel_clk_set_rate, + .round_rate = ipu_pixel_clk_round_rate, + .set_parent = ipu_pixel_clk_set_parent, + .enable = ipu_pixel_clk_enable, + .disable = ipu_pixel_clk_disable, + .usecount = 0, + }, +}; + +/* + * This function resets IPU + */ +void ipu_reset(void) +{ + u32 *reg; + u32 value; + + reg = (u32 *)SRC_BASE_ADDR; + value = __raw_readl(reg); + value = value | SW_IPU_RST; + __raw_writel(value, reg); +} + +/* + * This function is called by the driver framework to initialize the IPU + * hardware. + * + * @param dev The device structure for the IPU passed in by the + * driver framework. + * + * @return Returns 0 on success or negative error code on error + */ +int ipu_probe(void) +{ + unsigned long ipu_base; + u32 temp; + + u32 *reg_hsc_mcd = (u32 *)MIPI_HSC_BASE_ADDR; + u32 *reg_hsc_mxt_conf = (u32 *)(MIPI_HSC_BASE_ADDR + 0x800); + + __raw_writel(0xF00, reg_hsc_mcd); + + /* CSI mode reserved*/ + temp = __raw_readl(reg_hsc_mxt_conf); + __raw_writel(temp | 0x0FF, reg_hsc_mxt_conf); + + temp = __raw_readl(reg_hsc_mxt_conf); + __raw_writel(temp | 0x10000, reg_hsc_mxt_conf); + + ipu_base = IPU_CTRL_BASE_ADDR; + ipu_cpmem_base = (u32 *)(ipu_base + IPU_CPMEM_REG_BASE); + ipu_dc_tmpl_reg = (u32 *)(ipu_base + IPU_DC_TMPL_REG_BASE); + + g_pixel_clk[0] = &pixel_clk[0]; + g_pixel_clk[1] = &pixel_clk[1]; + + g_ipu_clk = &ipu_clk; + debug("ipu_clk = %u\n", clk_get_rate(g_ipu_clk)); + + ipu_reset(); + + clk_set_parent(g_pixel_clk[0], g_ipu_clk); + clk_set_parent(g_pixel_clk[1], g_ipu_clk); + clk_enable(g_ipu_clk); + + g_di_clk[0] = NULL; + g_di_clk[1] = NULL; + + __raw_writel(0x807FFFFF, IPU_MEM_RST); + while (__raw_readl(IPU_MEM_RST) & 0x80000000) + ; + + ipu_init_dc_mappings(); + + __raw_writel(0, IPU_INT_CTRL(5)); + __raw_writel(0, IPU_INT_CTRL(6)); + __raw_writel(0, IPU_INT_CTRL(9)); + __raw_writel(0, IPU_INT_CTRL(10)); + + /* DMFC Init */ + ipu_dmfc_init(DMFC_NORMAL, 1); + + /* Set sync refresh channels as high priority */ + __raw_writel(0x18800000L, IDMAC_CHA_PRI(0)); + + /* Set MCU_T to divide MCU access window into 2 */ + __raw_writel(0x00400000L | (IPU_MCU_T_DEFAULT << 18), IPU_DISP_GEN); + + clk_disable(g_ipu_clk); + + return 0; +} + +void ipu_dump_registers(void) +{ + debug("IPU_CONF = \t0x%08X\n", __raw_readl(IPU_CONF)); + debug("IDMAC_CONF = \t0x%08X\n", __raw_readl(IDMAC_CONF)); + debug("IDMAC_CHA_EN1 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_EN(0))); + debug("IDMAC_CHA_EN2 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_EN(32))); + debug("IDMAC_CHA_PRI1 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_PRI(0))); + debug("IDMAC_CHA_PRI2 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_PRI(32))); + debug("IPU_CHA_DB_MODE_SEL0 = \t0x%08X\n", + __raw_readl(IPU_CHA_DB_MODE_SEL(0))); + debug("IPU_CHA_DB_MODE_SEL1 = \t0x%08X\n", + __raw_readl(IPU_CHA_DB_MODE_SEL(32))); + debug("DMFC_WR_CHAN = \t0x%08X\n", + __raw_readl(DMFC_WR_CHAN)); + debug("DMFC_WR_CHAN_DEF = \t0x%08X\n", + __raw_readl(DMFC_WR_CHAN_DEF)); + debug("DMFC_DP_CHAN = \t0x%08X\n", + __raw_readl(DMFC_DP_CHAN)); + debug("DMFC_DP_CHAN_DEF = \t0x%08X\n", + __raw_readl(DMFC_DP_CHAN_DEF)); + debug("DMFC_IC_CTRL = \t0x%08X\n", + __raw_readl(DMFC_IC_CTRL)); + debug("IPU_FS_PROC_FLOW1 = \t0x%08X\n", + __raw_readl(IPU_FS_PROC_FLOW1)); + debug("IPU_FS_PROC_FLOW2 = \t0x%08X\n", + __raw_readl(IPU_FS_PROC_FLOW2)); + debug("IPU_FS_PROC_FLOW3 = \t0x%08X\n", + __raw_readl(IPU_FS_PROC_FLOW3)); + debug("IPU_FS_DISP_FLOW1 = \t0x%08X\n", + __raw_readl(IPU_FS_DISP_FLOW1)); +} + +/* + * This function is called to initialize a logical IPU channel. + * + * @param channel Input parameter for the logical channel ID to init. + * + * @param params Input parameter containing union of channel + * initialization parameters. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_init_channel(ipu_channel_t channel, ipu_channel_params_t *params) +{ + int ret = 0; + uint32_t ipu_conf; + + debug("init channel = %d\n", IPU_CHAN_ID(channel)); + + if (g_ipu_clk_enabled == false) { + g_ipu_clk_enabled = true; + clk_enable(g_ipu_clk); + } + + + if (g_channel_init_mask & (1L << IPU_CHAN_ID(channel))) { + printf("Warning: channel already initialized %d\n", + IPU_CHAN_ID(channel)); + } + + ipu_conf = __raw_readl(IPU_CONF); + + switch (channel) { + case MEM_DC_SYNC: + if (params->mem_dc_sync.di > 1) { + ret = -EINVAL; + goto err; + } + + g_dc_di_assignment[1] = params->mem_dc_sync.di; + ipu_dc_init(1, params->mem_dc_sync.di, + params->mem_dc_sync.interlaced); + ipu_di_use_count[params->mem_dc_sync.di]++; + ipu_dc_use_count++; + ipu_dmfc_use_count++; + break; + case MEM_BG_SYNC: + if (params->mem_dp_bg_sync.di > 1) { + ret = -EINVAL; + goto err; + } + + g_dc_di_assignment[5] = params->mem_dp_bg_sync.di; + ipu_dp_init(channel, params->mem_dp_bg_sync.in_pixel_fmt, + params->mem_dp_bg_sync.out_pixel_fmt); + ipu_dc_init(5, params->mem_dp_bg_sync.di, + params->mem_dp_bg_sync.interlaced); + ipu_di_use_count[params->mem_dp_bg_sync.di]++; + ipu_dc_use_count++; + ipu_dp_use_count++; + ipu_dmfc_use_count++; + break; + case MEM_FG_SYNC: + ipu_dp_init(channel, params->mem_dp_fg_sync.in_pixel_fmt, + params->mem_dp_fg_sync.out_pixel_fmt); + + ipu_dc_use_count++; + ipu_dp_use_count++; + ipu_dmfc_use_count++; + break; + default: + printf("Missing channel initialization\n"); + break; + } + + /* Enable IPU sub module */ + g_channel_init_mask |= 1L << IPU_CHAN_ID(channel); + if (ipu_dc_use_count == 1) + ipu_conf |= IPU_CONF_DC_EN; + if (ipu_dp_use_count == 1) + ipu_conf |= IPU_CONF_DP_EN; + if (ipu_dmfc_use_count == 1) + ipu_conf |= IPU_CONF_DMFC_EN; + if (ipu_di_use_count[0] == 1) { + ipu_conf |= IPU_CONF_DI0_EN; + } + if (ipu_di_use_count[1] == 1) { + ipu_conf |= IPU_CONF_DI1_EN; + } + + __raw_writel(ipu_conf, IPU_CONF); + +err: + return ret; +} + +/* + * This function is called to uninitialize a logical IPU channel. + * + * @param channel Input parameter for the logical channel ID to uninit. + */ +void ipu_uninit_channel(ipu_channel_t channel) +{ + uint32_t reg; + uint32_t in_dma, out_dma = 0; + uint32_t ipu_conf; + + if ((g_channel_init_mask & (1L << IPU_CHAN_ID(channel))) == 0) { + debug("Channel already uninitialized %d\n", + IPU_CHAN_ID(channel)); + return; + } + + /* Make sure channel is disabled */ + /* Get input and output dma channels */ + in_dma = channel_2_dma(channel, IPU_OUTPUT_BUFFER); + out_dma = channel_2_dma(channel, IPU_VIDEO_IN_BUFFER); + + if (idma_is_set(IDMAC_CHA_EN, in_dma) || + idma_is_set(IDMAC_CHA_EN, out_dma)) { + printf( + "Channel %d is not disabled, disable first\n", + IPU_CHAN_ID(channel)); + return; + } + + ipu_conf = __raw_readl(IPU_CONF); + + /* Reset the double buffer */ + reg = __raw_readl(IPU_CHA_DB_MODE_SEL(in_dma)); + __raw_writel(reg & ~idma_mask(in_dma), IPU_CHA_DB_MODE_SEL(in_dma)); + reg = __raw_readl(IPU_CHA_DB_MODE_SEL(out_dma)); + __raw_writel(reg & ~idma_mask(out_dma), IPU_CHA_DB_MODE_SEL(out_dma)); + + switch (channel) { + case MEM_DC_SYNC: + ipu_dc_uninit(1); + ipu_di_use_count[g_dc_di_assignment[1]]--; + ipu_dc_use_count--; + ipu_dmfc_use_count--; + break; + case MEM_BG_SYNC: + ipu_dp_uninit(channel); + ipu_dc_uninit(5); + ipu_di_use_count[g_dc_di_assignment[5]]--; + ipu_dc_use_count--; + ipu_dp_use_count--; + ipu_dmfc_use_count--; + break; + case MEM_FG_SYNC: + ipu_dp_uninit(channel); + ipu_dc_use_count--; + ipu_dp_use_count--; + ipu_dmfc_use_count--; + break; + default: + break; + } + + g_channel_init_mask &= ~(1L << IPU_CHAN_ID(channel)); + + if (ipu_dc_use_count == 0) + ipu_conf &= ~IPU_CONF_DC_EN; + if (ipu_dp_use_count == 0) + ipu_conf &= ~IPU_CONF_DP_EN; + if (ipu_dmfc_use_count == 0) + ipu_conf &= ~IPU_CONF_DMFC_EN; + if (ipu_di_use_count[0] == 0) { + ipu_conf &= ~IPU_CONF_DI0_EN; + } + if (ipu_di_use_count[1] == 0) { + ipu_conf &= ~IPU_CONF_DI1_EN; + } + + __raw_writel(ipu_conf, IPU_CONF); + + if (ipu_conf == 0) { + clk_disable(g_ipu_clk); + g_ipu_clk_enabled = false; + } + +} + +static inline void ipu_ch_param_dump(int ch) +{ +#ifdef DEBUG + struct ipu_ch_param *p = ipu_ch_param_addr(ch); + debug("ch %d word 0 - %08X %08X %08X %08X %08X\n", ch, + p->word[0].data[0], p->word[0].data[1], p->word[0].data[2], + p->word[0].data[3], p->word[0].data[4]); + debug("ch %d word 1 - %08X %08X %08X %08X %08X\n", ch, + p->word[1].data[0], p->word[1].data[1], p->word[1].data[2], + p->word[1].data[3], p->word[1].data[4]); + debug("PFS 0x%x, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 85, 4)); + debug("BPP 0x%x, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 0, 107, 3)); + debug("NPB 0x%x\n", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 78, 7)); + + debug("FW %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 0, 125, 13)); + debug("FH %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 0, 138, 12)); + debug("Stride %d\n", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 102, 14)); + + debug("Width0 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 116, 3)); + debug("Width1 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 119, 3)); + debug("Width2 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 122, 3)); + debug("Width3 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 125, 3)); + debug("Offset0 %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 128, 5)); + debug("Offset1 %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 133, 5)); + debug("Offset2 %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 138, 5)); + debug("Offset3 %d\n", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 143, 5)); +#endif +} + +static inline void ipu_ch_params_set_packing(struct ipu_ch_param *p, + int red_width, int red_offset, + int green_width, int green_offset, + int blue_width, int blue_offset, + int alpha_width, int alpha_offset) +{ + /* Setup red width and offset */ + ipu_ch_param_set_field(p, 1, 116, 3, red_width - 1); + ipu_ch_param_set_field(p, 1, 128, 5, red_offset); + /* Setup green width and offset */ + ipu_ch_param_set_field(p, 1, 119, 3, green_width - 1); + ipu_ch_param_set_field(p, 1, 133, 5, green_offset); + /* Setup blue width and offset */ + ipu_ch_param_set_field(p, 1, 122, 3, blue_width - 1); + ipu_ch_param_set_field(p, 1, 138, 5, blue_offset); + /* Setup alpha width and offset */ + ipu_ch_param_set_field(p, 1, 125, 3, alpha_width - 1); + ipu_ch_param_set_field(p, 1, 143, 5, alpha_offset); +} + +static void ipu_ch_param_init(int ch, + uint32_t pixel_fmt, uint32_t width, + uint32_t height, uint32_t stride, + uint32_t u, uint32_t v, + uint32_t uv_stride, dma_addr_t addr0, + dma_addr_t addr1) +{ + uint32_t u_offset = 0; + uint32_t v_offset = 0; + struct ipu_ch_param params; + + memset(¶ms, 0, sizeof(params)); + + ipu_ch_param_set_field(¶ms, 0, 125, 13, width - 1); + + if ((ch == 8) || (ch == 9) || (ch == 10)) { + ipu_ch_param_set_field(¶ms, 0, 138, 12, (height / 2) - 1); + ipu_ch_param_set_field(¶ms, 1, 102, 14, (stride * 2) - 1); + } else { + ipu_ch_param_set_field(¶ms, 0, 138, 12, height - 1); + ipu_ch_param_set_field(¶ms, 1, 102, 14, stride - 1); + } + + ipu_ch_param_set_field(¶ms, 1, 0, 29, addr0 >> 3); + ipu_ch_param_set_field(¶ms, 1, 29, 29, addr1 >> 3); + + switch (pixel_fmt) { + case IPU_PIX_FMT_GENERIC: + /*Represents 8-bit Generic data */ + ipu_ch_param_set_field(¶ms, 0, 107, 3, 5); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 6); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 63); /* burst size */ + + break; + case IPU_PIX_FMT_GENERIC_32: + /*Represents 32-bit Generic data */ + break; + case IPU_PIX_FMT_RGB565: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 3); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 5, 0, 6, 5, 5, 11, 8, 16); + break; + case IPU_PIX_FMT_BGR24: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 1); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 19); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 0, 8, 8, 8, 16, 8, 24); + break; + case IPU_PIX_FMT_RGB24: + case IPU_PIX_FMT_YUV444: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 1); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 19); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 16, 8, 8, 8, 0, 8, 24); + break; + case IPU_PIX_FMT_BGRA32: + case IPU_PIX_FMT_BGR32: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 0); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 8, 8, 16, 8, 24, 8, 0); + break; + case IPU_PIX_FMT_RGBA32: + case IPU_PIX_FMT_RGB32: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 0); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 24, 8, 16, 8, 8, 8, 0); + break; + case IPU_PIX_FMT_ABGR32: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 0); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + + ipu_ch_params_set_packing(¶ms, 8, 0, 8, 8, 8, 16, 8, 24); + break; + case IPU_PIX_FMT_UYVY: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 3); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 0xA); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + break; + case IPU_PIX_FMT_YUYV: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 3); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 0x8); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + break; + case IPU_PIX_FMT_YUV420P2: + case IPU_PIX_FMT_YUV420P: + ipu_ch_param_set_field(¶ms, 1, 85, 4, 2); /* pix format */ + + if (uv_stride < stride / 2) + uv_stride = stride / 2; + + u_offset = stride * height; + v_offset = u_offset + (uv_stride * height / 2); + /* burst size */ + if ((ch == 8) || (ch == 9) || (ch == 10)) { + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); + uv_stride = uv_stride*2; + } else { + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); + } + break; + case IPU_PIX_FMT_YVU422P: + /* BPP & pixel format */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 1); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + + if (uv_stride < stride / 2) + uv_stride = stride / 2; + + v_offset = (v == 0) ? stride * height : v; + u_offset = (u == 0) ? v_offset + v_offset / 2 : u; + break; + case IPU_PIX_FMT_YUV422P: + /* BPP & pixel format */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 1); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + + if (uv_stride < stride / 2) + uv_stride = stride / 2; + + u_offset = (u == 0) ? stride * height : u; + v_offset = (v == 0) ? u_offset + u_offset / 2 : v; + break; + case IPU_PIX_FMT_NV12: + /* BPP & pixel format */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 4); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + uv_stride = stride; + u_offset = (u == 0) ? stride * height : u; + break; + default: + puts("mxc ipu: unimplemented pixel format\n"); + break; + } + + + if (uv_stride) + ipu_ch_param_set_field(¶ms, 1, 128, 14, uv_stride - 1); + + /* Get the uv offset from user when need cropping */ + if (u || v) { + u_offset = u; + v_offset = v; + } + + /* UBO and VBO are 22-bit */ + if (u_offset/8 > 0x3fffff) + puts("The value of U offset exceeds IPU limitation\n"); + if (v_offset/8 > 0x3fffff) + puts("The value of V offset exceeds IPU limitation\n"); + + ipu_ch_param_set_field(¶ms, 0, 46, 22, u_offset / 8); + ipu_ch_param_set_field(¶ms, 0, 68, 22, v_offset / 8); + + debug("initializing idma ch %d @ %p\n", ch, ipu_ch_param_addr(ch)); + memcpy(ipu_ch_param_addr(ch), ¶ms, sizeof(params)); +}; + +/* + * This function is called to initialize a buffer for logical IPU channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @param type Input parameter which buffer to initialize. + * + * @param pixel_fmt Input parameter for pixel format of buffer. + * Pixel format is a FOURCC ASCII code. + * + * @param width Input parameter for width of buffer in pixels. + * + * @param height Input parameter for height of buffer in pixels. + * + * @param stride Input parameter for stride length of buffer + * in pixels. + * + * @param phyaddr_0 Input parameter buffer 0 physical address. + * + * @param phyaddr_1 Input parameter buffer 1 physical address. + * Setting this to a value other than NULL enables + * double buffering mode. + * + * @param u private u offset for additional cropping, + * zero if not used. + * + * @param v private v offset for additional cropping, + * zero if not used. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_init_channel_buffer(ipu_channel_t channel, ipu_buffer_t type, + uint32_t pixel_fmt, + uint16_t width, uint16_t height, + uint32_t stride, + dma_addr_t phyaddr_0, dma_addr_t phyaddr_1, + uint32_t u, uint32_t v) +{ + uint32_t reg; + uint32_t dma_chan; + + dma_chan = channel_2_dma(channel, type); + if (!idma_is_valid(dma_chan)) + return -EINVAL; + + if (stride < width * bytes_per_pixel(pixel_fmt)) + stride = width * bytes_per_pixel(pixel_fmt); + + if (stride % 4) { + printf( + "Stride not 32-bit aligned, stride = %d\n", stride); + return -EINVAL; + } + /* Build parameter memory data for DMA channel */ + ipu_ch_param_init(dma_chan, pixel_fmt, width, height, stride, u, v, 0, + phyaddr_0, phyaddr_1); + + if (ipu_is_dmfc_chan(dma_chan)) { + ipu_dmfc_set_wait4eot(dma_chan, width); + } + + if (idma_is_set(IDMAC_CHA_PRI, dma_chan)) + ipu_ch_param_set_high_priority(dma_chan); + + ipu_ch_param_dump(dma_chan); + + reg = __raw_readl(IPU_CHA_DB_MODE_SEL(dma_chan)); + if (phyaddr_1) + reg |= idma_mask(dma_chan); + else + reg &= ~idma_mask(dma_chan); + __raw_writel(reg, IPU_CHA_DB_MODE_SEL(dma_chan)); + + /* Reset to buffer 0 */ + __raw_writel(idma_mask(dma_chan), IPU_CHA_CUR_BUF(dma_chan)); + + return 0; +} + +/* + * This function enables a logical channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @return This function returns 0 on success or negative error code on + * fail. + */ +int32_t ipu_enable_channel(ipu_channel_t channel) +{ + uint32_t reg; + uint32_t in_dma; + uint32_t out_dma; + + if (g_channel_enable_mask & (1L << IPU_CHAN_ID(channel))) { + printf("Warning: channel already enabled %d\n", + IPU_CHAN_ID(channel)); + } + + /* Get input and output dma channels */ + out_dma = channel_2_dma(channel, IPU_OUTPUT_BUFFER); + in_dma = channel_2_dma(channel, IPU_VIDEO_IN_BUFFER); + + if (idma_is_valid(in_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(in_dma)); + __raw_writel(reg | idma_mask(in_dma), IDMAC_CHA_EN(in_dma)); + } + if (idma_is_valid(out_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(out_dma)); + __raw_writel(reg | idma_mask(out_dma), IDMAC_CHA_EN(out_dma)); + } + + if ((channel == MEM_DC_SYNC) || (channel == MEM_BG_SYNC) || + (channel == MEM_FG_SYNC)) + ipu_dp_dc_enable(channel); + + g_channel_enable_mask |= 1L << IPU_CHAN_ID(channel); + + return 0; +} + +/* + * This function clear buffer ready for a logical channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @param type Input parameter which buffer to clear. + * + * @param bufNum Input parameter for which buffer number clear + * ready state. + * + */ +void ipu_clear_buffer_ready(ipu_channel_t channel, ipu_buffer_t type, + uint32_t bufNum) +{ + uint32_t dma_ch = channel_2_dma(channel, type); + + if (!idma_is_valid(dma_ch)) + return; + + __raw_writel(0xF0000000, IPU_GPR); /* write one to clear */ + if (bufNum == 0) { + if (idma_is_set(IPU_CHA_BUF0_RDY, dma_ch)) { + __raw_writel(idma_mask(dma_ch), + IPU_CHA_BUF0_RDY(dma_ch)); + } + } else { + if (idma_is_set(IPU_CHA_BUF1_RDY, dma_ch)) { + __raw_writel(idma_mask(dma_ch), + IPU_CHA_BUF1_RDY(dma_ch)); + } + } + __raw_writel(0x0, IPU_GPR); /* write one to set */ +} + +/* + * This function disables a logical channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @param wait_for_stop Flag to set whether to wait for channel end + * of frame or return immediately. + * + * @return This function returns 0 on success or negative error code on + * fail. + */ +int32_t ipu_disable_channel(ipu_channel_t channel) +{ + uint32_t reg; + uint32_t in_dma; + uint32_t out_dma; + + if ((g_channel_enable_mask & (1L << IPU_CHAN_ID(channel))) == 0) { + debug("Channel already disabled %d\n", + IPU_CHAN_ID(channel)); + return 0; + } + + /* Get input and output dma channels */ + out_dma = channel_2_dma(channel, IPU_OUTPUT_BUFFER); + in_dma = channel_2_dma(channel, IPU_VIDEO_IN_BUFFER); + + if ((idma_is_valid(in_dma) && + !idma_is_set(IDMAC_CHA_EN, in_dma)) + && (idma_is_valid(out_dma) && + !idma_is_set(IDMAC_CHA_EN, out_dma))) + return -EINVAL; + + if ((channel == MEM_BG_SYNC) || (channel == MEM_FG_SYNC) || + (channel == MEM_DC_SYNC)) { + ipu_dp_dc_disable(channel, false); + } + + /* Disable DMA channel(s) */ + if (idma_is_valid(in_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(in_dma)); + __raw_writel(reg & ~idma_mask(in_dma), IDMAC_CHA_EN(in_dma)); + __raw_writel(idma_mask(in_dma), IPU_CHA_CUR_BUF(in_dma)); + } + if (idma_is_valid(out_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(out_dma)); + __raw_writel(reg & ~idma_mask(out_dma), IDMAC_CHA_EN(out_dma)); + __raw_writel(idma_mask(out_dma), IPU_CHA_CUR_BUF(out_dma)); + } + + g_channel_enable_mask &= ~(1L << IPU_CHAN_ID(channel)); + + /* Set channel buffers NOT to be ready */ + if (idma_is_valid(in_dma)) { + ipu_clear_buffer_ready(channel, IPU_VIDEO_IN_BUFFER, 0); + ipu_clear_buffer_ready(channel, IPU_VIDEO_IN_BUFFER, 1); + } + if (idma_is_valid(out_dma)) { + ipu_clear_buffer_ready(channel, IPU_OUTPUT_BUFFER, 0); + ipu_clear_buffer_ready(channel, IPU_OUTPUT_BUFFER, 1); + } + + return 0; +} + +uint32_t bytes_per_pixel(uint32_t fmt) +{ + switch (fmt) { + case IPU_PIX_FMT_GENERIC: /*generic data */ + case IPU_PIX_FMT_RGB332: + case IPU_PIX_FMT_YUV420P: + case IPU_PIX_FMT_YUV422P: + return 1; + break; + case IPU_PIX_FMT_RGB565: + case IPU_PIX_FMT_YUYV: + case IPU_PIX_FMT_UYVY: + return 2; + break; + case IPU_PIX_FMT_BGR24: + case IPU_PIX_FMT_RGB24: + return 3; + break; + case IPU_PIX_FMT_GENERIC_32: /*generic data */ + case IPU_PIX_FMT_BGR32: + case IPU_PIX_FMT_BGRA32: + case IPU_PIX_FMT_RGB32: + case IPU_PIX_FMT_RGBA32: + case IPU_PIX_FMT_ABGR32: + return 4; + break; + default: + return 1; + break; + } + return 0; +} + +ipu_color_space_t format_to_colorspace(uint32_t fmt) +{ + switch (fmt) { + case IPU_PIX_FMT_RGB666: + case IPU_PIX_FMT_RGB565: + case IPU_PIX_FMT_BGR24: + case IPU_PIX_FMT_RGB24: + case IPU_PIX_FMT_BGR32: + case IPU_PIX_FMT_BGRA32: + case IPU_PIX_FMT_RGB32: + case IPU_PIX_FMT_RGBA32: + case IPU_PIX_FMT_ABGR32: + case IPU_PIX_FMT_LVDS666: + case IPU_PIX_FMT_LVDS888: + return RGB; + break; + + default: + return YCbCr; + break; + } + return RGB; +} diff --git a/drivers/video/ipu_disp.c b/drivers/video/ipu_disp.c new file mode 100644 index 0000000..ab3149d --- /dev/null +++ b/drivers/video/ipu_disp.c @@ -0,0 +1,1357 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ + +#include <common.h> +#include <linux/types.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include "ipu.h" +#include "ipu_regs.h" + +enum csc_type_t { + RGB2YUV = 0, + YUV2RGB, + RGB2RGB, + YUV2YUV, + CSC_NONE, + CSC_NUM +}; + +struct dp_csc_param_t { + int mode; + void *coeff; +}; + +#define SYNC_WAVE 0 + +/* DC display ID assignments */ +#define DC_DISP_ID_SYNC(di) (di) +#define DC_DISP_ID_SERIAL 2 +#define DC_DISP_ID_ASYNC 3 + +int dmfc_type_setup; +static int dmfc_size_28, dmfc_size_29, dmfc_size_24, dmfc_size_27, dmfc_size_23; +int g_di1_tvout; + +extern struct clk *g_ipu_clk; +extern struct clk *g_di_clk[2]; +extern struct clk *g_pixel_clk[2]; + +extern bool g_ipu_clk_enabled; +extern unsigned char g_dc_di_assignment[]; + +void ipu_dmfc_init(int dmfc_type, int first) +{ + u32 dmfc_wr_chan, dmfc_dp_chan; + + if (first) { + if (dmfc_type_setup > dmfc_type) + dmfc_type = dmfc_type_setup; + else + dmfc_type_setup = dmfc_type; + + /* disable DMFC-IC channel*/ + __raw_writel(0x2, DMFC_IC_CTRL); + } else if (dmfc_type_setup >= DMFC_HIGH_RESOLUTION_DC) { + printf("DMFC high resolution has set, will not change\n"); + return; + } else + dmfc_type_setup = dmfc_type; + + if (dmfc_type == DMFC_HIGH_RESOLUTION_DC) { + /* 1 - segment 0~3; + * 5B - segement 4, 5; + * 5F - segement 6, 7; + * 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC DC HIGH RES: 1(0~3), 5B(4,5), 5F(6,7)\n"); + dmfc_wr_chan = 0x00000088; + dmfc_dp_chan = 0x00009694; + dmfc_size_28 = 256 * 4; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 128 * 4; + dmfc_size_23 = 128 * 4; + } else if (dmfc_type == DMFC_HIGH_RESOLUTION_DP) { + /* 1 - segment 0, 1; + * 5B - segement 2~5; + * 5F - segement 6,7; + * 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC DP HIGH RES: 1(0,1), 5B(2~5), 5F(6,7)\n"); + dmfc_wr_chan = 0x00000090; + dmfc_dp_chan = 0x0000968a; + dmfc_size_28 = 128 * 4; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 128 * 4; + dmfc_size_23 = 256 * 4; + } else if (dmfc_type == DMFC_HIGH_RESOLUTION_ONLY_DP) { + /* 5B - segement 0~3; + * 5F - segement 4~7; + * 1, 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC ONLY-DP HIGH RES: 5B(0~3), 5F(4~7)\n"); + dmfc_wr_chan = 0x00000000; + dmfc_dp_chan = 0x00008c88; + dmfc_size_28 = 0; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 256 * 4; + dmfc_size_23 = 256 * 4; + } else { + /* 1 - segment 0, 1; + * 5B - segement 4, 5; + * 5F - segement 6, 7; + * 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)\n"); + dmfc_wr_chan = 0x00000090; + dmfc_dp_chan = 0x00009694; + dmfc_size_28 = 128 * 4; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 128 * 4; + dmfc_size_23 = 128 * 4; + } + __raw_writel(dmfc_wr_chan, DMFC_WR_CHAN); + __raw_writel(0x202020F6, DMFC_WR_CHAN_DEF); + __raw_writel(dmfc_dp_chan, DMFC_DP_CHAN); + /* Enable chan 5 watermark set at 5 bursts and clear at 7 bursts */ + __raw_writel(0x2020F6F6, DMFC_DP_CHAN_DEF); +} + +void ipu_dmfc_set_wait4eot(int dma_chan, int width) +{ + u32 dmfc_gen1 = __raw_readl(DMFC_GENERAL1); + + if (width >= HIGH_RESOLUTION_WIDTH) { + if (dma_chan == 23) + ipu_dmfc_init(DMFC_HIGH_RESOLUTION_DP, 0); + else if (dma_chan == 28) + ipu_dmfc_init(DMFC_HIGH_RESOLUTION_DC, 0); + } + + if (dma_chan == 23) { /*5B*/ + if (dmfc_size_23 / width > 3) + dmfc_gen1 |= 1UL << 20; + else + dmfc_gen1 &= ~(1UL << 20); + } else if (dma_chan == 24) { /*6B*/ + if (dmfc_size_24 / width > 1) + dmfc_gen1 |= 1UL << 22; + else + dmfc_gen1 &= ~(1UL << 22); + } else if (dma_chan == 27) { /*5F*/ + if (dmfc_size_27 / width > 2) + dmfc_gen1 |= 1UL << 21; + else + dmfc_gen1 &= ~(1UL << 21); + } else if (dma_chan == 28) { /*1*/ + if (dmfc_size_28 / width > 2) + dmfc_gen1 |= 1UL << 16; + else + dmfc_gen1 &= ~(1UL << 16); + } else if (dma_chan == 29) { /*6F*/ + if (dmfc_size_29 / width > 1) + dmfc_gen1 |= 1UL << 23; + else + dmfc_gen1 &= ~(1UL << 23); + } + + __raw_writel(dmfc_gen1, DMFC_GENERAL1); +} + +static void ipu_di_data_wave_config(int di, + int wave_gen, + int access_size, int component_size) +{ + u32 reg; + reg = (access_size << DI_DW_GEN_ACCESS_SIZE_OFFSET) | + (component_size << DI_DW_GEN_COMPONENT_SIZE_OFFSET); + __raw_writel(reg, DI_DW_GEN(di, wave_gen)); +} + +static void ipu_di_data_pin_config(int di, int wave_gen, int di_pin, int set, + int up, int down) +{ + u32 reg; + + reg = __raw_readl(DI_DW_GEN(di, wave_gen)); + reg &= ~(0x3 << (di_pin * 2)); + reg |= set << (di_pin * 2); + __raw_writel(reg, DI_DW_GEN(di, wave_gen)); + + __raw_writel((down << 16) | up, DI_DW_SET(di, wave_gen, set)); +} + +static void ipu_di_sync_config(int di, int wave_gen, + int run_count, int run_src, + int offset_count, int offset_src, + int repeat_count, int cnt_clr_src, + int cnt_polarity_gen_en, + int cnt_polarity_clr_src, + int cnt_polarity_trigger_src, + int cnt_up, int cnt_down) +{ + u32 reg; + + if ((run_count >= 0x1000) || (offset_count >= 0x1000) || + (repeat_count >= 0x1000) || + (cnt_up >= 0x400) || (cnt_down >= 0x400)) { + printf("DI%d counters out of range.\n", di); + return; + } + + reg = (run_count << 19) | (++run_src << 16) | + (offset_count << 3) | ++offset_src; + __raw_writel(reg, DI_SW_GEN0(di, wave_gen)); + reg = (cnt_polarity_gen_en << 29) | (++cnt_clr_src << 25) | + (++cnt_polarity_trigger_src << 12) | (++cnt_polarity_clr_src << 9); + reg |= (cnt_down << 16) | cnt_up; + if (repeat_count == 0) { + /* Enable auto reload */ + reg |= 0x10000000; + } + __raw_writel(reg, DI_SW_GEN1(di, wave_gen)); + reg = __raw_readl(DI_STP_REP(di, wave_gen)); + reg &= ~(0xFFFF << (16 * ((wave_gen - 1) & 0x1))); + reg |= repeat_count << (16 * ((wave_gen - 1) & 0x1)); + __raw_writel(reg, DI_STP_REP(di, wave_gen)); +} + +static void ipu_dc_map_config(int map, int byte_num, int offset, int mask) +{ + int ptr = map * 3 + byte_num; + u32 reg; + + reg = __raw_readl(DC_MAP_CONF_VAL(ptr)); + reg &= ~(0xFFFF << (16 * (ptr & 0x1))); + reg |= ((offset << 8) | mask) << (16 * (ptr & 0x1)); + __raw_writel(reg, DC_MAP_CONF_VAL(ptr)); + + reg = __raw_readl(DC_MAP_CONF_PTR(map)); + reg &= ~(0x1F << ((16 * (map & 0x1)) + (5 * byte_num))); + reg |= ptr << ((16 * (map & 0x1)) + (5 * byte_num)); + __raw_writel(reg, DC_MAP_CONF_PTR(map)); +} + +static void ipu_dc_map_clear(int map) +{ + u32 reg = __raw_readl(DC_MAP_CONF_PTR(map)); + __raw_writel(reg & ~(0xFFFF << (16 * (map & 0x1))), + DC_MAP_CONF_PTR(map)); +} + +static void ipu_dc_write_tmpl(int word, u32 opcode, u32 operand, int map, + int wave, int glue, int sync) +{ + u32 reg; + int stop = 1; + + reg = sync; + reg |= (glue << 4); + reg |= (++wave << 11); + reg |= (++map << 15); + reg |= (operand << 20) & 0xFFF00000; + __raw_writel(reg, ipu_dc_tmpl_reg + word * 2); + + reg = (operand >> 12); + reg |= opcode << 4; + reg |= (stop << 9); + __raw_writel(reg, ipu_dc_tmpl_reg + word * 2 + 1); +} + +static void ipu_dc_link_event(int chan, int event, int addr, int priority) +{ + u32 reg; + + reg = __raw_readl(DC_RL_CH(chan, event)); + reg &= ~(0xFFFF << (16 * (event & 0x1))); + reg |= ((addr << 8) | priority) << (16 * (event & 0x1)); + __raw_writel(reg, DC_RL_CH(chan, event)); +} + +/* Y = R * 1.200 + G * 2.343 + B * .453 + 0.250; + U = R * -.672 + G * -1.328 + B * 2.000 + 512.250.; + V = R * 2.000 + G * -1.672 + B * -.328 + 512.250.;*/ +static const int rgb2ycbcr_coeff[5][3] = { + {0x4D, 0x96, 0x1D}, + {0x3D5, 0x3AB, 0x80}, + {0x80, 0x395, 0x3EB}, + {0x0000, 0x0200, 0x0200}, /* B0, B1, B2 */ + {0x2, 0x2, 0x2}, /* S0, S1, S2 */ +}; + +/* R = (1.164 * (Y - 16)) + (1.596 * (Cr - 128)); + G = (1.164 * (Y - 16)) - (0.392 * (Cb - 128)) - (0.813 * (Cr - 128)); + B = (1.164 * (Y - 16)) + (2.017 * (Cb - 128); */ +static const int ycbcr2rgb_coeff[5][3] = { + {0x095, 0x000, 0x0CC}, + {0x095, 0x3CE, 0x398}, + {0x095, 0x0FF, 0x000}, + {0x3E42, 0x010A, 0x3DD6}, /*B0,B1,B2 */ + {0x1, 0x1, 0x1}, /*S0,S1,S2 */ +}; + +#define mask_a(a) ((u32)(a) & 0x3FF) +#define mask_b(b) ((u32)(b) & 0x3FFF) + +/* Pls keep S0, S1 and S2 as 0x2 by using this convertion */ +static int rgb_to_yuv(int n, int red, int green, int blue) +{ + int c; + c = red * rgb2ycbcr_coeff[n][0]; + c += green * rgb2ycbcr_coeff[n][1]; + c += blue * rgb2ycbcr_coeff[n][2]; + c /= 16; + c += rgb2ycbcr_coeff[3][n] * 4; + c += 8; + c /= 16; + if (c < 0) + c = 0; + if (c > 255) + c = 255; + return c; +} + +/* + * Row is for BG: RGB2YUV YUV2RGB RGB2RGB YUV2YUV CSC_NONE + * Column is for FG: RGB2YUV YUV2RGB RGB2RGB YUV2YUV CSC_NONE + */ +static struct dp_csc_param_t dp_csc_array[CSC_NUM][CSC_NUM] = { + { + {DP_COM_CONF_CSC_DEF_BOTH, &rgb2ycbcr_coeff}, + {0, 0}, + {0, 0}, + {DP_COM_CONF_CSC_DEF_BG, &rgb2ycbcr_coeff}, + {DP_COM_CONF_CSC_DEF_BG, &rgb2ycbcr_coeff} + }, + { + {0, 0}, + {DP_COM_CONF_CSC_DEF_BOTH, &ycbcr2rgb_coeff}, + {DP_COM_CONF_CSC_DEF_BG, &ycbcr2rgb_coeff}, + {0, 0}, + {DP_COM_CONF_CSC_DEF_BG, &ycbcr2rgb_coeff} + }, + { + {0, 0}, + {DP_COM_CONF_CSC_DEF_FG, &ycbcr2rgb_coeff}, + {0, 0}, + {0, 0}, + {0, 0} + }, + { + {DP_COM_CONF_CSC_DEF_FG, &rgb2ycbcr_coeff}, + {0, 0}, + {0, 0}, + {0, 0}, + {0, 0} + }, + { + {DP_COM_CONF_CSC_DEF_FG, &rgb2ycbcr_coeff}, + {DP_COM_CONF_CSC_DEF_FG, &ycbcr2rgb_coeff}, + {0, 0}, + {0, 0}, + {0, 0} + } +}; + +static enum csc_type_t fg_csc_type = CSC_NONE, bg_csc_type = CSC_NONE; +static int color_key_4rgb = 1; + +void ipu_dp_csc_setup(int dp, struct dp_csc_param_t dp_csc_param, + bool srm_mode_update) +{ + u32 reg; + const int (*coeff)[5][3]; + + if (dp_csc_param.mode >= 0) { + reg = __raw_readl(DP_COM_CONF(dp)); + reg &= ~DP_COM_CONF_CSC_DEF_MASK; + reg |= dp_csc_param.mode; + __raw_writel(reg, DP_COM_CONF(dp)); + } + + coeff = dp_csc_param.coeff; + + if (coeff) { + __raw_writel(mask_a((*coeff)[0][0]) | + (mask_a((*coeff)[0][1]) << 16), DP_CSC_A_0(dp)); + __raw_writel(mask_a((*coeff)[0][2]) | + (mask_a((*coeff)[1][0]) << 16), DP_CSC_A_1(dp)); + __raw_writel(mask_a((*coeff)[1][1]) | + (mask_a((*coeff)[1][2]) << 16), DP_CSC_A_2(dp)); + __raw_writel(mask_a((*coeff)[2][0]) | + (mask_a((*coeff)[2][1]) << 16), DP_CSC_A_3(dp)); + __raw_writel(mask_a((*coeff)[2][2]) | + (mask_b((*coeff)[3][0]) << 16) | + ((*coeff)[4][0] << 30), DP_CSC_0(dp)); + __raw_writel(mask_b((*coeff)[3][1]) | ((*coeff)[4][1] << 14) | + (mask_b((*coeff)[3][2]) << 16) | + ((*coeff)[4][2] << 30), DP_CSC_1(dp)); + } + + if (srm_mode_update) { + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + } +} + +int ipu_dp_init(ipu_channel_t channel, uint32_t in_pixel_fmt, + uint32_t out_pixel_fmt) +{ + int in_fmt, out_fmt; + int dp; + int partial = false; + uint32_t reg; + + if (channel == MEM_FG_SYNC) { + dp = DP_SYNC; + partial = true; + } else if (channel == MEM_BG_SYNC) { + dp = DP_SYNC; + partial = false; + } else if (channel == MEM_BG_ASYNC0) { + dp = DP_ASYNC0; + partial = false; + } else { + return -EINVAL; + } + + in_fmt = format_to_colorspace(in_pixel_fmt); + out_fmt = format_to_colorspace(out_pixel_fmt); + + if (partial) { + if (in_fmt == RGB) { + if (out_fmt == RGB) + fg_csc_type = RGB2RGB; + else + fg_csc_type = RGB2YUV; + } else { + if (out_fmt == RGB) + fg_csc_type = YUV2RGB; + else + fg_csc_type = YUV2YUV; + } + } else { + if (in_fmt == RGB) { + if (out_fmt == RGB) + bg_csc_type = RGB2RGB; + else + bg_csc_type = RGB2YUV; + } else { + if (out_fmt == RGB) + bg_csc_type = YUV2RGB; + else + bg_csc_type = YUV2YUV; + } + } + + /* Transform color key from rgb to yuv if CSC is enabled */ + reg = __raw_readl(DP_COM_CONF(dp)); + if (color_key_4rgb && (reg & DP_COM_CONF_GWCKE) && + (((fg_csc_type == RGB2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == RGB2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2RGB) && (bg_csc_type == YUV2RGB)))) { + int red, green, blue; + int y, u, v; + uint32_t color_key = __raw_readl(DP_GRAPH_WIND_CTRL(dp)) & + 0xFFFFFFL; + + debug("_ipu_dp_init color key 0x%x need change to yuv fmt!\n", + color_key); + + red = (color_key >> 16) & 0xFF; + green = (color_key >> 8) & 0xFF; + blue = color_key & 0xFF; + + y = rgb_to_yuv(0, red, green, blue); + u = rgb_to_yuv(1, red, green, blue); + v = rgb_to_yuv(2, red, green, blue); + color_key = (y << 16) | (u << 8) | v; + + reg = __raw_readl(DP_GRAPH_WIND_CTRL(dp)) & 0xFF000000L; + __raw_writel(reg | color_key, DP_GRAPH_WIND_CTRL(dp)); + color_key_4rgb = 0; + + debug("_ipu_dp_init color key change to yuv fmt 0x%x!\n", + color_key); + } + + ipu_dp_csc_setup(dp, dp_csc_array[bg_csc_type][fg_csc_type], true); + + return 0; +} + +void ipu_dp_uninit(ipu_channel_t channel) +{ + int dp; + int partial = false; + + if (channel == MEM_FG_SYNC) { + dp = DP_SYNC; + partial = true; + } else if (channel == MEM_BG_SYNC) { + dp = DP_SYNC; + partial = false; + } else if (channel == MEM_BG_ASYNC0) { + dp = DP_ASYNC0; + partial = false; + } else { + return; + } + + if (partial) + fg_csc_type = CSC_NONE; + else + bg_csc_type = CSC_NONE; + + ipu_dp_csc_setup(dp, dp_csc_array[bg_csc_type][fg_csc_type], false); +} + +void ipu_dc_init(int dc_chan, int di, bool interlaced) +{ + u32 reg = 0; + + if ((dc_chan == 1) || (dc_chan == 5)) { + if (interlaced) { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 0, 3); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 0, 2); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, 0, 1); + } else { + if (di) { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 2, 3); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 3, 2); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, + 4, 1); + } else { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 5, 3); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 6, 2); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, + 7, 1); + } + } + ipu_dc_link_event(dc_chan, DC_EVT_NF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR, 0, 0); + + reg = 0x2; + reg |= DC_DISP_ID_SYNC(di) << DC_WR_CH_CONF_PROG_DISP_ID_OFFSET; + reg |= di << 2; + if (interlaced) + reg |= DC_WR_CH_CONF_FIELD_MODE; + } else if ((dc_chan == 8) || (dc_chan == 9)) { + /* async channels */ + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_0, 0x64, 1); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_1, 0x64, 1); + + reg = 0x3; + reg |= DC_DISP_ID_SERIAL << DC_WR_CH_CONF_PROG_DISP_ID_OFFSET; + } + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + + __raw_writel(0x00000000, DC_WR_CH_ADDR(dc_chan)); + + __raw_writel(0x00000084, DC_GEN); +} + +void ipu_dc_uninit(int dc_chan) +{ + if ((dc_chan == 1) || (dc_chan == 5)) { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR, 0, 0); + } else if ((dc_chan == 8) || (dc_chan == 9)) { + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_W_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_W_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_W_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_W_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_R_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_R_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_R_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_R_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_R_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_R_1, 0, 0); + } +} + +int ipu_chan_is_interlaced(ipu_channel_t channel) +{ + if (channel == MEM_DC_SYNC) + return !!(__raw_readl(DC_WR_CH_CONF_1) & + DC_WR_CH_CONF_FIELD_MODE); + else if ((channel == MEM_BG_SYNC) || (channel == MEM_FG_SYNC)) + return !!(__raw_readl(DC_WR_CH_CONF_5) & + DC_WR_CH_CONF_FIELD_MODE); + return 0; +} + +void ipu_dp_dc_enable(ipu_channel_t channel) +{ + int di; + uint32_t reg; + uint32_t dc_chan; + + if (channel == MEM_FG_SYNC) + dc_chan = 5; + if (channel == MEM_DC_SYNC) + dc_chan = 1; + else if (channel == MEM_BG_SYNC) + dc_chan = 5; + else + return; + + if (channel == MEM_FG_SYNC) { + /* Enable FG channel */ + reg = __raw_readl(DP_COM_CONF(DP_SYNC)); + __raw_writel(reg | DP_COM_CONF_FG_EN, DP_COM_CONF(DP_SYNC)); + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + return; + } + + di = g_dc_di_assignment[dc_chan]; + + /* Make sure other DC sync channel is not assigned same DI */ + reg = __raw_readl(DC_WR_CH_CONF(6 - dc_chan)); + if ((di << 2) == (reg & DC_WR_CH_CONF_PROG_DI_ID)) { + reg &= ~DC_WR_CH_CONF_PROG_DI_ID; + reg |= di ? 0 : DC_WR_CH_CONF_PROG_DI_ID; + __raw_writel(reg, DC_WR_CH_CONF(6 - dc_chan)); + } + + reg = __raw_readl(DC_WR_CH_CONF(dc_chan)); + reg |= 4 << DC_WR_CH_CONF_PROG_TYPE_OFFSET; + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + + clk_enable(g_pixel_clk[di]); +} + +static bool dc_swap; + +void ipu_dp_dc_disable(ipu_channel_t channel, bool swap) +{ + uint32_t reg; + uint32_t csc; + uint32_t dc_chan = 0; + int timeout = 50; + + dc_swap = swap; + + if (channel == MEM_DC_SYNC) { + dc_chan = 1; + } else if (channel == MEM_BG_SYNC) { + dc_chan = 5; + } else if (channel == MEM_FG_SYNC) { + /* Disable FG channel */ + dc_chan = 5; + + reg = __raw_readl(DP_COM_CONF(DP_SYNC)); + csc = reg & DP_COM_CONF_CSC_DEF_MASK; + if (csc == DP_COM_CONF_CSC_DEF_FG) + reg &= ~DP_COM_CONF_CSC_DEF_MASK; + + reg &= ~DP_COM_CONF_FG_EN; + __raw_writel(reg, DP_COM_CONF(DP_SYNC)); + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + + timeout = 50; + + /* + * Wait for DC triple buffer to empty, + * this check is useful for tv overlay. + */ + if (g_dc_di_assignment[dc_chan] == 0) + while ((__raw_readl(DC_STAT) & 0x00000002) + != 0x00000002) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + else if (g_dc_di_assignment[dc_chan] == 1) + while ((__raw_readl(DC_STAT) & 0x00000020) + != 0x00000020) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + return; + } else { + return; + } + + if (dc_swap) { + /* Swap DC channel 1 and 5 settings, and disable old dc chan */ + reg = __raw_readl(DC_WR_CH_CONF(dc_chan)); + __raw_writel(reg, DC_WR_CH_CONF(6 - dc_chan)); + reg &= ~DC_WR_CH_CONF_PROG_TYPE_MASK; + reg ^= DC_WR_CH_CONF_PROG_DI_ID; + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + } else { + timeout = 50; + + /* Wait for DC triple buffer to empty */ + if (g_dc_di_assignment[dc_chan] == 0) + while ((__raw_readl(DC_STAT) & 0x00000002) + != 0x00000002) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + else if (g_dc_di_assignment[dc_chan] == 1) + while ((__raw_readl(DC_STAT) & 0x00000020) + != 0x00000020) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + + reg = __raw_readl(DC_WR_CH_CONF(dc_chan)); + reg &= ~DC_WR_CH_CONF_PROG_TYPE_MASK; + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + + reg = __raw_readl(IPU_DISP_GEN); + if (g_dc_di_assignment[dc_chan]) + reg &= ~DI1_COUNTER_RELEASE; + else + reg &= ~DI0_COUNTER_RELEASE; + __raw_writel(reg, IPU_DISP_GEN); + + /* Clock is already off because it must be done quickly, but + we need to fix the ref count */ + clk_disable(g_pixel_clk[g_dc_di_assignment[dc_chan]]); + } +} + +void ipu_init_dc_mappings(void) +{ + /* IPU_PIX_FMT_RGB24 */ + ipu_dc_map_clear(0); + ipu_dc_map_config(0, 0, 7, 0xFF); + ipu_dc_map_config(0, 1, 15, 0xFF); + ipu_dc_map_config(0, 2, 23, 0xFF); + + /* IPU_PIX_FMT_RGB666 */ + ipu_dc_map_clear(1); + ipu_dc_map_config(1, 0, 5, 0xFC); + ipu_dc_map_config(1, 1, 11, 0xFC); + ipu_dc_map_config(1, 2, 17, 0xFC); + + /* IPU_PIX_FMT_YUV444 */ + ipu_dc_map_clear(2); + ipu_dc_map_config(2, 0, 15, 0xFF); + ipu_dc_map_config(2, 1, 23, 0xFF); + ipu_dc_map_config(2, 2, 7, 0xFF); + + /* IPU_PIX_FMT_RGB565 */ + ipu_dc_map_clear(3); + ipu_dc_map_config(3, 0, 4, 0xF8); + ipu_dc_map_config(3, 1, 10, 0xFC); + ipu_dc_map_config(3, 2, 15, 0xF8); + + /* IPU_PIX_FMT_LVDS666 */ + ipu_dc_map_clear(4); + ipu_dc_map_config(4, 0, 5, 0xFC); + ipu_dc_map_config(4, 1, 13, 0xFC); + ipu_dc_map_config(4, 2, 21, 0xFC); +} + +int ipu_pixfmt_to_map(uint32_t fmt) +{ + switch (fmt) { + case IPU_PIX_FMT_GENERIC: + case IPU_PIX_FMT_RGB24: + return 0; + case IPU_PIX_FMT_RGB666: + return 1; + case IPU_PIX_FMT_YUV444: + return 2; + case IPU_PIX_FMT_RGB565: + return 3; + case IPU_PIX_FMT_LVDS666: + return 4; + } + + return -1; +} + +/* + * This function is called to adapt synchronous LCD panel to IPU restriction. + */ +void adapt_panel_to_ipu_restricitions(uint32_t *pixel_clk, + uint16_t width, uint16_t height, + uint16_t h_start_width, + uint16_t h_end_width, + uint16_t v_start_width, + uint16_t *v_end_width) +{ + if (*v_end_width < 2) { + uint16_t total_width = width + h_start_width + h_end_width; + uint16_t total_height_old = height + v_start_width + + (*v_end_width); + uint16_t total_height_new = height + v_start_width + 2; + *v_end_width = 2; + *pixel_clk = (*pixel_clk) * total_width * total_height_new / + (total_width * total_height_old); + printf("WARNING: adapt panel end blank lines\n"); + } +} + +/* + * This function is called to initialize a synchronous LCD panel. + * + * @param disp The DI the panel is attached to. + * + * @param pixel_clk Desired pixel clock frequency in Hz. + * + * @param pixel_fmt Input parameter for pixel format of buffer. + * Pixel format is a FOURCC ASCII code. + * + * @param width The width of panel in pixels. + * + * @param height The height of panel in pixels. + * + * @param hStartWidth The number of pixel clocks between the HSYNC + * signal pulse and the start of valid data. + * + * @param hSyncWidth The width of the HSYNC signal in units of pixel + * clocks. + * + * @param hEndWidth The number of pixel clocks between the end of + * valid data and the HSYNC signal for next line. + * + * @param vStartWidth The number of lines between the VSYNC + * signal pulse and the start of valid data. + * + * @param vSyncWidth The width of the VSYNC signal in units of lines + * + * @param vEndWidth The number of lines between the end of valid + * data and the VSYNC signal for next frame. + * + * @param sig Bitfield of signal polarities for LCD interface. + * + * @return This function returns 0 on success or negative error code on + * fail. + */ + +int32_t ipu_init_sync_panel(int disp, uint32_t pixel_clk, + uint16_t width, uint16_t height, + uint32_t pixel_fmt, + uint16_t h_start_width, uint16_t h_sync_width, + uint16_t h_end_width, uint16_t v_start_width, + uint16_t v_sync_width, uint16_t v_end_width, + uint32_t v_to_h_sync, ipu_di_signal_cfg_t sig) +{ + uint32_t reg; + uint32_t di_gen, vsync_cnt; + uint32_t div, rounded_pixel_clk; + uint32_t h_total, v_total; + int map; + struct clk *di_parent; + + debug("panel size = %d x %d\n", width, height); + + if ((v_sync_width == 0) || (h_sync_width == 0)) + return EINVAL; + + adapt_panel_to_ipu_restricitions(&pixel_clk, width, height, + h_start_width, h_end_width, + v_start_width, &v_end_width); + h_total = width + h_sync_width + h_start_width + h_end_width; + v_total = height + v_sync_width + v_start_width + v_end_width; + + /* Init clocking */ + debug("pixel clk = %d\n", pixel_clk); + + if (sig.ext_clk) { + if (!(g_di1_tvout && (disp == 1))) { /*not round div for tvout*/ + /* + * Set the PLL to be an even multiple + * of the pixel clock. + */ + if ((clk_get_usecount(g_pixel_clk[0]) == 0) && + (clk_get_usecount(g_pixel_clk[1]) == 0)) { + di_parent = clk_get_parent(g_di_clk[disp]); + rounded_pixel_clk = + clk_round_rate(g_pixel_clk[disp], + pixel_clk); + div = clk_get_rate(di_parent) / + rounded_pixel_clk; + if (div % 2) + div++; + if (clk_get_rate(di_parent) != div * + rounded_pixel_clk) + clk_set_rate(di_parent, + div * rounded_pixel_clk); + udelay(10000); + clk_set_rate(g_di_clk[disp], + 2 * rounded_pixel_clk); + udelay(10000); + } + } + clk_set_parent(g_pixel_clk[disp], g_di_clk[disp]); + } else { + if (clk_get_usecount(g_pixel_clk[disp]) != 0) + clk_set_parent(g_pixel_clk[disp], g_ipu_clk); + } + rounded_pixel_clk = clk_round_rate(g_pixel_clk[disp], pixel_clk); + clk_set_rate(g_pixel_clk[disp], rounded_pixel_clk); + udelay(5000); + /* Get integer portion of divider */ + div = clk_get_rate(clk_get_parent(g_pixel_clk[disp])) / + rounded_pixel_clk; + + ipu_di_data_wave_config(disp, SYNC_WAVE, div - 1, div - 1); + ipu_di_data_pin_config(disp, SYNC_WAVE, DI_PIN15, 3, 0, div * 2); + + map = ipu_pixfmt_to_map(pixel_fmt); + if (map < 0) { + debug("IPU_DISP: No MAP\n"); + return -EINVAL; + } + + di_gen = __raw_readl(DI_GENERAL(disp)); + + if (sig.interlaced) { + /* Setup internal HSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 1, /* counter */ + h_total / 2 - 1,/* run count */ + DI_SYNC_CLK, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* Field 1 VSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 2, /* counter */ + h_total - 1, /* run count */ + DI_SYNC_CLK, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 4 /* COUNT DOWN */ + ); + + /* Setup internal HSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 3, /* counter */ + v_total * 2 - 1,/* run count */ + DI_SYNC_INT_HSYNC, /* run_resolution */ + 1, /* offset */ + DI_SYNC_INT_HSYNC, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 4 /* COUNT DOWN */ + ); + + /* Active Field ? */ + ipu_di_sync_config( + disp, /* display */ + 4, /* counter */ + v_total / 2 - 1,/* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + v_start_width, /* offset */ + DI_SYNC_HSYNC, /* offset resolution */ + 2, /* repeat count */ + DI_SYNC_VSYNC, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* Active Line */ + ipu_di_sync_config( + disp, /* display */ + 5, /* counter */ + 0, /* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + height / 2, /* repeat count */ + 4, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* Field 0 VSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 6, /* counter */ + v_total - 1, /* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* DC VSYNC waveform */ + vsync_cnt = 7; + ipu_di_sync_config( + disp, /* display */ + 7, /* counter */ + v_total / 2 - 1,/* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + 9, /* offset */ + DI_SYNC_HSYNC, /* offset resolution */ + 2, /* repeat count */ + DI_SYNC_VSYNC, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* active pixel waveform */ + ipu_di_sync_config( + disp, /* display */ + 8, /* counter */ + 0, /* run count */ + DI_SYNC_CLK, /* run_resolution */ + h_start_width, /* offset */ + DI_SYNC_CLK, /* offset resolution */ + width, /* repeat count */ + 5, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + ipu_di_sync_config( + disp, /* display */ + 9, /* counter */ + v_total - 1, /* run count */ + DI_SYNC_INT_HSYNC,/* run_resolution */ + v_total / 2, /* offset */ + DI_SYNC_INT_HSYNC,/* offset resolution */ + 0, /* repeat count */ + DI_SYNC_HSYNC, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 4 /* COUNT DOWN */ + ); + + /* set gentime select and tag sel */ + reg = __raw_readl(DI_SW_GEN1(disp, 9)); + reg &= 0x1FFFFFFF; + reg |= (3 - 1)<<29 | 0x00008000; + __raw_writel(reg, DI_SW_GEN1(disp, 9)); + + __raw_writel(v_total / 2 - 1, DI_SCR_CONF(disp)); + + /* set y_sel = 1 */ + di_gen |= 0x10000000; + di_gen |= DI_GEN_POLARITY_5; + di_gen |= DI_GEN_POLARITY_8; + } else { + /* Setup internal HSYNC waveform */ + ipu_di_sync_config(disp, 1, h_total - 1, DI_SYNC_CLK, + 0, DI_SYNC_NONE, 0, DI_SYNC_NONE, + 0, DI_SYNC_NONE, + DI_SYNC_NONE, 0, 0); + + /* Setup external (delayed) HSYNC waveform */ + ipu_di_sync_config(disp, DI_SYNC_HSYNC, h_total - 1, + DI_SYNC_CLK, div * v_to_h_sync, DI_SYNC_CLK, + 0, DI_SYNC_NONE, 1, DI_SYNC_NONE, + DI_SYNC_CLK, 0, h_sync_width * 2); + /* Setup VSYNC waveform */ + vsync_cnt = DI_SYNC_VSYNC; + ipu_di_sync_config(disp, DI_SYNC_VSYNC, v_total - 1, + DI_SYNC_INT_HSYNC, 0, DI_SYNC_NONE, 0, + DI_SYNC_NONE, 1, DI_SYNC_NONE, + DI_SYNC_INT_HSYNC, 0, v_sync_width * 2); + __raw_writel(v_total - 1, DI_SCR_CONF(disp)); + + /* Setup active data waveform to sync with DC */ + ipu_di_sync_config(disp, 4, 0, DI_SYNC_HSYNC, + v_sync_width + v_start_width, DI_SYNC_HSYNC, + height, + DI_SYNC_VSYNC, 0, DI_SYNC_NONE, + DI_SYNC_NONE, 0, 0); + ipu_di_sync_config(disp, 5, 0, DI_SYNC_CLK, + h_sync_width + h_start_width, DI_SYNC_CLK, + width, 4, 0, DI_SYNC_NONE, DI_SYNC_NONE, 0, + 0); + + /* reset all unused counters */ + __raw_writel(0, DI_SW_GEN0(disp, 6)); + __raw_writel(0, DI_SW_GEN1(disp, 6)); + __raw_writel(0, DI_SW_GEN0(disp, 7)); + __raw_writel(0, DI_SW_GEN1(disp, 7)); + __raw_writel(0, DI_SW_GEN0(disp, 8)); + __raw_writel(0, DI_SW_GEN1(disp, 8)); + __raw_writel(0, DI_SW_GEN0(disp, 9)); + __raw_writel(0, DI_SW_GEN1(disp, 9)); + + reg = __raw_readl(DI_STP_REP(disp, 6)); + reg &= 0x0000FFFF; + __raw_writel(reg, DI_STP_REP(disp, 6)); + __raw_writel(0, DI_STP_REP(disp, 7)); + __raw_writel(0, DI_STP_REP(disp, 9)); + + /* Init template microcode */ + if (disp) { + ipu_dc_write_tmpl(2, WROD(0), 0, map, SYNC_WAVE, 8, 5); + ipu_dc_write_tmpl(3, WROD(0), 0, map, SYNC_WAVE, 4, 5); + ipu_dc_write_tmpl(4, WROD(0), 0, map, SYNC_WAVE, 0, 5); + } else { + ipu_dc_write_tmpl(5, WROD(0), 0, map, SYNC_WAVE, 8, 5); + ipu_dc_write_tmpl(6, WROD(0), 0, map, SYNC_WAVE, 4, 5); + ipu_dc_write_tmpl(7, WROD(0), 0, map, SYNC_WAVE, 0, 5); + } + + if (sig.Hsync_pol) + di_gen |= DI_GEN_POLARITY_2; + if (sig.Vsync_pol) + di_gen |= DI_GEN_POLARITY_3; + + if (sig.clk_pol) + di_gen |= DI_GEN_POL_CLK; + + } + + __raw_writel(di_gen, DI_GENERAL(disp)); + + __raw_writel((--vsync_cnt << DI_VSYNC_SEL_OFFSET) | + 0x00000002, DI_SYNC_AS_GEN(disp)); + + reg = __raw_readl(DI_POL(disp)); + reg &= ~(DI_POL_DRDY_DATA_POLARITY | DI_POL_DRDY_POLARITY_15); + if (sig.enable_pol) + reg |= DI_POL_DRDY_POLARITY_15; + if (sig.data_pol) + reg |= DI_POL_DRDY_DATA_POLARITY; + __raw_writel(reg, DI_POL(disp)); + + __raw_writel(width, DC_DISP_CONF2(DC_DISP_ID_SYNC(disp))); + + return 0; +} + +/* + * This function sets the foreground and background plane global alpha blending + * modes. This function also sets the DP graphic plane according to the + * parameter of IPUv3 DP channel. + * + * @param channel IPUv3 DP channel + * + * @param enable Boolean to enable or disable global alpha + * blending. If disabled, local blending is used. + * + * @param alpha Global alpha value. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_disp_set_global_alpha(ipu_channel_t channel, bool enable, + uint8_t alpha) +{ + uint32_t reg; + uint32_t flow; + + bool bg_chan; + + if (channel == MEM_BG_SYNC || channel == MEM_FG_SYNC) + flow = DP_SYNC; + else if (channel == MEM_BG_ASYNC0 || channel == MEM_FG_ASYNC0) + flow = DP_ASYNC0; + else if (channel == MEM_BG_ASYNC1 || channel == MEM_FG_ASYNC1) + flow = DP_ASYNC1; + else + return -EINVAL; + + if (channel == MEM_BG_SYNC || channel == MEM_BG_ASYNC0 || + channel == MEM_BG_ASYNC1) + bg_chan = true; + else + bg_chan = false; + + if (!g_ipu_clk_enabled) + clk_enable(g_ipu_clk); + + if (bg_chan) { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg & ~DP_COM_CONF_GWSEL, DP_COM_CONF(flow)); + } else { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg | DP_COM_CONF_GWSEL, DP_COM_CONF(flow)); + } + + if (enable) { + reg = __raw_readl(DP_GRAPH_WIND_CTRL(flow)) & 0x00FFFFFFL; + __raw_writel(reg | ((uint32_t) alpha << 24), + DP_GRAPH_WIND_CTRL(flow)); + + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg | DP_COM_CONF_GWAM, DP_COM_CONF(flow)); + } else { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg & ~DP_COM_CONF_GWAM, DP_COM_CONF(flow)); + } + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + + if (!g_ipu_clk_enabled) + clk_disable(g_ipu_clk); + + return 0; +} + +/* + * This function sets the transparent color key for SDC graphic plane. + * + * @param channel Input parameter for the logical channel ID. + * + * @param enable Boolean to enable or disable color key + * + * @param colorKey 24-bit RGB color for transparent color key. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_disp_set_color_key(ipu_channel_t channel, bool enable, + uint32_t color_key) +{ + uint32_t reg, flow; + int y, u, v; + int red, green, blue; + + if (channel == MEM_BG_SYNC || channel == MEM_FG_SYNC) + flow = DP_SYNC; + else if (channel == MEM_BG_ASYNC0 || channel == MEM_FG_ASYNC0) + flow = DP_ASYNC0; + else if (channel == MEM_BG_ASYNC1 || channel == MEM_FG_ASYNC1) + flow = DP_ASYNC1; + else + return -EINVAL; + + if (!g_ipu_clk_enabled) + clk_enable(g_ipu_clk); + + color_key_4rgb = 1; + /* Transform color key from rgb to yuv if CSC is enabled */ + if (((fg_csc_type == RGB2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == RGB2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2RGB) && (bg_csc_type == YUV2RGB))) { + + debug("color key 0x%x need change to yuv fmt\n", color_key); + + red = (color_key >> 16) & 0xFF; + green = (color_key >> 8) & 0xFF; + blue = color_key & 0xFF; + + y = rgb_to_yuv(0, red, green, blue); + u = rgb_to_yuv(1, red, green, blue); + v = rgb_to_yuv(2, red, green, blue); + color_key = (y << 16) | (u << 8) | v; + + color_key_4rgb = 0; + + debug("color key change to yuv fmt 0x%x\n", color_key); + } + + if (enable) { + reg = __raw_readl(DP_GRAPH_WIND_CTRL(flow)) & 0xFF000000L; + __raw_writel(reg | color_key, DP_GRAPH_WIND_CTRL(flow)); + + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg | DP_COM_CONF_GWCKE, DP_COM_CONF(flow)); + } else { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg & ~DP_COM_CONF_GWCKE, DP_COM_CONF(flow)); + } + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + + if (!g_ipu_clk_enabled) + clk_disable(g_ipu_clk); + + return 0; +} diff --git a/drivers/video/ipu_regs.h b/drivers/video/ipu_regs.h new file mode 100644 index 0000000..36f07bb --- /dev/null +++ b/drivers/video/ipu_regs.h @@ -0,0 +1,418 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __IPU_REGS_INCLUDED__ +#define __IPU_REGS_INCLUDED__ + +#define IPU_DISP0_BASE 0x00000000 +#define IPU_MCU_T_DEFAULT 8 +#define IPU_DISP1_BASE (IPU_MCU_T_DEFAULT << 25) +#define IPU_CM_REG_BASE 0x1E000000 +#define IPU_STAT_REG_BASE 0x1E000200 +#define IPU_IDMAC_REG_BASE 0x1E008000 +#define IPU_ISP_REG_BASE 0x1E010000 +#define IPU_DP_REG_BASE 0x1E018000 +#define IPU_IC_REG_BASE 0x1E020000 +#define IPU_IRT_REG_BASE 0x1E028000 +#define IPU_CSI0_REG_BASE 0x1E030000 +#define IPU_CSI1_REG_BASE 0x1E038000 +#define IPU_DI0_REG_BASE 0x1E040000 +#define IPU_DI1_REG_BASE 0x1E048000 +#define IPU_SMFC_REG_BASE 0x1E050000 +#define IPU_DC_REG_BASE 0x1E058000 +#define IPU_DMFC_REG_BASE 0x1E060000 +#define IPU_CPMEM_REG_BASE 0x1F000000 +#define IPU_LUT_REG_BASE 0x1F020000 +#define IPU_SRM_REG_BASE 0x1F040000 +#define IPU_TPM_REG_BASE 0x1F060000 +#define IPU_DC_TMPL_REG_BASE 0x1F080000 +#define IPU_ISP_TBPR_REG_BASE 0x1F0C0000 +#define IPU_VDI_REG_BASE 0x1E068000 + + +extern u32 *ipu_dc_tmpl_reg; + +#define DC_EVT_NF 0 +#define DC_EVT_NL 1 +#define DC_EVT_EOF 2 +#define DC_EVT_NFIELD 3 +#define DC_EVT_EOL 4 +#define DC_EVT_EOFIELD 5 +#define DC_EVT_NEW_ADDR 6 +#define DC_EVT_NEW_CHAN 7 +#define DC_EVT_NEW_DATA 8 + +#define DC_EVT_NEW_ADDR_W_0 0 +#define DC_EVT_NEW_ADDR_W_1 1 +#define DC_EVT_NEW_CHAN_W_0 2 +#define DC_EVT_NEW_CHAN_W_1 3 +#define DC_EVT_NEW_DATA_W_0 4 +#define DC_EVT_NEW_DATA_W_1 5 +#define DC_EVT_NEW_ADDR_R_0 6 +#define DC_EVT_NEW_ADDR_R_1 7 +#define DC_EVT_NEW_CHAN_R_0 8 +#define DC_EVT_NEW_CHAN_R_1 9 +#define DC_EVT_NEW_DATA_R_0 10 +#define DC_EVT_NEW_DATA_R_1 11 + +/* Software reset for ipu */ +#define SW_IPU_RST 8 + +enum { + IPU_CONF_DP_EN = 0x00000020, + IPU_CONF_DI0_EN = 0x00000040, + IPU_CONF_DI1_EN = 0x00000080, + IPU_CONF_DMFC_EN = 0x00000400, + IPU_CONF_DC_EN = 0x00000200, + + DI0_COUNTER_RELEASE = 0x01000000, + DI1_COUNTER_RELEASE = 0x02000000, + + DI_DW_GEN_ACCESS_SIZE_OFFSET = 24, + DI_DW_GEN_COMPONENT_SIZE_OFFSET = 16, + + DI_GEN_DI_CLK_EXT = 0x100000, + DI_GEN_POLARITY_1 = 0x00000001, + DI_GEN_POLARITY_2 = 0x00000002, + DI_GEN_POLARITY_3 = 0x00000004, + DI_GEN_POLARITY_4 = 0x00000008, + DI_GEN_POLARITY_5 = 0x00000010, + DI_GEN_POLARITY_6 = 0x00000020, + DI_GEN_POLARITY_7 = 0x00000040, + DI_GEN_POLARITY_8 = 0x00000080, + DI_GEN_POL_CLK = 0x20000, + + DI_POL_DRDY_DATA_POLARITY = 0x00000080, + DI_POL_DRDY_POLARITY_15 = 0x00000010, + DI_VSYNC_SEL_OFFSET = 13, + + DC_WR_CH_CONF_FIELD_MODE = 0x00000200, + DC_WR_CH_CONF_PROG_TYPE_OFFSET = 5, + DC_WR_CH_CONF_PROG_TYPE_MASK = 0x000000E0, + DC_WR_CH_CONF_PROG_DI_ID = 0x00000004, + DC_WR_CH_CONF_PROG_DISP_ID_OFFSET = 3, + DC_WR_CH_CONF_PROG_DISP_ID_MASK = 0x00000018, + + DP_COM_CONF_FG_EN = 0x00000001, + DP_COM_CONF_GWSEL = 0x00000002, + DP_COM_CONF_GWAM = 0x00000004, + DP_COM_CONF_GWCKE = 0x00000008, + DP_COM_CONF_CSC_DEF_MASK = 0x00000300, + DP_COM_CONF_CSC_DEF_OFFSET = 8, + DP_COM_CONF_CSC_DEF_FG = 0x00000300, + DP_COM_CONF_CSC_DEF_BG = 0x00000200, + DP_COM_CONF_CSC_DEF_BOTH = 0x00000100, + DP_COM_CONF_GAMMA_EN = 0x00001000, + DP_COM_CONF_GAMMA_YUV_EN = 0x00002000, +}; + +enum di_pins { + DI_PIN11 = 0, + DI_PIN12 = 1, + DI_PIN13 = 2, + DI_PIN14 = 3, + DI_PIN15 = 4, + DI_PIN16 = 5, + DI_PIN17 = 6, + DI_PIN_CS = 7, + + DI_PIN_SER_CLK = 0, + DI_PIN_SER_RS = 1, +}; + +enum di_sync_wave { + DI_SYNC_NONE = -1, + DI_SYNC_CLK = 0, + DI_SYNC_INT_HSYNC = 1, + DI_SYNC_HSYNC = 2, + DI_SYNC_VSYNC = 3, + DI_SYNC_DE = 5, +}; + +struct ipu_cm { + u32 conf; + u32 sisg_ctrl0; + u32 sisg_ctrl1; + u32 sisg_set[6]; + u32 sisg_clear[6]; + u32 int_ctrl[15]; + u32 sdma_event[10]; + u32 srm_pri1; + u32 srm_pri2; + u32 fs_proc_flow[3]; + u32 fs_disp_flow[2]; + u32 skip; + u32 disp_alt_conf; + u32 disp_gen; + u32 disp_alt[4]; + u32 snoop; + u32 mem_rst; + u32 pm; + u32 gpr; + u32 reserved0[26]; + u32 ch_db_mode_sel[2]; + u32 reserved1[16]; + u32 alt_ch_db_mode_sel[2]; + u32 reserved2[2]; + u32 ch_trb_mode_sel[2]; +}; + +struct ipu_idmac { + u32 conf; + u32 ch_en[2]; + u32 sep_alpha; + u32 alt_sep_alpha; + u32 ch_pri[2]; + u32 wm_en[2]; + u32 lock_en[2]; + u32 sub_addr[5]; + u32 bndm_en[2]; + u32 sc_cord[2]; + u32 reserved[45]; + u32 ch_busy[2]; +}; + +struct ipu_com_async { + u32 com_conf_async; + u32 graph_wind_ctrl_async; + u32 fg_pos_async; + u32 cur_pos_async; + u32 cur_map_async; + u32 gamma_c_async[8]; + u32 gamma_s_async[4]; + u32 dp_csca_async[4]; + u32 dp_csc_async[2]; +}; + +struct ipu_dp { + u32 com_conf_sync; + u32 graph_wind_ctrl_sync; + u32 fg_pos_sync; + u32 cur_pos_sync; + u32 cur_map_sync; + u32 gamma_c_sync[8]; + u32 gamma_s_sync[4]; + u32 csca_sync[4]; + u32 csc_sync[2]; + u32 cur_pos_alt; + struct ipu_com_async async[2]; +}; + +struct ipu_di { + u32 general; + u32 bs_clkgen0; + u32 bs_clkgen1; + u32 sw_gen0[9]; + u32 sw_gen1[9]; + u32 sync_as; + u32 dw_gen[12]; + u32 dw_set[48]; + u32 stp_rep[4]; + u32 stp_rep9; + u32 ser_conf; + u32 ssc; + u32 pol; + u32 aw0; + u32 aw1; + u32 scr_conf; + u32 stat; +}; + +struct ipu_stat { + u32 int_stat[15]; + u32 cur_buf[2]; + u32 alt_cur_buf_0; + u32 alt_cur_buf_1; + u32 srm_stat; + u32 proc_task_stat; + u32 disp_task_stat; + u32 triple_cur_buf[4]; + u32 ch_buf0_rdy[2]; + u32 ch_buf1_rdy[2]; + u32 alt_ch_buf0_rdy[2]; + u32 alt_ch_buf1_rdy[2]; + u32 ch_buf2_rdy[2]; +}; + +struct ipu_dc_ch { + u32 wr_ch_conf; + u32 wr_ch_addr; + u32 rl[5]; +}; + +struct ipu_dc { + struct ipu_dc_ch dc_ch0_1_2[3]; + u32 cmd_ch_conf_3; + u32 cmd_ch_conf_4; + struct ipu_dc_ch dc_ch5_6[2]; + struct ipu_dc_ch dc_ch8; + u32 rl6_ch_8; + struct ipu_dc_ch dc_ch9; + u32 rl6_ch_9; + u32 gen; + u32 disp_conf1[4]; + u32 disp_conf2[4]; + u32 di0_conf[2]; + u32 di1_conf[2]; + u32 dc_map_ptr[15]; + u32 dc_map_val[12]; + u32 udge[16]; + u32 lla[2]; + u32 r_lla[2]; + u32 wr_ch_addr_5_alt; + u32 stat; +}; + +struct ipu_dmfc { + u32 rd_chan; + u32 wr_chan; + u32 wr_chan_def; + u32 dp_chan; + u32 dp_chan_def; + u32 general[2]; + u32 ic_ctrl; + u32 wr_chan_alt; + u32 wr_chan_def_alt; + u32 general1_alt; + u32 stat; +}; + +#define IPU_CM_REG ((struct ipu_cm *)(IPU_CTRL_BASE_ADDR + \ + IPU_CM_REG_BASE)) +#define IPU_CONF (&IPU_CM_REG->conf) +#define IPU_SRM_PRI1 (&IPU_CM_REG->srm_pri1) +#define IPU_SRM_PRI2 (&IPU_CM_REG->srm_pri2) +#define IPU_FS_PROC_FLOW1 (&IPU_CM_REG->fs_proc_flow[0]) +#define IPU_FS_PROC_FLOW2 (&IPU_CM_REG->fs_proc_flow[1]) +#define IPU_FS_PROC_FLOW3 (&IPU_CM_REG->fs_proc_flow[2]) +#define IPU_FS_DISP_FLOW1 (&IPU_CM_REG->fs_disp_flow[0]) +#define IPU_DISP_GEN (&IPU_CM_REG->disp_gen) +#define IPU_MEM_RST (&IPU_CM_REG->mem_rst) +#define IPU_GPR (&IPU_CM_REG->gpr) +#define IPU_CHA_DB_MODE_SEL(ch) (&IPU_CM_REG->ch_db_mode_sel[ch / 32]) + +#define IPU_STAT ((struct ipu_stat *)(IPU_CTRL_BASE_ADDR + \ + IPU_STAT_REG_BASE)) +#define IPU_CHA_CUR_BUF(ch) (&IPU_STAT->cur_buf[ch / 32]) +#define IPU_CHA_BUF0_RDY(ch) (&IPU_STAT->ch_buf0_rdy[ch / 32]) +#define IPU_CHA_BUF1_RDY(ch) (&IPU_STAT->ch_buf1_rdy[ch / 32]) + +#define IPU_INT_CTRL(n) (&IPU_CM_REG->int_ctrl[(n) - 1]) + +#define IDMAC_REG ((struct ipu_idmac *)(IPU_CTRL_BASE_ADDR + \ + IPU_IDMAC_REG_BASE)) +#define IDMAC_CONF (&IDMAC_REG->conf) +#define IDMAC_CHA_EN(ch) (&IDMAC_REG->ch_en[ch / 32]) +#define IDMAC_CHA_PRI(ch) (&IDMAC_REG->ch_pri[ch / 32]) + +#define DI_REG(di) ((struct ipu_di *)(IPU_CTRL_BASE_ADDR + \ + ((di == 1) ? IPU_DI1_REG_BASE : \ + IPU_DI0_REG_BASE))) +#define DI_GENERAL(di) (&DI_REG(di)->general) +#define DI_BS_CLKGEN0(di) (&DI_REG(di)->bs_clkgen0) +#define DI_BS_CLKGEN1(di) (&DI_REG(di)->bs_clkgen1) + +#define DI_SW_GEN0(di, gen) (&DI_REG(di)->sw_gen0[gen - 1]) +#define DI_SW_GEN1(di, gen) (&DI_REG(di)->sw_gen1[gen - 1]) +#define DI_STP_REP(di, gen) (&DI_REG(di)->stp_rep[(gen - 1) / 2]) +#define DI_SYNC_AS_GEN(di) (&DI_REG(di)->sync_as) +#define DI_DW_GEN(di, gen) (&DI_REG(di)->dw_gen[gen]) +#define DI_DW_SET(di, gen, set) (&DI_REG(di)->dw_set[gen + 12 * set]) +#define DI_POL(di) (&DI_REG(di)->pol) +#define DI_SCR_CONF(di) (&DI_REG(di)->scr_conf) + +#define DMFC_REG ((struct ipu_dmfc *)(IPU_CTRL_BASE_ADDR + \ + IPU_DMFC_REG_BASE)) +#define DMFC_WR_CHAN (&DMFC_REG->wr_chan) +#define DMFC_WR_CHAN_DEF (&DMFC_REG->wr_chan_def) +#define DMFC_DP_CHAN (&DMFC_REG->dp_chan) +#define DMFC_DP_CHAN_DEF (&DMFC_REG->dp_chan_def) +#define DMFC_GENERAL1 (&DMFC_REG->general[0]) +#define DMFC_IC_CTRL (&DMFC_REG->ic_ctrl) + + +#define DC_REG ((struct ipu_dc *)(IPU_CTRL_BASE_ADDR + \ + IPU_DC_REG_BASE)) +#define DC_MAP_CONF_PTR(n) (&DC_REG->dc_map_ptr[n / 2]) +#define DC_MAP_CONF_VAL(n) (&DC_REG->dc_map_val[n / 2]) + + +static inline struct ipu_dc_ch *dc_ch_offset(int ch) +{ + switch (ch) { + case 0: + case 1: + case 2: + return &DC_REG->dc_ch0_1_2[ch]; + case 5: + case 6: + return &DC_REG->dc_ch5_6[ch - 5]; + case 8: + return &DC_REG->dc_ch8; + case 9: + return &DC_REG->dc_ch9; + default: + printf("%s: invalid channel %d\n", __func__, ch); + return NULL; + } + +} + +#define DC_RL_CH(ch, evt) (&dc_ch_offset(ch)->rl[evt / 2]) + +#define DC_WR_CH_CONF(ch) (&dc_ch_offset(ch)->wr_ch_conf) +#define DC_WR_CH_ADDR(ch) (&dc_ch_offset(ch)->wr_ch_addr) + +#define DC_WR_CH_CONF_1 DC_WR_CH_CONF(1) +#define DC_WR_CH_CONF_5 DC_WR_CH_CONF(5) + +#define DC_GEN (&DC_REG->gen) +#define DC_DISP_CONF2(disp) (&DC_REG->disp_conf2[disp]) +#define DC_STAT (&DC_REG->stat) + +#define DP_SYNC 0 +#define DP_ASYNC0 0x60 +#define DP_ASYNC1 0xBC + +#define DP_REG ((struct ipu_dp *)(IPU_CTRL_BASE_ADDR + \ + IPU_DP_REG_BASE)) +#define DP_COM_CONF(flow) (&DP_REG->com_conf_sync) +#define DP_GRAPH_WIND_CTRL(flow) (&DP_REG->graph_wind_ctrl_sync) +#define DP_CSC_A_0(flow) (&DP_REG->csca_sync[0]) +#define DP_CSC_A_1(flow) (&DP_REG->csca_sync[1]) +#define DP_CSC_A_2(flow) (&DP_REG->csca_sync[2]) +#define DP_CSC_A_3(flow) (&DP_REG->csca_sync[3]) + +#define DP_CSC_0(flow) (&DP_REG->csc_sync[0]) +#define DP_CSC_1(flow) (&DP_REG->csc_sync[1]) + +/* DC template opcodes */ +#define WROD(lf) (0x18 | (lf << 1)) + +#endif
Add framebuffer driver for the MX51 processor working on the IPUv3 internal graphic processor.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/video/Makefile | 1 + drivers/video/mxc_ipuv3_fb.c | 661 ++++++++++++++++++++++++++++++++++++++++++ drivers/video/mxcfb.h | 78 +++++ 3 files changed, 740 insertions(+), 0 deletions(-) create mode 100644 drivers/video/mxc_ipuv3_fb.c create mode 100644 drivers/video/mxcfb.h
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4be82e7..5b7b261 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o COBJS-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o +COBJS-$(CONFIG_VIDEO_MX5) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o COBJS-$(CONFIG_SED156X) += sed156x.o COBJS-$(CONFIG_VIDEO_SM501) += sm501.o diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c new file mode 100644 index 0000000..7a905c5 --- /dev/null +++ b/drivers/video/mxc_ipuv3_fb.c @@ -0,0 +1,661 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * MX51 Linux framebuffer: + * + * (C) Copyright 2004-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ +#include <common.h> +#include <asm/errno.h> +#include <linux/string.h> +#include <linux/list.h> +#include <linux/fb.h> +#include <asm/io.h> +#include <malloc.h> +#include <lcd.h> +#include "videomodes.h" +#include "ipu.h" +#include "mxcfb.h" + +DECLARE_GLOBAL_DATA_PTR; + +void *lcd_base; /* Start of framebuffer memory */ +void *lcd_console_address; /* Start of console buffer */ + +int lcd_line_length; +int lcd_color_fg; +int lcd_color_bg; + +short console_col; +short console_row; + +vidinfo_t panel_info; + +static int mxcfb_map_video_memory(struct fb_info *fbi); +static int mxcfb_unmap_video_memory(struct fb_info *fbi); + +void lcd_initcolregs(void) +{ +} + +void lcd_setcolreg(ushort regno, ushort red, ushort green, ushort blue) +{ +} + +void lcd_disable(void) +{ +} + +void lcd_panel_disable(void) +{ +} + +void fb_videomode_to_var(struct fb_var_screeninfo *var, + const struct fb_videomode *mode) +{ + var->xres = mode->xres; + var->yres = mode->yres; + var->xres_virtual = mode->xres; + var->yres_virtual = mode->yres; + var->xoffset = 0; + var->yoffset = 0; + var->pixclock = mode->pixclock; + var->left_margin = mode->left_margin; + var->right_margin = mode->right_margin; + var->upper_margin = mode->upper_margin; + var->lower_margin = mode->lower_margin; + var->hsync_len = mode->hsync_len; + var->vsync_len = mode->vsync_len; + var->sync = mode->sync; + var->vmode = mode->vmode & FB_VMODE_MASK; +} + +/* + * Structure containing the MXC specific framebuffer information. + */ +struct mxcfb_info { + int blank; + ipu_channel_t ipu_ch; + int ipu_di; + u32 ipu_di_pix_fmt; + bool overlay; + bool alpha_chan_en; + dma_addr_t alpha_phy_addr0; + dma_addr_t alpha_phy_addr1; + void *alpha_virt_addr0; + void *alpha_virt_addr1; + uint32_t alpha_mem_len; + uint32_t cur_ipu_buf; + uint32_t cur_ipu_alpha_buf; + + u32 pseudo_palette[16]; +}; + +enum { + BOTH_ON, + SRC_ON, + TGT_ON, + BOTH_OFF +}; + +static unsigned long default_bpp = 16; +static bool g_dp_in_use; +static struct fb_info *mxcfb_info[3]; +static int ext_clk_used; + +static uint32_t bpp_to_pixfmt(struct fb_info *fbi) +{ + uint32_t pixfmt = 0; + + debug("bpp_to_pixfmt: %d\n", fbi->var.bits_per_pixel); + + if (fbi->var.nonstd) + return fbi->var.nonstd; + + switch (fbi->var.bits_per_pixel) { + case 24: + pixfmt = IPU_PIX_FMT_BGR24; + break; + case 32: + pixfmt = IPU_PIX_FMT_BGR32; + break; + case 16: + pixfmt = IPU_PIX_FMT_RGB565; + break; + } + return pixfmt; +} + +/* + * Set fixed framebuffer parameters based on variable settings. + * + * @param info framebuffer information pointer + */ +static int mxcfb_set_fix(struct fb_info *info) +{ + struct fb_fix_screeninfo *fix = &info->fix; + struct fb_var_screeninfo *var = &info->var; + + fix->line_length = var->xres_virtual * var->bits_per_pixel / 8; + + fix->type = FB_TYPE_PACKED_PIXELS; + fix->accel = FB_ACCEL_NONE; + fix->visual = FB_VISUAL_TRUECOLOR; + fix->xpanstep = 1; + fix->ypanstep = 1; + + return 0; +} + +static int setup_disp_channel1(struct fb_info *fbi) +{ + ipu_channel_params_t params; + struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par; + + memset(¶ms, 0, sizeof(params)); + params.mem_dp_bg_sync.di = mxc_fbi->ipu_di; + + debug("%s called\n", __func__); + /* + * Assuming interlaced means yuv output, below setting also + * valid for mem_dc_sync. FG should have the same vmode as BG. + */ + if (fbi->var.vmode & FB_VMODE_INTERLACED) { + params.mem_dp_bg_sync.interlaced = true; + params.mem_dp_bg_sync.out_pixel_fmt = + IPU_PIX_FMT_YUV444; + } else { + if (mxc_fbi->ipu_di_pix_fmt) + params.mem_dp_bg_sync.out_pixel_fmt = + mxc_fbi->ipu_di_pix_fmt; + else + params.mem_dp_bg_sync.out_pixel_fmt = + IPU_PIX_FMT_RGB666; + } + params.mem_dp_bg_sync.in_pixel_fmt = bpp_to_pixfmt(fbi); + if (mxc_fbi->alpha_chan_en) + params.mem_dp_bg_sync.alpha_chan_en = true; + + ipu_init_channel(mxc_fbi->ipu_ch, ¶ms); + + return 0; +} + +static int setup_disp_channel2(struct fb_info *fbi) +{ + int retval = 0; + struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par; + + mxc_fbi->cur_ipu_buf = 1; + if (mxc_fbi->alpha_chan_en) { + mxc_fbi->cur_ipu_alpha_buf = 1; + } + fbi->var.xoffset = fbi->var.yoffset = 0; + + debug("%s: %x %d %d %d %lx %lx\n", + __func__, + mxc_fbi->ipu_ch, + fbi->var.xres, + fbi->var.yres, + fbi->fix.line_length, + fbi->fix.smem_start, + fbi->fix.smem_start + + (fbi->fix.line_length * fbi->var.yres)); + + retval = ipu_init_channel_buffer(mxc_fbi->ipu_ch, IPU_INPUT_BUFFER, + bpp_to_pixfmt(fbi), + fbi->var.xres, fbi->var.yres, + fbi->fix.line_length, + fbi->fix.smem_start + + (fbi->fix.line_length * fbi->var.yres), + fbi->fix.smem_start, + 0, 0); + if (retval) { + printf("ipu_init_channel_buffer error %d\n", retval); + } + + return retval; +} + +/* + * Set framebuffer parameters and change the operating mode. + * + * @param info framebuffer information pointer + */ +static int mxcfb_set_par(struct fb_info *fbi) +{ + int retval = 0; + u32 mem_len; + ipu_di_signal_cfg_t sig_cfg; + struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par; + uint32_t out_pixel_fmt; + + ipu_disable_channel(mxc_fbi->ipu_ch); + ipu_uninit_channel(mxc_fbi->ipu_ch); + mxcfb_set_fix(fbi); + + mem_len = fbi->var.yres_virtual * fbi->fix.line_length; + if (!fbi->fix.smem_start || (mem_len > fbi->fix.smem_len)) { + if (fbi->fix.smem_start) + mxcfb_unmap_video_memory(fbi); + + if (mxcfb_map_video_memory(fbi) < 0) + return -ENOMEM; + } + + setup_disp_channel1(fbi); + + memset(&sig_cfg, 0, sizeof(sig_cfg)); + if (fbi->var.vmode & FB_VMODE_INTERLACED) { + sig_cfg.interlaced = true; + out_pixel_fmt = IPU_PIX_FMT_YUV444; + } else { + if (mxc_fbi->ipu_di_pix_fmt) + out_pixel_fmt = mxc_fbi->ipu_di_pix_fmt; + else + out_pixel_fmt = IPU_PIX_FMT_RGB666; + } + if (fbi->var.vmode & FB_VMODE_ODD_FLD_FIRST) /* PAL */ + sig_cfg.odd_field_first = true; + if ((fbi->var.sync & FB_SYNC_EXT) || ext_clk_used) + sig_cfg.ext_clk = true; + if (fbi->var.sync & FB_SYNC_HOR_HIGH_ACT) + sig_cfg.Hsync_pol = true; + if (fbi->var.sync & FB_SYNC_VERT_HIGH_ACT) + sig_cfg.Vsync_pol = true; + if (!(fbi->var.sync & FB_SYNC_CLK_LAT_FALL)) + sig_cfg.clk_pol = true; + if (fbi->var.sync & FB_SYNC_DATA_INVERT) + sig_cfg.data_pol = true; + if (!(fbi->var.sync & FB_SYNC_OE_LOW_ACT)) + sig_cfg.enable_pol = true; + if (fbi->var.sync & FB_SYNC_CLK_IDLE_EN) + sig_cfg.clkidle_en = true; + + debug("pixclock = %ul Hz\n", + (u32) (PICOS2KHZ(fbi->var.pixclock) * 1000UL)); + + if (ipu_init_sync_panel(mxc_fbi->ipu_di, + (PICOS2KHZ(fbi->var.pixclock)) * 1000UL, + fbi->var.xres, fbi->var.yres, + out_pixel_fmt, + fbi->var.left_margin, + fbi->var.hsync_len, + fbi->var.right_margin, + fbi->var.upper_margin, + fbi->var.vsync_len, + fbi->var.lower_margin, + 0, sig_cfg) != 0) { + puts("mxcfb: Error initializing panel.\n"); + return -EINVAL; + } + + retval = setup_disp_channel2(fbi); + if (retval) + return retval; + + if (mxc_fbi->blank == FB_BLANK_UNBLANK) { + ipu_enable_channel(mxc_fbi->ipu_ch); + } + + return retval; +} + +/* + * Check framebuffer variable parameters and adjust to valid values. + * + * @param var framebuffer variable parameters + * + * @param info framebuffer information pointer + */ +static int mxcfb_check_var(struct fb_var_screeninfo *var, struct fb_info *info) +{ + u32 vtotal; + u32 htotal; + + if (var->xres_virtual < var->xres) + var->xres_virtual = var->xres; + if (var->yres_virtual < var->yres) + var->yres_virtual = var->yres; + + if ((var->bits_per_pixel != 32) && (var->bits_per_pixel != 24) && + (var->bits_per_pixel != 16) && (var->bits_per_pixel != 8)) + var->bits_per_pixel = default_bpp; + + switch (var->bits_per_pixel) { + case 8: + var->red.length = 3; + var->red.offset = 5; + var->red.msb_right = 0; + + var->green.length = 3; + var->green.offset = 2; + var->green.msb_right = 0; + + var->blue.length = 2; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 0; + var->transp.offset = 0; + var->transp.msb_right = 0; + break; + case 16: + var->red.length = 5; + var->red.offset = 11; + var->red.msb_right = 0; + + var->green.length = 6; + var->green.offset = 5; + var->green.msb_right = 0; + + var->blue.length = 5; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 0; + var->transp.offset = 0; + var->transp.msb_right = 0; + break; + case 24: + var->red.length = 8; + var->red.offset = 16; + var->red.msb_right = 0; + + var->green.length = 8; + var->green.offset = 8; + var->green.msb_right = 0; + + var->blue.length = 8; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 0; + var->transp.offset = 0; + var->transp.msb_right = 0; + break; + case 32: + var->red.length = 8; + var->red.offset = 16; + var->red.msb_right = 0; + + var->green.length = 8; + var->green.offset = 8; + var->green.msb_right = 0; + + var->blue.length = 8; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 8; + var->transp.offset = 24; + var->transp.msb_right = 0; + break; + } + + if (var->pixclock < 1000) { + htotal = var->xres + var->right_margin + var->hsync_len + + var->left_margin; + vtotal = var->yres + var->lower_margin + var->vsync_len + + var->upper_margin; + var->pixclock = (vtotal * htotal * 6UL) / 100UL; + var->pixclock = KHZ2PICOS(var->pixclock); + printf("pixclock set for 60Hz refresh = %u ps\n", + var->pixclock); + } + + var->height = -1; + var->width = -1; + var->grayscale = 0; + + return 0; +} + +/* + * Allocates the DRAM memory for the frame buffer. This buffer is remapped + * into a non-cached, non-buffered, memory region to allow palette and pixel + * writes to occur without flushing the cache. Once this area is remapped, + * all virtual memory access to the video memory should occur at the new region. + * + * @param fbi framebuffer information pointer + * + * @return Error code indicating success or failure + */ +static int mxcfb_map_video_memory(struct fb_info *fbi) +{ + if (fbi->fix.smem_len < fbi->var.yres_virtual * fbi->fix.line_length) + fbi->fix.smem_len = fbi->var.yres_virtual * + fbi->fix.line_length; + + fbi->screen_base = (char *)lcd_base; + fbi->fix.smem_start = (unsigned long)lcd_base; + if (fbi->screen_base == 0) { + puts("Unable to allocate framebuffer memory\n"); + fbi->fix.smem_len = 0; + fbi->fix.smem_start = 0; + return -EBUSY; + } + + debug("allocated fb @ paddr=0x%08X, size=%d.\n", + (uint32_t) fbi->fix.smem_start, fbi->fix.smem_len); + + fbi->screen_size = fbi->fix.smem_len; + + /* Clear the screen */ + memset((char *)fbi->screen_base, 0, fbi->fix.smem_len); + + return 0; +} + +/* + * De-allocates the DRAM memory for the frame buffer. + * + * @param fbi framebuffer information pointer + * + * @return Error code indicating success or failure + */ +static int mxcfb_unmap_video_memory(struct fb_info *fbi) +{ + fbi->screen_base = 0; + fbi->fix.smem_start = 0; + fbi->fix.smem_len = 0; + return 0; +} + +/* + * Initializes the framebuffer information pointer. After allocating + * sufficient memory for the framebuffer structure, the fields are + * filled with custom information passed in from the configurable + * structures. This includes information such as bits per pixel, + * color maps, screen width/height and RGBA offsets. + * + * @return Framebuffer structure initialized with our information + */ +static struct fb_info *mxcfb_init_fbinfo(void) +{ +#define BYTES_PER_LONG 4 +#define PADDING (BYTES_PER_LONG - (sizeof(struct fb_info) % BYTES_PER_LONG)) + struct fb_info *fbi; + struct mxcfb_info *mxcfbi; + char *p; + int size = sizeof(struct mxcfb_info) + PADDING + + sizeof(struct fb_info); + + debug("%s: %d %d %d %d\n", + __func__, + PADDING, + size, + sizeof(struct mxcfb_info), + sizeof(struct fb_info)); + /* + * Allocate sufficient memory for the fb structure + */ + + p = malloc(size); + if (!p) + return NULL; + + memset(p, 0, size); + + fbi = (struct fb_info *)p; + fbi->par = p + sizeof(struct fb_info) + PADDING; + + mxcfbi = (struct mxcfb_info *)fbi->par; + debug("Framebuffer structures at: fbi=0x%x mxcfbi=0x%x\n", + (unsigned int)fbi, (unsigned int)mxcfbi); + + fbi->var.activate = FB_ACTIVATE_NOW; + + fbi->flags = FBINFO_FLAG_DEFAULT; + fbi->pseudo_palette = mxcfbi->pseudo_palette; + + return fbi; +} + +/* + * Probe routine for the framebuffer driver. It is called during the + * driver binding process. The following functions are performed in + * this routine: Framebuffer initialization, Memory allocation and + * mapping, Framebuffer registration, IPU initialization. + * + * @return Appropriate error code to the kernel common code + */ +static int mxcfb_probe(u32 interface_pix_fmt, struct fb_videomode *mode) +{ + struct fb_info *fbi; + struct mxcfb_info *mxcfbi; + int ret = 0; + + /* + * Initialize FB structures + */ + fbi = mxcfb_init_fbinfo(); + if (!fbi) { + ret = -ENOMEM; + goto err0; + } + mxcfbi = (struct mxcfb_info *)fbi->par; + + if (!g_dp_in_use) { + mxcfbi->ipu_ch = MEM_BG_SYNC; + mxcfbi->blank = FB_BLANK_UNBLANK; + } else { + mxcfbi->ipu_ch = MEM_DC_SYNC; + mxcfbi->blank = FB_BLANK_POWERDOWN; + } + + mxcfbi->ipu_di = 0; + + ipu_disp_set_global_alpha(mxcfbi->ipu_ch, true, 0x80); + ipu_disp_set_color_key(mxcfbi->ipu_ch, false, 0); + strcpy(fbi->fix.id, "DISP3 BG"); + + g_dp_in_use = true; + + mxcfb_info[mxcfbi->ipu_di] = fbi; + + /* Need dummy values until real panel is configured */ + fbi->var.xres = 640; + fbi->var.yres = 480; + fbi->var.bits_per_pixel = 16; + + mxcfbi->ipu_di_pix_fmt = interface_pix_fmt; + fb_videomode_to_var(&fbi->var, mode); + + mxcfb_check_var(&fbi->var, fbi); + + /* Default Y virtual size is 2x panel size */ + fbi->var.yres_virtual = fbi->var.yres * 2; + + mxcfb_set_fix(fbi); + + /* alocate fb first */ + if (mxcfb_map_video_memory(fbi) < 0) + return -ENOMEM; + + mxcfb_set_par(fbi); + + /* Setting panel_info for lcd */ + panel_info.cmap = NULL; + panel_info.vl_col = fbi->var.xres; + panel_info.vl_row = fbi->var.yres; + panel_info.vl_bpix = LCD_BPP; + + lcd_line_length = (panel_info.vl_col * NBITS(panel_info.vl_bpix)) / 8; + + debug("MXC IPUV3 configured\n" + "XRES = %d YRES = %d BitsXpixel = %d\n", + panel_info.vl_col, + panel_info.vl_row, + panel_info.vl_bpix); + + ipu_dump_registers(); + + return 0; + +err0: + return ret; +} + +int overwrite_console(void) +{ + /* Keep stdout / stderr on serial, our LCD is for splashscreen only */ + return 1; +} + +void lcd_ctrl_init(void *lcdbase) +{ + u32 mem_len = panel_info.vl_col * + panel_info.vl_row * + NBITS(panel_info.vl_bpix) / 8; + + /* + * We rely on lcdbase being a physical address, i.e., either MMU off, + * or 1-to-1 mapping. Might want to add some virt2phys here. + */ + if (!lcdbase) + return; + + memset(lcdbase, 0, mem_len); +} + +int mx51_fb_init(struct fb_videomode *mode) +{ + int ret; + + ret = ipu_probe(); + if (ret) { + puts("Error initializing IPU\n"); + } + + + lcd_base += 56; + + debug("Framebuffet at 0x%x\n", (unsigned int)lcd_base); + ret = mxcfb_probe(IPU_PIX_FMT_RGB666, mode); + + return ret; +} diff --git a/drivers/video/mxcfb.h b/drivers/video/mxcfb.h new file mode 100644 index 0000000..e1c1d72 --- /dev/null +++ b/drivers/video/mxcfb.h @@ -0,0 +1,78 @@ +/* + * Copyright 2004-2009 Freescale Semiconductor, Inc. All Rights Reserved. + */ + +/* + * The code contained herein is licensed under the GNU Lesser General + * Public License. You may obtain a copy of the GNU Lesser General + * Public License Version 2.1 or later at the following locations: + * + * http://www.opensource.org/licenses/lgpl-license.html + * http://www.gnu.org/copyleft/lgpl.html + */ + +/* + * @file arch-mxc/ mxcfb.h + * + * @brief Global header file for the MXC Frame buffer + * + * @ingroup Framebuffer + */ +#ifndef __ASM_ARCH_MXCFB_H__ +#define __ASM_ARCH_MXCFB_H__ + +#define FB_SYNC_OE_LOW_ACT 0x80000000 +#define FB_SYNC_CLK_LAT_FALL 0x40000000 +#define FB_SYNC_DATA_INVERT 0x20000000 +#define FB_SYNC_CLK_IDLE_EN 0x10000000 +#define FB_SYNC_SHARP_MODE 0x08000000 +#define FB_SYNC_SWAP_RGB 0x04000000 + +struct mxcfb_gbl_alpha { + int enable; + int alpha; +}; + +struct mxcfb_loc_alpha { + int enable; + int alpha_in_pixel; + unsigned long alpha_phy_addr0; + unsigned long alpha_phy_addr1; +}; + +struct mxcfb_color_key { + int enable; + __u32 color_key; +}; + +struct mxcfb_pos { + __u16 x; + __u16 y; +}; + +struct mxcfb_gamma { + int enable; + int constk[16]; + int slopek[16]; +}; + +#ifdef __KERNEL__ + +extern struct fb_videomode mxcfb_modedb[]; +extern int mxcfb_modedb_sz; + +enum { + MXCFB_REFRESH_OFF, + MXCFB_REFRESH_AUTO, + MXCFB_REFRESH_PARTIAL, +}; + +struct mxcfb_rect { + u32 top; + u32 left; + u32 width; + u32 height; +}; + +#endif /* __KERNEL__ */ +#endif
The patch adds support for LCD to the vision board.
Signed-off-by: Stefano Babic sbabic@denx.de --- board/ttcontrol/vision2/vision2.c | 69 +++++++++++++++++++++++++++++++++++++ include/configs/vision2.h | 15 ++++++++ 2 files changed, 84 insertions(+), 0 deletions(-)
diff --git a/board/ttcontrol/vision2/vision2.c b/board/ttcontrol/vision2/vision2.c index c991ee2..c3e6c70 100644 --- a/board/ttcontrol/vision2/vision2.c +++ b/board/ttcontrol/vision2/vision2.c @@ -37,14 +37,34 @@ #include <fsl_esdhc.h> #include <fsl_pmic.h> #include <mc13892.h> +#include <linux/fb.h>
static u32 system_rev;
+extern int mx51_fb_init(struct fb_videomode *mode); + #ifdef CONFIG_HW_WATCHDOG #include <watchdog.h>
+static struct fb_videomode nec_nl6448bc26_09c = { + "NEC_NL6448BC26-09C", + 60, /* Refresh */ + 640, /* xres */ + 480, /* yres */ + 37650, /* pixclock = 26.56Mhz */ + 48, /* left margin */ + 16, /* right margin */ + 31, /* upper margin */ + 12, /* lower margin */ + 96, /* hsync-len */ + 2, /* vsync-len */ + 0, /* sync */ + FB_VMODE_NONINTERLACED, /* vmode */ + 0, /* flag */ +}; + void hw_watchdog_reset(void) { int val; @@ -423,6 +443,9 @@ static void setup_gpios(void) mxc_request_iomux(MX51_PIN_CSPI1_RDY, IOMUX_CONFIG_ALT3); mxc_iomux_set_pad(MX51_PIN_CSPI1_RDY, 0x82);
+ /* PWM Output GPIO1_2 */ + mxc_request_iomux(MX51_PIN_GPIO1_2, IOMUX_CONFIG_ALT1); + /* * Set GPIO1_4 to high and output; it is used to reset * the system on reboot @@ -630,6 +653,34 @@ int board_early_init_f(void) return 0; }
+static void backlight(int on) +{ + if (on) { + mxc_gpio_set(65, 1); + udelay(10000); + mxc_gpio_set(68, 1); + } else { + mxc_gpio_set(65, 0); + mxc_gpio_set(68, 0); + } +} + +void lcd_enable(void) +{ + int ret; + + mxc_request_iomux(MX51_PIN_DI1_PIN2, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_DI1_PIN3, IOMUX_CONFIG_ALT0); + + mxc_gpio_set(2, 1); + mxc_request_iomux(MX51_PIN_GPIO1_2, IOMUX_CONFIG_ALT0); + + ret = mx51_fb_init(&nec_nl6448bc26_09c); + if (ret) { + puts("LCD cannot be configured\n"); + } +} + int board_init(void) { #ifdef CONFIG_SYS_ARM_WITHOUT_RELOC @@ -709,3 +760,21 @@ int checkboard(void) return 0; }
+int do_vision_lcd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int on; + + if (argc < 2) + return cmd_usage(cmdtp); + + on = (strcmp(argv[1], "on") == 0); + backlight(on); + + return 0; +} + +U_BOOT_CMD( + lcdbl, CONFIG_SYS_MAXARGS, 1, do_vision_lcd, + "Vision2 Backlight", + "lcdbl [on|off]\n" +); diff --git a/include/configs/vision2.h b/include/configs/vision2.h index 1f73c71..5710375 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -212,6 +212,21 @@ #define CONFIG_SYS_CLKTL_CBCDR 0x19239100
/* + * Framebuffer and LCD + */ +#define CONFIG_PREBOOT +#define CONFIG_LCD +#define CONFIG_VIDEO_MX5 +#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define LCD_BPP LCD_COLOR16 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_CMD_BMP +#define CONFIG_BMP_16BPP +#define CMD_DISPLAY + +/* * NAND FLASH driver setup */ #define CONFIG_CMD_NAND
Dear Stefano Babic,
Normally one defines a default command here ?
CONFIG_CMD_DISPLAY ???
Am 12.10.2010 13:37, schrieb Wolfgang Denk:
Dear Stefano Babic,
Probably I misunderstand its usage, but my intention is to enable the PREBOOT feature, but let the user to decide with the "preboot" variable if it is required or not. In my case for this board, I use it to load an image from a NAND device, as "splashimage" can be used only with an address.
In common/main.c:
#ifdef CONFIG_PREBOOT if ((p = getenv ("preboot")) != NULL) {
So I need to set this config even without a value if I would like to use it later setting the "preboot" variable.
This is wrong ! Thanks, I forget to remove it.
Stefano
Dear stefano babic,
No, you did not misinderstand. Everything is fine if this was your intention. I just wantred to make that sure, as most people define some default command here.
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes since V1: - Remove wrong CONFIG_CMD_DISPLAY
board/ttcontrol/vision2/vision2.c | 69 +++++++++++++++++++++++++++++++++++++ include/configs/vision2.h | 14 +++++++ 2 files changed, 83 insertions(+), 0 deletions(-)
+int do_vision_lcd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int on; + + if (argc < 2) + return cmd_usage(cmdtp); + + on = (strcmp(argv[1], "on") == 0); + backlight(on); + + return 0; +} + +U_BOOT_CMD( + lcdbl, CONFIG_SYS_MAXARGS, 1, do_vision_lcd, + "Vision2 Backlight", + "lcdbl [on|off]\n" +); diff --git a/include/configs/vision2.h b/include/configs/vision2.h index 1f73c71..e23bdd2 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -212,6 +212,20 @@ #define CONFIG_SYS_CLKTL_CBCDR 0x19239100
/* + * Framebuffer and LCD + */ +#define CONFIG_PREBOOT +#define CONFIG_LCD +#define CONFIG_VIDEO_MX5 +#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define LCD_BPP LCD_COLOR16 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_CMD_BMP +#define CONFIG_BMP_16BPP + +/* * NAND FLASH driver setup */ #define CONFIG_CMD_NAND
Changes since V1:
This one is dropped since it is replaced by rebased patch.
Best regards, Anatolij
Dear Stefano Babic,
Please add reference to original sources.
- Allocates the DRAM memory for the frame buffer. This buffer is remapped
- into a non-cached, non-buffered, memory region to allow palette and pixel
- writes to occur without flushing the cache. Once this area is remapped,
- all virtual memory access to the video memory should occur at the new region.
Is this comment still valid for the U-Boot port?
Does it work with both "dcache on" and "dcache off" settings?
Wolfgang Denk wrote:
Dear Stefano Babic,
Ok
No, it is not. The comment makes no sense for u-boot. There is no allocation and malloc is not called, as the memory for the framebuffer is taken from the lcd_base variable.
Well, as there is not yet support for L2-Cache on the MX51, we can say yes ;-). However, this range of memory is used directly from the IPU processor and not by the CPU, as well as in Linux without calling any function to invalidate the cache. But I agree, it should be tested again when support for L2-cache will be integrated.
Stefano
Dear stefano babic,
What about L1 cache? Have Heiko's chache patches been adapted for MX5 yet?
On 10/12/2010 05:12 PM, Wolfgang Denk wrote:
Dear stefano babic,
No, they are not - however, probably the cache functions in arch/arm/cpu/omap3 can be reused for the i.MX51, too.
Stefano
Add framebuffer driver for the MX51 processor working on the IPUv3 internal graphic processor. The port is based on the driver found in the kernel delivered by Freescale as part of i.MX BSP:
[kernel 2.6.31 commit cc4fe714041805997b601fe8e5dd585d8a99297f]
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes since V1: - added precise reference to the kernel version used for porting in the commit message - correct multiline comments - drop wrong comments (useful only in the kernel, not in u-boot)
drivers/video/Makefile | 1 + drivers/video/mxc_ipuv3_fb.c | 644 ++++++++++++++++++++++++++++++++++++++++++ drivers/video/mxcfb.h | 87 ++++++ 3 files changed, 732 insertions(+), 0 deletions(-) create mode 100644 drivers/video/mxc_ipuv3_fb.c create mode 100644 drivers/video/mxcfb.h
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4be82e7..5b7b261 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o COBJS-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o +COBJS-$(CONFIG_VIDEO_MX5) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o COBJS-$(CONFIG_SED156X) += sed156x.o COBJS-$(CONFIG_VIDEO_SM501) += sm501.o diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c new file mode 100644 index 0000000..108f035 --- /dev/null +++ b/drivers/video/mxc_ipuv3_fb.c @@ -0,0 +1,644 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * MX51 Linux framebuffer: + * + * (C) Copyright 2004-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ +#include <common.h> +#include <asm/errno.h> +#include <linux/string.h> +#include <linux/list.h> +#include <linux/fb.h> +#include <asm/io.h> +#include <malloc.h> +#include <lcd.h> +#include "videomodes.h" +#include "ipu.h" +#include "mxcfb.h" + +DECLARE_GLOBAL_DATA_PTR; + +void *lcd_base; /* Start of framebuffer memory */ +void *lcd_console_address; /* Start of console buffer */ + +int lcd_line_length; +int lcd_color_fg; +int lcd_color_bg; + +short console_col; +short console_row; + +vidinfo_t panel_info; + +static int mxcfb_map_video_memory(struct fb_info *fbi); +static int mxcfb_unmap_video_memory(struct fb_info *fbi); + +void lcd_initcolregs(void) +{ +} + +void lcd_setcolreg(ushort regno, ushort red, ushort green, ushort blue) +{ +} + +void lcd_disable(void) +{ +} + +void lcd_panel_disable(void) +{ +} + +void fb_videomode_to_var(struct fb_var_screeninfo *var, + const struct fb_videomode *mode) +{ + var->xres = mode->xres; + var->yres = mode->yres; + var->xres_virtual = mode->xres; + var->yres_virtual = mode->yres; + var->xoffset = 0; + var->yoffset = 0; + var->pixclock = mode->pixclock; + var->left_margin = mode->left_margin; + var->right_margin = mode->right_margin; + var->upper_margin = mode->upper_margin; + var->lower_margin = mode->lower_margin; + var->hsync_len = mode->hsync_len; + var->vsync_len = mode->vsync_len; + var->sync = mode->sync; + var->vmode = mode->vmode & FB_VMODE_MASK; +} + +/* + * Structure containing the MXC specific framebuffer information. + */ +struct mxcfb_info { + int blank; + ipu_channel_t ipu_ch; + int ipu_di; + u32 ipu_di_pix_fmt; + unsigned char overlay; + unsigned char alpha_chan_en; + dma_addr_t alpha_phy_addr0; + dma_addr_t alpha_phy_addr1; + void *alpha_virt_addr0; + void *alpha_virt_addr1; + uint32_t alpha_mem_len; + uint32_t cur_ipu_buf; + uint32_t cur_ipu_alpha_buf; + + u32 pseudo_palette[16]; +}; + +enum { + BOTH_ON, + SRC_ON, + TGT_ON, + BOTH_OFF +}; + +static unsigned long default_bpp = 16; +static unsigned char g_dp_in_use; +static struct fb_info *mxcfb_info[3]; +static int ext_clk_used; + +static uint32_t bpp_to_pixfmt(struct fb_info *fbi) +{ + uint32_t pixfmt = 0; + + debug("bpp_to_pixfmt: %d\n", fbi->var.bits_per_pixel); + + if (fbi->var.nonstd) + return fbi->var.nonstd; + + switch (fbi->var.bits_per_pixel) { + case 24: + pixfmt = IPU_PIX_FMT_BGR24; + break; + case 32: + pixfmt = IPU_PIX_FMT_BGR32; + break; + case 16: + pixfmt = IPU_PIX_FMT_RGB565; + break; + } + return pixfmt; +} + +/* + * Set fixed framebuffer parameters based on variable settings. + * + * @param info framebuffer information pointer + */ +static int mxcfb_set_fix(struct fb_info *info) +{ + struct fb_fix_screeninfo *fix = &info->fix; + struct fb_var_screeninfo *var = &info->var; + + fix->line_length = var->xres_virtual * var->bits_per_pixel / 8; + + fix->type = FB_TYPE_PACKED_PIXELS; + fix->accel = FB_ACCEL_NONE; + fix->visual = FB_VISUAL_TRUECOLOR; + fix->xpanstep = 1; + fix->ypanstep = 1; + + return 0; +} + +static int setup_disp_channel1(struct fb_info *fbi) +{ + ipu_channel_params_t params; + struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par; + + memset(¶ms, 0, sizeof(params)); + params.mem_dp_bg_sync.di = mxc_fbi->ipu_di; + + debug("%s called\n", __func__); + /* + * Assuming interlaced means yuv output, below setting also + * valid for mem_dc_sync. FG should have the same vmode as BG. + */ + if (fbi->var.vmode & FB_VMODE_INTERLACED) { + params.mem_dp_bg_sync.interlaced = 1; + params.mem_dp_bg_sync.out_pixel_fmt = + IPU_PIX_FMT_YUV444; + } else { + if (mxc_fbi->ipu_di_pix_fmt) + params.mem_dp_bg_sync.out_pixel_fmt = + mxc_fbi->ipu_di_pix_fmt; + else + params.mem_dp_bg_sync.out_pixel_fmt = + IPU_PIX_FMT_RGB666; + } + params.mem_dp_bg_sync.in_pixel_fmt = bpp_to_pixfmt(fbi); + if (mxc_fbi->alpha_chan_en) + params.mem_dp_bg_sync.alpha_chan_en = 1; + + ipu_init_channel(mxc_fbi->ipu_ch, ¶ms); + + return 0; +} + +static int setup_disp_channel2(struct fb_info *fbi) +{ + int retval = 0; + struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par; + + mxc_fbi->cur_ipu_buf = 1; + if (mxc_fbi->alpha_chan_en) { + mxc_fbi->cur_ipu_alpha_buf = 1; + } + fbi->var.xoffset = fbi->var.yoffset = 0; + + debug("%s: %x %d %d %d %lx %lx\n", + __func__, + mxc_fbi->ipu_ch, + fbi->var.xres, + fbi->var.yres, + fbi->fix.line_length, + fbi->fix.smem_start, + fbi->fix.smem_start + + (fbi->fix.line_length * fbi->var.yres)); + + retval = ipu_init_channel_buffer(mxc_fbi->ipu_ch, IPU_INPUT_BUFFER, + bpp_to_pixfmt(fbi), + fbi->var.xres, fbi->var.yres, + fbi->fix.line_length, + fbi->fix.smem_start + + (fbi->fix.line_length * fbi->var.yres), + fbi->fix.smem_start, + 0, 0); + if (retval) { + printf("ipu_init_channel_buffer error %d\n", retval); + } + + return retval; +} + +/* + * Set framebuffer parameters and change the operating mode. + * + * @param info framebuffer information pointer + */ +static int mxcfb_set_par(struct fb_info *fbi) +{ + int retval = 0; + u32 mem_len; + ipu_di_signal_cfg_t sig_cfg; + struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par; + uint32_t out_pixel_fmt; + + ipu_disable_channel(mxc_fbi->ipu_ch); + ipu_uninit_channel(mxc_fbi->ipu_ch); + mxcfb_set_fix(fbi); + + mem_len = fbi->var.yres_virtual * fbi->fix.line_length; + if (!fbi->fix.smem_start || (mem_len > fbi->fix.smem_len)) { + if (fbi->fix.smem_start) + mxcfb_unmap_video_memory(fbi); + + if (mxcfb_map_video_memory(fbi) < 0) + return -ENOMEM; + } + + setup_disp_channel1(fbi); + + memset(&sig_cfg, 0, sizeof(sig_cfg)); + if (fbi->var.vmode & FB_VMODE_INTERLACED) { + sig_cfg.interlaced = 1; + out_pixel_fmt = IPU_PIX_FMT_YUV444; + } else { + if (mxc_fbi->ipu_di_pix_fmt) + out_pixel_fmt = mxc_fbi->ipu_di_pix_fmt; + else + out_pixel_fmt = IPU_PIX_FMT_RGB666; + } + if (fbi->var.vmode & FB_VMODE_ODD_FLD_FIRST) /* PAL */ + sig_cfg.odd_field_first = 1; + if ((fbi->var.sync & FB_SYNC_EXT) || ext_clk_used) + sig_cfg.ext_clk = 1; + if (fbi->var.sync & FB_SYNC_HOR_HIGH_ACT) + sig_cfg.Hsync_pol = 1; + if (fbi->var.sync & FB_SYNC_VERT_HIGH_ACT) + sig_cfg.Vsync_pol = 1; + if (!(fbi->var.sync & FB_SYNC_CLK_LAT_FALL)) + sig_cfg.clk_pol = 1; + if (fbi->var.sync & FB_SYNC_DATA_INVERT) + sig_cfg.data_pol = 1; + if (!(fbi->var.sync & FB_SYNC_OE_LOW_ACT)) + sig_cfg.enable_pol = 1; + if (fbi->var.sync & FB_SYNC_CLK_IDLE_EN) + sig_cfg.clkidle_en = 1; + + debug("pixclock = %ul Hz\n", + (u32) (PICOS2KHZ(fbi->var.pixclock) * 1000UL)); + + if (ipu_init_sync_panel(mxc_fbi->ipu_di, + (PICOS2KHZ(fbi->var.pixclock)) * 1000UL, + fbi->var.xres, fbi->var.yres, + out_pixel_fmt, + fbi->var.left_margin, + fbi->var.hsync_len, + fbi->var.right_margin, + fbi->var.upper_margin, + fbi->var.vsync_len, + fbi->var.lower_margin, + 0, sig_cfg) != 0) { + puts("mxcfb: Error initializing panel.\n"); + return -EINVAL; + } + + retval = setup_disp_channel2(fbi); + if (retval) + return retval; + + if (mxc_fbi->blank == FB_BLANK_UNBLANK) { + ipu_enable_channel(mxc_fbi->ipu_ch); + } + + return retval; +} + +/* + * Check framebuffer variable parameters and adjust to valid values. + * + * @param var framebuffer variable parameters + * + * @param info framebuffer information pointer + */ +static int mxcfb_check_var(struct fb_var_screeninfo *var, struct fb_info *info) +{ + u32 vtotal; + u32 htotal; + + if (var->xres_virtual < var->xres) + var->xres_virtual = var->xres; + if (var->yres_virtual < var->yres) + var->yres_virtual = var->yres; + + if ((var->bits_per_pixel != 32) && (var->bits_per_pixel != 24) && + (var->bits_per_pixel != 16) && (var->bits_per_pixel != 8)) + var->bits_per_pixel = default_bpp; + + switch (var->bits_per_pixel) { + case 8: + var->red.length = 3; + var->red.offset = 5; + var->red.msb_right = 0; + + var->green.length = 3; + var->green.offset = 2; + var->green.msb_right = 0; + + var->blue.length = 2; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 0; + var->transp.offset = 0; + var->transp.msb_right = 0; + break; + case 16: + var->red.length = 5; + var->red.offset = 11; + var->red.msb_right = 0; + + var->green.length = 6; + var->green.offset = 5; + var->green.msb_right = 0; + + var->blue.length = 5; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 0; + var->transp.offset = 0; + var->transp.msb_right = 0; + break; + case 24: + var->red.length = 8; + var->red.offset = 16; + var->red.msb_right = 0; + + var->green.length = 8; + var->green.offset = 8; + var->green.msb_right = 0; + + var->blue.length = 8; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 0; + var->transp.offset = 0; + var->transp.msb_right = 0; + break; + case 32: + var->red.length = 8; + var->red.offset = 16; + var->red.msb_right = 0; + + var->green.length = 8; + var->green.offset = 8; + var->green.msb_right = 0; + + var->blue.length = 8; + var->blue.offset = 0; + var->blue.msb_right = 0; + + var->transp.length = 8; + var->transp.offset = 24; + var->transp.msb_right = 0; + break; + } + + if (var->pixclock < 1000) { + htotal = var->xres + var->right_margin + var->hsync_len + + var->left_margin; + vtotal = var->yres + var->lower_margin + var->vsync_len + + var->upper_margin; + var->pixclock = (vtotal * htotal * 6UL) / 100UL; + var->pixclock = KHZ2PICOS(var->pixclock); + printf("pixclock set for 60Hz refresh = %u ps\n", + var->pixclock); + } + + var->height = -1; + var->width = -1; + var->grayscale = 0; + + return 0; +} + +static int mxcfb_map_video_memory(struct fb_info *fbi) +{ + if (fbi->fix.smem_len < fbi->var.yres_virtual * fbi->fix.line_length) + fbi->fix.smem_len = fbi->var.yres_virtual * + fbi->fix.line_length; + + fbi->screen_base = (char *)lcd_base; + fbi->fix.smem_start = (unsigned long)lcd_base; + if (fbi->screen_base == 0) { + puts("Unable to allocate framebuffer memory\n"); + fbi->fix.smem_len = 0; + fbi->fix.smem_start = 0; + return -EBUSY; + } + + debug("allocated fb @ paddr=0x%08X, size=%d.\n", + (uint32_t) fbi->fix.smem_start, fbi->fix.smem_len); + + fbi->screen_size = fbi->fix.smem_len; + + /* Clear the screen */ + memset((char *)fbi->screen_base, 0, fbi->fix.smem_len); + + return 0; +} + +static int mxcfb_unmap_video_memory(struct fb_info *fbi) +{ + fbi->screen_base = 0; + fbi->fix.smem_start = 0; + fbi->fix.smem_len = 0; + return 0; +} + +/* + * Initializes the framebuffer information pointer. After allocating + * sufficient memory for the framebuffer structure, the fields are + * filled with custom information passed in from the configurable + * structures. This includes information such as bits per pixel, + * color maps, screen width/height and RGBA offsets. + * + * @return Framebuffer structure initialized with our information + */ +static struct fb_info *mxcfb_init_fbinfo(void) +{ +#define BYTES_PER_LONG 4 +#define PADDING (BYTES_PER_LONG - (sizeof(struct fb_info) % BYTES_PER_LONG)) + struct fb_info *fbi; + struct mxcfb_info *mxcfbi; + char *p; + int size = sizeof(struct mxcfb_info) + PADDING + + sizeof(struct fb_info); + + debug("%s: %d %d %d %d\n", + __func__, + PADDING, + size, + sizeof(struct mxcfb_info), + sizeof(struct fb_info)); + /* + * Allocate sufficient memory for the fb structure + */ + + p = malloc(size); + if (!p) + return NULL; + + memset(p, 0, size); + + fbi = (struct fb_info *)p; + fbi->par = p + sizeof(struct fb_info) + PADDING; + + mxcfbi = (struct mxcfb_info *)fbi->par; + debug("Framebuffer structures at: fbi=0x%x mxcfbi=0x%x\n", + (unsigned int)fbi, (unsigned int)mxcfbi); + + fbi->var.activate = FB_ACTIVATE_NOW; + + fbi->flags = FBINFO_FLAG_DEFAULT; + fbi->pseudo_palette = mxcfbi->pseudo_palette; + + return fbi; +} + +/* + * Probe routine for the framebuffer driver. It is called during the + * driver binding process. The following functions are performed in + * this routine: Framebuffer initialization, Memory allocation and + * mapping, Framebuffer registration, IPU initialization. + * + * @return Appropriate error code to the kernel common code + */ +static int mxcfb_probe(u32 interface_pix_fmt, struct fb_videomode *mode) +{ + struct fb_info *fbi; + struct mxcfb_info *mxcfbi; + int ret = 0; + + /* + * Initialize FB structures + */ + fbi = mxcfb_init_fbinfo(); + if (!fbi) { + ret = -ENOMEM; + goto err0; + } + mxcfbi = (struct mxcfb_info *)fbi->par; + + if (!g_dp_in_use) { + mxcfbi->ipu_ch = MEM_BG_SYNC; + mxcfbi->blank = FB_BLANK_UNBLANK; + } else { + mxcfbi->ipu_ch = MEM_DC_SYNC; + mxcfbi->blank = FB_BLANK_POWERDOWN; + } + + mxcfbi->ipu_di = 0; + + ipu_disp_set_global_alpha(mxcfbi->ipu_ch, 1, 0x80); + ipu_disp_set_color_key(mxcfbi->ipu_ch, 0, 0); + strcpy(fbi->fix.id, "DISP3 BG"); + + g_dp_in_use = 1; + + mxcfb_info[mxcfbi->ipu_di] = fbi; + + /* Need dummy values until real panel is configured */ + fbi->var.xres = 640; + fbi->var.yres = 480; + fbi->var.bits_per_pixel = 16; + + mxcfbi->ipu_di_pix_fmt = interface_pix_fmt; + fb_videomode_to_var(&fbi->var, mode); + + mxcfb_check_var(&fbi->var, fbi); + + /* Default Y virtual size is 2x panel size */ + fbi->var.yres_virtual = fbi->var.yres * 2; + + mxcfb_set_fix(fbi); + + /* alocate fb first */ + if (mxcfb_map_video_memory(fbi) < 0) + return -ENOMEM; + + mxcfb_set_par(fbi); + + /* Setting panel_info for lcd */ + panel_info.cmap = NULL; + panel_info.vl_col = fbi->var.xres; + panel_info.vl_row = fbi->var.yres; + panel_info.vl_bpix = LCD_BPP; + + lcd_line_length = (panel_info.vl_col * NBITS(panel_info.vl_bpix)) / 8; + + debug("MXC IPUV3 configured\n" + "XRES = %d YRES = %d BitsXpixel = %d\n", + panel_info.vl_col, + panel_info.vl_row, + panel_info.vl_bpix); + + ipu_dump_registers(); + + return 0; + +err0: + return ret; +} + +int overwrite_console(void) +{ + /* Keep stdout / stderr on serial, our LCD is for splashscreen only */ + return 1; +} + +void lcd_ctrl_init(void *lcdbase) +{ + u32 mem_len = panel_info.vl_col * + panel_info.vl_row * + NBITS(panel_info.vl_bpix) / 8; + + /* + * We rely on lcdbase being a physical address, i.e., either MMU off, + * or 1-to-1 mapping. Might want to add some virt2phys here. + */ + if (!lcdbase) + return; + + memset(lcdbase, 0, mem_len); +} + +int mx51_fb_init(struct fb_videomode *mode) +{ + int ret; + + ret = ipu_probe(); + if (ret) { + puts("Error initializing IPU\n"); + } + + + lcd_base += 56; + + debug("Framebuffet at 0x%x\n", (unsigned int)lcd_base); + ret = mxcfb_probe(IPU_PIX_FMT_RGB666, mode); + + return ret; +} diff --git a/drivers/video/mxcfb.h b/drivers/video/mxcfb.h new file mode 100644 index 0000000..fd284a2 --- /dev/null +++ b/drivers/video/mxcfb.h @@ -0,0 +1,87 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2004-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_MXCFB_H__ +#define __ASM_ARCH_MXCFB_H__ + +#define FB_SYNC_OE_LOW_ACT 0x80000000 +#define FB_SYNC_CLK_LAT_FALL 0x40000000 +#define FB_SYNC_DATA_INVERT 0x20000000 +#define FB_SYNC_CLK_IDLE_EN 0x10000000 +#define FB_SYNC_SHARP_MODE 0x08000000 +#define FB_SYNC_SWAP_RGB 0x04000000 + +struct mxcfb_gbl_alpha { + int enable; + int alpha; +}; + +struct mxcfb_loc_alpha { + int enable; + int alpha_in_pixel; + unsigned long alpha_phy_addr0; + unsigned long alpha_phy_addr1; +}; + +struct mxcfb_color_key { + int enable; + __u32 color_key; +}; + +struct mxcfb_pos { + __u16 x; + __u16 y; +}; + +struct mxcfb_gamma { + int enable; + int constk[16]; + int slopek[16]; +}; + +#ifdef __KERNEL__ + +extern struct fb_videomode mxcfb_modedb[]; +extern int mxcfb_modedb_sz; + +enum { + MXCFB_REFRESH_OFF, + MXCFB_REFRESH_AUTO, + MXCFB_REFRESH_PARTIAL, +}; + +struct mxcfb_rect { + u32 top; + u32 left; + u32 width; + u32 height; +}; + +#endif /* __KERNEL__ */ +#endif
Changes since V1:
Applied to u-boot-video/master after some style fixes and dead code removal. Thanks!
Dear Stefano Babic,
In message 1286875504-9058-3-git-send-email-sbabic@denx.de you wrote:
The patch is a porting of the IPU Linux driver developed by Freescale to have framebuffer functionalities in u-boot. Most features are dropped from the original driver and only LCD support is the goal of this porting.
I don't know how close this is to the original Linux driver; eventually you should add a more precise reference to the original version in the commit message here, too.
--- /dev/null +++ b/drivers/video/ipu.h @@ -0,0 +1,316 @@
+typedef unsigned char bool; +#define true 1 +#define false 0
An, no. Can we please drop that.
+#define IDMA_CHAN_INVALID 0xFF +#define HIGH_RESOLUTION_WIDTH 1024
+struct clk {
- const char *name;
- int id;
- /* Source clock this clk depends on */
- struct clk *parent;
- /* Secondary clock to enable/disable with this clock */
- struct clk *secondary;
- /* Current clock rate */
- unsigned long rate;
- /* Reference count of clock enable/disable */
- __s8 usecount;
- /* Register bit position for clock's enable/disable control. */
- u8 enable_shift;
- /* Register address for clock's enable/disable control. */
- void *enable_reg;
- u32 flags;
- /* Function ptr to recalculate the clock's rate based on parent
clock's rate */
- void (*recalc) (struct clk *);
- /* Function ptr to set the clock to a new rate. The rate must match a
supported rate returned from round_rate. Leave blank if clock is not
programmable */
- int (*set_rate) (struct clk *, unsigned long);
- /* Function ptr to round the requested clock rate to the nearest
supported rate that is less than or equal to the requested rate. */
- unsigned long (*round_rate) (struct clk *, unsigned long);
- /* Function ptr to enable the clock. Leave blank if clock can not
be gated. */
- int (*enable) (struct clk *);
- /* Function ptr to disable the clock. Leave blank if clock can not
be gated. */
- void (*disable) (struct clk *);
- /* Function ptr to set the parent clock of the clock. */
- int (*set_parent) (struct clk *, struct clk *);
Incorrect multi-line comment style. Please fix globally. [or is the whole file a verbatim copy of the Linux file?]
+/* @} */ +/* @name YUV Planar Formats */ +/* @{ */
Oops. What's that?
Dear Stefano Babic,
The original driver is part of the Freescale's kernel for i.MX, based on the vanilla kernel 2.6.31. However, the code was not sent to LKML and it is not part of the kernel mainline. For this reason and because I dropped a lot of parts that I thought not useful in u-boot, this porting is not so close to the original one. I have already tried to fix all code styling issues, but it seems I missed a lot of them and I have to check them again. And of course, I will add the reference to the original code, too.
Yes, this was already in my list to drop. I missed it ;-)
No, I will fix them.
Oops. What's that?
A comment in the original code that I cannot understand and I have to drop ;-)
Best regards, Stefano Babic
The patch is a porting of the IPU Linux driver developed by Freescale to have framebuffer functionalities in u-boot. The port is based on kernel 2.6.31 commit cc4fe714041805997b601fe8e5dd585d8a99297f, as delivered by Freescale [i.MX BSP]. Most features are dropped from the original driver and only LCD support is the goal of this porting.
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes since V1: - added precise reference to the kernel version used for porting in the commit message - correct multiline comments - drop dummy true/false booleans
arch/arm/include/asm/arch-mx51/crm_regs.h | 11 + drivers/video/ipu.h | 321 +++++++ drivers/video/ipu_common.c | 1183 +++++++++++++++++++++++++ drivers/video/ipu_disp.c | 1359 +++++++++++++++++++++++++++++ drivers/video/ipu_regs.h | 418 +++++++++ 5 files changed, 3292 insertions(+), 0 deletions(-) create mode 100644 drivers/video/ipu.h create mode 100644 drivers/video/ipu_common.c create mode 100644 drivers/video/ipu_disp.c create mode 100644 drivers/video/ipu_regs.h
diff --git a/arch/arm/include/asm/arch-mx51/crm_regs.h b/arch/arm/include/asm/arch-mx51/crm_regs.h index 14aa231..4ed8eb3 100644 --- a/arch/arm/include/asm/arch-mx51/crm_regs.h +++ b/arch/arm/include/asm/arch-mx51/crm_regs.h @@ -189,4 +189,15 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0 #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x7
+/* Define the bits in register CCDR */ +#define MXC_CCM_CCDR_IPU_HS_MASK (0x1 << 17) + +/* Define the bits in register CCGRx */ +#define MXC_CCM_CCGR_CG_MASK 0x3 + +#define MXC_CCM_CCGR5_CG5_OFFSET 10 + +/* Define the bits in register CLPCR */ +#define MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS (0x1 << 18) + #endif /* __ARCH_ARM_MACH_MX51_CRM_REGS_H__ */ diff --git a/drivers/video/ipu.h b/drivers/video/ipu.h new file mode 100644 index 0000000..d8bc287 --- /dev/null +++ b/drivers/video/ipu.h @@ -0,0 +1,321 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_IPU_H__ +#define __ASM_ARCH_IPU_H__ + +#include <linux/types.h> + +#define IDMA_CHAN_INVALID 0xFF +#define HIGH_RESOLUTION_WIDTH 1024 + +struct clk { + const char *name; + int id; + /* Source clock this clk depends on */ + struct clk *parent; + /* Secondary clock to enable/disable with this clock */ + struct clk *secondary; + /* Current clock rate */ + unsigned long rate; + /* Reference count of clock enable/disable */ + __s8 usecount; + /* Register bit position for clock's enable/disable control. */ + u8 enable_shift; + /* Register address for clock's enable/disable control. */ + void *enable_reg; + u32 flags; + /* + * Function ptr to recalculate the clock's rate based on parent + * clock's rate + */ + void (*recalc) (struct clk *); + /* + * Function ptr to set the clock to a new rate. The rate must match a + * supported rate returned from round_rate. Leave blank if clock is not + * programmable + */ + int (*set_rate) (struct clk *, unsigned long); + /* + * Function ptr to round the requested clock rate to the nearest + * supported rate that is less than or equal to the requested rate. + */ + unsigned long (*round_rate) (struct clk *, unsigned long); + /* + * Function ptr to enable the clock. Leave blank if clock can not + * be gated. + */ + int (*enable) (struct clk *); + /* + * Function ptr to disable the clock. Leave blank if clock can not + * be gated. + */ + void (*disable) (struct clk *); + /* Function ptr to set the parent clock of the clock. */ + int (*set_parent) (struct clk *, struct clk *); +}; + +/* + * Enumeration of Synchronous (Memory-less) panel types + */ +typedef enum { + IPU_PANEL_SHARP_TFT, + IPU_PANEL_TFT, +} ipu_panel_t; + +/* IPU Pixel format definitions */ +#define fourcc(a, b, c, d)\ + (((__u32)(a)<<0)|((__u32)(b)<<8)|((__u32)(c)<<16)|((__u32)(d)<<24)) + +/* + * Pixel formats are defined with ASCII FOURCC code. The pixel format codes are + * the same used by V4L2 API. + */ + +#define IPU_PIX_FMT_GENERIC fourcc('I', 'P', 'U', '0') +#define IPU_PIX_FMT_GENERIC_32 fourcc('I', 'P', 'U', '1') +#define IPU_PIX_FMT_LVDS666 fourcc('L', 'V', 'D', '6') +#define IPU_PIX_FMT_LVDS888 fourcc('L', 'V', 'D', '8') + +#define IPU_PIX_FMT_RGB332 fourcc('R', 'G', 'B', '1') /*< 8 RGB-3-3-2 */ +#define IPU_PIX_FMT_RGB555 fourcc('R', 'G', 'B', 'O') /*< 16 RGB-5-5-5 */ +#define IPU_PIX_FMT_RGB565 fourcc('R', 'G', 'B', 'P') /*< 1 6 RGB-5-6-5 */ +#define IPU_PIX_FMT_RGB666 fourcc('R', 'G', 'B', '6') /*< 18 RGB-6-6-6 */ +#define IPU_PIX_FMT_BGR666 fourcc('B', 'G', 'R', '6') /*< 18 BGR-6-6-6 */ +#define IPU_PIX_FMT_BGR24 fourcc('B', 'G', 'R', '3') /*< 24 BGR-8-8-8 */ +#define IPU_PIX_FMT_RGB24 fourcc('R', 'G', 'B', '3') /*< 24 RGB-8-8-8 */ +#define IPU_PIX_FMT_BGR32 fourcc('B', 'G', 'R', '4') /*< 32 BGR-8-8-8-8 */ +#define IPU_PIX_FMT_BGRA32 fourcc('B', 'G', 'R', 'A') /*< 32 BGR-8-8-8-8 */ +#define IPU_PIX_FMT_RGB32 fourcc('R', 'G', 'B', '4') /*< 32 RGB-8-8-8-8 */ +#define IPU_PIX_FMT_RGBA32 fourcc('R', 'G', 'B', 'A') /*< 32 RGB-8-8-8-8 */ +#define IPU_PIX_FMT_ABGR32 fourcc('A', 'B', 'G', 'R') /*< 32 ABGR-8-8-8-8 */ + +/* YUV Interleaved Formats */ +#define IPU_PIX_FMT_YUYV fourcc('Y', 'U', 'Y', 'V') /*< 16 YUV 4:2:2 */ +#define IPU_PIX_FMT_UYVY fourcc('U', 'Y', 'V', 'Y') /*< 16 YUV 4:2:2 */ +#define IPU_PIX_FMT_Y41P fourcc('Y', '4', '1', 'P') /*< 12 YUV 4:1:1 */ +#define IPU_PIX_FMT_YUV444 fourcc('Y', '4', '4', '4') /*< 24 YUV 4:4:4 */ + +/* two planes -- one Y, one Cb + Cr interleaved */ +#define IPU_PIX_FMT_NV12 fourcc('N', 'V', '1', '2') /* 12 Y/CbCr 4:2:0 */ + +#define IPU_PIX_FMT_GREY fourcc('G', 'R', 'E', 'Y') /*< 8 Greyscale */ +#define IPU_PIX_FMT_YVU410P fourcc('Y', 'V', 'U', '9') /*< 9 YVU 4:1:0 */ +#define IPU_PIX_FMT_YUV410P fourcc('Y', 'U', 'V', '9') /*< 9 YUV 4:1:0 */ +#define IPU_PIX_FMT_YVU420P fourcc('Y', 'V', '1', '2') /*< 12 YVU 4:2:0 */ +#define IPU_PIX_FMT_YUV420P fourcc('I', '4', '2', '0') /*< 12 YUV 4:2:0 */ +#define IPU_PIX_FMT_YUV420P2 fourcc('Y', 'U', '1', '2') /*< 12 YUV 4:2:0 */ +#define IPU_PIX_FMT_YVU422P fourcc('Y', 'V', '1', '6') /*< 16 YVU 4:2:2 */ +#define IPU_PIX_FMT_YUV422P fourcc('4', '2', '2', 'P') /*< 16 YUV 4:2:2 */ + +/* + * IPU Driver channels definitions. + * Note these are different from IDMA channels + */ +#define IPU_MAX_CH 32 +#define _MAKE_CHAN(num, v_in, g_in, a_in, out) \ + ((num << 24) | (v_in << 18) | (g_in << 12) | (a_in << 6) | out) +#define _MAKE_ALT_CHAN(ch) (ch | (IPU_MAX_CH << 24)) +#define IPU_CHAN_ID(ch) (ch >> 24) +#define IPU_CHAN_ALT(ch) (ch & 0x02000000) +#define IPU_CHAN_ALPHA_IN_DMA(ch) ((uint32_t) (ch >> 6) & 0x3F) +#define IPU_CHAN_GRAPH_IN_DMA(ch) ((uint32_t) (ch >> 12) & 0x3F) +#define IPU_CHAN_VIDEO_IN_DMA(ch) ((uint32_t) (ch >> 18) & 0x3F) +#define IPU_CHAN_OUT_DMA(ch) ((uint32_t) (ch & 0x3F)) +#define NO_DMA 0x3F +#define ALT 1 + +/* + * Enumeration of IPU logical channels. An IPU logical channel is defined as a + * combination of an input (memory to IPU), output (IPU to memory), and/or + * secondary input IDMA channels and in some cases an Image Converter task. + * Some channels consist of only an input or output. + */ +typedef enum { + CHAN_NONE = -1, + + MEM_DC_SYNC = _MAKE_CHAN(7, 28, NO_DMA, NO_DMA, NO_DMA), + MEM_DC_ASYNC = _MAKE_CHAN(8, 41, NO_DMA, NO_DMA, NO_DMA), + MEM_BG_SYNC = _MAKE_CHAN(9, 23, NO_DMA, 51, NO_DMA), + MEM_FG_SYNC = _MAKE_CHAN(10, 27, NO_DMA, 31, NO_DMA), + + MEM_BG_ASYNC0 = _MAKE_CHAN(11, 24, NO_DMA, 52, NO_DMA), + MEM_FG_ASYNC0 = _MAKE_CHAN(12, 29, NO_DMA, 33, NO_DMA), + MEM_BG_ASYNC1 = _MAKE_ALT_CHAN(MEM_BG_ASYNC0), + MEM_FG_ASYNC1 = _MAKE_ALT_CHAN(MEM_FG_ASYNC0), + + DIRECT_ASYNC0 = _MAKE_CHAN(13, NO_DMA, NO_DMA, NO_DMA, NO_DMA), + DIRECT_ASYNC1 = _MAKE_CHAN(14, NO_DMA, NO_DMA, NO_DMA, NO_DMA), + +} ipu_channel_t; + +/* + * Enumeration of types of buffers for a logical channel. + */ +typedef enum { + IPU_OUTPUT_BUFFER = 0, /*< Buffer for output from IPU */ + IPU_ALPHA_IN_BUFFER = 1, /*< Buffer for input to IPU */ + IPU_GRAPH_IN_BUFFER = 2, /*< Buffer for input to IPU */ + IPU_VIDEO_IN_BUFFER = 3, /*< Buffer for input to IPU */ + IPU_INPUT_BUFFER = IPU_VIDEO_IN_BUFFER, + IPU_SEC_INPUT_BUFFER = IPU_GRAPH_IN_BUFFER, +} ipu_buffer_t; + +#define IPU_PANEL_SERIAL 1 +#define IPU_PANEL_PARALLEL 2 + +struct ipu_channel { + u8 video_in_dma; + u8 alpha_in_dma; + u8 graph_in_dma; + u8 out_dma; +}; + +enum ipu_dmfc_type { + DMFC_NORMAL = 0, + DMFC_HIGH_RESOLUTION_DC, + DMFC_HIGH_RESOLUTION_DP, + DMFC_HIGH_RESOLUTION_ONLY_DP, +}; + + +/* + * Union of initialization parameters for a logical channel. + */ +typedef union { + struct { + uint32_t di; + unsigned char interlaced; + } mem_dc_sync; + struct { + uint32_t temp; + } mem_sdc_fg; + struct { + uint32_t di; + unsigned char interlaced; + uint32_t in_pixel_fmt; + uint32_t out_pixel_fmt; + unsigned char alpha_chan_en; + } mem_dp_bg_sync; + struct { + uint32_t temp; + } mem_sdc_bg; + struct { + uint32_t di; + unsigned char interlaced; + uint32_t in_pixel_fmt; + uint32_t out_pixel_fmt; + unsigned char alpha_chan_en; + } mem_dp_fg_sync; +} ipu_channel_params_t; + +/* + * Bitfield of Display Interface signal polarities. + */ +typedef struct { + unsigned datamask_en:1; + unsigned ext_clk:1; + unsigned interlaced:1; + unsigned odd_field_first:1; + unsigned clksel_en:1; + unsigned clkidle_en:1; + unsigned data_pol:1; /* true = inverted */ + unsigned clk_pol:1; /* true = rising edge */ + unsigned enable_pol:1; + unsigned Hsync_pol:1; /* true = active high */ + unsigned Vsync_pol:1; +} ipu_di_signal_cfg_t; + +typedef enum { + RGB, + YCbCr, + YUV +} ipu_color_space_t; + +/* Common IPU API */ +int32_t ipu_init_channel(ipu_channel_t channel, ipu_channel_params_t *params); +void ipu_uninit_channel(ipu_channel_t channel); + +int32_t ipu_init_channel_buffer(ipu_channel_t channel, ipu_buffer_t type, + uint32_t pixel_fmt, + uint16_t width, uint16_t height, + uint32_t stride, + dma_addr_t phyaddr_0, dma_addr_t phyaddr_1, + uint32_t u_offset, uint32_t v_offset); + +int32_t ipu_update_channel_buffer(ipu_channel_t channel, ipu_buffer_t type, + uint32_t bufNum, dma_addr_t phyaddr); + +int32_t ipu_is_channel_busy(ipu_channel_t channel); +void ipu_clear_buffer_ready(ipu_channel_t channel, ipu_buffer_t type, + uint32_t bufNum); +int32_t ipu_enable_channel(ipu_channel_t channel); +int32_t ipu_disable_channel(ipu_channel_t channel); + +int32_t ipu_init_sync_panel(int disp, + uint32_t pixel_clk, + uint16_t width, uint16_t height, + uint32_t pixel_fmt, + uint16_t h_start_width, uint16_t h_sync_width, + uint16_t h_end_width, uint16_t v_start_width, + uint16_t v_sync_width, uint16_t v_end_width, + uint32_t v_to_h_sync, ipu_di_signal_cfg_t sig); + +int32_t ipu_disp_set_global_alpha(ipu_channel_t channel, unsigned char enable, + uint8_t alpha); +int32_t ipu_disp_set_color_key(ipu_channel_t channel, unsigned char enable, + uint32_t colorKey); + +uint32_t bytes_per_pixel(uint32_t fmt); + +void clk_enable(struct clk *clk); +void clk_disable(struct clk *clk); +u32 clk_get_rate(struct clk *clk); +int clk_set_rate(struct clk *clk, unsigned long rate); +long clk_round_rate(struct clk *clk, unsigned long rate); +int clk_set_parent(struct clk *clk, struct clk *parent); +int clk_get_usecount(struct clk *clk); +struct clk *clk_get_parent(struct clk *clk); + +void ipu_dump_registers(void); +int ipu_probe(void); + +void ipu_dmfc_init(int dmfc_type, int first); +void ipu_init_dc_mappings(void); +void ipu_dmfc_set_wait4eot(int dma_chan, int width); +void ipu_dc_init(int dc_chan, int di, unsigned char interlaced); +void ipu_dc_uninit(int dc_chan); +void ipu_dp_dc_enable(ipu_channel_t channel); +int ipu_dp_init(ipu_channel_t channel, uint32_t in_pixel_fmt, + uint32_t out_pixel_fmt); +void ipu_dp_uninit(ipu_channel_t channel); +void ipu_dp_dc_disable(ipu_channel_t channel, unsigned char swap); +ipu_color_space_t format_to_colorspace(uint32_t fmt); + +#endif diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c new file mode 100644 index 0000000..9d20c86 --- /dev/null +++ b/drivers/video/ipu_common.c @@ -0,0 +1,1183 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ +#include <common.h> +#include <linux/types.h> +#include <linux/err.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include "ipu.h" +#include "ipu_regs.h" + +extern struct mxc_ccm_reg *mxc_ccm; +extern u32 *ipu_cpmem_base; + +struct ipu_ch_param_word { + uint32_t data[5]; + uint32_t res[3]; +}; + +struct ipu_ch_param { + struct ipu_ch_param_word word[2]; +}; + +#define ipu_ch_param_addr(ch) (((struct ipu_ch_param *)ipu_cpmem_base) + (ch)) + +#define _param_word(base, w) \ + (((struct ipu_ch_param *)(base))->word[(w)].data) + +#define ipu_ch_param_set_field(base, w, bit, size, v) { \ + int i = (bit) / 32; \ + int off = (bit) % 32; \ + _param_word(base, w)[i] |= (v) << off; \ + if (((bit) + (size) - 1) / 32 > i) { \ + _param_word(base, w)[i + 1] |= (v) >> (off ? (32 - off) : 0); \ + } \ +} + +#define ipu_ch_param_mod_field(base, w, bit, size, v) { \ + int i = (bit) / 32; \ + int off = (bit) % 32; \ + u32 mask = (1UL << size) - 1; \ + u32 temp = _param_word(base, w)[i]; \ + temp &= ~(mask << off); \ + _param_word(base, w)[i] = temp | (v) << off; \ + if (((bit) + (size) - 1) / 32 > i) { \ + temp = _param_word(base, w)[i + 1]; \ + temp &= ~(mask >> (32 - off)); \ + _param_word(base, w)[i + 1] = \ + temp | ((v) >> (off ? (32 - off) : 0)); \ + } \ +} + +#define ipu_ch_param_read_field(base, w, bit, size) ({ \ + u32 temp2; \ + int i = (bit) / 32; \ + int off = (bit) % 32; \ + u32 mask = (1UL << size) - 1; \ + u32 temp1 = _param_word(base, w)[i]; \ + temp1 = mask & (temp1 >> off); \ + if (((bit)+(size) - 1) / 32 > i) { \ + temp2 = _param_word(base, w)[i + 1]; \ + temp2 &= mask >> (off ? (32 - off) : 0); \ + temp1 |= temp2 << (off ? (32 - off) : 0); \ + } \ + temp1; \ +}) + + +void clk_enable(struct clk *clk) +{ + if (clk) { + if (clk->usecount++ == 0) { + clk->enable(clk); + } + } +} + +void clk_disable(struct clk *clk) +{ + if (clk) { + if (!(--clk->usecount)) { + if (clk->disable) + clk->disable(clk); + } + } +} + +int clk_get_usecount(struct clk *clk) +{ + if (clk == NULL) + return 0; + + return clk->usecount; +} + +u32 clk_get_rate(struct clk *clk) +{ + if (!clk) + return 0; + + return clk->rate; +} + +struct clk *clk_get_parent(struct clk *clk) +{ + if (!clk) + return 0; + + return clk->parent; +} + +int clk_set_rate(struct clk *clk, unsigned long rate) +{ + if (clk && clk->set_rate) + clk->set_rate(clk, rate); + return clk->rate; +} + +long clk_round_rate(struct clk *clk, unsigned long rate) +{ + if (clk == NULL || !clk->round_rate) + return 0; + + return clk->round_rate(clk, rate); +} + +int clk_set_parent(struct clk *clk, struct clk *parent) +{ + clk->parent = parent; + if (clk->set_parent) + return clk->set_parent(clk, parent); + return 0; +} + +static int clk_ipu_enable(struct clk *clk) +{ + u32 reg; + + reg = __raw_readl(clk->enable_reg); + reg |= MXC_CCM_CCGR_CG_MASK << clk->enable_shift; + __raw_writel(reg, clk->enable_reg); + + /* Handshake with IPU when certain clock rates are changed. */ + reg = __raw_readl(&mxc_ccm->ccdr); + reg &= ~MXC_CCM_CCDR_IPU_HS_MASK; + __raw_writel(reg, &mxc_ccm->ccdr); + + /* Handshake with IPU when LPM is entered as its enabled. */ + reg = __raw_readl(&mxc_ccm->clpcr); + reg &= ~MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS; + __raw_writel(reg, &mxc_ccm->clpcr); + + return 0; +} + +static void clk_ipu_disable(struct clk *clk) +{ + u32 reg; + + reg = __raw_readl(clk->enable_reg); + reg &= ~(MXC_CCM_CCGR_CG_MASK << clk->enable_shift); + __raw_writel(reg, clk->enable_reg); + + /* + * No handshake with IPU whe dividers are changed + * as its not enabled. + */ + reg = __raw_readl(&mxc_ccm->ccdr); + reg |= MXC_CCM_CCDR_IPU_HS_MASK; + __raw_writel(reg, &mxc_ccm->ccdr); + + /* No handshake with IPU when LPM is entered as its not enabled. */ + reg = __raw_readl(&mxc_ccm->clpcr); + reg |= MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS; + __raw_writel(reg, &mxc_ccm->clpcr); +} + + +static struct clk ipu_clk = { + .name = "ipu_clk", + .rate = 133000000, + .enable_reg = (u32 *)(MXC_CCM_BASE + + offsetof(struct mxc_ccm_reg, CCGR5)), + .enable_shift = MXC_CCM_CCGR5_CG5_OFFSET, + .enable = clk_ipu_enable, + .disable = clk_ipu_disable, + .usecount = 0, +}; + +/* Globals */ +struct clk *g_ipu_clk; +unsigned char g_ipu_clk_enabled; +struct clk *g_di_clk[2]; +struct clk *g_pixel_clk[2]; +unsigned char g_dc_di_assignment[10]; +uint32_t g_channel_init_mask; +uint32_t g_channel_enable_mask; + +static int ipu_dc_use_count; +static int ipu_dp_use_count; +static int ipu_dmfc_use_count; +static int ipu_di_use_count[2]; + +u32 *ipu_cpmem_base; +u32 *ipu_dc_tmpl_reg; + +/* Static functions */ + +static inline void ipu_ch_param_set_high_priority(uint32_t ch) +{ + ipu_ch_param_mod_field(ipu_ch_param_addr(ch), 1, 93, 2, 1); +}; + +static inline uint32_t channel_2_dma(ipu_channel_t ch, ipu_buffer_t type) +{ + return ((uint32_t) ch >> (6 * type)) & 0x3F; +}; + +/* Either DP BG or DP FG can be graphic window */ +static inline int ipu_is_dp_graphic_chan(uint32_t dma_chan) +{ + return (dma_chan == 23 || dma_chan == 27); +} + +static inline int ipu_is_dmfc_chan(uint32_t dma_chan) +{ + return ((dma_chan >= 23) && (dma_chan <= 29)); +} + + +static inline void ipu_ch_param_set_buffer(uint32_t ch, int bufNum, + dma_addr_t phyaddr) +{ + ipu_ch_param_mod_field(ipu_ch_param_addr(ch), 1, 29 * bufNum, 29, + phyaddr / 8); +}; + +#define idma_is_valid(ch) (ch != NO_DMA) +#define idma_mask(ch) (idma_is_valid(ch) ? (1UL << (ch & 0x1F)) : 0) +#define idma_is_set(reg, dma) (__raw_readl(reg(dma)) & idma_mask(dma)) + +static void ipu_pixel_clk_recalc(struct clk *clk) +{ + u32 div = __raw_readl(DI_BS_CLKGEN0(clk->id)); + if (div == 0) + clk->rate = 0; + else + clk->rate = (clk->parent->rate * 16) / div; +} + +static unsigned long ipu_pixel_clk_round_rate(struct clk *clk, + unsigned long rate) +{ + u32 div, div1; + u32 tmp; + /* + * Calculate divider + * Fractional part is 4 bits, + * so simply multiply by 2^4 to get fractional part. + */ + tmp = (clk->parent->rate * 16); + div = tmp / rate; + + if (div < 0x10) /* Min DI disp clock divider is 1 */ + div = 0x10; + if (div & ~0xFEF) + div &= 0xFF8; + else { + div1 = div & 0xFE0; + if ((tmp/div1 - tmp/div) < rate / 4) + div = div1; + else + div &= 0xFF8; + } + return (clk->parent->rate * 16) / div; +} + +static int ipu_pixel_clk_set_rate(struct clk *clk, unsigned long rate) +{ + u32 div = (clk->parent->rate * 16) / rate; + + __raw_writel(div, DI_BS_CLKGEN0(clk->id)); + + /* Setup pixel clock timing */ + __raw_writel((div / 16) << 16, DI_BS_CLKGEN1(clk->id)); + + clk->rate = (clk->parent->rate * 16) / div; + return 0; +} + +static int ipu_pixel_clk_enable(struct clk *clk) +{ + u32 disp_gen = __raw_readl(IPU_DISP_GEN); + disp_gen |= clk->id ? DI1_COUNTER_RELEASE : DI0_COUNTER_RELEASE; + __raw_writel(disp_gen, IPU_DISP_GEN); + + return 0; +} + +static void ipu_pixel_clk_disable(struct clk *clk) +{ + u32 disp_gen = __raw_readl(IPU_DISP_GEN); + disp_gen &= clk->id ? ~DI1_COUNTER_RELEASE : ~DI0_COUNTER_RELEASE; + __raw_writel(disp_gen, IPU_DISP_GEN); + +} + +static int ipu_pixel_clk_set_parent(struct clk *clk, struct clk *parent) +{ + u32 di_gen = __raw_readl(DI_GENERAL(clk->id)); + + if (parent == g_ipu_clk) + di_gen &= ~DI_GEN_DI_CLK_EXT; + else if (!IS_ERR(g_di_clk[clk->id]) && parent == g_di_clk[clk->id]) + di_gen |= DI_GEN_DI_CLK_EXT; + else + return -EINVAL; + + __raw_writel(di_gen, DI_GENERAL(clk->id)); + ipu_pixel_clk_recalc(clk); + return 0; +} + +static struct clk pixel_clk[] = { + { + .name = "pixel_clk", + .id = 0, + .recalc = ipu_pixel_clk_recalc, + .set_rate = ipu_pixel_clk_set_rate, + .round_rate = ipu_pixel_clk_round_rate, + .set_parent = ipu_pixel_clk_set_parent, + .enable = ipu_pixel_clk_enable, + .disable = ipu_pixel_clk_disable, + .usecount = 0, + }, + { + .name = "pixel_clk", + .id = 1, + .recalc = ipu_pixel_clk_recalc, + .set_rate = ipu_pixel_clk_set_rate, + .round_rate = ipu_pixel_clk_round_rate, + .set_parent = ipu_pixel_clk_set_parent, + .enable = ipu_pixel_clk_enable, + .disable = ipu_pixel_clk_disable, + .usecount = 0, + }, +}; + +/* + * This function resets IPU + */ +void ipu_reset(void) +{ + u32 *reg; + u32 value; + + reg = (u32 *)SRC_BASE_ADDR; + value = __raw_readl(reg); + value = value | SW_IPU_RST; + __raw_writel(value, reg); +} + +/* + * This function is called by the driver framework to initialize the IPU + * hardware. + * + * @param dev The device structure for the IPU passed in by the + * driver framework. + * + * @return Returns 0 on success or negative error code on error + */ +int ipu_probe(void) +{ + unsigned long ipu_base; + u32 temp; + + u32 *reg_hsc_mcd = (u32 *)MIPI_HSC_BASE_ADDR; + u32 *reg_hsc_mxt_conf = (u32 *)(MIPI_HSC_BASE_ADDR + 0x800); + + __raw_writel(0xF00, reg_hsc_mcd); + + /* CSI mode reserved*/ + temp = __raw_readl(reg_hsc_mxt_conf); + __raw_writel(temp | 0x0FF, reg_hsc_mxt_conf); + + temp = __raw_readl(reg_hsc_mxt_conf); + __raw_writel(temp | 0x10000, reg_hsc_mxt_conf); + + ipu_base = IPU_CTRL_BASE_ADDR; + ipu_cpmem_base = (u32 *)(ipu_base + IPU_CPMEM_REG_BASE); + ipu_dc_tmpl_reg = (u32 *)(ipu_base + IPU_DC_TMPL_REG_BASE); + + g_pixel_clk[0] = &pixel_clk[0]; + g_pixel_clk[1] = &pixel_clk[1]; + + g_ipu_clk = &ipu_clk; + debug("ipu_clk = %u\n", clk_get_rate(g_ipu_clk)); + + ipu_reset(); + + clk_set_parent(g_pixel_clk[0], g_ipu_clk); + clk_set_parent(g_pixel_clk[1], g_ipu_clk); + clk_enable(g_ipu_clk); + + g_di_clk[0] = NULL; + g_di_clk[1] = NULL; + + __raw_writel(0x807FFFFF, IPU_MEM_RST); + while (__raw_readl(IPU_MEM_RST) & 0x80000000) + ; + + ipu_init_dc_mappings(); + + __raw_writel(0, IPU_INT_CTRL(5)); + __raw_writel(0, IPU_INT_CTRL(6)); + __raw_writel(0, IPU_INT_CTRL(9)); + __raw_writel(0, IPU_INT_CTRL(10)); + + /* DMFC Init */ + ipu_dmfc_init(DMFC_NORMAL, 1); + + /* Set sync refresh channels as high priority */ + __raw_writel(0x18800000L, IDMAC_CHA_PRI(0)); + + /* Set MCU_T to divide MCU access window into 2 */ + __raw_writel(0x00400000L | (IPU_MCU_T_DEFAULT << 18), IPU_DISP_GEN); + + clk_disable(g_ipu_clk); + + return 0; +} + +void ipu_dump_registers(void) +{ + debug("IPU_CONF = \t0x%08X\n", __raw_readl(IPU_CONF)); + debug("IDMAC_CONF = \t0x%08X\n", __raw_readl(IDMAC_CONF)); + debug("IDMAC_CHA_EN1 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_EN(0))); + debug("IDMAC_CHA_EN2 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_EN(32))); + debug("IDMAC_CHA_PRI1 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_PRI(0))); + debug("IDMAC_CHA_PRI2 = \t0x%08X\n", + __raw_readl(IDMAC_CHA_PRI(32))); + debug("IPU_CHA_DB_MODE_SEL0 = \t0x%08X\n", + __raw_readl(IPU_CHA_DB_MODE_SEL(0))); + debug("IPU_CHA_DB_MODE_SEL1 = \t0x%08X\n", + __raw_readl(IPU_CHA_DB_MODE_SEL(32))); + debug("DMFC_WR_CHAN = \t0x%08X\n", + __raw_readl(DMFC_WR_CHAN)); + debug("DMFC_WR_CHAN_DEF = \t0x%08X\n", + __raw_readl(DMFC_WR_CHAN_DEF)); + debug("DMFC_DP_CHAN = \t0x%08X\n", + __raw_readl(DMFC_DP_CHAN)); + debug("DMFC_DP_CHAN_DEF = \t0x%08X\n", + __raw_readl(DMFC_DP_CHAN_DEF)); + debug("DMFC_IC_CTRL = \t0x%08X\n", + __raw_readl(DMFC_IC_CTRL)); + debug("IPU_FS_PROC_FLOW1 = \t0x%08X\n", + __raw_readl(IPU_FS_PROC_FLOW1)); + debug("IPU_FS_PROC_FLOW2 = \t0x%08X\n", + __raw_readl(IPU_FS_PROC_FLOW2)); + debug("IPU_FS_PROC_FLOW3 = \t0x%08X\n", + __raw_readl(IPU_FS_PROC_FLOW3)); + debug("IPU_FS_DISP_FLOW1 = \t0x%08X\n", + __raw_readl(IPU_FS_DISP_FLOW1)); +} + +/* + * This function is called to initialize a logical IPU channel. + * + * @param channel Input parameter for the logical channel ID to init. + * + * @param params Input parameter containing union of channel + * initialization parameters. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_init_channel(ipu_channel_t channel, ipu_channel_params_t *params) +{ + int ret = 0; + uint32_t ipu_conf; + + debug("init channel = %d\n", IPU_CHAN_ID(channel)); + + if (g_ipu_clk_enabled == 0) { + g_ipu_clk_enabled = 1; + clk_enable(g_ipu_clk); + } + + + if (g_channel_init_mask & (1L << IPU_CHAN_ID(channel))) { + printf("Warning: channel already initialized %d\n", + IPU_CHAN_ID(channel)); + } + + ipu_conf = __raw_readl(IPU_CONF); + + switch (channel) { + case MEM_DC_SYNC: + if (params->mem_dc_sync.di > 1) { + ret = -EINVAL; + goto err; + } + + g_dc_di_assignment[1] = params->mem_dc_sync.di; + ipu_dc_init(1, params->mem_dc_sync.di, + params->mem_dc_sync.interlaced); + ipu_di_use_count[params->mem_dc_sync.di]++; + ipu_dc_use_count++; + ipu_dmfc_use_count++; + break; + case MEM_BG_SYNC: + if (params->mem_dp_bg_sync.di > 1) { + ret = -EINVAL; + goto err; + } + + g_dc_di_assignment[5] = params->mem_dp_bg_sync.di; + ipu_dp_init(channel, params->mem_dp_bg_sync.in_pixel_fmt, + params->mem_dp_bg_sync.out_pixel_fmt); + ipu_dc_init(5, params->mem_dp_bg_sync.di, + params->mem_dp_bg_sync.interlaced); + ipu_di_use_count[params->mem_dp_bg_sync.di]++; + ipu_dc_use_count++; + ipu_dp_use_count++; + ipu_dmfc_use_count++; + break; + case MEM_FG_SYNC: + ipu_dp_init(channel, params->mem_dp_fg_sync.in_pixel_fmt, + params->mem_dp_fg_sync.out_pixel_fmt); + + ipu_dc_use_count++; + ipu_dp_use_count++; + ipu_dmfc_use_count++; + break; + default: + printf("Missing channel initialization\n"); + break; + } + + /* Enable IPU sub module */ + g_channel_init_mask |= 1L << IPU_CHAN_ID(channel); + if (ipu_dc_use_count == 1) + ipu_conf |= IPU_CONF_DC_EN; + if (ipu_dp_use_count == 1) + ipu_conf |= IPU_CONF_DP_EN; + if (ipu_dmfc_use_count == 1) + ipu_conf |= IPU_CONF_DMFC_EN; + if (ipu_di_use_count[0] == 1) { + ipu_conf |= IPU_CONF_DI0_EN; + } + if (ipu_di_use_count[1] == 1) { + ipu_conf |= IPU_CONF_DI1_EN; + } + + __raw_writel(ipu_conf, IPU_CONF); + +err: + return ret; +} + +/* + * This function is called to uninitialize a logical IPU channel. + * + * @param channel Input parameter for the logical channel ID to uninit. + */ +void ipu_uninit_channel(ipu_channel_t channel) +{ + uint32_t reg; + uint32_t in_dma, out_dma = 0; + uint32_t ipu_conf; + + if ((g_channel_init_mask & (1L << IPU_CHAN_ID(channel))) == 0) { + debug("Channel already uninitialized %d\n", + IPU_CHAN_ID(channel)); + return; + } + + /* + * Make sure channel is disabled + * Get input and output dma channels + */ + in_dma = channel_2_dma(channel, IPU_OUTPUT_BUFFER); + out_dma = channel_2_dma(channel, IPU_VIDEO_IN_BUFFER); + + if (idma_is_set(IDMAC_CHA_EN, in_dma) || + idma_is_set(IDMAC_CHA_EN, out_dma)) { + printf( + "Channel %d is not disabled, disable first\n", + IPU_CHAN_ID(channel)); + return; + } + + ipu_conf = __raw_readl(IPU_CONF); + + /* Reset the double buffer */ + reg = __raw_readl(IPU_CHA_DB_MODE_SEL(in_dma)); + __raw_writel(reg & ~idma_mask(in_dma), IPU_CHA_DB_MODE_SEL(in_dma)); + reg = __raw_readl(IPU_CHA_DB_MODE_SEL(out_dma)); + __raw_writel(reg & ~idma_mask(out_dma), IPU_CHA_DB_MODE_SEL(out_dma)); + + switch (channel) { + case MEM_DC_SYNC: + ipu_dc_uninit(1); + ipu_di_use_count[g_dc_di_assignment[1]]--; + ipu_dc_use_count--; + ipu_dmfc_use_count--; + break; + case MEM_BG_SYNC: + ipu_dp_uninit(channel); + ipu_dc_uninit(5); + ipu_di_use_count[g_dc_di_assignment[5]]--; + ipu_dc_use_count--; + ipu_dp_use_count--; + ipu_dmfc_use_count--; + break; + case MEM_FG_SYNC: + ipu_dp_uninit(channel); + ipu_dc_use_count--; + ipu_dp_use_count--; + ipu_dmfc_use_count--; + break; + default: + break; + } + + g_channel_init_mask &= ~(1L << IPU_CHAN_ID(channel)); + + if (ipu_dc_use_count == 0) + ipu_conf &= ~IPU_CONF_DC_EN; + if (ipu_dp_use_count == 0) + ipu_conf &= ~IPU_CONF_DP_EN; + if (ipu_dmfc_use_count == 0) + ipu_conf &= ~IPU_CONF_DMFC_EN; + if (ipu_di_use_count[0] == 0) { + ipu_conf &= ~IPU_CONF_DI0_EN; + } + if (ipu_di_use_count[1] == 0) { + ipu_conf &= ~IPU_CONF_DI1_EN; + } + + __raw_writel(ipu_conf, IPU_CONF); + + if (ipu_conf == 0) { + clk_disable(g_ipu_clk); + g_ipu_clk_enabled = 0; + } + +} + +static inline void ipu_ch_param_dump(int ch) +{ +#ifdef DEBUG + struct ipu_ch_param *p = ipu_ch_param_addr(ch); + debug("ch %d word 0 - %08X %08X %08X %08X %08X\n", ch, + p->word[0].data[0], p->word[0].data[1], p->word[0].data[2], + p->word[0].data[3], p->word[0].data[4]); + debug("ch %d word 1 - %08X %08X %08X %08X %08X\n", ch, + p->word[1].data[0], p->word[1].data[1], p->word[1].data[2], + p->word[1].data[3], p->word[1].data[4]); + debug("PFS 0x%x, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 85, 4)); + debug("BPP 0x%x, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 0, 107, 3)); + debug("NPB 0x%x\n", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 78, 7)); + + debug("FW %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 0, 125, 13)); + debug("FH %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 0, 138, 12)); + debug("Stride %d\n", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 102, 14)); + + debug("Width0 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 116, 3)); + debug("Width1 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 119, 3)); + debug("Width2 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 122, 3)); + debug("Width3 %d+1, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 125, 3)); + debug("Offset0 %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 128, 5)); + debug("Offset1 %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 133, 5)); + debug("Offset2 %d, ", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 138, 5)); + debug("Offset3 %d\n", + ipu_ch_param_read_field(ipu_ch_param_addr(ch), 1, 143, 5)); +#endif +} + +static inline void ipu_ch_params_set_packing(struct ipu_ch_param *p, + int red_width, int red_offset, + int green_width, int green_offset, + int blue_width, int blue_offset, + int alpha_width, int alpha_offset) +{ + /* Setup red width and offset */ + ipu_ch_param_set_field(p, 1, 116, 3, red_width - 1); + ipu_ch_param_set_field(p, 1, 128, 5, red_offset); + /* Setup green width and offset */ + ipu_ch_param_set_field(p, 1, 119, 3, green_width - 1); + ipu_ch_param_set_field(p, 1, 133, 5, green_offset); + /* Setup blue width and offset */ + ipu_ch_param_set_field(p, 1, 122, 3, blue_width - 1); + ipu_ch_param_set_field(p, 1, 138, 5, blue_offset); + /* Setup alpha width and offset */ + ipu_ch_param_set_field(p, 1, 125, 3, alpha_width - 1); + ipu_ch_param_set_field(p, 1, 143, 5, alpha_offset); +} + +static void ipu_ch_param_init(int ch, + uint32_t pixel_fmt, uint32_t width, + uint32_t height, uint32_t stride, + uint32_t u, uint32_t v, + uint32_t uv_stride, dma_addr_t addr0, + dma_addr_t addr1) +{ + uint32_t u_offset = 0; + uint32_t v_offset = 0; + struct ipu_ch_param params; + + memset(¶ms, 0, sizeof(params)); + + ipu_ch_param_set_field(¶ms, 0, 125, 13, width - 1); + + if ((ch == 8) || (ch == 9) || (ch == 10)) { + ipu_ch_param_set_field(¶ms, 0, 138, 12, (height / 2) - 1); + ipu_ch_param_set_field(¶ms, 1, 102, 14, (stride * 2) - 1); + } else { + ipu_ch_param_set_field(¶ms, 0, 138, 12, height - 1); + ipu_ch_param_set_field(¶ms, 1, 102, 14, stride - 1); + } + + ipu_ch_param_set_field(¶ms, 1, 0, 29, addr0 >> 3); + ipu_ch_param_set_field(¶ms, 1, 29, 29, addr1 >> 3); + + switch (pixel_fmt) { + case IPU_PIX_FMT_GENERIC: + /*Represents 8-bit Generic data */ + ipu_ch_param_set_field(¶ms, 0, 107, 3, 5); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 6); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 63); /* burst size */ + + break; + case IPU_PIX_FMT_GENERIC_32: + /*Represents 32-bit Generic data */ + break; + case IPU_PIX_FMT_RGB565: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 3); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 5, 0, 6, 5, 5, 11, 8, 16); + break; + case IPU_PIX_FMT_BGR24: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 1); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 19); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 0, 8, 8, 8, 16, 8, 24); + break; + case IPU_PIX_FMT_RGB24: + case IPU_PIX_FMT_YUV444: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 1); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 19); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 16, 8, 8, 8, 0, 8, 24); + break; + case IPU_PIX_FMT_BGRA32: + case IPU_PIX_FMT_BGR32: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 0); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 8, 8, 16, 8, 24, 8, 0); + break; + case IPU_PIX_FMT_RGBA32: + case IPU_PIX_FMT_RGB32: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 0); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + + ipu_ch_params_set_packing(¶ms, 8, 24, 8, 16, 8, 8, 8, 0); + break; + case IPU_PIX_FMT_ABGR32: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 0); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 7); /* pix format */ + + ipu_ch_params_set_packing(¶ms, 8, 0, 8, 8, 8, 16, 8, 24); + break; + case IPU_PIX_FMT_UYVY: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 3); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 0xA); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); /* burst size */ + break; + case IPU_PIX_FMT_YUYV: + ipu_ch_param_set_field(¶ms, 0, 107, 3, 3); /* bits/pixel */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 0x8); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + break; + case IPU_PIX_FMT_YUV420P2: + case IPU_PIX_FMT_YUV420P: + ipu_ch_param_set_field(¶ms, 1, 85, 4, 2); /* pix format */ + + if (uv_stride < stride / 2) + uv_stride = stride / 2; + + u_offset = stride * height; + v_offset = u_offset + (uv_stride * height / 2); + /* burst size */ + if ((ch == 8) || (ch == 9) || (ch == 10)) { + ipu_ch_param_set_field(¶ms, 1, 78, 7, 15); + uv_stride = uv_stride*2; + } else { + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); + } + break; + case IPU_PIX_FMT_YVU422P: + /* BPP & pixel format */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 1); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + + if (uv_stride < stride / 2) + uv_stride = stride / 2; + + v_offset = (v == 0) ? stride * height : v; + u_offset = (u == 0) ? v_offset + v_offset / 2 : u; + break; + case IPU_PIX_FMT_YUV422P: + /* BPP & pixel format */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 1); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + + if (uv_stride < stride / 2) + uv_stride = stride / 2; + + u_offset = (u == 0) ? stride * height : u; + v_offset = (v == 0) ? u_offset + u_offset / 2 : v; + break; + case IPU_PIX_FMT_NV12: + /* BPP & pixel format */ + ipu_ch_param_set_field(¶ms, 1, 85, 4, 4); /* pix format */ + ipu_ch_param_set_field(¶ms, 1, 78, 7, 31); /* burst size */ + uv_stride = stride; + u_offset = (u == 0) ? stride * height : u; + break; + default: + puts("mxc ipu: unimplemented pixel format\n"); + break; + } + + + if (uv_stride) + ipu_ch_param_set_field(¶ms, 1, 128, 14, uv_stride - 1); + + /* Get the uv offset from user when need cropping */ + if (u || v) { + u_offset = u; + v_offset = v; + } + + /* UBO and VBO are 22-bit */ + if (u_offset/8 > 0x3fffff) + puts("The value of U offset exceeds IPU limitation\n"); + if (v_offset/8 > 0x3fffff) + puts("The value of V offset exceeds IPU limitation\n"); + + ipu_ch_param_set_field(¶ms, 0, 46, 22, u_offset / 8); + ipu_ch_param_set_field(¶ms, 0, 68, 22, v_offset / 8); + + debug("initializing idma ch %d @ %p\n", ch, ipu_ch_param_addr(ch)); + memcpy(ipu_ch_param_addr(ch), ¶ms, sizeof(params)); +}; + +/* + * This function is called to initialize a buffer for logical IPU channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @param type Input parameter which buffer to initialize. + * + * @param pixel_fmt Input parameter for pixel format of buffer. + * Pixel format is a FOURCC ASCII code. + * + * @param width Input parameter for width of buffer in pixels. + * + * @param height Input parameter for height of buffer in pixels. + * + * @param stride Input parameter for stride length of buffer + * in pixels. + * + * @param phyaddr_0 Input parameter buffer 0 physical address. + * + * @param phyaddr_1 Input parameter buffer 1 physical address. + * Setting this to a value other than NULL enables + * double buffering mode. + * + * @param u private u offset for additional cropping, + * zero if not used. + * + * @param v private v offset for additional cropping, + * zero if not used. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_init_channel_buffer(ipu_channel_t channel, ipu_buffer_t type, + uint32_t pixel_fmt, + uint16_t width, uint16_t height, + uint32_t stride, + dma_addr_t phyaddr_0, dma_addr_t phyaddr_1, + uint32_t u, uint32_t v) +{ + uint32_t reg; + uint32_t dma_chan; + + dma_chan = channel_2_dma(channel, type); + if (!idma_is_valid(dma_chan)) + return -EINVAL; + + if (stride < width * bytes_per_pixel(pixel_fmt)) + stride = width * bytes_per_pixel(pixel_fmt); + + if (stride % 4) { + printf( + "Stride not 32-bit aligned, stride = %d\n", stride); + return -EINVAL; + } + /* Build parameter memory data for DMA channel */ + ipu_ch_param_init(dma_chan, pixel_fmt, width, height, stride, u, v, 0, + phyaddr_0, phyaddr_1); + + if (ipu_is_dmfc_chan(dma_chan)) { + ipu_dmfc_set_wait4eot(dma_chan, width); + } + + if (idma_is_set(IDMAC_CHA_PRI, dma_chan)) + ipu_ch_param_set_high_priority(dma_chan); + + ipu_ch_param_dump(dma_chan); + + reg = __raw_readl(IPU_CHA_DB_MODE_SEL(dma_chan)); + if (phyaddr_1) + reg |= idma_mask(dma_chan); + else + reg &= ~idma_mask(dma_chan); + __raw_writel(reg, IPU_CHA_DB_MODE_SEL(dma_chan)); + + /* Reset to buffer 0 */ + __raw_writel(idma_mask(dma_chan), IPU_CHA_CUR_BUF(dma_chan)); + + return 0; +} + +/* + * This function enables a logical channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @return This function returns 0 on success or negative error code on + * fail. + */ +int32_t ipu_enable_channel(ipu_channel_t channel) +{ + uint32_t reg; + uint32_t in_dma; + uint32_t out_dma; + + if (g_channel_enable_mask & (1L << IPU_CHAN_ID(channel))) { + printf("Warning: channel already enabled %d\n", + IPU_CHAN_ID(channel)); + } + + /* Get input and output dma channels */ + out_dma = channel_2_dma(channel, IPU_OUTPUT_BUFFER); + in_dma = channel_2_dma(channel, IPU_VIDEO_IN_BUFFER); + + if (idma_is_valid(in_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(in_dma)); + __raw_writel(reg | idma_mask(in_dma), IDMAC_CHA_EN(in_dma)); + } + if (idma_is_valid(out_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(out_dma)); + __raw_writel(reg | idma_mask(out_dma), IDMAC_CHA_EN(out_dma)); + } + + if ((channel == MEM_DC_SYNC) || (channel == MEM_BG_SYNC) || + (channel == MEM_FG_SYNC)) + ipu_dp_dc_enable(channel); + + g_channel_enable_mask |= 1L << IPU_CHAN_ID(channel); + + return 0; +} + +/* + * This function clear buffer ready for a logical channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @param type Input parameter which buffer to clear. + * + * @param bufNum Input parameter for which buffer number clear + * ready state. + * + */ +void ipu_clear_buffer_ready(ipu_channel_t channel, ipu_buffer_t type, + uint32_t bufNum) +{ + uint32_t dma_ch = channel_2_dma(channel, type); + + if (!idma_is_valid(dma_ch)) + return; + + __raw_writel(0xF0000000, IPU_GPR); /* write one to clear */ + if (bufNum == 0) { + if (idma_is_set(IPU_CHA_BUF0_RDY, dma_ch)) { + __raw_writel(idma_mask(dma_ch), + IPU_CHA_BUF0_RDY(dma_ch)); + } + } else { + if (idma_is_set(IPU_CHA_BUF1_RDY, dma_ch)) { + __raw_writel(idma_mask(dma_ch), + IPU_CHA_BUF1_RDY(dma_ch)); + } + } + __raw_writel(0x0, IPU_GPR); /* write one to set */ +} + +/* + * This function disables a logical channel. + * + * @param channel Input parameter for the logical channel ID. + * + * @param wait_for_stop Flag to set whether to wait for channel end + * of frame or return immediately. + * + * @return This function returns 0 on success or negative error code on + * fail. + */ +int32_t ipu_disable_channel(ipu_channel_t channel) +{ + uint32_t reg; + uint32_t in_dma; + uint32_t out_dma; + + if ((g_channel_enable_mask & (1L << IPU_CHAN_ID(channel))) == 0) { + debug("Channel already disabled %d\n", + IPU_CHAN_ID(channel)); + return 0; + } + + /* Get input and output dma channels */ + out_dma = channel_2_dma(channel, IPU_OUTPUT_BUFFER); + in_dma = channel_2_dma(channel, IPU_VIDEO_IN_BUFFER); + + if ((idma_is_valid(in_dma) && + !idma_is_set(IDMAC_CHA_EN, in_dma)) + && (idma_is_valid(out_dma) && + !idma_is_set(IDMAC_CHA_EN, out_dma))) + return -EINVAL; + + if ((channel == MEM_BG_SYNC) || (channel == MEM_FG_SYNC) || + (channel == MEM_DC_SYNC)) { + ipu_dp_dc_disable(channel, 0); + } + + /* Disable DMA channel(s) */ + if (idma_is_valid(in_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(in_dma)); + __raw_writel(reg & ~idma_mask(in_dma), IDMAC_CHA_EN(in_dma)); + __raw_writel(idma_mask(in_dma), IPU_CHA_CUR_BUF(in_dma)); + } + if (idma_is_valid(out_dma)) { + reg = __raw_readl(IDMAC_CHA_EN(out_dma)); + __raw_writel(reg & ~idma_mask(out_dma), IDMAC_CHA_EN(out_dma)); + __raw_writel(idma_mask(out_dma), IPU_CHA_CUR_BUF(out_dma)); + } + + g_channel_enable_mask &= ~(1L << IPU_CHAN_ID(channel)); + + /* Set channel buffers NOT to be ready */ + if (idma_is_valid(in_dma)) { + ipu_clear_buffer_ready(channel, IPU_VIDEO_IN_BUFFER, 0); + ipu_clear_buffer_ready(channel, IPU_VIDEO_IN_BUFFER, 1); + } + if (idma_is_valid(out_dma)) { + ipu_clear_buffer_ready(channel, IPU_OUTPUT_BUFFER, 0); + ipu_clear_buffer_ready(channel, IPU_OUTPUT_BUFFER, 1); + } + + return 0; +} + +uint32_t bytes_per_pixel(uint32_t fmt) +{ + switch (fmt) { + case IPU_PIX_FMT_GENERIC: /*generic data */ + case IPU_PIX_FMT_RGB332: + case IPU_PIX_FMT_YUV420P: + case IPU_PIX_FMT_YUV422P: + return 1; + break; + case IPU_PIX_FMT_RGB565: + case IPU_PIX_FMT_YUYV: + case IPU_PIX_FMT_UYVY: + return 2; + break; + case IPU_PIX_FMT_BGR24: + case IPU_PIX_FMT_RGB24: + return 3; + break; + case IPU_PIX_FMT_GENERIC_32: /*generic data */ + case IPU_PIX_FMT_BGR32: + case IPU_PIX_FMT_BGRA32: + case IPU_PIX_FMT_RGB32: + case IPU_PIX_FMT_RGBA32: + case IPU_PIX_FMT_ABGR32: + return 4; + break; + default: + return 1; + break; + } + return 0; +} + +ipu_color_space_t format_to_colorspace(uint32_t fmt) +{ + switch (fmt) { + case IPU_PIX_FMT_RGB666: + case IPU_PIX_FMT_RGB565: + case IPU_PIX_FMT_BGR24: + case IPU_PIX_FMT_RGB24: + case IPU_PIX_FMT_BGR32: + case IPU_PIX_FMT_BGRA32: + case IPU_PIX_FMT_RGB32: + case IPU_PIX_FMT_RGBA32: + case IPU_PIX_FMT_ABGR32: + case IPU_PIX_FMT_LVDS666: + case IPU_PIX_FMT_LVDS888: + return RGB; + break; + + default: + return YCbCr; + break; + } + return RGB; +} diff --git a/drivers/video/ipu_disp.c b/drivers/video/ipu_disp.c new file mode 100644 index 0000000..11cf98d --- /dev/null +++ b/drivers/video/ipu_disp.c @@ -0,0 +1,1359 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ + +#include <common.h> +#include <linux/types.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include "ipu.h" +#include "ipu_regs.h" + +enum csc_type_t { + RGB2YUV = 0, + YUV2RGB, + RGB2RGB, + YUV2YUV, + CSC_NONE, + CSC_NUM +}; + +struct dp_csc_param_t { + int mode; + void *coeff; +}; + +#define SYNC_WAVE 0 + +/* DC display ID assignments */ +#define DC_DISP_ID_SYNC(di) (di) +#define DC_DISP_ID_SERIAL 2 +#define DC_DISP_ID_ASYNC 3 + +int dmfc_type_setup; +static int dmfc_size_28, dmfc_size_29, dmfc_size_24, dmfc_size_27, dmfc_size_23; +int g_di1_tvout; + +extern struct clk *g_ipu_clk; +extern struct clk *g_di_clk[2]; +extern struct clk *g_pixel_clk[2]; + +extern unsigned char g_ipu_clk_enabled; +extern unsigned char g_dc_di_assignment[]; + +void ipu_dmfc_init(int dmfc_type, int first) +{ + u32 dmfc_wr_chan, dmfc_dp_chan; + + if (first) { + if (dmfc_type_setup > dmfc_type) + dmfc_type = dmfc_type_setup; + else + dmfc_type_setup = dmfc_type; + + /* disable DMFC-IC channel*/ + __raw_writel(0x2, DMFC_IC_CTRL); + } else if (dmfc_type_setup >= DMFC_HIGH_RESOLUTION_DC) { + printf("DMFC high resolution has set, will not change\n"); + return; + } else + dmfc_type_setup = dmfc_type; + + if (dmfc_type == DMFC_HIGH_RESOLUTION_DC) { + /* 1 - segment 0~3; + * 5B - segement 4, 5; + * 5F - segement 6, 7; + * 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC DC HIGH RES: 1(0~3), 5B(4,5), 5F(6,7)\n"); + dmfc_wr_chan = 0x00000088; + dmfc_dp_chan = 0x00009694; + dmfc_size_28 = 256 * 4; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 128 * 4; + dmfc_size_23 = 128 * 4; + } else if (dmfc_type == DMFC_HIGH_RESOLUTION_DP) { + /* 1 - segment 0, 1; + * 5B - segement 2~5; + * 5F - segement 6,7; + * 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC DP HIGH RES: 1(0,1), 5B(2~5), 5F(6,7)\n"); + dmfc_wr_chan = 0x00000090; + dmfc_dp_chan = 0x0000968a; + dmfc_size_28 = 128 * 4; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 128 * 4; + dmfc_size_23 = 256 * 4; + } else if (dmfc_type == DMFC_HIGH_RESOLUTION_ONLY_DP) { + /* 5B - segement 0~3; + * 5F - segement 4~7; + * 1, 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC ONLY-DP HIGH RES: 5B(0~3), 5F(4~7)\n"); + dmfc_wr_chan = 0x00000000; + dmfc_dp_chan = 0x00008c88; + dmfc_size_28 = 0; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 256 * 4; + dmfc_size_23 = 256 * 4; + } else { + /* 1 - segment 0, 1; + * 5B - segement 4, 5; + * 5F - segement 6, 7; + * 1C, 2C and 6B, 6F unused; + */ + debug("IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)\n"); + dmfc_wr_chan = 0x00000090; + dmfc_dp_chan = 0x00009694; + dmfc_size_28 = 128 * 4; + dmfc_size_29 = 0; + dmfc_size_24 = 0; + dmfc_size_27 = 128 * 4; + dmfc_size_23 = 128 * 4; + } + __raw_writel(dmfc_wr_chan, DMFC_WR_CHAN); + __raw_writel(0x202020F6, DMFC_WR_CHAN_DEF); + __raw_writel(dmfc_dp_chan, DMFC_DP_CHAN); + /* Enable chan 5 watermark set at 5 bursts and clear at 7 bursts */ + __raw_writel(0x2020F6F6, DMFC_DP_CHAN_DEF); +} + +void ipu_dmfc_set_wait4eot(int dma_chan, int width) +{ + u32 dmfc_gen1 = __raw_readl(DMFC_GENERAL1); + + if (width >= HIGH_RESOLUTION_WIDTH) { + if (dma_chan == 23) + ipu_dmfc_init(DMFC_HIGH_RESOLUTION_DP, 0); + else if (dma_chan == 28) + ipu_dmfc_init(DMFC_HIGH_RESOLUTION_DC, 0); + } + + if (dma_chan == 23) { /*5B*/ + if (dmfc_size_23 / width > 3) + dmfc_gen1 |= 1UL << 20; + else + dmfc_gen1 &= ~(1UL << 20); + } else if (dma_chan == 24) { /*6B*/ + if (dmfc_size_24 / width > 1) + dmfc_gen1 |= 1UL << 22; + else + dmfc_gen1 &= ~(1UL << 22); + } else if (dma_chan == 27) { /*5F*/ + if (dmfc_size_27 / width > 2) + dmfc_gen1 |= 1UL << 21; + else + dmfc_gen1 &= ~(1UL << 21); + } else if (dma_chan == 28) { /*1*/ + if (dmfc_size_28 / width > 2) + dmfc_gen1 |= 1UL << 16; + else + dmfc_gen1 &= ~(1UL << 16); + } else if (dma_chan == 29) { /*6F*/ + if (dmfc_size_29 / width > 1) + dmfc_gen1 |= 1UL << 23; + else + dmfc_gen1 &= ~(1UL << 23); + } + + __raw_writel(dmfc_gen1, DMFC_GENERAL1); +} + +static void ipu_di_data_wave_config(int di, + int wave_gen, + int access_size, int component_size) +{ + u32 reg; + reg = (access_size << DI_DW_GEN_ACCESS_SIZE_OFFSET) | + (component_size << DI_DW_GEN_COMPONENT_SIZE_OFFSET); + __raw_writel(reg, DI_DW_GEN(di, wave_gen)); +} + +static void ipu_di_data_pin_config(int di, int wave_gen, int di_pin, int set, + int up, int down) +{ + u32 reg; + + reg = __raw_readl(DI_DW_GEN(di, wave_gen)); + reg &= ~(0x3 << (di_pin * 2)); + reg |= set << (di_pin * 2); + __raw_writel(reg, DI_DW_GEN(di, wave_gen)); + + __raw_writel((down << 16) | up, DI_DW_SET(di, wave_gen, set)); +} + +static void ipu_di_sync_config(int di, int wave_gen, + int run_count, int run_src, + int offset_count, int offset_src, + int repeat_count, int cnt_clr_src, + int cnt_polarity_gen_en, + int cnt_polarity_clr_src, + int cnt_polarity_trigger_src, + int cnt_up, int cnt_down) +{ + u32 reg; + + if ((run_count >= 0x1000) || (offset_count >= 0x1000) || + (repeat_count >= 0x1000) || + (cnt_up >= 0x400) || (cnt_down >= 0x400)) { + printf("DI%d counters out of range.\n", di); + return; + } + + reg = (run_count << 19) | (++run_src << 16) | + (offset_count << 3) | ++offset_src; + __raw_writel(reg, DI_SW_GEN0(di, wave_gen)); + reg = (cnt_polarity_gen_en << 29) | (++cnt_clr_src << 25) | + (++cnt_polarity_trigger_src << 12) | (++cnt_polarity_clr_src << 9); + reg |= (cnt_down << 16) | cnt_up; + if (repeat_count == 0) { + /* Enable auto reload */ + reg |= 0x10000000; + } + __raw_writel(reg, DI_SW_GEN1(di, wave_gen)); + reg = __raw_readl(DI_STP_REP(di, wave_gen)); + reg &= ~(0xFFFF << (16 * ((wave_gen - 1) & 0x1))); + reg |= repeat_count << (16 * ((wave_gen - 1) & 0x1)); + __raw_writel(reg, DI_STP_REP(di, wave_gen)); +} + +static void ipu_dc_map_config(int map, int byte_num, int offset, int mask) +{ + int ptr = map * 3 + byte_num; + u32 reg; + + reg = __raw_readl(DC_MAP_CONF_VAL(ptr)); + reg &= ~(0xFFFF << (16 * (ptr & 0x1))); + reg |= ((offset << 8) | mask) << (16 * (ptr & 0x1)); + __raw_writel(reg, DC_MAP_CONF_VAL(ptr)); + + reg = __raw_readl(DC_MAP_CONF_PTR(map)); + reg &= ~(0x1F << ((16 * (map & 0x1)) + (5 * byte_num))); + reg |= ptr << ((16 * (map & 0x1)) + (5 * byte_num)); + __raw_writel(reg, DC_MAP_CONF_PTR(map)); +} + +static void ipu_dc_map_clear(int map) +{ + u32 reg = __raw_readl(DC_MAP_CONF_PTR(map)); + __raw_writel(reg & ~(0xFFFF << (16 * (map & 0x1))), + DC_MAP_CONF_PTR(map)); +} + +static void ipu_dc_write_tmpl(int word, u32 opcode, u32 operand, int map, + int wave, int glue, int sync) +{ + u32 reg; + int stop = 1; + + reg = sync; + reg |= (glue << 4); + reg |= (++wave << 11); + reg |= (++map << 15); + reg |= (operand << 20) & 0xFFF00000; + __raw_writel(reg, ipu_dc_tmpl_reg + word * 2); + + reg = (operand >> 12); + reg |= opcode << 4; + reg |= (stop << 9); + __raw_writel(reg, ipu_dc_tmpl_reg + word * 2 + 1); +} + +static void ipu_dc_link_event(int chan, int event, int addr, int priority) +{ + u32 reg; + + reg = __raw_readl(DC_RL_CH(chan, event)); + reg &= ~(0xFFFF << (16 * (event & 0x1))); + reg |= ((addr << 8) | priority) << (16 * (event & 0x1)); + __raw_writel(reg, DC_RL_CH(chan, event)); +} + +/* Y = R * 1.200 + G * 2.343 + B * .453 + 0.250; + * U = R * -.672 + G * -1.328 + B * 2.000 + 512.250.; + * V = R * 2.000 + G * -1.672 + B * -.328 + 512.250.; + */ +static const int rgb2ycbcr_coeff[5][3] = { + {0x4D, 0x96, 0x1D}, + {0x3D5, 0x3AB, 0x80}, + {0x80, 0x395, 0x3EB}, + {0x0000, 0x0200, 0x0200}, /* B0, B1, B2 */ + {0x2, 0x2, 0x2}, /* S0, S1, S2 */ +}; + +/* R = (1.164 * (Y - 16)) + (1.596 * (Cr - 128)); + * G = (1.164 * (Y - 16)) - (0.392 * (Cb - 128)) - (0.813 * (Cr - 128)); + * B = (1.164 * (Y - 16)) + (2.017 * (Cb - 128); + */ +static const int ycbcr2rgb_coeff[5][3] = { + {0x095, 0x000, 0x0CC}, + {0x095, 0x3CE, 0x398}, + {0x095, 0x0FF, 0x000}, + {0x3E42, 0x010A, 0x3DD6}, /*B0,B1,B2 */ + {0x1, 0x1, 0x1}, /*S0,S1,S2 */ +}; + +#define mask_a(a) ((u32)(a) & 0x3FF) +#define mask_b(b) ((u32)(b) & 0x3FFF) + +/* Pls keep S0, S1 and S2 as 0x2 by using this convertion */ +static int rgb_to_yuv(int n, int red, int green, int blue) +{ + int c; + c = red * rgb2ycbcr_coeff[n][0]; + c += green * rgb2ycbcr_coeff[n][1]; + c += blue * rgb2ycbcr_coeff[n][2]; + c /= 16; + c += rgb2ycbcr_coeff[3][n] * 4; + c += 8; + c /= 16; + if (c < 0) + c = 0; + if (c > 255) + c = 255; + return c; +} + +/* + * Row is for BG: RGB2YUV YUV2RGB RGB2RGB YUV2YUV CSC_NONE + * Column is for FG: RGB2YUV YUV2RGB RGB2RGB YUV2YUV CSC_NONE + */ +static struct dp_csc_param_t dp_csc_array[CSC_NUM][CSC_NUM] = { + { + {DP_COM_CONF_CSC_DEF_BOTH, &rgb2ycbcr_coeff}, + {0, 0}, + {0, 0}, + {DP_COM_CONF_CSC_DEF_BG, &rgb2ycbcr_coeff}, + {DP_COM_CONF_CSC_DEF_BG, &rgb2ycbcr_coeff} + }, + { + {0, 0}, + {DP_COM_CONF_CSC_DEF_BOTH, &ycbcr2rgb_coeff}, + {DP_COM_CONF_CSC_DEF_BG, &ycbcr2rgb_coeff}, + {0, 0}, + {DP_COM_CONF_CSC_DEF_BG, &ycbcr2rgb_coeff} + }, + { + {0, 0}, + {DP_COM_CONF_CSC_DEF_FG, &ycbcr2rgb_coeff}, + {0, 0}, + {0, 0}, + {0, 0} + }, + { + {DP_COM_CONF_CSC_DEF_FG, &rgb2ycbcr_coeff}, + {0, 0}, + {0, 0}, + {0, 0}, + {0, 0} + }, + { + {DP_COM_CONF_CSC_DEF_FG, &rgb2ycbcr_coeff}, + {DP_COM_CONF_CSC_DEF_FG, &ycbcr2rgb_coeff}, + {0, 0}, + {0, 0}, + {0, 0} + } +}; + +static enum csc_type_t fg_csc_type = CSC_NONE, bg_csc_type = CSC_NONE; +static int color_key_4rgb = 1; + +void ipu_dp_csc_setup(int dp, struct dp_csc_param_t dp_csc_param, + unsigned char srm_mode_update) +{ + u32 reg; + const int (*coeff)[5][3]; + + if (dp_csc_param.mode >= 0) { + reg = __raw_readl(DP_COM_CONF(dp)); + reg &= ~DP_COM_CONF_CSC_DEF_MASK; + reg |= dp_csc_param.mode; + __raw_writel(reg, DP_COM_CONF(dp)); + } + + coeff = dp_csc_param.coeff; + + if (coeff) { + __raw_writel(mask_a((*coeff)[0][0]) | + (mask_a((*coeff)[0][1]) << 16), DP_CSC_A_0(dp)); + __raw_writel(mask_a((*coeff)[0][2]) | + (mask_a((*coeff)[1][0]) << 16), DP_CSC_A_1(dp)); + __raw_writel(mask_a((*coeff)[1][1]) | + (mask_a((*coeff)[1][2]) << 16), DP_CSC_A_2(dp)); + __raw_writel(mask_a((*coeff)[2][0]) | + (mask_a((*coeff)[2][1]) << 16), DP_CSC_A_3(dp)); + __raw_writel(mask_a((*coeff)[2][2]) | + (mask_b((*coeff)[3][0]) << 16) | + ((*coeff)[4][0] << 30), DP_CSC_0(dp)); + __raw_writel(mask_b((*coeff)[3][1]) | ((*coeff)[4][1] << 14) | + (mask_b((*coeff)[3][2]) << 16) | + ((*coeff)[4][2] << 30), DP_CSC_1(dp)); + } + + if (srm_mode_update) { + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + } +} + +int ipu_dp_init(ipu_channel_t channel, uint32_t in_pixel_fmt, + uint32_t out_pixel_fmt) +{ + int in_fmt, out_fmt; + int dp; + int partial = 0; + uint32_t reg; + + if (channel == MEM_FG_SYNC) { + dp = DP_SYNC; + partial = 1; + } else if (channel == MEM_BG_SYNC) { + dp = DP_SYNC; + partial = 0; + } else if (channel == MEM_BG_ASYNC0) { + dp = DP_ASYNC0; + partial = 0; + } else { + return -EINVAL; + } + + in_fmt = format_to_colorspace(in_pixel_fmt); + out_fmt = format_to_colorspace(out_pixel_fmt); + + if (partial) { + if (in_fmt == RGB) { + if (out_fmt == RGB) + fg_csc_type = RGB2RGB; + else + fg_csc_type = RGB2YUV; + } else { + if (out_fmt == RGB) + fg_csc_type = YUV2RGB; + else + fg_csc_type = YUV2YUV; + } + } else { + if (in_fmt == RGB) { + if (out_fmt == RGB) + bg_csc_type = RGB2RGB; + else + bg_csc_type = RGB2YUV; + } else { + if (out_fmt == RGB) + bg_csc_type = YUV2RGB; + else + bg_csc_type = YUV2YUV; + } + } + + /* Transform color key from rgb to yuv if CSC is enabled */ + reg = __raw_readl(DP_COM_CONF(dp)); + if (color_key_4rgb && (reg & DP_COM_CONF_GWCKE) && + (((fg_csc_type == RGB2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == RGB2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2RGB) && (bg_csc_type == YUV2RGB)))) { + int red, green, blue; + int y, u, v; + uint32_t color_key = __raw_readl(DP_GRAPH_WIND_CTRL(dp)) & + 0xFFFFFFL; + + debug("_ipu_dp_init color key 0x%x need change to yuv fmt!\n", + color_key); + + red = (color_key >> 16) & 0xFF; + green = (color_key >> 8) & 0xFF; + blue = color_key & 0xFF; + + y = rgb_to_yuv(0, red, green, blue); + u = rgb_to_yuv(1, red, green, blue); + v = rgb_to_yuv(2, red, green, blue); + color_key = (y << 16) | (u << 8) | v; + + reg = __raw_readl(DP_GRAPH_WIND_CTRL(dp)) & 0xFF000000L; + __raw_writel(reg | color_key, DP_GRAPH_WIND_CTRL(dp)); + color_key_4rgb = 0; + + debug("_ipu_dp_init color key change to yuv fmt 0x%x!\n", + color_key); + } + + ipu_dp_csc_setup(dp, dp_csc_array[bg_csc_type][fg_csc_type], 1); + + return 0; +} + +void ipu_dp_uninit(ipu_channel_t channel) +{ + int dp; + int partial = 0; + + if (channel == MEM_FG_SYNC) { + dp = DP_SYNC; + partial = 1; + } else if (channel == MEM_BG_SYNC) { + dp = DP_SYNC; + partial = 0; + } else if (channel == MEM_BG_ASYNC0) { + dp = DP_ASYNC0; + partial = 0; + } else { + return; + } + + if (partial) + fg_csc_type = CSC_NONE; + else + bg_csc_type = CSC_NONE; + + ipu_dp_csc_setup(dp, dp_csc_array[bg_csc_type][fg_csc_type], 0); +} + +void ipu_dc_init(int dc_chan, int di, unsigned char interlaced) +{ + u32 reg = 0; + + if ((dc_chan == 1) || (dc_chan == 5)) { + if (interlaced) { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 0, 3); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 0, 2); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, 0, 1); + } else { + if (di) { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 2, 3); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 3, 2); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, + 4, 1); + } else { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 5, 3); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 6, 2); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, + 7, 1); + } + } + ipu_dc_link_event(dc_chan, DC_EVT_NF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR, 0, 0); + + reg = 0x2; + reg |= DC_DISP_ID_SYNC(di) << DC_WR_CH_CONF_PROG_DISP_ID_OFFSET; + reg |= di << 2; + if (interlaced) + reg |= DC_WR_CH_CONF_FIELD_MODE; + } else if ((dc_chan == 8) || (dc_chan == 9)) { + /* async channels */ + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_0, 0x64, 1); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_1, 0x64, 1); + + reg = 0x3; + reg |= DC_DISP_ID_SERIAL << DC_WR_CH_CONF_PROG_DISP_ID_OFFSET; + } + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + + __raw_writel(0x00000000, DC_WR_CH_ADDR(dc_chan)); + + __raw_writel(0x00000084, DC_GEN); +} + +void ipu_dc_uninit(int dc_chan) +{ + if ((dc_chan == 1) || (dc_chan == 5)) { + ipu_dc_link_event(dc_chan, DC_EVT_NL, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOL, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOF, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_EOFIELD, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR, 0, 0); + } else if ((dc_chan == 8) || (dc_chan == 9)) { + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_W_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_W_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_W_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_W_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_W_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_R_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_ADDR_R_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_R_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_CHAN_R_1, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_R_0, 0, 0); + ipu_dc_link_event(dc_chan, DC_EVT_NEW_DATA_R_1, 0, 0); + } +} + +int ipu_chan_is_interlaced(ipu_channel_t channel) +{ + if (channel == MEM_DC_SYNC) + return !!(__raw_readl(DC_WR_CH_CONF_1) & + DC_WR_CH_CONF_FIELD_MODE); + else if ((channel == MEM_BG_SYNC) || (channel == MEM_FG_SYNC)) + return !!(__raw_readl(DC_WR_CH_CONF_5) & + DC_WR_CH_CONF_FIELD_MODE); + return 0; +} + +void ipu_dp_dc_enable(ipu_channel_t channel) +{ + int di; + uint32_t reg; + uint32_t dc_chan; + + if (channel == MEM_FG_SYNC) + dc_chan = 5; + if (channel == MEM_DC_SYNC) + dc_chan = 1; + else if (channel == MEM_BG_SYNC) + dc_chan = 5; + else + return; + + if (channel == MEM_FG_SYNC) { + /* Enable FG channel */ + reg = __raw_readl(DP_COM_CONF(DP_SYNC)); + __raw_writel(reg | DP_COM_CONF_FG_EN, DP_COM_CONF(DP_SYNC)); + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + return; + } + + di = g_dc_di_assignment[dc_chan]; + + /* Make sure other DC sync channel is not assigned same DI */ + reg = __raw_readl(DC_WR_CH_CONF(6 - dc_chan)); + if ((di << 2) == (reg & DC_WR_CH_CONF_PROG_DI_ID)) { + reg &= ~DC_WR_CH_CONF_PROG_DI_ID; + reg |= di ? 0 : DC_WR_CH_CONF_PROG_DI_ID; + __raw_writel(reg, DC_WR_CH_CONF(6 - dc_chan)); + } + + reg = __raw_readl(DC_WR_CH_CONF(dc_chan)); + reg |= 4 << DC_WR_CH_CONF_PROG_TYPE_OFFSET; + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + + clk_enable(g_pixel_clk[di]); +} + +static unsigned char dc_swap; + +void ipu_dp_dc_disable(ipu_channel_t channel, unsigned char swap) +{ + uint32_t reg; + uint32_t csc; + uint32_t dc_chan = 0; + int timeout = 50; + + dc_swap = swap; + + if (channel == MEM_DC_SYNC) { + dc_chan = 1; + } else if (channel == MEM_BG_SYNC) { + dc_chan = 5; + } else if (channel == MEM_FG_SYNC) { + /* Disable FG channel */ + dc_chan = 5; + + reg = __raw_readl(DP_COM_CONF(DP_SYNC)); + csc = reg & DP_COM_CONF_CSC_DEF_MASK; + if (csc == DP_COM_CONF_CSC_DEF_FG) + reg &= ~DP_COM_CONF_CSC_DEF_MASK; + + reg &= ~DP_COM_CONF_FG_EN; + __raw_writel(reg, DP_COM_CONF(DP_SYNC)); + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + + timeout = 50; + + /* + * Wait for DC triple buffer to empty, + * this check is useful for tv overlay. + */ + if (g_dc_di_assignment[dc_chan] == 0) + while ((__raw_readl(DC_STAT) & 0x00000002) + != 0x00000002) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + else if (g_dc_di_assignment[dc_chan] == 1) + while ((__raw_readl(DC_STAT) & 0x00000020) + != 0x00000020) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + return; + } else { + return; + } + + if (dc_swap) { + /* Swap DC channel 1 and 5 settings, and disable old dc chan */ + reg = __raw_readl(DC_WR_CH_CONF(dc_chan)); + __raw_writel(reg, DC_WR_CH_CONF(6 - dc_chan)); + reg &= ~DC_WR_CH_CONF_PROG_TYPE_MASK; + reg ^= DC_WR_CH_CONF_PROG_DI_ID; + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + } else { + timeout = 50; + + /* Wait for DC triple buffer to empty */ + if (g_dc_di_assignment[dc_chan] == 0) + while ((__raw_readl(DC_STAT) & 0x00000002) + != 0x00000002) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + else if (g_dc_di_assignment[dc_chan] == 1) + while ((__raw_readl(DC_STAT) & 0x00000020) + != 0x00000020) { + udelay(2000); + timeout -= 2; + if (timeout <= 0) + break; + } + + reg = __raw_readl(DC_WR_CH_CONF(dc_chan)); + reg &= ~DC_WR_CH_CONF_PROG_TYPE_MASK; + __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); + + reg = __raw_readl(IPU_DISP_GEN); + if (g_dc_di_assignment[dc_chan]) + reg &= ~DI1_COUNTER_RELEASE; + else + reg &= ~DI0_COUNTER_RELEASE; + __raw_writel(reg, IPU_DISP_GEN); + + /* Clock is already off because it must be done quickly, but + we need to fix the ref count */ + clk_disable(g_pixel_clk[g_dc_di_assignment[dc_chan]]); + } +} + +void ipu_init_dc_mappings(void) +{ + /* IPU_PIX_FMT_RGB24 */ + ipu_dc_map_clear(0); + ipu_dc_map_config(0, 0, 7, 0xFF); + ipu_dc_map_config(0, 1, 15, 0xFF); + ipu_dc_map_config(0, 2, 23, 0xFF); + + /* IPU_PIX_FMT_RGB666 */ + ipu_dc_map_clear(1); + ipu_dc_map_config(1, 0, 5, 0xFC); + ipu_dc_map_config(1, 1, 11, 0xFC); + ipu_dc_map_config(1, 2, 17, 0xFC); + + /* IPU_PIX_FMT_YUV444 */ + ipu_dc_map_clear(2); + ipu_dc_map_config(2, 0, 15, 0xFF); + ipu_dc_map_config(2, 1, 23, 0xFF); + ipu_dc_map_config(2, 2, 7, 0xFF); + + /* IPU_PIX_FMT_RGB565 */ + ipu_dc_map_clear(3); + ipu_dc_map_config(3, 0, 4, 0xF8); + ipu_dc_map_config(3, 1, 10, 0xFC); + ipu_dc_map_config(3, 2, 15, 0xF8); + + /* IPU_PIX_FMT_LVDS666 */ + ipu_dc_map_clear(4); + ipu_dc_map_config(4, 0, 5, 0xFC); + ipu_dc_map_config(4, 1, 13, 0xFC); + ipu_dc_map_config(4, 2, 21, 0xFC); +} + +int ipu_pixfmt_to_map(uint32_t fmt) +{ + switch (fmt) { + case IPU_PIX_FMT_GENERIC: + case IPU_PIX_FMT_RGB24: + return 0; + case IPU_PIX_FMT_RGB666: + return 1; + case IPU_PIX_FMT_YUV444: + return 2; + case IPU_PIX_FMT_RGB565: + return 3; + case IPU_PIX_FMT_LVDS666: + return 4; + } + + return -1; +} + +/* + * This function is called to adapt synchronous LCD panel to IPU restriction. + */ +void adapt_panel_to_ipu_restricitions(uint32_t *pixel_clk, + uint16_t width, uint16_t height, + uint16_t h_start_width, + uint16_t h_end_width, + uint16_t v_start_width, + uint16_t *v_end_width) +{ + if (*v_end_width < 2) { + uint16_t total_width = width + h_start_width + h_end_width; + uint16_t total_height_old = height + v_start_width + + (*v_end_width); + uint16_t total_height_new = height + v_start_width + 2; + *v_end_width = 2; + *pixel_clk = (*pixel_clk) * total_width * total_height_new / + (total_width * total_height_old); + printf("WARNING: adapt panel end blank lines\n"); + } +} + +/* + * This function is called to initialize a synchronous LCD panel. + * + * @param disp The DI the panel is attached to. + * + * @param pixel_clk Desired pixel clock frequency in Hz. + * + * @param pixel_fmt Input parameter for pixel format of buffer. + * Pixel format is a FOURCC ASCII code. + * + * @param width The width of panel in pixels. + * + * @param height The height of panel in pixels. + * + * @param hStartWidth The number of pixel clocks between the HSYNC + * signal pulse and the start of valid data. + * + * @param hSyncWidth The width of the HSYNC signal in units of pixel + * clocks. + * + * @param hEndWidth The number of pixel clocks between the end of + * valid data and the HSYNC signal for next line. + * + * @param vStartWidth The number of lines between the VSYNC + * signal pulse and the start of valid data. + * + * @param vSyncWidth The width of the VSYNC signal in units of lines + * + * @param vEndWidth The number of lines between the end of valid + * data and the VSYNC signal for next frame. + * + * @param sig Bitfield of signal polarities for LCD interface. + * + * @return This function returns 0 on success or negative error code on + * fail. + */ + +int32_t ipu_init_sync_panel(int disp, uint32_t pixel_clk, + uint16_t width, uint16_t height, + uint32_t pixel_fmt, + uint16_t h_start_width, uint16_t h_sync_width, + uint16_t h_end_width, uint16_t v_start_width, + uint16_t v_sync_width, uint16_t v_end_width, + uint32_t v_to_h_sync, ipu_di_signal_cfg_t sig) +{ + uint32_t reg; + uint32_t di_gen, vsync_cnt; + uint32_t div, rounded_pixel_clk; + uint32_t h_total, v_total; + int map; + struct clk *di_parent; + + debug("panel size = %d x %d\n", width, height); + + if ((v_sync_width == 0) || (h_sync_width == 0)) + return EINVAL; + + adapt_panel_to_ipu_restricitions(&pixel_clk, width, height, + h_start_width, h_end_width, + v_start_width, &v_end_width); + h_total = width + h_sync_width + h_start_width + h_end_width; + v_total = height + v_sync_width + v_start_width + v_end_width; + + /* Init clocking */ + debug("pixel clk = %d\n", pixel_clk); + + if (sig.ext_clk) { + if (!(g_di1_tvout && (disp == 1))) { /*not round div for tvout*/ + /* + * Set the PLL to be an even multiple + * of the pixel clock. + */ + if ((clk_get_usecount(g_pixel_clk[0]) == 0) && + (clk_get_usecount(g_pixel_clk[1]) == 0)) { + di_parent = clk_get_parent(g_di_clk[disp]); + rounded_pixel_clk = + clk_round_rate(g_pixel_clk[disp], + pixel_clk); + div = clk_get_rate(di_parent) / + rounded_pixel_clk; + if (div % 2) + div++; + if (clk_get_rate(di_parent) != div * + rounded_pixel_clk) + clk_set_rate(di_parent, + div * rounded_pixel_clk); + udelay(10000); + clk_set_rate(g_di_clk[disp], + 2 * rounded_pixel_clk); + udelay(10000); + } + } + clk_set_parent(g_pixel_clk[disp], g_di_clk[disp]); + } else { + if (clk_get_usecount(g_pixel_clk[disp]) != 0) + clk_set_parent(g_pixel_clk[disp], g_ipu_clk); + } + rounded_pixel_clk = clk_round_rate(g_pixel_clk[disp], pixel_clk); + clk_set_rate(g_pixel_clk[disp], rounded_pixel_clk); + udelay(5000); + /* Get integer portion of divider */ + div = clk_get_rate(clk_get_parent(g_pixel_clk[disp])) / + rounded_pixel_clk; + + ipu_di_data_wave_config(disp, SYNC_WAVE, div - 1, div - 1); + ipu_di_data_pin_config(disp, SYNC_WAVE, DI_PIN15, 3, 0, div * 2); + + map = ipu_pixfmt_to_map(pixel_fmt); + if (map < 0) { + debug("IPU_DISP: No MAP\n"); + return -EINVAL; + } + + di_gen = __raw_readl(DI_GENERAL(disp)); + + if (sig.interlaced) { + /* Setup internal HSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 1, /* counter */ + h_total / 2 - 1,/* run count */ + DI_SYNC_CLK, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* Field 1 VSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 2, /* counter */ + h_total - 1, /* run count */ + DI_SYNC_CLK, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 4 /* COUNT DOWN */ + ); + + /* Setup internal HSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 3, /* counter */ + v_total * 2 - 1,/* run count */ + DI_SYNC_INT_HSYNC, /* run_resolution */ + 1, /* offset */ + DI_SYNC_INT_HSYNC, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 4 /* COUNT DOWN */ + ); + + /* Active Field ? */ + ipu_di_sync_config( + disp, /* display */ + 4, /* counter */ + v_total / 2 - 1,/* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + v_start_width, /* offset */ + DI_SYNC_HSYNC, /* offset resolution */ + 2, /* repeat count */ + DI_SYNC_VSYNC, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* Active Line */ + ipu_di_sync_config( + disp, /* display */ + 5, /* counter */ + 0, /* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + height / 2, /* repeat count */ + 4, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* Field 0 VSYNC waveform */ + ipu_di_sync_config( + disp, /* display */ + 6, /* counter */ + v_total - 1, /* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + 0, /* offset */ + DI_SYNC_NONE, /* offset resolution */ + 0, /* repeat count */ + DI_SYNC_NONE, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* DC VSYNC waveform */ + vsync_cnt = 7; + ipu_di_sync_config( + disp, /* display */ + 7, /* counter */ + v_total / 2 - 1,/* run count */ + DI_SYNC_HSYNC, /* run_resolution */ + 9, /* offset */ + DI_SYNC_HSYNC, /* offset resolution */ + 2, /* repeat count */ + DI_SYNC_VSYNC, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + /* active pixel waveform */ + ipu_di_sync_config( + disp, /* display */ + 8, /* counter */ + 0, /* run count */ + DI_SYNC_CLK, /* run_resolution */ + h_start_width, /* offset */ + DI_SYNC_CLK, /* offset resolution */ + width, /* repeat count */ + 5, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 0 /* COUNT DOWN */ + ); + + ipu_di_sync_config( + disp, /* display */ + 9, /* counter */ + v_total - 1, /* run count */ + DI_SYNC_INT_HSYNC,/* run_resolution */ + v_total / 2, /* offset */ + DI_SYNC_INT_HSYNC,/* offset resolution */ + 0, /* repeat count */ + DI_SYNC_HSYNC, /* CNT_CLR_SEL */ + 0, /* CNT_POLARITY_GEN_EN */ + DI_SYNC_NONE, /* CNT_POLARITY_CLR_SEL */ + DI_SYNC_NONE, /* CNT_POLARITY_TRIGGER_SEL */ + 0, /* COUNT UP */ + 4 /* COUNT DOWN */ + ); + + /* set gentime select and tag sel */ + reg = __raw_readl(DI_SW_GEN1(disp, 9)); + reg &= 0x1FFFFFFF; + reg |= (3 - 1)<<29 | 0x00008000; + __raw_writel(reg, DI_SW_GEN1(disp, 9)); + + __raw_writel(v_total / 2 - 1, DI_SCR_CONF(disp)); + + /* set y_sel = 1 */ + di_gen |= 0x10000000; + di_gen |= DI_GEN_POLARITY_5; + di_gen |= DI_GEN_POLARITY_8; + } else { + /* Setup internal HSYNC waveform */ + ipu_di_sync_config(disp, 1, h_total - 1, DI_SYNC_CLK, + 0, DI_SYNC_NONE, 0, DI_SYNC_NONE, + 0, DI_SYNC_NONE, + DI_SYNC_NONE, 0, 0); + + /* Setup external (delayed) HSYNC waveform */ + ipu_di_sync_config(disp, DI_SYNC_HSYNC, h_total - 1, + DI_SYNC_CLK, div * v_to_h_sync, DI_SYNC_CLK, + 0, DI_SYNC_NONE, 1, DI_SYNC_NONE, + DI_SYNC_CLK, 0, h_sync_width * 2); + /* Setup VSYNC waveform */ + vsync_cnt = DI_SYNC_VSYNC; + ipu_di_sync_config(disp, DI_SYNC_VSYNC, v_total - 1, + DI_SYNC_INT_HSYNC, 0, DI_SYNC_NONE, 0, + DI_SYNC_NONE, 1, DI_SYNC_NONE, + DI_SYNC_INT_HSYNC, 0, v_sync_width * 2); + __raw_writel(v_total - 1, DI_SCR_CONF(disp)); + + /* Setup active data waveform to sync with DC */ + ipu_di_sync_config(disp, 4, 0, DI_SYNC_HSYNC, + v_sync_width + v_start_width, DI_SYNC_HSYNC, + height, + DI_SYNC_VSYNC, 0, DI_SYNC_NONE, + DI_SYNC_NONE, 0, 0); + ipu_di_sync_config(disp, 5, 0, DI_SYNC_CLK, + h_sync_width + h_start_width, DI_SYNC_CLK, + width, 4, 0, DI_SYNC_NONE, DI_SYNC_NONE, 0, + 0); + + /* reset all unused counters */ + __raw_writel(0, DI_SW_GEN0(disp, 6)); + __raw_writel(0, DI_SW_GEN1(disp, 6)); + __raw_writel(0, DI_SW_GEN0(disp, 7)); + __raw_writel(0, DI_SW_GEN1(disp, 7)); + __raw_writel(0, DI_SW_GEN0(disp, 8)); + __raw_writel(0, DI_SW_GEN1(disp, 8)); + __raw_writel(0, DI_SW_GEN0(disp, 9)); + __raw_writel(0, DI_SW_GEN1(disp, 9)); + + reg = __raw_readl(DI_STP_REP(disp, 6)); + reg &= 0x0000FFFF; + __raw_writel(reg, DI_STP_REP(disp, 6)); + __raw_writel(0, DI_STP_REP(disp, 7)); + __raw_writel(0, DI_STP_REP(disp, 9)); + + /* Init template microcode */ + if (disp) { + ipu_dc_write_tmpl(2, WROD(0), 0, map, SYNC_WAVE, 8, 5); + ipu_dc_write_tmpl(3, WROD(0), 0, map, SYNC_WAVE, 4, 5); + ipu_dc_write_tmpl(4, WROD(0), 0, map, SYNC_WAVE, 0, 5); + } else { + ipu_dc_write_tmpl(5, WROD(0), 0, map, SYNC_WAVE, 8, 5); + ipu_dc_write_tmpl(6, WROD(0), 0, map, SYNC_WAVE, 4, 5); + ipu_dc_write_tmpl(7, WROD(0), 0, map, SYNC_WAVE, 0, 5); + } + + if (sig.Hsync_pol) + di_gen |= DI_GEN_POLARITY_2; + if (sig.Vsync_pol) + di_gen |= DI_GEN_POLARITY_3; + + if (sig.clk_pol) + di_gen |= DI_GEN_POL_CLK; + + } + + __raw_writel(di_gen, DI_GENERAL(disp)); + + __raw_writel((--vsync_cnt << DI_VSYNC_SEL_OFFSET) | + 0x00000002, DI_SYNC_AS_GEN(disp)); + + reg = __raw_readl(DI_POL(disp)); + reg &= ~(DI_POL_DRDY_DATA_POLARITY | DI_POL_DRDY_POLARITY_15); + if (sig.enable_pol) + reg |= DI_POL_DRDY_POLARITY_15; + if (sig.data_pol) + reg |= DI_POL_DRDY_DATA_POLARITY; + __raw_writel(reg, DI_POL(disp)); + + __raw_writel(width, DC_DISP_CONF2(DC_DISP_ID_SYNC(disp))); + + return 0; +} + +/* + * This function sets the foreground and background plane global alpha blending + * modes. This function also sets the DP graphic plane according to the + * parameter of IPUv3 DP channel. + * + * @param channel IPUv3 DP channel + * + * @param enable Boolean to enable or disable global alpha + * blending. If disabled, local blending is used. + * + * @param alpha Global alpha value. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_disp_set_global_alpha(ipu_channel_t channel, unsigned char enable, + uint8_t alpha) +{ + uint32_t reg; + uint32_t flow; + + unsigned char bg_chan; + + if (channel == MEM_BG_SYNC || channel == MEM_FG_SYNC) + flow = DP_SYNC; + else if (channel == MEM_BG_ASYNC0 || channel == MEM_FG_ASYNC0) + flow = DP_ASYNC0; + else if (channel == MEM_BG_ASYNC1 || channel == MEM_FG_ASYNC1) + flow = DP_ASYNC1; + else + return -EINVAL; + + if (channel == MEM_BG_SYNC || channel == MEM_BG_ASYNC0 || + channel == MEM_BG_ASYNC1) + bg_chan = 1; + else + bg_chan = 0; + + if (!g_ipu_clk_enabled) + clk_enable(g_ipu_clk); + + if (bg_chan) { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg & ~DP_COM_CONF_GWSEL, DP_COM_CONF(flow)); + } else { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg | DP_COM_CONF_GWSEL, DP_COM_CONF(flow)); + } + + if (enable) { + reg = __raw_readl(DP_GRAPH_WIND_CTRL(flow)) & 0x00FFFFFFL; + __raw_writel(reg | ((uint32_t) alpha << 24), + DP_GRAPH_WIND_CTRL(flow)); + + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg | DP_COM_CONF_GWAM, DP_COM_CONF(flow)); + } else { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg & ~DP_COM_CONF_GWAM, DP_COM_CONF(flow)); + } + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + + if (!g_ipu_clk_enabled) + clk_disable(g_ipu_clk); + + return 0; +} + +/* + * This function sets the transparent color key for SDC graphic plane. + * + * @param channel Input parameter for the logical channel ID. + * + * @param enable Boolean to enable or disable color key + * + * @param colorKey 24-bit RGB color for transparent color key. + * + * @return Returns 0 on success or negative error code on fail + */ +int32_t ipu_disp_set_color_key(ipu_channel_t channel, unsigned char enable, + uint32_t color_key) +{ + uint32_t reg, flow; + int y, u, v; + int red, green, blue; + + if (channel == MEM_BG_SYNC || channel == MEM_FG_SYNC) + flow = DP_SYNC; + else if (channel == MEM_BG_ASYNC0 || channel == MEM_FG_ASYNC0) + flow = DP_ASYNC0; + else if (channel == MEM_BG_ASYNC1 || channel == MEM_FG_ASYNC1) + flow = DP_ASYNC1; + else + return -EINVAL; + + if (!g_ipu_clk_enabled) + clk_enable(g_ipu_clk); + + color_key_4rgb = 1; + /* Transform color key from rgb to yuv if CSC is enabled */ + if (((fg_csc_type == RGB2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == RGB2YUV)) || + ((fg_csc_type == YUV2YUV) && (bg_csc_type == YUV2YUV)) || + ((fg_csc_type == YUV2RGB) && (bg_csc_type == YUV2RGB))) { + + debug("color key 0x%x need change to yuv fmt\n", color_key); + + red = (color_key >> 16) & 0xFF; + green = (color_key >> 8) & 0xFF; + blue = color_key & 0xFF; + + y = rgb_to_yuv(0, red, green, blue); + u = rgb_to_yuv(1, red, green, blue); + v = rgb_to_yuv(2, red, green, blue); + color_key = (y << 16) | (u << 8) | v; + + color_key_4rgb = 0; + + debug("color key change to yuv fmt 0x%x\n", color_key); + } + + if (enable) { + reg = __raw_readl(DP_GRAPH_WIND_CTRL(flow)) & 0xFF000000L; + __raw_writel(reg | color_key, DP_GRAPH_WIND_CTRL(flow)); + + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg | DP_COM_CONF_GWCKE, DP_COM_CONF(flow)); + } else { + reg = __raw_readl(DP_COM_CONF(flow)); + __raw_writel(reg & ~DP_COM_CONF_GWCKE, DP_COM_CONF(flow)); + } + + reg = __raw_readl(IPU_SRM_PRI2) | 0x8; + __raw_writel(reg, IPU_SRM_PRI2); + + if (!g_ipu_clk_enabled) + clk_disable(g_ipu_clk); + + return 0; +} diff --git a/drivers/video/ipu_regs.h b/drivers/video/ipu_regs.h new file mode 100644 index 0000000..36f07bb --- /dev/null +++ b/drivers/video/ipu_regs.h @@ -0,0 +1,418 @@ +/* + * Porting to u-boot: + * + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de + * + * Linux IPU driver for MX51: + * + * (C) Copyright 2005-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __IPU_REGS_INCLUDED__ +#define __IPU_REGS_INCLUDED__ + +#define IPU_DISP0_BASE 0x00000000 +#define IPU_MCU_T_DEFAULT 8 +#define IPU_DISP1_BASE (IPU_MCU_T_DEFAULT << 25) +#define IPU_CM_REG_BASE 0x1E000000 +#define IPU_STAT_REG_BASE 0x1E000200 +#define IPU_IDMAC_REG_BASE 0x1E008000 +#define IPU_ISP_REG_BASE 0x1E010000 +#define IPU_DP_REG_BASE 0x1E018000 +#define IPU_IC_REG_BASE 0x1E020000 +#define IPU_IRT_REG_BASE 0x1E028000 +#define IPU_CSI0_REG_BASE 0x1E030000 +#define IPU_CSI1_REG_BASE 0x1E038000 +#define IPU_DI0_REG_BASE 0x1E040000 +#define IPU_DI1_REG_BASE 0x1E048000 +#define IPU_SMFC_REG_BASE 0x1E050000 +#define IPU_DC_REG_BASE 0x1E058000 +#define IPU_DMFC_REG_BASE 0x1E060000 +#define IPU_CPMEM_REG_BASE 0x1F000000 +#define IPU_LUT_REG_BASE 0x1F020000 +#define IPU_SRM_REG_BASE 0x1F040000 +#define IPU_TPM_REG_BASE 0x1F060000 +#define IPU_DC_TMPL_REG_BASE 0x1F080000 +#define IPU_ISP_TBPR_REG_BASE 0x1F0C0000 +#define IPU_VDI_REG_BASE 0x1E068000 + + +extern u32 *ipu_dc_tmpl_reg; + +#define DC_EVT_NF 0 +#define DC_EVT_NL 1 +#define DC_EVT_EOF 2 +#define DC_EVT_NFIELD 3 +#define DC_EVT_EOL 4 +#define DC_EVT_EOFIELD 5 +#define DC_EVT_NEW_ADDR 6 +#define DC_EVT_NEW_CHAN 7 +#define DC_EVT_NEW_DATA 8 + +#define DC_EVT_NEW_ADDR_W_0 0 +#define DC_EVT_NEW_ADDR_W_1 1 +#define DC_EVT_NEW_CHAN_W_0 2 +#define DC_EVT_NEW_CHAN_W_1 3 +#define DC_EVT_NEW_DATA_W_0 4 +#define DC_EVT_NEW_DATA_W_1 5 +#define DC_EVT_NEW_ADDR_R_0 6 +#define DC_EVT_NEW_ADDR_R_1 7 +#define DC_EVT_NEW_CHAN_R_0 8 +#define DC_EVT_NEW_CHAN_R_1 9 +#define DC_EVT_NEW_DATA_R_0 10 +#define DC_EVT_NEW_DATA_R_1 11 + +/* Software reset for ipu */ +#define SW_IPU_RST 8 + +enum { + IPU_CONF_DP_EN = 0x00000020, + IPU_CONF_DI0_EN = 0x00000040, + IPU_CONF_DI1_EN = 0x00000080, + IPU_CONF_DMFC_EN = 0x00000400, + IPU_CONF_DC_EN = 0x00000200, + + DI0_COUNTER_RELEASE = 0x01000000, + DI1_COUNTER_RELEASE = 0x02000000, + + DI_DW_GEN_ACCESS_SIZE_OFFSET = 24, + DI_DW_GEN_COMPONENT_SIZE_OFFSET = 16, + + DI_GEN_DI_CLK_EXT = 0x100000, + DI_GEN_POLARITY_1 = 0x00000001, + DI_GEN_POLARITY_2 = 0x00000002, + DI_GEN_POLARITY_3 = 0x00000004, + DI_GEN_POLARITY_4 = 0x00000008, + DI_GEN_POLARITY_5 = 0x00000010, + DI_GEN_POLARITY_6 = 0x00000020, + DI_GEN_POLARITY_7 = 0x00000040, + DI_GEN_POLARITY_8 = 0x00000080, + DI_GEN_POL_CLK = 0x20000, + + DI_POL_DRDY_DATA_POLARITY = 0x00000080, + DI_POL_DRDY_POLARITY_15 = 0x00000010, + DI_VSYNC_SEL_OFFSET = 13, + + DC_WR_CH_CONF_FIELD_MODE = 0x00000200, + DC_WR_CH_CONF_PROG_TYPE_OFFSET = 5, + DC_WR_CH_CONF_PROG_TYPE_MASK = 0x000000E0, + DC_WR_CH_CONF_PROG_DI_ID = 0x00000004, + DC_WR_CH_CONF_PROG_DISP_ID_OFFSET = 3, + DC_WR_CH_CONF_PROG_DISP_ID_MASK = 0x00000018, + + DP_COM_CONF_FG_EN = 0x00000001, + DP_COM_CONF_GWSEL = 0x00000002, + DP_COM_CONF_GWAM = 0x00000004, + DP_COM_CONF_GWCKE = 0x00000008, + DP_COM_CONF_CSC_DEF_MASK = 0x00000300, + DP_COM_CONF_CSC_DEF_OFFSET = 8, + DP_COM_CONF_CSC_DEF_FG = 0x00000300, + DP_COM_CONF_CSC_DEF_BG = 0x00000200, + DP_COM_CONF_CSC_DEF_BOTH = 0x00000100, + DP_COM_CONF_GAMMA_EN = 0x00001000, + DP_COM_CONF_GAMMA_YUV_EN = 0x00002000, +}; + +enum di_pins { + DI_PIN11 = 0, + DI_PIN12 = 1, + DI_PIN13 = 2, + DI_PIN14 = 3, + DI_PIN15 = 4, + DI_PIN16 = 5, + DI_PIN17 = 6, + DI_PIN_CS = 7, + + DI_PIN_SER_CLK = 0, + DI_PIN_SER_RS = 1, +}; + +enum di_sync_wave { + DI_SYNC_NONE = -1, + DI_SYNC_CLK = 0, + DI_SYNC_INT_HSYNC = 1, + DI_SYNC_HSYNC = 2, + DI_SYNC_VSYNC = 3, + DI_SYNC_DE = 5, +}; + +struct ipu_cm { + u32 conf; + u32 sisg_ctrl0; + u32 sisg_ctrl1; + u32 sisg_set[6]; + u32 sisg_clear[6]; + u32 int_ctrl[15]; + u32 sdma_event[10]; + u32 srm_pri1; + u32 srm_pri2; + u32 fs_proc_flow[3]; + u32 fs_disp_flow[2]; + u32 skip; + u32 disp_alt_conf; + u32 disp_gen; + u32 disp_alt[4]; + u32 snoop; + u32 mem_rst; + u32 pm; + u32 gpr; + u32 reserved0[26]; + u32 ch_db_mode_sel[2]; + u32 reserved1[16]; + u32 alt_ch_db_mode_sel[2]; + u32 reserved2[2]; + u32 ch_trb_mode_sel[2]; +}; + +struct ipu_idmac { + u32 conf; + u32 ch_en[2]; + u32 sep_alpha; + u32 alt_sep_alpha; + u32 ch_pri[2]; + u32 wm_en[2]; + u32 lock_en[2]; + u32 sub_addr[5]; + u32 bndm_en[2]; + u32 sc_cord[2]; + u32 reserved[45]; + u32 ch_busy[2]; +}; + +struct ipu_com_async { + u32 com_conf_async; + u32 graph_wind_ctrl_async; + u32 fg_pos_async; + u32 cur_pos_async; + u32 cur_map_async; + u32 gamma_c_async[8]; + u32 gamma_s_async[4]; + u32 dp_csca_async[4]; + u32 dp_csc_async[2]; +}; + +struct ipu_dp { + u32 com_conf_sync; + u32 graph_wind_ctrl_sync; + u32 fg_pos_sync; + u32 cur_pos_sync; + u32 cur_map_sync; + u32 gamma_c_sync[8]; + u32 gamma_s_sync[4]; + u32 csca_sync[4]; + u32 csc_sync[2]; + u32 cur_pos_alt; + struct ipu_com_async async[2]; +}; + +struct ipu_di { + u32 general; + u32 bs_clkgen0; + u32 bs_clkgen1; + u32 sw_gen0[9]; + u32 sw_gen1[9]; + u32 sync_as; + u32 dw_gen[12]; + u32 dw_set[48]; + u32 stp_rep[4]; + u32 stp_rep9; + u32 ser_conf; + u32 ssc; + u32 pol; + u32 aw0; + u32 aw1; + u32 scr_conf; + u32 stat; +}; + +struct ipu_stat { + u32 int_stat[15]; + u32 cur_buf[2]; + u32 alt_cur_buf_0; + u32 alt_cur_buf_1; + u32 srm_stat; + u32 proc_task_stat; + u32 disp_task_stat; + u32 triple_cur_buf[4]; + u32 ch_buf0_rdy[2]; + u32 ch_buf1_rdy[2]; + u32 alt_ch_buf0_rdy[2]; + u32 alt_ch_buf1_rdy[2]; + u32 ch_buf2_rdy[2]; +}; + +struct ipu_dc_ch { + u32 wr_ch_conf; + u32 wr_ch_addr; + u32 rl[5]; +}; + +struct ipu_dc { + struct ipu_dc_ch dc_ch0_1_2[3]; + u32 cmd_ch_conf_3; + u32 cmd_ch_conf_4; + struct ipu_dc_ch dc_ch5_6[2]; + struct ipu_dc_ch dc_ch8; + u32 rl6_ch_8; + struct ipu_dc_ch dc_ch9; + u32 rl6_ch_9; + u32 gen; + u32 disp_conf1[4]; + u32 disp_conf2[4]; + u32 di0_conf[2]; + u32 di1_conf[2]; + u32 dc_map_ptr[15]; + u32 dc_map_val[12]; + u32 udge[16]; + u32 lla[2]; + u32 r_lla[2]; + u32 wr_ch_addr_5_alt; + u32 stat; +}; + +struct ipu_dmfc { + u32 rd_chan; + u32 wr_chan; + u32 wr_chan_def; + u32 dp_chan; + u32 dp_chan_def; + u32 general[2]; + u32 ic_ctrl; + u32 wr_chan_alt; + u32 wr_chan_def_alt; + u32 general1_alt; + u32 stat; +}; + +#define IPU_CM_REG ((struct ipu_cm *)(IPU_CTRL_BASE_ADDR + \ + IPU_CM_REG_BASE)) +#define IPU_CONF (&IPU_CM_REG->conf) +#define IPU_SRM_PRI1 (&IPU_CM_REG->srm_pri1) +#define IPU_SRM_PRI2 (&IPU_CM_REG->srm_pri2) +#define IPU_FS_PROC_FLOW1 (&IPU_CM_REG->fs_proc_flow[0]) +#define IPU_FS_PROC_FLOW2 (&IPU_CM_REG->fs_proc_flow[1]) +#define IPU_FS_PROC_FLOW3 (&IPU_CM_REG->fs_proc_flow[2]) +#define IPU_FS_DISP_FLOW1 (&IPU_CM_REG->fs_disp_flow[0]) +#define IPU_DISP_GEN (&IPU_CM_REG->disp_gen) +#define IPU_MEM_RST (&IPU_CM_REG->mem_rst) +#define IPU_GPR (&IPU_CM_REG->gpr) +#define IPU_CHA_DB_MODE_SEL(ch) (&IPU_CM_REG->ch_db_mode_sel[ch / 32]) + +#define IPU_STAT ((struct ipu_stat *)(IPU_CTRL_BASE_ADDR + \ + IPU_STAT_REG_BASE)) +#define IPU_CHA_CUR_BUF(ch) (&IPU_STAT->cur_buf[ch / 32]) +#define IPU_CHA_BUF0_RDY(ch) (&IPU_STAT->ch_buf0_rdy[ch / 32]) +#define IPU_CHA_BUF1_RDY(ch) (&IPU_STAT->ch_buf1_rdy[ch / 32]) + +#define IPU_INT_CTRL(n) (&IPU_CM_REG->int_ctrl[(n) - 1]) + +#define IDMAC_REG ((struct ipu_idmac *)(IPU_CTRL_BASE_ADDR + \ + IPU_IDMAC_REG_BASE)) +#define IDMAC_CONF (&IDMAC_REG->conf) +#define IDMAC_CHA_EN(ch) (&IDMAC_REG->ch_en[ch / 32]) +#define IDMAC_CHA_PRI(ch) (&IDMAC_REG->ch_pri[ch / 32]) + +#define DI_REG(di) ((struct ipu_di *)(IPU_CTRL_BASE_ADDR + \ + ((di == 1) ? IPU_DI1_REG_BASE : \ + IPU_DI0_REG_BASE))) +#define DI_GENERAL(di) (&DI_REG(di)->general) +#define DI_BS_CLKGEN0(di) (&DI_REG(di)->bs_clkgen0) +#define DI_BS_CLKGEN1(di) (&DI_REG(di)->bs_clkgen1) + +#define DI_SW_GEN0(di, gen) (&DI_REG(di)->sw_gen0[gen - 1]) +#define DI_SW_GEN1(di, gen) (&DI_REG(di)->sw_gen1[gen - 1]) +#define DI_STP_REP(di, gen) (&DI_REG(di)->stp_rep[(gen - 1) / 2]) +#define DI_SYNC_AS_GEN(di) (&DI_REG(di)->sync_as) +#define DI_DW_GEN(di, gen) (&DI_REG(di)->dw_gen[gen]) +#define DI_DW_SET(di, gen, set) (&DI_REG(di)->dw_set[gen + 12 * set]) +#define DI_POL(di) (&DI_REG(di)->pol) +#define DI_SCR_CONF(di) (&DI_REG(di)->scr_conf) + +#define DMFC_REG ((struct ipu_dmfc *)(IPU_CTRL_BASE_ADDR + \ + IPU_DMFC_REG_BASE)) +#define DMFC_WR_CHAN (&DMFC_REG->wr_chan) +#define DMFC_WR_CHAN_DEF (&DMFC_REG->wr_chan_def) +#define DMFC_DP_CHAN (&DMFC_REG->dp_chan) +#define DMFC_DP_CHAN_DEF (&DMFC_REG->dp_chan_def) +#define DMFC_GENERAL1 (&DMFC_REG->general[0]) +#define DMFC_IC_CTRL (&DMFC_REG->ic_ctrl) + + +#define DC_REG ((struct ipu_dc *)(IPU_CTRL_BASE_ADDR + \ + IPU_DC_REG_BASE)) +#define DC_MAP_CONF_PTR(n) (&DC_REG->dc_map_ptr[n / 2]) +#define DC_MAP_CONF_VAL(n) (&DC_REG->dc_map_val[n / 2]) + + +static inline struct ipu_dc_ch *dc_ch_offset(int ch) +{ + switch (ch) { + case 0: + case 1: + case 2: + return &DC_REG->dc_ch0_1_2[ch]; + case 5: + case 6: + return &DC_REG->dc_ch5_6[ch - 5]; + case 8: + return &DC_REG->dc_ch8; + case 9: + return &DC_REG->dc_ch9; + default: + printf("%s: invalid channel %d\n", __func__, ch); + return NULL; + } + +} + +#define DC_RL_CH(ch, evt) (&dc_ch_offset(ch)->rl[evt / 2]) + +#define DC_WR_CH_CONF(ch) (&dc_ch_offset(ch)->wr_ch_conf) +#define DC_WR_CH_ADDR(ch) (&dc_ch_offset(ch)->wr_ch_addr) + +#define DC_WR_CH_CONF_1 DC_WR_CH_CONF(1) +#define DC_WR_CH_CONF_5 DC_WR_CH_CONF(5) + +#define DC_GEN (&DC_REG->gen) +#define DC_DISP_CONF2(disp) (&DC_REG->disp_conf2[disp]) +#define DC_STAT (&DC_REG->stat) + +#define DP_SYNC 0 +#define DP_ASYNC0 0x60 +#define DP_ASYNC1 0xBC + +#define DP_REG ((struct ipu_dp *)(IPU_CTRL_BASE_ADDR + \ + IPU_DP_REG_BASE)) +#define DP_COM_CONF(flow) (&DP_REG->com_conf_sync) +#define DP_GRAPH_WIND_CTRL(flow) (&DP_REG->graph_wind_ctrl_sync) +#define DP_CSC_A_0(flow) (&DP_REG->csca_sync[0]) +#define DP_CSC_A_1(flow) (&DP_REG->csca_sync[1]) +#define DP_CSC_A_2(flow) (&DP_REG->csca_sync[2]) +#define DP_CSC_A_3(flow) (&DP_REG->csca_sync[3]) + +#define DP_CSC_0(flow) (&DP_REG->csc_sync[0]) +#define DP_CSC_1(flow) (&DP_REG->csc_sync[1]) + +/* DC template opcodes */ +#define WROD(lf) (0x18 | (lf << 1)) + +#endif
Hello Stefano,
On Wed, 13 Oct 2010 12:16:35 +0200 Stefano Babic sbabic@denx.de wrote:
The patch is a porting of the IPU Linux driver developed by Freescale to have framebuffer functionalities in u-boot. The port is based on kernel 2.6.31 commit cc4fe714041805997b601fe8e5dd585d8a99297f, as delivered by Freescale [i.MX BSP]. Most features are dropped from the original driver and only LCD support is the goal of this porting.
Signed-off-by: Stefano Babic sbabic@denx.de
What tree is this patch based on? It doesn't apply on current u-boot.git/master:
$ git am ~/u-boot-patch-queue/[PATCH\ V2\ 2_4]\ MX51:\ Add\ IPU\ driver\ for\ video\ support Applying: MX51: Add IPU driver for video support error: arch/arm/include/asm/arch-mx51/crm_regs.h: does not exist in index Patch failed at 0001 MX51: Add IPU driver for video support When you have resolved this problem run "git am --resolved". If you would prefer to skip this patch, instead run "git am --skip". To restore the original branch and stop patching run "git am --abort".
Best regards, Anatolij
On 10/20/2010 11:45 PM, Anatolij Gustschin wrote:
Hello Stefano,
Hi Anatolij,
The patch is based on the u-boot tree at the time I sent to ML, in any case on the actual release 2e6e1772c0e34871769be4aef79748fe3e47d953 - in the meantime, several MX patches went to mainline.
The patchset does not apply because the mx51 directories are renamed to MX5, as it is expected to get more patches for other processors of the same family.
Should I rebase them and post again ?
Stefano
Hi Stefano,
On Thu, 21 Oct 2010 00:10:56 +0200 Stefano Babic sbabic@denx.de wrote: ...
I'll fix this patch and you don't need to resend it. But could you please rebase [PATCH 4/4] MX51: Add video support to vision2 board and post it again?
Thanks, Anatolij
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Changes since V1:
- added precise reference to the kernel version used for porting in the commit message
- correct multiline comments
- drop dummy true/false booleans
arch/arm/include/asm/arch-mx51/crm_regs.h | 11 + drivers/video/ipu.h | 321 +++++++ drivers/video/ipu_common.c | 1183 +++++++++++++++++++++++++ drivers/video/ipu_disp.c | 1359 +++++++++++++++++++++++++++++ drivers/video/ipu_regs.h | 418 +++++++++ 5 files changed, 3292 insertions(+), 0 deletions(-) create mode 100644 drivers/video/ipu.h create mode 100644 drivers/video/ipu_common.c create mode 100644 drivers/video/ipu_disp.c create mode 100644 drivers/video/ipu_regs.h
Applied to u-boot-video/master after fixing arch-mx51 to arch-mx5. Thanks!
Dear Stefano Babic,
In message 1286875504-9058-2-git-send-email-sbabic@denx.de you wrote:
The patch adds the linux framebuffer header file. As several drivers are ported from Linux, it is easier to reuse the same structures already present in the kernel.
include/linux/fb.h | 616 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 616 insertions(+), 0 deletions(-) create mode 100644 include/linux/fb.h
Please include an indication where exactly the code is coming from, as described in the Linux kernel's "SubmittingPatches" document:
| Special note to back-porters: It seems to be a common and useful practise | to insert an indication of the origin of a patch at the top of the commit | message (just after the subject line) to facilitate tracking. For instance, | here's what we see in 2.6-stable : | | Date: Tue May 13 19:10:30 2008 +0000 | | SCSI: libiscsi regression in 2.6.25: fix nop timer handling | | commit 4cf1043593db6a337f10e006c23c69e5fc93e722 upstream | | And here's what appears in 2.4 : | | Date: Tue May 13 22:12:27 2008 +0200 | | wireless, airo: waitbusy() won't delay | | [backport of 2.6 commit b7acbdfbd1f277c1eb23f344f899cfa4cd0bf36a] | | Whatever the format, this information provides a valuable help to people | tracking your trees, and to people trying to trouble-shoot bugs in your | tree.
So please include at least the name of the file in the Linux tree and the exact kenrel version used as a reference in the commit message.
Thanks.
[port of linux 2.6.34 commit 6a9ee8af344e3bd7dbd61e67037096cdf7f83289]
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes since V1: - added precise reference to the kernel version used for porting in the commit message
diff --git a/include/linux/fb.h b/include/linux/fb.h new file mode 100644 index 0000000..0138e61 --- /dev/null +++ b/include/linux/fb.h @@ -0,0 +1,616 @@ +#ifndef _LINUX_FB_H +#define _LINUX_FB_H + +#include <linux/types.h> + +/* Definitions of frame buffers */ + +#define FB_MAX 32 /* sufficient for now */ + +#define FB_TYPE_PACKED_PIXELS 0 /* Packed Pixels */ + +#define FB_VISUAL_MONO01 0 /* Monochr. 1=Black 0=White */ +#define FB_VISUAL_MONO10 1 /* Monochr. 1=White 0=Black */ +#define FB_VISUAL_TRUECOLOR 2 /* True color */ +#define FB_VISUAL_PSEUDOCOLOR 3 /* Pseudo color (like atari) */ +#define FB_VISUAL_DIRECTCOLOR 4 /* Direct color */ +#define FB_VISUAL_STATIC_PSEUDOCOLOR 5 /* Pseudo color readonly */ + +#define FB_ACCEL_NONE 0 /* no hardware accelerator */ + +struct fb_fix_screeninfo { + char id[16]; /* identification string eg "TT Builtin" */ + unsigned long smem_start; /* Start of frame buffer mem */ + /* (physical address) */ + __u32 smem_len; /* Length of frame buffer mem */ + __u32 type; /* see FB_TYPE_* */ + __u32 type_aux; /* Interleave for interleaved Planes */ + __u32 visual; /* see FB_VISUAL_* */ + __u16 xpanstep; /* zero if no hardware panning */ + __u16 ypanstep; /* zero if no hardware panning */ + __u16 ywrapstep; /* zero if no hardware ywrap */ + __u32 line_length; /* length of a line in bytes */ + unsigned long mmio_start; /* Start of Memory Mapped I/O */ + /* (physical address) */ + __u32 mmio_len; /* Length of Memory Mapped I/O */ + __u32 accel; /* Indicate to driver which */ + /* specific chip/card we have */ + __u16 reserved[3]; /* Reserved for future compatibility */ +}; + +/* + * Interpretation of offset for color fields: All offsets are from the right, + * inside a "pixel" value, which is exactly 'bits_per_pixel' wide (means: you + * can use the offset as right argument to <<). A pixel afterwards is a bit + * stream and is written to video memory as that unmodified. + * + * For pseudocolor: offset and length should be the same for all color + * components. Offset specifies the position of the least significant bit + * of the pallette index in a pixel value. Length indicates the number + * of available palette entries (i.e. # of entries = 1 << length). + */ +struct fb_bitfield { + __u32 offset; /* beginning of bitfield */ + __u32 length; /* length of bitfield */ + __u32 msb_right; + +}; + +#define FB_NONSTD_HAM 1 /* Hold-And-Modify (HAM) */ +#define FB_NONSTD_REV_PIX_IN_B 2 /* order of pixels in each byte is reversed */ + +#define FB_ACTIVATE_NOW 0 /* set values immediately (or vbl)*/ +#define FB_ACTIVATE_NXTOPEN 1 /* activate on next open */ +#define FB_ACTIVATE_TEST 2 /* don't set, round up impossible */ +#define FB_ACTIVATE_MASK 15 + /* values */ +#define FB_ACTIVATE_VBL 16 /* activate values on next vbl */ +#define FB_CHANGE_CMAP_VBL 32 /* change colormap on vbl */ +#define FB_ACTIVATE_ALL 64 /* change all VCs on this fb */ +#define FB_ACTIVATE_FORCE 128 /* force apply even when no change*/ +#define FB_ACTIVATE_INV_MODE 256 /* invalidate videomode */ + +#define FB_SYNC_HOR_HIGH_ACT 1 /* horizontal sync high active */ +#define FB_SYNC_VERT_HIGH_ACT 2 /* vertical sync high active */ +#define FB_SYNC_EXT 4 /* external sync */ +#define FB_SYNC_COMP_HIGH_ACT 8 /* composite sync high active */ +#define FB_SYNC_BROADCAST 16 /* broadcast video timings */ + /* vtotal = 144d/288n/576i => PAL */ + /* vtotal = 121d/242n/484i => NTSC */ +#define FB_SYNC_ON_GREEN 32 /* sync on green */ + +#define FB_VMODE_NONINTERLACED 0 /* non interlaced */ +#define FB_VMODE_INTERLACED 1 /* interlaced */ +#define FB_VMODE_DOUBLE 2 /* double scan */ +#define FB_VMODE_ODD_FLD_FIRST 4 /* interlaced: top line first */ +#define FB_VMODE_MASK 255 + +#define FB_VMODE_YWRAP 256 /* ywrap instead of panning */ +#define FB_VMODE_SMOOTH_XPAN 512 /* smooth xpan possible (internally used) */ +#define FB_VMODE_CONUPDATE 512 /* don't update x/yoffset */ + +/* + * Display rotation support + */ +#define FB_ROTATE_UR 0 +#define FB_ROTATE_CW 1 +#define FB_ROTATE_UD 2 +#define FB_ROTATE_CCW 3 + +#define PICOS2KHZ(a) (1000000000UL/(a)) +#define KHZ2PICOS(a) (1000000000UL/(a)) + +struct fb_var_screeninfo { + __u32 xres; /* visible resolution */ + __u32 yres; + __u32 xres_virtual; /* virtual resolution */ + __u32 yres_virtual; + __u32 xoffset; /* offset from virtual to visible */ + __u32 yoffset; /* resolution */ + + __u32 bits_per_pixel; /* guess what */ + __u32 grayscale; /* != 0 Graylevels instead of colors */ + + struct fb_bitfield red; /* bitfield in fb mem if true color, */ + struct fb_bitfield green; /* else only length is significant */ + struct fb_bitfield blue; + struct fb_bitfield transp; /* transparency */ + + __u32 nonstd; /* != 0 Non standard pixel format */ + + __u32 activate; /* see FB_ACTIVATE_* */ + + __u32 height; /* height of picture in mm */ + __u32 width; /* width of picture in mm */ + + __u32 accel_flags; /* (OBSOLETE) see fb_info.flags */ + + /* Timing: All values in pixclocks, except pixclock (of course) */ + __u32 pixclock; /* pixel clock in ps (pico seconds) */ + __u32 left_margin; /* time from sync to picture */ + __u32 right_margin; /* time from picture to sync */ + __u32 upper_margin; /* time from sync to picture */ + __u32 lower_margin; + __u32 hsync_len; /* length of horizontal sync */ + __u32 vsync_len; /* length of vertical sync */ + __u32 sync; /* see FB_SYNC_* */ + __u32 vmode; /* see FB_VMODE_* */ + __u32 rotate; /* angle we rotate counter clockwise */ + __u32 reserved[5]; /* Reserved for future compatibility */ +}; + +struct fb_cmap { + __u32 start; /* First entry */ + __u32 len; /* Number of entries */ + __u16 *red; /* Red values */ + __u16 *green; + __u16 *blue; + __u16 *transp; /* transparency, can be NULL */ +}; + +struct fb_con2fbmap { + __u32 console; + __u32 framebuffer; +}; + +/* VESA Blanking Levels */ +#define VESA_NO_BLANKING 0 +#define VESA_VSYNC_SUSPEND 1 +#define VESA_HSYNC_SUSPEND 2 +#define VESA_POWERDOWN 3 + + +enum { + /* screen: unblanked, hsync: on, vsync: on */ + FB_BLANK_UNBLANK = VESA_NO_BLANKING, + + /* screen: blanked, hsync: on, vsync: on */ + FB_BLANK_NORMAL = VESA_NO_BLANKING + 1, + + /* screen: blanked, hsync: on, vsync: off */ + FB_BLANK_VSYNC_SUSPEND = VESA_VSYNC_SUSPEND + 1, + + /* screen: blanked, hsync: off, vsync: on */ + FB_BLANK_HSYNC_SUSPEND = VESA_HSYNC_SUSPEND + 1, + + /* screen: blanked, hsync: off, vsync: off */ + FB_BLANK_POWERDOWN = VESA_POWERDOWN + 1 +}; + +#define FB_VBLANK_VBLANKING 0x001 /* currently in a vertical blank */ +#define FB_VBLANK_HBLANKING 0x002 /* currently in a horizontal blank */ +#define FB_VBLANK_HAVE_VBLANK 0x004 /* vertical blanks can be detected */ +#define FB_VBLANK_HAVE_HBLANK 0x008 /* horizontal blanks can be detected */ +#define FB_VBLANK_HAVE_COUNT 0x010 /* global retrace counter is available */ +#define FB_VBLANK_HAVE_VCOUNT 0x020 /* the vcount field is valid */ +#define FB_VBLANK_HAVE_HCOUNT 0x040 /* the hcount field is valid */ +#define FB_VBLANK_VSYNCING 0x080 /* currently in a vsync */ +#define FB_VBLANK_HAVE_VSYNC 0x100 /* verical syncs can be detected */ + +struct fb_vblank { + __u32 flags; /* FB_VBLANK flags */ + __u32 count; /* counter of retraces since boot */ + __u32 vcount; /* current scanline position */ + __u32 hcount; /* current scandot position */ + __u32 reserved[4]; /* reserved for future compatibility */ +}; + +/* Internal HW accel */ +#define ROP_COPY 0 +#define ROP_XOR 1 + +struct fb_copyarea { + __u32 dx; + __u32 dy; + __u32 width; + __u32 height; + __u32 sx; + __u32 sy; +}; + +struct fb_fillrect { + __u32 dx; /* screen-relative */ + __u32 dy; + __u32 width; + __u32 height; + __u32 color; + __u32 rop; +}; + +struct fb_image { + __u32 dx; /* Where to place image */ + __u32 dy; + __u32 width; /* Size of image */ + __u32 height; + __u32 fg_color; /* Only used when a mono bitmap */ + __u32 bg_color; + __u8 depth; /* Depth of the image */ + const char *data; /* Pointer to image data */ + struct fb_cmap cmap; /* color map info */ +}; + +/* + * hardware cursor control + */ + +#define FB_CUR_SETIMAGE 0x01 +#define FB_CUR_SETPOS 0x02 +#define FB_CUR_SETHOT 0x04 +#define FB_CUR_SETCMAP 0x08 +#define FB_CUR_SETSHAPE 0x10 +#define FB_CUR_SETSIZE 0x20 +#define FB_CUR_SETALL 0xFF + +struct fbcurpos { + __u16 x, y; +}; + +struct fb_cursor { + __u16 set; /* what to set */ + __u16 enable; /* cursor on/off */ + __u16 rop; /* bitop operation */ + const char *mask; /* cursor mask bits */ + struct fbcurpos hot; /* cursor hot spot */ + struct fb_image image; /* Cursor image */ +}; + +#ifdef CONFIG_FB_BACKLIGHT +/* Settings for the generic backlight code */ +#define FB_BACKLIGHT_LEVELS 128 +#define FB_BACKLIGHT_MAX 0xFF +#endif + +#ifdef __KERNEL__ + +struct vm_area_struct; +struct fb_info; +struct device; +struct file; + +/* Definitions below are used in the parsed monitor specs */ +#define FB_DPMS_ACTIVE_OFF 1 +#define FB_DPMS_SUSPEND 2 +#define FB_DPMS_STANDBY 4 + +#define FB_DISP_DDI 1 +#define FB_DISP_ANA_700_300 2 +#define FB_DISP_ANA_714_286 4 +#define FB_DISP_ANA_1000_400 8 +#define FB_DISP_ANA_700_000 16 + +#define FB_DISP_MONO 32 +#define FB_DISP_RGB 64 +#define FB_DISP_MULTI 128 +#define FB_DISP_UNKNOWN 256 + +#define FB_SIGNAL_NONE 0 +#define FB_SIGNAL_BLANK_BLANK 1 +#define FB_SIGNAL_SEPARATE 2 +#define FB_SIGNAL_COMPOSITE 4 +#define FB_SIGNAL_SYNC_ON_GREEN 8 +#define FB_SIGNAL_SERRATION_ON 16 + +#define FB_MISC_PRIM_COLOR 1 +#define FB_MISC_1ST_DETAIL 2 /* First Detailed Timing is preferred */ +struct fb_chroma { + __u32 redx; /* in fraction of 1024 */ + __u32 greenx; + __u32 bluex; + __u32 whitex; + __u32 redy; + __u32 greeny; + __u32 bluey; + __u32 whitey; +}; + +struct fb_monspecs { + struct fb_chroma chroma; + struct fb_videomode *modedb; /* mode database */ + __u8 manufacturer[4]; /* Manufacturer */ + __u8 monitor[14]; /* Monitor String */ + __u8 serial_no[14]; /* Serial Number */ + __u8 ascii[14]; /* ? */ + __u32 modedb_len; /* mode database length */ + __u32 model; /* Monitor Model */ + __u32 serial; /* Serial Number - Integer */ + __u32 year; /* Year manufactured */ + __u32 week; /* Week Manufactured */ + __u32 hfmin; /* hfreq lower limit (Hz) */ + __u32 hfmax; /* hfreq upper limit (Hz) */ + __u32 dclkmin; /* pixelclock lower limit (Hz) */ + __u32 dclkmax; /* pixelclock upper limit (Hz) */ + __u16 input; /* display type - see FB_DISP_* */ + __u16 dpms; /* DPMS support - see FB_DPMS_ */ + __u16 signal; /* Signal Type - see FB_SIGNAL_* */ + __u16 vfmin; /* vfreq lower limit (Hz) */ + __u16 vfmax; /* vfreq upper limit (Hz) */ + __u16 gamma; /* Gamma - in fractions of 100 */ + __u16 gtf : 1; /* supports GTF */ + __u16 misc; /* Misc flags - see FB_MISC_* */ + __u8 version; /* EDID version... */ + __u8 revision; /* ...and revision */ + __u8 max_x; /* Maximum horizontal size (cm) */ + __u8 max_y; /* Maximum vertical size (cm) */ +}; + +struct fb_cmap_user { + __u32 start; /* First entry */ + __u32 len; /* Number of entries */ + __u16 *red; /* Red values */ + __u16 *green; + __u16 *blue; + __u16 *transp; /* transparency, can be NULL */ +}; + +struct fb_image_user { + __u32 dx; /* Where to place image */ + __u32 dy; + __u32 width; /* Size of image */ + __u32 height; + __u32 fg_color; /* Only used when a mono bitmap */ + __u32 bg_color; + __u8 depth; /* Depth of the image */ + const char *data; /* Pointer to image data */ + struct fb_cmap_user cmap; /* color map info */ +}; + +struct fb_cursor_user { + __u16 set; /* what to set */ + __u16 enable; /* cursor on/off */ + __u16 rop; /* bitop operation */ + const char *mask; /* cursor mask bits */ + struct fbcurpos hot; /* cursor hot spot */ + struct fb_image_user image; /* Cursor image */ +}; + +/* + * Register/unregister for framebuffer events + */ + +/* The resolution of the passed in fb_info about to change */ +#define FB_EVENT_MODE_CHANGE 0x01 +/* The display on this fb_info is beeing suspended, no access to the + * framebuffer is allowed any more after that call returns + */ +#define FB_EVENT_SUSPEND 0x02 +/* The display on this fb_info was resumed, you can restore the display + * if you own it + */ +#define FB_EVENT_RESUME 0x03 +/* An entry from the modelist was removed */ +#define FB_EVENT_MODE_DELETE 0x04 +/* A driver registered itself */ +#define FB_EVENT_FB_REGISTERED 0x05 +/* A driver unregistered itself */ +#define FB_EVENT_FB_UNREGISTERED 0x06 +/* CONSOLE-SPECIFIC: get console to framebuffer mapping */ +#define FB_EVENT_GET_CONSOLE_MAP 0x07 +/* CONSOLE-SPECIFIC: set console to framebuffer mapping */ +#define FB_EVENT_SET_CONSOLE_MAP 0x08 +/* A hardware display blank change occured */ +#define FB_EVENT_BLANK 0x09 +/* Private modelist is to be replaced */ +#define FB_EVENT_NEW_MODELIST 0x0A +/* The resolution of the passed in fb_info about to change and + all vc's should be changed */ +#define FB_EVENT_MODE_CHANGE_ALL 0x0B +/* A software display blank change occured */ +#define FB_EVENT_CONBLANK 0x0C +/* Get drawing requirements */ +#define FB_EVENT_GET_REQ 0x0D +/* Unbind from the console if possible */ +#define FB_EVENT_FB_UNBIND 0x0E + +struct fb_event { + struct fb_info *info; + void *data; +}; + +struct fb_blit_caps { + u32 x; + u32 y; + u32 len; + u32 flags; +}; + +/* + * Pixmap structure definition + * + * The purpose of this structure is to translate data + * from the hardware independent format of fbdev to what + * format the hardware needs. + */ + +#define FB_PIXMAP_DEFAULT 1 /* used internally by fbcon */ +#define FB_PIXMAP_SYSTEM 2 /* memory is in system RAM */ +#define FB_PIXMAP_IO 4 /* memory is iomapped */ +#define FB_PIXMAP_SYNC 256 /* set if GPU can DMA */ + +struct fb_pixmap { + u8 *addr; /* pointer to memory */ + u32 size; /* size of buffer in bytes */ + u32 offset; /* current offset to buffer */ + u32 buf_align; /* byte alignment of each bitmap */ + u32 scan_align; /* alignment per scanline */ + u32 access_align; /* alignment per read/write (bits) */ + u32 flags; /* see FB_PIXMAP_* */ + u32 blit_x; /* supported bit block dimensions (1-32)*/ + u32 blit_y; /* Format: blit_x = 1 << (width - 1) */ + /* blit_y = 1 << (height - 1) */ + /* if 0, will be set to 0xffffffff (all)*/ + /* access methods */ + void (*writeio)(struct fb_info *info, void *dst, void *src, unsigned int size); + void (*readio) (struct fb_info *info, void *dst, void *src, unsigned int size); +}; + +#ifdef CONFIG_FB_DEFERRED_IO +struct fb_deferred_io { + /* delay between mkwrite and deferred handler */ + unsigned long delay; + struct mutex lock; /* mutex that protects the page list */ + struct list_head pagelist; /* list of touched pages */ + /* callback */ + void (*deferred_io)(struct fb_info *info, struct list_head *pagelist); +}; +#endif + +/* FBINFO_* = fb_info.flags bit flags */ +#define FBINFO_MODULE 0x0001 /* Low-level driver is a module */ +#define FBINFO_HWACCEL_DISABLED 0x0002 + /* When FBINFO_HWACCEL_DISABLED is set: + * Hardware acceleration is turned off. Software implementations + * of required functions (copyarea(), fillrect(), and imageblit()) + * takes over; acceleration engine should be in a quiescent state */ + +/* hints */ +#define FBINFO_PARTIAL_PAN_OK 0x0040 /* otw use pan only for double-buffering */ +#define FBINFO_READS_FAST 0x0080 /* soft-copy faster than rendering */ + +/* + * A driver may set this flag to indicate that it does want a set_par to be + * called every time when fbcon_switch is executed. The advantage is that with + * this flag set you can really be sure that set_par is always called before + * any of the functions dependant on the correct hardware state or altering + * that state, even if you are using some broken X releases. The disadvantage + * is that it introduces unwanted delays to every console switch if set_par + * is slow. It is a good idea to try this flag in the drivers initialization + * code whenever there is a bug report related to switching between X and the + * framebuffer console. + */ +#define FBINFO_MISC_ALWAYS_SETPAR 0x40000 + +/* + * Host and GPU endianness differ. + */ +#define FBINFO_FOREIGN_ENDIAN 0x100000 +/* + * Big endian math. This is the same flags as above, but with different + * meaning, it is set by the fb subsystem depending FOREIGN_ENDIAN flag + * and host endianness. Drivers should not use this flag. + */ +#define FBINFO_BE_MATH 0x100000 + +struct fb_info { + int node; + int flags; + struct fb_var_screeninfo var; /* Current var */ + struct fb_fix_screeninfo fix; /* Current fix */ + struct fb_monspecs monspecs; /* Current Monitor specs */ + struct fb_pixmap pixmap; /* Image hardware mapper */ + struct fb_pixmap sprite; /* Cursor hardware mapper */ + struct fb_cmap cmap; /* Current cmap */ + struct list_head modelist; /* mode list */ + struct fb_videomode *mode; /* current mode */ + + char *screen_base; /* Virtual address */ + unsigned long screen_size; /* Amount of ioremapped VRAM or 0 */ + void *pseudo_palette; /* Fake palette of 16 colors */ +#define FBINFO_STATE_RUNNING 0 +#define FBINFO_STATE_SUSPENDED 1 + u32 state; /* Hardware state i.e suspend */ + void *fbcon_par; /* fbcon use-only private area */ + /* From here on everything is device dependent */ + void *par; +}; + +#define FBINFO_DEFAULT 0 + +#define FBINFO_FLAG_MODULE FBINFO_MODULE +#define FBINFO_FLAG_DEFAULT FBINFO_DEFAULT + +// This will go away +#if defined(__sparc__) + +/* We map all of our framebuffers such that big-endian accesses + * are what we want, so the following is sufficient. + */ + +// This will go away +#define fb_readb sbus_readb +#define fb_readw sbus_readw +#define fb_readl sbus_readl +#define fb_readq sbus_readq +#define fb_writeb sbus_writeb +#define fb_writew sbus_writew +#define fb_writel sbus_writel +#define fb_writeq sbus_writeq +#define fb_memset sbus_memset_io + +#elif defined(__i386__) || defined(__alpha__) || defined(__x86_64__) || defined(__hppa__) || defined(__sh__) || defined(__powerpc__) || defined(__avr32__) || defined(__bfin__) + +#define fb_readb __raw_readb +#define fb_readw __raw_readw +#define fb_readl __raw_readl +#define fb_readq __raw_readq +#define fb_writeb __raw_writeb +#define fb_writew __raw_writew +#define fb_writel __raw_writel +#define fb_writeq __raw_writeq +#define fb_memset memset_io + +#else + +#define fb_readb(addr) (*(volatile u8 *) (addr)) +#define fb_readw(addr) (*(volatile u16 *) (addr)) +#define fb_readl(addr) (*(volatile u32 *) (addr)) +#define fb_readq(addr) (*(volatile u64 *) (addr)) +#define fb_writeb(b,addr) (*(volatile u8 *) (addr) = (b)) +#define fb_writew(b,addr) (*(volatile u16 *) (addr) = (b)) +#define fb_writel(b,addr) (*(volatile u32 *) (addr) = (b)) +#define fb_writeq(b,addr) (*(volatile u64 *) (addr) = (b)) +#define fb_memset memset + +#endif + +#define FB_LEFT_POS(p, bpp) (fb_be_math(p) ? (32 - (bpp)) : 0) +#define FB_SHIFT_HIGH(p, val, bits) (fb_be_math(p) ? (val) >> (bits) : \ + (val) << (bits)) +#define FB_SHIFT_LOW(p, val, bits) (fb_be_math(p) ? (val) << (bits) : \ + (val) >> (bits)) +/* drivers/video/fbmon.c */ +#define FB_MAXTIMINGS 0 +#define FB_VSYNCTIMINGS 1 +#define FB_HSYNCTIMINGS 2 +#define FB_DCLKTIMINGS 3 +#define FB_IGNOREMON 0x100 + +#define FB_MODE_IS_UNKNOWN 0 +#define FB_MODE_IS_DETAILED 1 +#define FB_MODE_IS_STANDARD 2 +#define FB_MODE_IS_VESA 4 +#define FB_MODE_IS_CALCULATED 8 +#define FB_MODE_IS_FIRST 16 +#define FB_MODE_IS_FROM_VAR 32 + + +/* drivers/video/fbcmap.c */ + +extern int fb_alloc_cmap(struct fb_cmap *cmap, int len, int transp); +extern void fb_dealloc_cmap(struct fb_cmap *cmap); +extern int fb_copy_cmap(const struct fb_cmap *from, struct fb_cmap *to); +extern int fb_cmap_to_user(const struct fb_cmap *from, struct fb_cmap_user *to); +extern int fb_set_cmap(struct fb_cmap *cmap, struct fb_info *fb_info); +extern int fb_set_user_cmap(struct fb_cmap_user *cmap, struct fb_info *fb_info); +extern const struct fb_cmap *fb_default_cmap(int len); +extern void fb_invert_cmaps(void); + +struct fb_videomode { + const char *name; /* optional */ + u32 refresh; /* optional */ + u32 xres; + u32 yres; + u32 pixclock; + u32 left_margin; + u32 right_margin; + u32 upper_margin; + u32 lower_margin; + u32 hsync_len; + u32 vsync_len; + u32 sync; + u32 vmode; + u32 flag; +}; + +#endif /* __KERNEL__ */ + +#endif /* _LINUX_FB_H */
Changes since V1:
Applied to u-boot-video/master. Fixed some trailing whitespace errors while applying. Thanks!
Why are we adding this header file?
Changes since V1:
Hi Timur,
the main reason is to simplify the porting of Linux framebuffer's drivers and to not reinvent new structures to set up the LCD parameters, as well as avoiding to hard-coding their values as some drivers currently do (I can point to the mx3fb.c driver for MX31).
IMHO using the fb.h makes a reference to a documented (in linux) header file, that it is easier to understand for someone adding a new custom board.
I have checked now and I see that some other drivers are requiring these kind of stuctures: the fsl_diu.c for mpc512x has a custom header file ("board/freescale/common/fsl_diu_fb.h"), where a couple of these structures are defined from Linux and that are part of fb.h. Really there is nothing in this header that is suitable only for Freescale's board, but it points to the fact that a general header is required.
Then, as it is supposed other drivers can have the same requirements, why do not take the header directly from Linux instead of redefining the same structures again ?
Stefano
So would you expect fsl_diu.c to be modified to use the new header files?
Dear Timur Tabi,
Yes, please.
The patch adds support for LCD to the vision board.
Signed-off-by: Stefano Babic sbabic@denx.de --- board/ttcontrol/vision2/vision2.c | 69 +++++++++++++++++++++++++++++++++++++ include/configs/vision2.h | 14 +++++++ 2 files changed, 83 insertions(+), 0 deletions(-)
diff --git a/board/ttcontrol/vision2/vision2.c b/board/ttcontrol/vision2/vision2.c index ce4cb78..5193b56 100644 --- a/board/ttcontrol/vision2/vision2.c +++ b/board/ttcontrol/vision2/vision2.c @@ -37,14 +37,34 @@ #include <fsl_esdhc.h> #include <fsl_pmic.h> #include <mc13892.h> +#include <linux/fb.h>
DECLARE_GLOBAL_DATA_PTR;
static u32 system_rev;
+extern int mx51_fb_init(struct fb_videomode *mode); + #ifdef CONFIG_HW_WATCHDOG #include <watchdog.h>
+static struct fb_videomode nec_nl6448bc26_09c = { + "NEC_NL6448BC26-09C", + 60, /* Refresh */ + 640, /* xres */ + 480, /* yres */ + 37650, /* pixclock = 26.56Mhz */ + 48, /* left margin */ + 16, /* right margin */ + 31, /* upper margin */ + 12, /* lower margin */ + 96, /* hsync-len */ + 2, /* vsync-len */ + 0, /* sync */ + FB_VMODE_NONINTERLACED, /* vmode */ + 0, /* flag */ +}; + void hw_watchdog_reset(void) { int val; @@ -423,6 +443,9 @@ static void setup_gpios(void) mxc_request_iomux(MX51_PIN_CSPI1_RDY, IOMUX_CONFIG_ALT3); mxc_iomux_set_pad(MX51_PIN_CSPI1_RDY, 0x82);
+ /* PWM Output GPIO1_2 */ + mxc_request_iomux(MX51_PIN_GPIO1_2, IOMUX_CONFIG_ALT1); + /* * Set GPIO1_4 to high and output; it is used to reset * the system on reboot @@ -630,6 +653,34 @@ int board_early_init_f(void) return 0; }
+static void backlight(int on) +{ + if (on) { + mxc_gpio_set(65, 1); + udelay(10000); + mxc_gpio_set(68, 1); + } else { + mxc_gpio_set(65, 0); + mxc_gpio_set(68, 0); + } +} + +void lcd_enable(void) +{ + int ret; + + mxc_request_iomux(MX51_PIN_DI1_PIN2, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_DI1_PIN3, IOMUX_CONFIG_ALT0); + + mxc_gpio_set(2, 1); + mxc_request_iomux(MX51_PIN_GPIO1_2, IOMUX_CONFIG_ALT0); + + ret = mx51_fb_init(&nec_nl6448bc26_09c); + if (ret) { + puts("LCD cannot be configured\n"); + } +} + int board_init(void) { #ifdef CONFIG_SYS_ARM_WITHOUT_RELOC @@ -709,3 +760,21 @@ int checkboard(void) return 0; }
+int do_vision_lcd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int on; + + if (argc < 2) + return cmd_usage(cmdtp); + + on = (strcmp(argv[1], "on") == 0); + backlight(on); + + return 0; +} + +U_BOOT_CMD( + lcdbl, CONFIG_SYS_MAXARGS, 1, do_vision_lcd, + "Vision2 Backlight", + "lcdbl [on|off]\n" +); diff --git a/include/configs/vision2.h b/include/configs/vision2.h index a2ecbe5..4162807 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -211,4 +211,18 @@
#define CONFIG_SYS_NO_FLASH
+/* + * Framebuffer and LCD + */ +#define CONFIG_PREBOOT +#define CONFIG_LCD +#define CONFIG_VIDEO_MX5 +#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define LCD_BPP LCD_COLOR16 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_CMD_BMP +#define CONFIG_BMP_16BPP + #endif /* __CONFIG_H */
Hi Stefano,
Applied to u-boot-video/master after some style fixes. Thanks for rebasing!
participants (5)
Anatolij Gustschin
Stefano Babic
stefano babic
Timur Tabi
