[U-Boot] [PATCH 1/5] powerpc/85xx: fix definition of MAS register macros
Some of the MAS register macros do not protect the parameter with parentheses, which could cause wrong values if the parameter includes operators.
Also fix the definition of TSIZE_TO_BYTES() so that it actually uses the parameter. This hasn't caused any problems to date because the parameter was always been 'tsize'.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/include/asm/mmu.h | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/include/asm/mmu.h b/arch/powerpc/include/asm/mmu.h index ef5076b..209103e 100644 --- a/arch/powerpc/include/asm/mmu.h +++ b/arch/powerpc/include/asm/mmu.h @@ -392,17 +392,17 @@ extern void print_bats(void); */
#define MAS0_TLBSEL_MSK 0x30000000 -#define MAS0_TLBSEL(x) ((x << 28) & MAS0_TLBSEL_MSK) +#define MAS0_TLBSEL(x) (((x) << 28) & MAS0_TLBSEL_MSK) #define MAS0_ESEL_MSK 0x0FFF0000 -#define MAS0_ESEL(x) ((x << 16) & MAS0_ESEL_MSK) +#define MAS0_ESEL(x) (((x) << 16) & MAS0_ESEL_MSK) #define MAS0_NV(x) ((x) & 0x00000FFF)
#define MAS1_VALID 0x80000000 #define MAS1_IPROT 0x40000000 -#define MAS1_TID(x) ((x << 16) & 0x3FFF0000) +#define MAS1_TID(x) (((x) << 16) & 0x3FFF0000) #define MAS1_TS 0x00001000 -#define MAS1_TSIZE(x) ((x << 8) & 0x00000F00) -#define TSIZE_TO_BYTES(x) ((phys_addr_t)(1UL << ((tsize * 2) + 10))) +#define MAS1_TSIZE(x) (((x) << 8) & 0x00000F00) +#define TSIZE_TO_BYTES(x) (1ULL << (((x) * 2) + 10))
#define MAS2_EPN 0xFFFFF000 #define MAS2_X0 0x00000040
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 528abc9..b5bf1fa 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -398,7 +398,7 @@ create_ccsr_new_tlb: tlbwe
/* - * Create a TLB for the old location of CCSR. Register R9 is reserved + * Create a TLB for the current location of CCSR. Register R9 is reserved * for the virtual address of this TLB (CONFIG_SYS_CCSRBAR + 0x1000). */ create_ccsr_old_tlb: @@ -457,7 +457,7 @@ create_temp_law: */ read_old_ccsrbar: lwz r0, 0(r9) /* CCSRBARH */ - lwz r0, 4(r9) /* CCSRBARH */ + lwz r0, 4(r9) /* CCSRBARL */ isync
applied to 85xx
- k
Calls to tlbwe and tlbsx should be preceded with an isync/msync pair.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index b5bf1fa..ccb331a 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -363,6 +363,8 @@ purge_old_ccsr_tlb:
li r1, 0 mtspr MAS6, r1 /* Search the current address space and PID */ + isync + msync tlbsx 0, r8 mfspr r1, MAS1 andis. r2, r1, MAS1_VALID@h /* Check for the Valid bit */ @@ -370,6 +372,8 @@ purge_old_ccsr_tlb:
rlwinm r1, r1, 0, 1, 31 /* Clear Valid bit */ mtspr MAS1, r1 + isync + msync tlbwe 1:
applied to 85xx
- k
Verify that CCSR is actually located where it is supposed to be before we relocate it. This is useful in detecting U-Boot configurations that are broken (e.g. an incorrect value for CONFIG_SYS_CCSRBAR_DEFAULT). If the current value is wrong, we enter an infinite loop, which is handy for debuggers.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 27 +++++++++++++++++++++++++++ 1 files changed, 27 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index ccb331a..6de8765 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -422,6 +422,33 @@ create_ccsr_old_tlb: msync tlbwe
+ /* + * We have a TLB for what we think is the current (old) CCSR. Let's + * verify that, otherwise we won't be able to move it. + * CONFIG_SYS_CCSRBAR_DEFAULT is always a 32-bit number, so we only + * need to compare the lower 32 bits of CCSRBAR on CoreNet systems. + */ +verify_old_ccsr: + lis r0, CONFIG_SYS_CCSRBAR_DEFAULT@h + ori r0, r0, CONFIG_SYS_CCSRBAR_DEFAULT@l +#ifdef CONFIG_FSL_CORENET + lwz r1, 4(r9) /* CCSRBARL */ +#else + lwz r1, 0(r9) /* CCSRBAR, shifted right by 12 */ + slwi r1, r1, 12 +#endif + + cmpl 0, r0, r1 + + /* + * If the value we read from CCSRBARL is not what we expect, then + * enter an infinite loop. This will at least allow a debugger to + * halt execution and examine TLBs, etc. There's no point in going + * on. + */ +infinite_debug_loop: + bne infinite_debug_loop + #ifdef CONFIG_FSL_CORENET
#define CCSR_LAWBARH0 (CONFIG_SYS_CCSRBAR + 0x1000)
applied to 85xx
- k
On some Freescale systems (e.g. those booted from the on-chip ROM), the TLB that covers the boot page can also cover CCSR, which breaks the CCSR relocation code. To fix this, we resize the boot page TLB so that it only covers the 4KB boot page.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 49 ++++++++++++++++++++++++++++++++++++++ 1 files changed, 49 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 6de8765..39f1438 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -330,6 +330,55 @@ l2_disabled: #endif /* CONFIG_MPC8569 */
/* + * Search for the TLB that covers the code we're executing, and shrink it + * so that it covers only this 4K page. That will ensure that any other + * TLB we create won't interfere with it. We assume that the TLB exists, + * which is why we don't check the Valid bit of MAS1. + * + * This is necessary, for example, when booting from the on-chip ROM, + * which (oddly) creates a single 4GB TLB that covers CCSR and DDR. + * If we don't shrink this TLB now, then we'll accidentally delete it + * in "purge_old_ccsr_tlb" below. + */ + bl nexti /* Find our address */ +nexti: mflr r1 /* R1 = our PC */ + li r2, 0 + mtspr MAS6, r2 /* Assume the current PID and AS are 0 */ + isync + msync + tlbsx 0, r1 /* This must succeed */ + + /* Set the size of the TLB to 4KB */ + mfspr r3, MAS1 + li r2, 0xF00 + andc r3, r3, r2 /* Clear the TSIZE bits */ + ori r3, r3, MAS1_TSIZE(BOOKE_PAGESZ_4K)@l + mtspr MAS1, r3 + + /* + * Set the base address of the TLB to our PC. We assume that + * virtual == physical. We also assume that MAS2_EPN == MAS3_RPN. + */ + lis r3, MAS2_EPN@h + ori r3, r3, MAS2_EPN@l /* R3 = MAS2_EPN */ + + and r1, r1, r3 /* Our PC, rounded down to the nearest page */ + + mfspr r2, MAS2 + andc r2, r2, r3 + or r2, r2, r1 + mtspr MAS2, r2 /* Set the EPN to our PC base address */ + + mfspr r2, MAS3 + andc r2, r2, r3 + or r2, r2, r1 + mtspr MAS3, r2 /* Set the RPN to our PC base address */ + + isync + msync + tlbwe + +/* * Relocate CCSR, if necessary. We relocate CCSR if (obviously) the default * location is not where we want it. This typically happens on a 36-bit * system, where we want to move CCSR to near the top of 36-bit address space.
applied to 85xx
- k
applied to 85xx
- k
Kumar Gala
Timur Tabi
