[U-Boot] 82xx serial, smc: Coding-Style cleanup serial SMC driver
Signed-off-by: Heiko Schocher hs@denx.de --- cpu/mpc8260/serial_smc.c | 54 +++++++++++++++------------------------------ 1 files changed, 18 insertions(+), 36 deletions(-)
diff --git a/cpu/mpc8260/serial_smc.c b/cpu/mpc8260/serial_smc.c index 794d6b3..fbb3fb0 100644 --- a/cpu/mpc8260/serial_smc.c +++ b/cpu/mpc8260/serial_smc.c @@ -106,8 +106,7 @@ int serial_init (void) *(ushort *)(&im->im_dprambase[PROFF_SMC_BASE]) = PROFF_SMC; up = (smc_uart_t *)&im->im_dprambase[PROFF_SMC];
- /* Disable transmitter/receiver. - */ + /* Disable transmitter/receiver. */ sp->smc_smcmr &= ~(SMCMR_REN | SMCMR_TEN);
/* NOTE: I/O port pins are set up via the iop_conf_tab[] table */ @@ -132,8 +131,7 @@ int serial_init (void) rtx->txbd.cbd_bufaddr = (uint) &rtx->txbuf; rtx->txbd.cbd_sc = 0;
- /* Set up the uart parameters in the parameter ram. - */ + /* Set up the uart parameters in the parameter ram. */ up->smc_rbase = dpaddr; up->smc_tbase = dpaddr+sizeof(cbd_t); up->smc_rfcr = CPMFCR_EB; @@ -147,8 +145,7 @@ int serial_init (void) */ sp->smc_smcmr = smcr_mk_clen(9) | SMCMR_SM_UART;
- /* Mask all interrupts and remove anything pending. - */ + /* Mask all interrupts and remove anything pending. */ sp->smc_smcm = 0; sp->smc_smce = 0xff;
@@ -157,12 +154,10 @@ int serial_init (void) */ im->im_cpmux.cmx_smr = (im->im_cpmux.cmx_smr&~CMXSMR_MASK)|CMXSMR_VALUE;
- /* Set up the baud rate generator. - */ + /* Set up the baud rate generator. */ serial_setbrg ();
- /* Make the first buffer the only buffer. - */ + /* Make the first buffer the only buffer. */ rtx->txbd.cbd_sc |= BD_SC_WRAP; rtx->rxbd.cbd_sc |= BD_SC_EMPTY | BD_SC_WRAP;
@@ -171,8 +166,7 @@ int serial_init (void) up->smc_maxidl = CONFIG_SYS_MAXIDLE; rtx->rxindex = 0;
- /* Initialize Tx/Rx parameters. - */ + /* Initialize Tx/Rx parameters. */
while (cp->cp_cpcr & CPM_CR_FLG) /* wait if cp is busy */ ; @@ -183,8 +177,7 @@ int serial_init (void) while (cp->cp_cpcr & CPM_CR_FLG) /* wait if cp is busy */ ;
- /* Enable transmitter/receiver. - */ + /* Enable transmitter/receiver. */ sp->smc_smcmr |= SMCMR_REN | SMCMR_TEN;
return (0); @@ -243,8 +236,7 @@ serial_getc(void)
rtx = (serialbuffer_t *)&im->im_dprambase[up->smc_rbase];
- /* Wait for character to show up. - */ + /* Wait for character to show up. */ while (rtx->rxbd.cbd_sc & BD_SC_EMPTY) ;
@@ -332,8 +324,7 @@ kgdb_serial_init (void) *(ushort *)(&im->im_dprambase[KGDB_PROFF_SMC_BASE]) = KGDB_PROFF_SMC; up = (smc_uart_t *)&im->im_dprambase[KGDB_PROFF_SMC];
/* NOTE: I/O port pins are set up via the iop_conf_tab[] table */ @@ -354,8 +345,7 @@ kgdb_serial_init (void) tbdf->cbd_bufaddr = ((uint) (rbdf+2)) + 1; tbdf->cbd_sc = 0;
- /* Set up the uart parameters in the parameter ram. - */ + /* Set up the uart parameters in the parameter ram. */ up->smc_rbase = dpaddr; up->smc_tbase = dpaddr+sizeof(cbd_t); up->smc_rfcr = CPMFCR_EB; @@ -369,8 +359,7 @@ kgdb_serial_init (void) */ sp->smc_smcmr = smcr_mk_clen(9) | SMCMR_SM_UART;
@@ -380,8 +369,7 @@ kgdb_serial_init (void) im->im_cpmux.cmx_smr = (im->im_cpmux.cmx_smr & ~KGDB_CMXSMR_MASK) | KGDB_CMXSMR_VALUE;
- /* Set up the baud rate generator. - */ + /* Set up the baud rate generator. */ #if defined(CONFIG_KGDB_USE_EXTC) m8260_cpm_extcbrg(brg_map[KGDB_SMC_INDEX], speed, CONFIG_KGDB_EXTC_RATE, CONFIG_KGDB_EXTC_PINSEL); @@ -389,18 +377,15 @@ kgdb_serial_init (void) m8260_cpm_setbrg(brg_map[KGDB_SMC_INDEX], speed); #endif
- /* Make the first buffer the only buffer. - */ + /* Make the first buffer the only buffer. */ tbdf->cbd_sc |= BD_SC_WRAP; rbdf->cbd_sc |= BD_SC_EMPTY | BD_SC_WRAP;
- /* Single character receive. - */ + /* Single character receive. */ up->smc_mrblr = 1; up->smc_maxidl = 0;
while (cp->cp_cpcr & CPM_CR_FLG) /* wait if cp is busy */ ; @@ -411,8 +396,7 @@ kgdb_serial_init (void) while (cp->cp_cpcr & CPM_CR_FLG) /* wait if cp is busy */ ;
printf("SMC%d at %dbps ", CONFIG_KGDB_INDEX, speed); @@ -433,8 +417,7 @@ putDebugChar(const char c)
tbdf = (cbd_t *)&im->im_dprambase[up->smc_tbase];
- /* Wait for last character to go. - */ + /* Wait for last character to go. */ buf = (char *)tbdf->cbd_bufaddr; while (tbdf->cbd_sc & BD_SC_READY) ; @@ -465,8 +448,7 @@ getDebugChar(void)
rbdf = (cbd_t *)&im->im_dprambase[up->smc_rbase];
- /* Wait for character to show up. - */ + /* Wait for character to show up. */ buf = (unsigned char *)rbdf->cbd_bufaddr; while (rbdf->cbd_sc & BD_SC_EMPTY) ;
Dear Heiko Schocher,
Applied, thanks.
Heiko Schocher
