[PATCH] efi_loader: build warning in efi_tcg2.c
Building 32bit boards with the TCG2 protocol enabled leads to a build warning due to a missing conversion.
lib/efi_loader/efi_tcg2.c: In function 'tcg2_measure_pe_image': lib/efi_loader/efi_tcg2.c:856:47: error: cast from pointer to integer of different size [-Werror=pointer-to-int-cast] 856 | image_load_event->image_location_in_memory = (efi_physical_addr_t)efi; | ^ lib/efi_loader/efi_tcg2.c: In function 'efi_tcg2_hash_log_extend_event': lib/efi_loader/efi_tcg2.c:947:22: error: cast to pointer from integer of different size [-Werror=int-to-pointer-cast] 947 | ret = efi_check_pe((void *)data_to_hash, data_to_hash_len, | ^ lib/efi_loader/efi_tcg2.c:953:28: error: cast to pointer from integer of different size [-Werror=int-to-pointer-cast] 953 | ret = tcg2_hash_pe_image((void *)data_to_hash, data_to_hash_len, | ^
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- lib/efi_loader/efi_tcg2.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 3dd417aa27..47bc371477 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -853,7 +853,7 @@ efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, if (!image_load_event) return EFI_OUT_OF_RESOURCES;
- image_load_event->image_location_in_memory = (efi_physical_addr_t)efi; + image_load_event->image_location_in_memory = (uintptr_t)efi; image_load_event->image_length_in_memory = efi_size; image_load_event->length_of_device_path = device_path_length;
@@ -944,14 +944,14 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, if (flags & PE_COFF_IMAGE) { IMAGE_NT_HEADERS32 *nt;
- ret = efi_check_pe((void *)data_to_hash, data_to_hash_len, - (void **)&nt); + ret = efi_check_pe((void *)(uintptr_t)data_to_hash, + data_to_hash_len, (void **)&nt); if (ret != EFI_SUCCESS) { log_err("Not a valid PE-COFF file\n"); goto out; } - ret = tcg2_hash_pe_image((void *)data_to_hash, data_to_hash_len, - &digest_list); + ret = tcg2_hash_pe_image((void *)(uintptr_t)data_to_hash, + data_to_hash_len, &digest_list); } else { ret = tcg2_create_digest((u8 *)(uintptr_t)data_to_hash, data_to_hash_len, &digest_list);
I will squash the changes into your previous patch. Cf.
https://source.denx.de/u-boot/custodians/u-boot-efi/-/commit/fd22139cee34750...
Best regards
Heinrich
- image_load_event->image_location_in_memory = (uintptr_t)efi; image_load_event->image_length_in_memory = efi_size; image_load_event->length_of_device_path = device_path_length;
(void **)&nt);
if (ret != EFI_SUCCESS) { log_err("Not a valid PE-COFF file\n"); goto out; }data_to_hash_len, (void **)&nt);
&digest_list);
} else { ret = tcg2_create_digest((u8 *)(uintptr_t)data_to_hash, data_to_hash_len, &digest_list);data_to_hash_len, &digest_list);
Masahisa Kojima
