[PATCHv2 0/4] FWU: Handle meta-data in common code
The patchset reduces ~400 lines of code, while keeping the functionality same and making meta-data operations much faster (by using cached structures).
Issue: meta-data copies (primary and secondary) are being handled by the backend/storage layer instead of the common core in fwu.c (as also noted by Ilias) that is, gpt_blk.c manages meta-data and similarly raw_mtd.c will have to do the same when it arrives. The code could by make smaller, cleaner and optimised.
Basic idea: Introduce .read_mdata() and .write_mdata() in fwu_mdata_ops that simply read/write meta-data copy. The core code takes care of integrity and redundancy of the meta-data, as a result we can get rid of every other callback .get_mdata() .update_mdata() .get_mdata_part_num() .read_mdata_partition() .write_mdata_partition() and the corresponding wrapper functions thereby making the code 100s of LOC smaller.
Get rid of fwu_check_mdata_validity() and fwu_mdata_check() which expected underlying layer to manage and verify mdata copies. Implement fwu_get_verified_mdata(struct fwu_mdata *mdata) public function that reads, verifies and, if needed, fixes the meta-data copies.
Verified copy of meta-data is now cached as 'g_mdata' in fwu.c, which avoids multiple low-level expensive read and parse calls. gpt meta-data partition numbers are now cached in gpt_blk.c, so that we don't have to do expensive part_get_info() and uid ops.
Changes since v1: * Fix typos and misc cosmetic changes * Catch error returns
Jassi Brar (4): fwu: gpt: use cached meta-data partition numbers fwu: move meta-data management in core fwu: gpt: implement read_mdata and write_mdata callbacks fwu: meta-data: switch to management by common code
cmd/fwu_mdata.c | 17 +- drivers/fwu-mdata/fwu-mdata-uclass.c | 151 +------------- drivers/fwu-mdata/gpt_blk.c | 175 +++++----------- include/fwu.h | 198 ++---------------- lib/fwu_updates/fwu.c | 300 ++++++++++++--------------- 5 files changed, 214 insertions(+), 627 deletions(-)
Use cached values and avoid parsing and scanning through partitions everytime for meta-data partitions because they can't change after bootup.
Acked-by: Etienne Carriere etienne.carriere@linaro.org Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- drivers/fwu-mdata/gpt_blk.c | 43 +++++++++++++++++++++---------------- 1 file changed, 24 insertions(+), 19 deletions(-)
diff --git a/drivers/fwu-mdata/gpt_blk.c b/drivers/fwu-mdata/gpt_blk.c index d35ce49c5c..28f5d23e1e 100644 --- a/drivers/fwu-mdata/gpt_blk.c +++ b/drivers/fwu-mdata/gpt_blk.c @@ -24,8 +24,9 @@ enum { MDATA_WRITE, };
-static int gpt_get_mdata_partitions(struct blk_desc *desc, - uint mdata_parts[2]) +static uint g_mdata_part[2]; /* = {0, 0} to check against uninit parts */ + +static int gpt_get_mdata_partitions(struct blk_desc *desc) { int i, ret; u32 nparts; @@ -33,18 +34,19 @@ static int gpt_get_mdata_partitions(struct blk_desc *desc, struct disk_partition info; const efi_guid_t fwu_mdata_guid = FWU_MDATA_GUID;
+ /* if primary and secondary partitions already found */ + if (g_mdata_part[0] && g_mdata_part[1]) + return 0; + nparts = 0; - for (i = 1; i < MAX_SEARCH_PARTITIONS; i++) { + for (i = 1; i < MAX_SEARCH_PARTITIONS && nparts < 2; i++) { if (part_get_info(desc, i, &info)) continue; uuid_str_to_bin(info.type_guid, part_type_guid.b, UUID_STR_FORMAT_GUID);
- if (!guidcmp(&fwu_mdata_guid, &part_type_guid)) { - if (nparts < 2) - mdata_parts[nparts] = i; - ++nparts; - } + if (!guidcmp(&fwu_mdata_guid, &part_type_guid)) + g_mdata_part[nparts++] = i; }
if (nparts != 2) { @@ -127,26 +129,25 @@ static int fwu_gpt_update_mdata(struct udevice *dev, struct fwu_mdata *mdata) { int ret; struct blk_desc *desc; - uint mdata_parts[2]; struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev);
desc = dev_get_uclass_plat(priv->blk_dev);
- ret = gpt_get_mdata_partitions(desc, mdata_parts); + ret = gpt_get_mdata_partitions(desc); if (ret < 0) { log_debug("Error getting the FWU metadata partitions\n"); return -ENOENT; }
/* First write the primary partition */ - ret = gpt_read_write_mdata(desc, mdata, MDATA_WRITE, mdata_parts[0]); + ret = gpt_read_write_mdata(desc, mdata, MDATA_WRITE, g_mdata_part[0]); if (ret < 0) { log_debug("Updating primary FWU metadata partition failed\n"); return ret; }
/* And now the replica */ - ret = gpt_read_write_mdata(desc, mdata, MDATA_WRITE, mdata_parts[1]); + ret = gpt_read_write_mdata(desc, mdata, MDATA_WRITE, g_mdata_part[1]); if (ret < 0) { log_debug("Updating secondary FWU metadata partition failed\n"); return ret; @@ -158,16 +159,14 @@ static int fwu_gpt_update_mdata(struct udevice *dev, struct fwu_mdata *mdata) static int gpt_get_mdata(struct blk_desc *desc, struct fwu_mdata *mdata) { int ret; - uint mdata_parts[2]; - - ret = gpt_get_mdata_partitions(desc, mdata_parts);
- ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, mdata_parts[0]); + ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, g_mdata_part[0]); if (ret < 0) { log_debug("Failed to read the FWU metadata from the device\n"); return -EIO; @@ -182,7 +181,7 @@ static int gpt_get_mdata(struct blk_desc *desc, struct fwu_mdata *mdata) * Try to read the replica. */ memset(mdata, '\0', sizeof(struct fwu_mdata)); - ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, mdata_parts[1]); + ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, g_mdata_part[1]); if (ret < 0) { log_debug("Failed to read the FWU metadata from the device\n"); return -EIO; @@ -206,9 +205,15 @@ static int fwu_gpt_get_mdata(struct udevice *dev, struct fwu_mdata *mdata) static int fwu_gpt_get_mdata_partitions(struct udevice *dev, uint *mdata_parts) { struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + int err; + + err = gpt_get_mdata_partitions(dev_get_uclass_plat(priv->blk_dev)); + if (!err) { + mdata_parts[0] = g_mdata_part[0]; + mdata_parts[1] = g_mdata_part[1]; + }
- return gpt_get_mdata_partitions(dev_get_uclass_plat(priv->blk_dev), - mdata_parts); + return err; }
static int fwu_gpt_read_mdata_partition(struct udevice *dev,
- /* if primary and secondary partitions already found */
- if (g_mdata_part[0] && g_mdata_part[1])
- nparts = 0;
- for (i = 1; i < MAX_SEARCH_PARTITIONS && nparts < 2; i++) { if (part_get_info(desc, i, &info)) continue; uuid_str_to_bin(info.type_guid, part_type_guid.b, UUID_STR_FORMAT_GUID);
if (nparts < 2)
++nparts;
The reason the 'if (nparts < 2)' was outside the main loop was to show errors in case the user defined more than two partitions. Can we keep it like that or am I the only being paranoid here?
- ret = gpt_read_write_mdata(desc, mdata, MDATA_WRITE, g_mdata_part[1]); if (ret < 0) { log_debug("Updating secondary FWU metadata partition failed\n"); return ret;
- ret = gpt_get_mdata_partitions(desc); if (ret < 0) { log_debug("Error getting the FWU metadata partitions\n"); return -ENOENT; }
- ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, g_mdata_part[0]); if (ret < 0) { log_debug("Failed to read the FWU metadata from the device\n"); return -EIO;
- ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, g_mdata_part[1]); if (ret < 0) { log_debug("Failed to read the FWU metadata from the device\n"); return -EIO;
- int err;
- err = gpt_get_mdata_partitions(dev_get_uclass_plat(priv->blk_dev));
- if (!err) {
mdata_parts);
- return err;
2.34.1
Thanks /Ilias
On Thu, 22 Dec 2022 at 06:45, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
nparts = 0;
if (nparts < 2)
++nparts;
I am not sure if that is an 'error', because FWU only cares about the first two partitions it comes across. There is no way other ones could impact the operations. And if fwu code is responsible for correctness of the setup, there are things that we already don't care about. So maybe we keep the code simple?
cheers.
nparts = 0;
if (nparts < 2)
++nparts;
cheers.
I agree with Jassi. We can keep code simple here. The embedded code is not designed to valide DT content but to use it.
Etienne
Instead of each i/f having to implement their own meta-data verification and storage, move the logic in common code. This simplifies the i/f code much simpler and compact.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- drivers/fwu-mdata/fwu-mdata-uclass.c | 34 +++++++ include/fwu.h | 41 ++++++++ lib/fwu_updates/fwu.c | 143 ++++++++++++++++++++++++++- 3 files changed, 214 insertions(+), 4 deletions(-)
diff --git a/drivers/fwu-mdata/fwu-mdata-uclass.c b/drivers/fwu-mdata/fwu-mdata-uclass.c index b477e9603f..e03773c584 100644 --- a/drivers/fwu-mdata/fwu-mdata-uclass.c +++ b/drivers/fwu-mdata/fwu-mdata-uclass.c @@ -16,6 +16,40 @@ #include <linux/types.h> #include <u-boot/crc.h>
+/** + * fwu_read_mdata() - Wrapper around fwu_mdata_ops.read_mdata() + * + * Return: 0 if OK, -ve on error + */ +int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +{ + const struct fwu_mdata_ops *ops = device_get_ops(dev); + + if (!ops->read_mdata) { + log_debug("read_mdata() method not defined\n"); + return -ENOSYS; + } + + return ops->read_mdata(dev, mdata, primary); +} + +/** + * fwu_write_mdata() - Wrapper around fwu_mdata_ops.write_mdata() + * + * Return: 0 if OK, -ve on error + */ +int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +{ + const struct fwu_mdata_ops *ops = device_get_ops(dev); + + if (!ops->write_mdata) { + log_debug("write_mdata() method not defined\n"); + return -ENOSYS; + } + + return ops->write_mdata(dev, mdata, primary); +} + /** * fwu_get_mdata_part_num() - Get the FWU metadata partition numbers * @dev: FWU metadata device diff --git a/include/fwu.h b/include/fwu.h index 0919ced812..1a700c9e6a 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -24,6 +24,26 @@ struct fwu_mdata_gpt_blk_priv { * @update_mdata() - Update the FWU metadata copy */ struct fwu_mdata_ops { + /** + * read_mdata() - Populate the asked FWU metadata copy + * @dev: FWU metadata device + * @mdata: Copy of the FWU metadata + * @primary: If primary or secondary copy of meta-data is to be read + * + * Return: 0 if OK, -ve on error + */ + int (*read_mdata)(struct udevice *dev, struct fwu_mdata *mdata, bool primary); + + /** + * write_mdata() - Write the given FWU metadata copy + * @dev: FWU metadata device + * @mdata: Copy of the FWU metadata + * @primary: If primary or secondary copy of meta-data is to be written + * + * Return: 0 if OK, -ve on error + */ + int (*write_mdata)(struct udevice *dev, struct fwu_mdata *mdata, bool primary); + /** * check_mdata() - Check if the FWU metadata is valid * @dev: FWU device @@ -126,6 +146,27 @@ struct fwu_mdata_ops { EFI_GUID(0x0c996046, 0xbcc0, 0x4d04, 0x85, 0xec, \ 0xe1, 0xfc, 0xed, 0xf1, 0xc6, 0xf8)
+/** + * fwu_read_mdata() - Wrapper around fwu_mdata_ops.read_mdata() + */ +int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary); + +/** + * fwu_write_mdata() - Wrapper around fwu_mdata_ops.write_mdata() + */ +int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary); + +/** + * fwu_get_verified_mdata() - Read, verify and return the FWU metadata + * + * Read both the metadata copies from the storage media, verify their checksum, + * and ascertain that both copies match. If one of the copies has gone bad, + * restore it from the good copy. + * + * Return: 0 if OK, -ve on error +*/ +int fwu_get_verified_mdata(struct fwu_mdata *mdata); + /** * fwu_check_mdata_validity() - Check for validity of the FWU metadata copies * diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 5313d07302..f17bd8ea63 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -15,13 +15,13 @@ #include <linux/errno.h> #include <linux/types.h>
+#include <u-boot/crc.h> + +static struct fwu_mdata g_mdata; /* = {0} makes uninit crc32 always invalid */ +static struct udevice *g_dev; static u8 in_trial; static u8 boottime_check;
-#include <linux/errno.h> -#include <linux/types.h> -#include <u-boot/crc.h> - enum { IMAGE_ACCEPT_SET = 1, IMAGE_ACCEPT_CLEAR, @@ -161,6 +161,141 @@ static int fwu_get_image_type_id(u8 *image_index, efi_guid_t *image_type_id) return -ENOENT; }
+/** + * fwu_sync_mdata() - Update given meta-data partition(s) with the copy provided + * @mdata: FWU metadata structure + * @part: Bitmask of FWU metadata partitions to be written to + * + * Return: 0 if OK, -ve on error + */ +static int fwu_sync_mdata(struct fwu_mdata *mdata, int part) +{ + void *buf = &mdata->version; + int err = 0; + + /* + * Calculate the crc32 for the updated FWU metadata + * and put the updated value in the FWU metadata crc32 + * field + */ + mdata->crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); + + if (part & PRIMARY_PART) + err = fwu_write_mdata(g_dev, mdata, true); + + if (err) { + log_err("Unable to write primary mdata\n"); + return err; + } + + if (part & SECONDARY_PART) + err = fwu_write_mdata(g_dev, mdata, false); + + if (err) { + log_err("Unable to write secondary mdata\n"); + return err; + } + + /* update the cached copy of meta-data */ + memcpy(&g_mdata, mdata, sizeof(struct fwu_mdata)); + + return 0; +} + +static inline int mdata_crc_check(struct fwu_mdata *mdata) +{ + void *buf = &mdata->version; + u32 calc_crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); + + return calc_crc32 == mdata->crc32 ? 0 : -EINVAL; +} + +/** + * fwu_get_verified_mdata() - Read, verify and return the FWU metadata + * + * Read both the metadata copies from the storage media, verify their checksum, + * and ascertain that both copies match. If one of the copies has gone bad, + * restore it from the good copy. + * + * Return: 0 if OK, -ve on error + */ +int fwu_get_verified_mdata(struct fwu_mdata *mdata) +{ + int err; + bool pri_ok, sec_ok; + struct fwu_mdata s, *p_mdata, *s_mdata; + + p_mdata = &g_mdata; + s_mdata = &s; + + /* if mdata already read and ready */ + err = mdata_crc_check(p_mdata); + if (!err) { + if (mdata) + memcpy(mdata, p_mdata, sizeof(struct fwu_mdata)); + return 0; + } + /* else read, verify and, if needed, fix mdata */ + + pri_ok = false; + err = fwu_read_mdata(g_dev, p_mdata, true); + if (!err) { + err = mdata_crc_check(p_mdata); + if (!err) + pri_ok = true; + else + log_debug("primary mdata: crc32 failed\n"); + } + + sec_ok = false; + err = fwu_read_mdata(g_dev, s_mdata, false); + if (!err) { + err = mdata_crc_check(s_mdata); + if (!err) + sec_ok = true; + else + log_debug("secondary mdata: crc32 failed\n"); + } + + if (pri_ok && sec_ok) { + /* + * Before returning, check that both the + * FWU metadata copies are the same. + */ + err = memcmp(p_mdata, s_mdata, sizeof(struct fwu_mdata)); + if (!err) + return 0; + + /* + * If not, populate the secondary partition from the + * primary partition copy. + */ + log_info("Both FWU metadata copies are valid but do not match."); + log_info(" Restoring the secondary partition from the primary\n"); + sec_ok = false; + } + + if (!pri_ok) { + memcpy(p_mdata, s_mdata, sizeof(struct fwu_mdata)); + err = fwu_sync_mdata(p_mdata, PRIMARY_PART); + if (err) + goto exit_fix; + } + + if (!sec_ok) { + memcpy(s_mdata, p_mdata, sizeof(struct fwu_mdata)); + err = fwu_sync_mdata(s_mdata, SECONDARY_PART); + if (err) + goto exit_fix; + } + +exit_fix: + if (err) + log_debug("mdata saving : crc32 failed\n"); + + return err; +} + /** * fwu_verify_mdata() - Verify the FWU metadata * @mdata: FWU metadata structure
Hello Jassi,
- fwu_read_mdata() - Wrapper around fwu_mdata_ops.read_mdata()
- Return: 0 if OK, -ve on error
return -ENOSYS;
- fwu_write_mdata() - Wrapper around fwu_mdata_ops.write_mdata()
return -ENOSYS;
- fwu_get_mdata_part_num() - Get the FWU metadata partition numbers
- @dev: FWU metadata device
- @update_mdata() - Update the FWU metadata copy
- fwu_get_verified_mdata() - Read, verify and return the FWU metadata
- Read both the metadata copies from the storage media, verify their checksum,
- and ascertain that both copies match. If one of the copies has gone bad,
- restore it from the good copy.
- fwu_check_mdata_validity() - Check for validity of the FWU metadata copies
- fwu_sync_mdata() - Update given meta-data partition(s) with the copy provided
- @mdata: FWU metadata structure
- @part: Bitmask of FWU metadata partitions to be written to
int err = 0;
* field
if (err) {
return err;
if (err) {
return err;
int err;
p_mdata = &g_mdata;
s_mdata = &s;
if (!err) {
if (mdata)
pri_ok = false;
if (!err) {
if (!err)
pri_ok = true;
else
sec_ok = false;
if (!err) {
if (!err)
sec_ok = true;
else
if (!err)
Copy of the metadata to @mdata is missing here and in success path before exit_fix branch label.
regards, etienne
sec_ok = false;
if (!pri_ok) {
if (err)
goto exit_fix;
if (!sec_ok) {
if (err)
goto exit_fix;
+exit_fix:
if (err)
return err;
- fwu_verify_mdata() - Verify the FWU metadata
-- 2.34.1
On Tue, 13 Dec 2022 at 09:00, Etienne Carriere etienne.carriere@linaro.org wrote:
Hello Jassi,
return -ENOSYS;
return -ENOSYS;
int err = 0;
* field
if (err) {
return err;
if (err) {
return err;
int err;
p_mdata = &g_mdata;
s_mdata = &s;
if (!err) {
if (mdata)
pri_ok = false;
if (!err) {
if (!err)
pri_ok = true;
else
sec_ok = false;
if (!err) {
if (!err)
sec_ok = true;
else
if (!err)
Thanks for locating the omission.
Cheers.
Moving towards using common code for meta-data management, implement the read/write mdata hooks.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- drivers/fwu-mdata/gpt_blk.c | 40 +++++++++++++++++++++++++++++++++++-- 1 file changed, 38 insertions(+), 2 deletions(-)
diff --git a/drivers/fwu-mdata/gpt_blk.c b/drivers/fwu-mdata/gpt_blk.c index 28f5d23e1e..35239c0a4f 100644 --- a/drivers/fwu-mdata/gpt_blk.c +++ b/drivers/fwu-mdata/gpt_blk.c @@ -222,7 +222,7 @@ static int fwu_gpt_read_mdata_partition(struct udevice *dev, struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev);
return gpt_read_write_mdata(dev_get_uclass_plat(priv->blk_dev), - mdata, MDATA_READ, part_num); + mdata, MDATA_READ, part_num); }
static int fwu_gpt_write_mdata_partition(struct udevice *dev, @@ -231,7 +231,7 @@ static int fwu_gpt_write_mdata_partition(struct udevice *dev, struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev);
return gpt_read_write_mdata(dev_get_uclass_plat(priv->blk_dev), - mdata, MDATA_WRITE, part_num); + mdata, MDATA_WRITE, part_num); }
static int fwu_get_mdata_device(struct udevice *dev, struct udevice **mdata_dev) @@ -272,7 +272,43 @@ static int fwu_mdata_gpt_blk_probe(struct udevice *dev) return 0; }
+static int fwu_gpt_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, + bool primary) +{ + struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + struct blk_desc *desc = dev_get_uclass_plat(priv->blk_dev); + int ret; + + ret = gpt_get_mdata_partitions(desc); + if (ret < 0) { + log_debug("Error getting the FWU metadata partitions\n"); + return -ENOENT; + } + + return gpt_read_write_mdata(desc, mdata, MDATA_READ, + primary ? g_mdata_part[0] : g_mdata_part[1]); +} + +static int fwu_gpt_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, + bool primary) +{ + struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + struct blk_desc *desc = dev_get_uclass_plat(priv->blk_dev); + int ret; + + ret = gpt_get_mdata_partitions(desc); + if (ret < 0) { + log_debug("Error getting the FWU metadata partitions\n"); + return -ENOENT; + } + + return gpt_read_write_mdata(desc, mdata, MDATA_WRITE, + primary ? g_mdata_part[0] : g_mdata_part[1]); +} + static const struct fwu_mdata_ops fwu_gpt_blk_ops = { + .read_mdata = fwu_gpt_read_mdata, + .write_mdata = fwu_gpt_write_mdata, .get_mdata = fwu_gpt_get_mdata, .update_mdata = fwu_gpt_update_mdata, .get_mdata_part_num = fwu_gpt_get_mdata_partitions,
Hi Jassi,
I assume this was by mistake?
ditto
bool primary)
- struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev);
- struct blk_desc *desc = dev_get_uclass_plat(priv->blk_dev);
- int ret;
- if (ret < 0) {
return -ENOENT;
- return gpt_read_write_mdata(desc, mdata, MDATA_READ,
bool primary)
- int ret;
- if (ret < 0) {
return -ENOENT;
- return gpt_read_write_mdata(desc, mdata, MDATA_WRITE,
- .read_mdata = fwu_gpt_read_mdata,
- .write_mdata = fwu_gpt_write_mdata, .get_mdata = fwu_gpt_get_mdata, .update_mdata = fwu_gpt_update_mdata, .get_mdata_part_num = fwu_gpt_get_mdata_partitions,
-- 2.34.1
Other than that Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Hi Jassi,
On Thu, 22 Dec 2022 at 13:59, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Jassi,
I agree. Discard this change.
ditto
bool primary)
int ret;
if (ret < 0) {
return -ENOENT;
bool primary)
int ret;
if (ret < 0) {
return -ENOENT;
-- 2.34.1
Reviewed-by: Etienne Carriere etienne.carriere@linaro.org with Ilias' comments addressed.
On Mon, 2 Jan 2023 at 03:48, Etienne Carriere etienne.carriere@linaro.org wrote:
Hi Jassi,
Hi Jassi,
During the churn I changed from indentation by tabs to spaces. I will drop the change.
Thanks.
The common code can now read, verify and fix meta-data copies while exposing one consistent structure to users. Only the .read_mdata() and .write_mdata() callbacks of fwu_mdata_ops are needed. Get rid of .get_mdata() .update_mdata() .get_mdata_part_num() .read_mdata_partition() and .write_mdata_partition() and also the corresponding wrapper functions.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- cmd/fwu_mdata.c | 17 +- drivers/fwu-mdata/fwu-mdata-uclass.c | 165 ------------------- drivers/fwu-mdata/gpt_blk.c | 124 +------------- include/fwu.h | 199 ----------------------- lib/fwu_updates/fwu.c | 235 ++++----------------------- 5 files changed, 38 insertions(+), 702 deletions(-)
diff --git a/cmd/fwu_mdata.c b/cmd/fwu_mdata.c index f04af27de6..9b70340368 100644 --- a/cmd/fwu_mdata.c +++ b/cmd/fwu_mdata.c @@ -43,23 +43,10 @@ static void print_mdata(struct fwu_mdata *mdata) int do_fwu_mdata_read(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) { - struct udevice *dev; int ret = CMD_RET_SUCCESS, res; - struct fwu_mdata mdata = { 0 }; + struct fwu_mdata mdata;
- if (uclass_get_device(UCLASS_FWU_MDATA, 0, &dev) || !dev) { - log_err("Unable to get FWU metadata device\n"); - return CMD_RET_FAILURE; - } - - res = fwu_check_mdata_validity(); - if (res < 0) { - log_err("FWU Metadata check failed\n"); - ret = CMD_RET_FAILURE; - goto out; - } - - res = fwu_get_mdata(dev, &mdata); + res = fwu_get_verified_mdata(&mdata); if (res < 0) { log_err("Unable to get valid FWU metadata\n"); ret = CMD_RET_FAILURE; diff --git a/drivers/fwu-mdata/fwu-mdata-uclass.c b/drivers/fwu-mdata/fwu-mdata-uclass.c index e03773c584..0a8edaaa41 100644 --- a/drivers/fwu-mdata/fwu-mdata-uclass.c +++ b/drivers/fwu-mdata/fwu-mdata-uclass.c @@ -14,7 +14,6 @@
#include <linux/errno.h> #include <linux/types.h> -#include <u-boot/crc.h>
/** * fwu_read_mdata() - Wrapper around fwu_mdata_ops.read_mdata() @@ -50,170 +49,6 @@ int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) return ops->write_mdata(dev, mdata, primary); }
-/** - * fwu_get_mdata_part_num() - Get the FWU metadata partition numbers - * @dev: FWU metadata device - * @mdata_parts: array for storing the metadata partition numbers - * - * Get the partition numbers on the storage device on which the - * FWU metadata is stored. Two partition numbers will be returned. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_get_mdata_part_num(struct udevice *dev, uint *mdata_parts) -{ - const struct fwu_mdata_ops *ops = device_get_ops(dev); - - if (!ops->get_mdata_part_num) { - log_debug("get_mdata_part_num() method not defined\n"); - return -ENOSYS; - } - - return ops->get_mdata_part_num(dev, mdata_parts); -} - -/** - * fwu_read_mdata_partition() - Read the FWU metadata from a partition - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * @part_num: Partition number from which FWU metadata is to be read - * - * Read the FWU metadata from the specified partition number - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_read_mdata_partition(struct udevice *dev, struct fwu_mdata *mdata, - uint part_num) -{ - const struct fwu_mdata_ops *ops = device_get_ops(dev); - - if (!ops->read_mdata_partition) { - log_debug("read_mdata_partition() method not defined\n"); - return -ENOSYS; - } - - return ops->read_mdata_partition(dev, mdata, part_num); -} - -/** - * fwu_write_mdata_partition() - Write the FWU metadata to a partition - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * @part_num: Partition number to which FWU metadata is to be written - * - * Write the FWU metadata to the specified partition number - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_write_mdata_partition(struct udevice *dev, struct fwu_mdata *mdata, - uint part_num) -{ - const struct fwu_mdata_ops *ops = device_get_ops(dev); - - if (!ops->write_mdata_partition) { - log_debug("write_mdata_partition() method not defined\n"); - return -ENOSYS; - } - - return ops->write_mdata_partition(dev, mdata, part_num); -} - -/** - * fwu_mdata_check() - Check if the FWU metadata is valid - * @dev: FWU metadata device - * - * Validate both copies of the FWU metadata. If one of the copies - * has gone bad, restore it from the other copy. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_mdata_check(struct udevice *dev) -{ - const struct fwu_mdata_ops *ops = device_get_ops(dev); - - if (!ops->check_mdata) { - log_debug("check_mdata() method not defined\n"); - return -ENOSYS; - } - - return ops->check_mdata(dev); -} - -/** - * fwu_get_mdata() - Get a FWU metadata copy - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * - * Get a valid copy of the FWU metadata. - * - * Note: This function is to be called first when modifying any fields - * in the metadata. The sequence of calls to modify any field in the - * metadata would be 1) fwu_get_mdata 2) Modify metadata, followed by - * 3) fwu_update_mdata - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_get_mdata(struct udevice *dev, struct fwu_mdata *mdata) -{ - const struct fwu_mdata_ops *ops = device_get_ops(dev); - - if (!ops->get_mdata) { - log_debug("get_mdata() method not defined\n"); - return -ENOSYS; - } - - return ops->get_mdata(dev, mdata); -} - -/** - * fwu_update_mdata() - Update the FWU metadata - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * - * Update the FWU metadata structure by writing to the - * FWU metadata partitions. - * - * Note: This function is not to be called directly to update the - * metadata fields. The sequence of function calls should be - * 1) fwu_get_mdata() 2) Modify the medata fields 3) fwu_update_mdata() - * - * The sequence of updating the partitions should be, update the - * primary metadata partition (first partition encountered), followed - * by updating the secondary partition. With this update sequence, in - * the rare scenario that the two metadata partitions are valid but do - * not match, maybe due to power outage at the time of updating the - * metadata copies, the secondary partition can be updated from the - * primary. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_update_mdata(struct udevice *dev, struct fwu_mdata *mdata) -{ - void *buf; - const struct fwu_mdata_ops *ops = device_get_ops(dev); - - if (!ops->update_mdata) { - log_debug("get_mdata() method not defined\n"); - return -ENOSYS; - } - - /* - * Calculate the crc32 for the updated FWU metadata - * and put the updated value in the FWU metadata crc32 - * field - */ - buf = &mdata->version; - mdata->crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); - - return ops->update_mdata(dev, mdata); -} - UCLASS_DRIVER(fwu_mdata) = { .id = UCLASS_FWU_MDATA, .name = "fwu-mdata", diff --git a/drivers/fwu-mdata/gpt_blk.c b/drivers/fwu-mdata/gpt_blk.c index 35239c0a4f..b3c6953a6e 100644 --- a/drivers/fwu-mdata/gpt_blk.c +++ b/drivers/fwu-mdata/gpt_blk.c @@ -28,7 +28,7 @@ static uint g_mdata_part[2]; /* = {0, 0} to check against uninit parts */
static int gpt_get_mdata_partitions(struct blk_desc *desc) { - int i, ret; + int i; u32 nparts; efi_guid_t part_type_guid; struct disk_partition info; @@ -52,12 +52,12 @@ static int gpt_get_mdata_partitions(struct blk_desc *desc) if (nparts != 2) { log_debug("Expect two copies of the FWU metadata instead of %d\n", nparts); - ret = -EINVAL; - } else { - ret = 0; + g_mdata_part[0] = 0; + g_mdata_part[1] = 0; + return -EINVAL; }
- return ret; + return 0; }
static int gpt_get_mdata_disk_part(struct blk_desc *desc, @@ -125,115 +125,6 @@ static int gpt_read_write_mdata(struct blk_desc *desc, return 0; }
-static int fwu_gpt_update_mdata(struct udevice *dev, struct fwu_mdata *mdata) -{ - int ret; - struct blk_desc *desc; - struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); - - desc = dev_get_uclass_plat(priv->blk_dev); - - ret = gpt_get_mdata_partitions(desc); - if (ret < 0) { - log_debug("Error getting the FWU metadata partitions\n"); - return -ENOENT; - } - - /* First write the primary partition */ - ret = gpt_read_write_mdata(desc, mdata, MDATA_WRITE, g_mdata_part[0]); - if (ret < 0) { - log_debug("Updating primary FWU metadata partition failed\n"); - return ret; - } - - /* And now the replica */ - ret = gpt_read_write_mdata(desc, mdata, MDATA_WRITE, g_mdata_part[1]); - if (ret < 0) { - log_debug("Updating secondary FWU metadata partition failed\n"); - return ret; - } - - return 0; -} - -static int gpt_get_mdata(struct blk_desc *desc, struct fwu_mdata *mdata) -{ - int ret; - - ret = gpt_get_mdata_partitions(desc); - if (ret < 0) { - log_debug("Error getting the FWU metadata partitions\n"); - return -ENOENT; - } - - ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, g_mdata_part[0]); - if (ret < 0) { - log_debug("Failed to read the FWU metadata from the device\n"); - return -EIO; - } - - ret = fwu_verify_mdata(mdata, 1); - if (!ret) - return 0; - - /* - * Verification of the primary FWU metadata copy failed. - * Try to read the replica. - */ - memset(mdata, '\0', sizeof(struct fwu_mdata)); - ret = gpt_read_write_mdata(desc, mdata, MDATA_READ, g_mdata_part[1]); - if (ret < 0) { - log_debug("Failed to read the FWU metadata from the device\n"); - return -EIO; - } - - ret = fwu_verify_mdata(mdata, 0); - if (!ret) - return 0; - - /* Both the FWU metadata copies are corrupted. */ - return -EIO; -} - -static int fwu_gpt_get_mdata(struct udevice *dev, struct fwu_mdata *mdata) -{ - struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); - - return gpt_get_mdata(dev_get_uclass_plat(priv->blk_dev), mdata); -} - -static int fwu_gpt_get_mdata_partitions(struct udevice *dev, uint *mdata_parts) -{ - struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); - int err; - - err = gpt_get_mdata_partitions(dev_get_uclass_plat(priv->blk_dev)); - if (!err) { - mdata_parts[0] = g_mdata_part[0]; - mdata_parts[1] = g_mdata_part[1]; - } - - return err; -} - -static int fwu_gpt_read_mdata_partition(struct udevice *dev, - struct fwu_mdata *mdata, uint part_num) -{ - struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); - - return gpt_read_write_mdata(dev_get_uclass_plat(priv->blk_dev), - mdata, MDATA_READ, part_num); -} - -static int fwu_gpt_write_mdata_partition(struct udevice *dev, - struct fwu_mdata *mdata, uint part_num) -{ - struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); - - return gpt_read_write_mdata(dev_get_uclass_plat(priv->blk_dev), - mdata, MDATA_WRITE, part_num); -} - static int fwu_get_mdata_device(struct udevice *dev, struct udevice **mdata_dev) { u32 phandle; @@ -309,11 +200,6 @@ static int fwu_gpt_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, static const struct fwu_mdata_ops fwu_gpt_blk_ops = { .read_mdata = fwu_gpt_read_mdata, .write_mdata = fwu_gpt_write_mdata, - .get_mdata = fwu_gpt_get_mdata, - .update_mdata = fwu_gpt_update_mdata, - .get_mdata_part_num = fwu_gpt_get_mdata_partitions, - .read_mdata_partition = fwu_gpt_read_mdata_partition, - .write_mdata_partition = fwu_gpt_write_mdata_partition, };
static const struct udevice_id fwu_mdata_ids[] = { diff --git a/include/fwu.h b/include/fwu.h index 1a700c9e6a..23bd97fe86 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -18,11 +18,6 @@ struct fwu_mdata_gpt_blk_priv { struct udevice *blk_dev; };
-/** - * @mdata_check: check the validity of the FWU metadata partitions - * @get_mdata() - Get a FWU metadata copy - * @update_mdata() - Update the FWU metadata copy - */ struct fwu_mdata_ops { /** * read_mdata() - Populate the asked FWU metadata copy @@ -43,78 +38,6 @@ struct fwu_mdata_ops { * Return: 0 if OK, -ve on error */ int (*write_mdata)(struct udevice *dev, struct fwu_mdata *mdata, bool primary); - - /** - * check_mdata() - Check if the FWU metadata is valid - * @dev: FWU device - * - * Validate both copies of the FWU metadata. If one of the copies - * has gone bad, restore it from the other copy. - * - * Return: 0 if OK, -ve on error - */ - int (*check_mdata)(struct udevice *dev); - - /** - * get_mdata() - Get a FWU metadata copy - * @dev: FWU device - * @mdata: Pointer to FWU metadata - * - * Get a valid copy of the FWU metadata. - * - * Return: 0 if OK, -ve on error - */ - int (*get_mdata)(struct udevice *dev, struct fwu_mdata *mdata); - - /** - * update_mdata() - Update the FWU metadata - * @dev: FWU device - * @mdata: Copy of the FWU metadata - * - * Update the FWU metadata structure by writing to the - * FWU metadata partitions. - * - * Return: 0 if OK, -ve on error - */ - int (*update_mdata)(struct udevice *dev, struct fwu_mdata *mdata); - - /** - * get_mdata_part_num() - Get the FWU metadata partition numbers - * @dev: FWU metadata device - * @mdata_parts: array for storing the metadata partition numbers - * - * Get the partition numbers on the storage device on which the - * FWU metadata is stored. Two partition numbers will be returned. - * - * Return: 0 if OK, -ve on error - */ - int (*get_mdata_part_num)(struct udevice *dev, uint *mdata_parts); - - /** - * read_mdata_partition() - Read the FWU metadata from a partition - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * @part_num: Partition number from which FWU metadata is to be read - * - * Read the FWU metadata from the specified partition number - * - * Return: 0 if OK, -ve on error - */ - int (*read_mdata_partition)(struct udevice *dev, - struct fwu_mdata *mdata, uint part_num); - - /** - * write_mdata_partition() - Write the FWU metadata to a partition - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * @part_num: Partition number to which FWU metadata is to be written - * - * Write the FWU metadata to the specified partition number - * - * Return: 0 if OK, -ve on error - */ - int (*write_mdata_partition)(struct udevice *dev, - struct fwu_mdata *mdata, uint part_num); };
#define FWU_MDATA_VERSION 0x1 @@ -167,102 +90,6 @@ int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary); */ int fwu_get_verified_mdata(struct fwu_mdata *mdata);
-/** - * fwu_check_mdata_validity() - Check for validity of the FWU metadata copies - * - * Read both the metadata copies from the storage media, verify their - * checksum, and ascertain that both copies match. If one of the copies - * has gone bad, restore it from the good copy. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_check_mdata_validity(void); - -/** - * fwu_get_mdata_part_num() - Get the FWU metadata partition numbers - * @dev: FWU metadata device - * @mdata_parts: array for storing the metadata partition numbers - * - * Get the partition numbers on the storage device on which the - * FWU metadata is stored. Two partition numbers will be returned - * through the array. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_get_mdata_part_num(struct udevice *dev, uint *mdata_parts); - -/** - * fwu_read_mdata_partition() - Read the FWU metadata from a partition - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * @part_num: Partition number from which FWU metadata is to be read - * - * Read the FWU metadata from the specified partition number - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_read_mdata_partition(struct udevice *dev, struct fwu_mdata *mdata, - uint part_num); - -/** - * fwu_write_mdata_partition() - Write the FWU metadata to a partition - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * @part_num: Partition number to which FWU metadata is to be written - * - * Write the FWU metadata to the specified partition number - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_write_mdata_partition(struct udevice *dev, struct fwu_mdata *mdata, - uint part_num); - -/** - * fwu_get_mdata() - Get a FWU metadata copy - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * - * Get a valid copy of the FWU metadata. - * - * Note: This function is to be called first when modifying any fields - * in the metadata. The sequence of calls to modify any field in the - * metadata would be 1) fwu_get_mdata 2) Modify metadata, followed by - * 3) fwu_update_mdata - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_get_mdata(struct udevice *dev, struct fwu_mdata *mdata); - -/** - * fwu_update_mdata() - Update the FWU metadata - * @dev: FWU metadata device - * @mdata: Copy of the FWU metadata - * - * Update the FWU metadata structure by writing to the - * FWU metadata partitions. - * - * Note: This function is not to be called directly to update the - * metadata fields. The sequence of function calls should be - * 1) fwu_get_mdata() 2) Modify the medata fields 3) fwu_update_mdata() - * - * The sequence of updating the partitions should be, update the - * primary metadata partition (first partition encountered), followed - * by updating the secondary partition. With this update sequence, in - * the rare scenario that the two metadata partitions are valid but do - * not match, maybe due to power outage at the time of updating the - * metadata copies, the secondary partition can be updated from the - * primary. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_update_mdata(struct udevice *dev, struct fwu_mdata *mdata); - /** * fwu_get_active_index() - Get active_index from the FWU metadata * @active_idxp: active_index value to be read @@ -303,18 +130,6 @@ int fwu_set_active_index(uint active_idx); */ int fwu_get_image_index(u8 *image_index);
-/** - * fwu_mdata_check() - Check if the FWU metadata is valid - * @dev: FWU metadata device - * - * Validate both copies of the FWU metadata. If one of the copies - * has gone bad, restore it from the other copy. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_mdata_check(struct udevice *dev); - /** * fwu_revert_boot_index() - Revert the active index in the FWU metadata * @@ -327,20 +142,6 @@ int fwu_mdata_check(struct udevice *dev); */ int fwu_revert_boot_index(void);
-/** - * fwu_verify_mdata() - Verify the FWU metadata - * @mdata: FWU metadata structure - * @pri_part: FWU metadata partition is primary or secondary - * - * Verify the FWU metadata by computing the CRC32 for the metadata - * structure and comparing it against the CRC32 value stored as part - * of the structure. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_verify_mdata(struct fwu_mdata *mdata, bool pri_part); - /** * fwu_accept_image() - Set the Acceptance bit for the image * @img_type_id: GUID of the image type for which the accepted bit is to be diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index f17bd8ea63..3d11d92fb9 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -33,26 +33,6 @@ enum { BOTH_PARTS, };
-static int fwu_get_dev_mdata(struct udevice **dev, struct fwu_mdata *mdata) -{ - int ret; - - ret = uclass_first_device_err(UCLASS_FWU_MDATA, dev); - if (ret) { - log_debug("Cannot find fwu device\n"); - return ret; - } - - if (!mdata) - return 0; - - ret = fwu_get_mdata(*dev, mdata); - if (ret < 0) - log_debug("Unable to get valid FWU metadata\n"); - - return ret; -} - static int trial_counter_update(u16 *trial_state_ctr) { bool delete; @@ -296,136 +276,6 @@ exit_fix: return err; }
-/** - * fwu_verify_mdata() - Verify the FWU metadata - * @mdata: FWU metadata structure - * @pri_part: FWU metadata partition is primary or secondary - * - * Verify the FWU metadata by computing the CRC32 for the metadata - * structure and comparing it against the CRC32 value stored as part - * of the structure. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_verify_mdata(struct fwu_mdata *mdata, bool pri_part) -{ - u32 calc_crc32; - void *buf; - - buf = &mdata->version; - calc_crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); - - if (calc_crc32 != mdata->crc32) { - log_debug("crc32 check failed for %s FWU metadata partition\n", - pri_part ? "primary" : "secondary"); - return -EINVAL; - } - - return 0; -} - -/** - * fwu_check_mdata_validity() - Check for validity of the FWU metadata copies - * - * Read both the metadata copies from the storage media, verify their checksum, - * and ascertain that both copies match. If one of the copies has gone bad, - * restore it from the good copy. - * - * Return: 0 if OK, -ve on error - * - */ -int fwu_check_mdata_validity(void) -{ - int ret; - struct udevice *dev; - struct fwu_mdata pri_mdata; - struct fwu_mdata secondary_mdata; - uint mdata_parts[2]; - uint valid_partitions, invalid_partitions; - - ret = fwu_get_dev_mdata(&dev, NULL); - if (ret) - return ret; - - /* - * Check if the platform has defined its own - * function to check the metadata partitions' - * validity. If so, that takes precedence. - */ - ret = fwu_mdata_check(dev); - if (!ret || ret != -ENOSYS) - return ret; - - /* - * Two FWU metadata partitions are expected. - * If we don't have two, user needs to create - * them first - */ - valid_partitions = 0; - ret = fwu_get_mdata_part_num(dev, mdata_parts); - if (ret < 0) { - log_debug("Error getting the FWU metadata partitions\n"); - return -ENOENT; - } - - ret = fwu_read_mdata_partition(dev, &pri_mdata, mdata_parts[0]); - if (!ret) { - ret = fwu_verify_mdata(&pri_mdata, 1); - if (!ret) - valid_partitions |= PRIMARY_PART; - } - - ret = fwu_read_mdata_partition(dev, &secondary_mdata, mdata_parts[1]); - if (!ret) { - ret = fwu_verify_mdata(&secondary_mdata, 0); - if (!ret) - valid_partitions |= SECONDARY_PART; - } - - if (valid_partitions == (PRIMARY_PART | SECONDARY_PART)) { - /* - * Before returning, check that both the - * FWU metadata copies are the same. If not, - * populate the secondary partition from the - * primary partition copy. - */ - if (!memcmp(&pri_mdata, &secondary_mdata, - sizeof(struct fwu_mdata))) { - ret = 0; - } else { - log_info("Both FWU metadata copies are valid but do not match."); - log_info(" Restoring the secondary partition from the primary\n"); - ret = fwu_write_mdata_partition(dev, &pri_mdata, - mdata_parts[1]); - if (ret) - log_debug("Restoring secondary FWU metadata partition failed\n"); - } - goto out; - } - - if (!(valid_partitions & BOTH_PARTS)) { - log_info("Both FWU metadata partitions invalid\n"); - ret = -EBADMSG; - goto out; - } - - invalid_partitions = valid_partitions ^ BOTH_PARTS; - ret = fwu_write_mdata_partition(dev, - (invalid_partitions == PRIMARY_PART) ? - &secondary_mdata : &pri_mdata, - (invalid_partitions == PRIMARY_PART) ? - mdata_parts[0] : mdata_parts[1]); - - if (ret) - log_debug("Restoring %s FWU metadata partition failed\n", - (invalid_partitions == PRIMARY_PART) ? - "primary" : "secondary"); - -out: - return ret; -} - /** * fwu_get_active_index() - Get active_index from the FWU metadata * @active_idx: active_index value to be read @@ -438,19 +288,14 @@ out: */ int fwu_get_active_index(uint *active_idx) { - int ret; - struct udevice *dev; - struct fwu_mdata mdata = { 0 }; - - ret = fwu_get_dev_mdata(&dev, &mdata); - if (ret) - return ret; + int ret = 0; + struct fwu_mdata *mdata = &g_mdata;
/* * Found the FWU metadata partition, now read the active_index * value */ - *active_idx = mdata.active_index; + *active_idx = mdata->active_index; if (*active_idx >= CONFIG_FWU_NUM_BANKS) { log_debug("Active index value read is incorrect\n"); ret = -EINVAL; @@ -471,30 +316,25 @@ int fwu_get_active_index(uint *active_idx) int fwu_set_active_index(uint active_idx) { int ret; - struct udevice *dev; - struct fwu_mdata mdata = { 0 }; + struct fwu_mdata *mdata = &g_mdata;
if (active_idx >= CONFIG_FWU_NUM_BANKS) { log_debug("Invalid active index value\n"); return -EINVAL; }
- ret = fwu_get_dev_mdata(&dev, &mdata); - if (ret) - return ret; - /* * Update the active index and previous_active_index fields * in the FWU metadata */ - mdata.previous_active_index = mdata.active_index; - mdata.active_index = active_idx; + mdata->previous_active_index = mdata->active_index; + mdata->active_index = active_idx;
/* * Now write this updated FWU metadata to both the * FWU metadata partitions */ - ret = fwu_update_mdata(dev, &mdata); + ret = fwu_sync_mdata(mdata, BOTH_PARTS); if (ret) { log_debug("Failed to update FWU metadata partitions\n"); ret = -EIO; @@ -524,15 +364,10 @@ int fwu_get_image_index(u8 *image_index) u8 alt_num; uint update_bank; efi_guid_t *image_guid, image_type_id; - struct udevice *dev; - struct fwu_mdata mdata = { 0 }; + struct fwu_mdata *mdata = &g_mdata; struct fwu_image_entry *img_entry; struct fwu_image_bank_info *img_bank_info;
- ret = fwu_get_dev_mdata(&dev, &mdata); - if (ret) - return ret; - ret = fwu_plat_get_update_index(&update_bank); if (ret) { log_debug("Failed to get the FWU update bank\n"); @@ -553,11 +388,11 @@ int fwu_get_image_index(u8 *image_index) */ for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { if (!guidcmp(&image_type_id, - &mdata.img_entry[i].image_type_uuid)) { - img_entry = &mdata.img_entry[i]; + &mdata->img_entry[i].image_type_uuid)) { + img_entry = &mdata->img_entry[i]; img_bank_info = &img_entry->img_bank_info[update_bank]; image_guid = &img_bank_info->image_uuid; - ret = fwu_plat_get_alt_num(dev, image_guid, &alt_num); + ret = fwu_plat_get_alt_num(g_dev, image_guid, &alt_num); if (ret) { log_debug("alt_num not found for partition with GUID %pUs\n", image_guid); @@ -592,26 +427,21 @@ int fwu_revert_boot_index(void) { int ret; u32 cur_active_index; - struct udevice *dev; - struct fwu_mdata mdata = { 0 }; - - ret = fwu_get_dev_mdata(&dev, &mdata); - if (ret) - return ret; + struct fwu_mdata *mdata = &g_mdata;
/* * Swap the active index and previous_active_index fields * in the FWU metadata */ - cur_active_index = mdata.active_index; - mdata.active_index = mdata.previous_active_index; - mdata.previous_active_index = cur_active_index; + cur_active_index = mdata->active_index; + mdata->active_index = mdata->previous_active_index; + mdata->previous_active_index = cur_active_index;
/* * Now write this updated FWU metadata to both the * FWU metadata partitions */ - ret = fwu_update_mdata(dev, &mdata); + ret = fwu_sync_mdata(mdata, BOTH_PARTS); if (ret) { log_debug("Failed to update FWU metadata partitions\n"); ret = -EIO; @@ -638,16 +468,11 @@ int fwu_revert_boot_index(void) static int fwu_clrset_image_accept(efi_guid_t *img_type_id, u32 bank, u8 action) { int ret, i; - struct udevice *dev; - struct fwu_mdata mdata = { 0 }; + struct fwu_mdata *mdata = &g_mdata; struct fwu_image_entry *img_entry; struct fwu_image_bank_info *img_bank_info;
- ret = fwu_get_dev_mdata(&dev, &mdata); - if (ret) - return ret; - - img_entry = &mdata.img_entry[0]; + img_entry = &mdata->img_entry[0]; for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { if (!guidcmp(&img_entry[i].image_type_uuid, img_type_id)) { img_bank_info = &img_entry[i].img_bank_info[bank]; @@ -656,7 +481,7 @@ static int fwu_clrset_image_accept(efi_guid_t *img_type_id, u32 bank, u8 action) else img_bank_info->accepted = 0;
- ret = fwu_update_mdata(dev, &mdata); + ret = fwu_sync_mdata(mdata, BOTH_PARTS); goto out; } } @@ -791,8 +616,6 @@ static int fwu_boottime_checks(void *ctx, struct event *event) { int ret; u32 boot_idx, active_idx; - struct udevice *dev; - struct fwu_mdata mdata = { 0 };
/* Don't have boot time checks on sandbox */ if (IS_ENABLED(CONFIG_SANDBOX)) { @@ -800,9 +623,17 @@ static int fwu_boottime_checks(void *ctx, struct event *event) return 0; }
- ret = fwu_check_mdata_validity(); - if (ret) - return 0; + ret = uclass_first_device_err(UCLASS_FWU_MDATA, &g_dev); + if (ret) { + log_debug("Cannot find fwu device\n"); + return ret; + } + + ret = fwu_get_verified_mdata(NULL); + if (ret) { + log_debug("Unable to read meta-data\n"); + return ret; + }
/* * Get the Boot Index, i.e. the bank from @@ -838,11 +669,7 @@ static int fwu_boottime_checks(void *ctx, struct event *event) if (efi_init_obj_list() != EFI_SUCCESS) return 0;
- ret = fwu_get_dev_mdata(&dev, &mdata); - if (ret) - return ret; - - in_trial = in_trial_state(&mdata); + in_trial = in_trial_state(&g_mdata); if (!in_trial || (ret = fwu_trial_count_update()) > 0) ret = trial_counter_update(NULL);
if (res < 0) {
goto out;
- @mdata_parts: array for storing the metadata partition numbers
- Get the partition numbers on the storage device on which the
- FWU metadata is stored. Two partition numbers will be returned.
return -ENOSYS;
- fwu_read_mdata_partition() - Read the FWU metadata from a partition
- @mdata: Copy of the FWU metadata
- @part_num: Partition number from which FWU metadata is to be read
- Read the FWU metadata from the specified partition number
uint part_num)
return -ENOSYS;
- fwu_write_mdata_partition() - Write the FWU metadata to a partition
- @part_num: Partition number to which FWU metadata is to be written
- Write the FWU metadata to the specified partition number
uint part_num)
return -ENOSYS;
- fwu_mdata_check() - Check if the FWU metadata is valid
- Validate both copies of the FWU metadata. If one of the copies
- has gone bad, restore it from the other copy.
return -ENOSYS;
- fwu_get_mdata() - Get a FWU metadata copy
- Get a valid copy of the FWU metadata.
- Note: This function is to be called first when modifying any fields
- in the metadata. The sequence of calls to modify any field in the
- metadata would be 1) fwu_get_mdata 2) Modify metadata, followed by
- fwu_update_mdata
return -ENOSYS;
- fwu_update_mdata() - Update the FWU metadata
- Update the FWU metadata structure by writing to the
- FWU metadata partitions.
- Note: This function is not to be called directly to update the
- metadata fields. The sequence of function calls should be
- fwu_get_mdata() 2) Modify the medata fields 3) fwu_update_mdata()
- The sequence of updating the partitions should be, update the
- primary metadata partition (first partition encountered), followed
- by updating the secondary partition. With this update sequence, in
- the rare scenario that the two metadata partitions are valid but do
- not match, maybe due to power outage at the time of updating the
- metadata copies, the secondary partition can be updated from the
- primary.
void *buf;
return -ENOSYS;
* field
int i, ret;
ret = -EINVAL;
} else {
ret = 0;
return -EINVAL; }
return ret;
int ret;
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
int ret;
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
return -EIO;
if (!ret)
if (ret < 0) {
return -EIO;
if (!ret)
return -EIO;
int err;
if (!err) {
return err;
- @mdata_check: check the validity of the FWU metadata partitions
- @get_mdata() - Get a FWU metadata copy
* @dev: FWU device
* @dev: FWU device
* @dev: FWU device
- checksum, and ascertain that both copies match. If one of the copies
- has gone bad, restore it from the good copy.
- through the array.
uint part_num);
uint part_num);
- fwu_update_mdata
- primary.
- fwu_get_active_index() - Get active_index from the FWU metadata
- @active_idxp: active_index value to be read
- fwu_revert_boot_index() - Revert the active index in the FWU metadata
- @pri_part: FWU metadata partition is primary or secondary
- Verify the FWU metadata by computing the CRC32 for the metadata
- structure and comparing it against the CRC32 value stored as part
- of the structure.
- fwu_accept_image() - Set the Acceptance bit for the image
- @img_type_id: GUID of the image type for which the accepted bit is to be
int ret;
if (ret) {
return ret;
if (!mdata)
if (ret < 0)
return ret;
- of the structure.
u32 calc_crc32;
void *buf;
return -EINVAL;
int ret;
if (ret)
return ret;
return ret;
* them first
if (ret < 0) {
return -ENOENT;
if (!ret) {
if (!ret)
if (!ret) {
if (!ret)
ret = 0;
} else {
mdata_parts[1]);
if (ret)
goto out;
ret = -EBADMSG;
goto out;
if (ret)
-out:
return ret;
- @active_idx: active_index value to be read
int ret;
if (ret)
return ret;
int ret = 0;
struct fwu_mdata *mdata = &g_mdata; /* * Found the FWU metadata partition, now read the active_index * value */
struct fwu_mdata *mdata = &g_mdata; if (active_idx >= CONFIG_FWU_NUM_BANKS) { log_debug("Invalid active index value\n"); return -EINVAL; }
if (ret)
return ret;
mdata->active_index = active_idx; /* * Now write this updated FWU metadata to both the * FWU metadata partitions */
if (ret)
return ret;
if (ret)
return ret;
struct fwu_mdata *mdata = &g_mdata; /* * Swap the active index and previous_active_index fields * in the FWU metadata */
mdata->previous_active_index = cur_active_index; /* * Now write this updated FWU metadata to both the * FWU metadata partitions */
if (ret)
return ret;
struct fwu_mdata mdata = { 0 }; /* Don't have boot time checks on sandbox */ if (IS_ENABLED(CONFIG_SANDBOX)) {
if (ret)
if (ret) {
return ret;
if (ret) {
return ret;
} /* * Get the Boot Index, i.e. the bank from
if (ret)
return ret;
-- 2.34.1
fwu_get_mdata() sounds more appropriate than fwu_get_verified_mdata()
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- Forgot to send this patch previously in v2 cmd/fwu_mdata.c | 2 +- include/fwu.h | 4 ++-- lib/fwu_updates/fwu.c | 6 +++--- 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/cmd/fwu_mdata.c b/cmd/fwu_mdata.c index 9b70340368..5ecda455df 100644 --- a/cmd/fwu_mdata.c +++ b/cmd/fwu_mdata.c @@ -46,7 +46,7 @@ int do_fwu_mdata_read(struct cmd_tbl *cmdtp, int flag, int ret = CMD_RET_SUCCESS, res; struct fwu_mdata mdata;
- res = fwu_get_verified_mdata(&mdata); + res = fwu_get_mdata(&mdata); if (res < 0) { log_err("Unable to get valid FWU metadata\n"); ret = CMD_RET_FAILURE; diff --git a/include/fwu.h b/include/fwu.h index 23bd97fe86..ea25aca2cd 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -80,7 +80,7 @@ int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary); int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary);
/** - * fwu_get_verified_mdata() - Read, verify and return the FWU metadata + * fwu_get_mdata() - Read, verify and return the FWU metadata * * Read both the metadata copies from the storage media, verify their checksum, * and ascertain that both copies match. If one of the copies has gone bad, @@ -88,7 +88,7 @@ int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary); * * Return: 0 if OK, -ve on error */ -int fwu_get_verified_mdata(struct fwu_mdata *mdata); +int fwu_get_mdata(struct fwu_mdata *mdata);
/** * fwu_get_active_index() - Get active_index from the FWU metadata diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 3d11d92fb9..77444ba2de 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -191,7 +191,7 @@ static inline int mdata_crc_check(struct fwu_mdata *mdata) }
/** - * fwu_get_verified_mdata() - Read, verify and return the FWU metadata + * fwu_get_mdata() - Read, verify and return the FWU metadata * * Read both the metadata copies from the storage media, verify their checksum, * and ascertain that both copies match. If one of the copies has gone bad, @@ -199,7 +199,7 @@ static inline int mdata_crc_check(struct fwu_mdata *mdata) * * Return: 0 if OK, -ve on error */ -int fwu_get_verified_mdata(struct fwu_mdata *mdata) +int fwu_get_mdata(struct fwu_mdata *mdata) { int err; bool pri_ok, sec_ok; @@ -629,7 +629,7 @@ static int fwu_boottime_checks(void *ctx, struct event *event) return ret; }
- ret = fwu_get_verified_mdata(NULL); + ret = fwu_get_mdata(NULL); if (ret) { log_debug("Unable to read meta-data\n"); return ret;
- res = fwu_get_mdata(&mdata); if (res < 0) { log_err("Unable to get valid FWU metadata\n"); ret = CMD_RET_FAILURE;
- fwu_get_mdata() - Read, verify and return the FWU metadata
- ret = fwu_get_mdata(NULL); if (ret) { log_debug("Unable to read meta-data\n"); return ret;
-- 2.34.1
-- 2.34.1
Etienne Carriere
Ilias Apalodimas
Jassi Brar
