[U-Boot-Users] (no subject)
I have a custom MPC8560 Board that Ive been told to get U-Boot working on.
Ive added in board definition into it and modified the default MPC8560ADS configuration for it. I have been able to burn it into flash on the board, and step through it. U-Boot boots up and configures the TLB and then jumps to the proper place in FLASH to continue the load. But it seems to go off into the middle of nowhere when it comes to the serial_puts command. From the JTAG and using the memory map that U-Boot compile makes it gets into the serial_puts function and then jumps off into main memory for some reason. It then halts at where the debugger says is an invalid opcode.
Has anyone seen these sorts of problems before?
The board Ive been given is very bare. It has 256 MByte DDR Main RAM, 32 MByte Flash (64k sectors), Ethernet on MII, and Serial on SCC1. Nothing else on it.
This board use to run VxWorks so I took most of the settings used for that and modified U-boot as following (I hope someone can tell me if I did something wrong)
Made a new directory for the board Copied the MPC8560ADS board files to the new location Copied include/configs/MPC8560ADS.h to a file matching my new board.
Modified the .h file to meet the new board definitions. Removed the SDRAM on LBC, and the SPD_EEPROM
Modified the DDR as follows:
#define CFG_SDRAM_SIZE 256 /* DDR is 256MB */ #define CFG_DDR_CS0_BNDS 0x0000000f /* 0-256MB */ #define CFG_DDR_CS0_CONFIG 0x80000102 #define CFG_DDR_TIMING_1 0x37344321 #define CFG_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ #define CFG_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ #define CFG_DDR_MODE 0x00000062 /* DLL,normal,seq,4/2.5 */ #define CFG_DDR_INTERVAL 0x05100100 /* autocharge,no open page */
Modified flash section as:
#define CFG_FLASH_BASE 0xfe000000 /* start of FLASH 32M */ #define CFG_BR0_PRELIM 0xfe001001 /* port size 16bit */
#define CFG_OR0_PRELIM 0xfe000797 /* 16MB Flash */ #define CFG_MAX_FLASH_BANKS 1 /* number of banks */ #define CFG_MAX_FLASH_SECT 512 /* sectors per device */
Which match the settings that were used for VxWorks for this area
I left I2C alone even though the board has no I2C when I tried to remove it u-boot wouldnt compile.
I then modified init.S in the board directory so the TLB looks like:
tlb1_entry: entry_start
/* * Number of TLB0 and TLB1 entries in the following table */ .long 12
#if (CFG_CCSRBAR_DEFAULT != CFG_CCSRBAR) /* * TLB0 4K Non-cacheable, guarded * 0xff700000 4K Initial CCSRBAR mapping * * This ends up at a TLB0 Index==0 entry, and must not collide * with other TLB0 Entries. */ .long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_CCSRBAR_DEFAULT), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_CCSRBAR_DEFAULT), 0,0,0,0,0,1,0,1,0,1) #else #error("Update the number of table entries in tlb1_entry") #endif
/* * TLB0 16K Cacheable, non-guarded * 0xd001_0000 16K Temporary Global data for initialization * * Use four 4K TLB0 entries. These entries must be cacheable * as they provide the bootstrap memory before the memory * controler and real memory have been configured. * * These entries end up at TLB0 Indicies 0x10, 0x14, 0x18 and 0x1c, * and must not collide with other TLB0 entries. */ .long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR), 0,0,0,0,0,0,0,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR), 0,0,0,0,0,1,0,1,0,1)
.long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 4 * 1024), 0,0,0,0,0,0,0,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 4 * 1024), 0,0,0,0,0,1,0,1,0,1)
.long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 8 * 1024), 0,0,0,0,0,0,0,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 8 * 1024), 0,0,0,0,0,1,0,1,0,1) .long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 12 * 1024), 0,0,0,0,0,0,0,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 12 * 1024), 0,0,0,0,0,1,0,1,0,1)
/* * TLB 0: 16M Non-cacheable, guarded * 0xff000000 16M FLASH * Out of reset this entry is only 4K. */ .long TLB1_MAS0(1, 0, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_16M) .long TLB1_MAS2(E500_TLB_EPN(CFG_FLASH_BASE + 0x01000000), 0,0,0,1,0,1,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_FLASH_BASE + 0x01000000), 0,0,0,0,1,1,1,1,1,1)
/* * TLB 1: 256M Non-cacheable, guarded * 0x80000000 256M PCI1 MEM First half */ .long TLB1_MAS0(1, 1, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) .long TLB1_MAS2(E500_TLB_EPN(CFG_PCI1_MEM_BASE), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_PCI1_MEM_BASE), 0,0,0,0,0,1,0,1,0,1)
/* * TLB 2: 256M Non-cacheable, guarded * 0x90000000 256M PCI1 MEM Second half */ .long TLB1_MAS0(1, 2, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) .long TLB1_MAS2(E500_TLB_EPN(CFG_PCI1_MEM_BASE + 0x10000000), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_PCI1_MEM_BASE + 0x10000000), 0,0,0,0,0,1,0,1,0,1)
/* * TLB 3: 16M Non-cacheable, guarded * 0xfe000000 16M FLASH */ .long TLB1_MAS0(1, 3, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_16M) .long TLB1_MAS2(E500_TLB_EPN(CFG_FLASH_BASE), 0,0,0,1,0,1,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_FLASH_BASE), 0,0,0,0,1,1,1,1,1,1)
/* * TLB 5: 64M Non-cacheable, guarded * 0xe000_0000 1M CCSRBAR * 0xe200_0000 16M PCI1 IO */ .long TLB1_MAS0(1, 5, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) .long TLB1_MAS2(E500_TLB_EPN(CFG_CCSRBAR), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_CCSRBAR), 0,0,0,0,0,1,0,1,0,1)
/* * TLB 7: 16K Non-cacheable, guarded * 0xf8000000 16K BCSR registers */ .long TLB1_MAS0(1, 7, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_16K) .long TLB1_MAS2(E500_TLB_EPN(CFG_BCSR), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_BCSR), 0,0,0,0,0,1,0,1,0,1)
#if !defined(CONFIG_SPD_EEPROM) /* * TLB 8: 256M DDR * 0x00000000 64M DDR System memory * 0x04000000 64M DDR System memory * Without SPD EEPROM configured DDR, this must be setup manually. * Make sure the TLB count at the top of this table is correct. * Likely it needs to be increased by two for these entries. */
.long TLB1_MAS0(1, 8, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) .long TLB1_MAS2(E500_TLB_EPN(CFG_DDR_SDRAM_BASE), 0,0,0,0,0,1,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_DDR_SDRAM_BASE), 0,0,0,0,1,1,1,1,1,1) #endif
entry_end
Modified the Local Address window to:
#if !defined(CONFIG_SPD_EEPROM) #define LAWBAR0 ((CFG_DDR_SDRAM_BASE>>12) & 0xfffff) /*#define LAWAR0 (LAWAR_EN | LAWAR_TRGT_IF_DDR | (LAWAR_SIZE & LAWAR_SIZE_256M))*/ #define LAWAR0 0x80f0001b #else #define LAWBAR0 0 #define LAWAR0 ((LAWAR_TRGT_IF_DDR | (LAWAR_SIZE & LAWAR_SIZE_128M)) & ~LAWAR_EN) #endif
#define LAWBAR1 ((CFG_PCI1_MEM_BASE>>12) & 0xfffff) #define LAWAR1 (LAWAR_EN | LAWAR_TRGT_IF_PCIX | (LAWAR_SIZE & LAWAR_SIZE_512M))
/* * This is not so much the FLASH map as it is the whole localbus map. */ #define LAWBAR2 ((CFG_FLASH_BASE>>12) & 0xfffff) #define LAWAR2 (LAWAR_EN | LAWAR_TRGT_IF_LBC | (LAWAR_SIZE & LAWAR_SIZE_32M))
law_entry: entry_start .long 0x04 .long LAWBAR0,LAWAR0,LAWBAR1,LAWAR1,LAWBAR2,LAWAR2,LAWBAR3,LAWAR3 entry_end
Anyone have any idea on what Ive done wrong? Are there any other board definitions in U-Boot I could use that might meet what I have better?
Peter Wright Senior Software Engineer Base Station Development CDMA Division Main: 1-604-276-0055 Direct: 1-604-303-8599 ext 267
Dear Peter,
please provide a *descriptive* Subject next time. And ask short and simple questions instead of posting hundrets of lines of ighly specific stuff which nobody will read. Maybe you should (re-) read http://www.catb.org/%7eesr/faqs/smart-questions.html
N message 007601c67085$77b32bf0$3b8119ac@bc.ca.utstar.com you wrote:
Ive added in board definition into it and modified the default MPC8560ADS configuration for it. I have been able to burn it into flash on the > board,
What makes you think the MPC8560ADS would be a good starting point?
The board Ive been given is very bare. It has 256 MByte DDR Main > RAM, 32 MByte Flash (64k sectors), Ethernet on MII, and Serial on SCC1. > Nothing else on it.
I bet this is wrong. There are probabnly ten times more components on your board which you did not mention that there are you did.
This board use to run VxWorks so I took most of the settings used for > that and modified U-boot as following (I hope someone can tell me if I did something wrong)
No. How could we? We have absolutely no idea what your hardware looks like.
How could we without even having the slightest ideas of what you have?
Peter Wright
