[U-Boot] pull request for u-boot-tegra/master into ARM/master
Albert,
Please pull u-boot-tegra/master into ARM/master. Thanks!
./MAKEALL -a arm completes w/o any new errors, and checkpatch is clean.
The following changes since commit 3a9d879f6f64585b819af728b53be0a05037fe0d: Tom Rini (1): Prepare v2013.01
git://git.denx.de/u-boot-tegra master
Allen Martin (5): tegra: remove IRDA pinmux synonym tegra: fdt: remove clocks nodes tegra: fdt: sort dts files tegra: fdt: add apbdma node fdt: fix dts preprocessor options
Marc Dietrich (3): tegra: display: add board pinmux tegra: enable LCD on PAZ00 tegra: remove custom TEGRA_DEVICE_SETTINGS for board files
Thierry Reding (3): video: tegra: Update line length to match resolution tegra: Enable LCD on Medcom-Wide tegra: Enable LCD on TEC
Tom Warren (10): Tegra30: Add arch-tegra30 include files Tegra30: Add AVP (arm720t) files Tegra30: Add CPU (armv7) files Tegra30: Add common CPU (shared) files Tegra30: Cardhu: Add DT files Tegra30: Add generic Tegra30 build support Tegra30: Add/enable Cardhu build (T30 reference board) Tegra30: clocks: Fix clock tables for I2C and other periphs Tegra30: fdt: Update DT files with I2C info for T30/Cardhu Tegra30: I2C: Enable I2C driver on Cardhu
Makefile | 6 +- arch/arm/cpu/arm720t/tegra-common/Makefile | 1 + arch/arm/cpu/arm720t/tegra-common/cpu.c | 335 +++++++ arch/arm/cpu/arm720t/tegra-common/cpu.h | 68 +- arch/arm/cpu/arm720t/tegra-common/spl.c | 3 +- arch/arm/cpu/arm720t/tegra20/cpu.c | 216 +---- arch/arm/cpu/arm720t/tegra30/Makefile | 41 + arch/arm/cpu/arm720t/tegra30/config.mk | 19 + arch/arm/cpu/arm720t/tegra30/cpu.c | 176 ++++ arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/start.S | 4 +- arch/arm/cpu/armv7/tegra30/Makefile | 40 + arch/arm/cpu/armv7/tegra30/config.mk | 19 + arch/arm/cpu/tegra-common/ap.c | 14 +- arch/arm/cpu/tegra-common/board.c | 43 +- arch/arm/cpu/tegra-common/sys_info.c | 16 +- arch/arm/cpu/tegra20-common/funcmux.c | 4 +- arch/arm/cpu/tegra20-common/pinmux.c | 2 +- arch/arm/cpu/tegra20-common/warmboot.c | 2 +- arch/arm/cpu/tegra30-common/Makefile | 44 + arch/arm/cpu/tegra30-common/clock.c | 1102 ++++++++++++++++++++++ arch/arm/cpu/tegra30-common/funcmux.c | 57 ++ arch/arm/cpu/tegra30-common/pinmux.c | 506 ++++++++++ arch/arm/dts/tegra20.dtsi | 400 ++++---- arch/arm/dts/tegra30.dtsi | 93 ++ arch/arm/include/asm/arch-tegra/ap.h | 52 +- arch/arm/include/asm/arch-tegra/board.h | 7 +- arch/arm/include/asm/arch-tegra/clk_rst.h | 148 +++- arch/arm/include/asm/arch-tegra/clock.h | 8 +- arch/arm/include/asm/arch-tegra/funcmux.h | 39 + arch/arm/include/asm/arch-tegra/gp_padctrl.h | 39 + arch/arm/include/asm/arch-tegra/tegra.h | 12 +- arch/arm/include/asm/arch-tegra20/funcmux.h | 28 +- arch/arm/include/asm/arch-tegra20/gp_padctrl.h | 17 +- arch/arm/include/asm/arch-tegra20/pinmux.h | 1 - arch/arm/include/asm/arch-tegra30/clock-tables.h | 382 ++++++++ arch/arm/include/asm/arch-tegra30/clock.h | 24 + arch/arm/include/asm/arch-tegra30/flow.h | 35 + arch/arm/include/asm/arch-tegra30/funcmux.h | 31 + arch/arm/include/asm/arch-tegra30/gp_padctrl.h | 59 ++ arch/arm/include/asm/arch-tegra30/gpio.h | 304 ++++++ arch/arm/include/asm/arch-tegra30/hardware.h | 22 + arch/arm/include/asm/arch-tegra30/pinmux.h | 603 ++++++++++++ arch/arm/include/asm/arch-tegra30/pmu.h | 23 + arch/arm/include/asm/arch-tegra30/spl.h | 28 + arch/arm/include/asm/arch-tegra30/tegra.h | 26 + board/avionic-design/dts/tegra20-medcom-wide.dts | 38 +- board/avionic-design/dts/tegra20-plutux.dts | 14 - board/avionic-design/dts/tegra20-tec.dts | 56 +- board/compal/dts/tegra20-paz00.dts | 39 +- board/compal/paz00/paz00.c | 11 + board/compulab/dts/tegra20-trimslice.dts | 13 - board/nvidia/cardhu/Makefile | 44 + board/nvidia/cardhu/cardhu.c | 39 + board/nvidia/cardhu/cardhu.c.mmc | 151 +++ board/nvidia/cardhu/pinmux-config-cardhu.h | 329 +++++++ board/nvidia/common/board.c | 24 +- board/nvidia/dts/tegra20-harmony.dts | 33 +- board/nvidia/dts/tegra20-seaboard.dts | 118 +-- board/nvidia/dts/tegra20-ventana.dts | 13 - board/nvidia/dts/tegra20-whistler.dts | 10 - board/nvidia/dts/tegra30-cardhu.dts | 42 + boards.cfg | 1 + drivers/video/tegra.c | 4 +- dts/Makefile | 2 +- include/configs/cardhu.h | 54 ++ include/configs/medcom-wide.h | 8 + include/configs/paz00.h | 9 + include/configs/tec.h | 9 +- include/configs/tegra-common-post.h | 27 - include/configs/tegra-common.h | 160 ++++ include/configs/tegra20-common.h | 201 ++--- include/configs/tegra30-common.h | 89 ++ include/serial.h | 2 +- spl/Makefile | 2 +- 75 files changed, 5718 insertions(+), 925 deletions(-) create mode 100644 arch/arm/cpu/arm720t/tegra-common/cpu.c create mode 100644 arch/arm/cpu/arm720t/tegra30/Makefile create mode 100644 arch/arm/cpu/arm720t/tegra30/config.mk create mode 100644 arch/arm/cpu/arm720t/tegra30/cpu.c create mode 100644 arch/arm/cpu/armv7/tegra30/Makefile create mode 100644 arch/arm/cpu/armv7/tegra30/config.mk create mode 100644 arch/arm/cpu/tegra30-common/Makefile create mode 100644 arch/arm/cpu/tegra30-common/clock.c create mode 100644 arch/arm/cpu/tegra30-common/funcmux.c create mode 100644 arch/arm/cpu/tegra30-common/pinmux.c create mode 100644 arch/arm/dts/tegra30.dtsi create mode 100644 arch/arm/include/asm/arch-tegra/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock-tables.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock.h create mode 100644 arch/arm/include/asm/arch-tegra30/flow.h create mode 100644 arch/arm/include/asm/arch-tegra30/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra30/gpio.h create mode 100644 arch/arm/include/asm/arch-tegra30/hardware.h create mode 100644 arch/arm/include/asm/arch-tegra30/pinmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra30/spl.h create mode 100644 arch/arm/include/asm/arch-tegra30/tegra.h create mode 100644 board/nvidia/cardhu/Makefile create mode 100644 board/nvidia/cardhu/cardhu.c create mode 100644 board/nvidia/cardhu/cardhu.c.mmc create mode 100644 board/nvidia/cardhu/pinmux-config-cardhu.h create mode 100644 board/nvidia/dts/tegra30-cardhu.dts create mode 100644 include/configs/cardhu.h create mode 100644 include/configs/tegra-common.h create mode 100644 include/configs/tegra30-common.h
Hi Tom,
On Fri, 18 Jan 2013 09:00:44 -0700, Tom Warren twarren.nvidia@gmail.com wrote:
Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Tom Warren
