[PATCH v1 2/3] arm: dts: rockchip: update cpu and gpu nodes
In order to better compare the Linux rk3288.dtsi version with the u-boot version update the cpu and gpu nodes.
Changed: use operating-points-v2 update thermal for all cpus add labels to all cpus change gpu compatible change gpu interrupt names
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3288.dtsi | 148 +++++++++++++++++++++++++++++---------- 1 file changed, 111 insertions(+), 37 deletions(-)
diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index c46741b0..6b03a63c 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -45,44 +45,99 @@ device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x500>; - operating-points = < - /* KHz uV */ - 1800000 1400000 - 1704000 1350000 - 1608000 1300000 - 1512000 1250000 - 1416000 1200000 - 1200000 1100000 - 1008000 1050000 - 816000 1000000 - 696000 950000 - 600000 900000 - 408000 900000 - 216000 900000 - 126000 900000 - >; + resets = <&cru SRST_CORE0>; + operating-points-v2 = <&cpu_opp_table>; #cooling-cells = <2>; /* min followed by max */ clock-latency = <40000>; clocks = <&cru ARMCLK>; - resets = <&cru SRST_CORE0>; + dynamic-power-coefficient = <370>; }; - cpu@501 { + cpu1: cpu@501 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x501>; resets = <&cru SRST_CORE1>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; - cpu@502 { + cpu2: cpu@502 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x502>; resets = <&cru SRST_CORE2>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; - cpu@503 { + cpu3: cpu@503 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x503>; resets = <&cru SRST_CORE3>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; + }; + }; + + cpu_opp_table: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-126000000 { + opp-hz = /bits/ 64 <126000000>; + opp-microvolt = <900000>; + }; + opp-216000000 { + opp-hz = /bits/ 64 <216000000>; + opp-microvolt = <900000>; + }; + opp-312000000 { + opp-hz = /bits/ 64 <312000000>; + opp-microvolt = <900000>; + }; + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <900000>; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <900000>; + }; + opp-696000000 { + opp-hz = /bits/ 64 <696000000>; + opp-microvolt = <950000>; + }; + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1000000>; + }; + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1050000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1100000>; + }; + opp-1416000000 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1200000>; + }; + opp-1512000000 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <1300000>; + }; + opp-1608000000 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <1350000>; }; };
@@ -374,12 +429,18 @@ map0 { trip = <&cpu_alert0>; cooling-device = - <&cpu0 THERMAL_NO_LIMIT 6>; + <&cpu0 THERMAL_NO_LIMIT 6>, + <&cpu1 THERMAL_NO_LIMIT 6>, + <&cpu2 THERMAL_NO_LIMIT 6>, + <&cpu3 THERMAL_NO_LIMIT 6>; }; map1 { trip = <&cpu_alert1>; cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; @@ -900,31 +961,44 @@ };
gpu: gpu@ffa30000 { - compatible = "arm,malit764", - "arm,malit76x", - "arm,malit7xx", - "arm,mali-midgard"; + compatible = "rockchip,rk3288-mali", "arm,mali-t760"; reg = <0xffa30000 0x10000>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "JOB", "MMU", "GPU"; + interrupt-names = "job", "mmu", "gpu"; clocks = <&cru ACLK_GPU>; - clock-names = "aclk_gpu"; - operating-points = < - /* KHz uV */ - 100000 950000 - 200000 950000 - 300000 1000000 - 400000 1100000 - /* 500000 1200000 - See crosbug.com/p/33857 */ - 600000 1250000 - >; + operating-points-v2 = <&gpu_opp_table>; #cooling-cells = <2>; /* min followed by max */ power-domains = <&power RK3288_PD_GPU>; status = "disabled"; };
+ gpu_opp_table: opp-table-1 { + compatible = "operating-points-v2"; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + opp-microvolt = <950000>; + }; + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + opp-microvolt = <950000>; + }; + opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + opp-microvolt = <1000000>; + }; + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + opp-microvolt = <1100000>; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <1250000>; + }; + }; + dmac_bus_s: dma-controller@ffb20000 { compatible = "arm,pl330", "arm,primecell"; reg = <0xffb20000 0x4000>;
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
/* KHz uV */
1800000 1400000
1704000 1350000
1608000 1300000
1512000 1250000
1416000 1200000
1200000 1100000
1008000 1050000
816000 1000000
696000 950000
600000 900000
408000 900000
216000 900000
126000 900000
};dynamic-power-coefficient = <370>;
cpu@501 {
cpu@502 {
cpu@503 {
- cpu_opp_table: opp-table-0 {
opp-shared;
opp-126000000 {
opp-216000000 {
opp-312000000 {
opp-408000000 {
opp-600000000 {
opp-696000000 {
opp-816000000 {
opp-1008000000 {
opp-1200000000 {
opp-1416000000 {
opp-1512000000 {
opp-1608000000 {
}; };opp-microvolt = <1350000>;
};<&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; };
gpu: gpu@ffa30000 {
"arm,malit76x",
"arm,malit7xx",
"arm,mali-midgard";
reg = <0xffa30000 0x10000>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;compatible = "rockchip,rk3288-mali", "arm,mali-t760";
clocks = <&cru ACLK_GPU>;interrupt-names = "job", "mmu", "gpu";
/* KHz uV */
100000 950000
200000 950000
300000 1000000
400000 1100000
600000 1250000
opp-100000000 {
opp-200000000 {
opp-300000000 {
opp-400000000 {
opp-600000000 {
Johan Jonker
Kever Yang
