[U-Boot] [U-boot] [Patch v2 0/3] keystone: nand: add additional nand ecclayout
For keystyone k2hk board the default nand layout is different from davinci. So swich ecc layout at init in board file.
To do this the series adds a nand ecclayout command to davinci nand that allows the ecclayout of the current nand device to be changed during run time. This feature is useful when using u-boot to write something to nand flash that will be read by other applications, such as ROM bootloader, that expects a different ECC layout. In that case, change the current nand device ecclayout using the "nand ecclayout set" command before writing the data to nand flash.
Based on git://git.denx.de/u-boot-ti.git master
v2..v1: k2hk: change default nand ecc layout - new patch
mtd: nand: davinci: allow to change ecclayout by ecclayout command - aligned pattern. - used ARRAY_SIZE instead of definition of size - added some comments - rename board_nand_ecclayout_get_layout() to shorter name - don't change default ecc layout at init
common: cmd_nand: add nand ecclayout command - impove format of ecc layout printing - improve description of nand ecclayout command - add description of CONFIG_CMD_NAND_ECCLAYOUT config - move some code stuff to board_nand_ecclayout_set() - don't wrap user-visible string - remove #ifdef of function prototypes
Ivan Khoronzhuk (1): k2hk: change default nand ecc layout
WingMan Kwok (2): mtd: nand: davinci: allow to change ecclayout by ecclayout command common: cmd_nand: add nand ecclayout command
arch/arm/include/asm/ti-common/davinci_nand.h | 4 ++ board/ti/k2hk_evm/board.c | 11 ++++ common/cmd_nand.c | 91 ++++++++++++++++++++++++++ doc/README.nand | 12 ++++ drivers/mtd/nand/davinci_nand.c | 94 +++++++++++++++++++++++++++ include/nand.h | 7 ++ 6 files changed, 219 insertions(+)
This patch adds opportunity to change ecclayout of current nand device during runtime. So we can change the current nand device ecclayout using the "nand ecclayout set" command before writing the data to nand flash.
Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: WingMan Kwok w-kwok2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/include/asm/ti-common/davinci_nand.h | 4 ++ drivers/mtd/nand/davinci_nand.c | 94 +++++++++++++++++++++++++++ 2 files changed, 98 insertions(+)
diff --git a/arch/arm/include/asm/ti-common/davinci_nand.h b/arch/arm/include/asm/ti-common/davinci_nand.h index 11407be..bb3ed94 100644 --- a/arch/arm/include/asm/ti-common/davinci_nand.h +++ b/arch/arm/include/asm/ti-common/davinci_nand.h @@ -93,6 +93,10 @@ struct davinci_emif_regs { #define DAVINCI_ABCR_ASIZE_16BIT 1 #define DAVINCI_ABCR_ASIZE_8BIT 0
+/* Layouts */ +#define NAND_DAVINCI_4BIT_LAYOUT 0 +#define NAND_KEYSTONE_RBL_4BIT_LAYOUT 1 + void davinci_nand_init(struct nand_chip *nand);
#endif diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index 5d42509..a4bc921 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -305,6 +305,100 @@ static struct nand_ecclayout nand_davinci_4bit_layout_oobfirst = { #endif };
+#if defined(CONFIG_CMD_NAND_ECCLAYOUT) +#if defined(CONFIG_SYS_NAND_PAGE_2K) +static struct nand_ecclayout nand_keystone_rbl_4bit_layout_oobfirst = { + .eccbytes = 40, + .eccpos = { + 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, + 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, + 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, + 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, + }, + .oobfree = { + {.offset = 2, .length = 4, }, + {.offset = 16, .length = 6, }, + {.offset = 32, .length = 6, }, + {.offset = 48, .length = 6, }, + }, +}; +#elif defined(CONFIG_SYS_NAND_PAGE_4K) +static struct nand_ecclayout nand_keystone_rbl_4bit_layout_oobfirst = { + .eccbytes = 80, + .eccpos = { + 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, + 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, + 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, + 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, + 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, + 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, + 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, + 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, + }, + .oobfree = { + {.offset = 2, .length = 4, }, + {.offset = 16, .length = 6, }, + {.offset = 32, .length = 6, }, + {.offset = 48, .length = 6, }, + {.offset = 64, .length = 6, }, + {.offset = 80, .length = 6, }, + {.offset = 96, .length = 6, }, + {.offset = 112, .length = 6, }, + }, +}; +#endif + +struct nand_ecclayout *davinci_nand_ecclayouts[] = { + &nand_davinci_4bit_layout_oobfirst, + &nand_keystone_rbl_4bit_layout_oobfirst, +}; + +int board_nand_get_ecclayout_idx(struct nand_chip *nand, + struct nand_ecclayout *layout) +{ + int i; + + if (!layout) + return -1; + + for (i = 0; i < ARRAY_SIZE(davinci_nand_ecclayouts); i++) + if (davinci_nand_ecclayouts[i] == layout) + return i; + + return -1; +} + +struct nand_ecclayout *board_nand_get_ecclayout(int idx) +{ + if ((idx >= 0) && (idx < ARRAY_SIZE(davinci_nand_ecclayouts))) + return davinci_nand_ecclayouts[idx]; + else + return NULL; +} + +int board_nand_set_ecclayout(struct mtd_info *mtd, int idx) +{ + int i; + struct nand_ecclayout *layout; + struct nand_chip *nand = mtd->priv; + + if (idx < 0 || idx >= ARRAY_SIZE(davinci_nand_ecclayouts)) + return -1; + + layout = nand->ecc.layout; + layout = davinci_nand_ecclayouts[idx]; + + layout->oobavail = 0; + for (i = 0; layout->oobfree[i].length && + i < ARRAY_SIZE(layout->oobfree); i++) + layout->oobavail += layout->oobfree[i].length; + + mtd->oobavail = layout->oobavail; + + return 0; +} +#endif /* CONFIG_CMD_NAND_ECCLAYOUT */ + static void nand_davinci_4bit_enable_hwecc(struct mtd_info *mtd, int mode) { u32 val;
This commit adds a nand ecclayout command that allows the ecclayout of the current nand device to be changed during run time. This feature is useful when using u-boot to write something to nand flash that will be read by other applications, such as ROM bootloader, that expects a different ECC layout. In that case, change the current nand device ecclayout using the "nand ecclayout set" command before writing the data to nand flash.
Signed-off-by: WingMan Kwok w-kwok2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- common/cmd_nand.c | 91 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ doc/README.nand | 12 ++++++++ include/nand.h | 7 +++++ 3 files changed, 110 insertions(+)
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index a84f7dc..61d3fcc 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -462,6 +462,51 @@ static void adjust_size_for_badblocks(loff_t *size, loff_t offset, int dev) } }
+#ifdef CONFIG_CMD_NAND_ECCLAYOUT +static void nand_print_ecclayout_info(struct nand_ecclayout *layout) +{ + int i; + struct nand_oobfree *oobfree; + + if (!layout) + return; + + printf(" num ecc bytes: %d\n", layout->eccbytes); + puts(" ecc pos:\n "); + for (i = 0; i < layout->eccbytes; i++) { + if (i && !(i % 8)) + printf("\n "); + + printf("%4d ", layout->eccpos[i]); + } + + puts("\n oobfree:\n"); + puts(" offset length\n"); + oobfree = layout->oobfree; + for (i = 0; oobfree->length && i < MTD_MAX_OOBFREE_ENTRIES_LARGE; i++) { + printf(" %3d %3d\n", oobfree->offset, oobfree->length); + oobfree++; + } +} + +static void nand_print_device_ecclayout(int dev) +{ + int idx; + nand_info_t *nand = &nand_info[dev]; + struct nand_chip *chip = nand->priv; + + idx = board_nand_get_ecclayout_idx(chip, chip->ecc.layout); + + if (idx < 0) { + puts("no ecc layout\n"); + return; + } + + printf("\necc layout %d:\n", idx); + nand_print_ecclayout_info(chip->ecc.layout); +} +#endif + static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i, ret = 0; @@ -830,6 +875,45 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } #endif
+#ifdef CONFIG_CMD_NAND_ECCLAYOUT + if (strcmp(cmd, "ecclayout") == 0) { + int i; + struct nand_ecclayout *lt; + nand_info_t *nand = &nand_info[dev]; + + if (argc < 3) { + puts("Current device ecclayout:\n"); + nand_print_device_ecclayout(dev); + return 0; + } + + if (!strcmp(argv[2], "set")) { + if (argc < 4) + return 1; + + i = (int)simple_strtoul(argv[3], NULL, 10); + if (board_nand_set_ecclayout(nand, i)) + printf("Setting current device to ecc layout %d FAILED!\n", i); + + return 0; + } + + if (strcmp(argv[2], "all") != 0) + return 1; + + /* show all available ecc layouts */ + puts("Available ecc layouts:\n"); + + for (i = 0; (lt = board_nand_get_ecclayout(i)); i++) { + + printf("\n ecc laytout %d:\n", i); + nand_print_ecclayout_info(lt); + } + + return 0; + } +#endif + usage: return CMD_RET_USAGE; } @@ -884,6 +968,13 @@ static char nand_help_text[] = "nand env.oob set off|partition - set enviromnent offset\n" "nand env.oob get - get environment offset" #endif +#ifdef CONFIG_CMD_NAND_ECCLAYOUT + "\n" + "nand ecclayout [all] - show ecclayout, 'all' shows all \n" + " available ecc layouts for setting to current device\n" + "nand ecclayout set idx - sets current device ecc layout \n" + " to layout indexed by idx\n" +#endif ""; #endif
diff --git a/doc/README.nand b/doc/README.nand index 70cf768..6fdce26 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -87,6 +87,15 @@ Commands: a packed sequence of "data, oob, data, oob, ..." -- no alignment of individual pages is maintained.
+ nand ecclayout [all] + Enabled by the CONFIG_CMD_NAND_ECCLAYOUT macro. This command show current + ecclayout, "all" shows all available ecc layouts for setting to current + device. + + nand ecclayout set idx + Enabled by the CONFIG_CMD_NAND_ECCLAYOUT macro. This command set current + device ecc layout to layout indexed by idx. + Configuration Options:
CONFIG_CMD_NAND @@ -208,6 +217,9 @@ Configuration Options: drivers/mtd/nand/ndfc.c drivers/mtd/nand/omap_gpmc.c
+ CONFIG_CMD_NAND_ECCLAYOUT + Enables support of nand ecclayout commands. +
Platform specific options ========================= diff --git a/include/nand.h b/include/nand.h index fc735d1..a810626 100644 --- a/include/nand.h +++ b/include/nand.h @@ -155,6 +155,13 @@ void nand_deselect(void); void board_nand_select_device(struct nand_chip *nand, int chip); #endif
+int board_nand_get_ecclayout_idx(struct nand_chip *nand, + struct nand_ecclayout *layout); + +struct nand_ecclayout *board_nand_get_ecclayout(int idx); + +int board_nand_set_ecclayout(struct mtd_info *mtd, int idx); + __attribute__((noreturn)) void nand_boot(void);
#endif
Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- board/ti/k2hk_evm/board.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/board/ti/k2hk_evm/board.c b/board/ti/k2hk_evm/board.c index ef90f9d..baa6ab7 100644 --- a/board/ti/k2hk_evm/board.c +++ b/board/ti/k2hk_evm/board.c @@ -11,6 +11,7 @@ #include <exports.h> #include <fdt_support.h> #include <libfdt.h> +#include <nand.h>
#include <asm/arch/hardware.h> #include <asm/arch/clock.h> @@ -19,6 +20,7 @@ #include <asm/arch/emac_defs.h> #include <asm/arch/psc_defs.h> #include <asm/ti-common/ti-aemif.h> +#include <asm/ti-common/davinci_nand.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -147,6 +149,15 @@ int cpu_to_bus(u32 *ptr, u32 length) return 0; }
+int board_nand_init(struct nand_chip *chip) +{ + davinci_nand_init(chip); + chip->ecc.layout = + board_nand_get_ecclayout(NAND_KEYSTONE_RBL_4BIT_LAYOUT); + + return 0; +} + #if defined(CONFIG_BOARD_EARLY_INIT_F) int board_early_init_f(void) {
- davinci_nand_init(chip);
- chip->ecc.layout =
Shouldn't you be calling board_nand_set_ecclayout()? How will oobavail get set?
Is it really OK to start with the wrong ECC layout and switch later? Are you depending on lazy scanning of the BBT?
For that matter, you also seem to be assuming that markbad will never be called when the ECC is set to something other than what the BBT uses.
-Scott
There is no reason to set oobavail here, I suppose that's done while int nand_scan_tail().
It can be used to boot from nand.
No, define CONFIG_SYS_NAND_USE_FLASH_BBT
-Scott
I suppose that only ECC layout is different.
But nand_scan_tail() has already run at this point. oobavail would be set based on the wrong layout.
That doesn't answer my question.
My point is, if the scanning of the BBT happens before you set the layout, it will be read using the wrong ECC layout.
-Scott
"only"? That's a big deal.
-Scott
Where did you get.. I've checked it again. It was called after board_nand_init().
nand_init_chip -> board_nand_init -> nand_scan -> nand_scan_tail
Seems It can be started with default ecc layout. So I'm going to remove subj patch.
-Scott
-Scott
If I correctly understand you, what if while we are writing data a new bad block is found? Then we try to update BBT wich was written using a different layout....
Well probably I should rewrite BBT when layout is switched.. Will see if it can be done correctly. Thanks.
Never mind, I was thinking of the flow when using CONFIG_SYS_NAND_SELF_INIT.
Still, it's probably not great to introduce a mechanism that is incompatible with transitioning to self-init.
Could you clarify the use case here? Are you changing the layout at runtime so that different portions of the chip use different ECC schemes (e.g. because booting requires something different)? If so, then you don't want to rewrite the BBT based on this, and a better approach than a command line switcher would be to be able to define different layouts for different offset ranges.
If this is meant to be a permanent change that affects the entire chip, then the entire chip (not just the BBT, but excluding factory bad block markers) needs to be wiped when you change, and you should be recording the default in the environment (e.g. hwconfig) rather than switching with a command line option.
-Scott
Exactly. It has partitions with different ecc layouts. ROM bootloader uses own ecclayout ...(and it doesn't touch BBT).
-Scott
Thanks Scott, I'm thinking how to split chip for using different ecc layouts. If it be OK, I'll remove commands in question.
Ivan Khoronzhuk
Scott Wood
