[U-Boot] [PATCH v2 2/3] imx: Use a clear identification of an unidentified CPU type
In case an unidentified CPU type is detected it now returns i.MX??, in a const char.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br Cc: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com
Changes since v1: * use i.MX?? for unidentified CPU type --- arch/arm/cpu/armv7/imx-common/cpu.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/imx-common/cpu.c b/arch/arm/cpu/armv7/imx-common/cpu.c index b3195dd..e7bd0bf 100644 --- a/arch/arm/cpu/armv7/imx-common/cpu.c +++ b/arch/arm/cpu/armv7/imx-common/cpu.c @@ -66,7 +66,7 @@ char *get_reset_cause(void)
#if defined(CONFIG_DISPLAY_CPUINFO)
-static char *get_imx_type(u32 imxtype) +static const char *get_imx_type(u32 imxtype) { switch (imxtype) { case 0x63: @@ -80,7 +80,7 @@ static char *get_imx_type(u32 imxtype) case 0x53: return "53"; default: - return "unknown"; + return "??"; } }
The information now is gathered from HW_DIGCTL_CHIPID register and includes the revision of the chip on the output.
--- Changes since v1: * use ?? for unidentified revision and cpu type * use numeric revisions
arch/arm/cpu/arm926ejs/mx28/mx28.c | 55 +++++++++++++++++++++++++- arch/arm/include/asm/arch-mx28/regs-digctl.h | 5 +++ 2 files changed, 58 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index a82ff25..5a527cf 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -190,13 +190,64 @@ int arch_cpu_init(void) #endif
#if defined(CONFIG_DISPLAY_CPUINFO) +static const char *get_cpu_type(void) +{ + struct mx28_digctl_regs *digctl_regs = + (struct mx28_digctl_regs *)MXS_DIGCTL_BASE; + + switch (readl(&digctl_regs->hw_digctl_chipid) & HW_DIGCTL_CHIPID_MASK) { + case HW_DIGCTL_CHIPID_MX28: + return "28"; + case HW_DIGCTL_CHIPID_MX23: + return "23"; + default: + return "??"; + } +} + +static const char *get_cpu_rev(void) +{ + struct mx28_digctl_regs *digctl_regs = + (struct mx28_digctl_regs *)MXS_DIGCTL_BASE; + uint8_t rev = readl(&digctl_regs->hw_digctl_chipid) & 0x000000FF; + + switch (readl(&digctl_regs->hw_digctl_chipid) & HW_DIGCTL_CHIPID_MASK) { + case HW_DIGCTL_CHIPID_MX28: + switch (rev) { + case 0x1: + return "1.2"; + default: + return "??"; + } + case HW_DIGCTL_CHIPID_MX23: + switch (rev) { + case 0x0: + return "1.0"; + case 0x1: + return "1.1"; + case 0x2: + return "1.2"; + case 0x3: + return "1.3"; + case 0x4: + return "1.4"; + default: + return "??"; + } + default: + return "??"; + } +} + int print_cpuinfo(void) { struct mx28_spl_data *data = (struct mx28_spl_data *) ((CONFIG_SYS_TEXT_BASE - sizeof(struct mx28_spl_data)) & ~0xf);
- printf("Freescale i.MX28 family at %d MHz\n", - mxc_get_clock(MXC_ARM_CLK) / 1000000); + printf("CPU: Freescale i.MX%s %s at rev%s MHz\n", + get_cpu_type(), + get_cpu_rev(), + mxc_get_clock(MXC_ARM_CLK) / 1000000); printf("BOOT: %s\n", mx28_boot_modes[data->boot_mode_idx].mode); return 0; } diff --git a/arch/arm/include/asm/arch-mx28/regs-digctl.h b/arch/arm/include/asm/arch-mx28/regs-digctl.h index 9a63594..67f91e7 100644 --- a/arch/arm/include/asm/arch-mx28/regs-digctl.h +++ b/arch/arm/include/asm/arch-mx28/regs-digctl.h @@ -152,4 +152,9 @@ struct mx28_digctl_regs { }; #endif
+/* Product code identification */ +#define HW_DIGCTL_CHIPID_MASK (0xffff << 16) +#define HW_DIGCTL_CHIPID_MX23 (0x3780 << 16) +#define HW_DIGCTL_CHIPID_MX28 (0x2800 << 16) + #endif /* __MX28_REGS_DIGCTL_H__ */
On Sun, Jun 24, 2012 at 6:34 PM, Otavio Salvador otavio@ossystems.com.br wrote:
- struct mx28_digctl_regs *digctl_regs =
- (struct mx28_digctl_regs *)MXS_DIGCTL_BASE;
- switch (readl(&digctl_regs->hw_digctl_chipid) & HW_DIGCTL_CHIPID_MASK) {
- case HW_DIGCTL_CHIPID_MX28:
- return "28";
- case HW_DIGCTL_CHIPID_MX23:
- return "23";
- default:
- return "??";
- uint8_t rev = readl(&digctl_regs->hw_digctl_chipid) & 0x000000FF;
- switch (rev) {
- case 0x1:
- return "1.2";
- default:
- return "??";
- switch (rev) {
- case 0x0:
- return "1.0";
- case 0x1:
- return "1.1";
- case 0x2:
- return "1.2";
- case 0x3:
- return "1.3";
- case 0x4:
- return "1.4";
- default:
- return "??";
- default:
- return "??";
- printf("CPU: Freescale i.MX%s %s at rev%s MHz\n",
No, you are printing CPU: Freescale i.MX28 1.2 at rev454 MHz, which is very confusing.
Correct is: CPU: Freescale i.MX28 rev1.2 at 454 MHz
Dear Otavio Salvador,
In message 1340573676-29765-1-git-send-email-otavio@ossystems.com.br you wrote:
Changes since v1:
- use i.MX?? for unidentified CPU type
The change long belongs _below_ the "---" line, not above it, where it becomes part of the commessage.
Can you _please_ read http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions ?? You will even find examples there.
I asked you to do this before...
I used git send-email --annotate but probably did something wrong as it didn't ask me to edit this one. I am tracking the changelog on commit log or I forgot what changes I did since last send.
I read it; no problem with it and I am trying to get used to it.
Fabio Estevam
Otavio Salvador
