[PATCH 1/8] Convert CONFIG_AM335X_USB0 et al to Kconfig
This converts the following to Kconfig: CONFIG_AM335X_USB0 CONFIG_AM335X_USB0_MODE CONFIG_AM335X_USB1 CONFIG_AM335X_USB1_MODE
We do this by introducing specific options for static configuration of USB0/USB1 in SPL rather than defining CONFIG_AM335X_USBx_MODE to the enum value being used. Furthermore, with how the code is used now we do not need to have OTG mode exposed as an option here, so remove that.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-omap2/am33xx/Kconfig | 32 ++++++++++++++++++++++++++ arch/arm/mach-omap2/am33xx/board.c | 8 +++---- configs/am335x_evm_defconfig | 3 +++ configs/am335x_guardian_defconfig | 3 +++ include/configs/am335x_evm.h | 12 ---------- include/configs/am335x_guardian.h | 5 ---- include/configs/baltos.h | 12 ---------- include/configs/chiliboard.h | 4 ---- include/configs/siemens-am33x-common.h | 7 ------ 9 files changed, 42 insertions(+), 44 deletions(-)
diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 1402376915ea..b8e115dc92bf 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -280,3 +280,35 @@ config PUB_ROM_DATA_SIZE image, this area is no longer used, and can be reclaimed for run time use by the boot image. endif + +config AM335X_USB0 + bool "Static mode configuration for USB0 in SPL" + depends on AM33XX && SPL_MUSB_NEW && !SPL_OF_CONTROL + +choice + prompt "USB0 port configuration" + depends on AM335X_USB0 + +config AM335X_USB0_HOST + bool "Port is used in host mode" + +config AM335X_USB0_PERIPHERAL + bool "Port is used in peripheral mode" + +endchoice + +config AM335X_USB1 + bool "Static mode configuration for USB1 in SPL" + depends on AM33XX && SPL_MUSB_NEW && !SPL_OF_CONTROL + +choice + prompt "USB1 port configuration" + depends on AM335X_USB1 + +config AM335X_USB1_HOST + bool "Port is used in host mode" + +config AM335X_USB1_PERIPHERAL + bool "Port is used in peripheral mode" + +endchoice diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index ed809329f29c..7f1b84e466da 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -242,14 +242,14 @@ static struct ti_musb_plat usb1 = { #endif
U_BOOT_DRVINFOS(am33xx_usbs) = { -#if CONFIG_AM335X_USB0_MODE == MUSB_PERIPHERAL +#ifdef CONFIG_AM335X_USB0_PERIPHERAL { "ti-musb-peripheral", &usb0 }, -#elif CONFIG_AM335X_USB0_MODE == MUSB_HOST +#elif defined(CONFIG_AM335X_USB0_HOST) { "ti-musb-host", &usb0 }, #endif -#if CONFIG_AM335X_USB1_MODE == MUSB_PERIPHERAL +#ifdef CONFIG_AM335X_USB1_PERIPHERAL { "ti-musb-peripheral", &usb1 }, -#elif CONFIG_AM335X_USB1_MODE == MUSB_HOST +#elif defined(CONFIG_AM335X_USB1_HOST) { "ti-musb-host", &usb1 }, #endif }; diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 535b269076cf..497127d4065b 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -4,6 +4,9 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_AM33XX=y +CONFIG_AM335X_USB0=y +CONFIG_AM335X_USB0_PERIPHERAL=y +CONFIG_AM335X_USB1=y CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_TIMESTAMP=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index ca3d01aea429..f8cc073c2329 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -10,6 +10,9 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_DEFAULT_DEVICE_TREE="am335x-guardian" CONFIG_AM33XX=y CONFIG_TARGET_AM335X_GUARDIAN=y +CONFIG_AM335X_USB0=y +CONFIG_AM335X_USB0_PERIPHERAL=y +CONFIG_AM335X_USB1=y CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 9070845b7a64..4db04ff54e7e 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -201,18 +201,6 @@ * in memory. */
-/* - * USB configuration. We enable MUSB support, both for host and for - * gadget. We set USB0 as peripheral and USB1 as host, based on the - * board schematic and physical port wired to each. Then for host we - * add mass storage support and for gadget we add both RNDIS ethernet - * and DFU. - */ -#define CONFIG_AM335X_USB0 -#define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL -#define CONFIG_AM335X_USB1 -#define CONFIG_AM335X_USB1_MODE MUSB_HOST - /* * Disable MMC DM for SPL build and can be re-enabled after adding * DM support in SPL diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index 10a95a10a0eb..608a22db4442 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -129,9 +129,4 @@
#endif /* CONFIG_MTD_RAW_NAND */
-#define CONFIG_AM335X_USB0 -#define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL -#define CONFIG_AM335X_USB1 -#define CONFIG_AM335X_USB1_MODE MUSB_HOST - #endif /* ! __CONFIG_AM335X_GUARDIAN_H */ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index f4ab6640cdc8..b881d8c03fd7 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -214,18 +214,6 @@ #endif #endif
-/* - * USB configuration. We enable MUSB support, both for host and for - * gadget. We set USB0 as peripheral and USB1 as host, based on the - * board schematic and physical port wired to each. Then for host we - * add mass storage support and for gadget we add both RNDIS ethernet - * and DFU. - */ -#define CONFIG_AM335X_USB0 -#define CONFIG_AM335X_USB0_MODE MUSB_HOST -#define CONFIG_AM335X_USB1 -#define CONFIG_AM335X_USB1_MODE MUSB_OTG - /* NAND support */ #ifdef CONFIG_MTD_RAW_NAND #define GPMC_NAND_ECC_LP_x8_LAYOUT 1 diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index fe496272630d..aa2a07e910f8 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -127,10 +127,6 @@ #define CONFIG_SYS_NAND_ECCBYTES 14 /* NAND: SPL related configs */
-/* USB configuration */ -#define CONFIG_AM335X_USB1 -#define CONFIG_AM335X_USB1_MODE MUSB_HOST - /* * Disable MMC DM for SPL build and can be re-enabled after adding * DM support in SPL diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index c3a04c2f65a6..bfadf4a6b861 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -104,13 +104,6 @@ */
#ifndef CONFIG_SPL_BUILD -/* - * USB configuration - */ -#define CONFIG_AM335X_USB0 -#define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL -#define CONFIG_AM335X_USB1 -#define CONFIG_AM335X_USB1_MODE MUSB_HOST
/* USB DRACO ID as default */ #define CONFIG_USBD_HS
This converts the following to Kconfig: CONFIG_AT91SAM9260 CONFIG_AT91SAM9G20 CONFIG_AT91SAM9XE CONFIG_AT91SAM9261 CONFIG_AT91SAM9263 CONFIG_AT91SAM9G45 CONFIG_AT91SAM9M10G45 CONFIG_AT91SAM9N12 CONFIG_AT91SAM9RL CONFIG_AT91SAM9X5 CONFIG_SAM9X60 CONFIG_SAMA7G5 CONFIG_SAMA5D2 CONFIG_SAMA5D3 CONFIG_SAMA5D4
These options are already select'd as needed, so we're just cleaning up files here.
Cc: Eugen Hristev eugen.hristev@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-at91/Kconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9260ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9260ek_nandflash_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9261ek_dataflash_cs3_defconfig | 2 +- configs/at91sam9261ek_nandflash_defconfig | 2 +- configs/at91sam9263ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9263ek_dataflash_defconfig | 2 +- configs/at91sam9263ek_nandflash_defconfig | 2 +- configs/at91sam9263ek_norflash_boot_defconfig | 2 +- configs/at91sam9263ek_norflash_defconfig | 2 +- configs/at91sam9g20ek_2mmc_defconfig | 2 +- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 +- configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 +- configs/at91sam9g20ek_nandflash_defconfig | 2 +- configs/at91sam9rlek_dataflash_defconfig | 2 +- configs/at91sam9rlek_mmc_defconfig | 2 +- configs/at91sam9rlek_nandflash_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs0_defconfig | 2 +- configs/at91sam9xeek_dataflash_cs1_defconfig | 2 +- configs/at91sam9xeek_nandflash_defconfig | 2 +- configs/axm_defconfig | 1 - configs/corvus_defconfig | 2 +- configs/ethernut5_defconfig | 1 - configs/gurnard_defconfig | 1 - configs/meesc_dataflash_defconfig | 2 +- configs/meesc_defconfig | 2 +- configs/pm9261_defconfig | 1 - configs/pm9263_defconfig | 1 - configs/sama5d27_giantboard_defconfig | 1 - configs/sama5d27_som1_ek_mmc1_defconfig | 1 - configs/sama5d27_som1_ek_mmc_defconfig | 1 - configs/sama5d27_som1_ek_qspiflash_defconfig | 1 - configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 - configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 - configs/sama5d2_icp_mmc_defconfig | 1 - configs/sama5d2_icp_qspiflash_defconfig | 1 - configs/sama5d2_ptc_ek_mmc_defconfig | 1 - configs/sama5d2_ptc_ek_nandflash_defconfig | 1 - configs/sama5d2_xplained_emmc_defconfig | 2 +- configs/sama5d2_xplained_mmc_defconfig | 2 +- configs/sama5d2_xplained_qspiflash_defconfig | 2 +- configs/smartweb_defconfig | 1 - configs/snapper9260_defconfig | 1 - configs/snapper9g20_defconfig | 1 - configs/taurus_defconfig | 1 - configs/usb_a9263_dataflash_defconfig | 2 +- 49 files changed, 30 insertions(+), 48 deletions(-)
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 00f31045d67f..e99b9064e519 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -176,6 +176,7 @@ config TARGET_SAMA5D2_XPLAINED
config TARGET_SAMA5D27_SOM1_EK bool "SAMA5D27 SOM1 EK board" + select SAMA5D2 select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select CPU_V7A diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 0a6295e655f2..568084880192 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 1ddee34fe45d..a393120b9bef 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 0e92e3aa444a..a5b9b5e7f6e5 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 11126d59a7bd..809aa718160f 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -16,7 +16,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS0" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 01c8d0ed4543..aa7770637508 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -16,7 +16,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS3" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 5674944870d9..9b86fc5628e4 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -14,7 +14,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 5508855af8ec..641d91ef7e11 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 5508855af8ec..641d91ef7e11 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 4df2bfe249d1..a705e45636b8 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 4eb24a8b16d9..aeb189d2b7df 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_BOOT_NORFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_BOOT_NORFLASH" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 99c4d676ad9c..a424dd7fa740 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -16,7 +16,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NORFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NORFLASH" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index cbfaef4e4485..6ee645a7738f 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -16,7 +16,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" +CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20EK_2MMC,SYS_USE_MMC" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait" diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 77d9ab6b8b85..b2ee395433d2 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 2e09c7da5d00..1bfeb5a789ee 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 5ad7c4cbe249..cc6da7acca57 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 763a5f4fbc10..4a2550b49240 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 9943b868c0da..713dbb3621cb 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_DATAFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 9fd20428afe1..74e96b95f7e3 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_MMC" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_MMC" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 mtdparts=atmel_nand:8M(bootstrap/uboot/kernel)ro,-(rootfs) root=/dev/mmcblk0p2 rw rootwait" diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index a922780eaee1..d1c888bf3864 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256K(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=7 root=ubi0:rootfs" diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 8b4a146e340d..568084880192 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS0" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 57484dfd239f..a393120b9bef 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -17,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS1" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 6c25da9472b9..a5b9b5e7f6e5 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 518e6d44c08d..e27f0b71ed90 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run flash_self" diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 6ea76dbf4f6b..0d7352cc4e45 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -20,7 +20,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_LOAD_ADDR=0x70000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index b7169b19940f..339e8d147ac1 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -14,7 +14,6 @@ CONFIG_ENV_SECT_SIZE=0x21000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ethernut5" CONFIG_SYS_LOAD_ADDR=0x020000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 7def2253a5c1..c44714f4a38f 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -10,7 +10,6 @@ CONFIG_ENV_OFFSET=0x80000 CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-gurnard" CONFIG_SYS_LOAD_ADDR=0x23000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 0e8a545ea1eb..5858a99abd21 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -14,7 +14,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_SYS_LOAD_ADDR=0x20100000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 9e5eb5aeef81..9141bdfc749b 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -12,7 +12,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_SYS_LOAD_ADDR=0x20100000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index eb07b420a3d3..7a640ff35ece 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -11,7 +11,6 @@ CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock4 rootfstype=jffs2 fbcon=rotate:3 " diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index f0767a4aa68f..3c5f0b73abf6 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -11,7 +11,6 @@ CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock4 rootfstype=jffs2 fbcon=rotate:3 " diff --git a/configs/sama5d27_giantboard_defconfig b/configs/sama5d27_giantboard_defconfig index 9ca984c1c954..7d25474260d3 100644 --- a/configs/sama5d27_giantboard_defconfig +++ b/configs/sama5d27_giantboard_defconfig @@ -26,7 +26,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index c958f2a19b71..1df7ae08976f 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -25,7 +25,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 279a5f372667..adb6580f192c 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -26,7 +26,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 8753790d9e55..cd5142521a0d 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -26,7 +26,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index ac2e916c567e..43be6fbeb321 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -24,7 +24,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index a44ba50fa2ce..574a67e07ee6 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -24,7 +24,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_QSPI_BOOT=y CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 49fe180205ab..5b530f0da66e 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -24,7 +24,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_icp_qspiflash_defconfig b/configs/sama5d2_icp_qspiflash_defconfig index 78b65a94aa67..e103ae3ddec4 100644 --- a/configs/sama5d2_icp_qspiflash_defconfig +++ b/configs/sama5d2_icp_qspiflash_defconfig @@ -18,7 +18,6 @@ CONFIG_SYS_BOOT_GET_CMDLINE=y CONFIG_SYS_BOOT_GET_KBD=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_QSPI_BOOT=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 46f9bd33238c..609e202c34de 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -16,7 +16,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index cbef580be064..132f31a3d474 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -16,7 +16,6 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 47672b524a08..caacbabb7bf2 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -25,7 +25,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_MMC" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 4f22d6b9a7db..de9fe9d13b6c 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -26,7 +26,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_MMC" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index e21b6a8d7d6e..24b509d06276 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -26,7 +26,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_MMC" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 426b9394e2f9..64a77b0ddaeb 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index 59ab0756a3ae..c2049153275b 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -10,7 +10,6 @@ CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 CONFIG_SYS_LOAD_ADDR=0x23000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 ip=any" diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 4ed958d1c139..f18ead2f4080 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -10,7 +10,6 @@ CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 CONFIG_SYS_LOAD_ADDR=0x23000000 CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 ip=any" diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index eaede092f853..c68945d4b7ec 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -30,7 +30,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 1f34f3369add..e38313b9baf5 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -13,7 +13,7 @@ CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="usb_a9263" CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock1 mtdparts=mtdparts=atmel_nand:16m(kernel)ro,120m(root1),-(root2) rw rootfstype=jffs2"
This converts the following to Kconfig: CONFIG_AT91SAM9G20EK CONFIG_AT91SAM9260EK CONFIG_AT91SAM9G20EK_2MMC
Cc: Eugen Hristev eugen.hristev@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- board/atmel/at91sam9260ek/Kconfig | 15 +++++++++++++++ configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 4 +++- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 4 +++- configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + include/configs/at91sam9260ek.h | 9 --------- 13 files changed, 30 insertions(+), 11 deletions(-)
diff --git a/board/atmel/at91sam9260ek/Kconfig b/board/atmel/at91sam9260ek/Kconfig index 3844f086b4c1..40db313ba8aa 100644 --- a/board/atmel/at91sam9260ek/Kconfig +++ b/board/atmel/at91sam9260ek/Kconfig @@ -9,4 +9,19 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "at91sam9260ek"
+choice + prompt "Evaluation board" + +config AT91SAM9G20EK + bool "Atmel AT91SAM9G20 EK" + +config AT91SAM9260EK + bool "Atmel AT91SAM9260 EK" + +endchoice + +config AT91SAM9G20EK_2MMC + bool "Atmel AT91SAM9G20 EK 2MMC variant" + depends on AT91SAM9260EK + endif diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 568084880192..15866a8ebbda 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index a393120b9bef..ade828e48617 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index a5b9b5e7f6e5..caa9699425bb 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 6ee645a7738f..665dfc8c7890 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -6,6 +6,8 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x23000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y +CONFIG_AT91SAM9G20EK_2MMC=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x2000 @@ -16,7 +18,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20EK_2MMC,SYS_USE_MMC" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_MMC" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait" diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index b2ee395433d2..37a420edb71e 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -6,6 +6,8 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y +CONFIG_AT91SAM9G20EK_2MMC=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" @@ -15,7 +17,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 1bfeb5a789ee..48de0be95dc2 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index cc6da7acca57..dfc756a0e723 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 4a2550b49240..ddd64d31ff33 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 568084880192..15866a8ebbda 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index a393120b9bef..ade828e48617 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index a5b9b5e7f6e5..caa9699425bb 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 820c6a921be0..f5eeed8c179f 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -27,15 +27,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* main clock xtal */
-/* Define actual evaluation board type from used processor type */ -#ifdef CONFIG_AT91SAM9G20 -# define CONFIG_AT91SAM9G20EK /* It's an Atmel AT91SAM9G20 EK */ -#else -# define CONFIG_AT91SAM9260EK /* It's an Atmel AT91SAM9260 EK */ -#endif - -/* Misc CPU related */ - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */
This converts the following to Kconfig: CONFIG_AT91SAM9G10EK CONFIG_AT91SAM9261EK CONFIG_AT91SAM9G10
Cc: Eugen Hristev eugen.hristev@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- board/atmel/at91sam9261ek/Kconfig | 14 ++++++++++++++ configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 3 ++- configs/at91sam9g10ek_dataflash_cs3_defconfig | 3 ++- configs/at91sam9g10ek_nandflash_defconfig | 3 ++- include/configs/at91sam9261ek.h | 6 ------ 8 files changed, 23 insertions(+), 9 deletions(-)
diff --git a/board/atmel/at91sam9261ek/Kconfig b/board/atmel/at91sam9261ek/Kconfig index 2971b3cf9fb4..6133efe23e8a 100644 --- a/board/atmel/at91sam9261ek/Kconfig +++ b/board/atmel/at91sam9261ek/Kconfig @@ -9,4 +9,18 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "at91sam9261ek"
+choice + prompt "Evaluation board" + +config AT91SAM9G10EK + bool "Atmel AT91SAM9G10 EK" + +config AT91SAM9261EK + bool "Atmel AT91SAM9261 EK" + +config AT91SAM9G10 + bool "Atmel AT91SAM9G10 EK" + +endchoice + endif diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 809aa718160f..1bfd11f92fb8 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_AT91SAM9261EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index aa7770637508..ed6621438abe 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_AT91SAM9261EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 9b86fc5628e4..8e1bbb0441a3 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_AT91SAM9261EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index cee1f9c6f75a..a84736277d83 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_AT91SAM9G10=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 @@ -16,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS0" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index f2724cd26ddc..baff817cfaf2 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_AT91SAM9G10=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 @@ -16,7 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS3" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 647a0e7d1da7..9cdf3a2ee008 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_AT91SAM9G10=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" @@ -14,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_DEBUG_UART=y CONFIG_SYS_LOAD_ADDR=0x22000000 -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_NANDFLASH" +CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index b6d0247d7cf6..347e255bfb0a 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -14,12 +14,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */
-#ifdef CONFIG_AT91SAM9G10 -#define CONFIG_AT91SAM9G10EK /* It's an Atmel AT91SAM9G10 EK*/ -#else -#define CONFIG_AT91SAM9261EK /* It's an Atmel AT91SAM9261 EK*/ -#endif - #include <asm/hardware.h>
This symbol is used only once, and in comparison with an unset symbol, so drop it.
Cc: Eugen Hristev eugen.hristev@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 4 ---- include/configs/at91sam9m10g45ek.h | 2 -- 2 files changed, 6 deletions(-)
diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 8cb2808e058a..b1462b3e3ebd 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -267,11 +267,7 @@ int board_early_init_f(void) int board_init(void) { /* arch number of AT91SAM9M10G45EK-Board */ -#ifdef CONFIG_AT91SAM9M10G45EK gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9M10G45EK; -#elif defined CONFIG_AT91SAM9G45EKES - gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G45EKES; -#endif
/* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index a6f0844443d0..2616ca68eb5f 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -16,8 +16,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */
-#define CONFIG_AT91SAM9M10G45EK - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */
This variable is used once and is noted as board-specific. Use the value directly with a comment.
Cc: Eugen Hristev eugen.hristev@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 3 ++- include/configs/at91sam9m10g45ek.h | 2 -- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index b1462b3e3ebd..fcca8923e38f 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -214,7 +214,8 @@ static void at91sam9m10g45ek_lcd_hw_init(void)
at91_periph_clk_enable(ATMEL_ID_LCDC);
- gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE; + /* board specific(not enough SRAM) */ + gd->fb_base = 0x73E00000; }
#ifdef CONFIG_LCD_INFO diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 2616ca68eb5f..31e075350fd4 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -27,8 +27,6 @@ #define CONFIG_LCD_INFO_BELOW_LOGO #define CONFIG_ATMEL_LCD #define CONFIG_ATMEL_LCD_RGB565 -/* board specific(not enough SRAM) */ -#define CONFIG_AT91SAM9G45_LCD_BASE 0x73E00000
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE 0x70000000
This converts the following to Kconfig: CONFIG_AT91_GPIO_PULLUP
Cc: Eugen Hristev eugen.hristev@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-at91/Kconfig | 4 ++++ configs/axm_defconfig | 1 + configs/corvus_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/taurus_defconfig | 1 + include/configs/corvus.h | 1 - include/configs/smartweb.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/taurus.h | 1 - 13 files changed, 11 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index e99b9064e519..79fe87ca58e0 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -311,6 +311,10 @@ config AT91_EFLASH Enable the driver for the embedded flash used in the Atmel AT91SAM9XE devices.
+config AT91_GPIO_PULLUP + bool "Keep pullups on peripheral pins" + depends on CPU_ARM926EJS + source "board/atmel/at91sam9260ek/Kconfig" source "board/atmel/at91sam9261ek/Kconfig" source "board/atmel/at91sam9263ek/Kconfig" diff --git a/configs/axm_defconfig b/configs/axm_defconfig index e27f0b71ed90..b6b4104d243f 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_TEXT_BASE=0x21000000 CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_TAURUS=y +CONFIG_AT91_GPIO_PULLUP=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 0d7352cc4e45..57cc21764a64 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_TEXT_BASE=0x72000000 CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_TARGET_CORVUS=y +CONFIG_AT91_GPIO_PULLUP=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index c44714f4a38f..28ed4ae837db 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_TARGET_GURNARD=y +CONFIG_AT91_GPIO_PULLUP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 64a77b0ddaeb..f39d08371644 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_TEXT_BASE=0x23000000 CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SMARTWEB=y +CONFIG_AT91_GPIO_PULLUP=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index c2049153275b..69b73c982104 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_TARGET_SNAPPER9260=y +CONFIG_AT91_GPIO_PULLUP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index f18ead2f4080..13c4ebe803ad 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_TARGET_SNAPPER9260=y +CONFIG_AT91_GPIO_PULLUP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index c68945d4b7ec..0b25c3dac1de 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_TEXT_BASE=0x21000000 CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_TAURUS=y +CONFIG_AT91_GPIO_PULLUP=y CONFIG_BOARD_TAURUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 4c25c906e811..c08ef567ed48 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -31,7 +31,6 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ #define CONFIG_USART_BASE ATMEL_BASE_DBGU diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 8fb29b0babac..15b7727be0b0 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -74,7 +74,6 @@
/* serial console */ #define CONFIG_USART_BASE ATMEL_BASE_DBGU diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 686134409572..bf14bd498939 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -54,7 +54,6 @@
/* GPIOs and IO expander */ #define CONFIG_ATMEL_LEGACY -#define CONFIG_AT91_GPIO_PULLUP 1 #define CONFIG_PCA953X #define CONFIG_SYS_I2C_PCA953X_ADDR 0x28 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x28, 16} } diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index 069f4c2d2494..f79e421c2612 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -50,7 +50,6 @@
/* UARTs/Serial console */
diff --git a/include/configs/taurus.h b/include/configs/taurus.h index e4609b5c8971..92e691c1222d 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -36,7 +36,6 @@
#define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS
This converts the following to Kconfig: CONFIG_ATMEL_LEGACY
Cc: Eugen Hristev eugen.hristev@microchip.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-at91/Kconfig | 3 +++ configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + configs/at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 1 + configs/corvus_defconfig | 1 + configs/gardena-smart-gateway-at91sam_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/sam9x60ek_mmc_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sam9x60ek_qspiflash_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/taurus_defconfig | 1 + include/configs/at91sam9260ek.h | 3 --- include/configs/at91sam9261ek.h | 2 -- include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 3 --- include/configs/at91sam9rlek.h | 2 -- include/configs/at91sam9x5ek.h | 1 - include/configs/corvus.h | 5 ----- include/configs/gardena-smart-gateway-at91sam.h | 3 --- include/configs/pm9g45.h | 3 --- include/configs/sam9x60ek.h | 3 --- include/configs/smartweb.h | 3 --- include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 3 --- include/configs/taurus.h | 3 --- 58 files changed, 46 insertions(+), 36 deletions(-)
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 79fe87ca58e0..fc193b935e85 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -315,6 +315,9 @@ config AT91_GPIO_PULLUP bool "Keep pullups on peripheral pins" depends on CPU_ARM926EJS
+config ATMEL_LEGACY + bool "Legacy GPIO support" + source "board/atmel/at91sam9260ek/Kconfig" source "board/atmel/at91sam9261ek/Kconfig" source "board/atmel/at91sam9263ek/Kconfig" diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 15866a8ebbda..05bbbe539662 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index ade828e48617..09956bf75296 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index caa9699425bb..d87cb22138e7 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 1bfd11f92fb8..0f31c1180650 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9261EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index ed6621438abe..c51f5c2db1bc 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9261EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 8e1bbb0441a3..f8690f93c520 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9261EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 641d91ef7e11..080a38b053b9 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9263EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 641d91ef7e11..080a38b053b9 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9263EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index a705e45636b8..27c17146cec1 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9263EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index aeb189d2b7df..9644ada94f25 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x0000000 CONFIG_SYS_MALLOC_LEN=0x50000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9263EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_SECT_SIZE=0x10000 diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index a424dd7fa740..a66318dda463 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_SYS_MALLOC_LEN=0x50000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9263EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_SECT_SIZE=0x10000 diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index a84736277d83..a1e07304f970 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9G10=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index baff817cfaf2..008faccf02a5 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9G10=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 9cdf3a2ee008..14d7861a4923 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9261EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9G10=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 665dfc8c7890..bb1908e580f2 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x23000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_AT91SAM9G20EK_2MMC=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 37a420edb71e..95da2ca6ab34 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_AT91SAM9G20EK_2MMC=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 48de0be95dc2..d8531a8af753 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index dfc756a0e723..27bdb1eb9e98 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index ddd64d31ff33..c273357e600d 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index ea7b07dec89d..b57ff0e74636 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_SYS_MALLOC_LEN=0x2c000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9M10G45EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4000 CONFIG_DM_GPIO=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index c242c5cc7485..99540f84f54f 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9M10G45EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 713dbb3621cb..861724f82ce1 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9RLEK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 74e96b95f7e3..6b6ee626b34b 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_SYS_MALLOC_LEN=0x2c000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9RLEK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4000 CONFIG_DM_GPIO=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index d1c888bf3864..f77dafe61a76 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21F00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9RLEK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9rlek" diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 923ed9a56d4a..f3c763756770 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_SYS_MALLOC_LEN=0x81000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index b23c4b61ed62..5922f6c0f510 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_SYS_MALLOC_LEN=0x81000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4000 CONFIG_DM_GPIO=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index edb16c90d0cb..91a654d25891 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_SYS_MALLOC_LEN=0x81000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 781a85421e94..59b010d0d858 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_SYS_MALLOC_LEN=0x81000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x3000 CONFIG_ENV_OFFSET=0x5000 diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 15866a8ebbda..05bbbe539662 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index ade828e48617..09956bf75296 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x2d000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x4200 diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index caa9699425bb..d87cb22138e7 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_AT91SAM9260EK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index b6b4104d243f..3373e6291eaf 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_TAURUS=y CONFIG_AT91_GPIO_PULLUP=y +CONFIG_ATMEL_LEGACY=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 57cc21764a64..c7a59c75cc19 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_TARGET_CORVUS=y CONFIG_AT91_GPIO_PULLUP=y +CONFIG_ATMEL_LEGACY=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 97ed6709b3f0..450ff86a370b 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x22900000 CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_GARDENA_SMART_GATEWAY_AT91SAM=y +CONFIG_ATMEL_LEGACY=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 28ed4ae837db..5414f1095668 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_TARGET_GURNARD=y CONFIG_AT91_GPIO_PULLUP=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 96bd30cfa202..fc5ae69c19ae 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_PM9G45=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" diff --git a/configs/sam9x60ek_mmc_defconfig b/configs/sam9x60ek_mmc_defconfig index 25181d7f0009..238397f0ac9d 100644 --- a/configs/sam9x60ek_mmc_defconfig +++ b/configs/sam9x60ek_mmc_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x23f00000 CONFIG_SYS_MALLOC_LEN=0x81000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_TARGET_SAM9X60EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SIZE=0x4000 CONFIG_DM_GPIO=y diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index a786f5a1ea0a..0d3e9d03880d 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x23f00000 CONFIG_SYS_MALLOC_LEN=0x81000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_TARGET_SAM9X60EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=8 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sam9x60ek" diff --git a/configs/sam9x60ek_qspiflash_defconfig b/configs/sam9x60ek_qspiflash_defconfig index bc30c4ced8f1..b0f74e61c35b 100644 --- a/configs/sam9x60ek_qspiflash_defconfig +++ b/configs/sam9x60ek_qspiflash_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x23f00000 CONFIG_SYS_MALLOC_LEN=0x81000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_TARGET_SAM9X60EK=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DM_GPIO=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index f39d08371644..ecd689f6bf46 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SMARTWEB=y CONFIG_AT91_GPIO_PULLUP=y +CONFIG_ATMEL_LEGACY=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index 69b73c982104..51bf0448b3a4 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_TARGET_SNAPPER9260=y CONFIG_AT91_GPIO_PULLUP=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 13c4ebe803ad..38c10c8ea954 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_TARGET_SNAPPER9260=y CONFIG_AT91_GPIO_PULLUP=y +CONFIG_ATMEL_LEGACY=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 0b25c3dac1de..e7b661776799 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_MALLOC_LEN=0x460000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_TAURUS=y CONFIG_AT91_GPIO_PULLUP=y +CONFIG_ATMEL_LEGACY=y CONFIG_BOARD_TAURUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index f5eeed8c179f..4252a8ce3795 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -27,9 +27,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* main clock xtal */
-/* general purpose I/O */ -#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - /* * SDRAM: 1 bank, min 32, max 128 MB * Initialized before u-boot gets started. diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 347e255bfb0a..fefdb8370927 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -16,8 +16,6 @@
-#define CONFIG_ATMEL_LEGACY - /* * Hardware drivers */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index f523d4761bc8..b084f96afd86 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -30,7 +30,6 @@ /* * Hardware drivers */ -#define CONFIG_ATMEL_LEGACY
/* LCD */ #define LCD_BPP LCD_COLOR8 diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 31e075350fd4..0f5d991022c9 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -10,14 +10,11 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - /* ARM asynchronous clock */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */
/* LCD */ #define LCD_BPP LCD_COLOR8 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 5bc47d6442f9..89cfcbd9517f 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -16,8 +16,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* main clock xtal */
-#define CONFIG_ATMEL_LEGACY - /* * Hardware drivers */ diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 47c55ba4a0f1..c813136dbec6 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */
/* * define CONFIG_USB_EHCI_HCD to enable USB Hi-Speed (aka 2.0) diff --git a/include/configs/corvus.h b/include/configs/corvus.h index c08ef567ed48..caadf6462614 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -23,15 +23,10 @@ * hex number here! */
-/* general purpose I/O */ -#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - /* serial console */ #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 9d96dfcc31e4..5e6a8ee770e0 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -17,9 +17,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */
-/* general purpose I/O */ -#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - /* SDRAM */ #define CONFIG_SYS_SDRAM_BASE 0x20000000 #define CONFIG_SYS_SDRAM_SIZE 0x08000000 /* 128 megs */ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 48b6e1c077f3..61a7c6255fed 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -19,9 +19,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */
-/* general purpose I/O */ -#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - /* SDRAM */ #define CONFIG_SYS_SDRAM_BASE 0x70000000 #define CONFIG_SYS_SDRAM_SIZE 0x08000000 diff --git a/include/configs/sam9x60ek.h b/include/configs/sam9x60ek.h index 7716ac27fb90..772805d6242f 100644 --- a/include/configs/sam9x60ek.h +++ b/include/configs/sam9x60ek.h @@ -17,9 +17,6 @@ #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID 0 /* ignored in arm */
-/* general purpose I/O */ -#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - /* * define CONFIG_USB_EHCI_HCD to enable USB Hi-Speed (aka 2.0) * NB: in this case, USB 1.1 devices won't be recognized. diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 15b7727be0b0..259c05df5534 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -72,9 +72,6 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13
-/* general purpose I/O */ -#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - /* serial console */ #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index bf14bd498939..028c6234a073 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -53,7 +53,6 @@ #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2
/* GPIOs and IO expander */ -#define CONFIG_ATMEL_LEGACY #define CONFIG_PCA953X #define CONFIG_SYS_I2C_PCA953X_ADDR 0x28 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x28, 16} } diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index f79e421c2612..55e51b4b469d 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -48,9 +48,6 @@ #define CONFIG_ATMEL_LCD #define CONFIG_GURNARD_SPLASH
-/* GPIOs and IO expander */ -#define CONFIG_ATMEL_LEGACY - /* UARTs/Serial console */
/* Boot options */ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 92e691c1222d..4ea3607116e1 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -34,9 +34,6 @@
-/* general purpose I/O */ -#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ - #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS
On Fri, Mar 11, 2022 at 11:07:29PM -0500, Tom Rini wrote:
This converts the following to Kconfig: CONFIG_AM335X_USB0 CONFIG_AM335X_USB0_MODE CONFIG_AM335X_USB1 CONFIG_AM335X_USB1_MODE
We do this by introducing specific options for static configuration of USB0/USB1 in SPL rather than defining CONFIG_AM335X_USBx_MODE to the enum value being used. Furthermore, with how the code is used now we do not need to have OTG mode exposed as an option here, so remove that.
