[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 0764f24ae6bc937e358990c357f7452b4d5351e3:
net: Move CONFIG_RTL8169 to Kconfig (2016-03-22 12:19:53 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to ed2530d0963196a7175058ed9b5e6cbc29822f7f:
armv8/ls2080ardb: Enable VID support (2016-03-29 08:46:24 -0700)
---------------------------------------------------------------- Mingkai Hu (2): armv8: fsl-layerscape: Fix LS1043A SVR register armv8: fsl-layerscape: Add LS1023A SVR
Prabhakar Kushwaha (2): driver: net: fsl-mc: Free dflt_dpio pointer after its usage driver: net: fsl-mc: Check NULL before pointer dereference
Qianyu Gong (3): armv8/ls1043a: Update env settings for booting kernel armv8: fsl-layerscape: Skip reconfigure QSPI clock when booting from QSPI armv8/ls1043aqds: dts: Set SPI mode for DSPI
Rai Harninder (1): armv8/ls2080ardb: Enable VID support
Saksham Jain (14): armv8: ls2080: Add SFP Configs for LS2080 armv8: ls2080: Add configs for SEC, SecMon, SRK and DCFG armv8: fsl-lsch3: Add new header for secure boot armv8: ls2080rdb: ls2080qds: Add secure boot support armv8: ls2080: Add bootscript header addr for secure boot armv8: fsl-lsch3: Copy Bootscript and header from NOR to DDR armv8: ls2080: Change env variable "fdt_high" armv8: ls2080: Add config for endianess of CCSR GUR armv8: fsl-lsch3: Disable SMMU during secure boot crypto/fsl: Correct 64-bit write when MMU disabled crypto/fsl: Make CAAM transactions cacheable SECURE_BOOT: Use default bootargs SECURE BOOT: Halt execution when secure boot fail SECURE BOOT: Change fsl_secboot_validate func to pass image addr
Stuart Yoder (1): armv8: ls2080a: Update fdt path for fsl-mc node
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 20 +++++- arch/arm/dts/fsl-ls1043a-qds.dtsi | 8 ++- arch/arm/include/asm/arch-fsl-layerscape/config.h | 18 ++++++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 1 + .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 32 ++++++++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 3 +- arch/arm/include/asm/fsl_secure_boot.h | 50 +++++++++++++-- board/freescale/common/cmd_esbc_validate.c | 14 +++- board/freescale/common/fsl_validate.c | 66 ++++++++++++++----- board/freescale/common/vid.c | 15 ++++- board/freescale/ls2080a/ls2080a.c | 6 +- board/freescale/ls2080aqds/MAINTAINERS | 6 ++ board/freescale/ls2080aqds/ls2080aqds.c | 9 ++- board/freescale/ls2080ardb/MAINTAINERS | 6 ++ board/freescale/ls2080ardb/ls2080ardb.c | 18 +++++- configs/ls2080aqds_SECURE_BOOT_defconfig | 20 ++++++ configs/ls2080ardb_SECURE_BOOT_defconfig | 20 ++++++ configs/ls2085aqds_SECURE_BOOT_defconfig | 20 ++++++ configs/ls2085ardb_SECURE_BOOT_defconfig | 20 ++++++ drivers/crypto/fsl/desc_constr.h | 7 +- drivers/crypto/fsl/jr.c | 13 ++++ drivers/crypto/fsl/jr.h | 3 + drivers/net/fsl-mc/dpio/qbman_sys.h | 2 +- drivers/net/fsl-mc/mc.c | 2 +- include/config_fsl_chain_trust.h | 25 +++++--- include/configs/ls1043a_common.h | 8 +-- include/configs/ls2080aqds.h | 2 + include/configs/ls2080ardb.h | 18 ++++++ include/fsl_secboot_err.h | 3 + include/fsl_sfp.h | 3 +- include/fsl_validate.h | 67 +++++++++++++++++--- 31 files changed, 440 insertions(+), 65 deletions(-) create mode 100644 configs/ls2080aqds_SECURE_BOOT_defconfig create mode 100644 configs/ls2080ardb_SECURE_BOOT_defconfig create mode 100644 configs/ls2085aqds_SECURE_BOOT_defconfig create mode 100644 configs/ls2085ardb_SECURE_BOOT_defconfig
Thanks.
York
On Tue, Mar 29, 2016 at 09:06:20AM -0700, York Sun wrote:
Tom,
York Sun
