[U-Boot-Users] [PATCH 0/3] rtl8139.c related issues
These patches fixes a tx timeout problem, and adds two improvements. Lucas posted the similar patch around Oct 2007, but that was not checked in at that time. This is the try #2. Please review, and if possible give it a try.
Thanks,
Shinya
"to = (currticks() + RTL_TIMEOUT)" has possibilities to wrap around. If it does, the condition "(currticks() < to)" becomes invalid and immediately leads to tx timeout error. This patch introduces the fine-graded udely(10) loops to ease the impact of wrapping around.
Signed-off-by: Shinya Kuribayashi shinya.kuribayashi@necel.com Cc: Masami Komiya mkomiya@sonare.it Cc: Lucas Jin lucasjin@gmail.com ---
drivers/net/rtl8139.c | 17 +++++++---------- 1 files changed, 7 insertions(+), 10 deletions(-)
diff --git a/drivers/net/rtl8139.c b/drivers/net/rtl8139.c index 4c24805..5d7ae74 100644 --- a/drivers/net/rtl8139.c +++ b/drivers/net/rtl8139.c @@ -80,10 +80,7 @@ #if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) && \ defined(CONFIG_RTL8139)
-#define TICKS_PER_SEC CFG_HZ -#define TICKS_PER_MS (TICKS_PER_SEC/1000) - -#define RTL_TIMEOUT (1*TICKS_PER_SEC) +#define RTL_TIMEOUT 100000
#define ETH_FRAME_LEN 1514 #define ETH_ALEN 6 @@ -414,9 +411,10 @@ static void rtl_reset(struct eth_device *dev)
static int rtl_transmit(struct eth_device *dev, volatile void *packet, int length) { - unsigned int status, to; + unsigned int status; unsigned long txstatus; unsigned int len = length; + int i = 0;
ioaddr = dev->iobase;
@@ -436,8 +434,6 @@ static int rtl_transmit(struct eth_device *dev, volatile void *packet, int lengt outl(((TX_FIFO_THRESH<<11) & 0x003f0000) | len, ioaddr + TxStatus0 + cur_tx*4);
- to = currticks() + RTL_TIMEOUT; - do { status = inw(ioaddr + IntrStatus); /* Only acknlowledge interrupt sources we can properly handle @@ -445,7 +441,8 @@ static int rtl_transmit(struct eth_device *dev, volatile void *packet, int lengt * rtl_poll() function. */ outw(status & (TxOK | TxErr | PCIErr), ioaddr + IntrStatus); if ((status & (TxOK | TxErr | PCIErr)) != 0) break; - } while (currticks() < to); + udelay(10); + } while (i++ < RTL_TIMEOUT);
txstatus = inl(ioaddr + TxStatus0 + cur_tx*4);
@@ -458,8 +455,8 @@ static int rtl_transmit(struct eth_device *dev, volatile void *packet, int lengt return length; } else { #ifdef DEBUG_TX - printf("tx timeout/error (%d ticks), status %hX txstatus %X\n", - currticks()-to, status, txstatus); + printf("tx timeout/error (%d usecs), status %hX txstatus %X\n", + 10*i, status, txstatus); #endif rtl_reset(dev);
Current driver is meant for cache coherent systems. This patch adds flush_cache() routines to support cache non-coherent systems.
drivers/net/rtl8139.c | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/drivers/net/rtl8139.c b/drivers/net/rtl8139.c index 5d7ae74..014f3b4 100644 --- a/drivers/net/rtl8139.c +++ b/drivers/net/rtl8139.c @@ -389,6 +389,7 @@ static void rtl_reset(struct eth_device *dev) #ifdef DEBUG_RX printf("rx ring address is %X\n",(unsigned long)rx_ring); #endif + flush_cache((unsigned long)rx_ring, RX_BUF_LEN); outl(phys_to_bus((int)rx_ring), ioaddr + RxBuf);
/* If we add multicast support, the MAR0 register would have to be @@ -430,6 +431,7 @@ static int rtl_transmit(struct eth_device *dev, volatile void *packet, int lengt tx_buffer[len++] = '\0'; }
+ flush_cache((unsigned long)tx_buffer, length); outl(phys_to_bus((int)tx_buffer), ioaddr + TxAddr0 + cur_tx*4); outl(((TX_FIFO_THRESH<<11) & 0x003f0000) | len, ioaddr + TxStatus0 + cur_tx*4); @@ -486,7 +488,8 @@ static int rtl_poll(struct eth_device *dev) #endif
ring_offs = cur_rx % RX_BUF_LEN; - rx_status = *(unsigned int*)KSEG1ADDR((rx_ring + ring_offs)); + /* ring_offs is guaranteed being 4-byte aligned */ + rx_status = *(unsigned int *)(rx_ring + ring_offs); rx_size = rx_status >> 16; rx_status &= 0xffff;
@@ -516,6 +519,7 @@ static int rtl_poll(struct eth_device *dev) printf("rx packet %d bytes", rx_size-4); #endif } + flush_cache((unsigned long)rx_ring, RX_BUF_LEN);
cur_rx = (cur_rx + rx_size + 4 + 3) & ~3; outw(cur_rx - 16, ioaddr + RxBufPtr);
rx_status on the memory is basically in LE, but needs to be handled in CPU endian. le32_to_cpu() takes up this mission. Even if on the sane hardware, it'll work fine.
drivers/net/rtl8139.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/net/rtl8139.c b/drivers/net/rtl8139.c index 014f3b4..097f684 100644 --- a/drivers/net/rtl8139.c +++ b/drivers/net/rtl8139.c @@ -489,7 +489,7 @@ static int rtl_poll(struct eth_device *dev)
ring_offs = cur_rx % RX_BUF_LEN; /* ring_offs is guaranteed being 4-byte aligned */ - rx_status = *(unsigned int *)(rx_ring + ring_offs); + rx_status = le32_to_cpu(*(unsigned int *)(rx_ring + ring_offs)); rx_size = rx_status >> 16; rx_status &= 0xffff;
Shinya Kuribayashi
