[U-Boot] [PATCH v3 1/1] MX5:MX53: add initial support for MX53EVK board
Add initial support for MX53EVK board support. FEC, SD/MMC, UART, I2C, have been support.
Signed-off-by: Jason Liu r64343@freescale.com
--- Changes for v2: -Address the comments from Stefano, Albert and Wolfgang, -remove the ivt.S file and use imximage.cfg instead, -remove the ivt link to u-boot -Address the comments from Stefano, -Correct the copyright issue, -Use mxc_get_gpio() and mxc_set_gpio() accessors. -Get rid of system_rev, -use i2c enumeration value (0,1,..N) instead of BASE address, -use fsl_pmic i2c interface, -Add comments for why manage the pmic in a different way for TO2 -Remove the comments from configs/mx53evk.h, - /* - * Disabled for now due to build problems under Debian and a significant - * increase in the final file size: 144260 vs. 109536 Bytes. - */ -Address the comments from Wolfgang, -Move CONFIG_SYS_TEXT_BASE to board config file, -Remove the comments from configs/mx53evk.h - /* size in bytes reserved for initial data */ #define BOARD_LATE_INIT -Change the comments, * Hardware drivers to * UART drivers Changes for v3: - put uart and fec iomux setting to board_early_init_f so that uart can print out the early information such as uboot banner and cpuinfo etc. --- MAINTAINERS | 3 + board/freescale/mx53evk/Makefile | 48 +++++ board/freescale/mx53evk/mx53evk.c | 398 +++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/mx53evk.h | 217 ++++++++++++++++++++ 5 files changed, 667 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 0590ad9..c87ca56 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1085,6 +1085,9 @@ Peter Meerwald devel@bct-electronic.com
bct-brettl2 BF536
+Jason Liu r64343@freescale.com + + MX53evk i.MX53 ######################################################################### # End of MAINTAINERS list # ######################################################################### diff --git a/board/freescale/mx53evk/Makefile b/board/freescale/mx53evk/Makefile new file mode 100755 index 0000000..6b820f4 --- /dev/null +++ b/board/freescale/mx53evk/Makefile @@ -0,0 +1,48 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2010 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := mx53evk.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c new file mode 100755 index 0000000..e8fe6b2 --- /dev/null +++ b/board/freescale/mx53evk/mx53evk.c @@ -0,0 +1,398 @@ +/* + * (C) Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx5x_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <asm/errno.h> +#include <netdev.h> +#include <i2c.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <fsl_pmic.h> +#include <mxc_gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int dram_init(void) +{ + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + PHYS_SDRAM_1_SIZE); + return 0; +} + +static void setup_iomux_uart(void) +{ + /* UART1 RXD */ + mxc_request_iomux(MX53_PIN_CSI0_D11, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX53_PIN_CSI0_D11, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + mxc_iomux_set_input(MX53_UART1_IPP_UART_RXD_MUX_SELECT_INPUT, 0x1); + + /* UART1 TXD */ + mxc_request_iomux(MX53_PIN_CSI0_D10, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX53_PIN_CSI0_D10, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU | + PAD_CTL_ODE_OPENDRAIN_ENABLE); +} + +#ifdef CONFIG_I2C_MXC +static void setup_i2c(unsigned int port_number) +{ + switch (port_number) { + case 0: + /* i2c1 SDA */ + mxc_request_iomux(MX53_PIN_CSI0_D8, + IOMUX_CONFIG_ALT5 | IOMUX_CONFIG_SION); + mxc_iomux_set_input(MX53_I2C1_IPP_SDA_IN_SELECT_INPUT, + INPUT_CTL_PATH0); + mxc_iomux_set_pad(MX53_PIN_CSI0_D8, + PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH | + PAD_CTL_100K_PU | PAD_CTL_HYS_ENABLE | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + /* i2c1 SCL */ + mxc_request_iomux(MX53_PIN_CSI0_D9, + IOMUX_CONFIG_ALT5 | IOMUX_CONFIG_SION); + mxc_iomux_set_input(MX53_I2C1_IPP_SCL_IN_SELECT_INPUT, + INPUT_CTL_PATH0); + mxc_iomux_set_pad(MX53_PIN_CSI0_D9, + PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH | + PAD_CTL_100K_PU | PAD_CTL_HYS_ENABLE | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + break; + case 1: + /* i2c2 SDA */ + mxc_request_iomux(MX53_PIN_KEY_ROW3, + IOMUX_CONFIG_ALT4 | IOMUX_CONFIG_SION); + mxc_iomux_set_input(MX53_I2C2_IPP_SDA_IN_SELECT_INPUT, + INPUT_CTL_PATH0); + mxc_iomux_set_pad(MX53_PIN_KEY_ROW3, + PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH | + PAD_CTL_100K_PU | PAD_CTL_HYS_ENABLE | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + + /* i2c2 SCL */ + mxc_request_iomux(MX53_PIN_KEY_COL3, + IOMUX_CONFIG_ALT4 | IOMUX_CONFIG_SION); + mxc_iomux_set_input(MX53_I2C2_IPP_SCL_IN_SELECT_INPUT, + INPUT_CTL_PATH0); + mxc_iomux_set_pad(MX53_PIN_KEY_COL3, + PAD_CTL_SRE_FAST | PAD_CTL_DRV_HIGH | + PAD_CTL_100K_PU | PAD_CTL_HYS_ENABLE | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + break; + default: + printf("Warning: Wrong I2C port number\n"); + break; + } +} + +void power_init(void) +{ + unsigned int val; + + /* Set VDDA to 1.25V */ + val = pmic_reg_read(REG_SW_2); + val = (val & (~0x1F)) | 0x1A; + pmic_reg_write(REG_SW_2, val); + + /* + * Need increase VCC and VDDA to 1.3V + * according to MX53 IC TO2 datasheet. + */ + if (is_soc_rev(CHIP_REV_2_0) == 0) { + /* Set VCC to 1.3V for TO2 */ + val = pmic_reg_read(REG_SW_1); + val = (val & (~0x1F)) | 0x1C; + pmic_reg_write(REG_SW_2, val); + + /* Set VDDA to 1.3V for TO2 */ + val = pmic_reg_read(REG_SW_2); + val = (val & (~0x1F)) | 0x1C; + pmic_reg_write(REG_SW_2, val); + } +} +#endif + +static void setup_iomux_fec(void) +{ + /*FEC_MDIO*/ + mxc_request_iomux(MX53_PIN_FEC_MDIO, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_MDIO, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_22K_PU | PAD_CTL_ODE_OPENDRAIN_ENABLE); + mxc_iomux_set_input(MX53_FEC_FEC_MDI_SELECT_INPUT, 0x1); + + /*FEC_MDC*/ + mxc_request_iomux(MX53_PIN_FEC_MDC, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_MDC, PAD_CTL_DRV_HIGH); + + /* FEC RXD1 */ + mxc_request_iomux(MX53_PIN_FEC_RXD1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RXD1, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC RXD0 */ + mxc_request_iomux(MX53_PIN_FEC_RXD0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RXD0, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC TXD1 */ + mxc_request_iomux(MX53_PIN_FEC_TXD1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TXD1, PAD_CTL_DRV_HIGH); + + /* FEC TXD0 */ + mxc_request_iomux(MX53_PIN_FEC_TXD0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TXD0, PAD_CTL_DRV_HIGH); + + /* FEC TX_EN */ + mxc_request_iomux(MX53_PIN_FEC_TX_EN, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TX_EN, PAD_CTL_DRV_HIGH); + + /* FEC TX_CLK */ + mxc_request_iomux(MX53_PIN_FEC_REF_CLK, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_REF_CLK, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC RX_ER */ + mxc_request_iomux(MX53_PIN_FEC_RX_ER, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RX_ER, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC CRS */ + mxc_request_iomux(MX53_PIN_FEC_CRS_DV, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_CRS_DV, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); +} + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg esdhc_cfg[2] = { + {MMC_SDHC1_BASE_ADDR, 1}, + {MMC_SDHC3_BASE_ADDR, 1}, +}; + +int board_mmc_getcd(u8 *cd, struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + + if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) + *cd = mxc_gpio_get(77); /*GPIO3_13*/ + else + *cd = mxc_gpio_get(75); /*GPIO3_11*/ + + return 0; +} + +int board_mmc_init(bd_t *bis) +{ + u32 index; + s32 status = 0; + + for (index = 0; index < CONFIG_SYS_FSL_ESDHC_NUM; index++) { + switch (index) { + case 0: + mxc_request_iomux(MX53_PIN_SD1_CMD, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_CLK, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA0, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA1, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA2, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA3, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_EIM_DA13, + IOMUX_CONFIG_ALT1); + + mxc_iomux_set_pad(MX53_PIN_SD1_CMD, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_CLK, + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_DRV_HIGH); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA0, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA1, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA2, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA3, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + break; + case 1: + mxc_request_iomux(MX53_PIN_ATA_RESET_B, + IOMUX_CONFIG_ALT2); + mxc_request_iomux(MX53_PIN_ATA_IORDY, + IOMUX_CONFIG_ALT2); + mxc_request_iomux(MX53_PIN_ATA_DATA8, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA9, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA10, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA11, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA0, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA1, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA2, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA3, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_EIM_DA11, + IOMUX_CONFIG_ALT1); + + mxc_iomux_set_pad(MX53_PIN_ATA_RESET_B, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_IORDY, + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_DRV_HIGH); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA8, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA9, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA10, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA11, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA0, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA1, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA2, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA3, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + + break; + default: + printf("Warning: you configured more ESDHC controller" + "(%d) as supported by the board(2)\n", + CONFIG_SYS_FSL_ESDHC_NUM); + return status; + } + status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); + } + + return status; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + setup_iomux_fec(); + + return 0; +} + +int board_init(void) +{ + gd->bd->bi_arch_number = MACH_TYPE_MX53_EVK; + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +#ifdef BOARD_LATE_INIT +int board_late_init(void) +{ +#ifdef CONFIG_I2C_MXC + setup_i2c(1); + power_init(); +#endif + return 0; +} +#endif + +int checkboard(void) +{ + u32 cause; + struct src *src_regs = (struct src *)SRC_BASE_ADDR; + + puts("Board: MX53EVK ["); + + cause = src_regs->srsr; + switch (cause) { + case 0x0001: + printf("POR"); + break; + case 0x0009: + printf("RST"); + break; + case 0x0010: + case 0x0011: + printf("WDOG"); + break; + default: + printf("unknown"); + } + printf("]\n"); + return 0; +} diff --git a/boards.cfg b/boards.cfg index dcd5a12..736e88e 100644 --- a/boards.cfg +++ b/boards.cfg @@ -101,6 +101,7 @@ omap5912osk arm arm926ejs - ti edminiv2 arm arm926ejs - LaCie orion5x ca9x4_ct_vxp arm armv7 vexpress armltd mx51evk arm armv7 mx51evk freescale mx5 +mx53evk arm armv7 mx53evk freescale mx5 vision2 arm armv7 vision2 ttcontrol mx5 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3 diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h new file mode 100755 index 0000000..d6cf04e --- /dev/null +++ b/include/configs/mx53evk.h @@ -0,0 +1,217 @@ +/* + * Copyright (C) 2010 Freescale Semiconductor, Inc. + * + * Configuration settings for the MX53-EVK Freescale board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + + /* High Level Configuration Options */ + +#define CONFIG_MX53 + +#define CONFIG_SYS_MX5_HCLK 24000000 +#define CONFIG_SYS_MX5_CLK32 32768 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_L2_OFF + +#include <asm/arch/imx-regs.h> + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_REVISION_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F +#define BOARD_LATE_INIT +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_SYS_MX53_UART1 + +/* + * I2C Configs + */ +#define CONFIG_CMD_I2C 1 +#define CONFIG_HARD_I2C 1 +#define CONFIG_I2C_MXC 1 +#define CONFIG_SYS_I2C_MX53_PORT2 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0xfe + +/* + * PMIC Configs + */ +#define CONFIG_FSL_PMIC +#define CONFIG_FSL_PMIC_I2C +#define CONFIG_SYS_FSL_PMIC_I2C_ADDR 8 + +/* + * MMC Configs + */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_ESDHC_NUM 2 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* + * Eth Configs + */ +#define CONFIG_HAS_ETH1 +#define CONFIG_NET_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY + +#define CONFIG_FEC_MXC +#define IMX_FEC_BASE FEC_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1F + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/*********************************************************** + * Command definition + ***********************************************************/ + +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_PRIME "FEC0" + +#define CONFIG_LOADADDR 0x70800000 /* loadaddr env var */ +#define CONFIG_SYS_TEXT_BASE 0x77800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "mmcargs=setenv bootargs console=ttymxc0,${baudrate} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm\0" \ + "netargs=setenv bootargs console=ttymxc0,${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmc rescan ${mmcdev}; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +#define CONFIG_ARP_TIMEOUT 200UL + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "MX53EVK U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0x70000000 +#define CONFIG_SYS_MEMTEST_END 0x10000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_CMDLINE_EDITING + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024) + +#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) +#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#endif /* __CONFIG_H */
Jason Liu
