[PATCH v2 0/2] riscv: Support booting SiFive Unmatched from SPI flash.
This patch set adds support for booting the SiFive Unmatched board from SPI flash memory and saving the environment to flash.
Thomas Skibo (2): riscv: Support booting SiFive Unmatched from SPI. riscv: Enable SPI flash env for SiFive Unmatched.
arch/riscv/cpu/fu740/Kconfig | 13 +++++++++ .../dts/hifive-unmatched-a00-u-boot.dtsi | 11 +++++++ board/sifive/unmatched/Kconfig | 1 + board/sifive/unmatched/spl.c | 3 ++ configs/sifive_unmatched_defconfig | 6 ++++ doc/board/sifive/unmatched.rst | 29 +++++++++++++++++++ 6 files changed, 63 insertions(+)
Configure SPI flash devices into SPL. Add SPI boot option to spl.c. Document how to format flash for booting.
Signed-off-by: Thomas Skibo thomas-git@skibo.net --- .../dts/hifive-unmatched-a00-u-boot.dtsi | 11 +++++++ board/sifive/unmatched/spl.c | 3 ++ configs/sifive_unmatched_defconfig | 6 ++++ doc/board/sifive/unmatched.rst | 29 +++++++++++++++++++ 4 files changed, 49 insertions(+)
diff --git a/arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi index c5475aa149..1ee8ab1868 100644 --- a/arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unmatched-a00-u-boot.dtsi @@ -16,6 +16,10 @@ u-boot,dm-spl; };
+ config { + u-boot,spl-payload-offset = <0x105000>; /* loader2 @1044KB */ + }; + hfclk { u-boot,dm-spl; }; @@ -30,6 +34,13 @@ clocks = <&rtcclk>; };
+&qspi0 { + u-boot,dm-spl; + flash@0 { + u-boot,dm-spl; + }; +}; + &spi0 { mmc@0 { u-boot,dm-spl; diff --git a/board/sifive/unmatched/spl.c b/board/sifive/unmatched/spl.c index d5663274cd..7c0beedc08 100644 --- a/board/sifive/unmatched/spl.c +++ b/board/sifive/unmatched/spl.c @@ -22,6 +22,7 @@ #define GEM_PHY_RESET SIFIVE_GENERIC_GPIO_NR(0, 12)
#define MODE_SELECT_REG 0x1000 +#define MODE_SELECT_SPI 0x6 #define MODE_SELECT_SD 0xb #define MODE_SELECT_MASK GENMASK(3, 0)
@@ -123,6 +124,8 @@ u32 spl_boot_device(void) u32 boot_device = mode_select & MODE_SELECT_MASK;
switch (boot_device) { + case MODE_SELECT_SPI: + return BOOT_DEVICE_SPI; case MODE_SELECT_SD: return BOOT_DEVICE_MMC1; default: diff --git a/configs/sifive_unmatched_defconfig b/configs/sifive_unmatched_defconfig index 9cc18b029c..d400ed0b23 100644 --- a/configs/sifive_unmatched_defconfig +++ b/configs/sifive_unmatched_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="hifive-unmatched-a00" CONFIG_SPL_MMC=y CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_AHCI=y CONFIG_TARGET_SIFIVE_UNMATCHED=y @@ -23,17 +24,22 @@ CONFIG_DISPLAY_BOARDINFO=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ID_EEPROM=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_DM_RESET=y +CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_PWM=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=1 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y CONFIG_SPL_CLK=y +CONFIG_SPI_FLASH_ISSI=y CONFIG_SYS_I2C_EEPROM_ADDR=0x54 CONFIG_E1000=y CONFIG_NVME=y diff --git a/doc/board/sifive/unmatched.rst b/doc/board/sifive/unmatched.rst index 6b024f07f6..387785d76b 100644 --- a/doc/board/sifive/unmatched.rst +++ b/doc/board/sifive/unmatched.rst @@ -534,3 +534,32 @@ Sample boot log from HiFive Unmatched board OpenEmbedded nodistro.0 unmatched ttySIF0
unmatched login: + + +Booting from SPI +---------------- + +Use Building steps from "Booting from uSD using U-Boot SPL" section. + +Partition the SPI in Linux via mtdblock. + +.. code-block:: none + + sgdisk --clear -a 1 \ + --new=1:40:2087 --change-name=1:spl --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ + --new=2:2088:10279 --change-name=2:uboot --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ + --new=3:10280:10535 --change-name=3:env --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ + /dev/mtdblock0 + +Write U-boot SPL and U-boot to their partitions. + +.. code-block:: none + + dd if=u-boot-spl.bin of=/dev/mtdblock0 bs=4096 seek=5 conv=sync + dd if=u-boot.itb of=/dev/mtdblock0 bs=4096 seek=261 conv=sync + +Power off the board. + +Change DIP switches MSEL[3:0] to 0110. + +Power up the board.
- config {
- hfclk { u-boot,dm-spl; };
+&qspi0 {
- u-boot,dm-spl;
- flash@0 {
u-boot,dm-spl;
- &spi0 { mmc@0 { u-boot,dm-spl;
- case MODE_SELECT_SPI:
case MODE_SELECT_SD: return BOOT_DEVICE_MMC1; default:return BOOT_DEVICE_SPI;
unmatched login:
- sgdisk --clear -a 1 \
nit: Please use hexcodes as printed with sgdisk -L. And also document what the type is. Documentation is for us humans after all :)
--Sean
/dev/mtdblock0
- dd if=u-boot-spl.bin of=/dev/mtdblock0 bs=4096 seek=5 conv=sync
- dd if=u-boot.itb of=/dev/mtdblock0 bs=4096 seek=261 conv=sync
--Sean
The first two partitions' typecodes are unique to the SiFive chip so they don't have a short hexcode. The third partition, storage for the environment, is hexcode 8300 which is a Linux filesystem. I wonder if there is better partition type for the environment.
I can change the typecode for the third partition and add a note about what the other partitions are.
-Thomas
--Sean
That's correct. The 1st two are SiFive boards specific. From util-linux:
/* HiFive bootloaders */ DEF_GUID("5B193300-FC78-40CD-8002-E86C45580B47", N_("HiFive FSBL")), DEF_GUID("2E54B353-1271-4842-806F-E436D6AF6985", N_("HiFive BBL")),
Shouldn't this be?
"u-boot-env" = PARTITION_U_BOOT_ENVIRONMENT (3DE21764-95BD-54BD-A5C3-4ABE786F38A8)
Taken from doc/README.gpt
See: https://github.com/u-boot/u-boot/commit/c0364ce1c6957c5295e933b95802e6966e00...
david
-Thomas
Enable saving environment to SPI flash memory on SiFive Unmatched.
Signed-off-by: Thomas Skibo thomas-git@skibo.net --- arch/riscv/cpu/fu740/Kconfig | 13 +++++++++++++ board/sifive/unmatched/Kconfig | 1 + 2 files changed, 14 insertions(+)
diff --git a/arch/riscv/cpu/fu740/Kconfig b/arch/riscv/cpu/fu740/Kconfig index 049a0a0584..3e0c1fddc8 100644 --- a/arch/riscv/cpu/fu740/Kconfig +++ b/arch/riscv/cpu/fu740/Kconfig @@ -40,3 +40,16 @@ config SIFIVE_FU740 imply DM_I2C imply SYS_I2C_OCORES imply SPL_I2C + +if ENV_IS_IN_SPI_FLASH + +config ENV_OFFSET + default 0x505000 + +config ENV_SIZE + default 0x20000 + +config ENV_SECT_SIZE + default 0x10000 + +endif # ENV_IS_IN_SPI_FLASH diff --git a/board/sifive/unmatched/Kconfig b/board/sifive/unmatched/Kconfig index fb2c1fbb58..fe213fd504 100644 --- a/board/sifive/unmatched/Kconfig +++ b/board/sifive/unmatched/Kconfig @@ -26,6 +26,7 @@ config SPL_OPENSBI_LOAD_ADDR config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select SIFIVE_FU740 + select ENV_IS_IN_SPI_FLASH select SUPPORT_SPL select RESET_SIFIVE select BINMAN
David Abdurachmanov
Sean Anderson
Thomas Skibo
