[U-Boot] mpc83xx: SICRL #defines
Kim,
This is defined this way:
#define SICRL_USBDR 0x00000C00
However in order to actually set these pins to the USB_DR functionality the setting should be 0x00000800. So it appears that these (#define SICRL_*) are all masks. Each field seems to be two bits and therefore 4 possible settings.
So, should they all be used as masks, should this be changed, or should we create new '#define's for the different functionalities? I need to make a change to my config file and I thought I'd get your opinion before I submitted a patch; I can make any suggested changes with my change at the same time.
Thanks,
Ron
On Fri, 28 May 2010 16:44:21 -0700 Ron Madrid ron_madrid@sbcglobal.net wrote:
Kim,
It looks like the pin functions wouldn't be able to be efficiently named in a uniform fashion - I'd be ok with just introducing the four new defines SICRL_USBDR_00, SICRL_USBDR_01, and so on.
Kim
Kim Phillips
Ron Madrid
