This serials patches add mipi dsi support for rk3399. Except the basic mipi driver, we need also enable pmic rk808 for lcd power and enable i2c for rk808 communication. what's more, the needed clk and pwm for backlight is init in spl stage, make sure spl work first.
Eric Gao (3): rockchip: video: Add mipi dsi driver rockchip: Add dts config for mipi dsi rockchip: Enable mipi dsi configs
eric.gao (2): rockchip: i2c: enable i2c for rk3399 rockchip: pmic: Enable RK808 for rk3399 evb
arch/arm/dts/rk3399-evb.dts | 123 ++++++ arch/arm/dts/rk3399.dtsi | 88 +++++ arch/arm/include/asm/arch-rockchip/cru_rk3399.h | 1 + arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 25 ++ arch/arm/include/asm/arch-rockchip/mipi_rk3399.h | 189 +++++++++ arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 1 + configs/evb-rk3399_defconfig | 12 + drivers/i2c/rk_i2c.c | 1 + drivers/video/Kconfig | 2 + drivers/video/rockchip/Kconfig | 47 +++ drivers/video/rockchip/Makefile | 6 +- drivers/video/rockchip/rk_mipi.c | 465 +++++++++++++++++++++++ drivers/video/rockchip/rk_vop.c | 39 +- 13 files changed, 992 insertions(+), 7 deletions(-) create mode 100644 arch/arm/include/asm/arch-rockchip/mipi_rk3399.h create mode 100644 drivers/video/rockchip/Kconfig create mode 100644 drivers/video/rockchip/rk_mipi.c
To enable mipi display, we need to enable pmic rk808 first for lcd3v3 power,which use i2c0 to communicate with soc. So enable i2c0.
Signed-off-by: eric.gao eric.gao@rock-chips.com
Signed-off-by: Eric Gao eric.gao@rock-chips.com ---
arch/arm/dts/rk3399.dtsi | 16 ++++++++++++++++ configs/evb-rk3399_defconfig | 1 + drivers/i2c/rk_i2c.c | 1 + 3 files changed, 18 insertions(+)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 456fdb6..93e3bf4 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -26,6 +26,7 @@ serial4 = &uart4; mmc0 = &sdhci; mmc1 = &sdmmc; + i2c0 = &i2c0; };
cpus { @@ -651,6 +652,21 @@ status = "disabled"; };
+ i2c0: i2c@ff3c0000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff3c0000 0x0 0x1000>; + assigned-clocks = <&pmucru SCLK_I2C0_PMU>; + assigned-clock-rates = <200000000>; + clocks = <&pmucru SCLK_I2C0_PMU>, <&pmucru PCLK_I2C0_PMU>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + pinctrl: pinctrl { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pinctrl"; diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index bedc1fd..2e2f9a8 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -58,3 +58,4 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y CONFIG_USE_TINY_PRINTF=y CONFIG_ERRNO_STR=y +CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/drivers/i2c/rk_i2c.c b/drivers/i2c/rk_i2c.c index 7c701cb..a4c8c2ba 100644 --- a/drivers/i2c/rk_i2c.c +++ b/drivers/i2c/rk_i2c.c @@ -381,6 +381,7 @@ static const struct dm_i2c_ops rockchip_i2c_ops = {
static const struct udevice_id rockchip_i2c_ids[] = { { .compatible = "rockchip,rk3288-i2c" }, + { .compatible = "rockchip,rk3399-i2c" }, { } };
Hello Eric,
Am 08.04.2017 um 14:22 schrieb Eric Gao:
Why you have 2 "Signed-off-by" lines?
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Dear all,
I am very very sorry. Because I used patman tool to send the patches , which use "send-email" by default.
but "send-email" combine “263.com smtp server” will always encounter problem. It‘s show as that when the
patch's quantity more than 3, patches can not be send completely(log said: session count exceed limit).
I have ever tried many times and get the same result. Finally, I changed to use msmtp, it can works
well. So, forget all these incomplete junk email and refer to the latest one please. Sorry to bother all your guys.
Many Thanks.
On 2017年04月10日 11:55, Heiko Schocher wrote:
Hello Eric,
bye, Heiko
Eric
Eric Gao
Heiko Schocher
