[PATCH] common: console: Fix print complete stdio device list
In case CONSOLE_MUX and SYS_CONSOLE_IS_IN_ENV are on and stdin or stdout or stderr are missing in environment, as fallback, get these either from stdio_devices[std] or stdio_devices[std]->name.
Fixes: 6b343ab38d ("console: Print out complete stdio device list")
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
common/console.c | 23 +++++++++++------------ 1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/common/console.c b/common/console.c index cad65891fc9..8bfcfce5643 100644 --- a/common/console.c +++ b/common/console.c @@ -1049,6 +1049,11 @@ int console_clear(void) return 0; }
+static char *get_stdio(const u8 std) +{ + return stdio_devices[std] ? stdio_devices[std]->name : "No devices available!"; +} + static void stdio_print_current_devices(void) { char *stdinname, *stdoutname, *stderrname; @@ -1060,19 +1065,13 @@ static void stdio_print_current_devices(void) stdoutname = env_get("stdout"); stderrname = env_get("stderr");
- stdinname = stdinname ? : "No input devices available!"; - stdoutname = stdoutname ? : "No output devices available!"; - stderrname = stderrname ? : "No error devices available!"; + stdinname = stdinname ? : get_stdio(stdin); + stdoutname = stdoutname ? : get_stdio(stdout); + stderrname = stderrname ? : get_stdio(stderr); } else { - stdinname = stdio_devices[stdin] ? - stdio_devices[stdin]->name : - "No input devices available!"; - stdoutname = stdio_devices[stdout] ? - stdio_devices[stdout]->name : - "No output devices available!"; - stderrname = stdio_devices[stderr] ? - stdio_devices[stderr]->name : - "No error devices available!"; + stdinname = get_stdio(stdin); + stdoutname = get_stdio(stdout); + stderrname = get_stdio(stderr); }
/* Print information */
On Wed, Jan 17, 2024 at 12:13 AM Patrice Chotard patrice.chotard@foss.st.com wrote:
stderrname = get_stdio(stderr); } /* Print information */
This can be further simplified to:
char *stdinname = NULL; char *stdoutname = NULL; char *stderrname NULL;
if (CONFIG_IS_ENABLED(CONSOLE_MUX) && CONFIG_IS_ENABLED(SYS_CONSOLE_IS_IN_ENV)) { /* stdin stdout and stderr are in environment */ stdinname = env_get("stdin"); stdoutname = env_get("stdout"); stderrname = env_get("stderr"); }
stdinname = stdinname ? : get_stdio(stdin); stdoutname = stdoutname ? : get_stdio(stdout); stderrname = stderrname ? : get_stdio(stderr);
Regards, Bin
Regards, Bin
Right, i will send a v2 Thanks
Patrice
Bin Meng
Patrice CHOTARD
Patrice Chotard
