[U-Boot] [PATCH PATCH v1] watchdog: Fix Watchdog Reset while in U-Boot Prompt
Hardware: CM-FX6 Module from Compulab
This patch fixes unwanted watchdog resets while the user enters a command at the U-Boot prompt.
As found on the CM-FX6 board from Compulab, when having enabled the watchdog, a missing WATCHDOG_RESET call in common/console.c causes this and alike boards to reset when the watchdog's timeout has elapsed while waiting at the U-Boot prompt.
Despite the user could press several keys within the watchdog timeout limit, the while loop in cli_readline.c, line 261, does only call WATCHDOG_RESET if first == 1, which gets set to 0 in the 1st loop iteration. This leads to a watchdog timeout no matter if the user presses keys or not.
Although, this affects other boards as well as it touches common/console.c, the macro WATCHDOG_RESET expands to {} if watchdog support isn't configured. Hence, there's no harm caused and no need to surround it by #ifdef in this case.
* Symptom: U-Boot resets after watchdog times out when in commandline prompt and watchdog is enabled.
* Reasoning: When U-Boot shows the commandline prompt, the following function call stack is executed while waiting for a keypress:
common/main.c: main_loop => common/cli.c: cli_loop() => common/cli_hush.c: parse_file_outer => parse_stream_outer => parse_stream => b_getch(i) => i->get(i) => file_get => get_user_input => cmdedit_read_input => uboot_cli_readline => common/cli_readline.c: cli_readline => cli_readline_into_buffer => cread_line => getcmd_getch (== getc) => common/console.c: fgetc => console_tstc
common/console.c: (with CONFIG_CONSOLE_MUX is set)
- in console_tstc line 181: If dev->tstc(dev) returns 0, the global tstcdev variable doesn't get set. This is the case if no character is in the serial buffer.
- in fgetc(int file), line 297: Program flow keeps looping because tstcdev does not get set. Therefore WATCHDOG_RESET is not called, as mx_serial_tstc from drivers/serial/serial_mxc.c does not call it.
* Solution: Add WATCHDOG_RESET into the loop of console_tstc.
Note: Macro expands to {} if not configured, so no #ifdef is needed.
* Comment:
Signed-off-by: Christian Storm christian.storm@tngtech.com Signed-off-by: Jan Kiszka jan.kiszka@siemens.com Signed-off-by: Andreas J. Reichel Andreas.Reichel@tngtech.com ---
common/console.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/common/console.c b/common/console.c index 12293f3..054b6cd 100644 --- a/common/console.c +++ b/common/console.c @@ -16,6 +16,7 @@ #include <stdio_dev.h> #include <exports.h> #include <environment.h> +#include <watchdog.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -294,6 +295,7 @@ int fgetc(int file) * Effectively poll for input wherever it may be available. */ for (;;) { + WATCHDOG_RESET(); /* * Upper layer may have already called tstc() so * check for that first.
On 13 July 2016 at 04:56, Andreas J. Reichel Andreas.Reichel@tngtech.com wrote:
Comment:
Thanks for the detailed info.
Would it be better to put this in _serial_tstc()?
-- 2.8.2
As found on the CM-FX6 board from Compulab, when having enabled the watchdog, a missing WATCHDOG_RESET call in _serial_tstc() in (/drivers/serial/serial-uclass.c) causes this and alike boards to reset when the watchdog's timeout has elapsed while waiting at the U-Boot prompt.
The problem is solved with a call to WATCHDOG_RESET in _serial_tstc, defined in drivers/serial/serial-uclass.c.
Since the macro WATCHDOG_RESET expands to {} if watchdog support isn't configured, there's no need to surround it by #ifdef in this case.
common/main.c: main_loop => common/cli.c: cli_loop() => common/cli_hush.c: parse_file_outer => parse_stream_outer => parse_stream => b_getch(i) => i->get(i) => file_get => get_user_input => cmdedit_read_input => uboot_cli_readline => common/cli_readline.c: cli_readline => cli_readline_into_buffer => cread_line => getcmd_getch (== getc) => commonn/console.c: fgetc => console_tstc
- Initialization calls drv_system_init in stdio.c, which sets dev.tstc = stdio_serial_tstc. Thus, dev->tstc(dev) calls serial_tstc() which in turn calls _serial_tstc().
Hence, _serial_tstc() needs to call WATCHDOG_RESET() to periodically reset the watchdog while cli_readline waits for user input.
Changes in v2: - Move WATCHDOG_RESET() call from common/console.c to drivers/serial/serial-uclass.c.
drivers/serial/serial-uclass.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 0ce5c44..72cf808 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -155,6 +155,7 @@ static int _serial_tstc(struct udevice *dev) { struct dm_serial_ops *ops = serial_get_ops(dev);
+ WATCHDOG_RESET(); if (ops->pending) return ops->pending(dev, true);
+Tom, in case this should go into the release.
On 1 August 2016 at 05:49, Andreas J. Reichel Andreas.Reichel@tngtech.com wrote:
Changes in v2:
Great explanation, thank you.
-- 2.8.2
Hi Tom,
is my patch going to be applied or is the problem resolved otherwhise?
Kind regards Andreas
Changes in v2:
-- 2.8.2
On Mon, Sep 19, 2016 at 01:59:44PM +0200, Andreas Reichel wrote:
Hi Tom,
Sorry, lost in my patchwork queue. I'll pick this up soon now.
Changes in v2:
-- 2.8.2
-- Andreas Reichel Dipl.-Phys. (Univ.) Software Consultant
Andreas.Reichel@tngtech.com +49-174-3180074
TNG Technology Consulting GmbH, Betastr. 13a, 85774 Unterföhring Geschäftsführer: Henrik Klagges, Christoph Stock, Dr. Robert Dahlke Sitz: Unterföhring * Amtsgericht München * HRB 135082
Andreas J. Reichel (1): watchdog: Fix Watchdog Reset while in U-Boot Prompt
Comment:
Signed-off-by: Christian Storm christian.storm@tngtech.com Signed-off-by: Jan Kiszka jan.kiszka@siemens.com Signed-off-by: Andreas J. Reichel Andreas.Reichel@tngtech.com Acked-by: Simon Glass sjg@chromium.org
Andreas J. Reichel
Andreas Reichel
