[U-Boot] [PATCH v2] dm: core: Add dev_get_addr_ptr() to return a pointer to the reg address
On some platforms (e.g. x86), the return value of dev_get_addr() can't be assigned to a pointer type variable directly. As there might be a difference between the size of fdt_addr_t and the pointer type. On x86 for example, "fdt_addr_t" is 64bit but "void *" only 32bit. So assigning the register base directly in dev_get_addr() results in this compilation warning: warning: cast to pointer from integer of different size
This patch introduces the new function dev_get_addr_ptr() that returns a pointer to the 'reg' address that can be used by drivers in this case.
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org --- v2: - Mention error condition in function prototype as suggested by Simon
drivers/core/device.c | 5 +++++ include/dm/device.h | 10 ++++++++++ 2 files changed, 15 insertions(+)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 269087a..1322991 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -673,6 +673,11 @@ fdt_addr_t dev_get_addr(struct udevice *dev) return dev_get_addr_index(dev, 0); }
+void *dev_get_addr_ptr(struct udevice *dev) +{ + return (void *)(uintptr_t)dev_get_addr_index(dev, 0); +} + bool device_has_children(struct udevice *dev) { return !list_empty(&dev->child_head); diff --git a/include/dm/device.h b/include/dm/device.h index dad7591..8970fc0 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -454,6 +454,16 @@ int device_find_next_child(struct udevice **devp); fdt_addr_t dev_get_addr(struct udevice *dev);
/** + * dev_get_addr_ptr() - Return pointer to the address of the reg property + * of a device + * + * @dev: Pointer to a device + * + * @return Pointer to addr, or NULL if there is no such property + */ +void *dev_get_addr_ptr(struct udevice *dev); + +/** * dev_get_addr_index() - Get the indexed reg property of a device * * @dev: Pointer to a device
v2:
v2:
Bin Meng
Stefan Roese
