[U-Boot] [PATCH] input: Finish simplifing key_matrix_decode_fdt()
[trini: Applied v1 of the series rather than v2, this commit is the delta from v1 to v2]
Signed-off-by: Stephen Warren swarren@nvidia.com Signed-off-by: Tom Rini trini@ti.com --- drivers/input/key_matrix.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/input/key_matrix.c b/drivers/input/key_matrix.c index ea05c77..c900e45 100644 --- a/drivers/input/key_matrix.c +++ b/drivers/input/key_matrix.c @@ -162,8 +162,10 @@ int key_matrix_decode_fdt(struct key_matrix *config, const void *blob, int node)
prop = fdt_get_property(blob, node, "linux,keymap", &proplen); /* Basic keymap is required */ - if (!prop) + if (!prop) { + debug("%s: cannot find keycode-plain map\n", __func__); return -1; + }
plain_keycode = create_keymap(config, (u32 *)prop->data, proplen, KEY_FN, &config->fn_pos); @@ -180,7 +182,7 @@ int key_matrix_decode_fdt(struct key_matrix *config, const void *blob, int node) config->fn_keycode = create_keymap(config, (u32 *)prop->data, proplen, -1, NULL); /* Conversion error -> fail */ - if (!config->plain_keycode) { + if (!config->fn_keycode) { free(plain_keycode); return -1; }
