[PATCH] arm: mach-k3: security: Lower verbosity of cert message for GP
When we find a certificate on an image to be booted on a GP device we print out a message explaining that the certificate is being skipped. This message is rather long and is printed for every image. Shorten the message and make the long version into a debug message.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/security.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/security.c b/arch/arm/mach-k3/security.c index 22697a263a8..7c46914d9dd 100644 --- a/arch/arm/mach-k3/security.c +++ b/arch/arm/mach-k3/security.c @@ -50,7 +50,7 @@ void ti_secure_image_check_binary(void **p_image, size_t *p_size)
if (get_device_type() == K3_DEVICE_TYPE_GP) { if (ti_secure_cert_detected(*p_image)) { - printf("Warning: Detected image signing certificate on GP device. " + debug("Warning: Detected image signing certificate on GP device. " "Skipping certificate to prevent boot failure. " "This will fail if the image was also encrypted\n");
@@ -60,6 +60,7 @@ void ti_secure_image_check_binary(void **p_image, size_t *p_size) return; }
+ printf("Skipping authentication on GP device\n"); *p_image += cert_length; *p_size -= cert_length; }
Andrew Davis afd@ti.com writes:
}printf("Skipping authentication on GP device\n"); *p_image += cert_length; *p_size -= cert_length;
-- 2.39.2
Would be nice if it only emitted the message once!
Tested-by: Jonathan Humphreys j-humphreys@ti.com
Andrew Davis
Jon Humphreys
