[U-Boot] [PATCH] ARM: pxa: Fix CONFIG_SYS_HZ on PXA
The PXA incorrectly uses CONFIG_SYS_HZ, which should be 1000 across U-Boot. Fix this.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@ti.com Cc: Albert Aribaud albert.u.boot@aribaud.net --- include/configs/balloon3.h | 10 +++++----- include/configs/palmld.h | 10 +++++----- include/configs/palmtc.h | 10 +++++----- include/configs/scb9328.h | 6 +++--- include/configs/zipitz2.h | 10 +++++----- 5 files changed, 23 insertions(+), 23 deletions(-)
diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index cbf2853..d90e29b 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -86,7 +86,7 @@ * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */
/* @@ -129,10 +129,10 @@
#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1
-#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 240000 +#define CONFIG_SYS_FLASH_LOCK_TOUT 240000 +#define CONFIG_SYS_FLASH_UNLOCK_TOUT 240000 #define CONFIG_SYS_FLASH_PROTECTION #define CONFIG_ENV_IS_IN_FLASH #else diff --git a/include/configs/palmld.h b/include/configs/palmld.h index 0302090..9479300 100644 --- a/include/configs/palmld.h +++ b/include/configs/palmld.h @@ -118,7 +118,7 @@ * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x210 /* 416MHz ; N=2,L=16 */
/* @@ -161,10 +161,10 @@
-#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_LOCK_TOUT (25*CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_UNLOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 240000 +#define CONFIG_SYS_FLASH_LOCK_TOUT 240000 +#define CONFIG_SYS_FLASH_UNLOCK_TOUT 240000 #define CONFIG_SYS_FLASH_PROTECTION
#define CONFIG_ENV_IS_IN_FLASH 1 diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h index d838356..05d677b 100644 --- a/include/configs/palmtc.h +++ b/include/configs/palmtc.h @@ -120,7 +120,7 @@ * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */ +#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x161 /* 400MHz;L=1 M=3 T=1 */
/* @@ -158,10 +158,10 @@
#define CONFIG_ENV_IS_IN_FLASH 1 diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index a09310c..c0048ac 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -69,7 +69,7 @@ #define CONFIG_SYS_MEMTEST_START 0x08100000 /* memtest test area */ #define CONFIG_SYS_MEMTEST_END 0x08F00000
-#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ +#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x141 /* core clock - register value */
#define CONFIG_BAUDRATE 115200 @@ -143,8 +143,8 @@ now.*/ #undef CONFIG_SYS_FLASH_CFI
-#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) /* timeout for Erase operation */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) /* timeout for Write operation */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* timeout for Erase operation */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 240000 /* timeout for Write operation */
#define CONFIG_SYS_FLASH_BASE SCB9328_FLASH_BASE
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 69aafa7..5e021a2 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -141,7 +141,7 @@ unsigned char zipitz2_spi_read(void); * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */
/* @@ -188,10 +188,10 @@ unsigned char zipitz2_spi_read(void);
