"mmc: rockchip_sdhci: add phy and clock config for rk3399" broke spl emmc boot
Hi Yifeng,
Since "mmc: rockchip_sdhci: add phy and clock config for rk3399", my RockPi 4b device can't boot off of eMMC. It will start tpl/spl and then fail:
U-Boot TPL 2021.10-rc1-gac804143cf-dirty (Aug 11 2021 - 10:02:07) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM...
U-Boot SPL 2021.10-rc1-gac804143cf-dirty (Aug 11 2021 - 10:02:07 +0000) Trying to boot from MMC1 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
If I revert these changes, all is well:
commit a63a57e59d864a1ca2b0acb5fadc5c3579c3e79c Author: Yifeng Zhao yifeng.zhao@rock-chips.com Date: Tue Jun 29 16:24:42 2021 +0800
mmc: rockchip_sdhci: Add support for RK3568
commit ac804143cfd128d144403ef2434344988c3fde9f (refs/bisect/bad) Author: Yifeng Zhao yifeng.zhao@rock-chips.com Date: Tue Jun 29 16:24:41 2021 +0800
Please let me know if you need help to test this.
Thanks, Alistair.
On 05/11/2021 19:03, Alistair Delva wrote:
Hi Yifeng,
Thanks, Alistair.
Hi Alistair,
You need the following patch:
https://patchwork.ozlabs.org/project/uboot/patch/20211101044347.17822-1-yife...
Please let me know if this fixes the issue for you as some people still have outstanding issues with this set of patches when the emmc is run the HS200/400 modes.
Regards, Jack.
Alistair Delva
Jack Mitchell
