[U-Boot] [PATCH v2 0/2] arm64: dts: sun50i: Add support for A64 OLinuXino (with eMMC)
This is a follow up a patch that didn't create a separate dts: https://lists.denx.de/pipermail/u-boot/2019-July/379109.html
A64 OLinuXino board from Olimex has three variants with onboard eMMC: A64-OLinuXino-1Ge16GW, A64-OLinuXino-1Ge4GW and A64-OLinuXino-2Ge8G-IND. In addition, there are two variants without eMMC. One without eMMC and one with SPI flash. This suggests the need for separate device tree for the three eMMC variants.
The Linux kernel upstream has chosen to create and use a separate device tree for the eMMC variants instead of adding eMMC support existing device tree. These changes to Linux kernel are queued for Linux 5.4.
https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux.git/commit/?h=su...
This patch has been tested on A64-OLinuXino-1Ge16GW and is based on Linux device-tree.
Changes:
v2: Separate device tree for emmc models.
Sunil Mohan Adapa (2): arm64: dts: sun50i: Add support for A64 OLinuXino (with eMMC) configs: sun50i: Add support for Olimex A64-Olinuxino-eMMC
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-olinuxino-emmc.dts | 23 ++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 +++++ configs/a64-olinuxino-emmc_defconfig | 17 ++++++++++++++++ 4 files changed, 46 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-olinuxino-emmc.dts create mode 100644 configs/a64-olinuxino-emmc_defconfig
Signed-off-by: Sunil Mohan Adapa sunil@medhas.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-olinuxino-emmc.dts | 23 ++++++++++++++++++++++ 2 files changed, 24 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-olinuxino-emmc.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 05ff624c07..d28906a63b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -530,6 +530,7 @@ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-nanopi-a64.dtb \ sun50i-a64-oceanic-5205-5inmfd.dtb \ sun50i-a64-olinuxino.dtb \ + sun50i-a64-olinuxino-emmc.dtb \ sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-lts.dtb \ sun50i-a64-pine64-plus.dtb \ diff --git a/arch/arm/dts/sun50i-a64-olinuxino-emmc.dts b/arch/arm/dts/sun50i-a64-olinuxino-emmc.dts new file mode 100644 index 0000000000..96ab0227e8 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-olinuxino-emmc.dts @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Martin Ayotte martinayotte@gmail.com + * Copyright (C) 2019 Sunil Mohan Adapa sunil@medhas.org + */ + +#include "sun50i-a64-olinuxino.dts" + +/ { + model = "Olimex A64-Olinuxino-eMMC"; + compatible = "olimex,a64-olinuxino-emmc", "allwinner,sun50i-a64"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +};
Based on a64-olinuxino_defconfig.
This patch has been tested on A64-OLinuXino-1Ge16GW.
Signed-off-by: Sunil Mohan Adapa sunil@medhas.org --- board/sunxi/MAINTAINERS | 5 +++++ configs/a64-olinuxino-emmc_defconfig | 17 +++++++++++++++++ 2 files changed, 22 insertions(+) create mode 100644 configs/a64-olinuxino-emmc_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index c7e9d3eda0..442ff3d9cd 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -106,6 +106,11 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: configs/a64-olinuxino_defconfig
+A64-OLINUXINO-EMMC BOARD +M: Sunil Mohan Adapa sunil@medhas.org +S: Maintained +F: configs/a64-olinuxino-emmc_defconfig + A80 OPTIMUS BOARD M: Chen-Yu Tsai wens@csie.org S: Maintained diff --git a/configs/a64-olinuxino-emmc_defconfig b/configs/a64-olinuxino-emmc_defconfig new file mode 100644 index 0000000000..56153e38a7 --- /dev/null +++ b/configs/a64-olinuxino-emmc_defconfig @@ -0,0 +1,17 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_USE_PREBOOT=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-olinuxino-emmc" +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
Changes:
Please squash and send it as single patch, all look fine to me.
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
Changes:
Thank you for reviewing the patch. I have posted v3 with the two patches squashed.
Jagan Teki
Sunil Mohan Adapa
