[PATCH v1] arm64: dts: rockchip: Add Radxa ROCK 4C Plus support
rk3399-rock-4c-plus.dts and rk3399-t-opp.dtsi were imported from Linux 6.3.
Signed-off-by: Denis 'GNUtoo' Carikli GNUtoo@cyberdimension.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-rock-4c-plus-u-boot.dtsi | 6 + arch/arm/dts/rk3399-rock-4c-plus.dts | 709 +++++++++++++++++++ arch/arm/dts/rk3399-t-opp.dtsi | 114 +++ board/rockchip/evb_rk3399/MAINTAINERS | 2 + configs/rock-4c-plus-rk3399_defconfig | 97 +++ doc/board/rockchip/rockchip.rst | 1 + 7 files changed, 930 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock-4c-plus-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-rock-4c-plus.dts create mode 100644 arch/arm/dts/rk3399-t-opp.dtsi create mode 100644 configs/rock-4c-plus-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3385948d22..c4db3753bb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -160,6 +160,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-rock-pi-4a.dtb \ rk3399-rock-pi-4b.dtb \ rk3399-rock-pi-4c.dtb \ + rk3399-rock-4c-plus.dtb \ rk3399-rock960.dtb \ rk3399-rockpro64.dtb \ rk3399pro-rock-pi-n10.dtb diff --git a/arch/arm/dts/rk3399-rock-4c-plus-u-boot.dtsi b/arch/arm/dts/rk3399-rock-4c-plus-u-boot.dtsi new file mode 100644 index 0000000000..85ee5770ad --- /dev/null +++ b/arch/arm/dts/rk3399-rock-4c-plus-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-rock-pi-4-u-boot.dtsi" diff --git a/arch/arm/dts/rk3399-rock-4c-plus.dts b/arch/arm/dts/rk3399-rock-4c-plus.dts new file mode 100644 index 0000000000..028eb508ae --- /dev/null +++ b/arch/arm/dts/rk3399-rock-4c-plus.dts @@ -0,0 +1,709 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2019 Radxa Limited + * Copyright (c) 2022 Amarula Solutions(India) + */ + +/dts-v1/; +#include <dt-bindings/leds/common.h> +#include "rk3399.dtsi" +#include "rk3399-t-opp.dtsi" + +/ { + model = "Radxa ROCK 4C+"; + compatible = "radxa,rock-4c-plus", "rockchip,rk3399"; + + aliases { + mmc0 = &sdhci; + mmc1 = &sdmmc; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&user_led1 &user_led2>; + + /* USER_LED1 */ + led-0 { + function = LED_FUNCTION_POWER; + color = <LED_COLOR_ID_GREEN>; + gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_LOW>; + linux,default-trigger = "default-on"; + }; + + /* USER_LED2 */ + led-1 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_BLUE>; + gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk809 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + vcc_3v3: vcc-3v3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc3v3_phy1: vcc3v3-phy1-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_phy1"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_3v3>; + }; + + vcc5v0_host1: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host1"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_host0_s0>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_typec: vcc5v0-typec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_typec0_en>; + regulator-name = "vcc5v0_typec"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; + + vdd_log: vdd-log-regulator { + compatible = "regulator-fixed"; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <950000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc3v3_phy1>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x2a>; + rx_delay = <0x21>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + avdd-0v9-supply = <&vcc_0v9_s0>; + avdd-1v8-supply = <&vcc_1v8_s0>; + ddc-i2c-bus = <&i2c3>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; + status = "okay"; +}; + +&hdmi_sound { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + i2c-scl-falling-time-ns = <30>; + i2c-scl-rising-time-ns = <180>; + clock-frequency = <400000>; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PC5 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rk808-clkout1", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc_buck5_s3>; + vcc6-supply = <&vcc_buck5_s3>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc5v0_sys>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-initial-mode = <0x2>; + regulator-name = "vdd_center"; + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-initial-mode = <0x2>; + regulator-name = "vdd_cpu_l"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_ddr"; + regulator-initial-mode = <0x2>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_sys: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-initial-mode = <0x2>; + regulator-name = "vcc3v3_sys"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_buck5_s3: DCDC_REG5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_buck5_s3"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_0v9_s3: LDO_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vcc_0v9_s3"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8_s3"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_0v9_s0: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vcc_0v9_s0"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vcc_1v8_s0: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8_s0"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_mipi: LDO_REG5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc_mipi"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5_s0: LDO_REG6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc_1v5_s0"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0_s0: LDO_REG7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc_3v0_s0"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_sdio_s0: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_sdio_s0"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_cam: LDO_REG9 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_cam"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc5v0_host0_s0: SWITCH_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc5v0_host0_s0"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + lcd_3v3: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-name = "lcd_3v3"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-compatible = "fan53555-reg"; + pinctrl-0 = <&vsel1_gpio>; + vsel-gpios = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-compatible = "fan53555-reg"; + pinctrl-0 = <&vsel2_gpio>; + vsel-gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_HIGH>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + regulator-initial-mode = <1>; /* 1:force PWM 2:auto */ + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2s2 { + status = "okay"; +}; + +&io_domains { + audio-supply = <&vcc_1v8_s0>; + bt656-supply = <&vcc_3v0_s0>; + gpio1830-supply = <&vcc_3v0_s0>; + sdmmc-supply = <&vcc_sdio_s0>; + status = "okay"; +}; + +&pinctrl { + bt { + bt_enable_h: bt-enable-h { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_l: bt-wake-l { + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + leds { + user_led1: user-led1 { + rockchip,pins = <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + user_led2: user-led2 { + rockchip,pins = <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vsel1_gpio: vsel1-gpio { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_gpio: vsel2-gpio { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sdmmc { + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <4 8 1 &pcfg_pull_up_8ma>, + <4 9 1 &pcfg_pull_up_8ma>, + <4 10 1 &pcfg_pull_up_8ma>, + <4 11 1 &pcfg_pull_up_8ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <4 12 1 &pcfg_pull_none_18ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <4 13 1 &pcfg_pull_up_8ma>; + }; + }; + + usb-typec { + vcc5v0_typec0_en: vcc5v0-typec-en { + rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb2 { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + wifi { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wifi_host_wake_l: wifi-host-wake-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_3v0_s0>; + status = "okay"; +}; + +&saradc { + status = "okay"; + vref-supply = <&vcc_1v8_s3>; +}; + +&sdhci { + max-frequency = <150000000>; + bus-width = <8>; + mmc-hs400-1_8v; + non-removable; + mmc-hs400-enhanced-strobe; + status = "okay"; +}; + +&sdio0 { + #address-cells = <1>; + #size-cells = <0>; + bus-width = <4>; + clock-frequency = <50000000>; + cap-sdio-irq; + cap-sd-highspeed; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; + + brcmf: wifi@1 { + compatible = "brcm,bcm4329-fmac"; + reg = <1>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "host-wake"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_host_wake_l>; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <800>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + vqmmc-supply = <&vcc_sdio_s0>; + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host1>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host1>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm4345c5"; + clocks = <&rk809 1>; + clock-names = "lpo"; + device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; + max-speed = <1500000>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; + vbat-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8_s3>; + }; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + extcon = <&u2phy0>; + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; + dr_mode = "host"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3399-t-opp.dtsi b/arch/arm/dts/rk3399-t-opp.dtsi new file mode 100644 index 0000000000..1ababadda9 --- /dev/null +++ b/arch/arm/dts/rk3399-t-opp.dtsi @@ -0,0 +1,114 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2022 Radxa Limited + */ + +/ { + cluster0_opp: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared; + + opp00 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <875000 875000 1250000>; + clock-latency-ns = <40000>; + }; + opp01 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <875000 875000 1250000>; + }; + opp02 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <900000 900000 1250000>; + }; + opp03 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <975000 975000 1250000>; + }; + }; + + cluster1_opp: opp-table-1 { + compatible = "operating-points-v2"; + opp-shared; + + opp00 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <875000 875000 1250000>; + clock-latency-ns = <40000>; + }; + opp01 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <875000 875000 1250000>; + }; + opp02 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <875000 875000 1250000>; + }; + opp03 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <925000 925000 1250000>; + }; + opp04 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1000000 1000000 1250000>; + }; + opp05 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1075000 1075000 1250000>; + }; + opp06 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <1150000 1150000 1250000>; + }; + }; + + gpu_opp_table: opp-table-2 { + compatible = "operating-points-v2"; + + opp00 { + opp-hz = /bits/ 64 <200000000>; + opp-microvolt = <875000 875000 1150000>; + }; + opp01 { + opp-hz = /bits/ 64 <300000000>; + opp-microvolt = <875000 875000 1150000>; + }; + opp02 { + opp-hz = /bits/ 64 <400000000>; + opp-microvolt = <875000 875000 1150000>; + }; + opp03 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <975000 975000 1150000>; + }; + }; +}; + +&cpu_l0 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l1 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l2 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l3 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_b0 { + operating-points-v2 = <&cluster1_opp>; +}; + +&cpu_b1 { + operating-points-v2 = <&cluster1_opp>; +}; + +&gpu { + operating-points-v2 = <&gpu_opp_table>; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index 5be58f80f9..4bfc25fae0 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -88,6 +88,8 @@ F: configs/rock-pi-4-rk3399_defconfig F: arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi F: configs/rock-pi-4c-rk3399_defconfig F: arch/arm/dts/rk3399-rock-pi-4c-u-boot.dtsi +F: configs/rock-4c-plus-rk3399_defconfig +F: arch/arm/dts/rk3399-rock-pi-4c-u-boot.dtsi
ROCK-PI-N10 M: Jagan Teki jagan@amarulasolutions.com diff --git a/configs/rock-4c-plus-rk3399_defconfig b/configs/rock-4c-plus-rk3399_defconfig new file mode 100644 index 0000000000..97693166d9 --- /dev/null +++ b/configs/rock-4c-plus-rk3399_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00200000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-4c-plus" +CONFIG_DM_RESET=y +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_EVB_RK3399=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-4c-plus.dtb" +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x400000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DFU_MMC=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_EFUSE=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCI=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_FUNCTION_ROCKUSB=y +CONFIG_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 1dccb17d72..3b6f1aad8f 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -84,6 +84,7 @@ List of mainline supported Rockchip boards: - Orange Pi RK3399 (orangepi-rk3399) - Pine64 RockPro64 (rockpro64-rk3399) - Radxa ROCK Pi 4 (rock-pi-4-rk3399) + - Radxa ROCK Pi Plus (rk3399-rock-4c-plus) - Rockchip Evb-RK3399 (evb_rk3399) - Theobroma Systems RK3399-Q7 SoM - Puma (puma_rk3399)
base-commit: c9c2c95d4cd27fe0cd41fe13a863899d268f973c
