[U-Boot] [PATCH v2] ARM: UniPhier: drop special CONFIG_AUTOBOOT_ settings
There is no good reason to use a particular key to stop autobooting. The default allows us to stop the autoboot with any key input.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Rebase on commit 7853d76b0
configs/ph1_ld4_defconfig | 4 ---- configs/ph1_pro4_defconfig | 4 ---- configs/ph1_sld8_defconfig | 4 ---- 3 files changed, 12 deletions(-)
diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 650201a..a71511c 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -7,10 +7,6 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-ld4-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_NAND=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 7d8d9cc..d02712e 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -6,10 +6,6 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-pro4-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_NAND=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index 90c44ac..ee4cebc 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -7,10 +7,6 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-sld8-ref" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_NAND=y
2015-06-30 17:10 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Changes in v2:
Applied to u-boot/master.
2015-07-02 1:12 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Changes in v2:
No, applied to u-boot-uniphier/master.
Masahiro Yamada
