[U-Boot-Users] [PATCH] v3 tftp: don't implicity trust the format of recevied packets
The TFTP OACK code trusts that the incoming packet is formated as ASCII text and can be processed by string functions. It also as a loop limit overflow bug where if the packet length is less than 8, it ends up looping over *all* of memory to find the 'blksize' string. This occurs because 'len' is an unsigned value, and 'len-8' is also calculated as unsigned which results in a huge loop limit.
This patch solves the problem by using memmem() to search for the sub string.
Signed-off-by: Grant Likely grant.likely@secretlab.ca --- Third version; this one makes sure simple_strtoul() doesn't run off the end of the buffer. Tested in my environment, but needs testing by others
net/tftp.c | 24 ++++++++++++++---------- 1 files changed, 14 insertions(+), 10 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index fb2f505..460bfa0 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -238,9 +238,9 @@ TftpSend (void) static void TftpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) { + void * blksize; ushort proto; ushort *s; - int i;
if (dest != TftpOurPort) { #ifdef CONFIG_MCAST_TFTP @@ -272,22 +272,26 @@ TftpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len)
case TFTP_OACK: #ifdef ET_DEBUG - printf("Got OACK: %s %s\n", pkt, pkt+strlen(pkt)+1); + printf("Got OACK:\n"); + print_buffer (0, pkt, 1, len, 16); #endif TftpState = STATE_OACK; TftpServerPort = src; - /* Check for 'blksize' option */ - for (i=0;i<len-8;i++) { - if (strcmp ((char*)pkt+i,"blksize") == 0) { - TftpBlkSize = (unsigned short) - simple_strtoul((char*)pkt+i+8,NULL,10); + + /* Search for the 'blksize' option */ + blksize = memmem(pkt, len, "blksize", 8); /* str + '\0' */ + if (blksize) { + blksize += 8; /* safe: "blksize\0" is inside pkt */ + + /* does blksize point at a terminated string? */ + if (memchr(pkt, '\0', (void*)pkt - blksize)) { + TftpBlkSize = simple_strtoul(blksize, NULL, 10); #ifdef ET_DEBUG - printf ("Blocksize ack: %s, %d\n", - (char*)pkt+i+8,TftpBlkSize); + printf("Blocksize ack: %d\n", TftpBlkSize); #endif - break; } } + #ifdef CONFIG_MCAST_TFTP parse_multicast_oack((char *)pkt,len-1); if ((Multicast) && (!MasterClient))
Grant Likely
