[U-Boot] [PATCH 0/6] Add support for Panasonic UniPhier SoCs/boards
UniPhier is the SoC family developed by Panasonic Corporation, based on ARM Cortex-A9.
This patch set adds its SoC/board support code with some drivers.
This series depends on the Denali NAND driver patch: http://patchwork.ozlabs.org/patch/357717/
It must be applied first.
Masahiro Yamada (6): nand: denali: add Denali NAND driver for SPL serial: add UniPhier serial driver arm: uniphier: add UniPhier SoC suppurt code arm: uniphier: add UniPhier config headers arm: uniphier: add board entries to boards.cfg git-mailrc: add me as the maintainer of UniPhier SoCs
arch/arm/cpu/armv7/uniphier/Makefile | 23 + arch/arm/cpu/armv7/uniphier/board_common.c | 32 + arch/arm/cpu/armv7/uniphier/board_late_init.c | 37 + arch/arm/cpu/armv7/uniphier/cache_uniphier.c | 154 +++ arch/arm/cpu/armv7/uniphier/cmd_pinmon.c | 33 + arch/arm/cpu/armv7/uniphier/cpu_info.c | 59 ++ arch/arm/cpu/armv7/uniphier/dram_init.c | 37 + arch/arm/cpu/armv7/uniphier/init_page_table.c | 1068 ++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/lowlevel_init.S | 159 +++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c | 33 + arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c | 16 + .../armv7/uniphier/ph1-ld4/board_postclk_init.c | 42 + arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c | 63 ++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c | 189 ++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c | 44 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c | 16 + .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 39 + arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c | 66 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c | 45 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c | 168 +++ .../arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c | 18 + arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 75 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c | 16 + .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c | 57 ++ arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c | 201 ++++ .../arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c | 51 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/reset.c | 29 + arch/arm/cpu/armv7/uniphier/smp.S | 54 + arch/arm/cpu/armv7/uniphier/spl.c | 17 + arch/arm/cpu/armv7/uniphier/support_card.c | 180 ++++ arch/arm/cpu/armv7/uniphier/timer.c | 39 + arch/arm/include/asm/arch-uniphier/arm-mpcore.h | 46 + arch/arm/include/asm/arch-uniphier/bcu-regs.h | 29 + arch/arm/include/asm/arch-uniphier/board.h | 35 + arch/arm/include/asm/arch-uniphier/boot-device.h | 20 + arch/arm/include/asm/arch-uniphier/led.h | 101 ++ arch/arm/include/asm/arch-uniphier/sbc-regs.h | 107 ++ arch/arm/include/asm/arch-uniphier/sc-regs.h | 62 ++ arch/arm/include/asm/arch-uniphier/sg-regs.h | 182 ++++ arch/arm/include/asm/arch-uniphier/ssc-regs.h | 65 ++ boards.cfg | 3 + doc/git-mailrc | 2 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/denali_spl.c | 201 ++++ drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_uniphier.c | 206 ++++ include/configs/ph1_ld4.h | 64 ++ include/configs/ph1_pro4.h | 66 ++ include/configs/ph1_sld8.h | 64 ++ include/configs/uniphier-common.h | 275 +++++ 69 files changed, 4802 insertions(+) create mode 100644 arch/arm/cpu/armv7/uniphier/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/board_common.c create mode 100644 arch/arm/cpu/armv7/uniphier/board_late_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/cache_uniphier.c create mode 100644 arch/arm/cpu/armv7/uniphier/cmd_pinmon.c create mode 100644 arch/arm/cpu/armv7/uniphier/cpu_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/dram_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/init_page_table.c create mode 100644 arch/arm/cpu/armv7/uniphier/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/reset.c create mode 100644 arch/arm/cpu/armv7/uniphier/smp.S create mode 100644 arch/arm/cpu/armv7/uniphier/spl.c create mode 100644 arch/arm/cpu/armv7/uniphier/support_card.c create mode 100644 arch/arm/cpu/armv7/uniphier/timer.c create mode 100644 arch/arm/include/asm/arch-uniphier/arm-mpcore.h create mode 100644 arch/arm/include/asm/arch-uniphier/bcu-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/board.h create mode 100644 arch/arm/include/asm/arch-uniphier/boot-device.h create mode 100644 arch/arm/include/asm/arch-uniphier/led.h create mode 100644 arch/arm/include/asm/arch-uniphier/sbc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sg-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/ssc-regs.h create mode 100644 drivers/mtd/nand/denali_spl.c create mode 100644 drivers/serial/serial_uniphier.c create mode 100644 include/configs/ph1_ld4.h create mode 100644 include/configs/ph1_pro4.h create mode 100644 include/configs/ph1_sld8.h create mode 100644 include/configs/uniphier-common.h
The SPL-mode driver for Denali(Cadence) NAND Flash Memory Controller IP.
This driver requires two CONFIG macros: - CONFIG_NAND_DENALI Define to enable this driver. - CONFIG_SYS_NAND_BAD_BLOCK_POS Specify bad block mark position in the oob space. Typically 0.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Chin Liang See clsee@altera.com Cc: Scott Wood scottwood@freescale.com ---
drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/denali_spl.c | 201 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 202 insertions(+) create mode 100644 drivers/mtd/nand/denali_spl.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index f298f84..052c285 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -66,6 +66,7 @@ obj-$(CONFIG_NAND_DOCG4) += docg4.o
else # minimal SPL drivers
+obj-$(CONFIG_NAND_DENALI) += denali_spl.o obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o obj-$(CONFIG_NAND_MXC) += mxc_nand_spl.o diff --git a/drivers/mtd/nand/denali_spl.c b/drivers/mtd/nand/denali_spl.c new file mode 100644 index 0000000..6eed079 --- /dev/null +++ b/drivers/mtd/nand/denali_spl.c @@ -0,0 +1,201 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include "denali.h" + +#define SPARE_ACCESS 0x41 +#define MAIN_ACCESS 0x42 + +#define BANK(x) ((x) << 24) + +static void __iomem *denali_flash_mem = + (void __iomem *)CONFIG_SYS_NAND_DATA_BASE; +static void __iomem *denali_flash_reg = + (void __iomem *)CONFIG_SYS_NAND_REGS_BASE; + +static const int flash_bank; +static uint8_t page_buffer[NAND_MAX_PAGESIZE]; +static int page_size, oob_size, pages_per_block; + +static void index_addr(uint32_t address, uint32_t data) +{ + writel(address, denali_flash_mem + INDEX_CTRL_REG); + writel(data, denali_flash_mem + INDEX_DATA_REG); +} + +static int wait_for_irq(uint32_t irq_mask) +{ + unsigned long timeout = 1000000; + uint32_t intr_status; + + do { + intr_status = readl(denali_flash_reg + INTR_STATUS(flash_bank)); + + if (intr_status & INTR_STATUS__ECC_UNCOR_ERR) { + debug("Uncorrected ECC detected\n"); + return -EIO; + } + + if (intr_status & irq_mask) + break; + + udelay(1); + timeout--; + } while (timeout); + + if (!timeout) { + debug("Timeout with interrupt status %08x\n", intr_status); + return -EIO; + } + + return 0; +} + +static void read_data_from_flash_mem(uint8_t *buf, int len) +{ + int i; + uint32_t *buf32; + + /* transfer the data from the flash */ + buf32 = (uint32_t *)buf; + for (i = 0; i < len / 4; i++) + *buf32++ = readl(denali_flash_mem + INDEX_DATA_REG); +} + +int denali_send_pipeline_cmd(int page, int ecc_en, int access_type) +{ + uint32_t addr, cmd; + static uint32_t page_count = 1; + + writel(ecc_en, denali_flash_reg + ECC_ENABLE); + + /* clear all bits of intr_status. */ + writel(0xffff, denali_flash_reg + INTR_STATUS(flash_bank)); + + addr = BANK(flash_bank) | page; + + /* setup the acccess type */ + cmd = MODE_10 | addr; + index_addr(cmd, access_type); + + /* setup the pipeline command */ + index_addr(cmd, 0x2000 | page_count); + + cmd = MODE_01 | addr; + writel(cmd, denali_flash_mem + INDEX_CTRL_REG); + + return wait_for_irq(INTR_STATUS__LOAD_COMP); +} + +static int nand_read_oob(void *buf, int page) +{ + int ret; + + ret = denali_send_pipeline_cmd(page, 0, SPARE_ACCESS); + if (ret < 0) + return ret; + + read_data_from_flash_mem(buf, oob_size); + + return 0; +} + +static int nand_read_page(void *buf, int page) +{ + int ret; + + ret = denali_send_pipeline_cmd(page, 1, MAIN_ACCESS); + if (ret < 0) + return ret; + + read_data_from_flash_mem(buf, page_size); + + return 0; +} + +static int nand_block_isbad(int block) +{ + int ret; + + ret = nand_read_oob(page_buffer, block * pages_per_block); + if (ret < 0) + return ret; + + return page_buffer[CONFIG_SYS_NAND_BAD_BLOCK_POS] != 0xff; +} + +/* nand_init() - initialize data to make nand usable by SPL */ +void nand_init(void) +{ + /* access to main area */ + writel(0, denali_flash_reg + TRANSFER_SPARE_REG); + + page_size = readl(denali_flash_reg + DEVICE_MAIN_AREA_SIZE); + oob_size = readl(denali_flash_reg + DEVICE_SPARE_AREA_SIZE); + pages_per_block = readl(denali_flash_reg + PAGES_PER_BLOCK); +} + +int nand_spl_load_image(uint32_t offs, unsigned int size, void *dst) +{ + int block, page, column, readlen; + int ret; + int force_bad_block_check = 1; + + page = offs / page_size; + column = offs % page_size; + + block = page / pages_per_block; + page = page % pages_per_block; + + while (size) { + if (force_bad_block_check || page == 0) { + ret = nand_block_isbad(block); + if (ret < 0) + return ret; + + if (ret) { + block++; + continue; + } + } + + force_bad_block_check = 0; + + if (unlikely(column || size < page_size)) { + /* Partial page read */ + ret = nand_read_page(page_buffer, + block * pages_per_block + page); + if (ret < 0) + return ret; + + readlen = min(page_size - column, size); + memcpy(dst, page_buffer, readlen); + + column = 0; + } else { + ret = nand_read_page(dst, + block * pages_per_block + page); + if (ret < 0) + return ret; + + readlen = page_size; + } + + size -= readlen; + dst += readlen; + page++; + if (page == pages_per_block) { + block++; + page = 0; + } + } + + return 0; +} + +void nand_deselect(void) {}
- int i;
- uint32_t *buf32;
- /* transfer the data from the flash */
- buf32 = (uint32_t *)buf;
- for (i = 0; i < len / 4; i++)
Won't this trigger unaligned access if $buf is not aligned to 4-byte boundary ?
- uint32_t addr, cmd;
- static uint32_t page_count = 1;
- writel(ecc_en, denali_flash_reg + ECC_ENABLE);
- /* clear all bits of intr_status. */
- writel(0xffff, denali_flash_reg + INTR_STATUS(flash_bank));
- addr = BANK(flash_bank) | page;
- /* setup the acccess type */
- cmd = MODE_10 | addr;
- index_addr(cmd, access_type);
- /* setup the pipeline command */
- index_addr(cmd, 0x2000 | page_count);
Magic value 0x2000 should be fixed here.
- cmd = MODE_01 | addr;
- writel(cmd, denali_flash_mem + INDEX_CTRL_REG);
Somehow, eventually, this should be migrated to "struct" based register access instead of such offset computation. If you feel like doing it, that'd be nice ;-)
- return wait_for_irq(INTR_STATUS__LOAD_COMP);
Thanks!
Hi Marek,
- int i;
- uint32_t *buf32;
Thanks for catching this.
Actually, it would seldom happen because the aligned load address is generally given.
But I will add a sanity check here in v2, just in case.
Actually, this part is the same as that of the normal Denali driver by Chin Liang See http://patchwork.ozlabs.org/patch/357717/
Moreover, it is the same as in Linux Kernel.
I understand what you mean, but I guess we can excuse here.
Dito. I am following the coding style of the normal Denali driver and the Linux one.
We might perhaps do that migration as the separated task in future, but not now.
Best Regards Masahiro Yamada
On Thursday, July 10, 2014 at 12:06:20 PM, Masahiro Yamada wrote:
Hi Marek,
Hi!
- int i;
- uint32_t *buf32;
Or just use put_unaligned() ?
OK, I see. Is there any chance to fix this in Linux maybe eventually?
Best regards, Marek Vasut
Hi Marek,
- int i;
- uint32_t *buf32;
Oh, year! put_unaligned() would be better. Thanks!
OK. I will send a patch to linux-mtd ML to use "#define PIPELINE_ACCESS 2000"
On Thursday, July 10, 2014 at 12:52:19 PM, Masahiro Yamada wrote:
Hi Marek,
Hi!
Ack on both, thank you !
Hi Marek,
Done.
http://patchwork.ozlabs.org/patch/368933/
The driver for on-chip UART used on Panasonic UniPhier platform.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_uniphier.c | 206 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 209 insertions(+) create mode 100644 drivers/serial/serial_uniphier.c
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 571c18f..385b2f9 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_BFIN_SERIAL) += serial_bfin.o obj-$(CONFIG_FSL_LPUART) += serial_lpuart.o obj-$(CONFIG_MXS_AUART) += mxs_auart.o obj-$(CONFIG_ARC_SERIAL) += serial_arc.o +obj-$(CONFIG_UNIPHIER_SERIAL) += serial_uniphier.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index fd61a5e..9a05bef 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -157,6 +157,7 @@ serial_initfunc(sh_serial_initialize); serial_initfunc(arm_dcc_initialize); serial_initfunc(mxs_auart_initialize); serial_initfunc(arc_serial_initialize); +serial_initfunc(uniphier_serial_initialize);
/** * serial_register() - Register serial driver with serial driver core @@ -250,6 +251,7 @@ void serial_initialize(void) arm_dcc_initialize(); mxs_auart_initialize(); arc_serial_initialize(); + uniphier_serial_initialize();
serial_assign(default_serial_console()->name); } diff --git a/drivers/serial/serial_uniphier.c b/drivers/serial/serial_uniphier.c new file mode 100644 index 0000000..82c754c --- /dev/null +++ b/drivers/serial/serial_uniphier.c @@ -0,0 +1,206 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * Based on serial_ns16550.c + * (C) Copyright 2000 + * Rob Taylor, Flying Pig Systems. robt@flyingpig.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <serial.h> + +#define UART_REG(x) \ + u8 x; \ + u8 postpad_##x[3]; + +/* + * Note: Register map is slightly different from that of 16550. + */ +struct uniphier_serial { + UART_REG(rbr); /* 0x00 */ + UART_REG(ier); /* 0x04 */ + UART_REG(iir); /* 0x08 */ + UART_REG(fcr); /* 0x0c */ + u8 mcr; /* 0x10 */ + u8 lcr; + u16 __postpad; + UART_REG(lsr); /* 0x14 */ + UART_REG(msr); /* 0x18 */ + u32 __none1; + u32 __none2; + u16 dlr; + u16 __postpad2; +}; + +#define thr rbr + +/* + * These are the definitions for the Line Control Register + */ +#define UART_LCR_WLS_8 0x03 /* 8 bit character length */ + +/* + * These are the definitions for the Line Status Register + */ +#define UART_LSR_DR 0x01 /* Data ready */ +#define UART_LSR_THRE 0x20 /* Xmit holding register empty */ + +DECLARE_GLOBAL_DATA_PTR; + +static void uniphier_serial_init(struct uniphier_serial *port) +{ + writeb(UART_LCR_WLS_8, &port->lcr); + +#define MODE_X_DIV 16 + + /* Compute divisor value. Normally, we should simply return: + * CONFIG_SYS_NS16550_CLK) / MODE_X_DIV / gd->baudrate + * but we need to round that value by adding 0.5. + * Rounding is especially important at high baud rates. + */ + writew((CONFIG_SYS_UNIPHIER_UART_CLK + (gd->baudrate * + (MODE_X_DIV / 2))) / (MODE_X_DIV * gd->baudrate), &port->dlr); +} + +static void uniphier_serial_setbrg(struct uniphier_serial *port) +{ + uniphier_serial_init(port); +} + +static int uniphier_serial_tstc(struct uniphier_serial *port) +{ + return (readb(&port->lsr) & UART_LSR_DR) != 0; +} + +static int uniphier_serial_getc(struct uniphier_serial *port) +{ + while (!uniphier_serial_tstc(port)) + ; + + return readb(&port->rbr); +} + +static void uniphier_serial_putc(struct uniphier_serial *port, const char c) +{ + if (c == '\n') + uniphier_serial_putc(port, '\r'); + + while (!(readb(&port->lsr) & UART_LSR_THRE)) + ; + + writeb(c, &port->thr); +} + +static struct uniphier_serial *serial_ports[4] = { +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE0 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE0, +#else + NULL, +#endif +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE1 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE1, +#else + NULL, +#endif +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE2 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE2, +#else + NULL, +#endif +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE3 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE3, +#else + NULL, +#endif +}; + +/* Multi serial device functions */ +#define DECLARE_ESERIAL_FUNCTIONS(port) \ + static int eserial##port##_init(void) \ + { \ + uniphier_serial_init(serial_ports[port]); \ + return 0 ; \ + } \ + static void eserial##port##_setbrg(void) \ + { \ + uniphier_serial_setbrg(serial_ports[port]); \ + } \ + static int eserial##port##_getc(void) \ + { \ + return uniphier_serial_getc(serial_ports[port]); \ + } \ + static int eserial##port##_tstc(void) \ + { \ + return uniphier_serial_tstc(serial_ports[port]); \ + } \ + static void eserial##port##_putc(const char c) \ + { \ + uniphier_serial_putc(serial_ports[port], c); \ + } + +/* Serial device descriptor */ +#define INIT_ESERIAL_STRUCTURE(port, __name) { \ + .name = __name, \ + .start = eserial##port##_init, \ + .stop = NULL, \ + .setbrg = eserial##port##_setbrg, \ + .getc = eserial##port##_getc, \ + .tstc = eserial##port##_tstc, \ + .putc = eserial##port##_putc, \ + .puts = default_serial_puts, \ +} + +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE0) +DECLARE_ESERIAL_FUNCTIONS(0); +struct serial_device uniphier_serial0_device = + INIT_ESERIAL_STRUCTURE(0, "ttyS0"); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE1) +DECLARE_ESERIAL_FUNCTIONS(1); +struct serial_device uniphier_serial1_device = + INIT_ESERIAL_STRUCTURE(1, "ttyS1"); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE2) +DECLARE_ESERIAL_FUNCTIONS(2); +struct serial_device uniphier_serial2_device = + INIT_ESERIAL_STRUCTURE(2, "ttyS2"); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE3) +DECLARE_ESERIAL_FUNCTIONS(3); +struct serial_device uniphier_serial3_device = + INIT_ESERIAL_STRUCTURE(3, "ttyS3"); +#endif + +__weak struct serial_device *default_serial_console(void) +{ +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE0) + return &uniphier_serial0_device; +#elif defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE1) + return &uniphier_serial1_device; +#elif defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE2) + return &uniphier_serial2_device; +#elif defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE3) + return &uniphier_serial3_device; +#else +#error "No uniphier serial ports configured." +#endif +} + +void uniphier_serial_initialize(void) +{ +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE0) + serial_register(&uniphier_serial0_device); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE1) + serial_register(&uniphier_serial1_device); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE2) + serial_register(&uniphier_serial2_device); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE3) + serial_register(&uniphier_serial3_device); +#endif +}
- writeb(UART_LCR_WLS_8, &port->lcr);
You can use just const unsigned here instead of #define.
- /* Compute divisor value. Normally, we should simply return:
- writew((CONFIG_SYS_UNIPHIER_UART_CLK + (gd->baudrate *
- uniphier_serial_init(port);
- return (readb(&port->lsr) & UART_LSR_DR) != 0;
- while (!uniphier_serial_tstc(port))
- return readb(&port->rbr);
- if (c == '\n')
- while (!(readb(&port->lsr) & UART_LSR_THRE))
I think in this function, you can avoid such completely unbounded loop.
Best regard, Marek Vasut
Hi Marek,
I adjusted drivers/serial/serial_ns16550.c for my own.
Is using a macro here so bad? If so, should I also fix the line 138 of drivers/serial/serial_ns16550.c ?
- if (c == '\n')
Why? Could you give me more detailed explanation?
On Thursday, July 10, 2014 at 12:06:50 PM, Masahiro Yamada wrote:
Hi Marek,
You're loosing the typechecking, that's all.
- if (c == '\n')
In case the LSR_THRE bit would never get cleared, this loop would keep spinning forever. On the other hand, if there was some kind of a timeout, U-Boot would be able to continue doing at least something when exiting this loop by timing out. Though you're right that something would most likely have gone really bonkers if this LSR_THRE never got cleared.
Hi Marek,
- if (c == '\n')
I guess you mentioned the case where the flow control with CTS/RTS results in the dead lock.
I am not sure if we need to be so careful.
Is there any other UART driver using timeout check?
(What would U-Boot continue to do in case console cannot display the error message?)
Best Regards Masahiro Masahiro
On Thursday, July 10, 2014 at 01:31:01 PM, Masahiro Yamada wrote:
Hi Marek,
Hi!
- if (c == '\n')
Either that or plain hardware failure.
I don't know. If you feel this is not needed, then please just ignore my suggestion. I'm just pushing the usual "let's not do unbounded loops where reasonable" thing here ;-)
It can still boot kernel, even if it cannot print on console.
Hi Marek,
Hi Marek,
Hi!
- if (c == '\n')
Finally, I decided to keep this as is because:
[1] Our on-chip UART do not have the flow control feature. It uses only TX/RX signals.
[2] So, the eternal loop occurrs only when the hardware is broken. In this case, the situation is really fatal and I don't think it is reasonable to continue to do something.
[3] I checked some (but not all) other serial drivers but I could not find ones using timeout and break thing.
On Friday, July 11, 2014 at 07:37:13 AM, Masahiro Yamada wrote: [...]
Hi!
All right then.
These are used by Panasonic UniPhier SoC family.
arch/arm/cpu/armv7/uniphier/Makefile | 23 + arch/arm/cpu/armv7/uniphier/board_common.c | 32 + arch/arm/cpu/armv7/uniphier/board_late_init.c | 37 + arch/arm/cpu/armv7/uniphier/cache_uniphier.c | 154 +++ arch/arm/cpu/armv7/uniphier/cmd_pinmon.c | 33 + arch/arm/cpu/armv7/uniphier/cpu_info.c | 59 ++ arch/arm/cpu/armv7/uniphier/dram_init.c | 37 + arch/arm/cpu/armv7/uniphier/init_page_table.c | 1068 ++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/lowlevel_init.S | 159 +++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c | 33 + arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c | 16 + .../armv7/uniphier/ph1-ld4/board_postclk_init.c | 42 + arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c | 63 ++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c | 189 ++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c | 44 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c | 16 + .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 39 + arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c | 66 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c | 45 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c | 168 +++ .../arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c | 18 + arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 75 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c | 16 + .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c | 57 ++ arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c | 201 ++++ .../arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c | 51 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/reset.c | 29 + arch/arm/cpu/armv7/uniphier/smp.S | 54 + arch/arm/cpu/armv7/uniphier/spl.c | 17 + arch/arm/cpu/armv7/uniphier/support_card.c | 180 ++++ arch/arm/cpu/armv7/uniphier/timer.c | 39 + arch/arm/include/asm/arch-uniphier/arm-mpcore.h | 46 + arch/arm/include/asm/arch-uniphier/bcu-regs.h | 29 + arch/arm/include/asm/arch-uniphier/board.h | 35 + arch/arm/include/asm/arch-uniphier/boot-device.h | 20 + arch/arm/include/asm/arch-uniphier/led.h | 101 ++ arch/arm/include/asm/arch-uniphier/sbc-regs.h | 107 ++ arch/arm/include/asm/arch-uniphier/sc-regs.h | 62 ++ arch/arm/include/asm/arch-uniphier/sg-regs.h | 182 ++++ arch/arm/include/asm/arch-uniphier/ssc-regs.h | 65 ++ 58 files changed, 3917 insertions(+) create mode 100644 arch/arm/cpu/armv7/uniphier/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/board_common.c create mode 100644 arch/arm/cpu/armv7/uniphier/board_late_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/cache_uniphier.c create mode 100644 arch/arm/cpu/armv7/uniphier/cmd_pinmon.c create mode 100644 arch/arm/cpu/armv7/uniphier/cpu_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/dram_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/init_page_table.c create mode 100644 arch/arm/cpu/armv7/uniphier/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/reset.c create mode 100644 arch/arm/cpu/armv7/uniphier/smp.S create mode 100644 arch/arm/cpu/armv7/uniphier/spl.c create mode 100644 arch/arm/cpu/armv7/uniphier/support_card.c create mode 100644 arch/arm/cpu/armv7/uniphier/timer.c create mode 100644 arch/arm/include/asm/arch-uniphier/arm-mpcore.h create mode 100644 arch/arm/include/asm/arch-uniphier/bcu-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/board.h create mode 100644 arch/arm/include/asm/arch-uniphier/boot-device.h create mode 100644 arch/arm/include/asm/arch-uniphier/led.h create mode 100644 arch/arm/include/asm/arch-uniphier/sbc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sg-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/ssc-regs.h
diff --git a/arch/arm/cpu/armv7/uniphier/Makefile b/arch/arm/cpu/armv7/uniphier/Makefile new file mode 100644 index 0000000..13d6ef1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/Makefile @@ -0,0 +1,23 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_SPL_BUILD) += lowlevel_init.o init_page_table.o +obj-$(CONFIG_SPL_BUILD) += spl.o + +obj-y += timer.o +obj-y += reset.o +obj-y += cache_uniphier.o +obj-y += dram_init.o +obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o +obj-$(CONFIG_UNIPHIER_SMP) += smp.o +obj-$(if $(CONFIG_SPL_BUILD),,y) += cmd_pinmon.o + +obj-y += board_common.o +obj-$(CONFIG_PFC_MICRO_SUPPORT_CARD) += support_card.o +obj-$(CONFIG_DCC_MICRO_SUPPORT_CARD) += support_card.o + +obj-$(CONFIG_PH1_LD4) += ph1-ld4/ +obj-$(CONFIG_PH1_PRO4) += ph1-pro4/ +obj-$(CONFIG_PH1_SLD8) += ph1-sld8/ diff --git a/arch/arm/cpu/armv7/uniphier/board_common.c b/arch/arm/cpu/armv7/uniphier/board_common.c new file mode 100644 index 0000000..3fb26c6 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/board_common.c @@ -0,0 +1,32 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + led_write(U, B, O, O); + + return 0; +} + +#if CONFIG_NR_DRAM_BANKS >= 2 +void dram_init_banksize(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_dram[0].start = CONFIG_SDRAM0_BASE; + gd->bd->bi_dram[0].size = CONFIG_SDRAM0_SIZE; + gd->bd->bi_dram[1].start = CONFIG_SDRAM1_BASE; + gd->bd->bi_dram[1].size = CONFIG_SDRAM1_SIZE; +} +#endif diff --git a/arch/arm/cpu/armv7/uniphier/board_late_init.c b/arch/arm/cpu/armv7/uniphier/board_late_init.c new file mode 100644 index 0000000..844b3e1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/board_late_init.c @@ -0,0 +1,37 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <nand.h> +#include <asm/io.h> +#include <../drivers/mtd/nand/denali.h> + +static void nand_denali_wp_disable(void) +{ + void __iomem *denali_reg = (void __iomem *)CONFIG_SYS_NAND_REGS_BASE; + + writel(WRITE_PROTECT__FLAG, denali_reg + WRITE_PROTECT); +} + +int board_late_init(void) +{ + puts("MODE: "); + + switch (spl_boot_device()) { + case BOOT_DEVICE_NAND: + printf("NAND Boot\n"); + setenv("bootmode", "nandboot"); + nand_denali_wp_disable(); + break; + default: + printf("Unsupported Boot Mode\n"); + return -1; + } + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/cache_uniphier.c b/arch/arm/cpu/armv7/uniphier/cache_uniphier.c new file mode 100644 index 0000000..e47f977 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cache_uniphier.c @@ -0,0 +1,154 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7.h> +#include <asm/arch/ssc-regs.h> + +#ifdef CONFIG_UNIPHIER_L2CACHE_ON +static void uniphier_cache_maint_all(u32 operation) +{ + /* try until the command is successfully set */ + do { + writel(SSCOQM_S_ALL | SSCOQM_CE | operation, SSCOQM); + } while (readl(SSCOPPQSEF) & (SSCOPPQSEF_FE | SSCOPPQSEF_OE)); + + /* wait until the operation is completed */ + while (readl(SSCOLPQS) != SSCOLPQS_EF) + ; + + /* clear the complete notification flag */ + writel(SSCOLPQS_EF, SSCOLPQS); + + writel(SSCOPE_CM_SYNC, SSCOPE); /* drain internal buffers */ + readl(SSCOPE); /* need a read back to confirm */ +} + +void v7_outer_cache_flush_all(void) +{ + uniphier_cache_maint_all(SSCOQM_CM_WB_INV); +} + +void v7_outer_cache_inval_all(void) +{ + uniphier_cache_maint_all(SSCOQM_CM_INV); +} + +static void __uniphier_cache_maint_range(u32 start, u32 size, u32 operation) +{ + /* try until the command is successfully set */ + do { + writel(SSCOQM_S_ADDRESS | SSCOQM_CE | operation, SSCOQM); + writel(start, SSCOQAD); + writel(size, SSCOQSZ); + + } while (readl(SSCOPPQSEF) & (SSCOPPQSEF_FE | SSCOPPQSEF_OE)); + + /* wait until the operation is completed */ + while (readl(SSCOLPQS) != SSCOLPQS_EF) + ; + + /* clear the complete notification flag */ + writel(SSCOLPQS_EF, SSCOLPQS); +} + +static void uniphier_cache_maint_range(u32 start, u32 end, u32 operation) +{ + u32 size; + + /* + * If start address is not aligned to cache-line, + * do cache operation for the first cache-line + */ + start = start & ~(SSC_LINE_SIZE - 1); + + if (start == 0 && end >= (u32)(-SSC_LINE_SIZE)) { + /* this means cache operation for all range */ + uniphier_cache_maint_all(operation); + return; + } + + /* + * If end address is not aligned to cache-line, + * do cache operation for the last cache-line + */ + size = (end - start + SSC_LINE_SIZE - 1) & ~(SSC_LINE_SIZE - 1); + + while (size) { + u32 chunk_size = size > SSC_RANGE_OP_MAX_SIZE ? + SSC_RANGE_OP_MAX_SIZE : size; + __uniphier_cache_maint_range(start, chunk_size, operation); + + start += chunk_size; + size -= chunk_size; + } + + writel(SSCOPE_CM_SYNC, SSCOPE); /* drain internal buffers */ + readl(SSCOPE); /* need a read back to confirm */ +} + +void v7_outer_cache_flush_range(u32 start, u32 end) +{ + uniphier_cache_maint_range(start, end, SSCOQM_CM_WB_INV); +} + +void v7_outer_cache_inval_range(u32 start, u32 end) +{ + uniphier_cache_maint_range(start, end, SSCOQM_CM_INV); +} + +void v7_outer_cache_enable(void) +{ + u32 tmp; + tmp = readl(SSCC); + tmp |= SSCC_ON; + writel(tmp, SSCC); +} +#endif + +void v7_outer_cache_disable(void) +{ + u32 tmp; + tmp = readl(SSCC); + tmp &= ~SSCC_ON; + writel(tmp, SSCC); +} + +void wakeup_secondary(void); + +void enable_caches(void) +{ + uint32_t reg; + +#ifdef CONFIG_UNIPHIER_SMP + /* + * The secondary CPU must move to DDR, + * before L2 disable. + * On SPL, the Page Table is located on the L2. + */ + wakeup_secondary(); +#endif + /* + * UniPhier SoCs must use L2 cache for init stack pointer. + * We disable L2 and L1 in this order. + * If CONFIG_SYS_DCACHE_OFF is not defined, + * caches are enabled again with a new page table. + */ + + /* L2 disable */ + v7_outer_cache_disable(); + + /* L1 disable */ + reg = get_cr(); + reg &= ~(CR_C | CR_M); + set_cr(reg); + +#ifndef CONFIG_SYS_DCACHE_OFF + dcache_enable(); +#endif +} diff --git a/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c b/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c new file mode 100644 index 0000000..eef9f39 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/boot-device.h> + +static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct boot_device_info *table; + u32 mode_sel, n = 0; + + mode_sel = get_boot_mode_sel(); + + puts("Boot Mode Pin:\n"); + + for (table = boot_device_table; strlen(table->info); table++) { + printf(" %c %02x %s\n", n == mode_sel ? '*' : ' ', n, + table->info); + n++; + } + + return 0; +} + +U_BOOT_CMD( + pinmon, 1, 1, do_pinmon, + "pin monitor", + "" +); diff --git a/arch/arm/cpu/armv7/uniphier/cpu_info.c b/arch/arm/cpu/armv7/uniphier/cpu_info.c new file mode 100644 index 0000000..86d079a --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cpu_info.c @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2013-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +int print_cpuinfo(void) +{ + u32 revision, type, model, rev, required_model = 1, required_rev = 1; + + revision = readl(SG_REVISION); + type = (revision & SG_REVISION_TYPE_MASK) >> SG_REVISION_TYPE_SHIFT; + model = (revision & SG_REVISION_MODEL_MASK) >> SG_REVISION_MODEL_SHIFT; + rev = (revision & SG_REVISION_REV_MASK) >> SG_REVISION_REV_SHIFT; + + puts("CPU: "); + + switch (type) { + case 0x25: + puts("PH1-sLD3 (MN2WS0220)"); + required_model = 2; + break; + case 0x26: + puts("PH1-LD4 (MN2WS0250)"); + required_rev = 2; + break; + case 0x28: + puts("PH1-Pro4 (MN2WS0230)"); + break; + case 0x29: + puts("PH1-sLD8 (MN2WS0270)"); + break; + default: + printf("Unknown Processor ID (0x%x)\n", revision); + return -1; + } + + if (model > 1) + printf(" model %d", model); + + printf(" (rev. %d)\n", rev); + + if (model < required_model) { + printf("Sorry, this model is not supported.\n"); + printf("Required model is %d.", required_model); + return -1; + } else if (rev < required_rev) { + printf("Sorry, this revision is not supported.\n"); + printf("Required revision is %d.", required_rev); + return -1; + } + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/dram_init.c b/arch/arm/cpu/armv7/uniphier/dram_init.c new file mode 100644 index 0000000..5465a0e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/dram_init.c @@ -0,0 +1,37 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> + +int umc_init(void); +void enable_dpll_ssc(void); + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + +#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) + led_write(B, 4, , ); + + { + int res; + + res = umc_init(); + if (res < 0) + return res; + } + led_write(B, 5, , ); + + enable_dpll_ssc(); +#endif + + led_write(B, 6, , ); + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/init_page_table.c b/arch/arm/cpu/armv7/uniphier/init_page_table.c new file mode 100644 index 0000000..d273835 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/init_page_table.c @@ -0,0 +1,1068 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +/* encoding without TEX remap */ +#define NO_MAP 0x00000000 /* No Map */ +#define DEVICE 0x00002002 /* Non-shareable Device */ +#define NORMAL 0x0000000e /* Normal Memory Write-Back, No Write-Allocate */ + +#define SSC NORMAL /* System Cache: Normal */ +#define EXT DEVICE /* External Bus: Device */ +#define REG DEVICE /* IO Register: Device */ +#define DDR DEVICE /* DDR SDRAM: Device */ + +#ifdef CONFIG_SPL_BUILD +#define IS_SPL_TEXT_AREA(x) ((x) == ((CONFIG_SPL_TEXT_BASE) >> 20)) +#else +#define IS_SPL_TEXT_AREA(x) ((x) == ((CONFIG_SYS_TEXT_BASE) >> 20)) +#endif + +#define IS_INIT_STACK_AREA(x) ((x) == ((CONFIG_SYS_INIT_SP_ADDR) >> 20)) + +#define IS_SSC(x) ((IS_SPL_TEXT_AREA(x)) || \ + (IS_INIT_STACK_AREA(x))) +#define IS_EXT(x) ((x) < 0x100) +#define IS_REG(x) (0x500 <= (x) && (x) < 0x700) +#define IS_DDR(x) (0x800 <= (x) && (x) < 0xf00) + +#define MMU_FLAGS(x) (IS_SSC(x)) ? SSC : \ + (IS_EXT(x)) ? EXT : \ + (IS_REG(x)) ? REG : \ + (IS_DDR(x)) ? DDR : \ + NO_MAP + +#define TBL_ENTRY(x) (((x) << 20) | (MMU_FLAGS(x))) + +const u32 __aligned(PGTABLE_SIZE) init_page_table[PGTABLE_SIZE / sizeof(u32)] + = { + TBL_ENTRY(0x000), TBL_ENTRY(0x001), TBL_ENTRY(0x002), TBL_ENTRY(0x003), + TBL_ENTRY(0x004), TBL_ENTRY(0x005), TBL_ENTRY(0x006), TBL_ENTRY(0x007), + TBL_ENTRY(0x008), TBL_ENTRY(0x009), TBL_ENTRY(0x00a), TBL_ENTRY(0x00b), + TBL_ENTRY(0x00c), TBL_ENTRY(0x00d), TBL_ENTRY(0x00e), TBL_ENTRY(0x00f), + TBL_ENTRY(0x010), TBL_ENTRY(0x011), TBL_ENTRY(0x012), TBL_ENTRY(0x013), + TBL_ENTRY(0x014), TBL_ENTRY(0x015), TBL_ENTRY(0x016), TBL_ENTRY(0x017), + TBL_ENTRY(0x018), TBL_ENTRY(0x019), TBL_ENTRY(0x01a), TBL_ENTRY(0x01b), + TBL_ENTRY(0x01c), TBL_ENTRY(0x01d), TBL_ENTRY(0x01e), TBL_ENTRY(0x01f), + TBL_ENTRY(0x020), TBL_ENTRY(0x021), TBL_ENTRY(0x022), TBL_ENTRY(0x023), + TBL_ENTRY(0x024), TBL_ENTRY(0x025), TBL_ENTRY(0x026), TBL_ENTRY(0x027), + TBL_ENTRY(0x028), TBL_ENTRY(0x029), TBL_ENTRY(0x02a), TBL_ENTRY(0x02b), + TBL_ENTRY(0x02c), TBL_ENTRY(0x02d), TBL_ENTRY(0x02e), TBL_ENTRY(0x02f), + TBL_ENTRY(0x030), TBL_ENTRY(0x031), TBL_ENTRY(0x032), TBL_ENTRY(0x033), + TBL_ENTRY(0x034), TBL_ENTRY(0x035), TBL_ENTRY(0x036), TBL_ENTRY(0x037), + TBL_ENTRY(0x038), TBL_ENTRY(0x039), TBL_ENTRY(0x03a), TBL_ENTRY(0x03b), + TBL_ENTRY(0x03c), TBL_ENTRY(0x03d), TBL_ENTRY(0x03e), TBL_ENTRY(0x03f), + TBL_ENTRY(0x040), TBL_ENTRY(0x041), TBL_ENTRY(0x042), TBL_ENTRY(0x043), + TBL_ENTRY(0x044), TBL_ENTRY(0x045), TBL_ENTRY(0x046), TBL_ENTRY(0x047), + TBL_ENTRY(0x048), TBL_ENTRY(0x049), TBL_ENTRY(0x04a), TBL_ENTRY(0x04b), + TBL_ENTRY(0x04c), TBL_ENTRY(0x04d), TBL_ENTRY(0x04e), TBL_ENTRY(0x04f), + TBL_ENTRY(0x050), TBL_ENTRY(0x051), TBL_ENTRY(0x052), TBL_ENTRY(0x053), + TBL_ENTRY(0x054), TBL_ENTRY(0x055), TBL_ENTRY(0x056), TBL_ENTRY(0x057), + TBL_ENTRY(0x058), TBL_ENTRY(0x059), TBL_ENTRY(0x05a), TBL_ENTRY(0x05b), + TBL_ENTRY(0x05c), TBL_ENTRY(0x05d), TBL_ENTRY(0x05e), TBL_ENTRY(0x05f), + TBL_ENTRY(0x060), TBL_ENTRY(0x061), TBL_ENTRY(0x062), TBL_ENTRY(0x063), + TBL_ENTRY(0x064), TBL_ENTRY(0x065), TBL_ENTRY(0x066), TBL_ENTRY(0x067), + TBL_ENTRY(0x068), TBL_ENTRY(0x069), TBL_ENTRY(0x06a), TBL_ENTRY(0x06b), + TBL_ENTRY(0x06c), TBL_ENTRY(0x06d), TBL_ENTRY(0x06e), TBL_ENTRY(0x06f), + TBL_ENTRY(0x070), TBL_ENTRY(0x071), TBL_ENTRY(0x072), TBL_ENTRY(0x073), + TBL_ENTRY(0x074), TBL_ENTRY(0x075), TBL_ENTRY(0x076), TBL_ENTRY(0x077), + TBL_ENTRY(0x078), TBL_ENTRY(0x079), TBL_ENTRY(0x07a), TBL_ENTRY(0x07b), + TBL_ENTRY(0x07c), TBL_ENTRY(0x07d), TBL_ENTRY(0x07e), TBL_ENTRY(0x07f), + TBL_ENTRY(0x080), TBL_ENTRY(0x081), TBL_ENTRY(0x082), TBL_ENTRY(0x083), + TBL_ENTRY(0x084), TBL_ENTRY(0x085), TBL_ENTRY(0x086), TBL_ENTRY(0x087), + TBL_ENTRY(0x088), TBL_ENTRY(0x089), TBL_ENTRY(0x08a), TBL_ENTRY(0x08b), + TBL_ENTRY(0x08c), TBL_ENTRY(0x08d), TBL_ENTRY(0x08e), TBL_ENTRY(0x08f), + TBL_ENTRY(0x090), TBL_ENTRY(0x091), TBL_ENTRY(0x092), TBL_ENTRY(0x093), + TBL_ENTRY(0x094), TBL_ENTRY(0x095), TBL_ENTRY(0x096), TBL_ENTRY(0x097), + TBL_ENTRY(0x098), TBL_ENTRY(0x099), TBL_ENTRY(0x09a), TBL_ENTRY(0x09b), + TBL_ENTRY(0x09c), TBL_ENTRY(0x09d), TBL_ENTRY(0x09e), TBL_ENTRY(0x09f), + TBL_ENTRY(0x0a0), TBL_ENTRY(0x0a1), TBL_ENTRY(0x0a2), TBL_ENTRY(0x0a3), + TBL_ENTRY(0x0a4), TBL_ENTRY(0x0a5), TBL_ENTRY(0x0a6), TBL_ENTRY(0x0a7), + TBL_ENTRY(0x0a8), TBL_ENTRY(0x0a9), TBL_ENTRY(0x0aa), TBL_ENTRY(0x0ab), + TBL_ENTRY(0x0ac), TBL_ENTRY(0x0ad), TBL_ENTRY(0x0ae), TBL_ENTRY(0x0af), + TBL_ENTRY(0x0b0), TBL_ENTRY(0x0b1), TBL_ENTRY(0x0b2), TBL_ENTRY(0x0b3), + TBL_ENTRY(0x0b4), TBL_ENTRY(0x0b5), TBL_ENTRY(0x0b6), TBL_ENTRY(0x0b7), + TBL_ENTRY(0x0b8), TBL_ENTRY(0x0b9), TBL_ENTRY(0x0ba), TBL_ENTRY(0x0bb), + TBL_ENTRY(0x0bc), TBL_ENTRY(0x0bd), TBL_ENTRY(0x0be), TBL_ENTRY(0x0bf), + TBL_ENTRY(0x0c0), TBL_ENTRY(0x0c1), TBL_ENTRY(0x0c2), TBL_ENTRY(0x0c3), + TBL_ENTRY(0x0c4), TBL_ENTRY(0x0c5), TBL_ENTRY(0x0c6), TBL_ENTRY(0x0c7), + TBL_ENTRY(0x0c8), TBL_ENTRY(0x0c9), TBL_ENTRY(0x0ca), TBL_ENTRY(0x0cb), + TBL_ENTRY(0x0cc), TBL_ENTRY(0x0cd), TBL_ENTRY(0x0ce), TBL_ENTRY(0x0cf), + TBL_ENTRY(0x0d0), TBL_ENTRY(0x0d1), TBL_ENTRY(0x0d2), TBL_ENTRY(0x0d3), + TBL_ENTRY(0x0d4), TBL_ENTRY(0x0d5), TBL_ENTRY(0x0d6), TBL_ENTRY(0x0d7), + TBL_ENTRY(0x0d8), TBL_ENTRY(0x0d9), TBL_ENTRY(0x0da), TBL_ENTRY(0x0db), + TBL_ENTRY(0x0dc), TBL_ENTRY(0x0dd), TBL_ENTRY(0x0de), TBL_ENTRY(0x0df), + TBL_ENTRY(0x0e0), TBL_ENTRY(0x0e1), TBL_ENTRY(0x0e2), TBL_ENTRY(0x0e3), + TBL_ENTRY(0x0e4), TBL_ENTRY(0x0e5), TBL_ENTRY(0x0e6), TBL_ENTRY(0x0e7), + TBL_ENTRY(0x0e8), TBL_ENTRY(0x0e9), TBL_ENTRY(0x0ea), TBL_ENTRY(0x0eb), + TBL_ENTRY(0x0ec), TBL_ENTRY(0x0ed), TBL_ENTRY(0x0ee), TBL_ENTRY(0x0ef), + TBL_ENTRY(0x0f0), TBL_ENTRY(0x0f1), TBL_ENTRY(0x0f2), TBL_ENTRY(0x0f3), + TBL_ENTRY(0x0f4), TBL_ENTRY(0x0f5), TBL_ENTRY(0x0f6), TBL_ENTRY(0x0f7), + TBL_ENTRY(0x0f8), TBL_ENTRY(0x0f9), TBL_ENTRY(0x0fa), TBL_ENTRY(0x0fb), + TBL_ENTRY(0x0fc), TBL_ENTRY(0x0fd), TBL_ENTRY(0x0fe), TBL_ENTRY(0x0ff), + TBL_ENTRY(0x100), TBL_ENTRY(0x101), TBL_ENTRY(0x102), TBL_ENTRY(0x103), + TBL_ENTRY(0x104), TBL_ENTRY(0x105), TBL_ENTRY(0x106), TBL_ENTRY(0x107), + TBL_ENTRY(0x108), TBL_ENTRY(0x109), TBL_ENTRY(0x10a), TBL_ENTRY(0x10b), + TBL_ENTRY(0x10c), TBL_ENTRY(0x10d), TBL_ENTRY(0x10e), TBL_ENTRY(0x10f), + TBL_ENTRY(0x110), TBL_ENTRY(0x111), TBL_ENTRY(0x112), TBL_ENTRY(0x113), + TBL_ENTRY(0x114), TBL_ENTRY(0x115), TBL_ENTRY(0x116), TBL_ENTRY(0x117), + TBL_ENTRY(0x118), TBL_ENTRY(0x119), TBL_ENTRY(0x11a), TBL_ENTRY(0x11b), + TBL_ENTRY(0x11c), TBL_ENTRY(0x11d), TBL_ENTRY(0x11e), TBL_ENTRY(0x11f), + TBL_ENTRY(0x120), TBL_ENTRY(0x121), TBL_ENTRY(0x122), TBL_ENTRY(0x123), + TBL_ENTRY(0x124), TBL_ENTRY(0x125), TBL_ENTRY(0x126), TBL_ENTRY(0x127), + TBL_ENTRY(0x128), TBL_ENTRY(0x129), TBL_ENTRY(0x12a), TBL_ENTRY(0x12b), + TBL_ENTRY(0x12c), TBL_ENTRY(0x12d), TBL_ENTRY(0x12e), TBL_ENTRY(0x12f), + TBL_ENTRY(0x130), TBL_ENTRY(0x131), TBL_ENTRY(0x132), TBL_ENTRY(0x133), + TBL_ENTRY(0x134), TBL_ENTRY(0x135), TBL_ENTRY(0x136), TBL_ENTRY(0x137), + TBL_ENTRY(0x138), TBL_ENTRY(0x139), TBL_ENTRY(0x13a), TBL_ENTRY(0x13b), + TBL_ENTRY(0x13c), TBL_ENTRY(0x13d), TBL_ENTRY(0x13e), TBL_ENTRY(0x13f), + TBL_ENTRY(0x140), TBL_ENTRY(0x141), TBL_ENTRY(0x142), TBL_ENTRY(0x143), + TBL_ENTRY(0x144), TBL_ENTRY(0x145), TBL_ENTRY(0x146), TBL_ENTRY(0x147), + TBL_ENTRY(0x148), TBL_ENTRY(0x149), TBL_ENTRY(0x14a), TBL_ENTRY(0x14b), + TBL_ENTRY(0x14c), TBL_ENTRY(0x14d), TBL_ENTRY(0x14e), TBL_ENTRY(0x14f), + TBL_ENTRY(0x150), TBL_ENTRY(0x151), TBL_ENTRY(0x152), TBL_ENTRY(0x153), + TBL_ENTRY(0x154), TBL_ENTRY(0x155), TBL_ENTRY(0x156), TBL_ENTRY(0x157), + TBL_ENTRY(0x158), TBL_ENTRY(0x159), TBL_ENTRY(0x15a), TBL_ENTRY(0x15b), + TBL_ENTRY(0x15c), TBL_ENTRY(0x15d), TBL_ENTRY(0x15e), TBL_ENTRY(0x15f), + TBL_ENTRY(0x160), TBL_ENTRY(0x161), TBL_ENTRY(0x162), TBL_ENTRY(0x163), + TBL_ENTRY(0x164), TBL_ENTRY(0x165), TBL_ENTRY(0x166), TBL_ENTRY(0x167), + TBL_ENTRY(0x168), TBL_ENTRY(0x169), TBL_ENTRY(0x16a), TBL_ENTRY(0x16b), + TBL_ENTRY(0x16c), TBL_ENTRY(0x16d), TBL_ENTRY(0x16e), TBL_ENTRY(0x16f), + TBL_ENTRY(0x170), TBL_ENTRY(0x171), TBL_ENTRY(0x172), TBL_ENTRY(0x173), + TBL_ENTRY(0x174), TBL_ENTRY(0x175), TBL_ENTRY(0x176), TBL_ENTRY(0x177), + TBL_ENTRY(0x178), TBL_ENTRY(0x179), TBL_ENTRY(0x17a), TBL_ENTRY(0x17b), + TBL_ENTRY(0x17c), TBL_ENTRY(0x17d), TBL_ENTRY(0x17e), TBL_ENTRY(0x17f), + TBL_ENTRY(0x180), TBL_ENTRY(0x181), TBL_ENTRY(0x182), TBL_ENTRY(0x183), + TBL_ENTRY(0x184), TBL_ENTRY(0x185), TBL_ENTRY(0x186), TBL_ENTRY(0x187), + TBL_ENTRY(0x188), TBL_ENTRY(0x189), TBL_ENTRY(0x18a), TBL_ENTRY(0x18b), + TBL_ENTRY(0x18c), TBL_ENTRY(0x18d), TBL_ENTRY(0x18e), TBL_ENTRY(0x18f), + TBL_ENTRY(0x190), TBL_ENTRY(0x191), TBL_ENTRY(0x192), TBL_ENTRY(0x193), + TBL_ENTRY(0x194), TBL_ENTRY(0x195), TBL_ENTRY(0x196), TBL_ENTRY(0x197), + TBL_ENTRY(0x198), TBL_ENTRY(0x199), TBL_ENTRY(0x19a), TBL_ENTRY(0x19b), + TBL_ENTRY(0x19c), TBL_ENTRY(0x19d), TBL_ENTRY(0x19e), TBL_ENTRY(0x19f), + TBL_ENTRY(0x1a0), TBL_ENTRY(0x1a1), TBL_ENTRY(0x1a2), TBL_ENTRY(0x1a3), + TBL_ENTRY(0x1a4), TBL_ENTRY(0x1a5), TBL_ENTRY(0x1a6), TBL_ENTRY(0x1a7), + TBL_ENTRY(0x1a8), TBL_ENTRY(0x1a9), TBL_ENTRY(0x1aa), TBL_ENTRY(0x1ab), + TBL_ENTRY(0x1ac), TBL_ENTRY(0x1ad), TBL_ENTRY(0x1ae), TBL_ENTRY(0x1af), + TBL_ENTRY(0x1b0), TBL_ENTRY(0x1b1), TBL_ENTRY(0x1b2), TBL_ENTRY(0x1b3), + TBL_ENTRY(0x1b4), TBL_ENTRY(0x1b5), TBL_ENTRY(0x1b6), TBL_ENTRY(0x1b7), + TBL_ENTRY(0x1b8), TBL_ENTRY(0x1b9), TBL_ENTRY(0x1ba), TBL_ENTRY(0x1bb), + TBL_ENTRY(0x1bc), TBL_ENTRY(0x1bd), TBL_ENTRY(0x1be), TBL_ENTRY(0x1bf), + TBL_ENTRY(0x1c0), TBL_ENTRY(0x1c1), TBL_ENTRY(0x1c2), TBL_ENTRY(0x1c3), + TBL_ENTRY(0x1c4), TBL_ENTRY(0x1c5), TBL_ENTRY(0x1c6), TBL_ENTRY(0x1c7), + TBL_ENTRY(0x1c8), TBL_ENTRY(0x1c9), TBL_ENTRY(0x1ca), TBL_ENTRY(0x1cb), + TBL_ENTRY(0x1cc), TBL_ENTRY(0x1cd), TBL_ENTRY(0x1ce), TBL_ENTRY(0x1cf), + TBL_ENTRY(0x1d0), TBL_ENTRY(0x1d1), TBL_ENTRY(0x1d2), TBL_ENTRY(0x1d3), + TBL_ENTRY(0x1d4), TBL_ENTRY(0x1d5), TBL_ENTRY(0x1d6), TBL_ENTRY(0x1d7), + TBL_ENTRY(0x1d8), TBL_ENTRY(0x1d9), TBL_ENTRY(0x1da), TBL_ENTRY(0x1db), + TBL_ENTRY(0x1dc), TBL_ENTRY(0x1dd), TBL_ENTRY(0x1de), TBL_ENTRY(0x1df), + TBL_ENTRY(0x1e0), TBL_ENTRY(0x1e1), TBL_ENTRY(0x1e2), TBL_ENTRY(0x1e3), + TBL_ENTRY(0x1e4), TBL_ENTRY(0x1e5), TBL_ENTRY(0x1e6), TBL_ENTRY(0x1e7), + TBL_ENTRY(0x1e8), TBL_ENTRY(0x1e9), TBL_ENTRY(0x1ea), TBL_ENTRY(0x1eb), + TBL_ENTRY(0x1ec), TBL_ENTRY(0x1ed), TBL_ENTRY(0x1ee), TBL_ENTRY(0x1ef), + TBL_ENTRY(0x1f0), TBL_ENTRY(0x1f1), TBL_ENTRY(0x1f2), TBL_ENTRY(0x1f3), + TBL_ENTRY(0x1f4), TBL_ENTRY(0x1f5), TBL_ENTRY(0x1f6), TBL_ENTRY(0x1f7), + TBL_ENTRY(0x1f8), TBL_ENTRY(0x1f9), TBL_ENTRY(0x1fa), TBL_ENTRY(0x1fb), + TBL_ENTRY(0x1fc), TBL_ENTRY(0x1fd), TBL_ENTRY(0x1fe), TBL_ENTRY(0x1ff), + TBL_ENTRY(0x200), TBL_ENTRY(0x201), TBL_ENTRY(0x202), TBL_ENTRY(0x203), + TBL_ENTRY(0x204), TBL_ENTRY(0x205), TBL_ENTRY(0x206), TBL_ENTRY(0x207), + TBL_ENTRY(0x208), TBL_ENTRY(0x209), TBL_ENTRY(0x20a), TBL_ENTRY(0x20b), + TBL_ENTRY(0x20c), TBL_ENTRY(0x20d), TBL_ENTRY(0x20e), TBL_ENTRY(0x20f), + TBL_ENTRY(0x210), TBL_ENTRY(0x211), TBL_ENTRY(0x212), TBL_ENTRY(0x213), + TBL_ENTRY(0x214), TBL_ENTRY(0x215), TBL_ENTRY(0x216), TBL_ENTRY(0x217), + TBL_ENTRY(0x218), TBL_ENTRY(0x219), TBL_ENTRY(0x21a), TBL_ENTRY(0x21b), + TBL_ENTRY(0x21c), TBL_ENTRY(0x21d), TBL_ENTRY(0x21e), TBL_ENTRY(0x21f), + TBL_ENTRY(0x220), TBL_ENTRY(0x221), TBL_ENTRY(0x222), TBL_ENTRY(0x223), + TBL_ENTRY(0x224), TBL_ENTRY(0x225), TBL_ENTRY(0x226), TBL_ENTRY(0x227), + TBL_ENTRY(0x228), TBL_ENTRY(0x229), TBL_ENTRY(0x22a), TBL_ENTRY(0x22b), + TBL_ENTRY(0x22c), TBL_ENTRY(0x22d), TBL_ENTRY(0x22e), TBL_ENTRY(0x22f), + TBL_ENTRY(0x230), TBL_ENTRY(0x231), TBL_ENTRY(0x232), TBL_ENTRY(0x233), + TBL_ENTRY(0x234), TBL_ENTRY(0x235), TBL_ENTRY(0x236), TBL_ENTRY(0x237), + TBL_ENTRY(0x238), TBL_ENTRY(0x239), TBL_ENTRY(0x23a), TBL_ENTRY(0x23b), + TBL_ENTRY(0x23c), TBL_ENTRY(0x23d), TBL_ENTRY(0x23e), TBL_ENTRY(0x23f), + TBL_ENTRY(0x240), TBL_ENTRY(0x241), TBL_ENTRY(0x242), TBL_ENTRY(0x243), + TBL_ENTRY(0x244), TBL_ENTRY(0x245), TBL_ENTRY(0x246), TBL_ENTRY(0x247), + TBL_ENTRY(0x248), TBL_ENTRY(0x249), TBL_ENTRY(0x24a), TBL_ENTRY(0x24b), + TBL_ENTRY(0x24c), TBL_ENTRY(0x24d), TBL_ENTRY(0x24e), TBL_ENTRY(0x24f), + TBL_ENTRY(0x250), TBL_ENTRY(0x251), TBL_ENTRY(0x252), TBL_ENTRY(0x253), + TBL_ENTRY(0x254), TBL_ENTRY(0x255), TBL_ENTRY(0x256), TBL_ENTRY(0x257), + TBL_ENTRY(0x258), TBL_ENTRY(0x259), TBL_ENTRY(0x25a), TBL_ENTRY(0x25b), + TBL_ENTRY(0x25c), TBL_ENTRY(0x25d), TBL_ENTRY(0x25e), TBL_ENTRY(0x25f), + TBL_ENTRY(0x260), TBL_ENTRY(0x261), TBL_ENTRY(0x262), TBL_ENTRY(0x263), + TBL_ENTRY(0x264), TBL_ENTRY(0x265), TBL_ENTRY(0x266), TBL_ENTRY(0x267), + TBL_ENTRY(0x268), TBL_ENTRY(0x269), TBL_ENTRY(0x26a), TBL_ENTRY(0x26b), + TBL_ENTRY(0x26c), TBL_ENTRY(0x26d), TBL_ENTRY(0x26e), TBL_ENTRY(0x26f), + TBL_ENTRY(0x270), TBL_ENTRY(0x271), TBL_ENTRY(0x272), TBL_ENTRY(0x273), + TBL_ENTRY(0x274), TBL_ENTRY(0x275), TBL_ENTRY(0x276), TBL_ENTRY(0x277), + TBL_ENTRY(0x278), TBL_ENTRY(0x279), TBL_ENTRY(0x27a), TBL_ENTRY(0x27b), + TBL_ENTRY(0x27c), TBL_ENTRY(0x27d), TBL_ENTRY(0x27e), TBL_ENTRY(0x27f), + TBL_ENTRY(0x280), TBL_ENTRY(0x281), TBL_ENTRY(0x282), TBL_ENTRY(0x283), + TBL_ENTRY(0x284), TBL_ENTRY(0x285), TBL_ENTRY(0x286), TBL_ENTRY(0x287), + TBL_ENTRY(0x288), TBL_ENTRY(0x289), TBL_ENTRY(0x28a), TBL_ENTRY(0x28b), + TBL_ENTRY(0x28c), TBL_ENTRY(0x28d), TBL_ENTRY(0x28e), TBL_ENTRY(0x28f), + TBL_ENTRY(0x290), TBL_ENTRY(0x291), TBL_ENTRY(0x292), TBL_ENTRY(0x293), + TBL_ENTRY(0x294), TBL_ENTRY(0x295), TBL_ENTRY(0x296), TBL_ENTRY(0x297), + TBL_ENTRY(0x298), TBL_ENTRY(0x299), TBL_ENTRY(0x29a), TBL_ENTRY(0x29b), + TBL_ENTRY(0x29c), TBL_ENTRY(0x29d), TBL_ENTRY(0x29e), TBL_ENTRY(0x29f), + TBL_ENTRY(0x2a0), TBL_ENTRY(0x2a1), TBL_ENTRY(0x2a2), TBL_ENTRY(0x2a3), + TBL_ENTRY(0x2a4), TBL_ENTRY(0x2a5), TBL_ENTRY(0x2a6), TBL_ENTRY(0x2a7), + TBL_ENTRY(0x2a8), TBL_ENTRY(0x2a9), TBL_ENTRY(0x2aa), TBL_ENTRY(0x2ab), + TBL_ENTRY(0x2ac), TBL_ENTRY(0x2ad), TBL_ENTRY(0x2ae), TBL_ENTRY(0x2af), + TBL_ENTRY(0x2b0), TBL_ENTRY(0x2b1), TBL_ENTRY(0x2b2), TBL_ENTRY(0x2b3), + TBL_ENTRY(0x2b4), TBL_ENTRY(0x2b5), TBL_ENTRY(0x2b6), TBL_ENTRY(0x2b7), + TBL_ENTRY(0x2b8), TBL_ENTRY(0x2b9), TBL_ENTRY(0x2ba), TBL_ENTRY(0x2bb), + TBL_ENTRY(0x2bc), TBL_ENTRY(0x2bd), TBL_ENTRY(0x2be), TBL_ENTRY(0x2bf), + TBL_ENTRY(0x2c0), TBL_ENTRY(0x2c1), TBL_ENTRY(0x2c2), TBL_ENTRY(0x2c3), + TBL_ENTRY(0x2c4), TBL_ENTRY(0x2c5), TBL_ENTRY(0x2c6), TBL_ENTRY(0x2c7), + TBL_ENTRY(0x2c8), TBL_ENTRY(0x2c9), TBL_ENTRY(0x2ca), TBL_ENTRY(0x2cb), + TBL_ENTRY(0x2cc), TBL_ENTRY(0x2cd), TBL_ENTRY(0x2ce), TBL_ENTRY(0x2cf), + TBL_ENTRY(0x2d0), TBL_ENTRY(0x2d1), TBL_ENTRY(0x2d2), TBL_ENTRY(0x2d3), + TBL_ENTRY(0x2d4), TBL_ENTRY(0x2d5), TBL_ENTRY(0x2d6), TBL_ENTRY(0x2d7), + TBL_ENTRY(0x2d8), TBL_ENTRY(0x2d9), TBL_ENTRY(0x2da), TBL_ENTRY(0x2db), + TBL_ENTRY(0x2dc), TBL_ENTRY(0x2dd), TBL_ENTRY(0x2de), TBL_ENTRY(0x2df), + TBL_ENTRY(0x2e0), TBL_ENTRY(0x2e1), TBL_ENTRY(0x2e2), TBL_ENTRY(0x2e3), + TBL_ENTRY(0x2e4), TBL_ENTRY(0x2e5), TBL_ENTRY(0x2e6), TBL_ENTRY(0x2e7), + TBL_ENTRY(0x2e8), TBL_ENTRY(0x2e9), TBL_ENTRY(0x2ea), TBL_ENTRY(0x2eb), + TBL_ENTRY(0x2ec), TBL_ENTRY(0x2ed), TBL_ENTRY(0x2ee), TBL_ENTRY(0x2ef), + TBL_ENTRY(0x2f0), TBL_ENTRY(0x2f1), TBL_ENTRY(0x2f2), TBL_ENTRY(0x2f3), + TBL_ENTRY(0x2f4), TBL_ENTRY(0x2f5), TBL_ENTRY(0x2f6), TBL_ENTRY(0x2f7), + TBL_ENTRY(0x2f8), TBL_ENTRY(0x2f9), TBL_ENTRY(0x2fa), TBL_ENTRY(0x2fb), + TBL_ENTRY(0x2fc), TBL_ENTRY(0x2fd), TBL_ENTRY(0x2fe), TBL_ENTRY(0x2ff), + TBL_ENTRY(0x300), TBL_ENTRY(0x301), TBL_ENTRY(0x302), TBL_ENTRY(0x303), + TBL_ENTRY(0x304), TBL_ENTRY(0x305), TBL_ENTRY(0x306), TBL_ENTRY(0x307), + TBL_ENTRY(0x308), TBL_ENTRY(0x309), TBL_ENTRY(0x30a), TBL_ENTRY(0x30b), + TBL_ENTRY(0x30c), TBL_ENTRY(0x30d), TBL_ENTRY(0x30e), TBL_ENTRY(0x30f), + TBL_ENTRY(0x310), TBL_ENTRY(0x311), TBL_ENTRY(0x312), TBL_ENTRY(0x313), + TBL_ENTRY(0x314), TBL_ENTRY(0x315), TBL_ENTRY(0x316), TBL_ENTRY(0x317), + TBL_ENTRY(0x318), TBL_ENTRY(0x319), TBL_ENTRY(0x31a), TBL_ENTRY(0x31b), + TBL_ENTRY(0x31c), TBL_ENTRY(0x31d), TBL_ENTRY(0x31e), TBL_ENTRY(0x31f), + TBL_ENTRY(0x320), TBL_ENTRY(0x321), TBL_ENTRY(0x322), TBL_ENTRY(0x323), + TBL_ENTRY(0x324), TBL_ENTRY(0x325), TBL_ENTRY(0x326), TBL_ENTRY(0x327), + TBL_ENTRY(0x328), TBL_ENTRY(0x329), TBL_ENTRY(0x32a), TBL_ENTRY(0x32b), + TBL_ENTRY(0x32c), TBL_ENTRY(0x32d), TBL_ENTRY(0x32e), TBL_ENTRY(0x32f), + TBL_ENTRY(0x330), TBL_ENTRY(0x331), TBL_ENTRY(0x332), TBL_ENTRY(0x333), + TBL_ENTRY(0x334), TBL_ENTRY(0x335), TBL_ENTRY(0x336), TBL_ENTRY(0x337), + TBL_ENTRY(0x338), TBL_ENTRY(0x339), TBL_ENTRY(0x33a), TBL_ENTRY(0x33b), + TBL_ENTRY(0x33c), TBL_ENTRY(0x33d), TBL_ENTRY(0x33e), TBL_ENTRY(0x33f), + TBL_ENTRY(0x340), TBL_ENTRY(0x341), TBL_ENTRY(0x342), TBL_ENTRY(0x343), + TBL_ENTRY(0x344), TBL_ENTRY(0x345), TBL_ENTRY(0x346), TBL_ENTRY(0x347), + TBL_ENTRY(0x348), TBL_ENTRY(0x349), TBL_ENTRY(0x34a), TBL_ENTRY(0x34b), + TBL_ENTRY(0x34c), TBL_ENTRY(0x34d), TBL_ENTRY(0x34e), TBL_ENTRY(0x34f), + TBL_ENTRY(0x350), TBL_ENTRY(0x351), TBL_ENTRY(0x352), TBL_ENTRY(0x353), + TBL_ENTRY(0x354), TBL_ENTRY(0x355), TBL_ENTRY(0x356), TBL_ENTRY(0x357), + TBL_ENTRY(0x358), TBL_ENTRY(0x359), TBL_ENTRY(0x35a), TBL_ENTRY(0x35b), + TBL_ENTRY(0x35c), TBL_ENTRY(0x35d), TBL_ENTRY(0x35e), TBL_ENTRY(0x35f), + TBL_ENTRY(0x360), TBL_ENTRY(0x361), TBL_ENTRY(0x362), TBL_ENTRY(0x363), + TBL_ENTRY(0x364), TBL_ENTRY(0x365), TBL_ENTRY(0x366), TBL_ENTRY(0x367), + TBL_ENTRY(0x368), TBL_ENTRY(0x369), TBL_ENTRY(0x36a), TBL_ENTRY(0x36b), + TBL_ENTRY(0x36c), TBL_ENTRY(0x36d), TBL_ENTRY(0x36e), TBL_ENTRY(0x36f), + TBL_ENTRY(0x370), TBL_ENTRY(0x371), TBL_ENTRY(0x372), TBL_ENTRY(0x373), + TBL_ENTRY(0x374), TBL_ENTRY(0x375), TBL_ENTRY(0x376), TBL_ENTRY(0x377), + TBL_ENTRY(0x378), TBL_ENTRY(0x379), TBL_ENTRY(0x37a), TBL_ENTRY(0x37b), + TBL_ENTRY(0x37c), TBL_ENTRY(0x37d), TBL_ENTRY(0x37e), TBL_ENTRY(0x37f), + TBL_ENTRY(0x380), TBL_ENTRY(0x381), TBL_ENTRY(0x382), TBL_ENTRY(0x383), + TBL_ENTRY(0x384), TBL_ENTRY(0x385), TBL_ENTRY(0x386), TBL_ENTRY(0x387), + TBL_ENTRY(0x388), TBL_ENTRY(0x389), TBL_ENTRY(0x38a), TBL_ENTRY(0x38b), + TBL_ENTRY(0x38c), TBL_ENTRY(0x38d), TBL_ENTRY(0x38e), TBL_ENTRY(0x38f), + TBL_ENTRY(0x390), TBL_ENTRY(0x391), TBL_ENTRY(0x392), TBL_ENTRY(0x393), + TBL_ENTRY(0x394), TBL_ENTRY(0x395), TBL_ENTRY(0x396), TBL_ENTRY(0x397), + TBL_ENTRY(0x398), TBL_ENTRY(0x399), TBL_ENTRY(0x39a), TBL_ENTRY(0x39b), + TBL_ENTRY(0x39c), TBL_ENTRY(0x39d), TBL_ENTRY(0x39e), TBL_ENTRY(0x39f), + TBL_ENTRY(0x3a0), TBL_ENTRY(0x3a1), TBL_ENTRY(0x3a2), TBL_ENTRY(0x3a3), + TBL_ENTRY(0x3a4), TBL_ENTRY(0x3a5), TBL_ENTRY(0x3a6), TBL_ENTRY(0x3a7), + TBL_ENTRY(0x3a8), TBL_ENTRY(0x3a9), TBL_ENTRY(0x3aa), TBL_ENTRY(0x3ab), + TBL_ENTRY(0x3ac), TBL_ENTRY(0x3ad), TBL_ENTRY(0x3ae), TBL_ENTRY(0x3af), + TBL_ENTRY(0x3b0), TBL_ENTRY(0x3b1), TBL_ENTRY(0x3b2), TBL_ENTRY(0x3b3), + TBL_ENTRY(0x3b4), TBL_ENTRY(0x3b5), TBL_ENTRY(0x3b6), TBL_ENTRY(0x3b7), + TBL_ENTRY(0x3b8), TBL_ENTRY(0x3b9), TBL_ENTRY(0x3ba), TBL_ENTRY(0x3bb), + TBL_ENTRY(0x3bc), TBL_ENTRY(0x3bd), TBL_ENTRY(0x3be), TBL_ENTRY(0x3bf), + TBL_ENTRY(0x3c0), TBL_ENTRY(0x3c1), TBL_ENTRY(0x3c2), TBL_ENTRY(0x3c3), + TBL_ENTRY(0x3c4), TBL_ENTRY(0x3c5), TBL_ENTRY(0x3c6), TBL_ENTRY(0x3c7), + TBL_ENTRY(0x3c8), TBL_ENTRY(0x3c9), TBL_ENTRY(0x3ca), TBL_ENTRY(0x3cb), + TBL_ENTRY(0x3cc), TBL_ENTRY(0x3cd), TBL_ENTRY(0x3ce), TBL_ENTRY(0x3cf), + TBL_ENTRY(0x3d0), TBL_ENTRY(0x3d1), TBL_ENTRY(0x3d2), TBL_ENTRY(0x3d3), + TBL_ENTRY(0x3d4), TBL_ENTRY(0x3d5), TBL_ENTRY(0x3d6), TBL_ENTRY(0x3d7), + TBL_ENTRY(0x3d8), TBL_ENTRY(0x3d9), TBL_ENTRY(0x3da), TBL_ENTRY(0x3db), + TBL_ENTRY(0x3dc), TBL_ENTRY(0x3dd), TBL_ENTRY(0x3de), TBL_ENTRY(0x3df), + TBL_ENTRY(0x3e0), TBL_ENTRY(0x3e1), TBL_ENTRY(0x3e2), TBL_ENTRY(0x3e3), + TBL_ENTRY(0x3e4), TBL_ENTRY(0x3e5), TBL_ENTRY(0x3e6), TBL_ENTRY(0x3e7), + TBL_ENTRY(0x3e8), TBL_ENTRY(0x3e9), TBL_ENTRY(0x3ea), TBL_ENTRY(0x3eb), + TBL_ENTRY(0x3ec), TBL_ENTRY(0x3ed), TBL_ENTRY(0x3ee), TBL_ENTRY(0x3ef), + TBL_ENTRY(0x3f0), TBL_ENTRY(0x3f1), TBL_ENTRY(0x3f2), TBL_ENTRY(0x3f3), + TBL_ENTRY(0x3f4), TBL_ENTRY(0x3f5), TBL_ENTRY(0x3f6), TBL_ENTRY(0x3f7), + TBL_ENTRY(0x3f8), TBL_ENTRY(0x3f9), TBL_ENTRY(0x3fa), TBL_ENTRY(0x3fb), + TBL_ENTRY(0x3fc), TBL_ENTRY(0x3fd), TBL_ENTRY(0x3fe), TBL_ENTRY(0x3ff), + TBL_ENTRY(0x400), TBL_ENTRY(0x401), TBL_ENTRY(0x402), TBL_ENTRY(0x403), + TBL_ENTRY(0x404), TBL_ENTRY(0x405), TBL_ENTRY(0x406), TBL_ENTRY(0x407), + TBL_ENTRY(0x408), TBL_ENTRY(0x409), TBL_ENTRY(0x40a), TBL_ENTRY(0x40b), + TBL_ENTRY(0x40c), TBL_ENTRY(0x40d), TBL_ENTRY(0x40e), TBL_ENTRY(0x40f), + TBL_ENTRY(0x410), TBL_ENTRY(0x411), TBL_ENTRY(0x412), TBL_ENTRY(0x413), + TBL_ENTRY(0x414), TBL_ENTRY(0x415), TBL_ENTRY(0x416), TBL_ENTRY(0x417), + TBL_ENTRY(0x418), TBL_ENTRY(0x419), TBL_ENTRY(0x41a), TBL_ENTRY(0x41b), + TBL_ENTRY(0x41c), TBL_ENTRY(0x41d), TBL_ENTRY(0x41e), TBL_ENTRY(0x41f), + TBL_ENTRY(0x420), TBL_ENTRY(0x421), TBL_ENTRY(0x422), TBL_ENTRY(0x423), + TBL_ENTRY(0x424), TBL_ENTRY(0x425), TBL_ENTRY(0x426), TBL_ENTRY(0x427), + TBL_ENTRY(0x428), TBL_ENTRY(0x429), TBL_ENTRY(0x42a), TBL_ENTRY(0x42b), + TBL_ENTRY(0x42c), TBL_ENTRY(0x42d), TBL_ENTRY(0x42e), TBL_ENTRY(0x42f), + TBL_ENTRY(0x430), TBL_ENTRY(0x431), TBL_ENTRY(0x432), TBL_ENTRY(0x433), + TBL_ENTRY(0x434), TBL_ENTRY(0x435), TBL_ENTRY(0x436), TBL_ENTRY(0x437), + TBL_ENTRY(0x438), TBL_ENTRY(0x439), TBL_ENTRY(0x43a), TBL_ENTRY(0x43b), + TBL_ENTRY(0x43c), TBL_ENTRY(0x43d), TBL_ENTRY(0x43e), TBL_ENTRY(0x43f), + TBL_ENTRY(0x440), TBL_ENTRY(0x441), TBL_ENTRY(0x442), TBL_ENTRY(0x443), + TBL_ENTRY(0x444), TBL_ENTRY(0x445), TBL_ENTRY(0x446), TBL_ENTRY(0x447), + TBL_ENTRY(0x448), TBL_ENTRY(0x449), TBL_ENTRY(0x44a), TBL_ENTRY(0x44b), + TBL_ENTRY(0x44c), TBL_ENTRY(0x44d), TBL_ENTRY(0x44e), TBL_ENTRY(0x44f), + TBL_ENTRY(0x450), TBL_ENTRY(0x451), TBL_ENTRY(0x452), TBL_ENTRY(0x453), + TBL_ENTRY(0x454), TBL_ENTRY(0x455), TBL_ENTRY(0x456), TBL_ENTRY(0x457), + TBL_ENTRY(0x458), TBL_ENTRY(0x459), TBL_ENTRY(0x45a), TBL_ENTRY(0x45b), + TBL_ENTRY(0x45c), TBL_ENTRY(0x45d), TBL_ENTRY(0x45e), TBL_ENTRY(0x45f), + TBL_ENTRY(0x460), TBL_ENTRY(0x461), TBL_ENTRY(0x462), TBL_ENTRY(0x463), + TBL_ENTRY(0x464), TBL_ENTRY(0x465), TBL_ENTRY(0x466), TBL_ENTRY(0x467), + TBL_ENTRY(0x468), TBL_ENTRY(0x469), TBL_ENTRY(0x46a), TBL_ENTRY(0x46b), + TBL_ENTRY(0x46c), TBL_ENTRY(0x46d), TBL_ENTRY(0x46e), TBL_ENTRY(0x46f), + TBL_ENTRY(0x470), TBL_ENTRY(0x471), TBL_ENTRY(0x472), TBL_ENTRY(0x473), + TBL_ENTRY(0x474), TBL_ENTRY(0x475), TBL_ENTRY(0x476), TBL_ENTRY(0x477), + TBL_ENTRY(0x478), TBL_ENTRY(0x479), TBL_ENTRY(0x47a), TBL_ENTRY(0x47b), + TBL_ENTRY(0x47c), TBL_ENTRY(0x47d), TBL_ENTRY(0x47e), TBL_ENTRY(0x47f), + TBL_ENTRY(0x480), TBL_ENTRY(0x481), TBL_ENTRY(0x482), TBL_ENTRY(0x483), + TBL_ENTRY(0x484), TBL_ENTRY(0x485), TBL_ENTRY(0x486), TBL_ENTRY(0x487), + TBL_ENTRY(0x488), TBL_ENTRY(0x489), TBL_ENTRY(0x48a), TBL_ENTRY(0x48b), + TBL_ENTRY(0x48c), TBL_ENTRY(0x48d), TBL_ENTRY(0x48e), TBL_ENTRY(0x48f), + TBL_ENTRY(0x490), TBL_ENTRY(0x491), TBL_ENTRY(0x492), TBL_ENTRY(0x493), + TBL_ENTRY(0x494), TBL_ENTRY(0x495), TBL_ENTRY(0x496), TBL_ENTRY(0x497), + TBL_ENTRY(0x498), TBL_ENTRY(0x499), TBL_ENTRY(0x49a), TBL_ENTRY(0x49b), + TBL_ENTRY(0x49c), TBL_ENTRY(0x49d), TBL_ENTRY(0x49e), TBL_ENTRY(0x49f), + TBL_ENTRY(0x4a0), TBL_ENTRY(0x4a1), TBL_ENTRY(0x4a2), TBL_ENTRY(0x4a3), + TBL_ENTRY(0x4a4), TBL_ENTRY(0x4a5), TBL_ENTRY(0x4a6), TBL_ENTRY(0x4a7), + TBL_ENTRY(0x4a8), TBL_ENTRY(0x4a9), TBL_ENTRY(0x4aa), TBL_ENTRY(0x4ab), + TBL_ENTRY(0x4ac), TBL_ENTRY(0x4ad), TBL_ENTRY(0x4ae), TBL_ENTRY(0x4af), + TBL_ENTRY(0x4b0), TBL_ENTRY(0x4b1), TBL_ENTRY(0x4b2), TBL_ENTRY(0x4b3), + TBL_ENTRY(0x4b4), TBL_ENTRY(0x4b5), TBL_ENTRY(0x4b6), TBL_ENTRY(0x4b7), + TBL_ENTRY(0x4b8), TBL_ENTRY(0x4b9), TBL_ENTRY(0x4ba), TBL_ENTRY(0x4bb), + TBL_ENTRY(0x4bc), TBL_ENTRY(0x4bd), TBL_ENTRY(0x4be), TBL_ENTRY(0x4bf), + TBL_ENTRY(0x4c0), TBL_ENTRY(0x4c1), TBL_ENTRY(0x4c2), TBL_ENTRY(0x4c3), + TBL_ENTRY(0x4c4), TBL_ENTRY(0x4c5), TBL_ENTRY(0x4c6), TBL_ENTRY(0x4c7), + TBL_ENTRY(0x4c8), TBL_ENTRY(0x4c9), TBL_ENTRY(0x4ca), TBL_ENTRY(0x4cb), + TBL_ENTRY(0x4cc), TBL_ENTRY(0x4cd), TBL_ENTRY(0x4ce), TBL_ENTRY(0x4cf), + TBL_ENTRY(0x4d0), TBL_ENTRY(0x4d1), TBL_ENTRY(0x4d2), TBL_ENTRY(0x4d3), + TBL_ENTRY(0x4d4), TBL_ENTRY(0x4d5), TBL_ENTRY(0x4d6), TBL_ENTRY(0x4d7), + TBL_ENTRY(0x4d8), TBL_ENTRY(0x4d9), TBL_ENTRY(0x4da), TBL_ENTRY(0x4db), + TBL_ENTRY(0x4dc), TBL_ENTRY(0x4dd), TBL_ENTRY(0x4de), TBL_ENTRY(0x4df), + TBL_ENTRY(0x4e0), TBL_ENTRY(0x4e1), TBL_ENTRY(0x4e2), TBL_ENTRY(0x4e3), + TBL_ENTRY(0x4e4), TBL_ENTRY(0x4e5), TBL_ENTRY(0x4e6), TBL_ENTRY(0x4e7), + TBL_ENTRY(0x4e8), TBL_ENTRY(0x4e9), TBL_ENTRY(0x4ea), TBL_ENTRY(0x4eb), + TBL_ENTRY(0x4ec), TBL_ENTRY(0x4ed), TBL_ENTRY(0x4ee), TBL_ENTRY(0x4ef), + TBL_ENTRY(0x4f0), TBL_ENTRY(0x4f1), TBL_ENTRY(0x4f2), TBL_ENTRY(0x4f3), + TBL_ENTRY(0x4f4), TBL_ENTRY(0x4f5), TBL_ENTRY(0x4f6), TBL_ENTRY(0x4f7), + TBL_ENTRY(0x4f8), TBL_ENTRY(0x4f9), TBL_ENTRY(0x4fa), TBL_ENTRY(0x4fb), + TBL_ENTRY(0x4fc), TBL_ENTRY(0x4fd), TBL_ENTRY(0x4fe), TBL_ENTRY(0x4ff), + TBL_ENTRY(0x500), TBL_ENTRY(0x501), TBL_ENTRY(0x502), TBL_ENTRY(0x503), + TBL_ENTRY(0x504), TBL_ENTRY(0x505), TBL_ENTRY(0x506), TBL_ENTRY(0x507), + TBL_ENTRY(0x508), TBL_ENTRY(0x509), TBL_ENTRY(0x50a), TBL_ENTRY(0x50b), + TBL_ENTRY(0x50c), TBL_ENTRY(0x50d), TBL_ENTRY(0x50e), TBL_ENTRY(0x50f), + TBL_ENTRY(0x510), TBL_ENTRY(0x511), TBL_ENTRY(0x512), TBL_ENTRY(0x513), + TBL_ENTRY(0x514), TBL_ENTRY(0x515), TBL_ENTRY(0x516), TBL_ENTRY(0x517), + TBL_ENTRY(0x518), TBL_ENTRY(0x519), TBL_ENTRY(0x51a), TBL_ENTRY(0x51b), + TBL_ENTRY(0x51c), TBL_ENTRY(0x51d), TBL_ENTRY(0x51e), TBL_ENTRY(0x51f), + TBL_ENTRY(0x520), TBL_ENTRY(0x521), TBL_ENTRY(0x522), TBL_ENTRY(0x523), + TBL_ENTRY(0x524), TBL_ENTRY(0x525), TBL_ENTRY(0x526), TBL_ENTRY(0x527), + TBL_ENTRY(0x528), TBL_ENTRY(0x529), TBL_ENTRY(0x52a), TBL_ENTRY(0x52b), + TBL_ENTRY(0x52c), TBL_ENTRY(0x52d), TBL_ENTRY(0x52e), TBL_ENTRY(0x52f), + TBL_ENTRY(0x530), TBL_ENTRY(0x531), TBL_ENTRY(0x532), TBL_ENTRY(0x533), + TBL_ENTRY(0x534), TBL_ENTRY(0x535), TBL_ENTRY(0x536), TBL_ENTRY(0x537), + TBL_ENTRY(0x538), TBL_ENTRY(0x539), TBL_ENTRY(0x53a), TBL_ENTRY(0x53b), + TBL_ENTRY(0x53c), TBL_ENTRY(0x53d), TBL_ENTRY(0x53e), TBL_ENTRY(0x53f), + TBL_ENTRY(0x540), TBL_ENTRY(0x541), TBL_ENTRY(0x542), TBL_ENTRY(0x543), + TBL_ENTRY(0x544), TBL_ENTRY(0x545), TBL_ENTRY(0x546), TBL_ENTRY(0x547), + TBL_ENTRY(0x548), TBL_ENTRY(0x549), TBL_ENTRY(0x54a), TBL_ENTRY(0x54b), + TBL_ENTRY(0x54c), TBL_ENTRY(0x54d), TBL_ENTRY(0x54e), TBL_ENTRY(0x54f), + TBL_ENTRY(0x550), TBL_ENTRY(0x551), TBL_ENTRY(0x552), TBL_ENTRY(0x553), + TBL_ENTRY(0x554), TBL_ENTRY(0x555), TBL_ENTRY(0x556), TBL_ENTRY(0x557), + TBL_ENTRY(0x558), TBL_ENTRY(0x559), TBL_ENTRY(0x55a), TBL_ENTRY(0x55b), + TBL_ENTRY(0x55c), TBL_ENTRY(0x55d), TBL_ENTRY(0x55e), TBL_ENTRY(0x55f), + TBL_ENTRY(0x560), TBL_ENTRY(0x561), TBL_ENTRY(0x562), TBL_ENTRY(0x563), + TBL_ENTRY(0x564), TBL_ENTRY(0x565), TBL_ENTRY(0x566), TBL_ENTRY(0x567), + TBL_ENTRY(0x568), TBL_ENTRY(0x569), TBL_ENTRY(0x56a), TBL_ENTRY(0x56b), + TBL_ENTRY(0x56c), TBL_ENTRY(0x56d), TBL_ENTRY(0x56e), TBL_ENTRY(0x56f), + TBL_ENTRY(0x570), TBL_ENTRY(0x571), TBL_ENTRY(0x572), TBL_ENTRY(0x573), + TBL_ENTRY(0x574), TBL_ENTRY(0x575), TBL_ENTRY(0x576), TBL_ENTRY(0x577), + TBL_ENTRY(0x578), TBL_ENTRY(0x579), TBL_ENTRY(0x57a), TBL_ENTRY(0x57b), + TBL_ENTRY(0x57c), TBL_ENTRY(0x57d), TBL_ENTRY(0x57e), TBL_ENTRY(0x57f), + TBL_ENTRY(0x580), TBL_ENTRY(0x581), TBL_ENTRY(0x582), TBL_ENTRY(0x583), + TBL_ENTRY(0x584), TBL_ENTRY(0x585), TBL_ENTRY(0x586), TBL_ENTRY(0x587), + TBL_ENTRY(0x588), TBL_ENTRY(0x589), TBL_ENTRY(0x58a), TBL_ENTRY(0x58b), + TBL_ENTRY(0x58c), TBL_ENTRY(0x58d), TBL_ENTRY(0x58e), TBL_ENTRY(0x58f), + TBL_ENTRY(0x590), TBL_ENTRY(0x591), TBL_ENTRY(0x592), TBL_ENTRY(0x593), + TBL_ENTRY(0x594), TBL_ENTRY(0x595), TBL_ENTRY(0x596), TBL_ENTRY(0x597), + TBL_ENTRY(0x598), TBL_ENTRY(0x599), TBL_ENTRY(0x59a), TBL_ENTRY(0x59b), + TBL_ENTRY(0x59c), TBL_ENTRY(0x59d), TBL_ENTRY(0x59e), TBL_ENTRY(0x59f), + TBL_ENTRY(0x5a0), TBL_ENTRY(0x5a1), TBL_ENTRY(0x5a2), TBL_ENTRY(0x5a3), + TBL_ENTRY(0x5a4), TBL_ENTRY(0x5a5), TBL_ENTRY(0x5a6), TBL_ENTRY(0x5a7), + TBL_ENTRY(0x5a8), TBL_ENTRY(0x5a9), TBL_ENTRY(0x5aa), TBL_ENTRY(0x5ab), + TBL_ENTRY(0x5ac), TBL_ENTRY(0x5ad), TBL_ENTRY(0x5ae), TBL_ENTRY(0x5af), + TBL_ENTRY(0x5b0), TBL_ENTRY(0x5b1), TBL_ENTRY(0x5b2), TBL_ENTRY(0x5b3), + TBL_ENTRY(0x5b4), TBL_ENTRY(0x5b5), TBL_ENTRY(0x5b6), TBL_ENTRY(0x5b7), + TBL_ENTRY(0x5b8), TBL_ENTRY(0x5b9), TBL_ENTRY(0x5ba), TBL_ENTRY(0x5bb), + TBL_ENTRY(0x5bc), TBL_ENTRY(0x5bd), TBL_ENTRY(0x5be), TBL_ENTRY(0x5bf), + TBL_ENTRY(0x5c0), TBL_ENTRY(0x5c1), TBL_ENTRY(0x5c2), TBL_ENTRY(0x5c3), + TBL_ENTRY(0x5c4), TBL_ENTRY(0x5c5), TBL_ENTRY(0x5c6), TBL_ENTRY(0x5c7), + TBL_ENTRY(0x5c8), TBL_ENTRY(0x5c9), TBL_ENTRY(0x5ca), TBL_ENTRY(0x5cb), + TBL_ENTRY(0x5cc), TBL_ENTRY(0x5cd), TBL_ENTRY(0x5ce), TBL_ENTRY(0x5cf), + TBL_ENTRY(0x5d0), TBL_ENTRY(0x5d1), TBL_ENTRY(0x5d2), TBL_ENTRY(0x5d3), + TBL_ENTRY(0x5d4), TBL_ENTRY(0x5d5), TBL_ENTRY(0x5d6), TBL_ENTRY(0x5d7), + TBL_ENTRY(0x5d8), TBL_ENTRY(0x5d9), TBL_ENTRY(0x5da), TBL_ENTRY(0x5db), + TBL_ENTRY(0x5dc), TBL_ENTRY(0x5dd), TBL_ENTRY(0x5de), TBL_ENTRY(0x5df), + TBL_ENTRY(0x5e0), TBL_ENTRY(0x5e1), TBL_ENTRY(0x5e2), TBL_ENTRY(0x5e3), + TBL_ENTRY(0x5e4), TBL_ENTRY(0x5e5), TBL_ENTRY(0x5e6), TBL_ENTRY(0x5e7), + TBL_ENTRY(0x5e8), TBL_ENTRY(0x5e9), TBL_ENTRY(0x5ea), TBL_ENTRY(0x5eb), + TBL_ENTRY(0x5ec), TBL_ENTRY(0x5ed), TBL_ENTRY(0x5ee), TBL_ENTRY(0x5ef), + TBL_ENTRY(0x5f0), TBL_ENTRY(0x5f1), TBL_ENTRY(0x5f2), TBL_ENTRY(0x5f3), + TBL_ENTRY(0x5f4), TBL_ENTRY(0x5f5), TBL_ENTRY(0x5f6), TBL_ENTRY(0x5f7), + TBL_ENTRY(0x5f8), TBL_ENTRY(0x5f9), TBL_ENTRY(0x5fa), TBL_ENTRY(0x5fb), + TBL_ENTRY(0x5fc), TBL_ENTRY(0x5fd), TBL_ENTRY(0x5fe), TBL_ENTRY(0x5ff), + TBL_ENTRY(0x600), TBL_ENTRY(0x601), TBL_ENTRY(0x602), TBL_ENTRY(0x603), + TBL_ENTRY(0x604), TBL_ENTRY(0x605), TBL_ENTRY(0x606), TBL_ENTRY(0x607), + TBL_ENTRY(0x608), TBL_ENTRY(0x609), TBL_ENTRY(0x60a), TBL_ENTRY(0x60b), + TBL_ENTRY(0x60c), TBL_ENTRY(0x60d), TBL_ENTRY(0x60e), TBL_ENTRY(0x60f), + TBL_ENTRY(0x610), TBL_ENTRY(0x611), TBL_ENTRY(0x612), TBL_ENTRY(0x613), + TBL_ENTRY(0x614), TBL_ENTRY(0x615), TBL_ENTRY(0x616), TBL_ENTRY(0x617), + TBL_ENTRY(0x618), TBL_ENTRY(0x619), TBL_ENTRY(0x61a), TBL_ENTRY(0x61b), + TBL_ENTRY(0x61c), TBL_ENTRY(0x61d), TBL_ENTRY(0x61e), TBL_ENTRY(0x61f), + TBL_ENTRY(0x620), TBL_ENTRY(0x621), TBL_ENTRY(0x622), TBL_ENTRY(0x623), + TBL_ENTRY(0x624), TBL_ENTRY(0x625), TBL_ENTRY(0x626), TBL_ENTRY(0x627), + TBL_ENTRY(0x628), TBL_ENTRY(0x629), TBL_ENTRY(0x62a), TBL_ENTRY(0x62b), + TBL_ENTRY(0x62c), TBL_ENTRY(0x62d), TBL_ENTRY(0x62e), TBL_ENTRY(0x62f), + TBL_ENTRY(0x630), TBL_ENTRY(0x631), TBL_ENTRY(0x632), TBL_ENTRY(0x633), + TBL_ENTRY(0x634), TBL_ENTRY(0x635), TBL_ENTRY(0x636), TBL_ENTRY(0x637), + TBL_ENTRY(0x638), TBL_ENTRY(0x639), TBL_ENTRY(0x63a), TBL_ENTRY(0x63b), + TBL_ENTRY(0x63c), TBL_ENTRY(0x63d), TBL_ENTRY(0x63e), TBL_ENTRY(0x63f), + TBL_ENTRY(0x640), TBL_ENTRY(0x641), TBL_ENTRY(0x642), TBL_ENTRY(0x643), + TBL_ENTRY(0x644), TBL_ENTRY(0x645), TBL_ENTRY(0x646), TBL_ENTRY(0x647), + TBL_ENTRY(0x648), TBL_ENTRY(0x649), TBL_ENTRY(0x64a), TBL_ENTRY(0x64b), + TBL_ENTRY(0x64c), TBL_ENTRY(0x64d), TBL_ENTRY(0x64e), TBL_ENTRY(0x64f), + TBL_ENTRY(0x650), TBL_ENTRY(0x651), TBL_ENTRY(0x652), TBL_ENTRY(0x653), + TBL_ENTRY(0x654), TBL_ENTRY(0x655), TBL_ENTRY(0x656), TBL_ENTRY(0x657), + TBL_ENTRY(0x658), TBL_ENTRY(0x659), TBL_ENTRY(0x65a), TBL_ENTRY(0x65b), + TBL_ENTRY(0x65c), TBL_ENTRY(0x65d), TBL_ENTRY(0x65e), TBL_ENTRY(0x65f), + TBL_ENTRY(0x660), TBL_ENTRY(0x661), TBL_ENTRY(0x662), TBL_ENTRY(0x663), + TBL_ENTRY(0x664), TBL_ENTRY(0x665), TBL_ENTRY(0x666), TBL_ENTRY(0x667), + TBL_ENTRY(0x668), TBL_ENTRY(0x669), TBL_ENTRY(0x66a), TBL_ENTRY(0x66b), + TBL_ENTRY(0x66c), TBL_ENTRY(0x66d), TBL_ENTRY(0x66e), TBL_ENTRY(0x66f), + TBL_ENTRY(0x670), TBL_ENTRY(0x671), TBL_ENTRY(0x672), TBL_ENTRY(0x673), + TBL_ENTRY(0x674), TBL_ENTRY(0x675), TBL_ENTRY(0x676), TBL_ENTRY(0x677), + TBL_ENTRY(0x678), TBL_ENTRY(0x679), TBL_ENTRY(0x67a), TBL_ENTRY(0x67b), + TBL_ENTRY(0x67c), TBL_ENTRY(0x67d), TBL_ENTRY(0x67e), TBL_ENTRY(0x67f), + TBL_ENTRY(0x680), TBL_ENTRY(0x681), TBL_ENTRY(0x682), TBL_ENTRY(0x683), + TBL_ENTRY(0x684), TBL_ENTRY(0x685), TBL_ENTRY(0x686), TBL_ENTRY(0x687), + TBL_ENTRY(0x688), TBL_ENTRY(0x689), TBL_ENTRY(0x68a), TBL_ENTRY(0x68b), + TBL_ENTRY(0x68c), TBL_ENTRY(0x68d), TBL_ENTRY(0x68e), TBL_ENTRY(0x68f), + TBL_ENTRY(0x690), TBL_ENTRY(0x691), TBL_ENTRY(0x692), TBL_ENTRY(0x693), + TBL_ENTRY(0x694), TBL_ENTRY(0x695), TBL_ENTRY(0x696), TBL_ENTRY(0x697), + TBL_ENTRY(0x698), TBL_ENTRY(0x699), TBL_ENTRY(0x69a), TBL_ENTRY(0x69b), + TBL_ENTRY(0x69c), TBL_ENTRY(0x69d), TBL_ENTRY(0x69e), TBL_ENTRY(0x69f), + TBL_ENTRY(0x6a0), TBL_ENTRY(0x6a1), TBL_ENTRY(0x6a2), TBL_ENTRY(0x6a3), + TBL_ENTRY(0x6a4), TBL_ENTRY(0x6a5), TBL_ENTRY(0x6a6), TBL_ENTRY(0x6a7), + TBL_ENTRY(0x6a8), TBL_ENTRY(0x6a9), TBL_ENTRY(0x6aa), TBL_ENTRY(0x6ab), + TBL_ENTRY(0x6ac), TBL_ENTRY(0x6ad), TBL_ENTRY(0x6ae), TBL_ENTRY(0x6af), + TBL_ENTRY(0x6b0), TBL_ENTRY(0x6b1), TBL_ENTRY(0x6b2), TBL_ENTRY(0x6b3), + TBL_ENTRY(0x6b4), TBL_ENTRY(0x6b5), TBL_ENTRY(0x6b6), TBL_ENTRY(0x6b7), + TBL_ENTRY(0x6b8), TBL_ENTRY(0x6b9), TBL_ENTRY(0x6ba), TBL_ENTRY(0x6bb), + TBL_ENTRY(0x6bc), TBL_ENTRY(0x6bd), TBL_ENTRY(0x6be), TBL_ENTRY(0x6bf), + TBL_ENTRY(0x6c0), TBL_ENTRY(0x6c1), TBL_ENTRY(0x6c2), TBL_ENTRY(0x6c3), + TBL_ENTRY(0x6c4), TBL_ENTRY(0x6c5), TBL_ENTRY(0x6c6), TBL_ENTRY(0x6c7), + TBL_ENTRY(0x6c8), TBL_ENTRY(0x6c9), TBL_ENTRY(0x6ca), TBL_ENTRY(0x6cb), + TBL_ENTRY(0x6cc), TBL_ENTRY(0x6cd), TBL_ENTRY(0x6ce), TBL_ENTRY(0x6cf), + TBL_ENTRY(0x6d0), TBL_ENTRY(0x6d1), TBL_ENTRY(0x6d2), TBL_ENTRY(0x6d3), + TBL_ENTRY(0x6d4), TBL_ENTRY(0x6d5), TBL_ENTRY(0x6d6), TBL_ENTRY(0x6d7), + TBL_ENTRY(0x6d8), TBL_ENTRY(0x6d9), TBL_ENTRY(0x6da), TBL_ENTRY(0x6db), + TBL_ENTRY(0x6dc), TBL_ENTRY(0x6dd), TBL_ENTRY(0x6de), TBL_ENTRY(0x6df), + TBL_ENTRY(0x6e0), TBL_ENTRY(0x6e1), TBL_ENTRY(0x6e2), TBL_ENTRY(0x6e3), + TBL_ENTRY(0x6e4), TBL_ENTRY(0x6e5), TBL_ENTRY(0x6e6), TBL_ENTRY(0x6e7), + TBL_ENTRY(0x6e8), TBL_ENTRY(0x6e9), TBL_ENTRY(0x6ea), TBL_ENTRY(0x6eb), + TBL_ENTRY(0x6ec), TBL_ENTRY(0x6ed), TBL_ENTRY(0x6ee), TBL_ENTRY(0x6ef), + TBL_ENTRY(0x6f0), TBL_ENTRY(0x6f1), TBL_ENTRY(0x6f2), TBL_ENTRY(0x6f3), + TBL_ENTRY(0x6f4), TBL_ENTRY(0x6f5), TBL_ENTRY(0x6f6), TBL_ENTRY(0x6f7), + TBL_ENTRY(0x6f8), TBL_ENTRY(0x6f9), TBL_ENTRY(0x6fa), TBL_ENTRY(0x6fb), + TBL_ENTRY(0x6fc), TBL_ENTRY(0x6fd), TBL_ENTRY(0x6fe), TBL_ENTRY(0x6ff), + TBL_ENTRY(0x700), TBL_ENTRY(0x701), TBL_ENTRY(0x702), TBL_ENTRY(0x703), + TBL_ENTRY(0x704), TBL_ENTRY(0x705), TBL_ENTRY(0x706), TBL_ENTRY(0x707), + TBL_ENTRY(0x708), TBL_ENTRY(0x709), TBL_ENTRY(0x70a), TBL_ENTRY(0x70b), + TBL_ENTRY(0x70c), TBL_ENTRY(0x70d), TBL_ENTRY(0x70e), TBL_ENTRY(0x70f), + TBL_ENTRY(0x710), TBL_ENTRY(0x711), TBL_ENTRY(0x712), TBL_ENTRY(0x713), + TBL_ENTRY(0x714), TBL_ENTRY(0x715), TBL_ENTRY(0x716), TBL_ENTRY(0x717), + TBL_ENTRY(0x718), TBL_ENTRY(0x719), TBL_ENTRY(0x71a), TBL_ENTRY(0x71b), + TBL_ENTRY(0x71c), TBL_ENTRY(0x71d), TBL_ENTRY(0x71e), TBL_ENTRY(0x71f), + TBL_ENTRY(0x720), TBL_ENTRY(0x721), TBL_ENTRY(0x722), TBL_ENTRY(0x723), + TBL_ENTRY(0x724), TBL_ENTRY(0x725), TBL_ENTRY(0x726), TBL_ENTRY(0x727), + TBL_ENTRY(0x728), TBL_ENTRY(0x729), TBL_ENTRY(0x72a), TBL_ENTRY(0x72b), + TBL_ENTRY(0x72c), TBL_ENTRY(0x72d), TBL_ENTRY(0x72e), TBL_ENTRY(0x72f), + TBL_ENTRY(0x730), TBL_ENTRY(0x731), TBL_ENTRY(0x732), TBL_ENTRY(0x733), + TBL_ENTRY(0x734), TBL_ENTRY(0x735), TBL_ENTRY(0x736), TBL_ENTRY(0x737), + TBL_ENTRY(0x738), TBL_ENTRY(0x739), TBL_ENTRY(0x73a), TBL_ENTRY(0x73b), + TBL_ENTRY(0x73c), TBL_ENTRY(0x73d), TBL_ENTRY(0x73e), TBL_ENTRY(0x73f), + TBL_ENTRY(0x740), TBL_ENTRY(0x741), TBL_ENTRY(0x742), TBL_ENTRY(0x743), + TBL_ENTRY(0x744), TBL_ENTRY(0x745), TBL_ENTRY(0x746), TBL_ENTRY(0x747), + TBL_ENTRY(0x748), TBL_ENTRY(0x749), TBL_ENTRY(0x74a), TBL_ENTRY(0x74b), + TBL_ENTRY(0x74c), TBL_ENTRY(0x74d), TBL_ENTRY(0x74e), TBL_ENTRY(0x74f), + TBL_ENTRY(0x750), TBL_ENTRY(0x751), TBL_ENTRY(0x752), TBL_ENTRY(0x753), + TBL_ENTRY(0x754), TBL_ENTRY(0x755), TBL_ENTRY(0x756), TBL_ENTRY(0x757), + TBL_ENTRY(0x758), TBL_ENTRY(0x759), TBL_ENTRY(0x75a), TBL_ENTRY(0x75b), + TBL_ENTRY(0x75c), TBL_ENTRY(0x75d), TBL_ENTRY(0x75e), TBL_ENTRY(0x75f), + TBL_ENTRY(0x760), TBL_ENTRY(0x761), TBL_ENTRY(0x762), TBL_ENTRY(0x763), + TBL_ENTRY(0x764), TBL_ENTRY(0x765), TBL_ENTRY(0x766), TBL_ENTRY(0x767), + TBL_ENTRY(0x768), TBL_ENTRY(0x769), TBL_ENTRY(0x76a), TBL_ENTRY(0x76b), + TBL_ENTRY(0x76c), TBL_ENTRY(0x76d), TBL_ENTRY(0x76e), TBL_ENTRY(0x76f), + TBL_ENTRY(0x770), TBL_ENTRY(0x771), TBL_ENTRY(0x772), TBL_ENTRY(0x773), + TBL_ENTRY(0x774), TBL_ENTRY(0x775), TBL_ENTRY(0x776), TBL_ENTRY(0x777), + TBL_ENTRY(0x778), TBL_ENTRY(0x779), TBL_ENTRY(0x77a), TBL_ENTRY(0x77b), + TBL_ENTRY(0x77c), TBL_ENTRY(0x77d), TBL_ENTRY(0x77e), TBL_ENTRY(0x77f), + TBL_ENTRY(0x780), TBL_ENTRY(0x781), TBL_ENTRY(0x782), TBL_ENTRY(0x783), + TBL_ENTRY(0x784), TBL_ENTRY(0x785), TBL_ENTRY(0x786), TBL_ENTRY(0x787), + TBL_ENTRY(0x788), TBL_ENTRY(0x789), TBL_ENTRY(0x78a), TBL_ENTRY(0x78b), + TBL_ENTRY(0x78c), TBL_ENTRY(0x78d), TBL_ENTRY(0x78e), TBL_ENTRY(0x78f), + TBL_ENTRY(0x790), TBL_ENTRY(0x791), TBL_ENTRY(0x792), TBL_ENTRY(0x793), + TBL_ENTRY(0x794), TBL_ENTRY(0x795), TBL_ENTRY(0x796), TBL_ENTRY(0x797), + TBL_ENTRY(0x798), TBL_ENTRY(0x799), TBL_ENTRY(0x79a), TBL_ENTRY(0x79b), + TBL_ENTRY(0x79c), TBL_ENTRY(0x79d), TBL_ENTRY(0x79e), TBL_ENTRY(0x79f), + TBL_ENTRY(0x7a0), TBL_ENTRY(0x7a1), TBL_ENTRY(0x7a2), TBL_ENTRY(0x7a3), + TBL_ENTRY(0x7a4), TBL_ENTRY(0x7a5), TBL_ENTRY(0x7a6), TBL_ENTRY(0x7a7), + TBL_ENTRY(0x7a8), TBL_ENTRY(0x7a9), TBL_ENTRY(0x7aa), TBL_ENTRY(0x7ab), + TBL_ENTRY(0x7ac), TBL_ENTRY(0x7ad), TBL_ENTRY(0x7ae), TBL_ENTRY(0x7af), + TBL_ENTRY(0x7b0), TBL_ENTRY(0x7b1), TBL_ENTRY(0x7b2), TBL_ENTRY(0x7b3), + TBL_ENTRY(0x7b4), TBL_ENTRY(0x7b5), TBL_ENTRY(0x7b6), TBL_ENTRY(0x7b7), + TBL_ENTRY(0x7b8), TBL_ENTRY(0x7b9), TBL_ENTRY(0x7ba), TBL_ENTRY(0x7bb), + TBL_ENTRY(0x7bc), TBL_ENTRY(0x7bd), TBL_ENTRY(0x7be), TBL_ENTRY(0x7bf), + TBL_ENTRY(0x7c0), TBL_ENTRY(0x7c1), TBL_ENTRY(0x7c2), TBL_ENTRY(0x7c3), + TBL_ENTRY(0x7c4), TBL_ENTRY(0x7c5), TBL_ENTRY(0x7c6), TBL_ENTRY(0x7c7), + TBL_ENTRY(0x7c8), TBL_ENTRY(0x7c9), TBL_ENTRY(0x7ca), TBL_ENTRY(0x7cb), + TBL_ENTRY(0x7cc), TBL_ENTRY(0x7cd), TBL_ENTRY(0x7ce), TBL_ENTRY(0x7cf), + TBL_ENTRY(0x7d0), TBL_ENTRY(0x7d1), TBL_ENTRY(0x7d2), TBL_ENTRY(0x7d3), + TBL_ENTRY(0x7d4), TBL_ENTRY(0x7d5), TBL_ENTRY(0x7d6), TBL_ENTRY(0x7d7), + TBL_ENTRY(0x7d8), TBL_ENTRY(0x7d9), TBL_ENTRY(0x7da), TBL_ENTRY(0x7db), + TBL_ENTRY(0x7dc), TBL_ENTRY(0x7dd), TBL_ENTRY(0x7de), TBL_ENTRY(0x7df), + TBL_ENTRY(0x7e0), TBL_ENTRY(0x7e1), TBL_ENTRY(0x7e2), TBL_ENTRY(0x7e3), + TBL_ENTRY(0x7e4), TBL_ENTRY(0x7e5), TBL_ENTRY(0x7e6), TBL_ENTRY(0x7e7), + TBL_ENTRY(0x7e8), TBL_ENTRY(0x7e9), TBL_ENTRY(0x7ea), TBL_ENTRY(0x7eb), + TBL_ENTRY(0x7ec), TBL_ENTRY(0x7ed), TBL_ENTRY(0x7ee), TBL_ENTRY(0x7ef), + TBL_ENTRY(0x7f0), TBL_ENTRY(0x7f1), TBL_ENTRY(0x7f2), TBL_ENTRY(0x7f3), + TBL_ENTRY(0x7f4), TBL_ENTRY(0x7f5), TBL_ENTRY(0x7f6), TBL_ENTRY(0x7f7), + TBL_ENTRY(0x7f8), TBL_ENTRY(0x7f9), TBL_ENTRY(0x7fa), TBL_ENTRY(0x7fb), + TBL_ENTRY(0x7fc), TBL_ENTRY(0x7fd), TBL_ENTRY(0x7fe), TBL_ENTRY(0x7ff), + TBL_ENTRY(0x800), TBL_ENTRY(0x801), TBL_ENTRY(0x802), TBL_ENTRY(0x803), + TBL_ENTRY(0x804), TBL_ENTRY(0x805), TBL_ENTRY(0x806), TBL_ENTRY(0x807), + TBL_ENTRY(0x808), TBL_ENTRY(0x809), TBL_ENTRY(0x80a), TBL_ENTRY(0x80b), + TBL_ENTRY(0x80c), TBL_ENTRY(0x80d), TBL_ENTRY(0x80e), TBL_ENTRY(0x80f), + TBL_ENTRY(0x810), TBL_ENTRY(0x811), TBL_ENTRY(0x812), TBL_ENTRY(0x813), + TBL_ENTRY(0x814), TBL_ENTRY(0x815), TBL_ENTRY(0x816), TBL_ENTRY(0x817), + TBL_ENTRY(0x818), TBL_ENTRY(0x819), TBL_ENTRY(0x81a), TBL_ENTRY(0x81b), + TBL_ENTRY(0x81c), TBL_ENTRY(0x81d), TBL_ENTRY(0x81e), TBL_ENTRY(0x81f), + TBL_ENTRY(0x820), TBL_ENTRY(0x821), TBL_ENTRY(0x822), TBL_ENTRY(0x823), + TBL_ENTRY(0x824), TBL_ENTRY(0x825), TBL_ENTRY(0x826), TBL_ENTRY(0x827), + TBL_ENTRY(0x828), TBL_ENTRY(0x829), TBL_ENTRY(0x82a), TBL_ENTRY(0x82b), + TBL_ENTRY(0x82c), TBL_ENTRY(0x82d), TBL_ENTRY(0x82e), TBL_ENTRY(0x82f), + TBL_ENTRY(0x830), TBL_ENTRY(0x831), TBL_ENTRY(0x832), TBL_ENTRY(0x833), + TBL_ENTRY(0x834), TBL_ENTRY(0x835), TBL_ENTRY(0x836), TBL_ENTRY(0x837), + TBL_ENTRY(0x838), TBL_ENTRY(0x839), TBL_ENTRY(0x83a), TBL_ENTRY(0x83b), + TBL_ENTRY(0x83c), TBL_ENTRY(0x83d), TBL_ENTRY(0x83e), TBL_ENTRY(0x83f), + TBL_ENTRY(0x840), TBL_ENTRY(0x841), TBL_ENTRY(0x842), TBL_ENTRY(0x843), + TBL_ENTRY(0x844), TBL_ENTRY(0x845), TBL_ENTRY(0x846), TBL_ENTRY(0x847), + TBL_ENTRY(0x848), TBL_ENTRY(0x849), TBL_ENTRY(0x84a), TBL_ENTRY(0x84b), + TBL_ENTRY(0x84c), TBL_ENTRY(0x84d), TBL_ENTRY(0x84e), TBL_ENTRY(0x84f), + TBL_ENTRY(0x850), TBL_ENTRY(0x851), TBL_ENTRY(0x852), TBL_ENTRY(0x853), + TBL_ENTRY(0x854), TBL_ENTRY(0x855), TBL_ENTRY(0x856), TBL_ENTRY(0x857), + TBL_ENTRY(0x858), TBL_ENTRY(0x859), TBL_ENTRY(0x85a), TBL_ENTRY(0x85b), + TBL_ENTRY(0x85c), TBL_ENTRY(0x85d), TBL_ENTRY(0x85e), TBL_ENTRY(0x85f), + TBL_ENTRY(0x860), TBL_ENTRY(0x861), TBL_ENTRY(0x862), TBL_ENTRY(0x863), + TBL_ENTRY(0x864), TBL_ENTRY(0x865), TBL_ENTRY(0x866), TBL_ENTRY(0x867), + TBL_ENTRY(0x868), TBL_ENTRY(0x869), TBL_ENTRY(0x86a), TBL_ENTRY(0x86b), + TBL_ENTRY(0x86c), TBL_ENTRY(0x86d), TBL_ENTRY(0x86e), TBL_ENTRY(0x86f), + TBL_ENTRY(0x870), TBL_ENTRY(0x871), TBL_ENTRY(0x872), TBL_ENTRY(0x873), + TBL_ENTRY(0x874), TBL_ENTRY(0x875), TBL_ENTRY(0x876), TBL_ENTRY(0x877), + TBL_ENTRY(0x878), TBL_ENTRY(0x879), TBL_ENTRY(0x87a), TBL_ENTRY(0x87b), + TBL_ENTRY(0x87c), TBL_ENTRY(0x87d), TBL_ENTRY(0x87e), TBL_ENTRY(0x87f), + TBL_ENTRY(0x880), TBL_ENTRY(0x881), TBL_ENTRY(0x882), TBL_ENTRY(0x883), + TBL_ENTRY(0x884), TBL_ENTRY(0x885), TBL_ENTRY(0x886), TBL_ENTRY(0x887), + TBL_ENTRY(0x888), TBL_ENTRY(0x889), TBL_ENTRY(0x88a), TBL_ENTRY(0x88b), + TBL_ENTRY(0x88c), TBL_ENTRY(0x88d), TBL_ENTRY(0x88e), TBL_ENTRY(0x88f), + TBL_ENTRY(0x890), TBL_ENTRY(0x891), TBL_ENTRY(0x892), TBL_ENTRY(0x893), + TBL_ENTRY(0x894), TBL_ENTRY(0x895), TBL_ENTRY(0x896), TBL_ENTRY(0x897), + TBL_ENTRY(0x898), TBL_ENTRY(0x899), TBL_ENTRY(0x89a), TBL_ENTRY(0x89b), + TBL_ENTRY(0x89c), TBL_ENTRY(0x89d), TBL_ENTRY(0x89e), TBL_ENTRY(0x89f), + TBL_ENTRY(0x8a0), TBL_ENTRY(0x8a1), TBL_ENTRY(0x8a2), TBL_ENTRY(0x8a3), + TBL_ENTRY(0x8a4), TBL_ENTRY(0x8a5), TBL_ENTRY(0x8a6), TBL_ENTRY(0x8a7), + TBL_ENTRY(0x8a8), TBL_ENTRY(0x8a9), TBL_ENTRY(0x8aa), TBL_ENTRY(0x8ab), + TBL_ENTRY(0x8ac), TBL_ENTRY(0x8ad), TBL_ENTRY(0x8ae), TBL_ENTRY(0x8af), + TBL_ENTRY(0x8b0), TBL_ENTRY(0x8b1), TBL_ENTRY(0x8b2), TBL_ENTRY(0x8b3), + TBL_ENTRY(0x8b4), TBL_ENTRY(0x8b5), TBL_ENTRY(0x8b6), TBL_ENTRY(0x8b7), + TBL_ENTRY(0x8b8), TBL_ENTRY(0x8b9), TBL_ENTRY(0x8ba), TBL_ENTRY(0x8bb), + TBL_ENTRY(0x8bc), TBL_ENTRY(0x8bd), TBL_ENTRY(0x8be), TBL_ENTRY(0x8bf), + TBL_ENTRY(0x8c0), TBL_ENTRY(0x8c1), TBL_ENTRY(0x8c2), TBL_ENTRY(0x8c3), + TBL_ENTRY(0x8c4), TBL_ENTRY(0x8c5), TBL_ENTRY(0x8c6), TBL_ENTRY(0x8c7), + TBL_ENTRY(0x8c8), TBL_ENTRY(0x8c9), TBL_ENTRY(0x8ca), TBL_ENTRY(0x8cb), + TBL_ENTRY(0x8cc), TBL_ENTRY(0x8cd), TBL_ENTRY(0x8ce), TBL_ENTRY(0x8cf), + TBL_ENTRY(0x8d0), TBL_ENTRY(0x8d1), TBL_ENTRY(0x8d2), TBL_ENTRY(0x8d3), + TBL_ENTRY(0x8d4), TBL_ENTRY(0x8d5), TBL_ENTRY(0x8d6), TBL_ENTRY(0x8d7), + TBL_ENTRY(0x8d8), TBL_ENTRY(0x8d9), TBL_ENTRY(0x8da), TBL_ENTRY(0x8db), + TBL_ENTRY(0x8dc), TBL_ENTRY(0x8dd), TBL_ENTRY(0x8de), TBL_ENTRY(0x8df), + TBL_ENTRY(0x8e0), TBL_ENTRY(0x8e1), TBL_ENTRY(0x8e2), TBL_ENTRY(0x8e3), + TBL_ENTRY(0x8e4), TBL_ENTRY(0x8e5), TBL_ENTRY(0x8e6), TBL_ENTRY(0x8e7), + TBL_ENTRY(0x8e8), TBL_ENTRY(0x8e9), TBL_ENTRY(0x8ea), TBL_ENTRY(0x8eb), + TBL_ENTRY(0x8ec), TBL_ENTRY(0x8ed), TBL_ENTRY(0x8ee), TBL_ENTRY(0x8ef), + TBL_ENTRY(0x8f0), TBL_ENTRY(0x8f1), TBL_ENTRY(0x8f2), TBL_ENTRY(0x8f3), + TBL_ENTRY(0x8f4), TBL_ENTRY(0x8f5), TBL_ENTRY(0x8f6), TBL_ENTRY(0x8f7), + TBL_ENTRY(0x8f8), TBL_ENTRY(0x8f9), TBL_ENTRY(0x8fa), TBL_ENTRY(0x8fb), + TBL_ENTRY(0x8fc), TBL_ENTRY(0x8fd), TBL_ENTRY(0x8fe), TBL_ENTRY(0x8ff), + TBL_ENTRY(0x900), TBL_ENTRY(0x901), TBL_ENTRY(0x902), TBL_ENTRY(0x903), + TBL_ENTRY(0x904), TBL_ENTRY(0x905), TBL_ENTRY(0x906), TBL_ENTRY(0x907), + TBL_ENTRY(0x908), TBL_ENTRY(0x909), TBL_ENTRY(0x90a), TBL_ENTRY(0x90b), + TBL_ENTRY(0x90c), TBL_ENTRY(0x90d), TBL_ENTRY(0x90e), TBL_ENTRY(0x90f), + TBL_ENTRY(0x910), TBL_ENTRY(0x911), TBL_ENTRY(0x912), TBL_ENTRY(0x913), + TBL_ENTRY(0x914), TBL_ENTRY(0x915), TBL_ENTRY(0x916), TBL_ENTRY(0x917), + TBL_ENTRY(0x918), TBL_ENTRY(0x919), TBL_ENTRY(0x91a), TBL_ENTRY(0x91b), + TBL_ENTRY(0x91c), TBL_ENTRY(0x91d), TBL_ENTRY(0x91e), TBL_ENTRY(0x91f), + TBL_ENTRY(0x920), TBL_ENTRY(0x921), TBL_ENTRY(0x922), TBL_ENTRY(0x923), + TBL_ENTRY(0x924), TBL_ENTRY(0x925), TBL_ENTRY(0x926), TBL_ENTRY(0x927), + TBL_ENTRY(0x928), TBL_ENTRY(0x929), TBL_ENTRY(0x92a), TBL_ENTRY(0x92b), + TBL_ENTRY(0x92c), TBL_ENTRY(0x92d), TBL_ENTRY(0x92e), TBL_ENTRY(0x92f), + TBL_ENTRY(0x930), TBL_ENTRY(0x931), TBL_ENTRY(0x932), TBL_ENTRY(0x933), + TBL_ENTRY(0x934), TBL_ENTRY(0x935), TBL_ENTRY(0x936), TBL_ENTRY(0x937), + TBL_ENTRY(0x938), TBL_ENTRY(0x939), TBL_ENTRY(0x93a), TBL_ENTRY(0x93b), + TBL_ENTRY(0x93c), TBL_ENTRY(0x93d), TBL_ENTRY(0x93e), TBL_ENTRY(0x93f), + TBL_ENTRY(0x940), TBL_ENTRY(0x941), TBL_ENTRY(0x942), TBL_ENTRY(0x943), + TBL_ENTRY(0x944), TBL_ENTRY(0x945), TBL_ENTRY(0x946), TBL_ENTRY(0x947), + TBL_ENTRY(0x948), TBL_ENTRY(0x949), TBL_ENTRY(0x94a), TBL_ENTRY(0x94b), + TBL_ENTRY(0x94c), TBL_ENTRY(0x94d), TBL_ENTRY(0x94e), TBL_ENTRY(0x94f), + TBL_ENTRY(0x950), TBL_ENTRY(0x951), TBL_ENTRY(0x952), TBL_ENTRY(0x953), + TBL_ENTRY(0x954), TBL_ENTRY(0x955), TBL_ENTRY(0x956), TBL_ENTRY(0x957), + TBL_ENTRY(0x958), TBL_ENTRY(0x959), TBL_ENTRY(0x95a), TBL_ENTRY(0x95b), + TBL_ENTRY(0x95c), TBL_ENTRY(0x95d), TBL_ENTRY(0x95e), TBL_ENTRY(0x95f), + TBL_ENTRY(0x960), TBL_ENTRY(0x961), TBL_ENTRY(0x962), TBL_ENTRY(0x963), + TBL_ENTRY(0x964), TBL_ENTRY(0x965), TBL_ENTRY(0x966), TBL_ENTRY(0x967), + TBL_ENTRY(0x968), TBL_ENTRY(0x969), TBL_ENTRY(0x96a), TBL_ENTRY(0x96b), + TBL_ENTRY(0x96c), TBL_ENTRY(0x96d), TBL_ENTRY(0x96e), TBL_ENTRY(0x96f), + TBL_ENTRY(0x970), TBL_ENTRY(0x971), TBL_ENTRY(0x972), TBL_ENTRY(0x973), + TBL_ENTRY(0x974), TBL_ENTRY(0x975), TBL_ENTRY(0x976), TBL_ENTRY(0x977), + TBL_ENTRY(0x978), TBL_ENTRY(0x979), TBL_ENTRY(0x97a), TBL_ENTRY(0x97b), + TBL_ENTRY(0x97c), TBL_ENTRY(0x97d), TBL_ENTRY(0x97e), TBL_ENTRY(0x97f), + TBL_ENTRY(0x980), TBL_ENTRY(0x981), TBL_ENTRY(0x982), TBL_ENTRY(0x983), + TBL_ENTRY(0x984), TBL_ENTRY(0x985), TBL_ENTRY(0x986), TBL_ENTRY(0x987), + TBL_ENTRY(0x988), TBL_ENTRY(0x989), TBL_ENTRY(0x98a), TBL_ENTRY(0x98b), + TBL_ENTRY(0x98c), TBL_ENTRY(0x98d), TBL_ENTRY(0x98e), TBL_ENTRY(0x98f), + TBL_ENTRY(0x990), TBL_ENTRY(0x991), TBL_ENTRY(0x992), TBL_ENTRY(0x993), + TBL_ENTRY(0x994), TBL_ENTRY(0x995), TBL_ENTRY(0x996), TBL_ENTRY(0x997), + TBL_ENTRY(0x998), TBL_ENTRY(0x999), TBL_ENTRY(0x99a), TBL_ENTRY(0x99b), + TBL_ENTRY(0x99c), TBL_ENTRY(0x99d), TBL_ENTRY(0x99e), TBL_ENTRY(0x99f), + TBL_ENTRY(0x9a0), TBL_ENTRY(0x9a1), TBL_ENTRY(0x9a2), TBL_ENTRY(0x9a3), + TBL_ENTRY(0x9a4), TBL_ENTRY(0x9a5), TBL_ENTRY(0x9a6), TBL_ENTRY(0x9a7), + TBL_ENTRY(0x9a8), TBL_ENTRY(0x9a9), TBL_ENTRY(0x9aa), TBL_ENTRY(0x9ab), + TBL_ENTRY(0x9ac), TBL_ENTRY(0x9ad), TBL_ENTRY(0x9ae), TBL_ENTRY(0x9af), + TBL_ENTRY(0x9b0), TBL_ENTRY(0x9b1), TBL_ENTRY(0x9b2), TBL_ENTRY(0x9b3), + TBL_ENTRY(0x9b4), TBL_ENTRY(0x9b5), TBL_ENTRY(0x9b6), TBL_ENTRY(0x9b7), + TBL_ENTRY(0x9b8), TBL_ENTRY(0x9b9), TBL_ENTRY(0x9ba), TBL_ENTRY(0x9bb), + TBL_ENTRY(0x9bc), TBL_ENTRY(0x9bd), TBL_ENTRY(0x9be), TBL_ENTRY(0x9bf), + TBL_ENTRY(0x9c0), TBL_ENTRY(0x9c1), TBL_ENTRY(0x9c2), TBL_ENTRY(0x9c3), + TBL_ENTRY(0x9c4), TBL_ENTRY(0x9c5), TBL_ENTRY(0x9c6), TBL_ENTRY(0x9c7), + TBL_ENTRY(0x9c8), TBL_ENTRY(0x9c9), TBL_ENTRY(0x9ca), TBL_ENTRY(0x9cb), + TBL_ENTRY(0x9cc), TBL_ENTRY(0x9cd), TBL_ENTRY(0x9ce), TBL_ENTRY(0x9cf), + TBL_ENTRY(0x9d0), TBL_ENTRY(0x9d1), TBL_ENTRY(0x9d2), TBL_ENTRY(0x9d3), + TBL_ENTRY(0x9d4), TBL_ENTRY(0x9d5), TBL_ENTRY(0x9d6), TBL_ENTRY(0x9d7), + TBL_ENTRY(0x9d8), TBL_ENTRY(0x9d9), TBL_ENTRY(0x9da), TBL_ENTRY(0x9db), + TBL_ENTRY(0x9dc), TBL_ENTRY(0x9dd), TBL_ENTRY(0x9de), TBL_ENTRY(0x9df), + TBL_ENTRY(0x9e0), TBL_ENTRY(0x9e1), TBL_ENTRY(0x9e2), TBL_ENTRY(0x9e3), + TBL_ENTRY(0x9e4), TBL_ENTRY(0x9e5), TBL_ENTRY(0x9e6), TBL_ENTRY(0x9e7), + TBL_ENTRY(0x9e8), TBL_ENTRY(0x9e9), TBL_ENTRY(0x9ea), TBL_ENTRY(0x9eb), + TBL_ENTRY(0x9ec), TBL_ENTRY(0x9ed), TBL_ENTRY(0x9ee), TBL_ENTRY(0x9ef), + TBL_ENTRY(0x9f0), TBL_ENTRY(0x9f1), TBL_ENTRY(0x9f2), TBL_ENTRY(0x9f3), + TBL_ENTRY(0x9f4), TBL_ENTRY(0x9f5), TBL_ENTRY(0x9f6), TBL_ENTRY(0x9f7), + TBL_ENTRY(0x9f8), TBL_ENTRY(0x9f9), TBL_ENTRY(0x9fa), TBL_ENTRY(0x9fb), + TBL_ENTRY(0x9fc), TBL_ENTRY(0x9fd), TBL_ENTRY(0x9fe), TBL_ENTRY(0x9ff), + TBL_ENTRY(0xa00), TBL_ENTRY(0xa01), TBL_ENTRY(0xa02), TBL_ENTRY(0xa03), + TBL_ENTRY(0xa04), TBL_ENTRY(0xa05), TBL_ENTRY(0xa06), TBL_ENTRY(0xa07), + TBL_ENTRY(0xa08), TBL_ENTRY(0xa09), TBL_ENTRY(0xa0a), TBL_ENTRY(0xa0b), + TBL_ENTRY(0xa0c), TBL_ENTRY(0xa0d), TBL_ENTRY(0xa0e), TBL_ENTRY(0xa0f), + TBL_ENTRY(0xa10), TBL_ENTRY(0xa11), TBL_ENTRY(0xa12), TBL_ENTRY(0xa13), + TBL_ENTRY(0xa14), TBL_ENTRY(0xa15), TBL_ENTRY(0xa16), TBL_ENTRY(0xa17), + TBL_ENTRY(0xa18), TBL_ENTRY(0xa19), TBL_ENTRY(0xa1a), TBL_ENTRY(0xa1b), + TBL_ENTRY(0xa1c), TBL_ENTRY(0xa1d), TBL_ENTRY(0xa1e), TBL_ENTRY(0xa1f), + TBL_ENTRY(0xa20), TBL_ENTRY(0xa21), TBL_ENTRY(0xa22), TBL_ENTRY(0xa23), + TBL_ENTRY(0xa24), TBL_ENTRY(0xa25), TBL_ENTRY(0xa26), TBL_ENTRY(0xa27), + TBL_ENTRY(0xa28), TBL_ENTRY(0xa29), TBL_ENTRY(0xa2a), TBL_ENTRY(0xa2b), + TBL_ENTRY(0xa2c), TBL_ENTRY(0xa2d), TBL_ENTRY(0xa2e), TBL_ENTRY(0xa2f), + TBL_ENTRY(0xa30), TBL_ENTRY(0xa31), TBL_ENTRY(0xa32), TBL_ENTRY(0xa33), + TBL_ENTRY(0xa34), TBL_ENTRY(0xa35), TBL_ENTRY(0xa36), TBL_ENTRY(0xa37), + TBL_ENTRY(0xa38), TBL_ENTRY(0xa39), TBL_ENTRY(0xa3a), TBL_ENTRY(0xa3b), + TBL_ENTRY(0xa3c), TBL_ENTRY(0xa3d), TBL_ENTRY(0xa3e), TBL_ENTRY(0xa3f), + TBL_ENTRY(0xa40), TBL_ENTRY(0xa41), TBL_ENTRY(0xa42), TBL_ENTRY(0xa43), + TBL_ENTRY(0xa44), TBL_ENTRY(0xa45), TBL_ENTRY(0xa46), TBL_ENTRY(0xa47), + TBL_ENTRY(0xa48), TBL_ENTRY(0xa49), TBL_ENTRY(0xa4a), TBL_ENTRY(0xa4b), + TBL_ENTRY(0xa4c), TBL_ENTRY(0xa4d), TBL_ENTRY(0xa4e), TBL_ENTRY(0xa4f), + TBL_ENTRY(0xa50), TBL_ENTRY(0xa51), TBL_ENTRY(0xa52), TBL_ENTRY(0xa53), + TBL_ENTRY(0xa54), TBL_ENTRY(0xa55), TBL_ENTRY(0xa56), TBL_ENTRY(0xa57), + TBL_ENTRY(0xa58), TBL_ENTRY(0xa59), TBL_ENTRY(0xa5a), TBL_ENTRY(0xa5b), + TBL_ENTRY(0xa5c), TBL_ENTRY(0xa5d), TBL_ENTRY(0xa5e), TBL_ENTRY(0xa5f), + TBL_ENTRY(0xa60), TBL_ENTRY(0xa61), TBL_ENTRY(0xa62), TBL_ENTRY(0xa63), + TBL_ENTRY(0xa64), TBL_ENTRY(0xa65), TBL_ENTRY(0xa66), TBL_ENTRY(0xa67), + TBL_ENTRY(0xa68), TBL_ENTRY(0xa69), TBL_ENTRY(0xa6a), TBL_ENTRY(0xa6b), + TBL_ENTRY(0xa6c), TBL_ENTRY(0xa6d), TBL_ENTRY(0xa6e), TBL_ENTRY(0xa6f), + TBL_ENTRY(0xa70), TBL_ENTRY(0xa71), TBL_ENTRY(0xa72), TBL_ENTRY(0xa73), + TBL_ENTRY(0xa74), TBL_ENTRY(0xa75), TBL_ENTRY(0xa76), TBL_ENTRY(0xa77), + TBL_ENTRY(0xa78), TBL_ENTRY(0xa79), TBL_ENTRY(0xa7a), TBL_ENTRY(0xa7b), + TBL_ENTRY(0xa7c), TBL_ENTRY(0xa7d), TBL_ENTRY(0xa7e), TBL_ENTRY(0xa7f), + TBL_ENTRY(0xa80), TBL_ENTRY(0xa81), TBL_ENTRY(0xa82), TBL_ENTRY(0xa83), + TBL_ENTRY(0xa84), TBL_ENTRY(0xa85), TBL_ENTRY(0xa86), TBL_ENTRY(0xa87), + TBL_ENTRY(0xa88), TBL_ENTRY(0xa89), TBL_ENTRY(0xa8a), TBL_ENTRY(0xa8b), + TBL_ENTRY(0xa8c), TBL_ENTRY(0xa8d), TBL_ENTRY(0xa8e), TBL_ENTRY(0xa8f), + TBL_ENTRY(0xa90), TBL_ENTRY(0xa91), TBL_ENTRY(0xa92), TBL_ENTRY(0xa93), + TBL_ENTRY(0xa94), TBL_ENTRY(0xa95), TBL_ENTRY(0xa96), TBL_ENTRY(0xa97), + TBL_ENTRY(0xa98), TBL_ENTRY(0xa99), TBL_ENTRY(0xa9a), TBL_ENTRY(0xa9b), + TBL_ENTRY(0xa9c), TBL_ENTRY(0xa9d), TBL_ENTRY(0xa9e), TBL_ENTRY(0xa9f), + TBL_ENTRY(0xaa0), TBL_ENTRY(0xaa1), TBL_ENTRY(0xaa2), TBL_ENTRY(0xaa3), + TBL_ENTRY(0xaa4), TBL_ENTRY(0xaa5), TBL_ENTRY(0xaa6), TBL_ENTRY(0xaa7), + TBL_ENTRY(0xaa8), TBL_ENTRY(0xaa9), TBL_ENTRY(0xaaa), TBL_ENTRY(0xaab), + TBL_ENTRY(0xaac), TBL_ENTRY(0xaad), TBL_ENTRY(0xaae), TBL_ENTRY(0xaaf), + TBL_ENTRY(0xab0), TBL_ENTRY(0xab1), TBL_ENTRY(0xab2), TBL_ENTRY(0xab3), + TBL_ENTRY(0xab4), TBL_ENTRY(0xab5), TBL_ENTRY(0xab6), TBL_ENTRY(0xab7), + TBL_ENTRY(0xab8), TBL_ENTRY(0xab9), TBL_ENTRY(0xaba), TBL_ENTRY(0xabb), + TBL_ENTRY(0xabc), TBL_ENTRY(0xabd), TBL_ENTRY(0xabe), TBL_ENTRY(0xabf), + TBL_ENTRY(0xac0), TBL_ENTRY(0xac1), TBL_ENTRY(0xac2), TBL_ENTRY(0xac3), + TBL_ENTRY(0xac4), TBL_ENTRY(0xac5), TBL_ENTRY(0xac6), TBL_ENTRY(0xac7), + TBL_ENTRY(0xac8), TBL_ENTRY(0xac9), TBL_ENTRY(0xaca), TBL_ENTRY(0xacb), + TBL_ENTRY(0xacc), TBL_ENTRY(0xacd), TBL_ENTRY(0xace), TBL_ENTRY(0xacf), + TBL_ENTRY(0xad0), TBL_ENTRY(0xad1), TBL_ENTRY(0xad2), TBL_ENTRY(0xad3), + TBL_ENTRY(0xad4), TBL_ENTRY(0xad5), TBL_ENTRY(0xad6), TBL_ENTRY(0xad7), + TBL_ENTRY(0xad8), TBL_ENTRY(0xad9), TBL_ENTRY(0xada), TBL_ENTRY(0xadb), + TBL_ENTRY(0xadc), TBL_ENTRY(0xadd), TBL_ENTRY(0xade), TBL_ENTRY(0xadf), + TBL_ENTRY(0xae0), TBL_ENTRY(0xae1), TBL_ENTRY(0xae2), TBL_ENTRY(0xae3), + TBL_ENTRY(0xae4), TBL_ENTRY(0xae5), TBL_ENTRY(0xae6), TBL_ENTRY(0xae7), + TBL_ENTRY(0xae8), TBL_ENTRY(0xae9), TBL_ENTRY(0xaea), TBL_ENTRY(0xaeb), + TBL_ENTRY(0xaec), TBL_ENTRY(0xaed), TBL_ENTRY(0xaee), TBL_ENTRY(0xaef), + TBL_ENTRY(0xaf0), TBL_ENTRY(0xaf1), TBL_ENTRY(0xaf2), TBL_ENTRY(0xaf3), + TBL_ENTRY(0xaf4), TBL_ENTRY(0xaf5), TBL_ENTRY(0xaf6), TBL_ENTRY(0xaf7), + TBL_ENTRY(0xaf8), TBL_ENTRY(0xaf9), TBL_ENTRY(0xafa), TBL_ENTRY(0xafb), + TBL_ENTRY(0xafc), TBL_ENTRY(0xafd), TBL_ENTRY(0xafe), TBL_ENTRY(0xaff), + TBL_ENTRY(0xb00), TBL_ENTRY(0xb01), TBL_ENTRY(0xb02), TBL_ENTRY(0xb03), + TBL_ENTRY(0xb04), TBL_ENTRY(0xb05), TBL_ENTRY(0xb06), TBL_ENTRY(0xb07), + TBL_ENTRY(0xb08), TBL_ENTRY(0xb09), TBL_ENTRY(0xb0a), TBL_ENTRY(0xb0b), + TBL_ENTRY(0xb0c), TBL_ENTRY(0xb0d), TBL_ENTRY(0xb0e), TBL_ENTRY(0xb0f), + TBL_ENTRY(0xb10), TBL_ENTRY(0xb11), TBL_ENTRY(0xb12), TBL_ENTRY(0xb13), + TBL_ENTRY(0xb14), TBL_ENTRY(0xb15), TBL_ENTRY(0xb16), TBL_ENTRY(0xb17), + TBL_ENTRY(0xb18), TBL_ENTRY(0xb19), TBL_ENTRY(0xb1a), TBL_ENTRY(0xb1b), + TBL_ENTRY(0xb1c), TBL_ENTRY(0xb1d), TBL_ENTRY(0xb1e), TBL_ENTRY(0xb1f), + TBL_ENTRY(0xb20), TBL_ENTRY(0xb21), TBL_ENTRY(0xb22), TBL_ENTRY(0xb23), + TBL_ENTRY(0xb24), TBL_ENTRY(0xb25), TBL_ENTRY(0xb26), TBL_ENTRY(0xb27), + TBL_ENTRY(0xb28), TBL_ENTRY(0xb29), TBL_ENTRY(0xb2a), TBL_ENTRY(0xb2b), + TBL_ENTRY(0xb2c), TBL_ENTRY(0xb2d), TBL_ENTRY(0xb2e), TBL_ENTRY(0xb2f), + TBL_ENTRY(0xb30), TBL_ENTRY(0xb31), TBL_ENTRY(0xb32), TBL_ENTRY(0xb33), + TBL_ENTRY(0xb34), TBL_ENTRY(0xb35), TBL_ENTRY(0xb36), TBL_ENTRY(0xb37), + TBL_ENTRY(0xb38), TBL_ENTRY(0xb39), TBL_ENTRY(0xb3a), TBL_ENTRY(0xb3b), + TBL_ENTRY(0xb3c), TBL_ENTRY(0xb3d), TBL_ENTRY(0xb3e), TBL_ENTRY(0xb3f), + TBL_ENTRY(0xb40), TBL_ENTRY(0xb41), TBL_ENTRY(0xb42), TBL_ENTRY(0xb43), + TBL_ENTRY(0xb44), TBL_ENTRY(0xb45), TBL_ENTRY(0xb46), TBL_ENTRY(0xb47), + TBL_ENTRY(0xb48), TBL_ENTRY(0xb49), TBL_ENTRY(0xb4a), TBL_ENTRY(0xb4b), + TBL_ENTRY(0xb4c), TBL_ENTRY(0xb4d), TBL_ENTRY(0xb4e), TBL_ENTRY(0xb4f), + TBL_ENTRY(0xb50), TBL_ENTRY(0xb51), TBL_ENTRY(0xb52), TBL_ENTRY(0xb53), + TBL_ENTRY(0xb54), TBL_ENTRY(0xb55), TBL_ENTRY(0xb56), TBL_ENTRY(0xb57), + TBL_ENTRY(0xb58), TBL_ENTRY(0xb59), TBL_ENTRY(0xb5a), TBL_ENTRY(0xb5b), + TBL_ENTRY(0xb5c), TBL_ENTRY(0xb5d), TBL_ENTRY(0xb5e), TBL_ENTRY(0xb5f), + TBL_ENTRY(0xb60), TBL_ENTRY(0xb61), TBL_ENTRY(0xb62), TBL_ENTRY(0xb63), + TBL_ENTRY(0xb64), TBL_ENTRY(0xb65), TBL_ENTRY(0xb66), TBL_ENTRY(0xb67), + TBL_ENTRY(0xb68), TBL_ENTRY(0xb69), TBL_ENTRY(0xb6a), TBL_ENTRY(0xb6b), + TBL_ENTRY(0xb6c), TBL_ENTRY(0xb6d), TBL_ENTRY(0xb6e), TBL_ENTRY(0xb6f), + TBL_ENTRY(0xb70), TBL_ENTRY(0xb71), TBL_ENTRY(0xb72), TBL_ENTRY(0xb73), + TBL_ENTRY(0xb74), TBL_ENTRY(0xb75), TBL_ENTRY(0xb76), TBL_ENTRY(0xb77), + TBL_ENTRY(0xb78), TBL_ENTRY(0xb79), TBL_ENTRY(0xb7a), TBL_ENTRY(0xb7b), + TBL_ENTRY(0xb7c), TBL_ENTRY(0xb7d), TBL_ENTRY(0xb7e), TBL_ENTRY(0xb7f), + TBL_ENTRY(0xb80), TBL_ENTRY(0xb81), TBL_ENTRY(0xb82), TBL_ENTRY(0xb83), + TBL_ENTRY(0xb84), TBL_ENTRY(0xb85), TBL_ENTRY(0xb86), TBL_ENTRY(0xb87), + TBL_ENTRY(0xb88), TBL_ENTRY(0xb89), TBL_ENTRY(0xb8a), TBL_ENTRY(0xb8b), + TBL_ENTRY(0xb8c), TBL_ENTRY(0xb8d), TBL_ENTRY(0xb8e), TBL_ENTRY(0xb8f), + TBL_ENTRY(0xb90), TBL_ENTRY(0xb91), TBL_ENTRY(0xb92), TBL_ENTRY(0xb93), + TBL_ENTRY(0xb94), TBL_ENTRY(0xb95), TBL_ENTRY(0xb96), TBL_ENTRY(0xb97), + TBL_ENTRY(0xb98), TBL_ENTRY(0xb99), TBL_ENTRY(0xb9a), TBL_ENTRY(0xb9b), + TBL_ENTRY(0xb9c), TBL_ENTRY(0xb9d), TBL_ENTRY(0xb9e), TBL_ENTRY(0xb9f), + TBL_ENTRY(0xba0), TBL_ENTRY(0xba1), TBL_ENTRY(0xba2), TBL_ENTRY(0xba3), + TBL_ENTRY(0xba4), TBL_ENTRY(0xba5), TBL_ENTRY(0xba6), TBL_ENTRY(0xba7), + TBL_ENTRY(0xba8), TBL_ENTRY(0xba9), TBL_ENTRY(0xbaa), TBL_ENTRY(0xbab), + TBL_ENTRY(0xbac), TBL_ENTRY(0xbad), TBL_ENTRY(0xbae), TBL_ENTRY(0xbaf), + TBL_ENTRY(0xbb0), TBL_ENTRY(0xbb1), TBL_ENTRY(0xbb2), TBL_ENTRY(0xbb3), + TBL_ENTRY(0xbb4), TBL_ENTRY(0xbb5), TBL_ENTRY(0xbb6), TBL_ENTRY(0xbb7), + TBL_ENTRY(0xbb8), TBL_ENTRY(0xbb9), TBL_ENTRY(0xbba), TBL_ENTRY(0xbbb), + TBL_ENTRY(0xbbc), TBL_ENTRY(0xbbd), TBL_ENTRY(0xbbe), TBL_ENTRY(0xbbf), + TBL_ENTRY(0xbc0), TBL_ENTRY(0xbc1), TBL_ENTRY(0xbc2), TBL_ENTRY(0xbc3), + TBL_ENTRY(0xbc4), TBL_ENTRY(0xbc5), TBL_ENTRY(0xbc6), TBL_ENTRY(0xbc7), + TBL_ENTRY(0xbc8), TBL_ENTRY(0xbc9), TBL_ENTRY(0xbca), TBL_ENTRY(0xbcb), + TBL_ENTRY(0xbcc), TBL_ENTRY(0xbcd), TBL_ENTRY(0xbce), TBL_ENTRY(0xbcf), + TBL_ENTRY(0xbd0), TBL_ENTRY(0xbd1), TBL_ENTRY(0xbd2), TBL_ENTRY(0xbd3), + TBL_ENTRY(0xbd4), TBL_ENTRY(0xbd5), TBL_ENTRY(0xbd6), TBL_ENTRY(0xbd7), + TBL_ENTRY(0xbd8), TBL_ENTRY(0xbd9), TBL_ENTRY(0xbda), TBL_ENTRY(0xbdb), + TBL_ENTRY(0xbdc), TBL_ENTRY(0xbdd), TBL_ENTRY(0xbde), TBL_ENTRY(0xbdf), + TBL_ENTRY(0xbe0), TBL_ENTRY(0xbe1), TBL_ENTRY(0xbe2), TBL_ENTRY(0xbe3), + TBL_ENTRY(0xbe4), TBL_ENTRY(0xbe5), TBL_ENTRY(0xbe6), TBL_ENTRY(0xbe7), + TBL_ENTRY(0xbe8), TBL_ENTRY(0xbe9), TBL_ENTRY(0xbea), TBL_ENTRY(0xbeb), + TBL_ENTRY(0xbec), TBL_ENTRY(0xbed), TBL_ENTRY(0xbee), TBL_ENTRY(0xbef), + TBL_ENTRY(0xbf0), TBL_ENTRY(0xbf1), TBL_ENTRY(0xbf2), TBL_ENTRY(0xbf3), + TBL_ENTRY(0xbf4), TBL_ENTRY(0xbf5), TBL_ENTRY(0xbf6), TBL_ENTRY(0xbf7), + TBL_ENTRY(0xbf8), TBL_ENTRY(0xbf9), TBL_ENTRY(0xbfa), TBL_ENTRY(0xbfb), + TBL_ENTRY(0xbfc), TBL_ENTRY(0xbfd), TBL_ENTRY(0xbfe), TBL_ENTRY(0xbff), + TBL_ENTRY(0xc00), TBL_ENTRY(0xc01), TBL_ENTRY(0xc02), TBL_ENTRY(0xc03), + TBL_ENTRY(0xc04), TBL_ENTRY(0xc05), TBL_ENTRY(0xc06), TBL_ENTRY(0xc07), + TBL_ENTRY(0xc08), TBL_ENTRY(0xc09), TBL_ENTRY(0xc0a), TBL_ENTRY(0xc0b), + TBL_ENTRY(0xc0c), TBL_ENTRY(0xc0d), TBL_ENTRY(0xc0e), TBL_ENTRY(0xc0f), + TBL_ENTRY(0xc10), TBL_ENTRY(0xc11), TBL_ENTRY(0xc12), TBL_ENTRY(0xc13), + TBL_ENTRY(0xc14), TBL_ENTRY(0xc15), TBL_ENTRY(0xc16), TBL_ENTRY(0xc17), + TBL_ENTRY(0xc18), TBL_ENTRY(0xc19), TBL_ENTRY(0xc1a), TBL_ENTRY(0xc1b), + TBL_ENTRY(0xc1c), TBL_ENTRY(0xc1d), TBL_ENTRY(0xc1e), TBL_ENTRY(0xc1f), + TBL_ENTRY(0xc20), TBL_ENTRY(0xc21), TBL_ENTRY(0xc22), TBL_ENTRY(0xc23), + TBL_ENTRY(0xc24), TBL_ENTRY(0xc25), TBL_ENTRY(0xc26), TBL_ENTRY(0xc27), + TBL_ENTRY(0xc28), TBL_ENTRY(0xc29), TBL_ENTRY(0xc2a), TBL_ENTRY(0xc2b), + TBL_ENTRY(0xc2c), TBL_ENTRY(0xc2d), TBL_ENTRY(0xc2e), TBL_ENTRY(0xc2f), + TBL_ENTRY(0xc30), TBL_ENTRY(0xc31), TBL_ENTRY(0xc32), TBL_ENTRY(0xc33), + TBL_ENTRY(0xc34), TBL_ENTRY(0xc35), TBL_ENTRY(0xc36), TBL_ENTRY(0xc37), + TBL_ENTRY(0xc38), TBL_ENTRY(0xc39), TBL_ENTRY(0xc3a), TBL_ENTRY(0xc3b), + TBL_ENTRY(0xc3c), TBL_ENTRY(0xc3d), TBL_ENTRY(0xc3e), TBL_ENTRY(0xc3f), + TBL_ENTRY(0xc40), TBL_ENTRY(0xc41), TBL_ENTRY(0xc42), TBL_ENTRY(0xc43), + TBL_ENTRY(0xc44), TBL_ENTRY(0xc45), TBL_ENTRY(0xc46), TBL_ENTRY(0xc47), + TBL_ENTRY(0xc48), TBL_ENTRY(0xc49), TBL_ENTRY(0xc4a), TBL_ENTRY(0xc4b), + TBL_ENTRY(0xc4c), TBL_ENTRY(0xc4d), TBL_ENTRY(0xc4e), TBL_ENTRY(0xc4f), + TBL_ENTRY(0xc50), TBL_ENTRY(0xc51), TBL_ENTRY(0xc52), TBL_ENTRY(0xc53), + TBL_ENTRY(0xc54), TBL_ENTRY(0xc55), TBL_ENTRY(0xc56), TBL_ENTRY(0xc57), + TBL_ENTRY(0xc58), TBL_ENTRY(0xc59), TBL_ENTRY(0xc5a), TBL_ENTRY(0xc5b), + TBL_ENTRY(0xc5c), TBL_ENTRY(0xc5d), TBL_ENTRY(0xc5e), TBL_ENTRY(0xc5f), + TBL_ENTRY(0xc60), TBL_ENTRY(0xc61), TBL_ENTRY(0xc62), TBL_ENTRY(0xc63), + TBL_ENTRY(0xc64), TBL_ENTRY(0xc65), TBL_ENTRY(0xc66), TBL_ENTRY(0xc67), + TBL_ENTRY(0xc68), TBL_ENTRY(0xc69), TBL_ENTRY(0xc6a), TBL_ENTRY(0xc6b), + TBL_ENTRY(0xc6c), TBL_ENTRY(0xc6d), TBL_ENTRY(0xc6e), TBL_ENTRY(0xc6f), + TBL_ENTRY(0xc70), TBL_ENTRY(0xc71), TBL_ENTRY(0xc72), TBL_ENTRY(0xc73), + TBL_ENTRY(0xc74), TBL_ENTRY(0xc75), TBL_ENTRY(0xc76), TBL_ENTRY(0xc77), + TBL_ENTRY(0xc78), TBL_ENTRY(0xc79), TBL_ENTRY(0xc7a), TBL_ENTRY(0xc7b), + TBL_ENTRY(0xc7c), TBL_ENTRY(0xc7d), TBL_ENTRY(0xc7e), TBL_ENTRY(0xc7f), + TBL_ENTRY(0xc80), TBL_ENTRY(0xc81), TBL_ENTRY(0xc82), TBL_ENTRY(0xc83), + TBL_ENTRY(0xc84), TBL_ENTRY(0xc85), TBL_ENTRY(0xc86), TBL_ENTRY(0xc87), + TBL_ENTRY(0xc88), TBL_ENTRY(0xc89), TBL_ENTRY(0xc8a), TBL_ENTRY(0xc8b), + TBL_ENTRY(0xc8c), TBL_ENTRY(0xc8d), TBL_ENTRY(0xc8e), TBL_ENTRY(0xc8f), + TBL_ENTRY(0xc90), TBL_ENTRY(0xc91), TBL_ENTRY(0xc92), TBL_ENTRY(0xc93), + TBL_ENTRY(0xc94), TBL_ENTRY(0xc95), TBL_ENTRY(0xc96), TBL_ENTRY(0xc97), + TBL_ENTRY(0xc98), TBL_ENTRY(0xc99), TBL_ENTRY(0xc9a), TBL_ENTRY(0xc9b), + TBL_ENTRY(0xc9c), TBL_ENTRY(0xc9d), TBL_ENTRY(0xc9e), TBL_ENTRY(0xc9f), + TBL_ENTRY(0xca0), TBL_ENTRY(0xca1), TBL_ENTRY(0xca2), TBL_ENTRY(0xca3), + TBL_ENTRY(0xca4), TBL_ENTRY(0xca5), TBL_ENTRY(0xca6), TBL_ENTRY(0xca7), + TBL_ENTRY(0xca8), TBL_ENTRY(0xca9), TBL_ENTRY(0xcaa), TBL_ENTRY(0xcab), + TBL_ENTRY(0xcac), TBL_ENTRY(0xcad), TBL_ENTRY(0xcae), TBL_ENTRY(0xcaf), + TBL_ENTRY(0xcb0), TBL_ENTRY(0xcb1), TBL_ENTRY(0xcb2), TBL_ENTRY(0xcb3), + TBL_ENTRY(0xcb4), TBL_ENTRY(0xcb5), TBL_ENTRY(0xcb6), TBL_ENTRY(0xcb7), + TBL_ENTRY(0xcb8), TBL_ENTRY(0xcb9), TBL_ENTRY(0xcba), TBL_ENTRY(0xcbb), + TBL_ENTRY(0xcbc), TBL_ENTRY(0xcbd), TBL_ENTRY(0xcbe), TBL_ENTRY(0xcbf), + TBL_ENTRY(0xcc0), TBL_ENTRY(0xcc1), TBL_ENTRY(0xcc2), TBL_ENTRY(0xcc3), + TBL_ENTRY(0xcc4), TBL_ENTRY(0xcc5), TBL_ENTRY(0xcc6), TBL_ENTRY(0xcc7), + TBL_ENTRY(0xcc8), TBL_ENTRY(0xcc9), TBL_ENTRY(0xcca), TBL_ENTRY(0xccb), + TBL_ENTRY(0xccc), TBL_ENTRY(0xccd), TBL_ENTRY(0xcce), TBL_ENTRY(0xccf), + TBL_ENTRY(0xcd0), TBL_ENTRY(0xcd1), TBL_ENTRY(0xcd2), TBL_ENTRY(0xcd3), + TBL_ENTRY(0xcd4), TBL_ENTRY(0xcd5), TBL_ENTRY(0xcd6), TBL_ENTRY(0xcd7), + TBL_ENTRY(0xcd8), TBL_ENTRY(0xcd9), TBL_ENTRY(0xcda), TBL_ENTRY(0xcdb), + TBL_ENTRY(0xcdc), TBL_ENTRY(0xcdd), TBL_ENTRY(0xcde), TBL_ENTRY(0xcdf), + TBL_ENTRY(0xce0), TBL_ENTRY(0xce1), TBL_ENTRY(0xce2), TBL_ENTRY(0xce3), + TBL_ENTRY(0xce4), TBL_ENTRY(0xce5), TBL_ENTRY(0xce6), TBL_ENTRY(0xce7), + TBL_ENTRY(0xce8), TBL_ENTRY(0xce9), TBL_ENTRY(0xcea), TBL_ENTRY(0xceb), + TBL_ENTRY(0xcec), TBL_ENTRY(0xced), TBL_ENTRY(0xcee), TBL_ENTRY(0xcef), + TBL_ENTRY(0xcf0), TBL_ENTRY(0xcf1), TBL_ENTRY(0xcf2), TBL_ENTRY(0xcf3), + TBL_ENTRY(0xcf4), TBL_ENTRY(0xcf5), TBL_ENTRY(0xcf6), TBL_ENTRY(0xcf7), + TBL_ENTRY(0xcf8), TBL_ENTRY(0xcf9), TBL_ENTRY(0xcfa), TBL_ENTRY(0xcfb), + TBL_ENTRY(0xcfc), TBL_ENTRY(0xcfd), TBL_ENTRY(0xcfe), TBL_ENTRY(0xcff), + TBL_ENTRY(0xd00), TBL_ENTRY(0xd01), TBL_ENTRY(0xd02), TBL_ENTRY(0xd03), + TBL_ENTRY(0xd04), TBL_ENTRY(0xd05), TBL_ENTRY(0xd06), TBL_ENTRY(0xd07), + TBL_ENTRY(0xd08), TBL_ENTRY(0xd09), TBL_ENTRY(0xd0a), TBL_ENTRY(0xd0b), + TBL_ENTRY(0xd0c), TBL_ENTRY(0xd0d), TBL_ENTRY(0xd0e), TBL_ENTRY(0xd0f), + TBL_ENTRY(0xd10), TBL_ENTRY(0xd11), TBL_ENTRY(0xd12), TBL_ENTRY(0xd13), + TBL_ENTRY(0xd14), TBL_ENTRY(0xd15), TBL_ENTRY(0xd16), TBL_ENTRY(0xd17), + TBL_ENTRY(0xd18), TBL_ENTRY(0xd19), TBL_ENTRY(0xd1a), TBL_ENTRY(0xd1b), + TBL_ENTRY(0xd1c), TBL_ENTRY(0xd1d), TBL_ENTRY(0xd1e), TBL_ENTRY(0xd1f), + TBL_ENTRY(0xd20), TBL_ENTRY(0xd21), TBL_ENTRY(0xd22), TBL_ENTRY(0xd23), + TBL_ENTRY(0xd24), TBL_ENTRY(0xd25), TBL_ENTRY(0xd26), TBL_ENTRY(0xd27), + TBL_ENTRY(0xd28), TBL_ENTRY(0xd29), TBL_ENTRY(0xd2a), TBL_ENTRY(0xd2b), + TBL_ENTRY(0xd2c), TBL_ENTRY(0xd2d), TBL_ENTRY(0xd2e), TBL_ENTRY(0xd2f), + TBL_ENTRY(0xd30), TBL_ENTRY(0xd31), TBL_ENTRY(0xd32), TBL_ENTRY(0xd33), + TBL_ENTRY(0xd34), TBL_ENTRY(0xd35), TBL_ENTRY(0xd36), TBL_ENTRY(0xd37), + TBL_ENTRY(0xd38), TBL_ENTRY(0xd39), TBL_ENTRY(0xd3a), TBL_ENTRY(0xd3b), + TBL_ENTRY(0xd3c), TBL_ENTRY(0xd3d), TBL_ENTRY(0xd3e), TBL_ENTRY(0xd3f), + TBL_ENTRY(0xd40), TBL_ENTRY(0xd41), TBL_ENTRY(0xd42), TBL_ENTRY(0xd43), + TBL_ENTRY(0xd44), TBL_ENTRY(0xd45), TBL_ENTRY(0xd46), TBL_ENTRY(0xd47), + TBL_ENTRY(0xd48), TBL_ENTRY(0xd49), TBL_ENTRY(0xd4a), TBL_ENTRY(0xd4b), + TBL_ENTRY(0xd4c), TBL_ENTRY(0xd4d), TBL_ENTRY(0xd4e), TBL_ENTRY(0xd4f), + TBL_ENTRY(0xd50), TBL_ENTRY(0xd51), TBL_ENTRY(0xd52), TBL_ENTRY(0xd53), + TBL_ENTRY(0xd54), TBL_ENTRY(0xd55), TBL_ENTRY(0xd56), TBL_ENTRY(0xd57), + TBL_ENTRY(0xd58), TBL_ENTRY(0xd59), TBL_ENTRY(0xd5a), TBL_ENTRY(0xd5b), + TBL_ENTRY(0xd5c), TBL_ENTRY(0xd5d), TBL_ENTRY(0xd5e), TBL_ENTRY(0xd5f), + TBL_ENTRY(0xd60), TBL_ENTRY(0xd61), TBL_ENTRY(0xd62), TBL_ENTRY(0xd63), + TBL_ENTRY(0xd64), TBL_ENTRY(0xd65), TBL_ENTRY(0xd66), TBL_ENTRY(0xd67), + TBL_ENTRY(0xd68), TBL_ENTRY(0xd69), TBL_ENTRY(0xd6a), TBL_ENTRY(0xd6b), + TBL_ENTRY(0xd6c), TBL_ENTRY(0xd6d), TBL_ENTRY(0xd6e), TBL_ENTRY(0xd6f), + TBL_ENTRY(0xd70), TBL_ENTRY(0xd71), TBL_ENTRY(0xd72), TBL_ENTRY(0xd73), + TBL_ENTRY(0xd74), TBL_ENTRY(0xd75), TBL_ENTRY(0xd76), TBL_ENTRY(0xd77), + TBL_ENTRY(0xd78), TBL_ENTRY(0xd79), TBL_ENTRY(0xd7a), TBL_ENTRY(0xd7b), + TBL_ENTRY(0xd7c), TBL_ENTRY(0xd7d), TBL_ENTRY(0xd7e), TBL_ENTRY(0xd7f), + TBL_ENTRY(0xd80), TBL_ENTRY(0xd81), TBL_ENTRY(0xd82), TBL_ENTRY(0xd83), + TBL_ENTRY(0xd84), TBL_ENTRY(0xd85), TBL_ENTRY(0xd86), TBL_ENTRY(0xd87), + TBL_ENTRY(0xd88), TBL_ENTRY(0xd89), TBL_ENTRY(0xd8a), TBL_ENTRY(0xd8b), + TBL_ENTRY(0xd8c), TBL_ENTRY(0xd8d), TBL_ENTRY(0xd8e), TBL_ENTRY(0xd8f), + TBL_ENTRY(0xd90), TBL_ENTRY(0xd91), TBL_ENTRY(0xd92), TBL_ENTRY(0xd93), + TBL_ENTRY(0xd94), TBL_ENTRY(0xd95), TBL_ENTRY(0xd96), TBL_ENTRY(0xd97), + TBL_ENTRY(0xd98), TBL_ENTRY(0xd99), TBL_ENTRY(0xd9a), TBL_ENTRY(0xd9b), + TBL_ENTRY(0xd9c), TBL_ENTRY(0xd9d), TBL_ENTRY(0xd9e), TBL_ENTRY(0xd9f), + TBL_ENTRY(0xda0), TBL_ENTRY(0xda1), TBL_ENTRY(0xda2), TBL_ENTRY(0xda3), + TBL_ENTRY(0xda4), TBL_ENTRY(0xda5), TBL_ENTRY(0xda6), TBL_ENTRY(0xda7), + TBL_ENTRY(0xda8), TBL_ENTRY(0xda9), TBL_ENTRY(0xdaa), TBL_ENTRY(0xdab), + TBL_ENTRY(0xdac), TBL_ENTRY(0xdad), TBL_ENTRY(0xdae), TBL_ENTRY(0xdaf), + TBL_ENTRY(0xdb0), TBL_ENTRY(0xdb1), TBL_ENTRY(0xdb2), TBL_ENTRY(0xdb3), + TBL_ENTRY(0xdb4), TBL_ENTRY(0xdb5), TBL_ENTRY(0xdb6), TBL_ENTRY(0xdb7), + TBL_ENTRY(0xdb8), TBL_ENTRY(0xdb9), TBL_ENTRY(0xdba), TBL_ENTRY(0xdbb), + TBL_ENTRY(0xdbc), TBL_ENTRY(0xdbd), TBL_ENTRY(0xdbe), TBL_ENTRY(0xdbf), + TBL_ENTRY(0xdc0), TBL_ENTRY(0xdc1), TBL_ENTRY(0xdc2), TBL_ENTRY(0xdc3), + TBL_ENTRY(0xdc4), TBL_ENTRY(0xdc5), TBL_ENTRY(0xdc6), TBL_ENTRY(0xdc7), + TBL_ENTRY(0xdc8), TBL_ENTRY(0xdc9), TBL_ENTRY(0xdca), TBL_ENTRY(0xdcb), + TBL_ENTRY(0xdcc), TBL_ENTRY(0xdcd), TBL_ENTRY(0xdce), TBL_ENTRY(0xdcf), + TBL_ENTRY(0xdd0), TBL_ENTRY(0xdd1), TBL_ENTRY(0xdd2), TBL_ENTRY(0xdd3), + TBL_ENTRY(0xdd4), TBL_ENTRY(0xdd5), TBL_ENTRY(0xdd6), TBL_ENTRY(0xdd7), + TBL_ENTRY(0xdd8), TBL_ENTRY(0xdd9), TBL_ENTRY(0xdda), TBL_ENTRY(0xddb), + TBL_ENTRY(0xddc), TBL_ENTRY(0xddd), TBL_ENTRY(0xdde), TBL_ENTRY(0xddf), + TBL_ENTRY(0xde0), TBL_ENTRY(0xde1), TBL_ENTRY(0xde2), TBL_ENTRY(0xde3), + TBL_ENTRY(0xde4), TBL_ENTRY(0xde5), TBL_ENTRY(0xde6), TBL_ENTRY(0xde7), + TBL_ENTRY(0xde8), TBL_ENTRY(0xde9), TBL_ENTRY(0xdea), TBL_ENTRY(0xdeb), + TBL_ENTRY(0xdec), TBL_ENTRY(0xded), TBL_ENTRY(0xdee), TBL_ENTRY(0xdef), + TBL_ENTRY(0xdf0), TBL_ENTRY(0xdf1), TBL_ENTRY(0xdf2), TBL_ENTRY(0xdf3), + TBL_ENTRY(0xdf4), TBL_ENTRY(0xdf5), TBL_ENTRY(0xdf6), TBL_ENTRY(0xdf7), + TBL_ENTRY(0xdf8), TBL_ENTRY(0xdf9), TBL_ENTRY(0xdfa), TBL_ENTRY(0xdfb), + TBL_ENTRY(0xdfc), TBL_ENTRY(0xdfd), TBL_ENTRY(0xdfe), TBL_ENTRY(0xdff), + TBL_ENTRY(0xe00), TBL_ENTRY(0xe01), TBL_ENTRY(0xe02), TBL_ENTRY(0xe03), + TBL_ENTRY(0xe04), TBL_ENTRY(0xe05), TBL_ENTRY(0xe06), TBL_ENTRY(0xe07), + TBL_ENTRY(0xe08), TBL_ENTRY(0xe09), TBL_ENTRY(0xe0a), TBL_ENTRY(0xe0b), + TBL_ENTRY(0xe0c), TBL_ENTRY(0xe0d), TBL_ENTRY(0xe0e), TBL_ENTRY(0xe0f), + TBL_ENTRY(0xe10), TBL_ENTRY(0xe11), TBL_ENTRY(0xe12), TBL_ENTRY(0xe13), + TBL_ENTRY(0xe14), TBL_ENTRY(0xe15), TBL_ENTRY(0xe16), TBL_ENTRY(0xe17), + TBL_ENTRY(0xe18), TBL_ENTRY(0xe19), TBL_ENTRY(0xe1a), TBL_ENTRY(0xe1b), + TBL_ENTRY(0xe1c), TBL_ENTRY(0xe1d), TBL_ENTRY(0xe1e), TBL_ENTRY(0xe1f), + TBL_ENTRY(0xe20), TBL_ENTRY(0xe21), TBL_ENTRY(0xe22), TBL_ENTRY(0xe23), + TBL_ENTRY(0xe24), TBL_ENTRY(0xe25), TBL_ENTRY(0xe26), TBL_ENTRY(0xe27), + TBL_ENTRY(0xe28), TBL_ENTRY(0xe29), TBL_ENTRY(0xe2a), TBL_ENTRY(0xe2b), + TBL_ENTRY(0xe2c), TBL_ENTRY(0xe2d), TBL_ENTRY(0xe2e), TBL_ENTRY(0xe2f), + TBL_ENTRY(0xe30), TBL_ENTRY(0xe31), TBL_ENTRY(0xe32), TBL_ENTRY(0xe33), + TBL_ENTRY(0xe34), TBL_ENTRY(0xe35), TBL_ENTRY(0xe36), TBL_ENTRY(0xe37), + TBL_ENTRY(0xe38), TBL_ENTRY(0xe39), TBL_ENTRY(0xe3a), TBL_ENTRY(0xe3b), + TBL_ENTRY(0xe3c), TBL_ENTRY(0xe3d), TBL_ENTRY(0xe3e), TBL_ENTRY(0xe3f), + TBL_ENTRY(0xe40), TBL_ENTRY(0xe41), TBL_ENTRY(0xe42), TBL_ENTRY(0xe43), + TBL_ENTRY(0xe44), TBL_ENTRY(0xe45), TBL_ENTRY(0xe46), TBL_ENTRY(0xe47), + TBL_ENTRY(0xe48), TBL_ENTRY(0xe49), TBL_ENTRY(0xe4a), TBL_ENTRY(0xe4b), + TBL_ENTRY(0xe4c), TBL_ENTRY(0xe4d), TBL_ENTRY(0xe4e), TBL_ENTRY(0xe4f), + TBL_ENTRY(0xe50), TBL_ENTRY(0xe51), TBL_ENTRY(0xe52), TBL_ENTRY(0xe53), + TBL_ENTRY(0xe54), TBL_ENTRY(0xe55), TBL_ENTRY(0xe56), TBL_ENTRY(0xe57), + TBL_ENTRY(0xe58), TBL_ENTRY(0xe59), TBL_ENTRY(0xe5a), TBL_ENTRY(0xe5b), + TBL_ENTRY(0xe5c), TBL_ENTRY(0xe5d), TBL_ENTRY(0xe5e), TBL_ENTRY(0xe5f), + TBL_ENTRY(0xe60), TBL_ENTRY(0xe61), TBL_ENTRY(0xe62), TBL_ENTRY(0xe63), + TBL_ENTRY(0xe64), TBL_ENTRY(0xe65), TBL_ENTRY(0xe66), TBL_ENTRY(0xe67), + TBL_ENTRY(0xe68), TBL_ENTRY(0xe69), TBL_ENTRY(0xe6a), TBL_ENTRY(0xe6b), + TBL_ENTRY(0xe6c), TBL_ENTRY(0xe6d), TBL_ENTRY(0xe6e), TBL_ENTRY(0xe6f), + TBL_ENTRY(0xe70), TBL_ENTRY(0xe71), TBL_ENTRY(0xe72), TBL_ENTRY(0xe73), + TBL_ENTRY(0xe74), TBL_ENTRY(0xe75), TBL_ENTRY(0xe76), TBL_ENTRY(0xe77), + TBL_ENTRY(0xe78), TBL_ENTRY(0xe79), TBL_ENTRY(0xe7a), TBL_ENTRY(0xe7b), + TBL_ENTRY(0xe7c), TBL_ENTRY(0xe7d), TBL_ENTRY(0xe7e), TBL_ENTRY(0xe7f), + TBL_ENTRY(0xe80), TBL_ENTRY(0xe81), TBL_ENTRY(0xe82), TBL_ENTRY(0xe83), + TBL_ENTRY(0xe84), TBL_ENTRY(0xe85), TBL_ENTRY(0xe86), TBL_ENTRY(0xe87), + TBL_ENTRY(0xe88), TBL_ENTRY(0xe89), TBL_ENTRY(0xe8a), TBL_ENTRY(0xe8b), + TBL_ENTRY(0xe8c), TBL_ENTRY(0xe8d), TBL_ENTRY(0xe8e), TBL_ENTRY(0xe8f), + TBL_ENTRY(0xe90), TBL_ENTRY(0xe91), TBL_ENTRY(0xe92), TBL_ENTRY(0xe93), + TBL_ENTRY(0xe94), TBL_ENTRY(0xe95), TBL_ENTRY(0xe96), TBL_ENTRY(0xe97), + TBL_ENTRY(0xe98), TBL_ENTRY(0xe99), TBL_ENTRY(0xe9a), TBL_ENTRY(0xe9b), + TBL_ENTRY(0xe9c), TBL_ENTRY(0xe9d), TBL_ENTRY(0xe9e), TBL_ENTRY(0xe9f), + TBL_ENTRY(0xea0), TBL_ENTRY(0xea1), TBL_ENTRY(0xea2), TBL_ENTRY(0xea3), + TBL_ENTRY(0xea4), TBL_ENTRY(0xea5), TBL_ENTRY(0xea6), TBL_ENTRY(0xea7), + TBL_ENTRY(0xea8), TBL_ENTRY(0xea9), TBL_ENTRY(0xeaa), TBL_ENTRY(0xeab), + TBL_ENTRY(0xeac), TBL_ENTRY(0xead), TBL_ENTRY(0xeae), TBL_ENTRY(0xeaf), + TBL_ENTRY(0xeb0), TBL_ENTRY(0xeb1), TBL_ENTRY(0xeb2), TBL_ENTRY(0xeb3), + TBL_ENTRY(0xeb4), TBL_ENTRY(0xeb5), TBL_ENTRY(0xeb6), TBL_ENTRY(0xeb7), + TBL_ENTRY(0xeb8), TBL_ENTRY(0xeb9), TBL_ENTRY(0xeba), TBL_ENTRY(0xebb), + TBL_ENTRY(0xebc), TBL_ENTRY(0xebd), TBL_ENTRY(0xebe), TBL_ENTRY(0xebf), + TBL_ENTRY(0xec0), TBL_ENTRY(0xec1), TBL_ENTRY(0xec2), TBL_ENTRY(0xec3), + TBL_ENTRY(0xec4), TBL_ENTRY(0xec5), TBL_ENTRY(0xec6), TBL_ENTRY(0xec7), + TBL_ENTRY(0xec8), TBL_ENTRY(0xec9), TBL_ENTRY(0xeca), TBL_ENTRY(0xecb), + TBL_ENTRY(0xecc), TBL_ENTRY(0xecd), TBL_ENTRY(0xece), TBL_ENTRY(0xecf), + TBL_ENTRY(0xed0), TBL_ENTRY(0xed1), TBL_ENTRY(0xed2), TBL_ENTRY(0xed3), + TBL_ENTRY(0xed4), TBL_ENTRY(0xed5), TBL_ENTRY(0xed6), TBL_ENTRY(0xed7), + TBL_ENTRY(0xed8), TBL_ENTRY(0xed9), TBL_ENTRY(0xeda), TBL_ENTRY(0xedb), + TBL_ENTRY(0xedc), TBL_ENTRY(0xedd), TBL_ENTRY(0xede), TBL_ENTRY(0xedf), + TBL_ENTRY(0xee0), TBL_ENTRY(0xee1), TBL_ENTRY(0xee2), TBL_ENTRY(0xee3), + TBL_ENTRY(0xee4), TBL_ENTRY(0xee5), TBL_ENTRY(0xee6), TBL_ENTRY(0xee7), + TBL_ENTRY(0xee8), TBL_ENTRY(0xee9), TBL_ENTRY(0xeea), TBL_ENTRY(0xeeb), + TBL_ENTRY(0xeec), TBL_ENTRY(0xeed), TBL_ENTRY(0xeee), TBL_ENTRY(0xeef), + TBL_ENTRY(0xef0), TBL_ENTRY(0xef1), TBL_ENTRY(0xef2), TBL_ENTRY(0xef3), + TBL_ENTRY(0xef4), TBL_ENTRY(0xef5), TBL_ENTRY(0xef6), TBL_ENTRY(0xef7), + TBL_ENTRY(0xef8), TBL_ENTRY(0xef9), TBL_ENTRY(0xefa), TBL_ENTRY(0xefb), + TBL_ENTRY(0xefc), TBL_ENTRY(0xefd), TBL_ENTRY(0xefe), TBL_ENTRY(0xeff), + TBL_ENTRY(0xf00), TBL_ENTRY(0xf01), TBL_ENTRY(0xf02), TBL_ENTRY(0xf03), + TBL_ENTRY(0xf04), TBL_ENTRY(0xf05), TBL_ENTRY(0xf06), TBL_ENTRY(0xf07), + TBL_ENTRY(0xf08), TBL_ENTRY(0xf09), TBL_ENTRY(0xf0a), TBL_ENTRY(0xf0b), + TBL_ENTRY(0xf0c), TBL_ENTRY(0xf0d), TBL_ENTRY(0xf0e), TBL_ENTRY(0xf0f), + TBL_ENTRY(0xf10), TBL_ENTRY(0xf11), TBL_ENTRY(0xf12), TBL_ENTRY(0xf13), + TBL_ENTRY(0xf14), TBL_ENTRY(0xf15), TBL_ENTRY(0xf16), TBL_ENTRY(0xf17), + TBL_ENTRY(0xf18), TBL_ENTRY(0xf19), TBL_ENTRY(0xf1a), TBL_ENTRY(0xf1b), + TBL_ENTRY(0xf1c), TBL_ENTRY(0xf1d), TBL_ENTRY(0xf1e), TBL_ENTRY(0xf1f), + TBL_ENTRY(0xf20), TBL_ENTRY(0xf21), TBL_ENTRY(0xf22), TBL_ENTRY(0xf23), + TBL_ENTRY(0xf24), TBL_ENTRY(0xf25), TBL_ENTRY(0xf26), TBL_ENTRY(0xf27), + TBL_ENTRY(0xf28), TBL_ENTRY(0xf29), TBL_ENTRY(0xf2a), TBL_ENTRY(0xf2b), + TBL_ENTRY(0xf2c), TBL_ENTRY(0xf2d), TBL_ENTRY(0xf2e), TBL_ENTRY(0xf2f), + TBL_ENTRY(0xf30), TBL_ENTRY(0xf31), TBL_ENTRY(0xf32), TBL_ENTRY(0xf33), + TBL_ENTRY(0xf34), TBL_ENTRY(0xf35), TBL_ENTRY(0xf36), TBL_ENTRY(0xf37), + TBL_ENTRY(0xf38), TBL_ENTRY(0xf39), TBL_ENTRY(0xf3a), TBL_ENTRY(0xf3b), + TBL_ENTRY(0xf3c), TBL_ENTRY(0xf3d), TBL_ENTRY(0xf3e), TBL_ENTRY(0xf3f), + TBL_ENTRY(0xf40), TBL_ENTRY(0xf41), TBL_ENTRY(0xf42), TBL_ENTRY(0xf43), + TBL_ENTRY(0xf44), TBL_ENTRY(0xf45), TBL_ENTRY(0xf46), TBL_ENTRY(0xf47), + TBL_ENTRY(0xf48), TBL_ENTRY(0xf49), TBL_ENTRY(0xf4a), TBL_ENTRY(0xf4b), + TBL_ENTRY(0xf4c), TBL_ENTRY(0xf4d), TBL_ENTRY(0xf4e), TBL_ENTRY(0xf4f), + TBL_ENTRY(0xf50), TBL_ENTRY(0xf51), TBL_ENTRY(0xf52), TBL_ENTRY(0xf53), + TBL_ENTRY(0xf54), TBL_ENTRY(0xf55), TBL_ENTRY(0xf56), TBL_ENTRY(0xf57), + TBL_ENTRY(0xf58), TBL_ENTRY(0xf59), TBL_ENTRY(0xf5a), TBL_ENTRY(0xf5b), + TBL_ENTRY(0xf5c), TBL_ENTRY(0xf5d), TBL_ENTRY(0xf5e), TBL_ENTRY(0xf5f), + TBL_ENTRY(0xf60), TBL_ENTRY(0xf61), TBL_ENTRY(0xf62), TBL_ENTRY(0xf63), + TBL_ENTRY(0xf64), TBL_ENTRY(0xf65), TBL_ENTRY(0xf66), TBL_ENTRY(0xf67), + TBL_ENTRY(0xf68), TBL_ENTRY(0xf69), TBL_ENTRY(0xf6a), TBL_ENTRY(0xf6b), + TBL_ENTRY(0xf6c), TBL_ENTRY(0xf6d), TBL_ENTRY(0xf6e), TBL_ENTRY(0xf6f), + TBL_ENTRY(0xf70), TBL_ENTRY(0xf71), TBL_ENTRY(0xf72), TBL_ENTRY(0xf73), + TBL_ENTRY(0xf74), TBL_ENTRY(0xf75), TBL_ENTRY(0xf76), TBL_ENTRY(0xf77), + TBL_ENTRY(0xf78), TBL_ENTRY(0xf79), TBL_ENTRY(0xf7a), TBL_ENTRY(0xf7b), + TBL_ENTRY(0xf7c), TBL_ENTRY(0xf7d), TBL_ENTRY(0xf7e), TBL_ENTRY(0xf7f), + TBL_ENTRY(0xf80), TBL_ENTRY(0xf81), TBL_ENTRY(0xf82), TBL_ENTRY(0xf83), + TBL_ENTRY(0xf84), TBL_ENTRY(0xf85), TBL_ENTRY(0xf86), TBL_ENTRY(0xf87), + TBL_ENTRY(0xf88), TBL_ENTRY(0xf89), TBL_ENTRY(0xf8a), TBL_ENTRY(0xf8b), + TBL_ENTRY(0xf8c), TBL_ENTRY(0xf8d), TBL_ENTRY(0xf8e), TBL_ENTRY(0xf8f), + TBL_ENTRY(0xf90), TBL_ENTRY(0xf91), TBL_ENTRY(0xf92), TBL_ENTRY(0xf93), + TBL_ENTRY(0xf94), TBL_ENTRY(0xf95), TBL_ENTRY(0xf96), TBL_ENTRY(0xf97), + TBL_ENTRY(0xf98), TBL_ENTRY(0xf99), TBL_ENTRY(0xf9a), TBL_ENTRY(0xf9b), + TBL_ENTRY(0xf9c), TBL_ENTRY(0xf9d), TBL_ENTRY(0xf9e), TBL_ENTRY(0xf9f), + TBL_ENTRY(0xfa0), TBL_ENTRY(0xfa1), TBL_ENTRY(0xfa2), TBL_ENTRY(0xfa3), + TBL_ENTRY(0xfa4), TBL_ENTRY(0xfa5), TBL_ENTRY(0xfa6), TBL_ENTRY(0xfa7), + TBL_ENTRY(0xfa8), TBL_ENTRY(0xfa9), TBL_ENTRY(0xfaa), TBL_ENTRY(0xfab), + TBL_ENTRY(0xfac), TBL_ENTRY(0xfad), TBL_ENTRY(0xfae), TBL_ENTRY(0xfaf), + TBL_ENTRY(0xfb0), TBL_ENTRY(0xfb1), TBL_ENTRY(0xfb2), TBL_ENTRY(0xfb3), + TBL_ENTRY(0xfb4), TBL_ENTRY(0xfb5), TBL_ENTRY(0xfb6), TBL_ENTRY(0xfb7), + TBL_ENTRY(0xfb8), TBL_ENTRY(0xfb9), TBL_ENTRY(0xfba), TBL_ENTRY(0xfbb), + TBL_ENTRY(0xfbc), TBL_ENTRY(0xfbd), TBL_ENTRY(0xfbe), TBL_ENTRY(0xfbf), + TBL_ENTRY(0xfc0), TBL_ENTRY(0xfc1), TBL_ENTRY(0xfc2), TBL_ENTRY(0xfc3), + TBL_ENTRY(0xfc4), TBL_ENTRY(0xfc5), TBL_ENTRY(0xfc6), TBL_ENTRY(0xfc7), + TBL_ENTRY(0xfc8), TBL_ENTRY(0xfc9), TBL_ENTRY(0xfca), TBL_ENTRY(0xfcb), + TBL_ENTRY(0xfcc), TBL_ENTRY(0xfcd), TBL_ENTRY(0xfce), TBL_ENTRY(0xfcf), + TBL_ENTRY(0xfd0), TBL_ENTRY(0xfd1), TBL_ENTRY(0xfd2), TBL_ENTRY(0xfd3), + TBL_ENTRY(0xfd4), TBL_ENTRY(0xfd5), TBL_ENTRY(0xfd6), TBL_ENTRY(0xfd7), + TBL_ENTRY(0xfd8), TBL_ENTRY(0xfd9), TBL_ENTRY(0xfda), TBL_ENTRY(0xfdb), + TBL_ENTRY(0xfdc), TBL_ENTRY(0xfdd), TBL_ENTRY(0xfde), TBL_ENTRY(0xfdf), + TBL_ENTRY(0xfe0), TBL_ENTRY(0xfe1), TBL_ENTRY(0xfe2), TBL_ENTRY(0xfe3), + TBL_ENTRY(0xfe4), TBL_ENTRY(0xfe5), TBL_ENTRY(0xfe6), TBL_ENTRY(0xfe7), + TBL_ENTRY(0xfe8), TBL_ENTRY(0xfe9), TBL_ENTRY(0xfea), TBL_ENTRY(0xfeb), + TBL_ENTRY(0xfec), TBL_ENTRY(0xfed), TBL_ENTRY(0xfee), TBL_ENTRY(0xfef), + TBL_ENTRY(0xff0), TBL_ENTRY(0xff1), TBL_ENTRY(0xff2), TBL_ENTRY(0xff3), + TBL_ENTRY(0xff4), TBL_ENTRY(0xff5), TBL_ENTRY(0xff6), TBL_ENTRY(0xff7), + TBL_ENTRY(0xff8), TBL_ENTRY(0xff9), TBL_ENTRY(0xffa), TBL_ENTRY(0xffb), + TBL_ENTRY(0xffc), TBL_ENTRY(0xffd), TBL_ENTRY(0xffe), TBL_ENTRY(0xfff), +}; diff --git a/arch/arm/cpu/armv7/uniphier/lowlevel_init.S b/arch/arm/cpu/armv7/uniphier/lowlevel_init.S new file mode 100644 index 0000000..0ea12d3 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/lowlevel_init.S @@ -0,0 +1,159 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/system.h> +#include <asm/arch/led.h> +#include <asm/arch/arm-mpcore.h> +#include <asm/arch/sbc-regs.h> + +ENTRY(lowlevel_init) + mov r8, lr @ persevere link reg across call + + /* + * The UniPhier Boot ROM loads SPL code to the L2 cache. + * But CPUs can only do instruction fetch now because start.S has + * cleared C and M bits. + * First we need to turn on MMU and Dcache again to get back + * data access to L2. + */ + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + orr r0, r0, #(CR_C | CR_M) @ enable MMU and Dcache + mcr p15, 0, r0, c1, c0, 0 + + /* + * Now we are using the page table embedded in the Boot ROM. + * It is not handy since it is not a straight mapped table for sLD3. + * What we need to do next is to switch over to the page table in SPL. + */ + ldr r3, =init_page_table @ page table must be 16KB aligned + + /* Disable MMU and Dcache before switching Page Table */ + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + bic r0, r0, #(CR_C | CR_M) @ disable MMU and Dcache + mcr p15, 0, r0, c1, c0, 0 + + bl enable_mmu + +#ifdef CONFIG_UNIPHIER_SMP + /* + * ACTLR (Auxiliary Control Register) for Cortex-A9 + * bit[9] Parity on + * bit[8] Alloc in one way + * bit[7] EXCL (Exclusive cache bit) + * bit[6] SMP + * bit[3] Write full line of zeros mode + * bit[2] L1 Prefetch enable + * bit[1] L2 prefetch enable + * bit[0] FW (Cache and TLB maintenance broadcast) + */ + mrc p15, 0, r0, c1, c0, 1 @ ACTLR (Auxiliary Control Register) + orr r0, r0, #0x41 @ enable SMP, FW bit + mcr p15, 0, r0, c1, c0, 1 + + /* branch by CPU ID */ + mrc p15, 0, r0, c0, c0, 5 @ MPIDR (Multiprocessor Affinity Register) + and r0, r0, #0x3 + cmp r0, #0x0 + beq primary_cpu + ldr r1, =ROM_BOOT_ROMRSV2 + mov r0, #0 + str r0, [r1] +0: wfe + ldr r0, [r1] + cmp r0, #0 + beq 0b + bx r0 @ r0: entry point of U-Boot main for the secondary CPU +primary_cpu: + ldr r1, =ROM_BOOT_ROMRSV2 + ldr r0, =_start @ entry for the secondary CPU + str r0, [r1] + ldr r0, [r1] @ make sure str is complete before sev + sev @ kick the sedoncary CPU + mrc p15, 4, r1, c15, c0, 0 @ Configuration Base Address Register + bfc r1, #0, #13 @ clear bit 12-0 + mov r0, #-1 + str r0, [r1, #SCU_INV_ALL] @ SCU Invalidate All Register + mov r0, #1 @ SCU enable + str r0, [r1, #SCU_CTRL] @ SCU Control Register +#endif + + bl setup_init_ram @ RAM area for temporary stack pointer + + mov lr, r8 @ restore link + mov pc, lr @ back to my caller +ENDPROC(lowlevel_init) + +ENTRY(enable_mmu) + mrc p15, 0, r0, c2, c0, 2 @ TTBCR (Translation Table Base Control Register) + bic r0, r0, #0x37 + orr r0, r0, #0x20 @ disable TTBR1 + mcr p15, 0, r0, c2, c0, 2 + + orr r0, r3, #0x8 @ Outer Cacheability for table walks: WBWA + mcr p15, 0, r0, c2, c0, 0 @ TTBR0 + + mov r0, #0 + mcr p15, 0, r0, c8, c7, 0 @ invalidate TLBs + + mov r0, #-1 @ manager for all domains (No permission check) + mcr p15, 0, r0, c3, c0, 0 @ DACR (Domain Access Control Register) + + dsb + isb + /* + * MMU on: + * TLBs was already invalidated in "../start.S" + * So, we don't need to invalidate it here. + */ + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + orr r0, r0, #(CR_C | CR_M) @ MMU and Dcache enable + mcr p15, 0, r0, c1, c0, 0 + + mov pc, lr +ENDPROC(enable_mmu) + +#include <asm/arch/ssc-regs.h> + +#define BOOT_RAM_SIZE (SSC_WAY_SIZE) +#define BOOT_WAY_BITS (0x00000100) /* way 8 */ + +ENTRY(setup_init_ram) + /* + * Touch to zero for the boot way + */ +0: + /* + * set SSCOQM, SSCOQAD, SSCOQSZ, SSCOQWN in this order + */ + ldr r0, = 0x00408006 @ touch to zero with address range + ldr r1, = SSCOQM + str r0, [r1] + ldr r0, = (CONFIG_SYS_INIT_SP_ADDR - BOOT_RAM_SIZE) @ base address + ldr r1, = SSCOQAD + str r0, [r1] + ldr r0, = BOOT_RAM_SIZE + ldr r1, = SSCOQSZ + str r0, [r1] + ldr r0, = BOOT_WAY_BITS + ldr r1, = SSCOQWN + str r0, [r1] + ldr r1, = SSCOPPQSEF + ldr r0, [r1] + cmp r0, #0 @ check if the command is successfully set + bne 0b @ try again if an error occurres + + ldr r1, = SSCOLPQS +1: + ldr r0, [r1] + cmp r0, #0x4 + bne 1b @ wait until the operation is completed + str r0, [r1] @ clear the complete notification flag + + mov pc, lr +ENDPROC(setup_init_ram) diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile new file mode 100644 index 0000000..b385e19 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o bcu_init.o \ + sbc_init.o sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SPL_BUILD) += pll_spectrum.o \ + umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c new file mode 100644 index 0000000..85f37f2 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/bcu-regs.h> + +#define ch(x) ((x) >= 32 ? 0 : (x) < 0 ? 0x11111111 : 0x11111111 << (x)) + +void bcu_init(void) +{ + int shift; + + writel(0x44444444, BCSCR0); /* 0x20000000-0x3fffffff: ASM bus */ + writel(0x11111111, BCSCR2); /* 0x80000000-0x9fffffff: IPPC/IPPD-bus */ + writel(0x11111111, BCSCR3); /* 0xa0000000-0xbfffffff: IPPC/IPPD-bus */ + writel(0x11111111, BCSCR4); /* 0xc0000000-0xdfffffff: IPPC/IPPD-bus */ + writel(0x11111111, BCSCR5); /* 0xe0000000-0Xffffffff: IPPC/IPPD-bus */ + + /* Specify DDR channel */ + shift = (CONFIG_SDRAM1_BASE - CONFIG_SDRAM0_BASE) / 0x04000000 * 4; + writel(ch(shift), BCIPPCCHR2); /* 0x80000000-0x9fffffff */ + + shift -= 32; + writel(ch(shift), BCIPPCCHR3); /* 0xa0000000-0xbfffffff */ + + shift -= 32; + writel(ch(shift), BCIPPCCHR4); /* 0xc0000000-0xdfffffff */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c new file mode 100644 index 0000000..27d772e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/board.h> + +int checkboard(void) +{ + puts("Board: PH1-LD4 Board\n"); + + return check_support_card(); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c new file mode 100644 index 0000000..92972e1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c @@ -0,0 +1,42 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> +#include <asm/arch/board.h> + +void bcu_init(void); +void sbc_init(void); +void sg_init(void); +void pll_init(void); +void pin_init(void); +void clkrst_init(void); + +int board_postclk_init(void) +{ + bcu_init(); + + sbc_init(); + + sg_init(); + + pll_init(); + + uniphier_board_init(); + + led_write(B, 1, , ); + + pin_init(); + + led_write(B, 2, , ); + + clkrst_init(); + + led_write(B, 3, , ); + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c new file mode 100644 index 0000000..d359b56 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c @@ -0,0 +1 @@ +#include "../ph1-pro4/boot-mode.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void clkrst_init(void) +{ + u32 tmp; + + /* deassert reset */ + tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 + | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; + writel(tmp, SC_RSTCTRL); + readl(SC_RSTCTRL); /* dummy read */ + + /* privide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC + | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c new file mode 100644 index 0000000..a742940 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c @@ -0,0 +1,63 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void pin_init(void) +{ + u32 tmp; + + /* Comment format: PAD Name -> Function Name */ + +#ifdef CONFIG_UNIPHIER_SERIAL + sg_set_pinsel(85, 1); /* HSDOUT3 -> RXD0 */ + sg_set_pinsel(88, 1); /* HDDOUT6 -> TXD0 */ + + sg_set_pinsel(69, 23); /* PCIOWR -> TXD1 */ + sg_set_pinsel(70, 23); /* PCIORD -> RXD1 */ + + sg_set_pinsel(128, 13); /* XIRQ6 -> TXD2 */ + sg_set_pinsel(129, 13); /* XIRQ7 -> RXD2 */ + + sg_set_pinsel(110, 1); /* SBO0 -> TXD3 */ + sg_set_pinsel(111, 1); /* SBI0 -> RXD3 */ +#endif + +#ifdef CONFIG_NAND_DENALI + sg_set_pinsel(158, 0); /* XNFRE -> XNFRE_GB */ + sg_set_pinsel(159, 0); /* XNFWE -> XNFWE_GB */ + sg_set_pinsel(160, 0); /* XFALE -> NFALE_GB */ + sg_set_pinsel(161, 0); /* XFCLE -> NFCLE_GB */ + sg_set_pinsel(162, 0); /* XNFWP -> XFNWP_GB */ + sg_set_pinsel(163, 0); /* XNFCE0 -> XNFCE0_GB */ + sg_set_pinsel(164, 0); /* NANDRYBY0 -> NANDRYBY0_GB */ + sg_set_pinsel(22, 0); /* MMCCLK -> XFNCE1_GB */ + sg_set_pinsel(23, 0); /* MMCCMD -> NANDRYBY1_GB */ + sg_set_pinsel(24, 0); /* MMCDAT0 -> NFD0_GB */ + sg_set_pinsel(25, 0); /* MMCDAT1 -> NFD1_GB */ + sg_set_pinsel(26, 0); /* MMCDAT2 -> NFD2_GB */ + sg_set_pinsel(27, 0); /* MMCDAT3 -> NFD3_GB */ + sg_set_pinsel(28, 0); /* MMCDAT4 -> NFD4_GB */ + sg_set_pinsel(29, 0); /* MMCDAT5 -> NFD5_GB */ + sg_set_pinsel(30, 0); /* MMCDAT6 -> NFD6_GB */ + sg_set_pinsel(31, 0); /* MMCDAT7 -> NFD7_GB */ +#endif + +#ifdef CONFIG_USB_EHCI_UNIPHIER + sg_set_pinsel(53, 0); /* USB0VBUS -> USB0VBUS */ + sg_set_pinsel(54, 0); /* USB0OD -> USB0OD */ + sg_set_pinsel(55, 0); /* USB1VBUS -> USB1VBUS */ + sg_set_pinsel(56, 0); /* USB1OD -> USB1OD */ + /* sg_set_pinsel(67, 23); */ /* PCOE -> USB2VBUS */ + /* sg_set_pinsel(68, 23); */ /* PCWAIT -> USB2OD */ +#endif + + tmp = readl(SG_IECTRL); + tmp |= 0x41; + writel(tmp, SG_IECTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c new file mode 100644 index 0000000..68b9d5f --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c @@ -0,0 +1,189 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/sg-regs.h> + +#undef DPLL_SSC_RATE_1PER + +void dpll_init(void) +{ + u32 tmp; + + /* + * Set Frequency + * Set 0xc(1600MHz)/0xd(1333MHz)/0xe(1066MHz) + * to FOUT (DPLLCTRL.bit[29:20]) + */ + tmp = readl(SC_DPLLCTRL); + tmp &= ~0x000f0000; +#if CONFIG_DDR_FREQ == 1600 + tmp |= 0x000c0000; +#elif CONFIG_DDR_FREQ == 1333 + tmp |= 0x000d0000; +#else +# error "Unknown frequency" +#endif + +#if defined(DPLL_SSC_RATE_1PER) + tmp &= ~SC_DPLLCTRL_SSC_RATE; +#else + tmp |= SC_DPLLCTRL_SSC_RATE; +#endif + writel(tmp, SC_DPLLCTRL); + + tmp = readl(SC_DPLLCTRL2); + tmp |= SC_DPLLCTRL2_NRSTDS; + writel(tmp, SC_DPLLCTRL2); +} + +void upll_init(void) +{ + u32 tmp, clk_mode_upll, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_upll = tmp & SG_PINMON0_CLK_MODE_UPLLSRC_MASK; + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 0 to SNRT(UPLLCTRL.bit28) and K_LD(UPLLCTRL.bit[27]) */ + tmp = readl(SC_UPLLCTRL); + tmp &= ~0x18000000; + writel(tmp, SC_UPLLCTRL); + + if (clk_mode_upll == SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT) { + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x0228f5c0; + } else { + /* AXO: default 24.576MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x02328000; + } + } + + writel(tmp, SC_UPLLCTRL); + + /* set 1 to K_LD(UPLLCTRL.bit[27]) */ + tmp |= 0x08000000; + writel(tmp, SC_UPLLCTRL); + + /* wait 10 usec */ + udelay(10); + + /* set 1 to SNRT(UPLLCTRL.bit[28]) */ + tmp |= 0x10000000; + writel(tmp, SC_UPLLCTRL); +} + +void vpll_init(void) +{ + u32 tmp, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 1 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27BCTRL); + + /* Set 0 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* Set 0x20 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27BCTRL2); + + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27BCTRL3); + } else { + /* AXO: default 24.576MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27BCTRL3); + } + + /* Set 1 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* wait 10 usec */ + udelay(10); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* set 0 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= ~0x00000001; + writel(tmp, SC_VPLL27BCTRL); +} + +void pll_init(void) +{ + dpll_init(); + upll_init(); + vpll_init(); + + /* + * Wait 500 usec until dpll get stable + * We wait 10 usec in upll_init() and vpll_init() + * so 20 usec can be saved here. + */ + udelay(480); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c new file mode 100644 index 0000000..837b2a8 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c @@ -0,0 +1 @@ +#include "../ph1-pro4/pll_spectrum.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c new file mode 100644 index 0000000..a37ed16 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c @@ -0,0 +1,44 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sbc-regs.h> +#include <asm/arch/sg-regs.h> + +void sbc_init(void) +{ + /* XECS1: sub/boot memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + +#if !defined(CONFIG_SPL_BUILD) + /* XECS0: boot/sub memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); +#endif + /* XECS3: peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); + + /* base address regsiters */ + writel(0x0000bc01, SBBASE0); + writel(0x0400bc01, SBBASE1); + writel(0x0800bf01, SBBASE3); + +#if !defined(CONFIG_SPL_BUILD) + /* enable access to sub memory when boot swap is on */ + sg_set_pinsel(155, 1); /* PORT24 -> XECS0 */ +#endif + sg_set_pinsel(156, 1); /* PORT25 -> XECS3 */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c new file mode 100644 index 0000000..8200959 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c @@ -0,0 +1,28 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void sg_init(void) +{ + u32 tmp; + + /* Set DDR size */ + tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE, CONFIG_DDR_NUM_CH0); + tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE, CONFIG_DDR_NUM_CH1); +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE + tmp |= SG_MEMCONF_SPARSEMEM; +#endif + writel(tmp, SG_MEMCONF); + + /* Must enable in-port before deasserting reset signals of cores */ + tmp = readl(SG_IECTRL); + tmp |= 0x1; + writel(tmp, SG_IECTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c new file mode 100644 index 0000000..e0e586b --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c @@ -0,0 +1,10 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +int umc_init(void) +{ + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile new file mode 100644 index 0000000..712afd1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o sbc_init.o \ + sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SPL_BUILD) += pll_spectrum.o \ + umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c new file mode 100644 index 0000000..325a4f6 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/board.h> + +int checkboard(void) +{ + puts("Board: PH1-Pro4 Board\n"); + + return check_support_card(); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c new file mode 100644 index 0000000..e261513 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c @@ -0,0 +1,39 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> +#include <asm/arch/board.h> + +void sbc_init(void); +void sg_init(void); +void pll_init(void); +void pin_init(void); +void clkrst_init(void); + +int board_postclk_init(void) +{ + sbc_init(); + + sg_init(); + + pll_init(); + + uniphier_board_init(); + + led_write(B, 1, , ); + + pin_init(); + + led_write(B, 2, , ); + + clkrst_init(); + + led_write(B, 3, , ); + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c new file mode 100644 index 0000000..33bccff --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/boot-device.h> +#include <asm/arch/sg-regs.h> +#include <asm/arch/sbc-regs.h> + +struct boot_device_info boot_device_table[] = { + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 128KB, Addr 4)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 24, EraseSize 1MB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 4, ECC 24, EraseSize 1MB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 24, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, ONFI, Addr 4)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 24, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 4, ECC 24, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 24, ONFI, Addr 5)"}, + {BOOT_DEVICE_MMC1, "eMMC Boot (3.3V)"}, + {BOOT_DEVICE_MMC1, "eMMC Boot (1.8V)"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, ""} +}; + +u32 get_boot_mode_sel(void) +{ + return (readl(SG_PINMON0) >> 1) & 0x1f; +} + +u32 spl_boot_device(void) +{ + u32 boot_mode; + + if (boot_is_swapped()) + return BOOT_DEVICE_NOR; + + boot_mode = get_boot_mode_sel(); + + return boot_device_table[boot_mode].type; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void clkrst_init(void) +{ + u32 tmp; + + /* deassert reset */ + tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 + | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; + writel(tmp, SC_RSTCTRL); + readl(SC_RSTCTRL); /* dummy read */ + + /* privide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC + | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c new file mode 100644 index 0000000..503c247 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void pin_init(void) +{ + /* Comment format: PAD Name -> Function Name */ + +#ifdef CONFIG_UNIPHIER_SERIAL + sg_set_pinsel(127, 0); /* RXD0 -> RXD0 */ + sg_set_pinsel(128, 0); /* TXD0 -> TXD0 */ + sg_set_pinsel(129, 0); /* RXD1 -> RXD1 */ + sg_set_pinsel(130, 0); /* TXD1 -> TXD1 */ + sg_set_pinsel(131, 0); /* RXD2 -> RXD2 */ + sg_set_pinsel(132, 0); /* TXD2 -> TXD2 */ + sg_set_pinsel(88, 2); /* CH6CLK -> RXD3 */ + sg_set_pinsel(89, 2); /* CH6VAL -> TXD3 */ +#endif + +#ifdef CONFIG_NAND_DENALI + sg_set_pinsel(40, 0); /* NFD0 -> NFD0 */ + sg_set_pinsel(41, 0); /* NFD1 -> NFD1 */ + sg_set_pinsel(42, 0); /* NFD2 -> NFD2 */ + sg_set_pinsel(43, 0); /* NFD3 -> NFD3 */ + sg_set_pinsel(44, 0); /* NFD4 -> NFD4 */ + sg_set_pinsel(45, 0); /* NFD5 -> NFD5 */ + sg_set_pinsel(46, 0); /* NFD6 -> NFD6 */ + sg_set_pinsel(47, 0); /* NFD7 -> NFD7 */ + sg_set_pinsel(48, 0); /* NFALE -> NFALE */ + sg_set_pinsel(49, 0); /* NFCLE -> NFCLE */ + sg_set_pinsel(50, 0); /* XNFRE -> XNFRE */ + sg_set_pinsel(51, 0); /* XNFWE -> XNFWE */ + sg_set_pinsel(52, 0); /* XNFWP -> XNFWP */ + sg_set_pinsel(53, 0); /* XNFCE0 -> XNFCE0 */ + sg_set_pinsel(54, 0); /* NRYBY0 -> NRYBY0 */ +#endif + + writel(1, SG_LOADPINCTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c new file mode 100644 index 0000000..fd08438 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c @@ -0,0 +1,168 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/sg-regs.h> + +#undef DPLL_SSC_RATE_1PER + +void dpll_init(void) +{ + u32 tmp; + + /* + * Set Frequency + * Set 0xc(1600MHz)/0xd(1333MHz)/0xe(1066MHz) + * to FOUT ( DPLLCTRL.bit[29:20] ) + */ + tmp = readl(SC_DPLLCTRL); + tmp &= ~(0x000f0000); +#if CONFIG_DDR_FREQ == 1600 + tmp |= 0x000c0000; +#elif CONFIG_DDR_FREQ == 1333 + tmp |= 0x000d0000; +#else +# error "Unsupported frequency" +#endif + + /* + * Set Moduration rate + * Set 0x0(1%)/0x1(2%) to SSC_RATE(DPLLCTRL.bit[15]) + */ +#if defined(DPLL_SSC_RATE_1PER) + tmp &= ~0x00008000; +#else + tmp |= 0x00008000; +#endif + writel(tmp, SC_DPLLCTRL); + + tmp = readl(SC_DPLLCTRL2); + tmp |= SC_DPLLCTRL2_NRSTDS; + writel(tmp, SC_DPLLCTRL2); +} + +void stop_mpll(void) +{ + u32 tmp; + + tmp = readl(SC_MPLLOSCCTL); + + if (!(tmp & SC_MPLLOSCCTL_MPLLST)) + return; /* already stopped */ + + tmp &= ~SC_MPLLOSCCTL_MPLLEN; + writel(tmp, SC_MPLLOSCCTL); + + while (readl(SC_MPLLOSCCTL) & SC_MPLLOSCCTL_MPLLST) + ; +} + +void vpll_init(void) +{ + u32 tmp, clk_mode_axosel; + + /* Set VPLL27A & VPLL27B */ + tmp = readl(SG_PINMON0); + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + +#if defined(CONFIG_PH1_PRO4) + /* 25MHz or 6.25MHz is default for Pro4R, no need to set VPLLA/B */ + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ) + return; +#endif + + /* Disable write protect of VPLL27ACTRL[2-7]*, VPLL27BCTRL[2-8] */ + tmp = readl(SC_VPLL27ACTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27BCTRL); + + /* Unset VPLA_K_LD and VPLB_K_LD bit */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Set VPLA_M and VPLB_M to 0x20 */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27BCTRL2); + + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ) { + /* Set VPLA_K and VPLB_K for AXO: 25MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066666; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066666; + writel(tmp, SC_VPLL27BCTRL3); + } else { + /* Set VPLA_K and VPLB_K for AXO: 24.576 MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27BCTRL3); + } + + /* wait 1 usec */ + udelay(1); + + /* Set VPLA_K_LD and VPLB_K_LD to load K parameters */ + tmp = readl(SC_VPLL27ACTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Unset VPLA_SNRST and VPLB_SNRST bit */ + tmp = readl(SC_VPLL27ACTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* Enable write protect of VPLL27ACTRL[2-7]*, VPLL27BCTRL[2-8] */ + tmp = readl(SC_VPLL27ACTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27BCTRL); +} + +void pll_init(void) +{ + dpll_init(); + stop_mpll(); + vpll_init(); + + /* + * Wait 500 usec until dpll get stable + * We wait 1 usec in vpll_init() so 1 usec can be saved here. + */ + udelay(499); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c new file mode 100644 index 0000000..4538d1a --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c @@ -0,0 +1,18 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void enable_dpll_ssc(void) +{ + u32 tmp; + + tmp = readl(SC_DPLLCTRL); + tmp |= SC_DPLLCTRL_SSC_EN; + writel(tmp, SC_DPLLCTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c new file mode 100644 index 0000000..f113db5 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c @@ -0,0 +1,75 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sbc-regs.h> +#include <asm/arch/sg-regs.h> + +void sbc_init(void) +{ +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) + /* + * Only CS1 is connected to support card. + * BKSZ[1:0] should be set to "01". + */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL14); + + if (readl(SBBASE0) & 0x1) { + /* + * Boot Swap Off: boot from mask ROM + * 0x00000000-0x01ffffff: mask ROM + * 0x02000000-0x3effffff: memory bank (31MB) + * 0x03f00000-0x3fffffff: peripherals (1MB) + */ + writel(0x0000be01, SBBASE0); /* dummy */ + writel(0x0200be01, SBBASE1); + } else { + /* + * Boot Swap On: boot from external NOR/SRAM + * 0x02000000-0x03ffffff is a mirror of 0x00000000-0x01ffffff. + * + * 0x00000000-0x01efffff, 0x02000000-0x03efffff: memory bank + * 0x01f00000-0x01ffffff, 0x03f00000-0x03ffffff: peripherals + */ + writel(0x0000bc01, SBBASE0); + } +#elif defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +#if !defined(CONFIG_SPL_BUILD) + /* XECS0: boot/sub memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); +#endif + /* XECS1: sub/boot memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + + /* XECS3: peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); + + writel(0x0000bc01, SBBASE0); /* boot memory */ + writel(0x0400bc01, SBBASE1); /* sub memory */ + writel(0x0800bf01, SBBASE3); /* peripherals */ + +#if !defined(CONFIG_SPL_BUILD) + sg_set_pinsel(318, 5); /* PORT22 -> XECS0 */ +#endif + sg_set_pinsel(313, 5); /* PORT15 -> XECS3 */ + writel(0x00000001, SG_LOADPINCTRL); + +#endif /* CONFIG_XXX_MICRO_SUPPORT_CARD */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c new file mode 100644 index 0000000..8200959 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c @@ -0,0 +1,28 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void sg_init(void) +{ + u32 tmp; + + /* Set DDR size */ + tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE, CONFIG_DDR_NUM_CH0); + tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE, CONFIG_DDR_NUM_CH1); +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE + tmp |= SG_MEMCONF_SPARSEMEM; +#endif + writel(tmp, SG_MEMCONF); + + /* Must enable in-port before deasserting reset signals of cores */ + tmp = readl(SG_IECTRL); + tmp |= 0x1; + writel(tmp, SG_IECTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c new file mode 100644 index 0000000..e0e586b --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c @@ -0,0 +1,10 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +int umc_init(void) +{ + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile new file mode 100644 index 0000000..b385e19 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o bcu_init.o \ + sbc_init.o sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SPL_BUILD) += pll_spectrum.o \ + umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c new file mode 100644 index 0000000..69b172e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/bcu_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c new file mode 100644 index 0000000..15dc289 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/board.h> + +int checkboard(void) +{ + puts("Board: PH1-sLD8 Board\n"); + + return check_support_card(); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c new file mode 100644 index 0000000..287b33c --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/board_postclk_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c new file mode 100644 index 0000000..d359b56 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c @@ -0,0 +1 @@ +#include "../ph1-pro4/boot-mode.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void clkrst_init(void) +{ + u32 tmp; + + /* deassert reset */ + tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 + | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; + writel(tmp, SC_RSTCTRL); + readl(SC_RSTCTRL); /* dummy read */ + + /* privide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC + | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c new file mode 100644 index 0000000..2b6403f --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void pin_init(void) +{ + /* Comment format: PAD Name -> Function Name */ + +#ifdef CONFIG_UNIPHIER_SERIAL + sg_set_pinsel(70, 3); /* HDDOUT0 -> TXD0 */ + sg_set_pinsel(71, 3); /* HSDOUT1 -> RXD0 */ + + sg_set_pinsel(114, 0); /* TXD1 -> TXD1 */ + sg_set_pinsel(115, 0); /* RXD1 -> RXD1 */ + + sg_set_pinsel(112, 1); /* SBO1 -> TXD2 */ + sg_set_pinsel(113, 1); /* SBI1 -> RXD2 */ + + sg_set_pinsel(110, 1); /* SBO0 -> TXD3 */ + sg_set_pinsel(111, 1); /* SBI0 -> RXD3 */ +#endif + +#ifdef CONFIG_NAND_DENALI + sg_set_pinsel(15, 0); /* XNFRE_GB -> XNFRE_GB */ + sg_set_pinsel(16, 0); /* XNFWE_GB -> XNFWE_GB */ + sg_set_pinsel(17, 0); /* XFALE_GB -> NFALE_GB */ + sg_set_pinsel(18, 0); /* XFCLE_GB -> NFCLE_GB */ + sg_set_pinsel(19, 0); /* XNFWP_GB -> XFNWP_GB */ + sg_set_pinsel(20, 0); /* XNFCE0_GB -> XNFCE0_GB */ + sg_set_pinsel(21, 0); /* NANDRYBY0_GB -> NANDRYBY0_GB */ + sg_set_pinsel(22, 0); /* XFNCE1_GB -> XFNCE1_GB */ + sg_set_pinsel(23, 0); /* NANDRYBY1_GB -> NANDRYBY1_GB */ + sg_set_pinsel(24, 0); /* NFD0_GB -> NFD0_GB */ + sg_set_pinsel(25, 0); /* NFD1_GB -> NFD1_GB */ + sg_set_pinsel(26, 0); /* NFD2_GB -> NFD2_GB */ + sg_set_pinsel(27, 0); /* NFD3_GB -> NFD3_GB */ + sg_set_pinsel(28, 0); /* NFD4_GB -> NFD4_GB */ + sg_set_pinsel(29, 0); /* NFD5_GB -> NFD5_GB */ + sg_set_pinsel(30, 0); /* NFD6_GB -> NFD6_GB */ + sg_set_pinsel(31, 0); /* NFD7_GB -> NFD7_GB */ +#endif + +#ifdef CONFIG_USB_EHCI_UNIPHIER + sg_set_pinsel(41, 0); /* USB0VBUS -> USB0VBUS */ + sg_set_pinsel(42, 0); /* USB0OD -> USB0OD */ + sg_set_pinsel(43, 0); /* USB1VBUS -> USB1VBUS */ + sg_set_pinsel(44, 0); /* USB1OD -> USB1OD */ + /* sg_set_pinsel(114, 4); */ /* TXD1 -> USB2VBUS (shared with UART) */ + /* sg_set_pinsel(115, 4); */ /* RXD1 -> USB2OD */ +#endif +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c new file mode 100644 index 0000000..76c5116 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c @@ -0,0 +1,201 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/sg-regs.h> + +void dpll_init(void) +{ + u32 tmp; + /* + * Set DPLL SSC parameters for DPLLCTRL3 + * [23] DIVN_TEST 1'b1 + * [22:16] DIVN 7'h50 + * [10] FREFSEL_TEST 1'b1 + * [9:8] FREFSEL 2'h2 + * [4] ICPD_TEST 1'b1 + * [3:0] ICPD 4'hB + */ + tmp = readl(SC_DPLLCTRL3); + tmp &= ~0x00ff0717; + tmp |= 0x00d0061b; + writel(tmp, SC_DPLLCTRL3); + + /* + * Set DPLL SSC parameters for DPLLCTRL - SSC + * <-1%> <-2%> + * [29:20] SSC_UPCNT 10'd132 (0x084) 10'd132 (0x084) + * [14:0] SSC_dK 15'd6335(0x18bf) 15'd12710(0x31a6) + */ + tmp = readl(SC_DPLLCTRL); + tmp &= ~0x3ff07fff; +#if defined(CONFIG_DPLL_SSC_RATE_1PER) + tmp |= 0x084018bf; +#else + tmp |= 0x084031a6; +#endif /* defined(CONFIG_DPLL_SSC_RATE_1PER) */ + writel(tmp, SC_DPLLCTRL); + + /* + * Set DPLL SSC parameters for DPLLCTRL2 + * [31:29] SSC_STEP 3' d0 (0x0) + * [27] SSC_REG_REF 1' b1 (0x1) + * [26:20] SSC_M 7' d79 (0x4f) + * [19:0] SSC_K 20'd964689(0xeb851) + */ + tmp = readl(SC_DPLLCTRL2); + tmp &= ~0xefffffff; + tmp |= 0x0cfeb851; + writel(tmp, SC_DPLLCTRL2); +} + +void upll_init(void) +{ + u32 tmp, clk_mode_upll, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_upll = tmp & SG_PINMON0_CLK_MODE_UPLLSRC_MASK; + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 0 to SNRT(UPLLCTRL.bit28) and K_LD(UPLLCTRL.bit[27]) */ + tmp = readl(SC_UPLLCTRL); + tmp &= ~0x18000000; + writel(tmp, SC_UPLLCTRL); + + if (clk_mode_upll == SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT) { + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x0228f5c0; + } else { + /* AXO: default 24.576MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x02328000; + } + } + + writel(tmp, SC_UPLLCTRL); + + /* set 1 to K_LD(UPLLCTRL.bit[27]) */ + tmp |= 0x08000000; + writel(tmp, SC_UPLLCTRL); + + /* wait 10 usec */ + udelay(10); + + /* set 1 to SNRT(UPLLCTRL.bit[28]) */ + tmp |= 0x10000000; + writel(tmp, SC_UPLLCTRL); +} + +void vpll_init(void) +{ + u32 tmp, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 1 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27BCTRL); + + /* Set 0 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* Set 0x20 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27BCTRL2); + + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27BCTRL3); + } else { + /* AXO: default 24.576MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27BCTRL3); + } + + /* Set 1 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* wait 10 usec */ + udelay(10); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* set 0 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= ~0x00000001; + writel(tmp, SC_VPLL27BCTRL); +} + +void pll_init(void) +{ + dpll_init(); + upll_init(); + vpll_init(); + + /* + * Wait 500 usec until dpll get stable + * We wait 10 usec in upll_init() and vpll_init() + * so 20 usec can be saved here. + */ + udelay(480); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c new file mode 100644 index 0000000..9b8c485 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c @@ -0,0 +1 @@ +#include "../ph1-ld4/pll_spectrum.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c new file mode 100644 index 0000000..af44dee --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sbc-regs.h> +#include <asm/arch/sg-regs.h> + +void sbc_init(void) +{ +#if !defined(CONFIG_SPL_BUILD) + /* XECS0 : dummy */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); +#endif + /* XECS1 : boot memory (always boot swap = on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + + /* XECS4 : sub memory */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL40); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL41); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL42); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL44); + + /* XECS5 : peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL50); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL51); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL52); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL54); + + /* base address regsiters */ + writel(0x0000bc01, SBBASE0); /* boot memory */ + writel(0x0900bfff, SBBASE1); /* dummy */ + writel(0x0400bc01, SBBASE4); /* sub memory */ + writel(0x0800bf01, SBBASE5); /* peripherals */ + + sg_set_pinsel(134, 16); /* XIRQ6 -> XECS4 */ + sg_set_pinsel(135, 16); /* XIRQ7 -> XECS5 */ + + /* dummy read to assure write process */ + readl(SG_PINCTRL(33)); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c new file mode 100644 index 0000000..a808289 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/sg_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c new file mode 100644 index 0000000..e0e586b --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c @@ -0,0 +1,10 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +int umc_init(void) +{ + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/reset.c b/arch/arm/cpu/armv7/uniphier/reset.c new file mode 100644 index 0000000..b0dc967 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/reset.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/board.h> + +void reset_cpu(unsigned long ignored) +{ + u32 tmp; + + uniphier_board_reset(); + + writel(5, SC_IRQTIMSET); /* default value */ + + tmp = readl(SC_SLFRSTSEL); + tmp &= ~0x3; /* mask [1:0] */ + tmp |= 0x0; /* XRST reboot */ + writel(tmp, SC_SLFRSTSEL); + + tmp = readl(SC_SLFRSTCTL); + tmp |= 0x1; + writel(tmp, SC_SLFRSTCTL); +} diff --git a/arch/arm/cpu/armv7/uniphier/smp.S b/arch/arm/cpu/armv7/uniphier/smp.S new file mode 100644 index 0000000..25ba981 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/smp.S @@ -0,0 +1,54 @@ +/* + * Copyright (C) 2013 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/system.h> +#include <asm/arch/led.h> +#include <asm/arch/sbc-regs.h> + +/* Entry point of U-Boot main program for the secondary CPU */ +LENTRY(secondary_entry) + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + bic r0, r0, #(CR_C | CR_M) @ MMU and Dcache disable + mcr p15, 0, r0, c1, c0, 0 + mcr p15, 0, r0, c8, c7, 0 @ invalidate TLBs + mcr p15, 0, r0, c7, c5, 0 @ invalidate icache + dsb + led_write(C,0,,) + ldr r1, =ROM_BOOT_ROMRSV2 + mov r0, #0 + str r0, [r1] +0: wfe + ldr r4, [r1] @ r4: entry point for secondary CPUs + cmp r4, #0 + beq 0b + led_write(C, P, U, 1) + bx r4 @ secondary CPUs jump to linux +ENDPROC(secondary_entry) + +ENTRY(wakeup_secondary) + ldr r1, =ROM_BOOT_ROMRSV2 +0: ldr r0, [r1] + cmp r0, #0 + bne 0b + + /* set entry address and send event to the secondary CPU */ + ldr r0, =secondary_entry + str r0, [r1] + ldr r0, [r1] @ make sure store is complete + mov r0, #0x100 +0: subs r0, r0, #1 @ I don't know the reason, but without this wait + bne 0b @ fails to wake up the secondary CPU + sev + + /* wait until the secondary CPU reach to secondary_entry */ +0: ldr r0, [r1] + cmp r0, #0 + bne 0b + bx lr +ENDPROC(wakeup_secondary) diff --git a/arch/arm/cpu/armv7/uniphier/spl.c b/arch/arm/cpu/armv7/uniphier/spl.c new file mode 100644 index 0000000..40d28ad --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/spl.c @@ -0,0 +1,17 @@ +/* + * Copyright (C) 2013-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> + +void spl_board_init(void) +{ +#if defined(CONFIG_BOARD_POSTCLK_INIT) + board_postclk_init(); +#endif + dram_init(); +} diff --git a/arch/arm/cpu/armv7/uniphier/support_card.c b/arch/arm/cpu/armv7/uniphier/support_card.c new file mode 100644 index 0000000..40d4940 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/support_card.c @@ -0,0 +1,180 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/board.h> + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) + +#define PFC_MICRO_SUPPORT_CARD_RESET \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x000D0034) +#define PFC_MICRO_SUPPORT_CARD_REVISION \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x000D00E0) +/* + * 0: reset deassert, 1: reset + * + * bit[0]: LAN, I2C, LED + * bit[1]: UART + */ +void support_card_reset_deassert(void) +{ + writel(0, PFC_MICRO_SUPPORT_CARD_RESET); +} + +void support_card_reset(void) +{ + writel(3, PFC_MICRO_SUPPORT_CARD_RESET); +} + +static int support_card_show_revision(void) +{ + u32 revision; + + revision = readl(PFC_MICRO_SUPPORT_CARD_REVISION); + printf("(PFC CPLD version %d.%d)\n", revision >> 4, revision & 0xf); + return 0; +} +#endif + +#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) + +#define DCC_MICRO_SUPPORT_CARD_RESET_LAN \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x00401300) +#define DCC_MICRO_SUPPORT_CARD_RESET_UART \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x00401304) +#define DCC_MICRO_SUPPORT_CARD_RESET_I2C \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x00401308) +#define DCC_MICRO_SUPPORT_CARD_REVISION \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x005000E0) + +void support_card_reset_deassert(void) +{ + writel(1, DCC_MICRO_SUPPORT_CARD_RESET_LAN); /* LAN and LED */ + writel(1, DCC_MICRO_SUPPORT_CARD_RESET_UART); /* UART */ + writel(1, DCC_MICRO_SUPPORT_CARD_RESET_I2C); /* I2C */ +} + +void support_card_reset(void) +{ + writel(0, DCC_MICRO_SUPPORT_CARD_RESET_LAN); /* LAN and LED */ + writel(0, DCC_MICRO_SUPPORT_CARD_RESET_UART); /* UART */ + writel(0, DCC_MICRO_SUPPORT_CARD_RESET_I2C); /* I2C */ +} + +static int support_card_show_revision(void) +{ + u32 revision; + + revision = readl(DCC_MICRO_SUPPORT_CARD_REVISION); + + if (revision >= 0x67) { + printf("(DCC CPLD version 3.%d.%d)\n", + revision >> 4, revision & 0xf); + return 0; + } else { + printf("(DCC CPLD unknown version)\n"); + return -1; + } +} +#endif + +void support_card_init(void) +{ + /* + * After power on, we need to keep the LAN controller in reset state + * for a while. (200 usec) + * Fortunatelly, enough wait time is already inserted in pll_init() + * function. So we do not have to wait here. + */ + support_card_reset_deassert(); +} + +int check_support_card(void) +{ + printf("SC: Micro Support Card "); + return support_card_show_revision(); +} + +#if defined(CONFIG_SMC911X) +#include <netdev.h> + +int board_eth_init(bd_t *bis) +{ + return smc911x_initialize(0, CONFIG_SMC911X_BASE); +} +#endif + +#if !defined(CONFIG_SYS_NO_FLASH) + +#include <mtd/cfi_flash.h> + +#if CONFIG_SYS_MAX_FLASH_BANKS > 1 +static phys_addr_t flash_banks_list[CONFIG_SYS_MAX_FLASH_BANKS] = + CONFIG_SYS_FLASH_BANKS_LIST; + +phys_addr_t cfi_flash_bank_addr(int i) +{ + return flash_banks_list[i]; +} +#endif + +int mem_is_flash(phys_addr_t base) +{ + const int loop = 128; + u32 *scratch_addr; + u32 saved_value; + int ret = 1; + int i; + + scratch_addr = map_physmem(base + 0x01e00000, + sizeof(u32) * loop, MAP_NOCACHE); + + for (i = 0; i < loop; i++, scratch_addr++) { + saved_value = readl(scratch_addr); + writel(~saved_value, scratch_addr); + if (readl(scratch_addr) != saved_value) { + /* We assume no memory or SRAM here. */ + writel(saved_value, scratch_addr); + ret = 0; + break; + } + } + + unmap_physmem(scratch_addr, MAP_NOCACHE); + + return ret; +} + +int board_flash_wp_on(void) +{ + int i; + int ret = 1; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + if (mem_is_flash(cfi_flash_bank_addr(i))) { + /* + * We found at least one flash. + * We need to return 0 and call flash_init(). + */ + ret = 0; + } +#if CONFIG_SYS_MAX_FLASH_BANKS > 1 + else { + /* + * We might have a SRAM here. + * To prevent SRAM data from being destroyed, + * we set dummy address (SDRAM). + */ + flash_banks_list[i] = 0x80000000 + 0x10000 * i; + } +#endif + } + + return ret; +} +#endif diff --git a/arch/arm/cpu/armv7/uniphier/timer.c b/arch/arm/cpu/armv7/uniphier/timer.c new file mode 100644 index 0000000..6edc084 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/timer.c @@ -0,0 +1,39 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/arm-mpcore.h> + +#define PERIPHCLK (50 * 1000 * 1000) /* 50 MHz */ +#define PRESCALER ((PERIPHCLK) / (CONFIG_SYS_TIMER_RATE) - 1) + +static void *get_global_timer_base(void) +{ + void *val; + + asm("mrc p15, 4, %0, c15, c0, 0" : "=r" (val) : : "memory"); + + return val + GLOBAL_TIMER_OFFSET; +} + +unsigned long timer_read_counter(void) +{ + /* + * ARM 64bit Global Timer is too much for our purpose. + * We use only lower 32 bit of the timer counter. + */ + return readl(get_global_timer_base() + GTIMER_CNT_L); +} + +int timer_init(void) +{ + /* enable timer */ + writel(PRESCALER << 8 | 1, get_global_timer_base() + GTIMER_CTRL); + + return 0; +} diff --git a/arch/arm/include/asm/arch-uniphier/arm-mpcore.h b/arch/arm/include/asm/arch-uniphier/arm-mpcore.h new file mode 100644 index 0000000..cf7cd46 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/arm-mpcore.h @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_ARM_MPCORE_H +#define ARCH_ARM_MPCORE_H + +/* Snoop Control Unit */ +#define SCU_OFFSET 0x00 + +/* SCU Control Register */ +#define SCU_CTRL 0x00 +/* SCU Configuration Register */ +#define SCU_CONF 0x04 +/* SCU CPU Power Status Register */ +#define SCU_PWR_STATUS 0x08 +/* SCU Invalidate All Registers in Secure State */ +#define SCU_INV_ALL 0x0C +/* SCU Filtering Start Address Register */ +#define SCU_FILTER_START 0x40 +/* SCU Filtering End Address Register */ +#define SCU_FILTER_END 0x44 +/* SCU Access Control Register */ +#define SCU_SAC 0x50 +/* SCU Non-secure Access Control Register */ +#define SCU_SNSAC 0x54 + +/* Global Timer */ +#define GLOBAL_TIMER_OFFSET 0x200 + +/* Global Timer Counter Registers */ +#define GTIMER_CNT_L 0x00 +#define GTIMER_CNT_H 0x04 +/* Global Timer Control Register */ +#define GTIMER_CTRL 0x08 +/* Global Timer Interrupt Status Register */ +#define GTIMER_STAT 0x0C +/* Comparator Value Registers */ +#define GTIMER_CMP_L 0x10 +#define GTIMER_CMP_H 0x14 +/* Auto-increment Register */ +#define GTIMER_INC 0x18 + +#endif /* ARCH_ARM_MPCORE_H */ diff --git a/arch/arm/include/asm/arch-uniphier/bcu-regs.h b/arch/arm/include/asm/arch-uniphier/bcu-regs.h new file mode 100644 index 0000000..5501b36 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/bcu-regs.h @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_BCU_REGS_H +#define ARCH_BCU_REGS_H + +/* Bus Control Unit registers */ +#define BCU_BASE 0x50080000 + +#define BCSCR(x) (BCU_BASE + 0x180 + (x) * 4) +#define BCSCR0 (BCSCR(0)) +#define BCSCR1 (BCSCR(1)) +#define BCSCR2 (BCSCR(2)) +#define BCSCR3 (BCSCR(3)) +#define BCSCR4 (BCSCR(4)) +#define BCSCR5 (BCSCR(5)) + +#define BCIPPCCHR(x) (BCU_BASE + 0x0280 + (x) * 4) +#define BCIPPCCHR0 (BCIPPCCHR(0)) +#define BCIPPCCHR1 (BCIPPCCHR(1)) +#define BCIPPCCHR2 (BCIPPCCHR(2)) +#define BCIPPCCHR3 (BCIPPCCHR(3)) +#define BCIPPCCHR4 (BCIPPCCHR(4)) +#define BCIPPCCHR5 (BCIPPCCHR(5)) + +#endif /* ARCH_BCU_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/board.h b/arch/arm/include/asm/arch-uniphier/board.h new file mode 100644 index 0000000..e6ba4e4 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/board.h @@ -0,0 +1,35 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_BOARD_H +#define ARCH_BOARD_H + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) || \ + defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +void support_card_reset(void); +void support_card_init(void); +int check_support_card(void); +#else +#define support_card_reset() do {} while (0) +#define support_card_init() do {} while (0) +static inline int check_support_card(void) +{ + return 0; +} +#endif + +static inline void uniphier_board_reset(void) +{ + support_card_reset(); +} + +static inline void uniphier_board_init(void) +{ + support_card_init(); +} + +#endif /* ARCH_BOARD_H */ diff --git a/arch/arm/include/asm/arch-uniphier/boot-device.h b/arch/arm/include/asm/arch-uniphier/boot-device.h new file mode 100644 index 0000000..6987f57 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/boot-device.h @@ -0,0 +1,20 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_BOOT_DEVICE_H_ +#define _ASM_BOOT_DEVICE_H_ + +u32 get_boot_mode_sel(void); + +struct boot_device_info { + u32 type; + char *info; +}; + +extern struct boot_device_info boot_device_table[]; + +#endif /* _ASM_BOOT_DEVICE_H_ */ diff --git a/arch/arm/include/asm/arch-uniphier/led.h b/arch/arm/include/asm/arch-uniphier/led.h new file mode 100644 index 0000000..21277da --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/led.h @@ -0,0 +1,101 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_LED_H +#define ARCH_LED_H + +#include <config.h> + +#define LED_CHAR_0 0x7e +#define LED_CHAR_1 0x0c +#define LED_CHAR_2 0xb6 +#define LED_CHAR_3 0x9e +#define LED_CHAR_4 0xcc +#define LED_CHAR_5 0xda +#define LED_CHAR_6 0xfa +#define LED_CHAR_7 0x4e +#define LED_CHAR_8 0xfe +#define LED_CHAR_9 0xde + +#define LED_CHAR_A 0xee +#define LED_CHAR_B 0xf8 +#define LED_CHAR_C 0x72 +#define LED_CHAR_D 0xbc +#define LED_CHAR_E 0xf2 +#define LED_CHAR_F 0xe2 +#define LED_CHAR_G 0x7a +#define LED_CHAR_H 0xe8 +#define LED_CHAR_I 0x08 +#define LED_CHAR_J 0x3c +#define LED_CHAR_K 0xea +#define LED_CHAR_L 0x70 +#define LED_CHAR_M 0x6e +#define LED_CHAR_N 0xa8 +#define LED_CHAR_O 0xb8 +#define LED_CHAR_P 0xe6 +#define LED_CHAR_Q 0xce +#define LED_CHAR_R 0xa0 +#define LED_CHAR_S 0xc8 +#define LED_CHAR_T 0x8c +#define LED_CHAR_U 0x7c +#define LED_CHAR_V 0x54 +#define LED_CHAR_W 0xfc +#define LED_CHAR_X 0xec +#define LED_CHAR_Y 0xdc +#define LED_CHAR_Z 0xa4 + +#define LED_CHAR_SPACE 0x00 +#define LED_CHAR_DOT 0x01 + +#define LED_CHAR_ (LED_CHAR_SPACE) + +/** Macro to translate 4 characters into integer to display led */ +#define LED_C2I(C0, C1, C2, C3) \ + (~( \ + (LED_CHAR_##C0 << 24) | \ + (LED_CHAR_##C1 << 16) | \ + (LED_CHAR_##C2 << 8) | \ + (LED_CHAR_##C3) \ + )) + +#if defined(CONFIG_SUPPORT_CARD_LED_BASE) + +#define LED_ADDR CONFIG_SUPPORT_CARD_LED_BASE + +#ifdef __ASSEMBLY__ + +#define led_write(C0, C1, C2, C3) raw_led_write LED_C2I(C0, C1, C2, C3) +.macro raw_led_write data + ldr r0, =\data + ldr r1, =LED_ADDR + str r0, [r1] +.endm + +#else /* __ASSEMBLY__ */ + +#include <asm/io.h> + +#define led_write(C0, C1, C2, C3) \ +do { \ + raw_led_write(LED_C2I(C0, C1, C2, C3)); \ +} while (0) + +static inline void raw_led_write(u32 data) +{ + writel(data, LED_ADDR); +} + +#endif /* __ASSEMBLY__ */ + +#else /* CONFIG_SUPPORT_CARD_LED_BASE */ + +#define led_write(C0, C1, C2, C3) +#define raw_led_write(x) + +#endif /* CONFIG_SUPPORT_CARD_LED_BASE */ + +#endif /* ARCH_LED_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sbc-regs.h b/arch/arm/include/asm/arch-uniphier/sbc-regs.h new file mode 100644 index 0000000..397d5b4 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sbc-regs.h @@ -0,0 +1,107 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SBC_REGS_H +#define ARCH_SBC_REGS_H + +/* System Bus Controller registers */ +#define SBBASE_BASE 0x58c00100 +#define SBBASE(x) (SBBASE_BASE + (x) * 0x10) + +#define SBBASE0 (SBBASE(0)) +#define SBBASE1 (SBBASE(1)) +#define SBBASE2 (SBBASE(2)) +#define SBBASE3 (SBBASE(3)) +#define SBBASE4 (SBBASE(4)) +#define SBBASE5 (SBBASE(5)) +#define SBBASE6 (SBBASE(6)) +#define SBBASE7 (SBBASE(7)) + +#define SBBASE_BANK_ENABLE (0x00000001) + +#define SBCTRL_BASE 0x58c00200 +#define SBCTRL(x, y) (SBCTRL_BASE + (x) * 0x10 + (y) * 4) + +#define SBCTRL00 SBCTRL(0, 0) +#define SBCTRL01 SBCTRL(0, 1) +#define SBCTRL02 SBCTRL(0, 2) +#define SBCTRL03 SBCTRL(0, 3) +#define SBCTRL04 (SBCTRL_BASE + 0x100) + +#define SBCTRL10 SBCTRL(1, 0) +#define SBCTRL11 SBCTRL(1, 1) +#define SBCTRL12 SBCTRL(1, 2) +#define SBCTRL13 SBCTRL(1, 3) +#define SBCTRL14 (SBCTRL_BASE + 0x110) + +#define SBCTRL20 SBCTRL(2, 0) +#define SBCTRL21 SBCTRL(2, 1) +#define SBCTRL22 SBCTRL(2, 2) +#define SBCTRL23 SBCTRL(2, 3) +#define SBCTRL24 (SBCTRL_BASE + 0x120) + +#define SBCTRL30 SBCTRL(3, 0) +#define SBCTRL31 SBCTRL(3, 1) +#define SBCTRL32 SBCTRL(3, 2) +#define SBCTRL33 SBCTRL(3, 3) +#define SBCTRL34 (SBCTRL_BASE + 0x130) + +#define SBCTRL40 SBCTRL(4, 0) +#define SBCTRL41 SBCTRL(4, 1) +#define SBCTRL42 SBCTRL(4, 2) +#define SBCTRL43 SBCTRL(4, 3) +#define SBCTRL44 (SBCTRL_BASE + 0x140) + +#define SBCTRL50 SBCTRL(5, 0) +#define SBCTRL51 SBCTRL(5, 1) +#define SBCTRL52 SBCTRL(5, 2) +#define SBCTRL53 SBCTRL(5, 3) +#define SBCTRL54 (SBCTRL_BASE + 0x150) + +#define SBCTRL60 SBCTRL(6, 0) +#define SBCTRL61 SBCTRL(6, 1) +#define SBCTRL62 SBCTRL(6, 2) +#define SBCTRL63 SBCTRL(6, 3) +#define SBCTRL64 (SBCTRL_BASE + 0x160) + +#define SBCTRL70 SBCTRL(7, 0) +#define SBCTRL71 SBCTRL(7, 1) +#define SBCTRL72 SBCTRL(7, 2) +#define SBCTRL73 SBCTRL(7, 3) +#define SBCTRL74 (SBCTRL_BASE + 0x170) + +/* slower but LED works */ +#define SBCTRL0_SAVEPIN_PERI_VALUE 0x55450000 +#define SBCTRL1_SAVEPIN_PERI_VALUE 0x07168d00 +#define SBCTRL2_SAVEPIN_PERI_VALUE 0x34000009 +#define SBCTRL4_SAVEPIN_PERI_VALUE 0x02110110 + +/* faster but LED does not work */ +#define SBCTRL0_SAVEPIN_MEM_VALUE 0x55450000 +#define SBCTRL1_SAVEPIN_MEM_VALUE 0x06057700 +/* NOR flash needs more wait counts than SRAM */ +#define SBCTRL2_SAVEPIN_MEM_VALUE 0x34000009 +#define SBCTRL4_SAVEPIN_MEM_VALUE 0x02110210 + +#define SBCTRL0_ADMULTIPLX_PERI_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_PERI_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_PERI_VALUE 0x14000020 + +#define SBCTRL0_ADMULTIPLX_MEM_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_MEM_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_MEM_VALUE 0x14000010 + +#define ROM_BOOT_ROMRSV2 0x59801208 + +#ifndef __ASSEMBLY__ +#include <asm/io.h> +static inline int boot_is_swapped(void) +{ + return !(readl(SBBASE0) & SBBASE_BANK_ENABLE); +} +#endif + +#endif /* ARCH_SBC_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sc-regs.h b/arch/arm/include/asm/arch-uniphier/sc-regs.h new file mode 100644 index 0000000..4d4dfdf --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sc-regs.h @@ -0,0 +1,62 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SC_REGS_H +#define ARCH_SC_REGS_H + +#include <config.h> + +#define SC_BASE_ADDR 0x61840000 + +#define SC_MPLLOSCCTL (SC_BASE_ADDR | 0x1184) +#define SC_MPLLOSCCTL_MPLLEN (0x1 << 0) +#define SC_MPLLOSCCTL_MPLLST (0x1 << 1) + +#define SC_DPLLCTRL (SC_BASE_ADDR | 0x1200) +#define SC_DPLLCTRL_SSC_EN (0x1 << 31) +#define SC_DPLLCTRL_FOUTMODE_MASK (0xf << 16) +#define SC_DPLLCTRL_SSC_RATE (0x1 << 15) + +#define SC_DPLLCTRL2 (SC_BASE_ADDR | 0x1204) +#define SC_DPLLCTRL2_NRSTDS (0x1 << 28) + +#define SC_DPLLCTRL3 (SC_BASE_ADDR | 0x1208) +#define SC_DPLLCTRL3_LPFSEL_COEF2 (0x0 << 31) +#define SC_DPLLCTRL3_LPFSEL_COEF3 (0x1 << 31) + +#define SC_UPLLCTRL (SC_BASE_ADDR | 0x1210) + +#define SC_VPLL27ACTRL (SC_BASE_ADDR | 0x1270) +#define SC_VPLL27ACTRL2 (SC_BASE_ADDR | 0x1274) +#define SC_VPLL27ACTRL3 (SC_BASE_ADDR | 0x1278) + +#define SC_VPLL27BCTRL (SC_BASE_ADDR | 0x1290) +#define SC_VPLL27BCTRL2 (SC_BASE_ADDR | 0x1294) +#define SC_VPLL27BCTRL3 (SC_BASE_ADDR | 0x1298) + +#define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) +#define SC_RSTCTRL_NRST_ETHER (0x1 << 12) +#define SC_RSTCTRL_NRST_UMC1 (0x1 << 5) +#define SC_RSTCTRL_NRST_UMC0 (0x1 << 4) +#define SC_RSTCTRL_NRST_NAND (0x1 << 2) + +#define SC_RSTCTRL2 (SC_BASE_ADDR | 0x2004) +#define SC_RSTCTRL3 (SC_BASE_ADDR | 0x2008) + +#define SC_CLKCTRL (SC_BASE_ADDR | 0x2104) +#define SC_CLKCTRL_CLK_ETHER (0x1 << 12) +#define SC_CLKCTRL_CLK_MIO (0x1 << 11) +#define SC_CLKCTRL_CLK_UMC (0x1 << 4) +#define SC_CLKCTRL_CLK_NAND (0x1 << 2) +#define SC_CLKCTRL_CLK_SBC (0x1 << 1) +#define SC_CLKCTRL_CLK_PERI (0x1 << 0) + +/* System reset control register */ +#define SC_IRQTIMSET (SC_BASE_ADDR | 0x3000) +#define SC_SLFRSTSEL (SC_BASE_ADDR | 0x3010) +#define SC_SLFRSTCTL (SC_BASE_ADDR | 0x3014) + +#endif /* ARCH_SC_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sg-regs.h b/arch/arm/include/asm/arch-uniphier/sg-regs.h new file mode 100644 index 0000000..4136774 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sg-regs.h @@ -0,0 +1,182 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SG_REGS_H +#define ARCH_SG_REGS_H + +#include <config.h> + +/* Base Address */ +#define SG_CTRL_BASE 0x5f800000 +#define SG_DBG_BASE 0x5f900000 + +/* Revision */ +#define SG_REVISION (SG_CTRL_BASE | 0x0000) +#define SG_REVISION_TYPE_SHIFT 16 +#define SG_REVISION_TYPE_MASK (0xff << SG_REVISION_TYPE_SHIFT) +#define SG_REVISION_MODEL_SHIFT 8 +#define SG_REVISION_MODEL_MASK (0x3 << SG_REVISION_MODEL_SHIFT) +#define SG_REVISION_REV_SHIFT 0 +#define SG_REVISION_REV_MASK (0x1f << SG_REVISION_REV_SHIFT) + +/* Memory Configuration */ +#define SG_MEMCONF (SG_CTRL_BASE | 0x0400) + +#define SG_MEMCONF_CH0_SIZE_64MB ((0x0 << 10) | (0x01 << 0)) +#define SG_MEMCONF_CH0_SIZE_128MB ((0x0 << 10) | (0x02 << 0)) +#define SG_MEMCONF_CH0_SIZE_256MB ((0x0 << 10) | (0x03 << 0)) +#define SG_MEMCONF_CH0_SIZE_512MB ((0x1 << 10) | (0x00 << 0)) +#define SG_MEMCONF_CH0_SIZE_1024MB ((0x1 << 10) | (0x01 << 0)) +#define SG_MEMCONF_CH0_NUM_1 (0x1 << 8) +#define SG_MEMCONF_CH0_NUM_2 (0x0 << 8) + +#define SG_MEMCONF_CH1_SIZE_64MB ((0x0 << 11) | (0x01 << 2)) +#define SG_MEMCONF_CH1_SIZE_128MB ((0x0 << 11) | (0x02 << 2)) +#define SG_MEMCONF_CH1_SIZE_256MB ((0x0 << 11) | (0x03 << 2)) +#define SG_MEMCONF_CH1_SIZE_512MB ((0x1 << 11) | (0x00 << 2)) +#define SG_MEMCONF_CH1_SIZE_1024MB ((0x1 << 11) | (0x01 << 2)) +#define SG_MEMCONF_CH1_NUM_1 (0x1 << 9) +#define SG_MEMCONF_CH1_NUM_2 (0x0 << 9) + +#define SG_MEMCONF_SPARSEMEM (0x1 << 4) + +/* Pin Control */ +#define SG_PINCTRL_BASE (SG_CTRL_BASE | 0x1000) + +#if defined(CONFIG_PH1_PRO4) +# define SG_PINCTRL(n) (SG_PINCTRL_BASE + (n) * 8) +#elif defined(CONFIG_PH1_LD4) || defined(CONFIG_PH1_SLD8) +# define SG_PINCTRL(n) (SG_PINCTRL_BASE + (n) * 4) +#endif + +#if defined(CONFIG_PH1_PRO4) +#define SG_PINSELBITS 4 +#elif defined(CONFIG_PH1_LD4) || defined(CONFIG_PH1_SLD8) +#define SG_PINSELBITS 8 +#endif + +#define SG_PINSEL_ADDR(n) (SG_PINCTRL((n) * (SG_PINSELBITS) / 32)) +#define SG_PINSEL_MASK(n) (~(((1 << (SG_PINSELBITS)) - 1) << \ + ((n) * (SG_PINSELBITS) % 32))) +#define SG_PINSEL_MODE(n, mode) ((mode) << ((n) * (SG_PINSELBITS) % 32)) + +/* Only for PH1-Pro4 */ +#define SG_LOADPINCTRL (SG_CTRL_BASE | 0x1700) + +/* Input Enable */ +#define SG_IECTRL (SG_CTRL_BASE | 0x1d00) + +/* Pin Monitor */ +#define SG_PINMON0 (SG_DBG_BASE | 0x0100) + +#define SG_PINMON0_CLK_MODE_UPLLSRC_MASK (0x3 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT (0x0 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_VPLL27A (0x2 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_VPLL27B (0x3 << 19) + +#define SG_PINMON0_CLK_MODE_AXOSEL_MASK (0x3 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_24576KHZ (0x0 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ (0x1 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_6144KHZ (0x2 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ (0x3 << 16) + +#define SG_PINMON0_CLK_MODE_AXOSEL_DEFAULT (0x0 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U (0x1 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_20480KHZ (0x2 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A (0x3 << 16) + +#ifndef __ASSEMBLY__ +#include <common.h> +#include <asm/io.h> + +static inline void sg_set_pinsel(int n, int value) +{ + writel((readl(SG_PINSEL_ADDR(n)) & SG_PINSEL_MASK(n)) + | SG_PINSEL_MODE(n, value), SG_PINSEL_ADDR(n)); +} + +static inline u32 sg_memconf_val_ch0(unsigned long size, int num) +{ + int size_mb = (size >> 20) / num; + u32 ret; + + switch (size_mb) { + case 64: + ret = SG_MEMCONF_CH0_SIZE_64MB; + break; + case 128: + ret = SG_MEMCONF_CH0_SIZE_128MB; + break; + case 256: + ret = SG_MEMCONF_CH0_SIZE_256MB; + break; + case 512: + ret = SG_MEMCONF_CH0_SIZE_512MB; + break; + case 1024: + ret = SG_MEMCONF_CH0_SIZE_1024MB; + break; + default: + BUG(); + break; + } + + switch (num) { + case 1: + ret |= SG_MEMCONF_CH0_NUM_1; + break; + case 2: + ret |= SG_MEMCONF_CH0_NUM_2; + break; + default: + BUG(); + break; + } + return ret; +} + +static inline u32 sg_memconf_val_ch1(unsigned long size, int num) +{ + int size_mb = (size >> 20) / num; + u32 ret; + + switch (size_mb) { + case 64: + ret = SG_MEMCONF_CH1_SIZE_64MB; + break; + case 128: + ret = SG_MEMCONF_CH1_SIZE_128MB; + break; + case 256: + ret = SG_MEMCONF_CH1_SIZE_256MB; + break; + case 512: + ret = SG_MEMCONF_CH1_SIZE_512MB; + break; + case 1024: + ret = SG_MEMCONF_CH1_SIZE_1024MB; + break; + default: + BUG(); + break; + } + + switch (num) { + case 1: + ret |= SG_MEMCONF_CH1_NUM_1; + break; + case 2: + ret |= SG_MEMCONF_CH1_NUM_2; + break; + default: + BUG(); + break; + } + return ret; +} +#endif /* __ASSEMBLY__ */ + +#endif /* ARCH_SG_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/ssc-regs.h b/arch/arm/include/asm/arch-uniphier/ssc-regs.h new file mode 100644 index 0000000..ae49956 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/ssc-regs.h @@ -0,0 +1,65 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SSC_REGS_H +#define ARCH_SSC_REGS_H + +#define SSCC 0x500c0000 +#define SSCC_BST (0x1 << 20) +#define SSCC_ACT (0x1 << 19) +#define SSCC_WTG (0x1 << 18) +#define SSCC_PRD (0x1 << 17) +#define SSCC_WBWA (0x1 << 16) +#define SSCC_EX (0x1 << 13) +#define SSCC_ON (0x1 << 0) + +#define SSCLPDAWCR 0x500c0030 + +#define SSCOPE 0x506c0244 +#define SSCOPE_CM_SYNC 0x00000008 + +#define SSCOQM 0x506c0248 +#define SSCOQM_TID_MASK (0x3 << 21) +#define SSCOQM_TID_BY_WAY (0x2 << 21) +#define SSCOQM_TID_BY_INST_WAY (0x1 << 21) +#define SSCOQM_TID_BY_DATA_WAY (0x0 << 21) +#define SSCOQM_S_MASK (0x3 << 17) +#define SSCOQM_S_WAY (0x2 << 17) +#define SSCOQM_S_ALL (0x1 << 17) +#define SSCOQM_S_ADDRESS (0x0 << 17) +#define SSCOQM_CE (0x1 << 15) +#define SSCOQM_CW (0x1 << 14) +#define SSCOQM_CM_MASK (0x7) +#define SSCOQM_CM_DIRT_TOUCH (0x7) +#define SSCOQM_CM_ZERO_TOUCH (0x6) +#define SSCOQM_CM_NORM_TOUCH (0x5) +#define SSCOQM_CM_PREF_FETCH (0x4) +#define SSCOQM_CM_SSC_FETCH (0x3) +#define SSCOQM_CM_WB_INV (0x2) +#define SSCOQM_CM_WB (0x1) +#define SSCOQM_CM_INV (0x0) + +#define SSCOQAD 0x506c024c +#define SSCOQSZ 0x506c0250 +#define SSCOQWN 0x506c0258 + +#define SSCOPPQSEF 0x506c025c +#define SSCOPPQSEF_FE (0x1 << 1) +#define SSCOPPQSEF_OE (0x1 << 0) + +#define SSCOLPQS 0x506c0260 +#define SSCOLPQS_EF (0x1 << 2) +#define SSCOLPQS_EST (0x1 << 1) +#define SSCOLPQS_QST (0x1 << 0) + +#define SSCOQCE0 0x506c0270 + +#define SSC_LINE_SIZE 128 +#define SSC_NUM_ENTRIES 256 +#define SSC_WAY_SIZE ((SSC_LINE_SIZE) * (SSC_NUM_ENTRIES)) +#define SSC_RANGE_OP_MAX_SIZE (0x00400000 - (SSC_LINE_SIZE)) + +#endif /* ARCH_SSC_REGS_H */
Hi Masahiro,
On Fri, 4 Jul 2014 19:19:15 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Subject: [PATCH 3/6] arm: uniphier: add UniPhier SoC suppurt code
Typo in subject -- since you're going to do a v2, please fix this too, thanks!
These are used by Panasonic UniPhier SoC family.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com
arch/arm/cpu/armv7/uniphier/Makefile | 23 + arch/arm/cpu/armv7/uniphier/board_common.c | 32 + arch/arm/cpu/armv7/uniphier/board_late_init.c | 37 + arch/arm/cpu/armv7/uniphier/cache_uniphier.c | 154 +++ arch/arm/cpu/armv7/uniphier/cmd_pinmon.c | 33 + arch/arm/cpu/armv7/uniphier/cpu_info.c | 59 ++ arch/arm/cpu/armv7/uniphier/dram_init.c | 37 + arch/arm/cpu/armv7/uniphier/init_page_table.c | 1068 ++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/lowlevel_init.S | 159 +++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c | 33 + arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c | 16
- .../armv7/uniphier/ph1-ld4/board_postclk_init.c | 42 +
arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c | 63 ++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c | 189 ++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c | 44 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c | 16
- .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 39 +
arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c | 66 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c | 45 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c | 168 +++ .../arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c | 18 + arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 75 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c | 16
- .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 +
arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c | 57 ++ arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c | 201 ++++ .../arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c | 51 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c | 10 + arch/arm/cpu/armv7/uniphier/reset.c | 29 + arch/arm/cpu/armv7/uniphier/smp.S | 54 + arch/arm/cpu/armv7/uniphier/spl.c | 17 + arch/arm/cpu/armv7/uniphier/support_card.c | 180 ++++ arch/arm/cpu/armv7/uniphier/timer.c | 39 + arch/arm/include/asm/arch-uniphier/arm-mpcore.h | 46 + arch/arm/include/asm/arch-uniphier/bcu-regs.h | 29 + arch/arm/include/asm/arch-uniphier/board.h | 35 + arch/arm/include/asm/arch-uniphier/boot-device.h | 20 + arch/arm/include/asm/arch-uniphier/led.h | 101 ++ arch/arm/include/asm/arch-uniphier/sbc-regs.h | 107 ++ arch/arm/include/asm/arch-uniphier/sc-regs.h | 62 ++ arch/arm/include/asm/arch-uniphier/sg-regs.h | 182 ++++ arch/arm/include/asm/arch-uniphier/ssc-regs.h | 65 ++ 58 files changed, 3917 insertions(+) create mode 100644 arch/arm/cpu/armv7/uniphier/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/board_common.c create mode 100644 arch/arm/cpu/armv7/uniphier/board_late_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/cache_uniphier.c create mode 100644 arch/arm/cpu/armv7/uniphier/cmd_pinmon.c create mode 100644 arch/arm/cpu/armv7/uniphier/cpu_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/dram_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/init_page_table.c create mode 100644 arch/arm/cpu/armv7/uniphier/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/reset.c create mode 100644 arch/arm/cpu/armv7/uniphier/smp.S create mode 100644 arch/arm/cpu/armv7/uniphier/spl.c create mode 100644 arch/arm/cpu/armv7/uniphier/support_card.c create mode 100644 arch/arm/cpu/armv7/uniphier/timer.c create mode 100644 arch/arm/include/asm/arch-uniphier/arm-mpcore.h create mode 100644 arch/arm/include/asm/arch-uniphier/bcu-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/board.h create mode 100644 arch/arm/include/asm/arch-uniphier/boot-device.h create mode 100644 arch/arm/include/asm/arch-uniphier/led.h create mode 100644 arch/arm/include/asm/arch-uniphier/sbc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sg-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/ssc-regs.h
diff --git a/arch/arm/cpu/armv7/uniphier/Makefile b/arch/arm/cpu/armv7/uniphier/Makefile new file mode 100644 index 0000000..13d6ef1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/Makefile @@ -0,0 +1,23 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-$(CONFIG_SPL_BUILD) += lowlevel_init.o init_page_table.o +obj-$(CONFIG_SPL_BUILD) += spl.o
+obj-y += timer.o +obj-y += reset.o +obj-y += cache_uniphier.o +obj-y += dram_init.o +obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o +obj-$(CONFIG_UNIPHIER_SMP) += smp.o +obj-$(if $(CONFIG_SPL_BUILD),,y) += cmd_pinmon.o
+obj-y += board_common.o +obj-$(CONFIG_PFC_MICRO_SUPPORT_CARD) += support_card.o +obj-$(CONFIG_DCC_MICRO_SUPPORT_CARD) += support_card.o
+obj-$(CONFIG_PH1_LD4) += ph1-ld4/ +obj-$(CONFIG_PH1_PRO4) += ph1-pro4/ +obj-$(CONFIG_PH1_SLD8) += ph1-sld8/ diff --git a/arch/arm/cpu/armv7/uniphier/board_common.c b/arch/arm/cpu/armv7/uniphier/board_common.c new file mode 100644 index 0000000..3fb26c6 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/board_common.c @@ -0,0 +1,32 @@ +/*
- Copyright (C) 2012-2014 Panasonic Corporation
- Author: Masahiro Yamada yamada.m@jp.panasonic.com
+#include <common.h> +#include <asm/arch/led.h>
- Routine: board_init
- Description: Early hardware init.
+int board_init(void) +{
- led_write(U, B, O, O);
+#if CONFIG_NR_DRAM_BANKS >= 2 +void dram_init_banksize(void) +{
- DECLARE_GLOBAL_DATA_PTR;
- gd->bd->bi_dram[0].start = CONFIG_SDRAM0_BASE;
- gd->bd->bi_dram[0].size = CONFIG_SDRAM0_SIZE;
- gd->bd->bi_dram[1].start = CONFIG_SDRAM1_BASE;
- gd->bd->bi_dram[1].size = CONFIG_SDRAM1_SIZE;
+} +#endif diff --git a/arch/arm/cpu/armv7/uniphier/board_late_init.c b/arch/arm/cpu/armv7/uniphier/board_late_init.c new file mode 100644 index 0000000..844b3e1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/board_late_init.c @@ -0,0 +1,37 @@ +/*
- Copyright (C) 2014 Panasonic Corporation
+#include <common.h> +#include <spl.h> +#include <nand.h> +#include <asm/io.h> +#include <../drivers/mtd/nand/denali.h>
+static void nand_denali_wp_disable(void) +{
- void __iomem *denali_reg = (void __iomem
*)CONFIG_SYS_NAND_REGS_BASE; +
- writel(WRITE_PROTECT__FLAG, denali_reg + WRITE_PROTECT);
+int board_late_init(void) +{
- puts("MODE: ");
- switch (spl_boot_device()) {
- case BOOT_DEVICE_NAND:
printf("NAND Boot\n");
setenv("bootmode", "nandboot");
nand_denali_wp_disable();
break;
- default:
printf("Unsupported Boot Mode\n");
Please add the mode value (decimal, hex or binary as you prefer, as long as the reader can understand the format) to the output.
return -1;
+} diff --git a/arch/arm/cpu/armv7/uniphier/cache_uniphier.c b/arch/arm/cpu/armv7/uniphier/cache_uniphier.c new file mode 100644 index 0000000..e47f977 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cache_uniphier.c @@ -0,0 +1,154 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/armv7.h> +#include <asm/arch/ssc-regs.h>
+#ifdef CONFIG_UNIPHIER_L2CACHE_ON +static void uniphier_cache_maint_all(u32 operation) +{
- /* try until the command is successfully set */
- do {
writel(SSCOQM_S_ALL | SSCOQM_CE | operation, SSCOQM);
- } while (readl(SSCOPPQSEF) & (SSCOPPQSEF_FE |
SSCOPPQSEF_OE)); +
- /* wait until the operation is completed */
- while (readl(SSCOLPQS) != SSCOLPQS_EF)
- /* clear the complete notification flag */
- writel(SSCOLPQS_EF, SSCOLPQS);
- writel(SSCOPE_CM_SYNC, SSCOPE); /* drain internal buffers */
- readl(SSCOPE); /* need a read back to confirm */
+void v7_outer_cache_flush_all(void) +{
- uniphier_cache_maint_all(SSCOQM_CM_WB_INV);
+void v7_outer_cache_inval_all(void) +{
- uniphier_cache_maint_all(SSCOQM_CM_INV);
+static void __uniphier_cache_maint_range(u32 start, u32 size, u32 operation) +{
- do {
writel(SSCOQM_S_ADDRESS | SSCOQM_CE | operation,
SSCOQM);
writel(start, SSCOQAD);
writel(size, SSCOQSZ);
SSCOPPQSEF_OE)); +
+static void uniphier_cache_maint_range(u32 start, u32 end, u32 operation) +{
- u32 size;
* If start address is not aligned to cache-line,
* do cache operation for the first cache-line
- start = start & ~(SSC_LINE_SIZE - 1);
- if (start == 0 && end >= (u32)(-SSC_LINE_SIZE)) {
/* this means cache operation for all range */
uniphier_cache_maint_all(operation);
return;
* If end address is not aligned to cache-line,
* do cache operation for the last cache-line
- size = (end - start + SSC_LINE_SIZE - 1) & ~(SSC_LINE_SIZE -
1); +
- while (size) {
u32 chunk_size = size > SSC_RANGE_OP_MAX_SIZE ?
SSC_RANGE_OP_MAX_SIZE : size;
__uniphier_cache_maint_range(start, chunk_size,
operation); +
start += chunk_size;
size -= chunk_size;
Does the readback contain some status showing whether the drain is in progress vs. complete? If it does, then shouldn't the line above be a loop waiting for completion?
+void v7_outer_cache_flush_range(u32 start, u32 end) +{
- uniphier_cache_maint_range(start, end, SSCOQM_CM_WB_INV);
+void v7_outer_cache_inval_range(u32 start, u32 end) +{
- uniphier_cache_maint_range(start, end, SSCOQM_CM_INV);
+void v7_outer_cache_enable(void) +{
- u32 tmp;
- tmp = readl(SSCC);
- tmp |= SSCC_ON;
- writel(tmp, SSCC);
+} +#endif
+void v7_outer_cache_disable(void) +{
- u32 tmp;
- tmp &= ~SSCC_ON;
+void wakeup_secondary(void);
+void enable_caches(void) +{
- uint32_t reg;
+#ifdef CONFIG_UNIPHIER_SMP
* The secondary CPU must move to DDR,
* before L2 disable.
* On SPL, the Page Table is located on the L2.
- wakeup_secondary();
* UniPhier SoCs must use L2 cache for init stack pointer.
* We disable L2 and L1 in this order.
* If CONFIG_SYS_DCACHE_OFF is not defined,
* caches are enabled again with a new page table.
- /* L2 disable */
- v7_outer_cache_disable();
- /* L1 disable */
- reg = get_cr();
- reg &= ~(CR_C | CR_M);
- set_cr(reg);
+#ifndef CONFIG_SYS_DCACHE_OFF
- dcache_enable();
+#endif +} diff --git a/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c b/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c new file mode 100644 index 0000000..eef9f39 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c @@ -0,0 +1,33 @@ +/*
+#include <common.h> +#include <asm/arch/boot-device.h>
+static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
- struct boot_device_info *table;
- u32 mode_sel, n = 0;
- mode_sel = get_boot_mode_sel();
- puts("Boot Mode Pin:\n");
- for (table = boot_device_table; strlen(table->info);
table++) {
printf(" %c %02x %s\n", n == mode_sel ? '*' : ' ', n,
table->info);
n++;
+U_BOOT_CMD(
- pinmon, 1, 1, do_pinmon,
- "pin monitor",
+); diff --git a/arch/arm/cpu/armv7/uniphier/cpu_info.c b/arch/arm/cpu/armv7/uniphier/cpu_info.c new file mode 100644 index 0000000..86d079a --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cpu_info.c @@ -0,0 +1,59 @@ +/*
- Copyright (C) 2013-2014 Panasonic Corporation
+int print_cpuinfo(void) +{
- u32 revision, type, model, rev, required_model = 1,
required_rev = 1; +
- revision = readl(SG_REVISION);
- type = (revision & SG_REVISION_TYPE_MASK) >>
SG_REVISION_TYPE_SHIFT;
- model = (revision & SG_REVISION_MODEL_MASK) >>
SG_REVISION_MODEL_SHIFT;
- rev = (revision & SG_REVISION_REV_MASK) >>
SG_REVISION_REV_SHIFT; +
- puts("CPU: ");
- switch (type) {
- case 0x25:
puts("PH1-sLD3 (MN2WS0220)");
required_model = 2;
break;
- case 0x26:
puts("PH1-LD4 (MN2WS0250)");
required_rev = 2;
break;
- case 0x28:
puts("PH1-Pro4 (MN2WS0230)");
break;
- case 0x29:
puts("PH1-sLD8 (MN2WS0270)");
break;
- default:
printf("Unknown Processor ID (0x%x)\n", revision);
return -1;
Maybe use symbolic constants rather tha magic numbers in switch cases above.
- if (model > 1)
printf(" model %d", model);
- printf(" (rev. %d)\n", rev);
- if (model < required_model) {
printf("Sorry, this model is not supported.\n");
printf("Required model is %d.", required_model);
return -1;
- } else if (rev < required_rev) {
printf("Sorry, this revision is not supported.\n");
printf("Required revision is %d.", required_rev);
return -1;
+} diff --git a/arch/arm/cpu/armv7/uniphier/dram_init.c b/arch/arm/cpu/armv7/uniphier/dram_init.c new file mode 100644 index 0000000..5465a0e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/dram_init.c @@ -0,0 +1,37 @@ +/*
+int umc_init(void); +void enable_dpll_ssc(void);
+int dram_init(void) +{
- gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
+#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)
- led_write(B, 4, , );
int res;
res = umc_init();
if (res < 0)
return res;
- led_write(B, 5, , );
- enable_dpll_ssc();
- led_write(B, 6, , );
+} diff --git a/arch/arm/cpu/armv7/uniphier/init_page_table.c b/arch/arm/cpu/armv7/uniphier/init_page_table.c new file mode 100644 index 0000000..d273835 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/init_page_table.c @@ -0,0 +1,1068 @@ +/*
+/* encoding without TEX remap */ +#define NO_MAP 0x00000000 /* No Map */ +#define DEVICE 0x00002002 /* Non-shareable Device */ +#define NORMAL 0x0000000e /* Normal Memory Write-Back, No Write-Allocate */ + +#define SSC NORMAL /* System Cache: Normal */ +#define EXT DEVICE /* External Bus: Device */ +#define REG DEVICE /* IO Register: Device */ +#define DDR DEVICE /* DDR SDRAM: Device */
+#ifdef CONFIG_SPL_BUILD +#define IS_SPL_TEXT_AREA(x) ((x) == ((CONFIG_SPL_TEXT_BASE)
20)) +#else
+#define IS_SPL_TEXT_AREA(x) ((x) == ((CONFIG_SYS_TEXT_BASE)
20)) +#endif
+#define IS_INIT_STACK_AREA(x) ((x) == ((CONFIG_SYS_INIT_SP_ADDR) >> 20)) + +#define IS_SSC(x) ((IS_SPL_TEXT_AREA(x)) || \
(IS_INIT_STACK_AREA(x)))
+#define IS_EXT(x) ((x) < 0x100) +#define IS_REG(x) (0x500 <= (x) && (x) < 0x700) +#define IS_DDR(x) (0x800 <= (x) && (x) < 0xf00)
+#define MMU_FLAGS(x) (IS_SSC(x)) ? SSC : \
(IS_EXT(x)) ? EXT : \
(IS_REG(x)) ? REG : \
(IS_DDR(x)) ? DDR : \
NO_MAP + +#define TBL_ENTRY(x) (((x) << 20) | (MMU_FLAGS(x)))
+const u32 __aligned(PGTABLE_SIZE) init_page_table[PGTABLE_SIZE / sizeof(u32)]
- TBL_ENTRY(0x000), TBL_ENTRY(0x001), TBL_ENTRY(0x002),
TBL_ENTRY(0x003),
- TBL_ENTRY(0x004), TBL_ENTRY(0x005), TBL_ENTRY(0x006),
TBL_ENTRY(0x007),
- TBL_ENTRY(0x008), TBL_ENTRY(0x009), TBL_ENTRY(0x00a),
TBL_ENTRY(0x00b),
- TBL_ENTRY(0x00c), TBL_ENTRY(0x00d), TBL_ENTRY(0x00e),
TBL_ENTRY(0x00f),
- TBL_ENTRY(0x010), TBL_ENTRY(0x011), TBL_ENTRY(0x012),
TBL_ENTRY(0x013),
- TBL_ENTRY(0x014), TBL_ENTRY(0x015), TBL_ENTRY(0x016),
TBL_ENTRY(0x017),
- TBL_ENTRY(0x018), TBL_ENTRY(0x019), TBL_ENTRY(0x01a),
TBL_ENTRY(0x01b),
- TBL_ENTRY(0x01c), TBL_ENTRY(0x01d), TBL_ENTRY(0x01e),
TBL_ENTRY(0x01f),
- TBL_ENTRY(0x020), TBL_ENTRY(0x021), TBL_ENTRY(0x022),
TBL_ENTRY(0x023),
- TBL_ENTRY(0x024), TBL_ENTRY(0x025), TBL_ENTRY(0x026),
TBL_ENTRY(0x027),
- TBL_ENTRY(0x028), TBL_ENTRY(0x029), TBL_ENTRY(0x02a),
TBL_ENTRY(0x02b),
- TBL_ENTRY(0x02c), TBL_ENTRY(0x02d), TBL_ENTRY(0x02e),
TBL_ENTRY(0x02f),
- TBL_ENTRY(0x030), TBL_ENTRY(0x031), TBL_ENTRY(0x032),
TBL_ENTRY(0x033),
- TBL_ENTRY(0x034), TBL_ENTRY(0x035), TBL_ENTRY(0x036),
TBL_ENTRY(0x037),
- TBL_ENTRY(0x038), TBL_ENTRY(0x039), TBL_ENTRY(0x03a),
TBL_ENTRY(0x03b),
- TBL_ENTRY(0x03c), TBL_ENTRY(0x03d), TBL_ENTRY(0x03e),
TBL_ENTRY(0x03f),
- TBL_ENTRY(0x040), TBL_ENTRY(0x041), TBL_ENTRY(0x042),
TBL_ENTRY(0x043),
- TBL_ENTRY(0x044), TBL_ENTRY(0x045), TBL_ENTRY(0x046),
TBL_ENTRY(0x047),
- TBL_ENTRY(0x048), TBL_ENTRY(0x049), TBL_ENTRY(0x04a),
TBL_ENTRY(0x04b),
- TBL_ENTRY(0x04c), TBL_ENTRY(0x04d), TBL_ENTRY(0x04e),
TBL_ENTRY(0x04f),
- TBL_ENTRY(0x050), TBL_ENTRY(0x051), TBL_ENTRY(0x052),
TBL_ENTRY(0x053),
- TBL_ENTRY(0x054), TBL_ENTRY(0x055), TBL_ENTRY(0x056),
TBL_ENTRY(0x057),
- TBL_ENTRY(0x058), TBL_ENTRY(0x059), TBL_ENTRY(0x05a),
TBL_ENTRY(0x05b),
- TBL_ENTRY(0x05c), TBL_ENTRY(0x05d), TBL_ENTRY(0x05e),
TBL_ENTRY(0x05f),
- TBL_ENTRY(0x060), TBL_ENTRY(0x061), TBL_ENTRY(0x062),
TBL_ENTRY(0x063),
- TBL_ENTRY(0x064), TBL_ENTRY(0x065), TBL_ENTRY(0x066),
TBL_ENTRY(0x067),
- TBL_ENTRY(0x068), TBL_ENTRY(0x069), TBL_ENTRY(0x06a),
TBL_ENTRY(0x06b),
- TBL_ENTRY(0x06c), TBL_ENTRY(0x06d), TBL_ENTRY(0x06e),
TBL_ENTRY(0x06f),
- TBL_ENTRY(0x070), TBL_ENTRY(0x071), TBL_ENTRY(0x072),
TBL_ENTRY(0x073),
- TBL_ENTRY(0x074), TBL_ENTRY(0x075), TBL_ENTRY(0x076),
TBL_ENTRY(0x077),
- TBL_ENTRY(0x078), TBL_ENTRY(0x079), TBL_ENTRY(0x07a),
TBL_ENTRY(0x07b),
- TBL_ENTRY(0x07c), TBL_ENTRY(0x07d), TBL_ENTRY(0x07e),
TBL_ENTRY(0x07f),
- TBL_ENTRY(0x080), TBL_ENTRY(0x081), TBL_ENTRY(0x082),
TBL_ENTRY(0x083),
- TBL_ENTRY(0x084), TBL_ENTRY(0x085), TBL_ENTRY(0x086),
TBL_ENTRY(0x087),
- TBL_ENTRY(0x088), TBL_ENTRY(0x089), TBL_ENTRY(0x08a),
TBL_ENTRY(0x08b),
- TBL_ENTRY(0x08c), TBL_ENTRY(0x08d), TBL_ENTRY(0x08e),
TBL_ENTRY(0x08f),
- TBL_ENTRY(0x090), TBL_ENTRY(0x091), TBL_ENTRY(0x092),
TBL_ENTRY(0x093),
- TBL_ENTRY(0x094), TBL_ENTRY(0x095), TBL_ENTRY(0x096),
TBL_ENTRY(0x097),
- TBL_ENTRY(0x098), TBL_ENTRY(0x099), TBL_ENTRY(0x09a),
TBL_ENTRY(0x09b),
- TBL_ENTRY(0x09c), TBL_ENTRY(0x09d), TBL_ENTRY(0x09e),
TBL_ENTRY(0x09f),
- TBL_ENTRY(0x0a0), TBL_ENTRY(0x0a1), TBL_ENTRY(0x0a2),
TBL_ENTRY(0x0a3),
- TBL_ENTRY(0x0a4), TBL_ENTRY(0x0a5), TBL_ENTRY(0x0a6),
TBL_ENTRY(0x0a7),
- TBL_ENTRY(0x0a8), TBL_ENTRY(0x0a9), TBL_ENTRY(0x0aa),
TBL_ENTRY(0x0ab),
- TBL_ENTRY(0x0ac), TBL_ENTRY(0x0ad), TBL_ENTRY(0x0ae),
TBL_ENTRY(0x0af),
- TBL_ENTRY(0x0b0), TBL_ENTRY(0x0b1), TBL_ENTRY(0x0b2),
TBL_ENTRY(0x0b3),
- TBL_ENTRY(0x0b4), TBL_ENTRY(0x0b5), TBL_ENTRY(0x0b6),
TBL_ENTRY(0x0b7),
- TBL_ENTRY(0x0b8), TBL_ENTRY(0x0b9), TBL_ENTRY(0x0ba),
TBL_ENTRY(0x0bb),
- TBL_ENTRY(0x0bc), TBL_ENTRY(0x0bd), TBL_ENTRY(0x0be),
TBL_ENTRY(0x0bf),
- TBL_ENTRY(0x0c0), TBL_ENTRY(0x0c1), TBL_ENTRY(0x0c2),
TBL_ENTRY(0x0c3),
- TBL_ENTRY(0x0c4), TBL_ENTRY(0x0c5), TBL_ENTRY(0x0c6),
TBL_ENTRY(0x0c7),
- TBL_ENTRY(0x0c8), TBL_ENTRY(0x0c9), TBL_ENTRY(0x0ca),
TBL_ENTRY(0x0cb),
- TBL_ENTRY(0x0cc), TBL_ENTRY(0x0cd), TBL_ENTRY(0x0ce),
TBL_ENTRY(0x0cf),
- TBL_ENTRY(0x0d0), TBL_ENTRY(0x0d1), TBL_ENTRY(0x0d2),
TBL_ENTRY(0x0d3),
- TBL_ENTRY(0x0d4), TBL_ENTRY(0x0d5), TBL_ENTRY(0x0d6),
TBL_ENTRY(0x0d7),
- TBL_ENTRY(0x0d8), TBL_ENTRY(0x0d9), TBL_ENTRY(0x0da),
TBL_ENTRY(0x0db),
- TBL_ENTRY(0x0dc), TBL_ENTRY(0x0dd), TBL_ENTRY(0x0de),
TBL_ENTRY(0x0df),
- TBL_ENTRY(0x0e0), TBL_ENTRY(0x0e1), TBL_ENTRY(0x0e2),
TBL_ENTRY(0x0e3),
- TBL_ENTRY(0x0e4), TBL_ENTRY(0x0e5), TBL_ENTRY(0x0e6),
TBL_ENTRY(0x0e7),
- TBL_ENTRY(0x0e8), TBL_ENTRY(0x0e9), TBL_ENTRY(0x0ea),
TBL_ENTRY(0x0eb),
- TBL_ENTRY(0x0ec), TBL_ENTRY(0x0ed), TBL_ENTRY(0x0ee),
TBL_ENTRY(0x0ef),
- TBL_ENTRY(0x0f0), TBL_ENTRY(0x0f1), TBL_ENTRY(0x0f2),
TBL_ENTRY(0x0f3),
- TBL_ENTRY(0x0f4), TBL_ENTRY(0x0f5), TBL_ENTRY(0x0f6),
TBL_ENTRY(0x0f7),
- TBL_ENTRY(0x0f8), TBL_ENTRY(0x0f9), TBL_ENTRY(0x0fa),
TBL_ENTRY(0x0fb),
- TBL_ENTRY(0x0fc), TBL_ENTRY(0x0fd), TBL_ENTRY(0x0fe),
TBL_ENTRY(0x0ff),
- TBL_ENTRY(0x100), TBL_ENTRY(0x101), TBL_ENTRY(0x102),
TBL_ENTRY(0x103),
- TBL_ENTRY(0x104), TBL_ENTRY(0x105), TBL_ENTRY(0x106),
TBL_ENTRY(0x107),
- TBL_ENTRY(0x108), TBL_ENTRY(0x109), TBL_ENTRY(0x10a),
TBL_ENTRY(0x10b),
- TBL_ENTRY(0x10c), TBL_ENTRY(0x10d), TBL_ENTRY(0x10e),
TBL_ENTRY(0x10f),
- TBL_ENTRY(0x110), TBL_ENTRY(0x111), TBL_ENTRY(0x112),
TBL_ENTRY(0x113),
- TBL_ENTRY(0x114), TBL_ENTRY(0x115), TBL_ENTRY(0x116),
TBL_ENTRY(0x117),
- TBL_ENTRY(0x118), TBL_ENTRY(0x119), TBL_ENTRY(0x11a),
TBL_ENTRY(0x11b),
- TBL_ENTRY(0x11c), TBL_ENTRY(0x11d), TBL_ENTRY(0x11e),
TBL_ENTRY(0x11f),
- TBL_ENTRY(0x120), TBL_ENTRY(0x121), TBL_ENTRY(0x122),
TBL_ENTRY(0x123),
- TBL_ENTRY(0x124), TBL_ENTRY(0x125), TBL_ENTRY(0x126),
TBL_ENTRY(0x127),
- TBL_ENTRY(0x128), TBL_ENTRY(0x129), TBL_ENTRY(0x12a),
TBL_ENTRY(0x12b),
- TBL_ENTRY(0x12c), TBL_ENTRY(0x12d), TBL_ENTRY(0x12e),
TBL_ENTRY(0x12f),
- TBL_ENTRY(0x130), TBL_ENTRY(0x131), TBL_ENTRY(0x132),
TBL_ENTRY(0x133),
- TBL_ENTRY(0x134), TBL_ENTRY(0x135), TBL_ENTRY(0x136),
TBL_ENTRY(0x137),
- TBL_ENTRY(0x138), TBL_ENTRY(0x139), TBL_ENTRY(0x13a),
TBL_ENTRY(0x13b),
- TBL_ENTRY(0x13c), TBL_ENTRY(0x13d), TBL_ENTRY(0x13e),
TBL_ENTRY(0x13f),
- TBL_ENTRY(0x140), TBL_ENTRY(0x141), TBL_ENTRY(0x142),
TBL_ENTRY(0x143),
- TBL_ENTRY(0x144), TBL_ENTRY(0x145), TBL_ENTRY(0x146),
TBL_ENTRY(0x147),
- TBL_ENTRY(0x148), TBL_ENTRY(0x149), TBL_ENTRY(0x14a),
TBL_ENTRY(0x14b),
- TBL_ENTRY(0x14c), TBL_ENTRY(0x14d), TBL_ENTRY(0x14e),
TBL_ENTRY(0x14f),
- TBL_ENTRY(0x150), TBL_ENTRY(0x151), TBL_ENTRY(0x152),
TBL_ENTRY(0x153),
- TBL_ENTRY(0x154), TBL_ENTRY(0x155), TBL_ENTRY(0x156),
TBL_ENTRY(0x157),
- TBL_ENTRY(0x158), TBL_ENTRY(0x159), TBL_ENTRY(0x15a),
TBL_ENTRY(0x15b),
- TBL_ENTRY(0x15c), TBL_ENTRY(0x15d), TBL_ENTRY(0x15e),
TBL_ENTRY(0x15f),
- TBL_ENTRY(0x160), TBL_ENTRY(0x161), TBL_ENTRY(0x162),
TBL_ENTRY(0x163),
- TBL_ENTRY(0x164), TBL_ENTRY(0x165), TBL_ENTRY(0x166),
TBL_ENTRY(0x167),
- TBL_ENTRY(0x168), TBL_ENTRY(0x169), TBL_ENTRY(0x16a),
TBL_ENTRY(0x16b),
- TBL_ENTRY(0x16c), TBL_ENTRY(0x16d), TBL_ENTRY(0x16e),
TBL_ENTRY(0x16f),
- TBL_ENTRY(0x170), TBL_ENTRY(0x171), TBL_ENTRY(0x172),
TBL_ENTRY(0x173),
- TBL_ENTRY(0x174), TBL_ENTRY(0x175), TBL_ENTRY(0x176),
TBL_ENTRY(0x177),
- TBL_ENTRY(0x178), TBL_ENTRY(0x179), TBL_ENTRY(0x17a),
TBL_ENTRY(0x17b),
- TBL_ENTRY(0x17c), TBL_ENTRY(0x17d), TBL_ENTRY(0x17e),
TBL_ENTRY(0x17f),
- TBL_ENTRY(0x180), TBL_ENTRY(0x181), TBL_ENTRY(0x182),
TBL_ENTRY(0x183),
- TBL_ENTRY(0x184), TBL_ENTRY(0x185), TBL_ENTRY(0x186),
TBL_ENTRY(0x187),
- TBL_ENTRY(0x188), TBL_ENTRY(0x189), TBL_ENTRY(0x18a),
TBL_ENTRY(0x18b),
- TBL_ENTRY(0x18c), TBL_ENTRY(0x18d), TBL_ENTRY(0x18e),
TBL_ENTRY(0x18f),
- TBL_ENTRY(0x190), TBL_ENTRY(0x191), TBL_ENTRY(0x192),
TBL_ENTRY(0x193),
- TBL_ENTRY(0x194), TBL_ENTRY(0x195), TBL_ENTRY(0x196),
TBL_ENTRY(0x197),
- TBL_ENTRY(0x198), TBL_ENTRY(0x199), TBL_ENTRY(0x19a),
TBL_ENTRY(0x19b),
- TBL_ENTRY(0x19c), TBL_ENTRY(0x19d), TBL_ENTRY(0x19e),
TBL_ENTRY(0x19f),
- TBL_ENTRY(0x1a0), TBL_ENTRY(0x1a1), TBL_ENTRY(0x1a2),
TBL_ENTRY(0x1a3),
- TBL_ENTRY(0x1a4), TBL_ENTRY(0x1a5), TBL_ENTRY(0x1a6),
TBL_ENTRY(0x1a7),
- TBL_ENTRY(0x1a8), TBL_ENTRY(0x1a9), TBL_ENTRY(0x1aa),
TBL_ENTRY(0x1ab),
- TBL_ENTRY(0x1ac), TBL_ENTRY(0x1ad), TBL_ENTRY(0x1ae),
TBL_ENTRY(0x1af),
- TBL_ENTRY(0x1b0), TBL_ENTRY(0x1b1), TBL_ENTRY(0x1b2),
TBL_ENTRY(0x1b3),
- TBL_ENTRY(0x1b4), TBL_ENTRY(0x1b5), TBL_ENTRY(0x1b6),
TBL_ENTRY(0x1b7),
- TBL_ENTRY(0x1b8), TBL_ENTRY(0x1b9), TBL_ENTRY(0x1ba),
TBL_ENTRY(0x1bb),
- TBL_ENTRY(0x1bc), TBL_ENTRY(0x1bd), TBL_ENTRY(0x1be),
TBL_ENTRY(0x1bf),
- TBL_ENTRY(0x1c0), TBL_ENTRY(0x1c1), TBL_ENTRY(0x1c2),
TBL_ENTRY(0x1c3),
- TBL_ENTRY(0x1c4), TBL_ENTRY(0x1c5), TBL_ENTRY(0x1c6),
TBL_ENTRY(0x1c7),
- TBL_ENTRY(0x1c8), TBL_ENTRY(0x1c9), TBL_ENTRY(0x1ca),
TBL_ENTRY(0x1cb),
- TBL_ENTRY(0x1cc), TBL_ENTRY(0x1cd), TBL_ENTRY(0x1ce),
TBL_ENTRY(0x1cf),
- TBL_ENTRY(0x1d0), TBL_ENTRY(0x1d1), TBL_ENTRY(0x1d2),
TBL_ENTRY(0x1d3),
- TBL_ENTRY(0x1d4), TBL_ENTRY(0x1d5), TBL_ENTRY(0x1d6),
TBL_ENTRY(0x1d7),
- TBL_ENTRY(0x1d8), TBL_ENTRY(0x1d9), TBL_ENTRY(0x1da),
TBL_ENTRY(0x1db),
- TBL_ENTRY(0x1dc), TBL_ENTRY(0x1dd), TBL_ENTRY(0x1de),
TBL_ENTRY(0x1df),
- TBL_ENTRY(0x1e0), TBL_ENTRY(0x1e1), TBL_ENTRY(0x1e2),
TBL_ENTRY(0x1e3),
- TBL_ENTRY(0x1e4), TBL_ENTRY(0x1e5), TBL_ENTRY(0x1e6),
TBL_ENTRY(0x1e7),
- TBL_ENTRY(0x1e8), TBL_ENTRY(0x1e9), TBL_ENTRY(0x1ea),
TBL_ENTRY(0x1eb),
- TBL_ENTRY(0x1ec), TBL_ENTRY(0x1ed), TBL_ENTRY(0x1ee),
TBL_ENTRY(0x1ef),
- TBL_ENTRY(0x1f0), TBL_ENTRY(0x1f1), TBL_ENTRY(0x1f2),
TBL_ENTRY(0x1f3),
- TBL_ENTRY(0x1f4), TBL_ENTRY(0x1f5), TBL_ENTRY(0x1f6),
TBL_ENTRY(0x1f7),
- TBL_ENTRY(0x1f8), TBL_ENTRY(0x1f9), TBL_ENTRY(0x1fa),
TBL_ENTRY(0x1fb),
- TBL_ENTRY(0x1fc), TBL_ENTRY(0x1fd), TBL_ENTRY(0x1fe),
TBL_ENTRY(0x1ff),
- TBL_ENTRY(0x200), TBL_ENTRY(0x201), TBL_ENTRY(0x202),
TBL_ENTRY(0x203),
- TBL_ENTRY(0x204), TBL_ENTRY(0x205), TBL_ENTRY(0x206),
TBL_ENTRY(0x207),
- TBL_ENTRY(0x208), TBL_ENTRY(0x209), TBL_ENTRY(0x20a),
TBL_ENTRY(0x20b),
- TBL_ENTRY(0x20c), TBL_ENTRY(0x20d), TBL_ENTRY(0x20e),
TBL_ENTRY(0x20f),
- TBL_ENTRY(0x210), TBL_ENTRY(0x211), TBL_ENTRY(0x212),
TBL_ENTRY(0x213),
- TBL_ENTRY(0x214), TBL_ENTRY(0x215), TBL_ENTRY(0x216),
TBL_ENTRY(0x217),
- TBL_ENTRY(0x218), TBL_ENTRY(0x219), TBL_ENTRY(0x21a),
TBL_ENTRY(0x21b),
- TBL_ENTRY(0x21c), TBL_ENTRY(0x21d), TBL_ENTRY(0x21e),
TBL_ENTRY(0x21f),
- TBL_ENTRY(0x220), TBL_ENTRY(0x221), TBL_ENTRY(0x222),
TBL_ENTRY(0x223),
- TBL_ENTRY(0x224), TBL_ENTRY(0x225), TBL_ENTRY(0x226),
TBL_ENTRY(0x227),
- TBL_ENTRY(0x228), TBL_ENTRY(0x229), TBL_ENTRY(0x22a),
TBL_ENTRY(0x22b),
- TBL_ENTRY(0x22c), TBL_ENTRY(0x22d), TBL_ENTRY(0x22e),
TBL_ENTRY(0x22f),
- TBL_ENTRY(0x230), TBL_ENTRY(0x231), TBL_ENTRY(0x232),
TBL_ENTRY(0x233),
- TBL_ENTRY(0x234), TBL_ENTRY(0x235), TBL_ENTRY(0x236),
TBL_ENTRY(0x237),
- TBL_ENTRY(0x238), TBL_ENTRY(0x239), TBL_ENTRY(0x23a),
TBL_ENTRY(0x23b),
- TBL_ENTRY(0x23c), TBL_ENTRY(0x23d), TBL_ENTRY(0x23e),
TBL_ENTRY(0x23f),
- TBL_ENTRY(0x240), TBL_ENTRY(0x241), TBL_ENTRY(0x242),
TBL_ENTRY(0x243),
- TBL_ENTRY(0x244), TBL_ENTRY(0x245), TBL_ENTRY(0x246),
TBL_ENTRY(0x247),
- TBL_ENTRY(0x248), TBL_ENTRY(0x249), TBL_ENTRY(0x24a),
TBL_ENTRY(0x24b),
- TBL_ENTRY(0x24c), TBL_ENTRY(0x24d), TBL_ENTRY(0x24e),
TBL_ENTRY(0x24f),
- TBL_ENTRY(0x250), TBL_ENTRY(0x251), TBL_ENTRY(0x252),
TBL_ENTRY(0x253),
- TBL_ENTRY(0x254), TBL_ENTRY(0x255), TBL_ENTRY(0x256),
TBL_ENTRY(0x257),
- TBL_ENTRY(0x258), TBL_ENTRY(0x259), TBL_ENTRY(0x25a),
TBL_ENTRY(0x25b),
- TBL_ENTRY(0x25c), TBL_ENTRY(0x25d), TBL_ENTRY(0x25e),
TBL_ENTRY(0x25f),
- TBL_ENTRY(0x260), TBL_ENTRY(0x261), TBL_ENTRY(0x262),
TBL_ENTRY(0x263),
- TBL_ENTRY(0x264), TBL_ENTRY(0x265), TBL_ENTRY(0x266),
TBL_ENTRY(0x267),
- TBL_ENTRY(0x268), TBL_ENTRY(0x269), TBL_ENTRY(0x26a),
TBL_ENTRY(0x26b),
- TBL_ENTRY(0x26c), TBL_ENTRY(0x26d), TBL_ENTRY(0x26e),
TBL_ENTRY(0x26f),
- TBL_ENTRY(0x270), TBL_ENTRY(0x271), TBL_ENTRY(0x272),
TBL_ENTRY(0x273),
- TBL_ENTRY(0x274), TBL_ENTRY(0x275), TBL_ENTRY(0x276),
TBL_ENTRY(0x277),
- TBL_ENTRY(0x278), TBL_ENTRY(0x279), TBL_ENTRY(0x27a),
TBL_ENTRY(0x27b),
- TBL_ENTRY(0x27c), TBL_ENTRY(0x27d), TBL_ENTRY(0x27e),
TBL_ENTRY(0x27f),
- TBL_ENTRY(0x280), TBL_ENTRY(0x281), TBL_ENTRY(0x282),
TBL_ENTRY(0x283),
- TBL_ENTRY(0x284), TBL_ENTRY(0x285), TBL_ENTRY(0x286),
TBL_ENTRY(0x287),
- TBL_ENTRY(0x288), TBL_ENTRY(0x289), TBL_ENTRY(0x28a),
TBL_ENTRY(0x28b),
- TBL_ENTRY(0x28c), TBL_ENTRY(0x28d), TBL_ENTRY(0x28e),
TBL_ENTRY(0x28f),
- TBL_ENTRY(0x290), TBL_ENTRY(0x291), TBL_ENTRY(0x292),
TBL_ENTRY(0x293),
- TBL_ENTRY(0x294), TBL_ENTRY(0x295), TBL_ENTRY(0x296),
TBL_ENTRY(0x297),
- TBL_ENTRY(0x298), TBL_ENTRY(0x299), TBL_ENTRY(0x29a),
TBL_ENTRY(0x29b),
- TBL_ENTRY(0x29c), TBL_ENTRY(0x29d), TBL_ENTRY(0x29e),
TBL_ENTRY(0x29f),
- TBL_ENTRY(0x2a0), TBL_ENTRY(0x2a1), TBL_ENTRY(0x2a2),
TBL_ENTRY(0x2a3),
- TBL_ENTRY(0x2a4), TBL_ENTRY(0x2a5), TBL_ENTRY(0x2a6),
TBL_ENTRY(0x2a7),
- TBL_ENTRY(0x2a8), TBL_ENTRY(0x2a9), TBL_ENTRY(0x2aa),
TBL_ENTRY(0x2ab),
- TBL_ENTRY(0x2ac), TBL_ENTRY(0x2ad), TBL_ENTRY(0x2ae),
TBL_ENTRY(0x2af),
- TBL_ENTRY(0x2b0), TBL_ENTRY(0x2b1), TBL_ENTRY(0x2b2),
TBL_ENTRY(0x2b3),
- TBL_ENTRY(0x2b4), TBL_ENTRY(0x2b5), TBL_ENTRY(0x2b6),
TBL_ENTRY(0x2b7),
- TBL_ENTRY(0x2b8), TBL_ENTRY(0x2b9), TBL_ENTRY(0x2ba),
TBL_ENTRY(0x2bb),
- TBL_ENTRY(0x2bc), TBL_ENTRY(0x2bd), TBL_ENTRY(0x2be),
TBL_ENTRY(0x2bf),
- TBL_ENTRY(0x2c0), TBL_ENTRY(0x2c1), TBL_ENTRY(0x2c2),
TBL_ENTRY(0x2c3),
- TBL_ENTRY(0x2c4), TBL_ENTRY(0x2c5), TBL_ENTRY(0x2c6),
TBL_ENTRY(0x2c7),
- TBL_ENTRY(0x2c8), TBL_ENTRY(0x2c9), TBL_ENTRY(0x2ca),
TBL_ENTRY(0x2cb),
- TBL_ENTRY(0x2cc), TBL_ENTRY(0x2cd), TBL_ENTRY(0x2ce),
TBL_ENTRY(0x2cf),
- TBL_ENTRY(0x2d0), TBL_ENTRY(0x2d1), TBL_ENTRY(0x2d2),
TBL_ENTRY(0x2d3),
- TBL_ENTRY(0x2d4), TBL_ENTRY(0x2d5), TBL_ENTRY(0x2d6),
TBL_ENTRY(0x2d7),
- TBL_ENTRY(0x2d8), TBL_ENTRY(0x2d9), TBL_ENTRY(0x2da),
TBL_ENTRY(0x2db),
- TBL_ENTRY(0x2dc), TBL_ENTRY(0x2dd), TBL_ENTRY(0x2de),
TBL_ENTRY(0x2df),
- TBL_ENTRY(0x2e0), TBL_ENTRY(0x2e1), TBL_ENTRY(0x2e2),
TBL_ENTRY(0x2e3),
- TBL_ENTRY(0x2e4), TBL_ENTRY(0x2e5), TBL_ENTRY(0x2e6),
TBL_ENTRY(0x2e7),
- TBL_ENTRY(0x2e8), TBL_ENTRY(0x2e9), TBL_ENTRY(0x2ea),
TBL_ENTRY(0x2eb),
- TBL_ENTRY(0x2ec), TBL_ENTRY(0x2ed), TBL_ENTRY(0x2ee),
TBL_ENTRY(0x2ef),
- TBL_ENTRY(0x2f0), TBL_ENTRY(0x2f1), TBL_ENTRY(0x2f2),
TBL_ENTRY(0x2f3),
- TBL_ENTRY(0x2f4), TBL_ENTRY(0x2f5), TBL_ENTRY(0x2f6),
TBL_ENTRY(0x2f7),
- TBL_ENTRY(0x2f8), TBL_ENTRY(0x2f9), TBL_ENTRY(0x2fa),
TBL_ENTRY(0x2fb),
- TBL_ENTRY(0x2fc), TBL_ENTRY(0x2fd), TBL_ENTRY(0x2fe),
TBL_ENTRY(0x2ff),
- TBL_ENTRY(0x300), TBL_ENTRY(0x301), TBL_ENTRY(0x302),
TBL_ENTRY(0x303),
- TBL_ENTRY(0x304), TBL_ENTRY(0x305), TBL_ENTRY(0x306),
TBL_ENTRY(0x307),
- TBL_ENTRY(0x308), TBL_ENTRY(0x309), TBL_ENTRY(0x30a),
TBL_ENTRY(0x30b),
- TBL_ENTRY(0x30c), TBL_ENTRY(0x30d), TBL_ENTRY(0x30e),
TBL_ENTRY(0x30f),
- TBL_ENTRY(0x310), TBL_ENTRY(0x311), TBL_ENTRY(0x312),
TBL_ENTRY(0x313),
- TBL_ENTRY(0x314), TBL_ENTRY(0x315), TBL_ENTRY(0x316),
TBL_ENTRY(0x317),
- TBL_ENTRY(0x318), TBL_ENTRY(0x319), TBL_ENTRY(0x31a),
TBL_ENTRY(0x31b),
- TBL_ENTRY(0x31c), TBL_ENTRY(0x31d), TBL_ENTRY(0x31e),
TBL_ENTRY(0x31f),
- TBL_ENTRY(0x320), TBL_ENTRY(0x321), TBL_ENTRY(0x322),
TBL_ENTRY(0x323),
- TBL_ENTRY(0x324), TBL_ENTRY(0x325), TBL_ENTRY(0x326),
TBL_ENTRY(0x327),
- TBL_ENTRY(0x328), TBL_ENTRY(0x329), TBL_ENTRY(0x32a),
TBL_ENTRY(0x32b),
- TBL_ENTRY(0x32c), TBL_ENTRY(0x32d), TBL_ENTRY(0x32e),
TBL_ENTRY(0x32f),
- TBL_ENTRY(0x330), TBL_ENTRY(0x331), TBL_ENTRY(0x332),
TBL_ENTRY(0x333),
- TBL_ENTRY(0x334), TBL_ENTRY(0x335), TBL_ENTRY(0x336),
TBL_ENTRY(0x337),
- TBL_ENTRY(0x338), TBL_ENTRY(0x339), TBL_ENTRY(0x33a),
TBL_ENTRY(0x33b),
- TBL_ENTRY(0x33c), TBL_ENTRY(0x33d), TBL_ENTRY(0x33e),
TBL_ENTRY(0x33f),
- TBL_ENTRY(0x340), TBL_ENTRY(0x341), TBL_ENTRY(0x342),
TBL_ENTRY(0x343),
- TBL_ENTRY(0x344), TBL_ENTRY(0x345), TBL_ENTRY(0x346),
TBL_ENTRY(0x347),
- TBL_ENTRY(0x348), TBL_ENTRY(0x349), TBL_ENTRY(0x34a),
TBL_ENTRY(0x34b),
- TBL_ENTRY(0x34c), TBL_ENTRY(0x34d), TBL_ENTRY(0x34e),
TBL_ENTRY(0x34f),
- TBL_ENTRY(0x350), TBL_ENTRY(0x351), TBL_ENTRY(0x352),
TBL_ENTRY(0x353),
- TBL_ENTRY(0x354), TBL_ENTRY(0x355), TBL_ENTRY(0x356),
TBL_ENTRY(0x357),
- TBL_ENTRY(0x358), TBL_ENTRY(0x359), TBL_ENTRY(0x35a),
TBL_ENTRY(0x35b),
- TBL_ENTRY(0x35c), TBL_ENTRY(0x35d), TBL_ENTRY(0x35e),
TBL_ENTRY(0x35f),
- TBL_ENTRY(0x360), TBL_ENTRY(0x361), TBL_ENTRY(0x362),
TBL_ENTRY(0x363),
- TBL_ENTRY(0x364), TBL_ENTRY(0x365), TBL_ENTRY(0x366),
TBL_ENTRY(0x367),
- TBL_ENTRY(0x368), TBL_ENTRY(0x369), TBL_ENTRY(0x36a),
TBL_ENTRY(0x36b),
- TBL_ENTRY(0x36c), TBL_ENTRY(0x36d), TBL_ENTRY(0x36e),
TBL_ENTRY(0x36f),
- TBL_ENTRY(0x370), TBL_ENTRY(0x371), TBL_ENTRY(0x372),
TBL_ENTRY(0x373),
- TBL_ENTRY(0x374), TBL_ENTRY(0x375), TBL_ENTRY(0x376),
TBL_ENTRY(0x377),
- TBL_ENTRY(0x378), TBL_ENTRY(0x379), TBL_ENTRY(0x37a),
TBL_ENTRY(0x37b),
- TBL_ENTRY(0x37c), TBL_ENTRY(0x37d), TBL_ENTRY(0x37e),
TBL_ENTRY(0x37f),
- TBL_ENTRY(0x380), TBL_ENTRY(0x381), TBL_ENTRY(0x382),
TBL_ENTRY(0x383),
- TBL_ENTRY(0x384), TBL_ENTRY(0x385), TBL_ENTRY(0x386),
TBL_ENTRY(0x387),
- TBL_ENTRY(0x388), TBL_ENTRY(0x389), TBL_ENTRY(0x38a),
TBL_ENTRY(0x38b),
- TBL_ENTRY(0x38c), TBL_ENTRY(0x38d), TBL_ENTRY(0x38e),
TBL_ENTRY(0x38f),
- TBL_ENTRY(0x390), TBL_ENTRY(0x391), TBL_ENTRY(0x392),
TBL_ENTRY(0x393),
- TBL_ENTRY(0x394), TBL_ENTRY(0x395), TBL_ENTRY(0x396),
TBL_ENTRY(0x397),
- TBL_ENTRY(0x398), TBL_ENTRY(0x399), TBL_ENTRY(0x39a),
TBL_ENTRY(0x39b),
- TBL_ENTRY(0x39c), TBL_ENTRY(0x39d), TBL_ENTRY(0x39e),
TBL_ENTRY(0x39f),
- TBL_ENTRY(0x3a0), TBL_ENTRY(0x3a1), TBL_ENTRY(0x3a2),
TBL_ENTRY(0x3a3),
- TBL_ENTRY(0x3a4), TBL_ENTRY(0x3a5), TBL_ENTRY(0x3a6),
TBL_ENTRY(0x3a7),
- TBL_ENTRY(0x3a8), TBL_ENTRY(0x3a9), TBL_ENTRY(0x3aa),
TBL_ENTRY(0x3ab),
- TBL_ENTRY(0x3ac), TBL_ENTRY(0x3ad), TBL_ENTRY(0x3ae),
TBL_ENTRY(0x3af),
- TBL_ENTRY(0x3b0), TBL_ENTRY(0x3b1), TBL_ENTRY(0x3b2),
TBL_ENTRY(0x3b3),
- TBL_ENTRY(0x3b4), TBL_ENTRY(0x3b5), TBL_ENTRY(0x3b6),
TBL_ENTRY(0x3b7),
- TBL_ENTRY(0x3b8), TBL_ENTRY(0x3b9), TBL_ENTRY(0x3ba),
TBL_ENTRY(0x3bb),
- TBL_ENTRY(0x3bc), TBL_ENTRY(0x3bd), TBL_ENTRY(0x3be),
TBL_ENTRY(0x3bf),
- TBL_ENTRY(0x3c0), TBL_ENTRY(0x3c1), TBL_ENTRY(0x3c2),
TBL_ENTRY(0x3c3),
- TBL_ENTRY(0x3c4), TBL_ENTRY(0x3c5), TBL_ENTRY(0x3c6),
TBL_ENTRY(0x3c7),
- TBL_ENTRY(0x3c8), TBL_ENTRY(0x3c9), TBL_ENTRY(0x3ca),
TBL_ENTRY(0x3cb),
- TBL_ENTRY(0x3cc), TBL_ENTRY(0x3cd), TBL_ENTRY(0x3ce),
TBL_ENTRY(0x3cf),
- TBL_ENTRY(0x3d0), TBL_ENTRY(0x3d1), TBL_ENTRY(0x3d2),
TBL_ENTRY(0x3d3),
- TBL_ENTRY(0x3d4), TBL_ENTRY(0x3d5), TBL_ENTRY(0x3d6),
TBL_ENTRY(0x3d7),
- TBL_ENTRY(0x3d8), TBL_ENTRY(0x3d9), TBL_ENTRY(0x3da),
TBL_ENTRY(0x3db),
- TBL_ENTRY(0x3dc), TBL_ENTRY(0x3dd), TBL_ENTRY(0x3de),
TBL_ENTRY(0x3df),
- TBL_ENTRY(0x3e0), TBL_ENTRY(0x3e1), TBL_ENTRY(0x3e2),
TBL_ENTRY(0x3e3),
- TBL_ENTRY(0x3e4), TBL_ENTRY(0x3e5), TBL_ENTRY(0x3e6),
TBL_ENTRY(0x3e7),
- TBL_ENTRY(0x3e8), TBL_ENTRY(0x3e9), TBL_ENTRY(0x3ea),
TBL_ENTRY(0x3eb),
- TBL_ENTRY(0x3ec), TBL_ENTRY(0x3ed), TBL_ENTRY(0x3ee),
TBL_ENTRY(0x3ef),
- TBL_ENTRY(0x3f0), TBL_ENTRY(0x3f1), TBL_ENTRY(0x3f2),
TBL_ENTRY(0x3f3),
- TBL_ENTRY(0x3f4), TBL_ENTRY(0x3f5), TBL_ENTRY(0x3f6),
TBL_ENTRY(0x3f7),
- TBL_ENTRY(0x3f8), TBL_ENTRY(0x3f9), TBL_ENTRY(0x3fa),
TBL_ENTRY(0x3fb),
- TBL_ENTRY(0x3fc), TBL_ENTRY(0x3fd), TBL_ENTRY(0x3fe),
TBL_ENTRY(0x3ff),
- TBL_ENTRY(0x400), TBL_ENTRY(0x401), TBL_ENTRY(0x402),
TBL_ENTRY(0x403),
- TBL_ENTRY(0x404), TBL_ENTRY(0x405), TBL_ENTRY(0x406),
TBL_ENTRY(0x407),
- TBL_ENTRY(0x408), TBL_ENTRY(0x409), TBL_ENTRY(0x40a),
TBL_ENTRY(0x40b),
- TBL_ENTRY(0x40c), TBL_ENTRY(0x40d), TBL_ENTRY(0x40e),
TBL_ENTRY(0x40f),
- TBL_ENTRY(0x410), TBL_ENTRY(0x411), TBL_ENTRY(0x412),
TBL_ENTRY(0x413),
- TBL_ENTRY(0x414), TBL_ENTRY(0x415), TBL_ENTRY(0x416),
TBL_ENTRY(0x417),
- TBL_ENTRY(0x418), TBL_ENTRY(0x419), TBL_ENTRY(0x41a),
TBL_ENTRY(0x41b),
- TBL_ENTRY(0x41c), TBL_ENTRY(0x41d), TBL_ENTRY(0x41e),
TBL_ENTRY(0x41f),
- TBL_ENTRY(0x420), TBL_ENTRY(0x421), TBL_ENTRY(0x422),
TBL_ENTRY(0x423),
- TBL_ENTRY(0x424), TBL_ENTRY(0x425), TBL_ENTRY(0x426),
TBL_ENTRY(0x427),
- TBL_ENTRY(0x428), TBL_ENTRY(0x429), TBL_ENTRY(0x42a),
TBL_ENTRY(0x42b),
- TBL_ENTRY(0x42c), TBL_ENTRY(0x42d), TBL_ENTRY(0x42e),
TBL_ENTRY(0x42f),
- TBL_ENTRY(0x430), TBL_ENTRY(0x431), TBL_ENTRY(0x432),
TBL_ENTRY(0x433),
- TBL_ENTRY(0x434), TBL_ENTRY(0x435), TBL_ENTRY(0x436),
TBL_ENTRY(0x437),
- TBL_ENTRY(0x438), TBL_ENTRY(0x439), TBL_ENTRY(0x43a),
TBL_ENTRY(0x43b),
- TBL_ENTRY(0x43c), TBL_ENTRY(0x43d), TBL_ENTRY(0x43e),
TBL_ENTRY(0x43f),
- TBL_ENTRY(0x440), TBL_ENTRY(0x441), TBL_ENTRY(0x442),
TBL_ENTRY(0x443),
- TBL_ENTRY(0x444), TBL_ENTRY(0x445), TBL_ENTRY(0x446),
TBL_ENTRY(0x447),
- TBL_ENTRY(0x448), TBL_ENTRY(0x449), TBL_ENTRY(0x44a),
TBL_ENTRY(0x44b),
- TBL_ENTRY(0x44c), TBL_ENTRY(0x44d), TBL_ENTRY(0x44e),
TBL_ENTRY(0x44f),
- TBL_ENTRY(0x450), TBL_ENTRY(0x451), TBL_ENTRY(0x452),
TBL_ENTRY(0x453),
- TBL_ENTRY(0x454), TBL_ENTRY(0x455), TBL_ENTRY(0x456),
TBL_ENTRY(0x457),
- TBL_ENTRY(0x458), TBL_ENTRY(0x459), TBL_ENTRY(0x45a),
TBL_ENTRY(0x45b),
- TBL_ENTRY(0x45c), TBL_ENTRY(0x45d), TBL_ENTRY(0x45e),
TBL_ENTRY(0x45f),
- TBL_ENTRY(0x460), TBL_ENTRY(0x461), TBL_ENTRY(0x462),
TBL_ENTRY(0x463),
- TBL_ENTRY(0x464), TBL_ENTRY(0x465), TBL_ENTRY(0x466),
TBL_ENTRY(0x467),
- TBL_ENTRY(0x468), TBL_ENTRY(0x469), TBL_ENTRY(0x46a),
TBL_ENTRY(0x46b),
- TBL_ENTRY(0x46c), TBL_ENTRY(0x46d), TBL_ENTRY(0x46e),
TBL_ENTRY(0x46f),
- TBL_ENTRY(0x470), TBL_ENTRY(0x471), TBL_ENTRY(0x472),
TBL_ENTRY(0x473),
- TBL_ENTRY(0x474), TBL_ENTRY(0x475), TBL_ENTRY(0x476),
TBL_ENTRY(0x477),
- TBL_ENTRY(0x478), TBL_ENTRY(0x479), TBL_ENTRY(0x47a),
TBL_ENTRY(0x47b),
- TBL_ENTRY(0x47c), TBL_ENTRY(0x47d), TBL_ENTRY(0x47e),
TBL_ENTRY(0x47f),
- TBL_ENTRY(0x480), TBL_ENTRY(0x481), TBL_ENTRY(0x482),
TBL_ENTRY(0x483),
- TBL_ENTRY(0x484), TBL_ENTRY(0x485), TBL_ENTRY(0x486),
TBL_ENTRY(0x487),
- TBL_ENTRY(0x488), TBL_ENTRY(0x489), TBL_ENTRY(0x48a),
TBL_ENTRY(0x48b),
- TBL_ENTRY(0x48c), TBL_ENTRY(0x48d), TBL_ENTRY(0x48e),
TBL_ENTRY(0x48f),
- TBL_ENTRY(0x490), TBL_ENTRY(0x491), TBL_ENTRY(0x492),
TBL_ENTRY(0x493),
- TBL_ENTRY(0x494), TBL_ENTRY(0x495), TBL_ENTRY(0x496),
TBL_ENTRY(0x497),
- TBL_ENTRY(0x498), TBL_ENTRY(0x499), TBL_ENTRY(0x49a),
TBL_ENTRY(0x49b),
- TBL_ENTRY(0x49c), TBL_ENTRY(0x49d), TBL_ENTRY(0x49e),
TBL_ENTRY(0x49f),
- TBL_ENTRY(0x4a0), TBL_ENTRY(0x4a1), TBL_ENTRY(0x4a2),
TBL_ENTRY(0x4a3),
- TBL_ENTRY(0x4a4), TBL_ENTRY(0x4a5), TBL_ENTRY(0x4a6),
TBL_ENTRY(0x4a7),
- TBL_ENTRY(0x4a8), TBL_ENTRY(0x4a9), TBL_ENTRY(0x4aa),
TBL_ENTRY(0x4ab),
- TBL_ENTRY(0x4ac), TBL_ENTRY(0x4ad), TBL_ENTRY(0x4ae),
TBL_ENTRY(0x4af),
- TBL_ENTRY(0x4b0), TBL_ENTRY(0x4b1), TBL_ENTRY(0x4b2),
TBL_ENTRY(0x4b3),
- TBL_ENTRY(0x4b4), TBL_ENTRY(0x4b5), TBL_ENTRY(0x4b6),
TBL_ENTRY(0x4b7),
- TBL_ENTRY(0x4b8), TBL_ENTRY(0x4b9), TBL_ENTRY(0x4ba),
TBL_ENTRY(0x4bb),
- TBL_ENTRY(0x4bc), TBL_ENTRY(0x4bd), TBL_ENTRY(0x4be),
TBL_ENTRY(0x4bf),
- TBL_ENTRY(0x4c0), TBL_ENTRY(0x4c1), TBL_ENTRY(0x4c2),
TBL_ENTRY(0x4c3),
- TBL_ENTRY(0x4c4), TBL_ENTRY(0x4c5), TBL_ENTRY(0x4c6),
TBL_ENTRY(0x4c7),
- TBL_ENTRY(0x4c8), TBL_ENTRY(0x4c9), TBL_ENTRY(0x4ca),
TBL_ENTRY(0x4cb),
- TBL_ENTRY(0x4cc), TBL_ENTRY(0x4cd), TBL_ENTRY(0x4ce),
TBL_ENTRY(0x4cf),
- TBL_ENTRY(0x4d0), TBL_ENTRY(0x4d1), TBL_ENTRY(0x4d2),
TBL_ENTRY(0x4d3),
- TBL_ENTRY(0x4d4), TBL_ENTRY(0x4d5), TBL_ENTRY(0x4d6),
TBL_ENTRY(0x4d7),
- TBL_ENTRY(0x4d8), TBL_ENTRY(0x4d9), TBL_ENTRY(0x4da),
TBL_ENTRY(0x4db),
- TBL_ENTRY(0x4dc), TBL_ENTRY(0x4dd), TBL_ENTRY(0x4de),
TBL_ENTRY(0x4df),
- TBL_ENTRY(0x4e0), TBL_ENTRY(0x4e1), TBL_ENTRY(0x4e2),
TBL_ENTRY(0x4e3),
- TBL_ENTRY(0x4e4), TBL_ENTRY(0x4e5), TBL_ENTRY(0x4e6),
TBL_ENTRY(0x4e7),
- TBL_ENTRY(0x4e8), TBL_ENTRY(0x4e9), TBL_ENTRY(0x4ea),
TBL_ENTRY(0x4eb),
- TBL_ENTRY(0x4ec), TBL_ENTRY(0x4ed), TBL_ENTRY(0x4ee),
TBL_ENTRY(0x4ef),
- TBL_ENTRY(0x4f0), TBL_ENTRY(0x4f1), TBL_ENTRY(0x4f2),
TBL_ENTRY(0x4f3),
- TBL_ENTRY(0x4f4), TBL_ENTRY(0x4f5), TBL_ENTRY(0x4f6),
TBL_ENTRY(0x4f7),
- TBL_ENTRY(0x4f8), TBL_ENTRY(0x4f9), TBL_ENTRY(0x4fa),
TBL_ENTRY(0x4fb),
- TBL_ENTRY(0x4fc), TBL_ENTRY(0x4fd), TBL_ENTRY(0x4fe),
TBL_ENTRY(0x4ff),
- TBL_ENTRY(0x500), TBL_ENTRY(0x501), TBL_ENTRY(0x502),
TBL_ENTRY(0x503),
- TBL_ENTRY(0x504), TBL_ENTRY(0x505), TBL_ENTRY(0x506),
TBL_ENTRY(0x507),
- TBL_ENTRY(0x508), TBL_ENTRY(0x509), TBL_ENTRY(0x50a),
TBL_ENTRY(0x50b),
- TBL_ENTRY(0x50c), TBL_ENTRY(0x50d), TBL_ENTRY(0x50e),
TBL_ENTRY(0x50f),
- TBL_ENTRY(0x510), TBL_ENTRY(0x511), TBL_ENTRY(0x512),
TBL_ENTRY(0x513),
- TBL_ENTRY(0x514), TBL_ENTRY(0x515), TBL_ENTRY(0x516),
TBL_ENTRY(0x517),
- TBL_ENTRY(0x518), TBL_ENTRY(0x519), TBL_ENTRY(0x51a),
TBL_ENTRY(0x51b),
- TBL_ENTRY(0x51c), TBL_ENTRY(0x51d), TBL_ENTRY(0x51e),
TBL_ENTRY(0x51f),
- TBL_ENTRY(0x520), TBL_ENTRY(0x521), TBL_ENTRY(0x522),
TBL_ENTRY(0x523),
- TBL_ENTRY(0x524), TBL_ENTRY(0x525), TBL_ENTRY(0x526),
TBL_ENTRY(0x527),
- TBL_ENTRY(0x528), TBL_ENTRY(0x529), TBL_ENTRY(0x52a),
TBL_ENTRY(0x52b),
- TBL_ENTRY(0x52c), TBL_ENTRY(0x52d), TBL_ENTRY(0x52e),
TBL_ENTRY(0x52f),
- TBL_ENTRY(0x530), TBL_ENTRY(0x531), TBL_ENTRY(0x532),
TBL_ENTRY(0x533),
- TBL_ENTRY(0x534), TBL_ENTRY(0x535), TBL_ENTRY(0x536),
TBL_ENTRY(0x537),
- TBL_ENTRY(0x538), TBL_ENTRY(0x539), TBL_ENTRY(0x53a),
TBL_ENTRY(0x53b),
- TBL_ENTRY(0x53c), TBL_ENTRY(0x53d), TBL_ENTRY(0x53e),
TBL_ENTRY(0x53f),
- TBL_ENTRY(0x540), TBL_ENTRY(0x541), TBL_ENTRY(0x542),
TBL_ENTRY(0x543),
- TBL_ENTRY(0x544), TBL_ENTRY(0x545), TBL_ENTRY(0x546),
TBL_ENTRY(0x547),
- TBL_ENTRY(0x548), TBL_ENTRY(0x549), TBL_ENTRY(0x54a),
TBL_ENTRY(0x54b),
- TBL_ENTRY(0x54c), TBL_ENTRY(0x54d), TBL_ENTRY(0x54e),
TBL_ENTRY(0x54f),
- TBL_ENTRY(0x550), TBL_ENTRY(0x551), TBL_ENTRY(0x552),
TBL_ENTRY(0x553),
- TBL_ENTRY(0x554), TBL_ENTRY(0x555), TBL_ENTRY(0x556),
TBL_ENTRY(0x557),
- TBL_ENTRY(0x558), TBL_ENTRY(0x559), TBL_ENTRY(0x55a),
TBL_ENTRY(0x55b),
- TBL_ENTRY(0x55c), TBL_ENTRY(0x55d), TBL_ENTRY(0x55e),
TBL_ENTRY(0x55f),
- TBL_ENTRY(0x560), TBL_ENTRY(0x561), TBL_ENTRY(0x562),
TBL_ENTRY(0x563),
- TBL_ENTRY(0x564), TBL_ENTRY(0x565), TBL_ENTRY(0x566),
TBL_ENTRY(0x567),
- TBL_ENTRY(0x568), TBL_ENTRY(0x569), TBL_ENTRY(0x56a),
TBL_ENTRY(0x56b),
- TBL_ENTRY(0x56c), TBL_ENTRY(0x56d), TBL_ENTRY(0x56e),
TBL_ENTRY(0x56f),
- TBL_ENTRY(0x570), TBL_ENTRY(0x571), TBL_ENTRY(0x572),
TBL_ENTRY(0x573),
- TBL_ENTRY(0x574), TBL_ENTRY(0x575), TBL_ENTRY(0x576),
TBL_ENTRY(0x577),
- TBL_ENTRY(0x578), TBL_ENTRY(0x579), TBL_ENTRY(0x57a),
TBL_ENTRY(0x57b),
- TBL_ENTRY(0x57c), TBL_ENTRY(0x57d), TBL_ENTRY(0x57e),
TBL_ENTRY(0x57f),
- TBL_ENTRY(0x580), TBL_ENTRY(0x581), TBL_ENTRY(0x582),
TBL_ENTRY(0x583),
- TBL_ENTRY(0x584), TBL_ENTRY(0x585), TBL_ENTRY(0x586),
TBL_ENTRY(0x587),
- TBL_ENTRY(0x588), TBL_ENTRY(0x589), TBL_ENTRY(0x58a),
TBL_ENTRY(0x58b),
- TBL_ENTRY(0x58c), TBL_ENTRY(0x58d), TBL_ENTRY(0x58e),
TBL_ENTRY(0x58f),
- TBL_ENTRY(0x590), TBL_ENTRY(0x591), TBL_ENTRY(0x592),
TBL_ENTRY(0x593),
- TBL_ENTRY(0x594), TBL_ENTRY(0x595), TBL_ENTRY(0x596),
TBL_ENTRY(0x597),
- TBL_ENTRY(0x598), TBL_ENTRY(0x599), TBL_ENTRY(0x59a),
TBL_ENTRY(0x59b),
- TBL_ENTRY(0x59c), TBL_ENTRY(0x59d), TBL_ENTRY(0x59e),
TBL_ENTRY(0x59f),
- TBL_ENTRY(0x5a0), TBL_ENTRY(0x5a1), TBL_ENTRY(0x5a2),
TBL_ENTRY(0x5a3),
- TBL_ENTRY(0x5a4), TBL_ENTRY(0x5a5), TBL_ENTRY(0x5a6),
TBL_ENTRY(0x5a7),
- TBL_ENTRY(0x5a8), TBL_ENTRY(0x5a9), TBL_ENTRY(0x5aa),
TBL_ENTRY(0x5ab),
- TBL_ENTRY(0x5ac), TBL_ENTRY(0x5ad), TBL_ENTRY(0x5ae),
TBL_ENTRY(0x5af),
- TBL_ENTRY(0x5b0), TBL_ENTRY(0x5b1), TBL_ENTRY(0x5b2),
TBL_ENTRY(0x5b3),
- TBL_ENTRY(0x5b4), TBL_ENTRY(0x5b5), TBL_ENTRY(0x5b6),
TBL_ENTRY(0x5b7),
- TBL_ENTRY(0x5b8), TBL_ENTRY(0x5b9), TBL_ENTRY(0x5ba),
TBL_ENTRY(0x5bb),
- TBL_ENTRY(0x5bc), TBL_ENTRY(0x5bd), TBL_ENTRY(0x5be),
TBL_ENTRY(0x5bf),
- TBL_ENTRY(0x5c0), TBL_ENTRY(0x5c1), TBL_ENTRY(0x5c2),
TBL_ENTRY(0x5c3),
- TBL_ENTRY(0x5c4), TBL_ENTRY(0x5c5), TBL_ENTRY(0x5c6),
TBL_ENTRY(0x5c7),
- TBL_ENTRY(0x5c8), TBL_ENTRY(0x5c9), TBL_ENTRY(0x5ca),
TBL_ENTRY(0x5cb),
- TBL_ENTRY(0x5cc), TBL_ENTRY(0x5cd), TBL_ENTRY(0x5ce),
TBL_ENTRY(0x5cf),
- TBL_ENTRY(0x5d0), TBL_ENTRY(0x5d1), TBL_ENTRY(0x5d2),
TBL_ENTRY(0x5d3),
- TBL_ENTRY(0x5d4), TBL_ENTRY(0x5d5), TBL_ENTRY(0x5d6),
TBL_ENTRY(0x5d7),
- TBL_ENTRY(0x5d8), TBL_ENTRY(0x5d9), TBL_ENTRY(0x5da),
TBL_ENTRY(0x5db),
- TBL_ENTRY(0x5dc), TBL_ENTRY(0x5dd), TBL_ENTRY(0x5de),
TBL_ENTRY(0x5df),
- TBL_ENTRY(0x5e0), TBL_ENTRY(0x5e1), TBL_ENTRY(0x5e2),
TBL_ENTRY(0x5e3),
- TBL_ENTRY(0x5e4), TBL_ENTRY(0x5e5), TBL_ENTRY(0x5e6),
TBL_ENTRY(0x5e7),
- TBL_ENTRY(0x5e8), TBL_ENTRY(0x5e9), TBL_ENTRY(0x5ea),
TBL_ENTRY(0x5eb),
- TBL_ENTRY(0x5ec), TBL_ENTRY(0x5ed), TBL_ENTRY(0x5ee),
TBL_ENTRY(0x5ef),
- TBL_ENTRY(0x5f0), TBL_ENTRY(0x5f1), TBL_ENTRY(0x5f2),
TBL_ENTRY(0x5f3),
- TBL_ENTRY(0x5f4), TBL_ENTRY(0x5f5), TBL_ENTRY(0x5f6),
TBL_ENTRY(0x5f7),
- TBL_ENTRY(0x5f8), TBL_ENTRY(0x5f9), TBL_ENTRY(0x5fa),
TBL_ENTRY(0x5fb),
- TBL_ENTRY(0x5fc), TBL_ENTRY(0x5fd), TBL_ENTRY(0x5fe),
TBL_ENTRY(0x5ff),
- TBL_ENTRY(0x600), TBL_ENTRY(0x601), TBL_ENTRY(0x602),
TBL_ENTRY(0x603),
- TBL_ENTRY(0x604), TBL_ENTRY(0x605), TBL_ENTRY(0x606),
TBL_ENTRY(0x607),
- TBL_ENTRY(0x608), TBL_ENTRY(0x609), TBL_ENTRY(0x60a),
TBL_ENTRY(0x60b),
- TBL_ENTRY(0x60c), TBL_ENTRY(0x60d), TBL_ENTRY(0x60e),
TBL_ENTRY(0x60f),
- TBL_ENTRY(0x610), TBL_ENTRY(0x611), TBL_ENTRY(0x612),
TBL_ENTRY(0x613),
- TBL_ENTRY(0x614), TBL_ENTRY(0x615), TBL_ENTRY(0x616),
TBL_ENTRY(0x617),
- TBL_ENTRY(0x618), TBL_ENTRY(0x619), TBL_ENTRY(0x61a),
TBL_ENTRY(0x61b),
- TBL_ENTRY(0x61c), TBL_ENTRY(0x61d), TBL_ENTRY(0x61e),
TBL_ENTRY(0x61f),
- TBL_ENTRY(0x620), TBL_ENTRY(0x621), TBL_ENTRY(0x622),
TBL_ENTRY(0x623),
- TBL_ENTRY(0x624), TBL_ENTRY(0x625), TBL_ENTRY(0x626),
TBL_ENTRY(0x627),
- TBL_ENTRY(0x628), TBL_ENTRY(0x629), TBL_ENTRY(0x62a),
TBL_ENTRY(0x62b),
- TBL_ENTRY(0x62c), TBL_ENTRY(0x62d), TBL_ENTRY(0x62e),
TBL_ENTRY(0x62f),
- TBL_ENTRY(0x630), TBL_ENTRY(0x631), TBL_ENTRY(0x632),
TBL_ENTRY(0x633),
- TBL_ENTRY(0x634), TBL_ENTRY(0x635), TBL_ENTRY(0x636),
TBL_ENTRY(0x637),
- TBL_ENTRY(0x638), TBL_ENTRY(0x639), TBL_ENTRY(0x63a),
TBL_ENTRY(0x63b),
- TBL_ENTRY(0x63c), TBL_ENTRY(0x63d), TBL_ENTRY(0x63e),
TBL_ENTRY(0x63f),
- TBL_ENTRY(0x640), TBL_ENTRY(0x641), TBL_ENTRY(0x642),
TBL_ENTRY(0x643),
- TBL_ENTRY(0x644), TBL_ENTRY(0x645), TBL_ENTRY(0x646),
TBL_ENTRY(0x647),
- TBL_ENTRY(0x648), TBL_ENTRY(0x649), TBL_ENTRY(0x64a),
TBL_ENTRY(0x64b),
- TBL_ENTRY(0x64c), TBL_ENTRY(0x64d), TBL_ENTRY(0x64e),
TBL_ENTRY(0x64f),
- TBL_ENTRY(0x650), TBL_ENTRY(0x651), TBL_ENTRY(0x652),
TBL_ENTRY(0x653),
- TBL_ENTRY(0x654), TBL_ENTRY(0x655), TBL_ENTRY(0x656),
TBL_ENTRY(0x657),
- TBL_ENTRY(0x658), TBL_ENTRY(0x659), TBL_ENTRY(0x65a),
TBL_ENTRY(0x65b),
- TBL_ENTRY(0x65c), TBL_ENTRY(0x65d), TBL_ENTRY(0x65e),
TBL_ENTRY(0x65f),
- TBL_ENTRY(0x660), TBL_ENTRY(0x661), TBL_ENTRY(0x662),
TBL_ENTRY(0x663),
- TBL_ENTRY(0x664), TBL_ENTRY(0x665), TBL_ENTRY(0x666),
TBL_ENTRY(0x667),
- TBL_ENTRY(0x668), TBL_ENTRY(0x669), TBL_ENTRY(0x66a),
TBL_ENTRY(0x66b),
- TBL_ENTRY(0x66c), TBL_ENTRY(0x66d), TBL_ENTRY(0x66e),
TBL_ENTRY(0x66f),
- TBL_ENTRY(0x670), TBL_ENTRY(0x671), TBL_ENTRY(0x672),
TBL_ENTRY(0x673),
- TBL_ENTRY(0x674), TBL_ENTRY(0x675), TBL_ENTRY(0x676),
TBL_ENTRY(0x677),
- TBL_ENTRY(0x678), TBL_ENTRY(0x679), TBL_ENTRY(0x67a),
TBL_ENTRY(0x67b),
- TBL_ENTRY(0x67c), TBL_ENTRY(0x67d), TBL_ENTRY(0x67e),
TBL_ENTRY(0x67f),
- TBL_ENTRY(0x680), TBL_ENTRY(0x681), TBL_ENTRY(0x682),
TBL_ENTRY(0x683),
- TBL_ENTRY(0x684), TBL_ENTRY(0x685), TBL_ENTRY(0x686),
TBL_ENTRY(0x687),
- TBL_ENTRY(0x688), TBL_ENTRY(0x689), TBL_ENTRY(0x68a),
TBL_ENTRY(0x68b),
- TBL_ENTRY(0x68c), TBL_ENTRY(0x68d), TBL_ENTRY(0x68e),
TBL_ENTRY(0x68f),
- TBL_ENTRY(0x690), TBL_ENTRY(0x691), TBL_ENTRY(0x692),
TBL_ENTRY(0x693),
- TBL_ENTRY(0x694), TBL_ENTRY(0x695), TBL_ENTRY(0x696),
TBL_ENTRY(0x697),
- TBL_ENTRY(0x698), TBL_ENTRY(0x699), TBL_ENTRY(0x69a),
TBL_ENTRY(0x69b),
- TBL_ENTRY(0x69c), TBL_ENTRY(0x69d), TBL_ENTRY(0x69e),
TBL_ENTRY(0x69f),
- TBL_ENTRY(0x6a0), TBL_ENTRY(0x6a1), TBL_ENTRY(0x6a2),
TBL_ENTRY(0x6a3),
- TBL_ENTRY(0x6a4), TBL_ENTRY(0x6a5), TBL_ENTRY(0x6a6),
TBL_ENTRY(0x6a7),
- TBL_ENTRY(0x6a8), TBL_ENTRY(0x6a9), TBL_ENTRY(0x6aa),
TBL_ENTRY(0x6ab),
- TBL_ENTRY(0x6ac), TBL_ENTRY(0x6ad), TBL_ENTRY(0x6ae),
TBL_ENTRY(0x6af),
- TBL_ENTRY(0x6b0), TBL_ENTRY(0x6b1), TBL_ENTRY(0x6b2),
TBL_ENTRY(0x6b3),
- TBL_ENTRY(0x6b4), TBL_ENTRY(0x6b5), TBL_ENTRY(0x6b6),
TBL_ENTRY(0x6b7),
- TBL_ENTRY(0x6b8), TBL_ENTRY(0x6b9), TBL_ENTRY(0x6ba),
TBL_ENTRY(0x6bb),
- TBL_ENTRY(0x6bc), TBL_ENTRY(0x6bd), TBL_ENTRY(0x6be),
TBL_ENTRY(0x6bf),
- TBL_ENTRY(0x6c0), TBL_ENTRY(0x6c1), TBL_ENTRY(0x6c2),
TBL_ENTRY(0x6c3),
- TBL_ENTRY(0x6c4), TBL_ENTRY(0x6c5), TBL_ENTRY(0x6c6),
TBL_ENTRY(0x6c7),
- TBL_ENTRY(0x6c8), TBL_ENTRY(0x6c9), TBL_ENTRY(0x6ca),
TBL_ENTRY(0x6cb),
- TBL_ENTRY(0x6cc), TBL_ENTRY(0x6cd), TBL_ENTRY(0x6ce),
TBL_ENTRY(0x6cf),
- TBL_ENTRY(0x6d0), TBL_ENTRY(0x6d1), TBL_ENTRY(0x6d2),
TBL_ENTRY(0x6d3),
- TBL_ENTRY(0x6d4), TBL_ENTRY(0x6d5), TBL_ENTRY(0x6d6),
TBL_ENTRY(0x6d7),
- TBL_ENTRY(0x6d8), TBL_ENTRY(0x6d9), TBL_ENTRY(0x6da),
TBL_ENTRY(0x6db),
- TBL_ENTRY(0x6dc), TBL_ENTRY(0x6dd), TBL_ENTRY(0x6de),
TBL_ENTRY(0x6df),
- TBL_ENTRY(0x6e0), TBL_ENTRY(0x6e1), TBL_ENTRY(0x6e2),
TBL_ENTRY(0x6e3),
- TBL_ENTRY(0x6e4), TBL_ENTRY(0x6e5), TBL_ENTRY(0x6e6),
TBL_ENTRY(0x6e7),
- TBL_ENTRY(0x6e8), TBL_ENTRY(0x6e9), TBL_ENTRY(0x6ea),
TBL_ENTRY(0x6eb),
- TBL_ENTRY(0x6ec), TBL_ENTRY(0x6ed), TBL_ENTRY(0x6ee),
TBL_ENTRY(0x6ef),
- TBL_ENTRY(0x6f0), TBL_ENTRY(0x6f1), TBL_ENTRY(0x6f2),
TBL_ENTRY(0x6f3),
- TBL_ENTRY(0x6f4), TBL_ENTRY(0x6f5), TBL_ENTRY(0x6f6),
TBL_ENTRY(0x6f7),
- TBL_ENTRY(0x6f8), TBL_ENTRY(0x6f9), TBL_ENTRY(0x6fa),
TBL_ENTRY(0x6fb),
- TBL_ENTRY(0x6fc), TBL_ENTRY(0x6fd), TBL_ENTRY(0x6fe),
TBL_ENTRY(0x6ff),
- TBL_ENTRY(0x700), TBL_ENTRY(0x701), TBL_ENTRY(0x702),
TBL_ENTRY(0x703),
- TBL_ENTRY(0x704), TBL_ENTRY(0x705), TBL_ENTRY(0x706),
TBL_ENTRY(0x707),
- TBL_ENTRY(0x708), TBL_ENTRY(0x709), TBL_ENTRY(0x70a),
TBL_ENTRY(0x70b),
- TBL_ENTRY(0x70c), TBL_ENTRY(0x70d), TBL_ENTRY(0x70e),
TBL_ENTRY(0x70f),
- TBL_ENTRY(0x710), TBL_ENTRY(0x711), TBL_ENTRY(0x712),
TBL_ENTRY(0x713),
- TBL_ENTRY(0x714), TBL_ENTRY(0x715), TBL_ENTRY(0x716),
TBL_ENTRY(0x717),
- TBL_ENTRY(0x718), TBL_ENTRY(0x719), TBL_ENTRY(0x71a),
TBL_ENTRY(0x71b),
- TBL_ENTRY(0x71c), TBL_ENTRY(0x71d), TBL_ENTRY(0x71e),
TBL_ENTRY(0x71f),
- TBL_ENTRY(0x720), TBL_ENTRY(0x721), TBL_ENTRY(0x722),
TBL_ENTRY(0x723),
- TBL_ENTRY(0x724), TBL_ENTRY(0x725), TBL_ENTRY(0x726),
TBL_ENTRY(0x727),
- TBL_ENTRY(0x728), TBL_ENTRY(0x729), TBL_ENTRY(0x72a),
TBL_ENTRY(0x72b),
- TBL_ENTRY(0x72c), TBL_ENTRY(0x72d), TBL_ENTRY(0x72e),
TBL_ENTRY(0x72f),
- TBL_ENTRY(0x730), TBL_ENTRY(0x731), TBL_ENTRY(0x732),
TBL_ENTRY(0x733),
- TBL_ENTRY(0x734), TBL_ENTRY(0x735), TBL_ENTRY(0x736),
TBL_ENTRY(0x737),
- TBL_ENTRY(0x738), TBL_ENTRY(0x739), TBL_ENTRY(0x73a),
TBL_ENTRY(0x73b),
- TBL_ENTRY(0x73c), TBL_ENTRY(0x73d), TBL_ENTRY(0x73e),
TBL_ENTRY(0x73f),
- TBL_ENTRY(0x740), TBL_ENTRY(0x741), TBL_ENTRY(0x742),
TBL_ENTRY(0x743),
- TBL_ENTRY(0x744), TBL_ENTRY(0x745), TBL_ENTRY(0x746),
TBL_ENTRY(0x747),
- TBL_ENTRY(0x748), TBL_ENTRY(0x749), TBL_ENTRY(0x74a),
TBL_ENTRY(0x74b),
- TBL_ENTRY(0x74c), TBL_ENTRY(0x74d), TBL_ENTRY(0x74e),
TBL_ENTRY(0x74f),
- TBL_ENTRY(0x750), TBL_ENTRY(0x751), TBL_ENTRY(0x752),
TBL_ENTRY(0x753),
- TBL_ENTRY(0x754), TBL_ENTRY(0x755), TBL_ENTRY(0x756),
TBL_ENTRY(0x757),
- TBL_ENTRY(0x758), TBL_ENTRY(0x759), TBL_ENTRY(0x75a),
TBL_ENTRY(0x75b),
- TBL_ENTRY(0x75c), TBL_ENTRY(0x75d), TBL_ENTRY(0x75e),
TBL_ENTRY(0x75f),
- TBL_ENTRY(0x760), TBL_ENTRY(0x761), TBL_ENTRY(0x762),
TBL_ENTRY(0x763),
- TBL_ENTRY(0x764), TBL_ENTRY(0x765), TBL_ENTRY(0x766),
TBL_ENTRY(0x767),
- TBL_ENTRY(0x768), TBL_ENTRY(0x769), TBL_ENTRY(0x76a),
TBL_ENTRY(0x76b),
- TBL_ENTRY(0x76c), TBL_ENTRY(0x76d), TBL_ENTRY(0x76e),
TBL_ENTRY(0x76f),
- TBL_ENTRY(0x770), TBL_ENTRY(0x771), TBL_ENTRY(0x772),
TBL_ENTRY(0x773),
- TBL_ENTRY(0x774), TBL_ENTRY(0x775), TBL_ENTRY(0x776),
TBL_ENTRY(0x777),
- TBL_ENTRY(0x778), TBL_ENTRY(0x779), TBL_ENTRY(0x77a),
TBL_ENTRY(0x77b),
- TBL_ENTRY(0x77c), TBL_ENTRY(0x77d), TBL_ENTRY(0x77e),
TBL_ENTRY(0x77f),
- TBL_ENTRY(0x780), TBL_ENTRY(0x781), TBL_ENTRY(0x782),
TBL_ENTRY(0x783),
- TBL_ENTRY(0x784), TBL_ENTRY(0x785), TBL_ENTRY(0x786),
TBL_ENTRY(0x787),
- TBL_ENTRY(0x788), TBL_ENTRY(0x789), TBL_ENTRY(0x78a),
TBL_ENTRY(0x78b),
- TBL_ENTRY(0x78c), TBL_ENTRY(0x78d), TBL_ENTRY(0x78e),
TBL_ENTRY(0x78f),
- TBL_ENTRY(0x790), TBL_ENTRY(0x791), TBL_ENTRY(0x792),
TBL_ENTRY(0x793),
- TBL_ENTRY(0x794), TBL_ENTRY(0x795), TBL_ENTRY(0x796),
TBL_ENTRY(0x797),
- TBL_ENTRY(0x798), TBL_ENTRY(0x799), TBL_ENTRY(0x79a),
TBL_ENTRY(0x79b),
- TBL_ENTRY(0x79c), TBL_ENTRY(0x79d), TBL_ENTRY(0x79e),
TBL_ENTRY(0x79f),
- TBL_ENTRY(0x7a0), TBL_ENTRY(0x7a1), TBL_ENTRY(0x7a2),
TBL_ENTRY(0x7a3),
- TBL_ENTRY(0x7a4), TBL_ENTRY(0x7a5), TBL_ENTRY(0x7a6),
TBL_ENTRY(0x7a7),
- TBL_ENTRY(0x7a8), TBL_ENTRY(0x7a9), TBL_ENTRY(0x7aa),
TBL_ENTRY(0x7ab),
- TBL_ENTRY(0x7ac), TBL_ENTRY(0x7ad), TBL_ENTRY(0x7ae),
TBL_ENTRY(0x7af),
- TBL_ENTRY(0x7b0), TBL_ENTRY(0x7b1), TBL_ENTRY(0x7b2),
TBL_ENTRY(0x7b3),
- TBL_ENTRY(0x7b4), TBL_ENTRY(0x7b5), TBL_ENTRY(0x7b6),
TBL_ENTRY(0x7b7),
- TBL_ENTRY(0x7b8), TBL_ENTRY(0x7b9), TBL_ENTRY(0x7ba),
TBL_ENTRY(0x7bb),
- TBL_ENTRY(0x7bc), TBL_ENTRY(0x7bd), TBL_ENTRY(0x7be),
TBL_ENTRY(0x7bf),
- TBL_ENTRY(0x7c0), TBL_ENTRY(0x7c1), TBL_ENTRY(0x7c2),
TBL_ENTRY(0x7c3),
- TBL_ENTRY(0x7c4), TBL_ENTRY(0x7c5), TBL_ENTRY(0x7c6),
TBL_ENTRY(0x7c7),
- TBL_ENTRY(0x7c8), TBL_ENTRY(0x7c9), TBL_ENTRY(0x7ca),
TBL_ENTRY(0x7cb),
- TBL_ENTRY(0x7cc), TBL_ENTRY(0x7cd), TBL_ENTRY(0x7ce),
TBL_ENTRY(0x7cf),
- TBL_ENTRY(0x7d0), TBL_ENTRY(0x7d1), TBL_ENTRY(0x7d2),
TBL_ENTRY(0x7d3),
- TBL_ENTRY(0x7d4), TBL_ENTRY(0x7d5), TBL_ENTRY(0x7d6),
TBL_ENTRY(0x7d7),
- TBL_ENTRY(0x7d8), TBL_ENTRY(0x7d9), TBL_ENTRY(0x7da),
TBL_ENTRY(0x7db),
- TBL_ENTRY(0x7dc), TBL_ENTRY(0x7dd), TBL_ENTRY(0x7de),
TBL_ENTRY(0x7df),
- TBL_ENTRY(0x7e0), TBL_ENTRY(0x7e1), TBL_ENTRY(0x7e2),
TBL_ENTRY(0x7e3),
- TBL_ENTRY(0x7e4), TBL_ENTRY(0x7e5), TBL_ENTRY(0x7e6),
TBL_ENTRY(0x7e7),
- TBL_ENTRY(0x7e8), TBL_ENTRY(0x7e9), TBL_ENTRY(0x7ea),
TBL_ENTRY(0x7eb),
- TBL_ENTRY(0x7ec), TBL_ENTRY(0x7ed), TBL_ENTRY(0x7ee),
TBL_ENTRY(0x7ef),
- TBL_ENTRY(0x7f0), TBL_ENTRY(0x7f1), TBL_ENTRY(0x7f2),
TBL_ENTRY(0x7f3),
- TBL_ENTRY(0x7f4), TBL_ENTRY(0x7f5), TBL_ENTRY(0x7f6),
TBL_ENTRY(0x7f7),
- TBL_ENTRY(0x7f8), TBL_ENTRY(0x7f9), TBL_ENTRY(0x7fa),
TBL_ENTRY(0x7fb),
- TBL_ENTRY(0x7fc), TBL_ENTRY(0x7fd), TBL_ENTRY(0x7fe),
TBL_ENTRY(0x7ff),
- TBL_ENTRY(0x800), TBL_ENTRY(0x801), TBL_ENTRY(0x802),
TBL_ENTRY(0x803),
- TBL_ENTRY(0x804), TBL_ENTRY(0x805), TBL_ENTRY(0x806),
TBL_ENTRY(0x807),
- TBL_ENTRY(0x808), TBL_ENTRY(0x809), TBL_ENTRY(0x80a),
TBL_ENTRY(0x80b),
- TBL_ENTRY(0x80c), TBL_ENTRY(0x80d), TBL_ENTRY(0x80e),
TBL_ENTRY(0x80f),
- TBL_ENTRY(0x810), TBL_ENTRY(0x811), TBL_ENTRY(0x812),
TBL_ENTRY(0x813),
- TBL_ENTRY(0x814), TBL_ENTRY(0x815), TBL_ENTRY(0x816),
TBL_ENTRY(0x817),
- TBL_ENTRY(0x818), TBL_ENTRY(0x819), TBL_ENTRY(0x81a),
TBL_ENTRY(0x81b),
- TBL_ENTRY(0x81c), TBL_ENTRY(0x81d), TBL_ENTRY(0x81e),
TBL_ENTRY(0x81f),
- TBL_ENTRY(0x820), TBL_ENTRY(0x821), TBL_ENTRY(0x822),
TBL_ENTRY(0x823),
- TBL_ENTRY(0x824), TBL_ENTRY(0x825), TBL_ENTRY(0x826),
TBL_ENTRY(0x827),
- TBL_ENTRY(0x828), TBL_ENTRY(0x829), TBL_ENTRY(0x82a),
TBL_ENTRY(0x82b),
- TBL_ENTRY(0x82c), TBL_ENTRY(0x82d), TBL_ENTRY(0x82e),
TBL_ENTRY(0x82f),
- TBL_ENTRY(0x830), TBL_ENTRY(0x831), TBL_ENTRY(0x832),
TBL_ENTRY(0x833),
- TBL_ENTRY(0x834), TBL_ENTRY(0x835), TBL_ENTRY(0x836),
TBL_ENTRY(0x837),
- TBL_ENTRY(0x838), TBL_ENTRY(0x839), TBL_ENTRY(0x83a),
TBL_ENTRY(0x83b),
- TBL_ENTRY(0x83c), TBL_ENTRY(0x83d), TBL_ENTRY(0x83e),
TBL_ENTRY(0x83f),
- TBL_ENTRY(0x840), TBL_ENTRY(0x841), TBL_ENTRY(0x842),
TBL_ENTRY(0x843),
- TBL_ENTRY(0x844), TBL_ENTRY(0x845), TBL_ENTRY(0x846),
TBL_ENTRY(0x847),
- TBL_ENTRY(0x848), TBL_ENTRY(0x849), TBL_ENTRY(0x84a),
TBL_ENTRY(0x84b),
- TBL_ENTRY(0x84c), TBL_ENTRY(0x84d), TBL_ENTRY(0x84e),
TBL_ENTRY(0x84f),
- TBL_ENTRY(0x850), TBL_ENTRY(0x851), TBL_ENTRY(0x852),
TBL_ENTRY(0x853),
- TBL_ENTRY(0x854), TBL_ENTRY(0x855), TBL_ENTRY(0x856),
TBL_ENTRY(0x857),
- TBL_ENTRY(0x858), TBL_ENTRY(0x859), TBL_ENTRY(0x85a),
TBL_ENTRY(0x85b),
- TBL_ENTRY(0x85c), TBL_ENTRY(0x85d), TBL_ENTRY(0x85e),
TBL_ENTRY(0x85f),
- TBL_ENTRY(0x860), TBL_ENTRY(0x861), TBL_ENTRY(0x862),
TBL_ENTRY(0x863),
- TBL_ENTRY(0x864), TBL_ENTRY(0x865), TBL_ENTRY(0x866),
TBL_ENTRY(0x867),
- TBL_ENTRY(0x868), TBL_ENTRY(0x869), TBL_ENTRY(0x86a),
TBL_ENTRY(0x86b),
- TBL_ENTRY(0x86c), TBL_ENTRY(0x86d), TBL_ENTRY(0x86e),
TBL_ENTRY(0x86f),
- TBL_ENTRY(0x870), TBL_ENTRY(0x871), TBL_ENTRY(0x872),
TBL_ENTRY(0x873),
- TBL_ENTRY(0x874), TBL_ENTRY(0x875), TBL_ENTRY(0x876),
TBL_ENTRY(0x877),
- TBL_ENTRY(0x878), TBL_ENTRY(0x879), TBL_ENTRY(0x87a),
TBL_ENTRY(0x87b),
- TBL_ENTRY(0x87c), TBL_ENTRY(0x87d), TBL_ENTRY(0x87e),
TBL_ENTRY(0x87f),
- TBL_ENTRY(0x880), TBL_ENTRY(0x881), TBL_ENTRY(0x882),
TBL_ENTRY(0x883),
- TBL_ENTRY(0x884), TBL_ENTRY(0x885), TBL_ENTRY(0x886),
TBL_ENTRY(0x887),
- TBL_ENTRY(0x888), TBL_ENTRY(0x889), TBL_ENTRY(0x88a),
TBL_ENTRY(0x88b),
- TBL_ENTRY(0x88c), TBL_ENTRY(0x88d), TBL_ENTRY(0x88e),
TBL_ENTRY(0x88f),
- TBL_ENTRY(0x890), TBL_ENTRY(0x891), TBL_ENTRY(0x892),
TBL_ENTRY(0x893),
- TBL_ENTRY(0x894), TBL_ENTRY(0x895), TBL_ENTRY(0x896),
TBL_ENTRY(0x897),
- TBL_ENTRY(0x898), TBL_ENTRY(0x899), TBL_ENTRY(0x89a),
TBL_ENTRY(0x89b),
- TBL_ENTRY(0x89c), TBL_ENTRY(0x89d), TBL_ENTRY(0x89e),
TBL_ENTRY(0x89f),
- TBL_ENTRY(0x8a0), TBL_ENTRY(0x8a1), TBL_ENTRY(0x8a2),
TBL_ENTRY(0x8a3),
- TBL_ENTRY(0x8a4), TBL_ENTRY(0x8a5), TBL_ENTRY(0x8a6),
TBL_ENTRY(0x8a7),
- TBL_ENTRY(0x8a8), TBL_ENTRY(0x8a9), TBL_ENTRY(0x8aa),
TBL_ENTRY(0x8ab),
- TBL_ENTRY(0x8ac), TBL_ENTRY(0x8ad), TBL_ENTRY(0x8ae),
TBL_ENTRY(0x8af),
- TBL_ENTRY(0x8b0), TBL_ENTRY(0x8b1), TBL_ENTRY(0x8b2),
TBL_ENTRY(0x8b3),
- TBL_ENTRY(0x8b4), TBL_ENTRY(0x8b5), TBL_ENTRY(0x8b6),
TBL_ENTRY(0x8b7),
- TBL_ENTRY(0x8b8), TBL_ENTRY(0x8b9), TBL_ENTRY(0x8ba),
TBL_ENTRY(0x8bb),
- TBL_ENTRY(0x8bc), TBL_ENTRY(0x8bd), TBL_ENTRY(0x8be),
TBL_ENTRY(0x8bf),
- TBL_ENTRY(0x8c0), TBL_ENTRY(0x8c1), TBL_ENTRY(0x8c2),
TBL_ENTRY(0x8c3),
- TBL_ENTRY(0x8c4), TBL_ENTRY(0x8c5), TBL_ENTRY(0x8c6),
TBL_ENTRY(0x8c7),
- TBL_ENTRY(0x8c8), TBL_ENTRY(0x8c9), TBL_ENTRY(0x8ca),
TBL_ENTRY(0x8cb),
- TBL_ENTRY(0x8cc), TBL_ENTRY(0x8cd), TBL_ENTRY(0x8ce),
TBL_ENTRY(0x8cf),
- TBL_ENTRY(0x8d0), TBL_ENTRY(0x8d1), TBL_ENTRY(0x8d2),
TBL_ENTRY(0x8d3),
- TBL_ENTRY(0x8d4), TBL_ENTRY(0x8d5), TBL_ENTRY(0x8d6),
TBL_ENTRY(0x8d7),
- TBL_ENTRY(0x8d8), TBL_ENTRY(0x8d9), TBL_ENTRY(0x8da),
TBL_ENTRY(0x8db),
- TBL_ENTRY(0x8dc), TBL_ENTRY(0x8dd), TBL_ENTRY(0x8de),
TBL_ENTRY(0x8df),
- TBL_ENTRY(0x8e0), TBL_ENTRY(0x8e1), TBL_ENTRY(0x8e2),
TBL_ENTRY(0x8e3),
- TBL_ENTRY(0x8e4), TBL_ENTRY(0x8e5), TBL_ENTRY(0x8e6),
TBL_ENTRY(0x8e7),
- TBL_ENTRY(0x8e8), TBL_ENTRY(0x8e9), TBL_ENTRY(0x8ea),
TBL_ENTRY(0x8eb),
- TBL_ENTRY(0x8ec), TBL_ENTRY(0x8ed), TBL_ENTRY(0x8ee),
TBL_ENTRY(0x8ef),
- TBL_ENTRY(0x8f0), TBL_ENTRY(0x8f1), TBL_ENTRY(0x8f2),
TBL_ENTRY(0x8f3),
- TBL_ENTRY(0x8f4), TBL_ENTRY(0x8f5), TBL_ENTRY(0x8f6),
TBL_ENTRY(0x8f7),
- TBL_ENTRY(0x8f8), TBL_ENTRY(0x8f9), TBL_ENTRY(0x8fa),
TBL_ENTRY(0x8fb),
- TBL_ENTRY(0x8fc), TBL_ENTRY(0x8fd), TBL_ENTRY(0x8fe),
TBL_ENTRY(0x8ff),
- TBL_ENTRY(0x900), TBL_ENTRY(0x901), TBL_ENTRY(0x902),
TBL_ENTRY(0x903),
- TBL_ENTRY(0x904), TBL_ENTRY(0x905), TBL_ENTRY(0x906),
TBL_ENTRY(0x907),
- TBL_ENTRY(0x908), TBL_ENTRY(0x909), TBL_ENTRY(0x90a),
TBL_ENTRY(0x90b),
- TBL_ENTRY(0x90c), TBL_ENTRY(0x90d), TBL_ENTRY(0x90e),
TBL_ENTRY(0x90f),
- TBL_ENTRY(0x910), TBL_ENTRY(0x911), TBL_ENTRY(0x912),
TBL_ENTRY(0x913),
- TBL_ENTRY(0x914), TBL_ENTRY(0x915), TBL_ENTRY(0x916),
TBL_ENTRY(0x917),
- TBL_ENTRY(0x918), TBL_ENTRY(0x919), TBL_ENTRY(0x91a),
TBL_ENTRY(0x91b),
- TBL_ENTRY(0x91c), TBL_ENTRY(0x91d), TBL_ENTRY(0x91e),
TBL_ENTRY(0x91f),
- TBL_ENTRY(0x920), TBL_ENTRY(0x921), TBL_ENTRY(0x922),
TBL_ENTRY(0x923),
- TBL_ENTRY(0x924), TBL_ENTRY(0x925), TBL_ENTRY(0x926),
TBL_ENTRY(0x927),
- TBL_ENTRY(0x928), TBL_ENTRY(0x929), TBL_ENTRY(0x92a),
TBL_ENTRY(0x92b),
- TBL_ENTRY(0x92c), TBL_ENTRY(0x92d), TBL_ENTRY(0x92e),
TBL_ENTRY(0x92f),
- TBL_ENTRY(0x930), TBL_ENTRY(0x931), TBL_ENTRY(0x932),
TBL_ENTRY(0x933),
- TBL_ENTRY(0x934), TBL_ENTRY(0x935), TBL_ENTRY(0x936),
TBL_ENTRY(0x937),
- TBL_ENTRY(0x938), TBL_ENTRY(0x939), TBL_ENTRY(0x93a),
TBL_ENTRY(0x93b),
- TBL_ENTRY(0x93c), TBL_ENTRY(0x93d), TBL_ENTRY(0x93e),
TBL_ENTRY(0x93f),
- TBL_ENTRY(0x940), TBL_ENTRY(0x941), TBL_ENTRY(0x942),
TBL_ENTRY(0x943),
- TBL_ENTRY(0x944), TBL_ENTRY(0x945), TBL_ENTRY(0x946),
TBL_ENTRY(0x947),
- TBL_ENTRY(0x948), TBL_ENTRY(0x949), TBL_ENTRY(0x94a),
TBL_ENTRY(0x94b),
- TBL_ENTRY(0x94c), TBL_ENTRY(0x94d), TBL_ENTRY(0x94e),
TBL_ENTRY(0x94f),
- TBL_ENTRY(0x950), TBL_ENTRY(0x951), TBL_ENTRY(0x952),
TBL_ENTRY(0x953),
- TBL_ENTRY(0x954), TBL_ENTRY(0x955), TBL_ENTRY(0x956),
TBL_ENTRY(0x957),
- TBL_ENTRY(0x958), TBL_ENTRY(0x959), TBL_ENTRY(0x95a),
TBL_ENTRY(0x95b),
- TBL_ENTRY(0x95c), TBL_ENTRY(0x95d), TBL_ENTRY(0x95e),
TBL_ENTRY(0x95f),
- TBL_ENTRY(0x960), TBL_ENTRY(0x961), TBL_ENTRY(0x962),
TBL_ENTRY(0x963),
- TBL_ENTRY(0x964), TBL_ENTRY(0x965), TBL_ENTRY(0x966),
TBL_ENTRY(0x967),
- TBL_ENTRY(0x968), TBL_ENTRY(0x969), TBL_ENTRY(0x96a),
TBL_ENTRY(0x96b),
- TBL_ENTRY(0x96c), TBL_ENTRY(0x96d), TBL_ENTRY(0x96e),
TBL_ENTRY(0x96f),
- TBL_ENTRY(0x970), TBL_ENTRY(0x971), TBL_ENTRY(0x972),
TBL_ENTRY(0x973),
- TBL_ENTRY(0x974), TBL_ENTRY(0x975), TBL_ENTRY(0x976),
TBL_ENTRY(0x977),
- TBL_ENTRY(0x978), TBL_ENTRY(0x979), TBL_ENTRY(0x97a),
TBL_ENTRY(0x97b),
- TBL_ENTRY(0x97c), TBL_ENTRY(0x97d), TBL_ENTRY(0x97e),
TBL_ENTRY(0x97f),
- TBL_ENTRY(0x980), TBL_ENTRY(0x981), TBL_ENTRY(0x982),
TBL_ENTRY(0x983),
- TBL_ENTRY(0x984), TBL_ENTRY(0x985), TBL_ENTRY(0x986),
TBL_ENTRY(0x987),
- TBL_ENTRY(0x988), TBL_ENTRY(0x989), TBL_ENTRY(0x98a),
TBL_ENTRY(0x98b),
- TBL_ENTRY(0x98c), TBL_ENTRY(0x98d), TBL_ENTRY(0x98e),
TBL_ENTRY(0x98f),
- TBL_ENTRY(0x990), TBL_ENTRY(0x991), TBL_ENTRY(0x992),
TBL_ENTRY(0x993),
- TBL_ENTRY(0x994), TBL_ENTRY(0x995), TBL_ENTRY(0x996),
TBL_ENTRY(0x997),
- TBL_ENTRY(0x998), TBL_ENTRY(0x999), TBL_ENTRY(0x99a),
TBL_ENTRY(0x99b),
- TBL_ENTRY(0x99c), TBL_ENTRY(0x99d), TBL_ENTRY(0x99e),
TBL_ENTRY(0x99f),
- TBL_ENTRY(0x9a0), TBL_ENTRY(0x9a1), TBL_ENTRY(0x9a2),
TBL_ENTRY(0x9a3),
- TBL_ENTRY(0x9a4), TBL_ENTRY(0x9a5), TBL_ENTRY(0x9a6),
TBL_ENTRY(0x9a7),
- TBL_ENTRY(0x9a8), TBL_ENTRY(0x9a9), TBL_ENTRY(0x9aa),
TBL_ENTRY(0x9ab),
- TBL_ENTRY(0x9ac), TBL_ENTRY(0x9ad), TBL_ENTRY(0x9ae),
TBL_ENTRY(0x9af),
- TBL_ENTRY(0x9b0), TBL_ENTRY(0x9b1), TBL_ENTRY(0x9b2),
TBL_ENTRY(0x9b3),
- TBL_ENTRY(0x9b4), TBL_ENTRY(0x9b5), TBL_ENTRY(0x9b6),
TBL_ENTRY(0x9b7),
- TBL_ENTRY(0x9b8), TBL_ENTRY(0x9b9), TBL_ENTRY(0x9ba),
TBL_ENTRY(0x9bb),
- TBL_ENTRY(0x9bc), TBL_ENTRY(0x9bd), TBL_ENTRY(0x9be),
TBL_ENTRY(0x9bf),
- TBL_ENTRY(0x9c0), TBL_ENTRY(0x9c1), TBL_ENTRY(0x9c2),
TBL_ENTRY(0x9c3),
- TBL_ENTRY(0x9c4), TBL_ENTRY(0x9c5), TBL_ENTRY(0x9c6),
TBL_ENTRY(0x9c7),
- TBL_ENTRY(0x9c8), TBL_ENTRY(0x9c9), TBL_ENTRY(0x9ca),
TBL_ENTRY(0x9cb),
- TBL_ENTRY(0x9cc), TBL_ENTRY(0x9cd), TBL_ENTRY(0x9ce),
TBL_ENTRY(0x9cf),
- TBL_ENTRY(0x9d0), TBL_ENTRY(0x9d1), TBL_ENTRY(0x9d2),
TBL_ENTRY(0x9d3),
- TBL_ENTRY(0x9d4), TBL_ENTRY(0x9d5), TBL_ENTRY(0x9d6),
TBL_ENTRY(0x9d7),
- TBL_ENTRY(0x9d8), TBL_ENTRY(0x9d9), TBL_ENTRY(0x9da),
TBL_ENTRY(0x9db),
- TBL_ENTRY(0x9dc), TBL_ENTRY(0x9dd), TBL_ENTRY(0x9de),
TBL_ENTRY(0x9df),
- TBL_ENTRY(0x9e0), TBL_ENTRY(0x9e1), TBL_ENTRY(0x9e2),
TBL_ENTRY(0x9e3),
- TBL_ENTRY(0x9e4), TBL_ENTRY(0x9e5), TBL_ENTRY(0x9e6),
TBL_ENTRY(0x9e7),
- TBL_ENTRY(0x9e8), TBL_ENTRY(0x9e9), TBL_ENTRY(0x9ea),
TBL_ENTRY(0x9eb),
- TBL_ENTRY(0x9ec), TBL_ENTRY(0x9ed), TBL_ENTRY(0x9ee),
TBL_ENTRY(0x9ef),
- TBL_ENTRY(0x9f0), TBL_ENTRY(0x9f1), TBL_ENTRY(0x9f2),
TBL_ENTRY(0x9f3),
- TBL_ENTRY(0x9f4), TBL_ENTRY(0x9f5), TBL_ENTRY(0x9f6),
TBL_ENTRY(0x9f7),
- TBL_ENTRY(0x9f8), TBL_ENTRY(0x9f9), TBL_ENTRY(0x9fa),
TBL_ENTRY(0x9fb),
- TBL_ENTRY(0x9fc), TBL_ENTRY(0x9fd), TBL_ENTRY(0x9fe),
TBL_ENTRY(0x9ff),
- TBL_ENTRY(0xa00), TBL_ENTRY(0xa01), TBL_ENTRY(0xa02),
TBL_ENTRY(0xa03),
- TBL_ENTRY(0xa04), TBL_ENTRY(0xa05), TBL_ENTRY(0xa06),
TBL_ENTRY(0xa07),
- TBL_ENTRY(0xa08), TBL_ENTRY(0xa09), TBL_ENTRY(0xa0a),
TBL_ENTRY(0xa0b),
- TBL_ENTRY(0xa0c), TBL_ENTRY(0xa0d), TBL_ENTRY(0xa0e),
TBL_ENTRY(0xa0f),
- TBL_ENTRY(0xa10), TBL_ENTRY(0xa11), TBL_ENTRY(0xa12),
TBL_ENTRY(0xa13),
- TBL_ENTRY(0xa14), TBL_ENTRY(0xa15), TBL_ENTRY(0xa16),
TBL_ENTRY(0xa17),
- TBL_ENTRY(0xa18), TBL_ENTRY(0xa19), TBL_ENTRY(0xa1a),
TBL_ENTRY(0xa1b),
- TBL_ENTRY(0xa1c), TBL_ENTRY(0xa1d), TBL_ENTRY(0xa1e),
TBL_ENTRY(0xa1f),
- TBL_ENTRY(0xa20), TBL_ENTRY(0xa21), TBL_ENTRY(0xa22),
TBL_ENTRY(0xa23),
- TBL_ENTRY(0xa24), TBL_ENTRY(0xa25), TBL_ENTRY(0xa26),
TBL_ENTRY(0xa27),
- TBL_ENTRY(0xa28), TBL_ENTRY(0xa29), TBL_ENTRY(0xa2a),
TBL_ENTRY(0xa2b),
- TBL_ENTRY(0xa2c), TBL_ENTRY(0xa2d), TBL_ENTRY(0xa2e),
TBL_ENTRY(0xa2f),
- TBL_ENTRY(0xa30), TBL_ENTRY(0xa31), TBL_ENTRY(0xa32),
TBL_ENTRY(0xa33),
- TBL_ENTRY(0xa34), TBL_ENTRY(0xa35), TBL_ENTRY(0xa36),
TBL_ENTRY(0xa37),
- TBL_ENTRY(0xa38), TBL_ENTRY(0xa39), TBL_ENTRY(0xa3a),
TBL_ENTRY(0xa3b),
- TBL_ENTRY(0xa3c), TBL_ENTRY(0xa3d), TBL_ENTRY(0xa3e),
TBL_ENTRY(0xa3f),
- TBL_ENTRY(0xa40), TBL_ENTRY(0xa41), TBL_ENTRY(0xa42),
TBL_ENTRY(0xa43),
- TBL_ENTRY(0xa44), TBL_ENTRY(0xa45), TBL_ENTRY(0xa46),
TBL_ENTRY(0xa47),
- TBL_ENTRY(0xa48), TBL_ENTRY(0xa49), TBL_ENTRY(0xa4a),
TBL_ENTRY(0xa4b),
- TBL_ENTRY(0xa4c), TBL_ENTRY(0xa4d), TBL_ENTRY(0xa4e),
TBL_ENTRY(0xa4f),
- TBL_ENTRY(0xa50), TBL_ENTRY(0xa51), TBL_ENTRY(0xa52),
TBL_ENTRY(0xa53),
- TBL_ENTRY(0xa54), TBL_ENTRY(0xa55), TBL_ENTRY(0xa56),
TBL_ENTRY(0xa57),
- TBL_ENTRY(0xa58), TBL_ENTRY(0xa59), TBL_ENTRY(0xa5a),
TBL_ENTRY(0xa5b),
- TBL_ENTRY(0xa5c), TBL_ENTRY(0xa5d), TBL_ENTRY(0xa5e),
TBL_ENTRY(0xa5f),
- TBL_ENTRY(0xa60), TBL_ENTRY(0xa61), TBL_ENTRY(0xa62),
TBL_ENTRY(0xa63),
- TBL_ENTRY(0xa64), TBL_ENTRY(0xa65), TBL_ENTRY(0xa66),
TBL_ENTRY(0xa67),
- TBL_ENTRY(0xa68), TBL_ENTRY(0xa69), TBL_ENTRY(0xa6a),
TBL_ENTRY(0xa6b),
- TBL_ENTRY(0xa6c), TBL_ENTRY(0xa6d), TBL_ENTRY(0xa6e),
TBL_ENTRY(0xa6f),
- TBL_ENTRY(0xa70), TBL_ENTRY(0xa71), TBL_ENTRY(0xa72),
TBL_ENTRY(0xa73),
- TBL_ENTRY(0xa74), TBL_ENTRY(0xa75), TBL_ENTRY(0xa76),
TBL_ENTRY(0xa77),
- TBL_ENTRY(0xa78), TBL_ENTRY(0xa79), TBL_ENTRY(0xa7a),
TBL_ENTRY(0xa7b),
- TBL_ENTRY(0xa7c), TBL_ENTRY(0xa7d), TBL_ENTRY(0xa7e),
TBL_ENTRY(0xa7f),
- TBL_ENTRY(0xa80), TBL_ENTRY(0xa81), TBL_ENTRY(0xa82),
TBL_ENTRY(0xa83),
- TBL_ENTRY(0xa84), TBL_ENTRY(0xa85), TBL_ENTRY(0xa86),
TBL_ENTRY(0xa87),
- TBL_ENTRY(0xa88), TBL_ENTRY(0xa89), TBL_ENTRY(0xa8a),
TBL_ENTRY(0xa8b),
- TBL_ENTRY(0xa8c), TBL_ENTRY(0xa8d), TBL_ENTRY(0xa8e),
TBL_ENTRY(0xa8f),
- TBL_ENTRY(0xa90), TBL_ENTRY(0xa91), TBL_ENTRY(0xa92),
TBL_ENTRY(0xa93),
- TBL_ENTRY(0xa94), TBL_ENTRY(0xa95), TBL_ENTRY(0xa96),
TBL_ENTRY(0xa97),
- TBL_ENTRY(0xa98), TBL_ENTRY(0xa99), TBL_ENTRY(0xa9a),
TBL_ENTRY(0xa9b),
- TBL_ENTRY(0xa9c), TBL_ENTRY(0xa9d), TBL_ENTRY(0xa9e),
TBL_ENTRY(0xa9f),
- TBL_ENTRY(0xaa0), TBL_ENTRY(0xaa1), TBL_ENTRY(0xaa2),
TBL_ENTRY(0xaa3),
- TBL_ENTRY(0xaa4), TBL_ENTRY(0xaa5), TBL_ENTRY(0xaa6),
TBL_ENTRY(0xaa7),
- TBL_ENTRY(0xaa8), TBL_ENTRY(0xaa9), TBL_ENTRY(0xaaa),
TBL_ENTRY(0xaab),
- TBL_ENTRY(0xaac), TBL_ENTRY(0xaad), TBL_ENTRY(0xaae),
TBL_ENTRY(0xaaf),
- TBL_ENTRY(0xab0), TBL_ENTRY(0xab1), TBL_ENTRY(0xab2),
TBL_ENTRY(0xab3),
- TBL_ENTRY(0xab4), TBL_ENTRY(0xab5), TBL_ENTRY(0xab6),
TBL_ENTRY(0xab7),
- TBL_ENTRY(0xab8), TBL_ENTRY(0xab9), TBL_ENTRY(0xaba),
TBL_ENTRY(0xabb),
- TBL_ENTRY(0xabc), TBL_ENTRY(0xabd), TBL_ENTRY(0xabe),
TBL_ENTRY(0xabf),
- TBL_ENTRY(0xac0), TBL_ENTRY(0xac1), TBL_ENTRY(0xac2),
TBL_ENTRY(0xac3),
- TBL_ENTRY(0xac4), TBL_ENTRY(0xac5), TBL_ENTRY(0xac6),
TBL_ENTRY(0xac7),
- TBL_ENTRY(0xac8), TBL_ENTRY(0xac9), TBL_ENTRY(0xaca),
TBL_ENTRY(0xacb),
- TBL_ENTRY(0xacc), TBL_ENTRY(0xacd), TBL_ENTRY(0xace),
TBL_ENTRY(0xacf),
- TBL_ENTRY(0xad0), TBL_ENTRY(0xad1), TBL_ENTRY(0xad2),
TBL_ENTRY(0xad3),
- TBL_ENTRY(0xad4), TBL_ENTRY(0xad5), TBL_ENTRY(0xad6),
TBL_ENTRY(0xad7),
- TBL_ENTRY(0xad8), TBL_ENTRY(0xad9), TBL_ENTRY(0xada),
TBL_ENTRY(0xadb),
- TBL_ENTRY(0xadc), TBL_ENTRY(0xadd), TBL_ENTRY(0xade),
TBL_ENTRY(0xadf),
- TBL_ENTRY(0xae0), TBL_ENTRY(0xae1), TBL_ENTRY(0xae2),
TBL_ENTRY(0xae3),
- TBL_ENTRY(0xae4), TBL_ENTRY(0xae5), TBL_ENTRY(0xae6),
TBL_ENTRY(0xae7),
- TBL_ENTRY(0xae8), TBL_ENTRY(0xae9), TBL_ENTRY(0xaea),
TBL_ENTRY(0xaeb),
- TBL_ENTRY(0xaec), TBL_ENTRY(0xaed), TBL_ENTRY(0xaee),
TBL_ENTRY(0xaef),
- TBL_ENTRY(0xaf0), TBL_ENTRY(0xaf1), TBL_ENTRY(0xaf2),
TBL_ENTRY(0xaf3),
- TBL_ENTRY(0xaf4), TBL_ENTRY(0xaf5), TBL_ENTRY(0xaf6),
TBL_ENTRY(0xaf7),
- TBL_ENTRY(0xaf8), TBL_ENTRY(0xaf9), TBL_ENTRY(0xafa),
TBL_ENTRY(0xafb),
- TBL_ENTRY(0xafc), TBL_ENTRY(0xafd), TBL_ENTRY(0xafe),
TBL_ENTRY(0xaff),
- TBL_ENTRY(0xb00), TBL_ENTRY(0xb01), TBL_ENTRY(0xb02),
TBL_ENTRY(0xb03),
- TBL_ENTRY(0xb04), TBL_ENTRY(0xb05), TBL_ENTRY(0xb06),
TBL_ENTRY(0xb07),
- TBL_ENTRY(0xb08), TBL_ENTRY(0xb09), TBL_ENTRY(0xb0a),
TBL_ENTRY(0xb0b),
- TBL_ENTRY(0xb0c), TBL_ENTRY(0xb0d), TBL_ENTRY(0xb0e),
TBL_ENTRY(0xb0f),
- TBL_ENTRY(0xb10), TBL_ENTRY(0xb11), TBL_ENTRY(0xb12),
TBL_ENTRY(0xb13),
- TBL_ENTRY(0xb14), TBL_ENTRY(0xb15), TBL_ENTRY(0xb16),
TBL_ENTRY(0xb17),
- TBL_ENTRY(0xb18), TBL_ENTRY(0xb19), TBL_ENTRY(0xb1a),
TBL_ENTRY(0xb1b),
- TBL_ENTRY(0xb1c), TBL_ENTRY(0xb1d), TBL_ENTRY(0xb1e),
TBL_ENTRY(0xb1f),
- TBL_ENTRY(0xb20), TBL_ENTRY(0xb21), TBL_ENTRY(0xb22),
TBL_ENTRY(0xb23),
- TBL_ENTRY(0xb24), TBL_ENTRY(0xb25), TBL_ENTRY(0xb26),
TBL_ENTRY(0xb27),
- TBL_ENTRY(0xb28), TBL_ENTRY(0xb29), TBL_ENTRY(0xb2a),
TBL_ENTRY(0xb2b),
- TBL_ENTRY(0xb2c), TBL_ENTRY(0xb2d), TBL_ENTRY(0xb2e),
TBL_ENTRY(0xb2f),
- TBL_ENTRY(0xb30), TBL_ENTRY(0xb31), TBL_ENTRY(0xb32),
TBL_ENTRY(0xb33),
- TBL_ENTRY(0xb34), TBL_ENTRY(0xb35), TBL_ENTRY(0xb36),
TBL_ENTRY(0xb37),
- TBL_ENTRY(0xb38), TBL_ENTRY(0xb39), TBL_ENTRY(0xb3a),
TBL_ENTRY(0xb3b),
- TBL_ENTRY(0xb3c), TBL_ENTRY(0xb3d), TBL_ENTRY(0xb3e),
TBL_ENTRY(0xb3f),
- TBL_ENTRY(0xb40), TBL_ENTRY(0xb41), TBL_ENTRY(0xb42),
TBL_ENTRY(0xb43),
- TBL_ENTRY(0xb44), TBL_ENTRY(0xb45), TBL_ENTRY(0xb46),
TBL_ENTRY(0xb47),
- TBL_ENTRY(0xb48), TBL_ENTRY(0xb49), TBL_ENTRY(0xb4a),
TBL_ENTRY(0xb4b),
- TBL_ENTRY(0xb4c), TBL_ENTRY(0xb4d), TBL_ENTRY(0xb4e),
TBL_ENTRY(0xb4f),
- TBL_ENTRY(0xb50), TBL_ENTRY(0xb51), TBL_ENTRY(0xb52),
TBL_ENTRY(0xb53),
- TBL_ENTRY(0xb54), TBL_ENTRY(0xb55), TBL_ENTRY(0xb56),
TBL_ENTRY(0xb57),
- TBL_ENTRY(0xb58), TBL_ENTRY(0xb59), TBL_ENTRY(0xb5a),
TBL_ENTRY(0xb5b),
- TBL_ENTRY(0xb5c), TBL_ENTRY(0xb5d), TBL_ENTRY(0xb5e),
TBL_ENTRY(0xb5f),
- TBL_ENTRY(0xb60), TBL_ENTRY(0xb61), TBL_ENTRY(0xb62),
TBL_ENTRY(0xb63),
- TBL_ENTRY(0xb64), TBL_ENTRY(0xb65), TBL_ENTRY(0xb66),
TBL_ENTRY(0xb67),
- TBL_ENTRY(0xb68), TBL_ENTRY(0xb69), TBL_ENTRY(0xb6a),
TBL_ENTRY(0xb6b),
- TBL_ENTRY(0xb6c), TBL_ENTRY(0xb6d), TBL_ENTRY(0xb6e),
TBL_ENTRY(0xb6f),
- TBL_ENTRY(0xb70), TBL_ENTRY(0xb71), TBL_ENTRY(0xb72),
TBL_ENTRY(0xb73),
- TBL_ENTRY(0xb74), TBL_ENTRY(0xb75), TBL_ENTRY(0xb76),
TBL_ENTRY(0xb77),
- TBL_ENTRY(0xb78), TBL_ENTRY(0xb79), TBL_ENTRY(0xb7a),
TBL_ENTRY(0xb7b),
- TBL_ENTRY(0xb7c), TBL_ENTRY(0xb7d), TBL_ENTRY(0xb7e),
TBL_ENTRY(0xb7f),
- TBL_ENTRY(0xb80), TBL_ENTRY(0xb81), TBL_ENTRY(0xb82),
TBL_ENTRY(0xb83),
- TBL_ENTRY(0xb84), TBL_ENTRY(0xb85), TBL_ENTRY(0xb86),
TBL_ENTRY(0xb87),
- TBL_ENTRY(0xb88), TBL_ENTRY(0xb89), TBL_ENTRY(0xb8a),
TBL_ENTRY(0xb8b),
- TBL_ENTRY(0xb8c), TBL_ENTRY(0xb8d), TBL_ENTRY(0xb8e),
TBL_ENTRY(0xb8f),
- TBL_ENTRY(0xb90), TBL_ENTRY(0xb91), TBL_ENTRY(0xb92),
TBL_ENTRY(0xb93),
- TBL_ENTRY(0xb94), TBL_ENTRY(0xb95), TBL_ENTRY(0xb96),
TBL_ENTRY(0xb97),
- TBL_ENTRY(0xb98), TBL_ENTRY(0xb99), TBL_ENTRY(0xb9a),
TBL_ENTRY(0xb9b),
- TBL_ENTRY(0xb9c), TBL_ENTRY(0xb9d), TBL_ENTRY(0xb9e),
TBL_ENTRY(0xb9f),
- TBL_ENTRY(0xba0), TBL_ENTRY(0xba1), TBL_ENTRY(0xba2),
TBL_ENTRY(0xba3),
- TBL_ENTRY(0xba4), TBL_ENTRY(0xba5), TBL_ENTRY(0xba6),
TBL_ENTRY(0xba7),
- TBL_ENTRY(0xba8), TBL_ENTRY(0xba9), TBL_ENTRY(0xbaa),
TBL_ENTRY(0xbab),
- TBL_ENTRY(0xbac), TBL_ENTRY(0xbad), TBL_ENTRY(0xbae),
TBL_ENTRY(0xbaf),
- TBL_ENTRY(0xbb0), TBL_ENTRY(0xbb1), TBL_ENTRY(0xbb2),
TBL_ENTRY(0xbb3),
- TBL_ENTRY(0xbb4), TBL_ENTRY(0xbb5), TBL_ENTRY(0xbb6),
TBL_ENTRY(0xbb7),
- TBL_ENTRY(0xbb8), TBL_ENTRY(0xbb9), TBL_ENTRY(0xbba),
TBL_ENTRY(0xbbb),
- TBL_ENTRY(0xbbc), TBL_ENTRY(0xbbd), TBL_ENTRY(0xbbe),
TBL_ENTRY(0xbbf),
- TBL_ENTRY(0xbc0), TBL_ENTRY(0xbc1), TBL_ENTRY(0xbc2),
TBL_ENTRY(0xbc3),
- TBL_ENTRY(0xbc4), TBL_ENTRY(0xbc5), TBL_ENTRY(0xbc6),
TBL_ENTRY(0xbc7),
- TBL_ENTRY(0xbc8), TBL_ENTRY(0xbc9), TBL_ENTRY(0xbca),
TBL_ENTRY(0xbcb),
- TBL_ENTRY(0xbcc), TBL_ENTRY(0xbcd), TBL_ENTRY(0xbce),
TBL_ENTRY(0xbcf),
- TBL_ENTRY(0xbd0), TBL_ENTRY(0xbd1), TBL_ENTRY(0xbd2),
TBL_ENTRY(0xbd3),
- TBL_ENTRY(0xbd4), TBL_ENTRY(0xbd5), TBL_ENTRY(0xbd6),
TBL_ENTRY(0xbd7),
- TBL_ENTRY(0xbd8), TBL_ENTRY(0xbd9), TBL_ENTRY(0xbda),
TBL_ENTRY(0xbdb),
- TBL_ENTRY(0xbdc), TBL_ENTRY(0xbdd), TBL_ENTRY(0xbde),
TBL_ENTRY(0xbdf),
- TBL_ENTRY(0xbe0), TBL_ENTRY(0xbe1), TBL_ENTRY(0xbe2),
TBL_ENTRY(0xbe3),
- TBL_ENTRY(0xbe4), TBL_ENTRY(0xbe5), TBL_ENTRY(0xbe6),
TBL_ENTRY(0xbe7),
- TBL_ENTRY(0xbe8), TBL_ENTRY(0xbe9), TBL_ENTRY(0xbea),
TBL_ENTRY(0xbeb),
- TBL_ENTRY(0xbec), TBL_ENTRY(0xbed), TBL_ENTRY(0xbee),
TBL_ENTRY(0xbef),
- TBL_ENTRY(0xbf0), TBL_ENTRY(0xbf1), TBL_ENTRY(0xbf2),
TBL_ENTRY(0xbf3),
- TBL_ENTRY(0xbf4), TBL_ENTRY(0xbf5), TBL_ENTRY(0xbf6),
TBL_ENTRY(0xbf7),
- TBL_ENTRY(0xbf8), TBL_ENTRY(0xbf9), TBL_ENTRY(0xbfa),
TBL_ENTRY(0xbfb),
- TBL_ENTRY(0xbfc), TBL_ENTRY(0xbfd), TBL_ENTRY(0xbfe),
TBL_ENTRY(0xbff),
- TBL_ENTRY(0xc00), TBL_ENTRY(0xc01), TBL_ENTRY(0xc02),
TBL_ENTRY(0xc03),
- TBL_ENTRY(0xc04), TBL_ENTRY(0xc05), TBL_ENTRY(0xc06),
TBL_ENTRY(0xc07),
- TBL_ENTRY(0xc08), TBL_ENTRY(0xc09), TBL_ENTRY(0xc0a),
TBL_ENTRY(0xc0b),
- TBL_ENTRY(0xc0c), TBL_ENTRY(0xc0d), TBL_ENTRY(0xc0e),
TBL_ENTRY(0xc0f),
- TBL_ENTRY(0xc10), TBL_ENTRY(0xc11), TBL_ENTRY(0xc12),
TBL_ENTRY(0xc13),
- TBL_ENTRY(0xc14), TBL_ENTRY(0xc15), TBL_ENTRY(0xc16),
TBL_ENTRY(0xc17),
- TBL_ENTRY(0xc18), TBL_ENTRY(0xc19), TBL_ENTRY(0xc1a),
TBL_ENTRY(0xc1b),
- TBL_ENTRY(0xc1c), TBL_ENTRY(0xc1d), TBL_ENTRY(0xc1e),
TBL_ENTRY(0xc1f),
- TBL_ENTRY(0xc20), TBL_ENTRY(0xc21), TBL_ENTRY(0xc22),
TBL_ENTRY(0xc23),
- TBL_ENTRY(0xc24), TBL_ENTRY(0xc25), TBL_ENTRY(0xc26),
TBL_ENTRY(0xc27),
- TBL_ENTRY(0xc28), TBL_ENTRY(0xc29), TBL_ENTRY(0xc2a),
TBL_ENTRY(0xc2b),
- TBL_ENTRY(0xc2c), TBL_ENTRY(0xc2d), TBL_ENTRY(0xc2e),
TBL_ENTRY(0xc2f),
- TBL_ENTRY(0xc30), TBL_ENTRY(0xc31), TBL_ENTRY(0xc32),
TBL_ENTRY(0xc33),
- TBL_ENTRY(0xc34), TBL_ENTRY(0xc35), TBL_ENTRY(0xc36),
TBL_ENTRY(0xc37),
- TBL_ENTRY(0xc38), TBL_ENTRY(0xc39), TBL_ENTRY(0xc3a),
TBL_ENTRY(0xc3b),
- TBL_ENTRY(0xc3c), TBL_ENTRY(0xc3d), TBL_ENTRY(0xc3e),
TBL_ENTRY(0xc3f),
- TBL_ENTRY(0xc40), TBL_ENTRY(0xc41), TBL_ENTRY(0xc42),
TBL_ENTRY(0xc43),
- TBL_ENTRY(0xc44), TBL_ENTRY(0xc45), TBL_ENTRY(0xc46),
TBL_ENTRY(0xc47),
- TBL_ENTRY(0xc48), TBL_ENTRY(0xc49), TBL_ENTRY(0xc4a),
TBL_ENTRY(0xc4b),
- TBL_ENTRY(0xc4c), TBL_ENTRY(0xc4d), TBL_ENTRY(0xc4e),
TBL_ENTRY(0xc4f),
- TBL_ENTRY(0xc50), TBL_ENTRY(0xc51), TBL_ENTRY(0xc52),
TBL_ENTRY(0xc53),
- TBL_ENTRY(0xc54), TBL_ENTRY(0xc55), TBL_ENTRY(0xc56),
TBL_ENTRY(0xc57),
- TBL_ENTRY(0xc58), TBL_ENTRY(0xc59), TBL_ENTRY(0xc5a),
TBL_ENTRY(0xc5b),
- TBL_ENTRY(0xc5c), TBL_ENTRY(0xc5d), TBL_ENTRY(0xc5e),
TBL_ENTRY(0xc5f),
- TBL_ENTRY(0xc60), TBL_ENTRY(0xc61), TBL_ENTRY(0xc62),
TBL_ENTRY(0xc63),
- TBL_ENTRY(0xc64), TBL_ENTRY(0xc65), TBL_ENTRY(0xc66),
TBL_ENTRY(0xc67),
- TBL_ENTRY(0xc68), TBL_ENTRY(0xc69), TBL_ENTRY(0xc6a),
TBL_ENTRY(0xc6b),
- TBL_ENTRY(0xc6c), TBL_ENTRY(0xc6d), TBL_ENTRY(0xc6e),
TBL_ENTRY(0xc6f),
- TBL_ENTRY(0xc70), TBL_ENTRY(0xc71), TBL_ENTRY(0xc72),
TBL_ENTRY(0xc73),
- TBL_ENTRY(0xc74), TBL_ENTRY(0xc75), TBL_ENTRY(0xc76),
TBL_ENTRY(0xc77),
- TBL_ENTRY(0xc78), TBL_ENTRY(0xc79), TBL_ENTRY(0xc7a),
TBL_ENTRY(0xc7b),
- TBL_ENTRY(0xc7c), TBL_ENTRY(0xc7d), TBL_ENTRY(0xc7e),
TBL_ENTRY(0xc7f),
- TBL_ENTRY(0xc80), TBL_ENTRY(0xc81), TBL_ENTRY(0xc82),
TBL_ENTRY(0xc83),
- TBL_ENTRY(0xc84), TBL_ENTRY(0xc85), TBL_ENTRY(0xc86),
TBL_ENTRY(0xc87),
- TBL_ENTRY(0xc88), TBL_ENTRY(0xc89), TBL_ENTRY(0xc8a),
TBL_ENTRY(0xc8b),
- TBL_ENTRY(0xc8c), TBL_ENTRY(0xc8d), TBL_ENTRY(0xc8e),
TBL_ENTRY(0xc8f),
- TBL_ENTRY(0xc90), TBL_ENTRY(0xc91), TBL_ENTRY(0xc92),
TBL_ENTRY(0xc93),
- TBL_ENTRY(0xc94), TBL_ENTRY(0xc95), TBL_ENTRY(0xc96),
TBL_ENTRY(0xc97),
- TBL_ENTRY(0xc98), TBL_ENTRY(0xc99), TBL_ENTRY(0xc9a),
TBL_ENTRY(0xc9b),
- TBL_ENTRY(0xc9c), TBL_ENTRY(0xc9d), TBL_ENTRY(0xc9e),
TBL_ENTRY(0xc9f),
- TBL_ENTRY(0xca0), TBL_ENTRY(0xca1), TBL_ENTRY(0xca2),
TBL_ENTRY(0xca3),
- TBL_ENTRY(0xca4), TBL_ENTRY(0xca5), TBL_ENTRY(0xca6),
TBL_ENTRY(0xca7),
- TBL_ENTRY(0xca8), TBL_ENTRY(0xca9), TBL_ENTRY(0xcaa),
TBL_ENTRY(0xcab),
- TBL_ENTRY(0xcac), TBL_ENTRY(0xcad), TBL_ENTRY(0xcae),
TBL_ENTRY(0xcaf),
- TBL_ENTRY(0xcb0), TBL_ENTRY(0xcb1), TBL_ENTRY(0xcb2),
TBL_ENTRY(0xcb3),
- TBL_ENTRY(0xcb4), TBL_ENTRY(0xcb5), TBL_ENTRY(0xcb6),
TBL_ENTRY(0xcb7),
- TBL_ENTRY(0xcb8), TBL_ENTRY(0xcb9), TBL_ENTRY(0xcba),
TBL_ENTRY(0xcbb),
- TBL_ENTRY(0xcbc), TBL_ENTRY(0xcbd), TBL_ENTRY(0xcbe),
TBL_ENTRY(0xcbf),
- TBL_ENTRY(0xcc0), TBL_ENTRY(0xcc1), TBL_ENTRY(0xcc2),
TBL_ENTRY(0xcc3),
- TBL_ENTRY(0xcc4), TBL_ENTRY(0xcc5), TBL_ENTRY(0xcc6),
TBL_ENTRY(0xcc7),
- TBL_ENTRY(0xcc8), TBL_ENTRY(0xcc9), TBL_ENTRY(0xcca),
TBL_ENTRY(0xccb),
- TBL_ENTRY(0xccc), TBL_ENTRY(0xccd), TBL_ENTRY(0xcce),
TBL_ENTRY(0xccf),
- TBL_ENTRY(0xcd0), TBL_ENTRY(0xcd1), TBL_ENTRY(0xcd2),
TBL_ENTRY(0xcd3),
- TBL_ENTRY(0xcd4), TBL_ENTRY(0xcd5), TBL_ENTRY(0xcd6),
TBL_ENTRY(0xcd7),
- TBL_ENTRY(0xcd8), TBL_ENTRY(0xcd9), TBL_ENTRY(0xcda),
TBL_ENTRY(0xcdb),
- TBL_ENTRY(0xcdc), TBL_ENTRY(0xcdd), TBL_ENTRY(0xcde),
TBL_ENTRY(0xcdf),
- TBL_ENTRY(0xce0), TBL_ENTRY(0xce1), TBL_ENTRY(0xce2),
TBL_ENTRY(0xce3),
- TBL_ENTRY(0xce4), TBL_ENTRY(0xce5), TBL_ENTRY(0xce6),
TBL_ENTRY(0xce7),
- TBL_ENTRY(0xce8), TBL_ENTRY(0xce9), TBL_ENTRY(0xcea),
TBL_ENTRY(0xceb),
- TBL_ENTRY(0xcec), TBL_ENTRY(0xced), TBL_ENTRY(0xcee),
TBL_ENTRY(0xcef),
- TBL_ENTRY(0xcf0), TBL_ENTRY(0xcf1), TBL_ENTRY(0xcf2),
TBL_ENTRY(0xcf3),
- TBL_ENTRY(0xcf4), TBL_ENTRY(0xcf5), TBL_ENTRY(0xcf6),
TBL_ENTRY(0xcf7),
- TBL_ENTRY(0xcf8), TBL_ENTRY(0xcf9), TBL_ENTRY(0xcfa),
TBL_ENTRY(0xcfb),
- TBL_ENTRY(0xcfc), TBL_ENTRY(0xcfd), TBL_ENTRY(0xcfe),
TBL_ENTRY(0xcff),
- TBL_ENTRY(0xd00), TBL_ENTRY(0xd01), TBL_ENTRY(0xd02),
TBL_ENTRY(0xd03),
- TBL_ENTRY(0xd04), TBL_ENTRY(0xd05), TBL_ENTRY(0xd06),
TBL_ENTRY(0xd07),
- TBL_ENTRY(0xd08), TBL_ENTRY(0xd09), TBL_ENTRY(0xd0a),
TBL_ENTRY(0xd0b),
- TBL_ENTRY(0xd0c), TBL_ENTRY(0xd0d), TBL_ENTRY(0xd0e),
TBL_ENTRY(0xd0f),
- TBL_ENTRY(0xd10), TBL_ENTRY(0xd11), TBL_ENTRY(0xd12),
TBL_ENTRY(0xd13),
- TBL_ENTRY(0xd14), TBL_ENTRY(0xd15), TBL_ENTRY(0xd16),
TBL_ENTRY(0xd17),
- TBL_ENTRY(0xd18), TBL_ENTRY(0xd19), TBL_ENTRY(0xd1a),
TBL_ENTRY(0xd1b),
- TBL_ENTRY(0xd1c), TBL_ENTRY(0xd1d), TBL_ENTRY(0xd1e),
TBL_ENTRY(0xd1f),
- TBL_ENTRY(0xd20), TBL_ENTRY(0xd21), TBL_ENTRY(0xd22),
TBL_ENTRY(0xd23),
- TBL_ENTRY(0xd24), TBL_ENTRY(0xd25), TBL_ENTRY(0xd26),
TBL_ENTRY(0xd27),
- TBL_ENTRY(0xd28), TBL_ENTRY(0xd29), TBL_ENTRY(0xd2a),
TBL_ENTRY(0xd2b),
- TBL_ENTRY(0xd2c), TBL_ENTRY(0xd2d), TBL_ENTRY(0xd2e),
TBL_ENTRY(0xd2f),
- TBL_ENTRY(0xd30), TBL_ENTRY(0xd31), TBL_ENTRY(0xd32),
TBL_ENTRY(0xd33),
- TBL_ENTRY(0xd34), TBL_ENTRY(0xd35), TBL_ENTRY(0xd36),
TBL_ENTRY(0xd37),
- TBL_ENTRY(0xd38), TBL_ENTRY(0xd39), TBL_ENTRY(0xd3a),
TBL_ENTRY(0xd3b),
- TBL_ENTRY(0xd3c), TBL_ENTRY(0xd3d), TBL_ENTRY(0xd3e),
TBL_ENTRY(0xd3f),
- TBL_ENTRY(0xd40), TBL_ENTRY(0xd41), TBL_ENTRY(0xd42),
TBL_ENTRY(0xd43),
- TBL_ENTRY(0xd44), TBL_ENTRY(0xd45), TBL_ENTRY(0xd46),
TBL_ENTRY(0xd47),
- TBL_ENTRY(0xd48), TBL_ENTRY(0xd49), TBL_ENTRY(0xd4a),
TBL_ENTRY(0xd4b),
- TBL_ENTRY(0xd4c), TBL_ENTRY(0xd4d), TBL_ENTRY(0xd4e),
TBL_ENTRY(0xd4f),
- TBL_ENTRY(0xd50), TBL_ENTRY(0xd51), TBL_ENTRY(0xd52),
TBL_ENTRY(0xd53),
- TBL_ENTRY(0xd54), TBL_ENTRY(0xd55), TBL_ENTRY(0xd56),
TBL_ENTRY(0xd57),
- TBL_ENTRY(0xd58), TBL_ENTRY(0xd59), TBL_ENTRY(0xd5a),
TBL_ENTRY(0xd5b),
- TBL_ENTRY(0xd5c), TBL_ENTRY(0xd5d), TBL_ENTRY(0xd5e),
TBL_ENTRY(0xd5f),
- TBL_ENTRY(0xd60), TBL_ENTRY(0xd61), TBL_ENTRY(0xd62),
TBL_ENTRY(0xd63),
- TBL_ENTRY(0xd64), TBL_ENTRY(0xd65), TBL_ENTRY(0xd66),
TBL_ENTRY(0xd67),
- TBL_ENTRY(0xd68), TBL_ENTRY(0xd69), TBL_ENTRY(0xd6a),
TBL_ENTRY(0xd6b),
- TBL_ENTRY(0xd6c), TBL_ENTRY(0xd6d), TBL_ENTRY(0xd6e),
TBL_ENTRY(0xd6f),
- TBL_ENTRY(0xd70), TBL_ENTRY(0xd71), TBL_ENTRY(0xd72),
TBL_ENTRY(0xd73),
- TBL_ENTRY(0xd74), TBL_ENTRY(0xd75), TBL_ENTRY(0xd76),
TBL_ENTRY(0xd77),
- TBL_ENTRY(0xd78), TBL_ENTRY(0xd79), TBL_ENTRY(0xd7a),
TBL_ENTRY(0xd7b),
- TBL_ENTRY(0xd7c), TBL_ENTRY(0xd7d), TBL_ENTRY(0xd7e),
TBL_ENTRY(0xd7f),
- TBL_ENTRY(0xd80), TBL_ENTRY(0xd81), TBL_ENTRY(0xd82),
TBL_ENTRY(0xd83),
- TBL_ENTRY(0xd84), TBL_ENTRY(0xd85), TBL_ENTRY(0xd86),
TBL_ENTRY(0xd87),
- TBL_ENTRY(0xd88), TBL_ENTRY(0xd89), TBL_ENTRY(0xd8a),
TBL_ENTRY(0xd8b),
- TBL_ENTRY(0xd8c), TBL_ENTRY(0xd8d), TBL_ENTRY(0xd8e),
TBL_ENTRY(0xd8f),
- TBL_ENTRY(0xd90), TBL_ENTRY(0xd91), TBL_ENTRY(0xd92),
TBL_ENTRY(0xd93),
- TBL_ENTRY(0xd94), TBL_ENTRY(0xd95), TBL_ENTRY(0xd96),
TBL_ENTRY(0xd97),
- TBL_ENTRY(0xd98), TBL_ENTRY(0xd99), TBL_ENTRY(0xd9a),
TBL_ENTRY(0xd9b),
- TBL_ENTRY(0xd9c), TBL_ENTRY(0xd9d), TBL_ENTRY(0xd9e),
TBL_ENTRY(0xd9f),
- TBL_ENTRY(0xda0), TBL_ENTRY(0xda1), TBL_ENTRY(0xda2),
TBL_ENTRY(0xda3),
- TBL_ENTRY(0xda4), TBL_ENTRY(0xda5), TBL_ENTRY(0xda6),
TBL_ENTRY(0xda7),
- TBL_ENTRY(0xda8), TBL_ENTRY(0xda9), TBL_ENTRY(0xdaa),
TBL_ENTRY(0xdab),
- TBL_ENTRY(0xdac), TBL_ENTRY(0xdad), TBL_ENTRY(0xdae),
TBL_ENTRY(0xdaf),
- TBL_ENTRY(0xdb0), TBL_ENTRY(0xdb1), TBL_ENTRY(0xdb2),
TBL_ENTRY(0xdb3),
- TBL_ENTRY(0xdb4), TBL_ENTRY(0xdb5), TBL_ENTRY(0xdb6),
TBL_ENTRY(0xdb7),
- TBL_ENTRY(0xdb8), TBL_ENTRY(0xdb9), TBL_ENTRY(0xdba),
TBL_ENTRY(0xdbb),
- TBL_ENTRY(0xdbc), TBL_ENTRY(0xdbd), TBL_ENTRY(0xdbe),
TBL_ENTRY(0xdbf),
- TBL_ENTRY(0xdc0), TBL_ENTRY(0xdc1), TBL_ENTRY(0xdc2),
TBL_ENTRY(0xdc3),
- TBL_ENTRY(0xdc4), TBL_ENTRY(0xdc5), TBL_ENTRY(0xdc6),
TBL_ENTRY(0xdc7),
- TBL_ENTRY(0xdc8), TBL_ENTRY(0xdc9), TBL_ENTRY(0xdca),
TBL_ENTRY(0xdcb),
- TBL_ENTRY(0xdcc), TBL_ENTRY(0xdcd), TBL_ENTRY(0xdce),
TBL_ENTRY(0xdcf),
- TBL_ENTRY(0xdd0), TBL_ENTRY(0xdd1), TBL_ENTRY(0xdd2),
TBL_ENTRY(0xdd3),
- TBL_ENTRY(0xdd4), TBL_ENTRY(0xdd5), TBL_ENTRY(0xdd6),
TBL_ENTRY(0xdd7),
- TBL_ENTRY(0xdd8), TBL_ENTRY(0xdd9), TBL_ENTRY(0xdda),
TBL_ENTRY(0xddb),
- TBL_ENTRY(0xddc), TBL_ENTRY(0xddd), TBL_ENTRY(0xdde),
TBL_ENTRY(0xddf),
- TBL_ENTRY(0xde0), TBL_ENTRY(0xde1), TBL_ENTRY(0xde2),
TBL_ENTRY(0xde3),
- TBL_ENTRY(0xde4), TBL_ENTRY(0xde5), TBL_ENTRY(0xde6),
TBL_ENTRY(0xde7),
- TBL_ENTRY(0xde8), TBL_ENTRY(0xde9), TBL_ENTRY(0xdea),
TBL_ENTRY(0xdeb),
- TBL_ENTRY(0xdec), TBL_ENTRY(0xded), TBL_ENTRY(0xdee),
TBL_ENTRY(0xdef),
- TBL_ENTRY(0xdf0), TBL_ENTRY(0xdf1), TBL_ENTRY(0xdf2),
TBL_ENTRY(0xdf3),
- TBL_ENTRY(0xdf4), TBL_ENTRY(0xdf5), TBL_ENTRY(0xdf6),
TBL_ENTRY(0xdf7),
- TBL_ENTRY(0xdf8), TBL_ENTRY(0xdf9), TBL_ENTRY(0xdfa),
TBL_ENTRY(0xdfb),
- TBL_ENTRY(0xdfc), TBL_ENTRY(0xdfd), TBL_ENTRY(0xdfe),
TBL_ENTRY(0xdff),
- TBL_ENTRY(0xe00), TBL_ENTRY(0xe01), TBL_ENTRY(0xe02),
TBL_ENTRY(0xe03),
- TBL_ENTRY(0xe04), TBL_ENTRY(0xe05), TBL_ENTRY(0xe06),
TBL_ENTRY(0xe07),
- TBL_ENTRY(0xe08), TBL_ENTRY(0xe09), TBL_ENTRY(0xe0a),
TBL_ENTRY(0xe0b),
- TBL_ENTRY(0xe0c), TBL_ENTRY(0xe0d), TBL_ENTRY(0xe0e),
TBL_ENTRY(0xe0f),
- TBL_ENTRY(0xe10), TBL_ENTRY(0xe11), TBL_ENTRY(0xe12),
TBL_ENTRY(0xe13),
- TBL_ENTRY(0xe14), TBL_ENTRY(0xe15), TBL_ENTRY(0xe16),
TBL_ENTRY(0xe17),
- TBL_ENTRY(0xe18), TBL_ENTRY(0xe19), TBL_ENTRY(0xe1a),
TBL_ENTRY(0xe1b),
- TBL_ENTRY(0xe1c), TBL_ENTRY(0xe1d), TBL_ENTRY(0xe1e),
TBL_ENTRY(0xe1f),
- TBL_ENTRY(0xe20), TBL_ENTRY(0xe21), TBL_ENTRY(0xe22),
TBL_ENTRY(0xe23),
- TBL_ENTRY(0xe24), TBL_ENTRY(0xe25), TBL_ENTRY(0xe26),
TBL_ENTRY(0xe27),
- TBL_ENTRY(0xe28), TBL_ENTRY(0xe29), TBL_ENTRY(0xe2a),
TBL_ENTRY(0xe2b),
- TBL_ENTRY(0xe2c), TBL_ENTRY(0xe2d), TBL_ENTRY(0xe2e),
TBL_ENTRY(0xe2f),
- TBL_ENTRY(0xe30), TBL_ENTRY(0xe31), TBL_ENTRY(0xe32),
TBL_ENTRY(0xe33),
- TBL_ENTRY(0xe34), TBL_ENTRY(0xe35), TBL_ENTRY(0xe36),
TBL_ENTRY(0xe37),
- TBL_ENTRY(0xe38), TBL_ENTRY(0xe39), TBL_ENTRY(0xe3a),
TBL_ENTRY(0xe3b),
- TBL_ENTRY(0xe3c), TBL_ENTRY(0xe3d), TBL_ENTRY(0xe3e),
TBL_ENTRY(0xe3f),
- TBL_ENTRY(0xe40), TBL_ENTRY(0xe41), TBL_ENTRY(0xe42),
TBL_ENTRY(0xe43),
- TBL_ENTRY(0xe44), TBL_ENTRY(0xe45), TBL_ENTRY(0xe46),
TBL_ENTRY(0xe47),
- TBL_ENTRY(0xe48), TBL_ENTRY(0xe49), TBL_ENTRY(0xe4a),
TBL_ENTRY(0xe4b),
- TBL_ENTRY(0xe4c), TBL_ENTRY(0xe4d), TBL_ENTRY(0xe4e),
TBL_ENTRY(0xe4f),
- TBL_ENTRY(0xe50), TBL_ENTRY(0xe51), TBL_ENTRY(0xe52),
TBL_ENTRY(0xe53),
- TBL_ENTRY(0xe54), TBL_ENTRY(0xe55), TBL_ENTRY(0xe56),
TBL_ENTRY(0xe57),
- TBL_ENTRY(0xe58), TBL_ENTRY(0xe59), TBL_ENTRY(0xe5a),
TBL_ENTRY(0xe5b),
- TBL_ENTRY(0xe5c), TBL_ENTRY(0xe5d), TBL_ENTRY(0xe5e),
TBL_ENTRY(0xe5f),
- TBL_ENTRY(0xe60), TBL_ENTRY(0xe61), TBL_ENTRY(0xe62),
TBL_ENTRY(0xe63),
- TBL_ENTRY(0xe64), TBL_ENTRY(0xe65), TBL_ENTRY(0xe66),
TBL_ENTRY(0xe67),
- TBL_ENTRY(0xe68), TBL_ENTRY(0xe69), TBL_ENTRY(0xe6a),
TBL_ENTRY(0xe6b),
- TBL_ENTRY(0xe6c), TBL_ENTRY(0xe6d), TBL_ENTRY(0xe6e),
TBL_ENTRY(0xe6f),
- TBL_ENTRY(0xe70), TBL_ENTRY(0xe71), TBL_ENTRY(0xe72),
TBL_ENTRY(0xe73),
- TBL_ENTRY(0xe74), TBL_ENTRY(0xe75), TBL_ENTRY(0xe76),
TBL_ENTRY(0xe77),
- TBL_ENTRY(0xe78), TBL_ENTRY(0xe79), TBL_ENTRY(0xe7a),
TBL_ENTRY(0xe7b),
- TBL_ENTRY(0xe7c), TBL_ENTRY(0xe7d), TBL_ENTRY(0xe7e),
TBL_ENTRY(0xe7f),
- TBL_ENTRY(0xe80), TBL_ENTRY(0xe81), TBL_ENTRY(0xe82),
TBL_ENTRY(0xe83),
- TBL_ENTRY(0xe84), TBL_ENTRY(0xe85), TBL_ENTRY(0xe86),
TBL_ENTRY(0xe87),
- TBL_ENTRY(0xe88), TBL_ENTRY(0xe89), TBL_ENTRY(0xe8a),
TBL_ENTRY(0xe8b),
- TBL_ENTRY(0xe8c), TBL_ENTRY(0xe8d), TBL_ENTRY(0xe8e),
TBL_ENTRY(0xe8f),
- TBL_ENTRY(0xe90), TBL_ENTRY(0xe91), TBL_ENTRY(0xe92),
TBL_ENTRY(0xe93),
- TBL_ENTRY(0xe94), TBL_ENTRY(0xe95), TBL_ENTRY(0xe96),
TBL_ENTRY(0xe97),
- TBL_ENTRY(0xe98), TBL_ENTRY(0xe99), TBL_ENTRY(0xe9a),
TBL_ENTRY(0xe9b),
- TBL_ENTRY(0xe9c), TBL_ENTRY(0xe9d), TBL_ENTRY(0xe9e),
TBL_ENTRY(0xe9f),
- TBL_ENTRY(0xea0), TBL_ENTRY(0xea1), TBL_ENTRY(0xea2),
TBL_ENTRY(0xea3),
- TBL_ENTRY(0xea4), TBL_ENTRY(0xea5), TBL_ENTRY(0xea6),
TBL_ENTRY(0xea7),
- TBL_ENTRY(0xea8), TBL_ENTRY(0xea9), TBL_ENTRY(0xeaa),
TBL_ENTRY(0xeab),
- TBL_ENTRY(0xeac), TBL_ENTRY(0xead), TBL_ENTRY(0xeae),
TBL_ENTRY(0xeaf),
- TBL_ENTRY(0xeb0), TBL_ENTRY(0xeb1), TBL_ENTRY(0xeb2),
TBL_ENTRY(0xeb3),
- TBL_ENTRY(0xeb4), TBL_ENTRY(0xeb5), TBL_ENTRY(0xeb6),
TBL_ENTRY(0xeb7),
- TBL_ENTRY(0xeb8), TBL_ENTRY(0xeb9), TBL_ENTRY(0xeba),
TBL_ENTRY(0xebb),
- TBL_ENTRY(0xebc), TBL_ENTRY(0xebd), TBL_ENTRY(0xebe),
TBL_ENTRY(0xebf),
- TBL_ENTRY(0xec0), TBL_ENTRY(0xec1), TBL_ENTRY(0xec2),
TBL_ENTRY(0xec3),
- TBL_ENTRY(0xec4), TBL_ENTRY(0xec5), TBL_ENTRY(0xec6),
TBL_ENTRY(0xec7),
- TBL_ENTRY(0xec8), TBL_ENTRY(0xec9), TBL_ENTRY(0xeca),
TBL_ENTRY(0xecb),
- TBL_ENTRY(0xecc), TBL_ENTRY(0xecd), TBL_ENTRY(0xece),
TBL_ENTRY(0xecf),
- TBL_ENTRY(0xed0), TBL_ENTRY(0xed1), TBL_ENTRY(0xed2),
TBL_ENTRY(0xed3),
- TBL_ENTRY(0xed4), TBL_ENTRY(0xed5), TBL_ENTRY(0xed6),
TBL_ENTRY(0xed7),
- TBL_ENTRY(0xed8), TBL_ENTRY(0xed9), TBL_ENTRY(0xeda),
TBL_ENTRY(0xedb),
- TBL_ENTRY(0xedc), TBL_ENTRY(0xedd), TBL_ENTRY(0xede),
TBL_ENTRY(0xedf),
- TBL_ENTRY(0xee0), TBL_ENTRY(0xee1), TBL_ENTRY(0xee2),
TBL_ENTRY(0xee3),
- TBL_ENTRY(0xee4), TBL_ENTRY(0xee5), TBL_ENTRY(0xee6),
TBL_ENTRY(0xee7),
- TBL_ENTRY(0xee8), TBL_ENTRY(0xee9), TBL_ENTRY(0xeea),
TBL_ENTRY(0xeeb),
- TBL_ENTRY(0xeec), TBL_ENTRY(0xeed), TBL_ENTRY(0xeee),
TBL_ENTRY(0xeef),
- TBL_ENTRY(0xef0), TBL_ENTRY(0xef1), TBL_ENTRY(0xef2),
TBL_ENTRY(0xef3),
- TBL_ENTRY(0xef4), TBL_ENTRY(0xef5), TBL_ENTRY(0xef6),
TBL_ENTRY(0xef7),
- TBL_ENTRY(0xef8), TBL_ENTRY(0xef9), TBL_ENTRY(0xefa),
TBL_ENTRY(0xefb),
- TBL_ENTRY(0xefc), TBL_ENTRY(0xefd), TBL_ENTRY(0xefe),
TBL_ENTRY(0xeff),
- TBL_ENTRY(0xf00), TBL_ENTRY(0xf01), TBL_ENTRY(0xf02),
TBL_ENTRY(0xf03),
- TBL_ENTRY(0xf04), TBL_ENTRY(0xf05), TBL_ENTRY(0xf06),
TBL_ENTRY(0xf07),
- TBL_ENTRY(0xf08), TBL_ENTRY(0xf09), TBL_ENTRY(0xf0a),
TBL_ENTRY(0xf0b),
- TBL_ENTRY(0xf0c), TBL_ENTRY(0xf0d), TBL_ENTRY(0xf0e),
TBL_ENTRY(0xf0f),
- TBL_ENTRY(0xf10), TBL_ENTRY(0xf11), TBL_ENTRY(0xf12),
TBL_ENTRY(0xf13),
- TBL_ENTRY(0xf14), TBL_ENTRY(0xf15), TBL_ENTRY(0xf16),
TBL_ENTRY(0xf17),
- TBL_ENTRY(0xf18), TBL_ENTRY(0xf19), TBL_ENTRY(0xf1a),
TBL_ENTRY(0xf1b),
- TBL_ENTRY(0xf1c), TBL_ENTRY(0xf1d), TBL_ENTRY(0xf1e),
TBL_ENTRY(0xf1f),
- TBL_ENTRY(0xf20), TBL_ENTRY(0xf21), TBL_ENTRY(0xf22),
TBL_ENTRY(0xf23),
- TBL_ENTRY(0xf24), TBL_ENTRY(0xf25), TBL_ENTRY(0xf26),
TBL_ENTRY(0xf27),
- TBL_ENTRY(0xf28), TBL_ENTRY(0xf29), TBL_ENTRY(0xf2a),
TBL_ENTRY(0xf2b),
- TBL_ENTRY(0xf2c), TBL_ENTRY(0xf2d), TBL_ENTRY(0xf2e),
TBL_ENTRY(0xf2f),
- TBL_ENTRY(0xf30), TBL_ENTRY(0xf31), TBL_ENTRY(0xf32),
TBL_ENTRY(0xf33),
- TBL_ENTRY(0xf34), TBL_ENTRY(0xf35), TBL_ENTRY(0xf36),
TBL_ENTRY(0xf37),
- TBL_ENTRY(0xf38), TBL_ENTRY(0xf39), TBL_ENTRY(0xf3a),
TBL_ENTRY(0xf3b),
- TBL_ENTRY(0xf3c), TBL_ENTRY(0xf3d), TBL_ENTRY(0xf3e),
TBL_ENTRY(0xf3f),
- TBL_ENTRY(0xf40), TBL_ENTRY(0xf41), TBL_ENTRY(0xf42),
TBL_ENTRY(0xf43),
- TBL_ENTRY(0xf44), TBL_ENTRY(0xf45), TBL_ENTRY(0xf46),
TBL_ENTRY(0xf47),
- TBL_ENTRY(0xf48), TBL_ENTRY(0xf49), TBL_ENTRY(0xf4a),
TBL_ENTRY(0xf4b),
- TBL_ENTRY(0xf4c), TBL_ENTRY(0xf4d), TBL_ENTRY(0xf4e),
TBL_ENTRY(0xf4f),
- TBL_ENTRY(0xf50), TBL_ENTRY(0xf51), TBL_ENTRY(0xf52),
TBL_ENTRY(0xf53),
- TBL_ENTRY(0xf54), TBL_ENTRY(0xf55), TBL_ENTRY(0xf56),
TBL_ENTRY(0xf57),
- TBL_ENTRY(0xf58), TBL_ENTRY(0xf59), TBL_ENTRY(0xf5a),
TBL_ENTRY(0xf5b),
- TBL_ENTRY(0xf5c), TBL_ENTRY(0xf5d), TBL_ENTRY(0xf5e),
TBL_ENTRY(0xf5f),
- TBL_ENTRY(0xf60), TBL_ENTRY(0xf61), TBL_ENTRY(0xf62),
TBL_ENTRY(0xf63),
- TBL_ENTRY(0xf64), TBL_ENTRY(0xf65), TBL_ENTRY(0xf66),
TBL_ENTRY(0xf67),
- TBL_ENTRY(0xf68), TBL_ENTRY(0xf69), TBL_ENTRY(0xf6a),
TBL_ENTRY(0xf6b),
- TBL_ENTRY(0xf6c), TBL_ENTRY(0xf6d), TBL_ENTRY(0xf6e),
TBL_ENTRY(0xf6f),
- TBL_ENTRY(0xf70), TBL_ENTRY(0xf71), TBL_ENTRY(0xf72),
TBL_ENTRY(0xf73),
- TBL_ENTRY(0xf74), TBL_ENTRY(0xf75), TBL_ENTRY(0xf76),
TBL_ENTRY(0xf77),
- TBL_ENTRY(0xf78), TBL_ENTRY(0xf79), TBL_ENTRY(0xf7a),
TBL_ENTRY(0xf7b),
- TBL_ENTRY(0xf7c), TBL_ENTRY(0xf7d), TBL_ENTRY(0xf7e),
TBL_ENTRY(0xf7f),
- TBL_ENTRY(0xf80), TBL_ENTRY(0xf81), TBL_ENTRY(0xf82),
TBL_ENTRY(0xf83),
- TBL_ENTRY(0xf84), TBL_ENTRY(0xf85), TBL_ENTRY(0xf86),
TBL_ENTRY(0xf87),
- TBL_ENTRY(0xf88), TBL_ENTRY(0xf89), TBL_ENTRY(0xf8a),
TBL_ENTRY(0xf8b),
- TBL_ENTRY(0xf8c), TBL_ENTRY(0xf8d), TBL_ENTRY(0xf8e),
TBL_ENTRY(0xf8f),
- TBL_ENTRY(0xf90), TBL_ENTRY(0xf91), TBL_ENTRY(0xf92),
TBL_ENTRY(0xf93),
- TBL_ENTRY(0xf94), TBL_ENTRY(0xf95), TBL_ENTRY(0xf96),
TBL_ENTRY(0xf97),
- TBL_ENTRY(0xf98), TBL_ENTRY(0xf99), TBL_ENTRY(0xf9a),
TBL_ENTRY(0xf9b),
- TBL_ENTRY(0xf9c), TBL_ENTRY(0xf9d), TBL_ENTRY(0xf9e),
TBL_ENTRY(0xf9f),
- TBL_ENTRY(0xfa0), TBL_ENTRY(0xfa1), TBL_ENTRY(0xfa2),
TBL_ENTRY(0xfa3),
- TBL_ENTRY(0xfa4), TBL_ENTRY(0xfa5), TBL_ENTRY(0xfa6),
TBL_ENTRY(0xfa7),
- TBL_ENTRY(0xfa8), TBL_ENTRY(0xfa9), TBL_ENTRY(0xfaa),
TBL_ENTRY(0xfab),
- TBL_ENTRY(0xfac), TBL_ENTRY(0xfad), TBL_ENTRY(0xfae),
TBL_ENTRY(0xfaf),
- TBL_ENTRY(0xfb0), TBL_ENTRY(0xfb1), TBL_ENTRY(0xfb2),
TBL_ENTRY(0xfb3),
- TBL_ENTRY(0xfb4), TBL_ENTRY(0xfb5), TBL_ENTRY(0xfb6),
TBL_ENTRY(0xfb7),
- TBL_ENTRY(0xfb8), TBL_ENTRY(0xfb9), TBL_ENTRY(0xfba),
TBL_ENTRY(0xfbb),
- TBL_ENTRY(0xfbc), TBL_ENTRY(0xfbd), TBL_ENTRY(0xfbe),
TBL_ENTRY(0xfbf),
- TBL_ENTRY(0xfc0), TBL_ENTRY(0xfc1), TBL_ENTRY(0xfc2),
TBL_ENTRY(0xfc3),
- TBL_ENTRY(0xfc4), TBL_ENTRY(0xfc5), TBL_ENTRY(0xfc6),
TBL_ENTRY(0xfc7),
- TBL_ENTRY(0xfc8), TBL_ENTRY(0xfc9), TBL_ENTRY(0xfca),
TBL_ENTRY(0xfcb),
- TBL_ENTRY(0xfcc), TBL_ENTRY(0xfcd), TBL_ENTRY(0xfce),
TBL_ENTRY(0xfcf),
- TBL_ENTRY(0xfd0), TBL_ENTRY(0xfd1), TBL_ENTRY(0xfd2),
TBL_ENTRY(0xfd3),
- TBL_ENTRY(0xfd4), TBL_ENTRY(0xfd5), TBL_ENTRY(0xfd6),
TBL_ENTRY(0xfd7),
- TBL_ENTRY(0xfd8), TBL_ENTRY(0xfd9), TBL_ENTRY(0xfda),
TBL_ENTRY(0xfdb),
- TBL_ENTRY(0xfdc), TBL_ENTRY(0xfdd), TBL_ENTRY(0xfde),
TBL_ENTRY(0xfdf),
- TBL_ENTRY(0xfe0), TBL_ENTRY(0xfe1), TBL_ENTRY(0xfe2),
TBL_ENTRY(0xfe3),
- TBL_ENTRY(0xfe4), TBL_ENTRY(0xfe5), TBL_ENTRY(0xfe6),
TBL_ENTRY(0xfe7),
- TBL_ENTRY(0xfe8), TBL_ENTRY(0xfe9), TBL_ENTRY(0xfea),
TBL_ENTRY(0xfeb),
- TBL_ENTRY(0xfec), TBL_ENTRY(0xfed), TBL_ENTRY(0xfee),
TBL_ENTRY(0xfef),
- TBL_ENTRY(0xff0), TBL_ENTRY(0xff1), TBL_ENTRY(0xff2),
TBL_ENTRY(0xff3),
- TBL_ENTRY(0xff4), TBL_ENTRY(0xff5), TBL_ENTRY(0xff6),
TBL_ENTRY(0xff7),
- TBL_ENTRY(0xff8), TBL_ENTRY(0xff9), TBL_ENTRY(0xffa),
TBL_ENTRY(0xffb),
- TBL_ENTRY(0xffc), TBL_ENTRY(0xffd), TBL_ENTRY(0xffe),
TBL_ENTRY(0xfff), +};
This table seems rather predictable -- the value of each entry seems to be computable from the index alone. Is there a shorter way to define it? I mean, here, it is an initialized non-const, bu we could also make it a un-initialized non-const and fill it through a for-loop, could we not?
diff --git a/arch/arm/cpu/armv7/uniphier/lowlevel_init.S b/arch/arm/cpu/armv7/uniphier/lowlevel_init.S new file mode 100644 index 0000000..0ea12d3 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/lowlevel_init.S @@ -0,0 +1,159 @@ +/*
- Copyright (C) 2012-2014 Panasonic Corporation
- Author: Masahiro Yamada yamada.m@jp.panasonic.com
+#include <config.h> +#include <linux/linkage.h> +#include <asm/system.h> +#include <asm/arch/led.h> +#include <asm/arch/arm-mpcore.h> +#include <asm/arch/sbc-regs.h>
+ENTRY(lowlevel_init)
- mov r8, lr @ persevere link
reg across call +
* The UniPhier Boot ROM loads SPL code to the L2 cache.
* But CPUs can only do instruction fetch now because
start.S has
* cleared C and M bits.
* First we need to turn on MMU and Dcache again to get back
* data access to L2.
- mrc p15, 0, r0, c1, c0, 0 @ SCTLR
(System Contrl Register)
- orr r0, r0, #(CR_C | CR_M) @ enable
MMU and Dcache
- mcr p15, 0, r0, c1, c0, 0
* Now we are using the page table embedded in the Boot ROM.
* It is not handy since it is not a straight mapped table
for sLD3.
* What we need to do next is to switch over to the page
table in SPL.
- ldr r3, =init_page_table @ page table must be
16KB aligned +
- /* Disable MMU and Dcache before switching Page Table */
- mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System
Contrl Register)
- bic r0, r0, #(CR_C | CR_M) @ disable MMU and
Dcache
- bl enable_mmu
+#ifdef CONFIG_UNIPHIER_SMP
* ACTLR (Auxiliary Control Register) for Cortex-A9
* bit[9] Parity on
* bit[8] Alloc in one way
* bit[7] EXCL (Exclusive cache bit)
* bit[6] SMP
* bit[3] Write full line of zeros mode
* bit[2] L1 Prefetch enable
* bit[1] L2 prefetch enable
* bit[0] FW (Cache and TLB maintenance broadcast)
- mrc p15, 0, r0, c1, c0, 1 @ ACTLR (Auxiliary
Control Register)
- orr r0, r0, #0x41 @ enable SMP, FW bit
- mcr p15, 0, r0, c1, c0, 1
- /* branch by CPU ID */
- mrc p15, 0, r0, c0, c0, 5 @ MPIDR
(Multiprocessor Affinity Register)
- and r0, r0, #0x3
- cmp r0, #0x0
- beq primary_cpu
- ldr r1, =ROM_BOOT_ROMRSV2
- mov r0, #0
- str r0, [r1]
+0: wfe
- ldr r0, [r1]
- cmp r0, #0
- beq 0b
- bx r0 @ r0: entry point of
U-Boot main for the secondary CPU +primary_cpu:
- ldr r0, =_start @ entry for the
secondary CPU
- str r0, [r1]
- ldr r0, [r1] @ make sure str is
complete before sev
- sev @ kick the sedoncary CPU
- mrc p15, 4, r1, c15, c0, 0 @ Configuration
Base Address Register
- bfc r1, #0, #13 @ clear bit 12-0
- mov r0, #-1
- str r0, [r1, #SCU_INV_ALL] @ SCU Invalidate
All Register
- mov r0, #1 @ SCU enable
- str r0, [r1, #SCU_CTRL] @ SCU Control Register
- bl setup_init_ram @ RAM area for
temporary stack pointer +
- mov lr, r8 @ restore link
- mov pc, lr @ back to my caller
+ENDPROC(lowlevel_init)
+ENTRY(enable_mmu)
- mrc p15, 0, r0, c2, c0, 2 @ TTBCR (Translation
Table Base Control Register)
- bic r0, r0, #0x37
- orr r0, r0, #0x20 @ disable TTBR1
- mcr p15, 0, r0, c2, c0, 2
- orr r0, r3, #0x8 @ Outer Cacheability
for table walks: WBWA
- mcr p15, 0, r0, c2, c0, 0 @ TTBR0
- mov r0, #0
- mcr p15, 0, r0, c8, c7, 0 @ invalidate TLBs
- mov r0, #-1 @ manager for all
domains (No permission check)
- mcr p15, 0, r0, c3, c0, 0 @ DACR (Domain Access
Control Register) +
- dsb
- isb
* MMU on:
* TLBs was already invalidated in "../start.S"
* So, we don't need to invalidate it here.
Contrl Register)
- orr r0, r0, #(CR_C | CR_M) @ MMU and Dcache
enable
- mov pc, lr
+ENDPROC(enable_mmu)
+#include <asm/arch/ssc-regs.h>
+#define BOOT_RAM_SIZE (SSC_WAY_SIZE) +#define BOOT_WAY_BITS (0x00000100) /* way 8 */
+ENTRY(setup_init_ram)
* Touch to zero for the boot way
+0:
* set SSCOQM, SSCOQAD, SSCOQSZ, SSCOQWN in this order
- ldr r0, = 0x00408006 @ touch to zero with
address range
- ldr r1, = SSCOQM
- str r0, [r1]
- ldr r0, = (CONFIG_SYS_INIT_SP_ADDR -
BOOT_RAM_SIZE) @ base address
- ldr r1, = SSCOQAD
- str r0, [r1]
- ldr r0, = BOOT_RAM_SIZE
- ldr r1, = SSCOQSZ
- str r0, [r1]
- ldr r0, = BOOT_WAY_BITS
- ldr r1, = SSCOQWN
- str r0, [r1]
- ldr r1, = SSCOPPQSEF
- ldr r0, [r1]
- cmp r0, #0 @ check if the
command is successfully set
- bne 0b @ try again if an error
occurres +
- ldr r1, = SSCOLPQS
+1:
- ldr r0, [r1]
- cmp r0, #0x4
- bne 1b @ wait until the
operation is completed
- str r0, [r1] @ clear the complete
notification flag +
- mov pc, lr
+ENDPROC(setup_init_ram) diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile new file mode 100644 index 0000000..b385e19 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o bcu_init.o \
sbc_init.o sg_init.o pll_init.o clkrst_init.o
pinctrl.o +obj-$(CONFIG_SPL_BUILD) += pll_spectrum.o \
- umc_init.o
diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c new file mode 100644 index 0000000..85f37f2 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c @@ -0,0 +1,33 @@ +/*
- Copyright (C) 2011-2014 Panasonic Corporation
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/bcu-regs.h>
+#define ch(x) ((x) >= 32 ? 0 : (x) < 0 ? 0x11111111 : 0x11111111 << (x)) + +void bcu_init(void) +{
- int shift;
- writel(0x44444444, BCSCR0); /* 0x20000000-0x3fffffff: ASM
bus */
- writel(0x11111111, BCSCR2); /* 0x80000000-0x9fffffff:
IPPC/IPPD-bus */
- writel(0x11111111, BCSCR3); /* 0xa0000000-0xbfffffff:
IPPC/IPPD-bus */
- writel(0x11111111, BCSCR4); /* 0xc0000000-0xdfffffff:
IPPC/IPPD-bus */
- writel(0x11111111, BCSCR5); /* 0xe0000000-0Xffffffff:
IPPC/IPPD-bus */ +
- /* Specify DDR channel */
- shift = (CONFIG_SDRAM1_BASE - CONFIG_SDRAM0_BASE) /
0x04000000 * 4;
- writel(ch(shift), BCIPPCCHR2); /* 0x80000000-0x9fffffff */
- shift -= 32;
- writel(ch(shift), BCIPPCCHR3); /* 0xa0000000-0xbfffffff */
- shift -= 32;
- writel(ch(shift), BCIPPCCHR4); /* 0xc0000000-0xdfffffff */
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c new file mode 100644 index 0000000..27d772e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c @@ -0,0 +1,16 @@ +/*
+#include <common.h> +#include <asm/arch/board.h>
+int checkboard(void) +{
- puts("Board: PH1-LD4 Board\n");
- return check_support_card();
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c new file mode 100644 index 0000000..92972e1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c @@ -0,0 +1,42 @@ +/*
+#include <common.h> +#include <asm/arch/led.h> +#include <asm/arch/board.h>
+void bcu_init(void); +void sbc_init(void); +void sg_init(void); +void pll_init(void); +void pin_init(void); +void clkrst_init(void);
+int board_postclk_init(void) +{
- bcu_init();
- sbc_init();
- sg_init();
- pll_init();
- uniphier_board_init();
- led_write(B, 1, , );
- pin_init();
- led_write(B, 2, , );
- clkrst_init();
- led_write(B, 3, , );
Can you remove the blank lines? Ditto in other places where double spacing occurs.
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c new file mode 100644 index 0000000..d359b56 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c @@ -0,0 +1 @@ +#include "../ph1-pro4/boot-mode.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c @@ -0,0 +1,29 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h>
+void clkrst_init(void) +{
- u32 tmp;
- /* deassert reset */
- tmp = readl(SC_RSTCTRL);
- tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1
| SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND;
- writel(tmp, SC_RSTCTRL);
- readl(SC_RSTCTRL); /* dummy read */
- /* privide clocks */
- tmp = readl(SC_CLKCTRL);
- tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO |
SC_CLKCTRL_CLK_UMC
| SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC |
SC_CLKCTRL_CLK_PERI;
- writel(tmp, SC_CLKCTRL);
- readl(SC_CLKCTRL); /* dummy read */
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c new file mode 100644 index 0000000..a742940 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c @@ -0,0 +1,63 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h>
+void pin_init(void) +{
- u32 tmp;
- /* Comment format: PAD Name -> Function Name */
+#ifdef CONFIG_UNIPHIER_SERIAL
- sg_set_pinsel(85, 1); /* HSDOUT3 -> RXD0 */
- sg_set_pinsel(88, 1); /* HDDOUT6 -> TXD0 */
- sg_set_pinsel(69, 23); /* PCIOWR -> TXD1 */
- sg_set_pinsel(70, 23); /* PCIORD -> RXD1 */
- sg_set_pinsel(128, 13); /* XIRQ6 -> TXD2 */
- sg_set_pinsel(129, 13); /* XIRQ7 -> RXD2 */
- sg_set_pinsel(110, 1); /* SBO0 -> TXD3 */
- sg_set_pinsel(111, 1); /* SBI0 -> RXD3 */
+#ifdef CONFIG_NAND_DENALI
- sg_set_pinsel(158, 0); /* XNFRE -> XNFRE_GB */
- sg_set_pinsel(159, 0); /* XNFWE -> XNFWE_GB */
- sg_set_pinsel(160, 0); /* XFALE -> NFALE_GB */
- sg_set_pinsel(161, 0); /* XFCLE -> NFCLE_GB */
- sg_set_pinsel(162, 0); /* XNFWP -> XFNWP_GB */
- sg_set_pinsel(163, 0); /* XNFCE0 -> XNFCE0_GB */
- sg_set_pinsel(164, 0); /* NANDRYBY0 -> NANDRYBY0_GB */
- sg_set_pinsel(22, 0); /* MMCCLK -> XFNCE1_GB */
- sg_set_pinsel(23, 0); /* MMCCMD -> NANDRYBY1_GB */
- sg_set_pinsel(24, 0); /* MMCDAT0 -> NFD0_GB */
- sg_set_pinsel(25, 0); /* MMCDAT1 -> NFD1_GB */
- sg_set_pinsel(26, 0); /* MMCDAT2 -> NFD2_GB */
- sg_set_pinsel(27, 0); /* MMCDAT3 -> NFD3_GB */
- sg_set_pinsel(28, 0); /* MMCDAT4 -> NFD4_GB */
- sg_set_pinsel(29, 0); /* MMCDAT5 -> NFD5_GB */
- sg_set_pinsel(30, 0); /* MMCDAT6 -> NFD6_GB */
- sg_set_pinsel(31, 0); /* MMCDAT7 -> NFD7_GB */
+#ifdef CONFIG_USB_EHCI_UNIPHIER
- sg_set_pinsel(53, 0); /* USB0VBUS -> USB0VBUS */
- sg_set_pinsel(54, 0); /* USB0OD -> USB0OD */
- sg_set_pinsel(55, 0); /* USB1VBUS -> USB1VBUS */
- sg_set_pinsel(56, 0); /* USB1OD -> USB1OD */
- /* sg_set_pinsel(67, 23); */ /* PCOE -> USB2VBUS */
- /* sg_set_pinsel(68, 23); */ /* PCWAIT -> USB2OD */
- tmp = readl(SG_IECTRL);
- tmp |= 0x41;
- writel(tmp, SG_IECTRL);
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c new file mode 100644 index 0000000..68b9d5f --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c @@ -0,0 +1,189 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/sg-regs.h>
+#undef DPLL_SSC_RATE_1PER
+void dpll_init(void) +{
- u32 tmp;
* Set Frequency
* Set 0xc(1600MHz)/0xd(1333MHz)/0xe(1066MHz)
* to FOUT (DPLLCTRL.bit[29:20])
- tmp = readl(SC_DPLLCTRL);
- tmp &= ~0x000f0000;
+#if CONFIG_DDR_FREQ == 1600
- tmp |= 0x000c0000;
+#elif CONFIG_DDR_FREQ == 1333
- tmp |= 0x000d0000;
+#else +# error "Unknown frequency" +#endif
+#if defined(DPLL_SSC_RATE_1PER)
- tmp &= ~SC_DPLLCTRL_SSC_RATE;
+#else
- tmp |= SC_DPLLCTRL_SSC_RATE;
- writel(tmp, SC_DPLLCTRL);
- tmp = readl(SC_DPLLCTRL2);
- tmp |= SC_DPLLCTRL2_NRSTDS;
- writel(tmp, SC_DPLLCTRL2);
+void upll_init(void) +{
- u32 tmp, clk_mode_upll, clk_mode_axosel;
- tmp = readl(SG_PINMON0);
- clk_mode_upll = tmp & SG_PINMON0_CLK_MODE_UPLLSRC_MASK;
- clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK;
- /* set 0 to SNRT(UPLLCTRL.bit28) and K_LD(UPLLCTRL.bit[27])
- tmp = readl(SC_UPLLCTRL);
- tmp &= ~0x18000000;
- writel(tmp, SC_UPLLCTRL);
- if (clk_mode_upll == SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT) {
if (clk_mode_axosel ==
SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U ||
clk_mode_axosel ==
SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) {
/* AXO: 25MHz */
tmp &= ~0x07ffffff;
tmp |= 0x0228f5c0;
} else {
/* AXO: default 24.576MHz */
tmp &= ~0x07ffffff;
tmp |= 0x02328000;
- /* set 1 to K_LD(UPLLCTRL.bit[27]) */
- tmp |= 0x08000000;
- /* wait 10 usec */
- udelay(10);
- /* set 1 to SNRT(UPLLCTRL.bit[28]) */
- tmp |= 0x10000000;
+void vpll_init(void) +{
- u32 tmp, clk_mode_axosel;
- /* set 1 to VPLA27WP and VPLA27WP */
- tmp = readl(SC_VPLL27ACTRL);
- tmp |= 0x00000001;
- writel(tmp, SC_VPLL27ACTRL);
- tmp = readl(SC_VPLL27BCTRL);
- writel(tmp, SC_VPLL27BCTRL);
- /* Set 0 to VPLA_K_LD and VPLB_K_LD */
- tmp = readl(SC_VPLL27ACTRL3);
- tmp &= ~0x10000000;
- writel(tmp, SC_VPLL27ACTRL3);
- tmp = readl(SC_VPLL27BCTRL3);
- writel(tmp, SC_VPLL27BCTRL3);
- /* Set 0 to VPLA_SNRST and VPLB_SNRST */
- tmp = readl(SC_VPLL27ACTRL2);
- writel(tmp, SC_VPLL27ACTRL2);
- tmp = readl(SC_VPLL27BCTRL2);
- writel(tmp, SC_VPLL27BCTRL2);
- /* Set 0x20 to VPLA_SNRST and VPLB_SNRST */
- tmp &= ~0x0000007f;
- tmp |= 0x00000020;
- if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U
clk_mode_axosel ==
/* AXO: 25MHz */
tmp &= ~0x000fffff;
tmp |= 0x00066664;
tmp &= ~0x000fffff;
tmp |= 0x00066664;
- } else {
tmp &= ~0x000fffff;
tmp |= 0x000f5800;
tmp &= ~0x000fffff;
tmp |= 0x000f5800;
- /* Set 1 to VPLA_K_LD and VPLB_K_LD */
- udelay(10);
- /* set 0 to VPLA27WP and VPLA27WP */
- tmp &= ~0x00000001;
- tmp |= ~0x00000001;
+void pll_init(void) +{
- dpll_init();
- upll_init();
- vpll_init();
* Wait 500 usec until dpll get stable
* We wait 10 usec in upll_init() and vpll_init()
* so 20 usec can be saved here.
- udelay(480);
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c new file mode 100644 index 0000000..837b2a8 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c @@ -0,0 +1 @@ +#include "../ph1-pro4/pll_spectrum.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c new file mode 100644 index 0000000..a37ed16 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c @@ -0,0 +1,44 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/sbc-regs.h> +#include <asm/arch/sg-regs.h>
+void sbc_init(void) +{
- /* XECS1: sub/boot memory (boot swap = off/on) */
- writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10);
- writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11);
- writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12);
- writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14);
+#if !defined(CONFIG_SPL_BUILD)
- /* XECS0: boot/sub memory (boot swap = off/on) */
- writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00);
- writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01);
- writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02);
- writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04);
- /* XECS3: peripherals */
- writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30);
- writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31);
- writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32);
- writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34);
- /* base address regsiters */
- writel(0x0000bc01, SBBASE0);
- writel(0x0400bc01, SBBASE1);
- writel(0x0800bf01, SBBASE3);
- /* enable access to sub memory when boot swap is on */
- sg_set_pinsel(155, 1); /* PORT24 -> XECS0 */
- sg_set_pinsel(156, 1); /* PORT25 -> XECS3 */
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c new file mode 100644 index 0000000..8200959 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c @@ -0,0 +1,28 @@ +/*
+void sg_init(void) +{
- u32 tmp;
- /* Set DDR size */
- tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE,
CONFIG_DDR_NUM_CH0);
- tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE,
CONFIG_DDR_NUM_CH1); +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE
- tmp |= SG_MEMCONF_SPARSEMEM;
- writel(tmp, SG_MEMCONF);
- /* Must enable in-port before deasserting reset signals of
cores */
- tmp |= 0x1;
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c new file mode 100644 index 0000000..e0e586b --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c @@ -0,0 +1,10 @@ +/*
+int umc_init(void) +{
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile new file mode 100644 index 0000000..712afd1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o sbc_init.o \
- umc_init.o
diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c new file mode 100644 index 0000000..325a4f6 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c @@ -0,0 +1,16 @@ +/*
- puts("Board: PH1-Pro4 Board\n");
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c new file mode 100644 index 0000000..e261513 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c @@ -0,0 +1,39 @@ +/*
- sbc_init();
- sg_init();
- pll_init();
- pin_init();
- clkrst_init();
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c new file mode 100644 index 0000000..33bccff --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c @@ -0,0 +1,66 @@ +/*
- Copyright (C) 2014 Panasonic Corporation
+#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/boot-device.h> +#include <asm/arch/sg-regs.h> +#include <asm/arch/sbc-regs.h>
+struct boot_device_info boot_device_table[] = {
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 128KB,
Addr 4)"},
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 128KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 256KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 256KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 512KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 512KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 24, EraseSize 1MB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 4, ECC 24, EraseSize 1MB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 128KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 128KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 256KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 256KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 512KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 512KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 24, EraseSize 512KB,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, ONFI,
Addr 4)"},
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, ONFI,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 24, ONFI,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 4, ECC 24, ONFI,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, ONFI,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, ONFI,
Addr 5)"},
- {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 24, ONFI,
Addr 5)"},
- {BOOT_DEVICE_MMC1, "eMMC Boot (3.3V)"},
- {BOOT_DEVICE_MMC1, "eMMC Boot (1.8V)"},
- {BOOT_DEVICE_NONE, "Reserved"},
- {BOOT_DEVICE_NONE, ""}
+u32 get_boot_mode_sel(void) +{
- return (readl(SG_PINMON0) >> 1) & 0x1f;
+u32 spl_boot_device(void) +{
- u32 boot_mode;
- if (boot_is_swapped())
return BOOT_DEVICE_NOR;
- boot_mode = get_boot_mode_sel();
- return boot_device_table[boot_mode].type;
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c @@ -0,0 +1,29 @@ +/*
- u32 tmp;
SC_CLKCTRL_CLK_UMC
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c new file mode 100644 index 0000000..503c247 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c @@ -0,0 +1,45 @@ +/*
- sg_set_pinsel(127, 0); /* RXD0 -> RXD0 */
- sg_set_pinsel(128, 0); /* TXD0 -> TXD0 */
- sg_set_pinsel(129, 0); /* RXD1 -> RXD1 */
- sg_set_pinsel(130, 0); /* TXD1 -> TXD1 */
- sg_set_pinsel(131, 0); /* RXD2 -> RXD2 */
- sg_set_pinsel(132, 0); /* TXD2 -> TXD2 */
- sg_set_pinsel(88, 2); /* CH6CLK -> RXD3 */
- sg_set_pinsel(89, 2); /* CH6VAL -> TXD3 */
- sg_set_pinsel(40, 0); /* NFD0 -> NFD0 */
- sg_set_pinsel(41, 0); /* NFD1 -> NFD1 */
- sg_set_pinsel(42, 0); /* NFD2 -> NFD2 */
- sg_set_pinsel(43, 0); /* NFD3 -> NFD3 */
- sg_set_pinsel(44, 0); /* NFD4 -> NFD4 */
- sg_set_pinsel(45, 0); /* NFD5 -> NFD5 */
- sg_set_pinsel(46, 0); /* NFD6 -> NFD6 */
- sg_set_pinsel(47, 0); /* NFD7 -> NFD7 */
- sg_set_pinsel(48, 0); /* NFALE -> NFALE */
- sg_set_pinsel(49, 0); /* NFCLE -> NFCLE */
- sg_set_pinsel(50, 0); /* XNFRE -> XNFRE */
- sg_set_pinsel(51, 0); /* XNFWE -> XNFWE */
- sg_set_pinsel(52, 0); /* XNFWP -> XNFWP */
- sg_set_pinsel(53, 0); /* XNFCE0 -> XNFCE0 */
- sg_set_pinsel(54, 0); /* NRYBY0 -> NRYBY0 */
- writel(1, SG_LOADPINCTRL);
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c new file mode 100644 index 0000000..fd08438 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c @@ -0,0 +1,168 @@ +/*
- u32 tmp;
* Set Frequency
* to FOUT ( DPLLCTRL.bit[29:20] )
- tmp &= ~(0x000f0000);
+#else +# error "Unsupported frequency" +#endif
* Set Moduration rate
* Set 0x0(1%)/0x1(2%) to SSC_RATE(DPLLCTRL.bit[15])
- tmp &= ~0x00008000;
+#else
- tmp |= 0x00008000;
+void stop_mpll(void) +{
- u32 tmp;
- tmp = readl(SC_MPLLOSCCTL);
- if (!(tmp & SC_MPLLOSCCTL_MPLLST))
return; /* already stopped */
- tmp &= ~SC_MPLLOSCCTL_MPLLEN;
- writel(tmp, SC_MPLLOSCCTL);
- while (readl(SC_MPLLOSCCTL) & SC_MPLLOSCCTL_MPLLST)
- /* Set VPLL27A & VPLL27B */
+#if defined(CONFIG_PH1_PRO4)
- /* 25MHz or 6.25MHz is default for Pro4R, no need to set
VPLLA/B */
- if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ ||
clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ)
return;
- /* Disable write protect of VPLL27ACTRL[2-7]*,
VPLL27BCTRL[2-8] */
- /* Unset VPLA_K_LD and VPLB_K_LD bit */
- /* Set VPLA_M and VPLB_M to 0x20 */
clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ) {
/* Set VPLA_K and VPLB_K for AXO: 25MHz */
tmp &= ~0x000fffff;
tmp |= 0x00066666;
tmp &= ~0x000fffff;
tmp |= 0x00066666;
- } else {
/* Set VPLA_K and VPLB_K for AXO: 24.576 MHz */
tmp &= ~0x000fffff;
tmp |= 0x000f5800;
tmp &= ~0x000fffff;
tmp |= 0x000f5800;
- /* wait 1 usec */
- udelay(1);
- /* Set VPLA_K_LD and VPLB_K_LD to load K parameters */
- /* Unset VPLA_SNRST and VPLB_SNRST bit */
- /* Enable write protect of VPLL27ACTRL[2-7]*,
VPLL27BCTRL[2-8] */
- dpll_init();
- stop_mpll();
- vpll_init();
* We wait 1 usec in vpll_init() so 1 usec can be saved here.
- udelay(499);
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c new file mode 100644 index 0000000..4538d1a --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c @@ -0,0 +1,18 @@ +/*
+void enable_dpll_ssc(void) +{
- u32 tmp;
- tmp |= SC_DPLLCTRL_SSC_EN;
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c new file mode 100644 index 0000000..f113db5 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c @@ -0,0 +1,75 @@ +/*
+void sbc_init(void) +{ +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD)
* Only CS1 is connected to support card.
* BKSZ[1:0] should be set to "01".
- writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL10);
- writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL11);
- writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL12);
- writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL14);
- if (readl(SBBASE0) & 0x1) {
* Boot Swap Off: boot from mask ROM
* 0x00000000-0x01ffffff: mask ROM
* 0x02000000-0x3effffff: memory bank (31MB)
* 0x03f00000-0x3fffffff: peripherals (1MB)
writel(0x0000be01, SBBASE0); /* dummy */
writel(0x0200be01, SBBASE1);
- } else {
* Boot Swap On: boot from external NOR/SRAM
* 0x02000000-0x03ffffff is a mirror of
0x00000000-0x01ffffff.
* 0x00000000-0x01efffff, 0x02000000-0x03efffff:
memory bank
* 0x01f00000-0x01ffffff, 0x03f00000-0x03ffffff:
peripherals
+#elif defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +#if !defined(CONFIG_SPL_BUILD)
- writel(0x0000bc01, SBBASE0); /* boot memory */
- writel(0x0400bc01, SBBASE1); /* sub memory */
- writel(0x0800bf01, SBBASE3); /* peripherals */
- sg_set_pinsel(318, 5); /* PORT22 -> XECS0 */
- sg_set_pinsel(313, 5); /* PORT15 -> XECS3 */
- writel(0x00000001, SG_LOADPINCTRL);
+#endif /* CONFIG_XXX_MICRO_SUPPORT_CARD */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c new file mode 100644 index 0000000..8200959 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c @@ -0,0 +1,28 @@ +/*
- u32 tmp;
cores */
- tmp |= 0x1;
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c new file mode 100644 index 0000000..e0e586b --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c @@ -0,0 +1,10 @@ +/*
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile new file mode 100644 index 0000000..b385e19 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +#
- umc_init.o
diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c new file mode 100644 index 0000000..69b172e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/bcu_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c new file mode 100644 index 0000000..15dc289 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c @@ -0,0 +1,16 @@ +/*
- puts("Board: PH1-sLD8 Board\n");
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c new file mode 100644 index 0000000..287b33c --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/board_postclk_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c new file mode 100644 index 0000000..d359b56 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c @@ -0,0 +1 @@ +#include "../ph1-pro4/boot-mode.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c @@ -0,0 +1,29 @@ +/*
- u32 tmp;
SC_CLKCTRL_CLK_UMC
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c new file mode 100644 index 0000000..2b6403f --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c @@ -0,0 +1,57 @@ +/*
- sg_set_pinsel(70, 3); /* HDDOUT0 -> TXD0 */
- sg_set_pinsel(71, 3); /* HSDOUT1 -> RXD0 */
- sg_set_pinsel(114, 0); /* TXD1 -> TXD1 */
- sg_set_pinsel(115, 0); /* RXD1 -> RXD1 */
- sg_set_pinsel(112, 1); /* SBO1 -> TXD2 */
- sg_set_pinsel(113, 1); /* SBI1 -> RXD2 */
- sg_set_pinsel(15, 0); /* XNFRE_GB -> XNFRE_GB */
- sg_set_pinsel(16, 0); /* XNFWE_GB -> XNFWE_GB */
- sg_set_pinsel(17, 0); /* XFALE_GB -> NFALE_GB */
- sg_set_pinsel(18, 0); /* XFCLE_GB -> NFCLE_GB */
- sg_set_pinsel(19, 0); /* XNFWP_GB -> XFNWP_GB */
- sg_set_pinsel(20, 0); /* XNFCE0_GB -> XNFCE0_GB */
- sg_set_pinsel(21, 0); /* NANDRYBY0_GB -> NANDRYBY0_GB
- sg_set_pinsel(22, 0); /* XFNCE1_GB -> XFNCE1_GB */
- sg_set_pinsel(23, 0); /* NANDRYBY1_GB ->
NANDRYBY1_GB */
- sg_set_pinsel(24, 0); /* NFD0_GB -> NFD0_GB */
- sg_set_pinsel(25, 0); /* NFD1_GB -> NFD1_GB */
- sg_set_pinsel(26, 0); /* NFD2_GB -> NFD2_GB */
- sg_set_pinsel(27, 0); /* NFD3_GB -> NFD3_GB */
- sg_set_pinsel(28, 0); /* NFD4_GB -> NFD4_GB */
- sg_set_pinsel(29, 0); /* NFD5_GB -> NFD5_GB */
- sg_set_pinsel(30, 0); /* NFD6_GB -> NFD6_GB */
- sg_set_pinsel(31, 0); /* NFD7_GB -> NFD7_GB */
- sg_set_pinsel(41, 0); /* USB0VBUS -> USB0VBUS */
- sg_set_pinsel(42, 0); /* USB0OD -> USB0OD */
- sg_set_pinsel(43, 0); /* USB1VBUS -> USB1VBUS */
- sg_set_pinsel(44, 0); /* USB1OD -> USB1OD */
- /* sg_set_pinsel(114, 4); */ /* TXD1 -> USB2VBUS (shared
with UART) */
- /* sg_set_pinsel(115, 4); */ /* RXD1 -> USB2OD */
+#endif +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c new file mode 100644 index 0000000..76c5116 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c @@ -0,0 +1,201 @@ +/*
- u32 tmp;
* Set DPLL SSC parameters for DPLLCTRL3
* [23] DIVN_TEST 1'b1
* [22:16] DIVN 7'h50
* [10] FREFSEL_TEST 1'b1
* [9:8] FREFSEL 2'h2
* [4] ICPD_TEST 1'b1
* [3:0] ICPD 4'hB
- tmp = readl(SC_DPLLCTRL3);
- tmp &= ~0x00ff0717;
- tmp |= 0x00d0061b;
- writel(tmp, SC_DPLLCTRL3);
* Set DPLL SSC parameters for DPLLCTRL - SSC
* <-1%> <-2%>
* [29:20] SSC_UPCNT 10'd132 (0x084) 10'd132 (0x084)
* [14:0] SSC_dK 15'd6335(0x18bf) 15'd12710(0x31a6)
- tmp &= ~0x3ff07fff;
+#if defined(CONFIG_DPLL_SSC_RATE_1PER)
- tmp |= 0x084018bf;
+#else
- tmp |= 0x084031a6;
+#endif /* defined(CONFIG_DPLL_SSC_RATE_1PER) */
* Set DPLL SSC parameters for DPLLCTRL2
* [31:29] SSC_STEP 3' d0 (0x0)
* [27] SSC_REG_REF 1' b1 (0x1)
* [26:20] SSC_M 7' d79 (0x4f)
* [19:0] SSC_K 20'd964689(0xeb851)
- tmp &= ~0xefffffff;
- tmp |= 0x0cfeb851;
clk_mode_axosel ==
/* AXO: 25MHz */
tmp &= ~0x07ffffff;
tmp |= 0x0228f5c0;
} else {
tmp &= ~0x07ffffff;
tmp |= 0x02328000;
- udelay(10);
clk_mode_axosel ==
/* AXO: 25MHz */
tmp &= ~0x000fffff;
tmp |= 0x00066664;
tmp &= ~0x000fffff;
tmp |= 0x00066664;
- } else {
tmp &= ~0x000fffff;
tmp |= 0x000f5800;
tmp &= ~0x000fffff;
tmp |= 0x000f5800;
- udelay(10);
- dpll_init();
- upll_init();
- vpll_init();
- udelay(480);
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c new file mode 100644 index 0000000..9b8c485 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c @@ -0,0 +1 @@ +#include "../ph1-ld4/pll_spectrum.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c new file mode 100644 index 0000000..af44dee --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c @@ -0,0 +1,51 @@ +/*
+void sbc_init(void) +{ +#if !defined(CONFIG_SPL_BUILD)
- /* XECS0 : dummy */
- /* XECS1 : boot memory (always boot swap = on) */
- /* XECS4 : sub memory */
- writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL40);
- writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL41);
- writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL42);
- writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL44);
- /* XECS5 : peripherals */
- writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL50);
- writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL51);
- writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL52);
- writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL54);
- writel(0x0900bfff, SBBASE1); /* dummy */
- writel(0x0400bc01, SBBASE4); /* sub memory */
- writel(0x0800bf01, SBBASE5); /* peripherals */
- sg_set_pinsel(134, 16); /* XIRQ6 -> XECS4 */
- sg_set_pinsel(135, 16); /* XIRQ7 -> XECS5 */
- /* dummy read to assure write process */
- readl(SG_PINCTRL(33));
+} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c new file mode 100644 index 0000000..a808289 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/sg_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c new file mode 100644 index 0000000..e0e586b --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c @@ -0,0 +1,10 @@ +/*
+} diff --git a/arch/arm/cpu/armv7/uniphier/reset.c b/arch/arm/cpu/armv7/uniphier/reset.c new file mode 100644 index 0000000..b0dc967 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/reset.c @@ -0,0 +1,29 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/board.h>
+void reset_cpu(unsigned long ignored) +{
- u32 tmp;
- uniphier_board_reset();
- writel(5, SC_IRQTIMSET); /* default value */
- tmp = readl(SC_SLFRSTSEL);
- tmp &= ~0x3; /* mask [1:0] */
- tmp |= 0x0; /* XRST reboot */
- writel(tmp, SC_SLFRSTSEL);
- tmp = readl(SC_SLFRSTCTL);
- tmp |= 0x1;
- writel(tmp, SC_SLFRSTCTL);
+} diff --git a/arch/arm/cpu/armv7/uniphier/smp.S b/arch/arm/cpu/armv7/uniphier/smp.S new file mode 100644 index 0000000..25ba981 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/smp.S @@ -0,0 +1,54 @@ +/*
- Copyright (C) 2013 Panasonic Corporation
+#include <config.h> +#include <linux/linkage.h> +#include <asm/system.h> +#include <asm/arch/led.h> +#include <asm/arch/sbc-regs.h>
+/* Entry point of U-Boot main program for the secondary CPU */ +LENTRY(secondary_entry)
Contrl Register)
- bic r0, r0, #(CR_C | CR_M) @ MMU and Dcache
disable
- mcr p15, 0, r0, c7, c5, 0 @ invalidate icache
- dsb
- led_write(C,0,,)
- mov r0, #0
- str r0, [r1]
+0: wfe
- ldr r4, [r1] @ r4: entry point for
secondary CPUs
- cmp r4, #0
- beq 0b
- led_write(C, P, U, 1)
- bx r4 @ secondary CPUs jump to
linux +ENDPROC(secondary_entry)
+ENTRY(wakeup_secondary)
+0: ldr r0, [r1]
- cmp r0, #0
- bne 0b
- /* set entry address and send event to the secondary CPU */
- ldr r0, =secondary_entry
- str r0, [r1]
- ldr r0, [r1] @ make sure store is complete
- mov r0, #0x100
+0: subs r0, r0, #1 @ I don't know the reason, but without this wait
- bne 0b @ fails to wake up the
secondary CPU
- sev
- /* wait until the secondary CPU reach to secondary_entry */
+0: ldr r0, [r1]
- cmp r0, #0
- bne 0b
- bx lr
+ENDPROC(wakeup_secondary) diff --git a/arch/arm/cpu/armv7/uniphier/spl.c b/arch/arm/cpu/armv7/uniphier/spl.c new file mode 100644 index 0000000..40d28ad --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/spl.c @@ -0,0 +1,17 @@ +/*
- Copyright (C) 2013-2014 Panasonic Corporation
+void spl_board_init(void) +{ +#if defined(CONFIG_BOARD_POSTCLK_INIT)
- board_postclk_init();
- dram_init();
+} diff --git a/arch/arm/cpu/armv7/uniphier/support_card.c b/arch/arm/cpu/armv7/uniphier/support_card.c new file mode 100644 index 0000000..40d4940 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/support_card.c @@ -0,0 +1,180 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/board.h>
+#define PFC_MICRO_SUPPORT_CARD_RESET \
((CONFIG_SUPPORT_CARD_BASE) +
0x000D0034) +#define PFC_MICRO_SUPPORT_CARD_REVISION \
0x000D00E0) +/*
- 0: reset deassert, 1: reset
- bit[0]: LAN, I2C, LED
- bit[1]: UART
+void support_card_reset_deassert(void) +{
- writel(0, PFC_MICRO_SUPPORT_CARD_RESET);
+void support_card_reset(void) +{
- writel(3, PFC_MICRO_SUPPORT_CARD_RESET);
+static int support_card_show_revision(void) +{
- u32 revision;
- revision = readl(PFC_MICRO_SUPPORT_CARD_REVISION);
- printf("(PFC CPLD version %d.%d)\n", revision >> 4, revision
& 0xf);
+} +#endif
+#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD)
+#define DCC_MICRO_SUPPORT_CARD_RESET_LAN \
0x00401300) +#define DCC_MICRO_SUPPORT_CARD_RESET_UART \
0x00401304) +#define DCC_MICRO_SUPPORT_CARD_RESET_I2C \
0x00401308) +#define DCC_MICRO_SUPPORT_CARD_REVISION \
0x005000E0) + +void support_card_reset_deassert(void) +{
- writel(1, DCC_MICRO_SUPPORT_CARD_RESET_LAN); /* LAN and LED
- writel(1, DCC_MICRO_SUPPORT_CARD_RESET_UART); /* UART */
- writel(1, DCC_MICRO_SUPPORT_CARD_RESET_I2C); /* I2C */
- writel(0, DCC_MICRO_SUPPORT_CARD_RESET_LAN); /* LAN and LED
- writel(0, DCC_MICRO_SUPPORT_CARD_RESET_UART); /* UART */
- writel(0, DCC_MICRO_SUPPORT_CARD_RESET_I2C); /* I2C */
- u32 revision;
- revision = readl(DCC_MICRO_SUPPORT_CARD_REVISION);
- if (revision >= 0x67) {
printf("(DCC CPLD version 3.%d.%d)\n",
revision >> 4, revision & 0xf);
- } else {
printf("(DCC CPLD unknown version)\n");
return -1;
+} +#endif
+void support_card_init(void) +{
* After power on, we need to keep the LAN controller in
reset state
* for a while. (200 usec)
* Fortunatelly, enough wait time is already inserted in
pll_init()
* function. So we do not have to wait here.
- support_card_reset_deassert();
+int check_support_card(void) +{
- printf("SC: Micro Support Card ");
- return support_card_show_revision();
+#if defined(CONFIG_SMC911X) +#include <netdev.h>
+int board_eth_init(bd_t *bis) +{
- return smc911x_initialize(0, CONFIG_SMC911X_BASE);
+} +#endif
+#if !defined(CONFIG_SYS_NO_FLASH)
+#include <mtd/cfi_flash.h>
+#if CONFIG_SYS_MAX_FLASH_BANKS > 1 +static phys_addr_t flash_banks_list[CONFIG_SYS_MAX_FLASH_BANKS] =
CONFIG_SYS_FLASH_BANKS_LIST;
+phys_addr_t cfi_flash_bank_addr(int i) +{
- return flash_banks_list[i];
+} +#endif
+int mem_is_flash(phys_addr_t base) +{
- const int loop = 128;
- u32 *scratch_addr;
- u32 saved_value;
- int ret = 1;
- int i;
- scratch_addr = map_physmem(base + 0x01e00000,
sizeof(u32) * loop,
MAP_NOCACHE); +
- for (i = 0; i < loop; i++, scratch_addr++) {
saved_value = readl(scratch_addr);
writel(~saved_value, scratch_addr);
if (readl(scratch_addr) != saved_value) {
/* We assume no memory or SRAM here. */
writel(saved_value, scratch_addr);
ret = 0;
break;
- unmap_physmem(scratch_addr, MAP_NOCACHE);
- return ret;
+int board_flash_wp_on(void) +{
- int i;
- int ret = 1;
- for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) {
if (mem_is_flash(cfi_flash_bank_addr(i))) {
* We found at least one flash.
* We need to return 0 and call flash_init().
ret = 0;
else {
* We might have a SRAM here.
* To prevent SRAM data from being destroyed,
* we set dummy address (SDRAM).
flash_banks_list[i] = 0x80000000 + 0x10000 *
i;
- return ret;
+} +#endif diff --git a/arch/arm/cpu/armv7/uniphier/timer.c b/arch/arm/cpu/armv7/uniphier/timer.c new file mode 100644 index 0000000..6edc084 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/timer.c @@ -0,0 +1,39 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/arm-mpcore.h>
+#define PERIPHCLK (50 * 1000 * 1000) /* 50 MHz */ +#define PRESCALER ((PERIPHCLK) / (CONFIG_SYS_TIMER_RATE) - 1)
+static void *get_global_timer_base(void) +{
- void *val;
- asm("mrc p15, 4, %0, c15, c0, 0" : "=r" (val) : : "memory");
- return val + GLOBAL_TIMER_OFFSET;
+unsigned long timer_read_counter(void) +{
* ARM 64bit Global Timer is too much for our purpose.
* We use only lower 32 bit of the timer counter.
- return readl(get_global_timer_base() + GTIMER_CNT_L);
+int timer_init(void) +{
- /* enable timer */
- writel(PRESCALER << 8 | 1, get_global_timer_base() +
GTIMER_CTRL); +
+} diff --git a/arch/arm/include/asm/arch-uniphier/arm-mpcore.h b/arch/arm/include/asm/arch-uniphier/arm-mpcore.h new file mode 100644 index 0000000..cf7cd46 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/arm-mpcore.h @@ -0,0 +1,46 @@ +/*
+#ifndef ARCH_ARM_MPCORE_H +#define ARCH_ARM_MPCORE_H
+/* Snoop Control Unit */ +#define SCU_OFFSET 0x00
+/* SCU Control Register */ +#define SCU_CTRL 0x00 +/* SCU Configuration Register */ +#define SCU_CONF 0x04 +/* SCU CPU Power Status Register */ +#define SCU_PWR_STATUS 0x08 +/* SCU Invalidate All Registers in Secure State */ +#define SCU_INV_ALL 0x0C +/* SCU Filtering Start Address Register */ +#define SCU_FILTER_START 0x40 +/* SCU Filtering End Address Register */ +#define SCU_FILTER_END 0x44 +/* SCU Access Control Register */ +#define SCU_SAC 0x50 +/* SCU Non-secure Access Control Register */ +#define SCU_SNSAC 0x54
+/* Global Timer */ +#define GLOBAL_TIMER_OFFSET 0x200
+/* Global Timer Counter Registers */ +#define GTIMER_CNT_L 0x00 +#define GTIMER_CNT_H 0x04 +/* Global Timer Control Register */ +#define GTIMER_CTRL 0x08 +/* Global Timer Interrupt Status Register */ +#define GTIMER_STAT 0x0C +/* Comparator Value Registers */ +#define GTIMER_CMP_L 0x10 +#define GTIMER_CMP_H 0x14 +/* Auto-increment Register */ +#define GTIMER_INC 0x18
+#endif /* ARCH_ARM_MPCORE_H */ diff --git a/arch/arm/include/asm/arch-uniphier/bcu-regs.h b/arch/arm/include/asm/arch-uniphier/bcu-regs.h new file mode 100644 index 0000000..5501b36 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/bcu-regs.h @@ -0,0 +1,29 @@ +/*
+#ifndef ARCH_BCU_REGS_H +#define ARCH_BCU_REGS_H
+/* Bus Control Unit registers */ +#define BCU_BASE 0x50080000
+#define BCSCR(x) (BCU_BASE + 0x180 + (x) * 4) +#define BCSCR0 (BCSCR(0)) +#define BCSCR1 (BCSCR(1)) +#define BCSCR2 (BCSCR(2)) +#define BCSCR3 (BCSCR(3)) +#define BCSCR4 (BCSCR(4)) +#define BCSCR5 (BCSCR(5))
+#define BCIPPCCHR(x) (BCU_BASE + 0x0280 + (x)
- +#define BCIPPCCHR0 (BCIPPCCHR(0))
+#define BCIPPCCHR1 (BCIPPCCHR(1)) +#define BCIPPCCHR2 (BCIPPCCHR(2)) +#define BCIPPCCHR3 (BCIPPCCHR(3)) +#define BCIPPCCHR4 (BCIPPCCHR(4)) +#define BCIPPCCHR5 (BCIPPCCHR(5))
+#endif /* ARCH_BCU_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/board.h b/arch/arm/include/asm/arch-uniphier/board.h new file mode 100644 index 0000000..e6ba4e4 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/board.h @@ -0,0 +1,35 @@ +/*
+#ifndef ARCH_BOARD_H +#define ARCH_BOARD_H
+#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) || \
- defined(CONFIG_DCC_MICRO_SUPPORT_CARD)
+void support_card_reset(void); +void support_card_init(void); +int check_support_card(void); +#else +#define support_card_reset() do {} while (0) +#define support_card_init() do {} while (0) +static inline int check_support_card(void) +{
+} +#endif
+static inline void uniphier_board_reset(void) +{
- support_card_reset();
+static inline void uniphier_board_init(void) +{
- support_card_init();
+#endif /* ARCH_BOARD_H */ diff --git a/arch/arm/include/asm/arch-uniphier/boot-device.h b/arch/arm/include/asm/arch-uniphier/boot-device.h new file mode 100644 index 0000000..6987f57 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/boot-device.h @@ -0,0 +1,20 @@ +/*
+#ifndef _ASM_BOOT_DEVICE_H_ +#define _ASM_BOOT_DEVICE_H_
+u32 get_boot_mode_sel(void);
+struct boot_device_info {
- u32 type;
- char *info;
+extern struct boot_device_info boot_device_table[];
+#endif /* _ASM_BOOT_DEVICE_H_ */ diff --git a/arch/arm/include/asm/arch-uniphier/led.h b/arch/arm/include/asm/arch-uniphier/led.h new file mode 100644 index 0000000..21277da --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/led.h @@ -0,0 +1,101 @@ +/*
+#ifndef ARCH_LED_H +#define ARCH_LED_H
+#define LED_CHAR_0 0x7e +#define LED_CHAR_1 0x0c +#define LED_CHAR_2 0xb6 +#define LED_CHAR_3 0x9e +#define LED_CHAR_4 0xcc +#define LED_CHAR_5 0xda +#define LED_CHAR_6 0xfa +#define LED_CHAR_7 0x4e +#define LED_CHAR_8 0xfe +#define LED_CHAR_9 0xde
+#define LED_CHAR_A 0xee +#define LED_CHAR_B 0xf8 +#define LED_CHAR_C 0x72 +#define LED_CHAR_D 0xbc +#define LED_CHAR_E 0xf2 +#define LED_CHAR_F 0xe2 +#define LED_CHAR_G 0x7a +#define LED_CHAR_H 0xe8 +#define LED_CHAR_I 0x08 +#define LED_CHAR_J 0x3c +#define LED_CHAR_K 0xea +#define LED_CHAR_L 0x70 +#define LED_CHAR_M 0x6e +#define LED_CHAR_N 0xa8 +#define LED_CHAR_O 0xb8 +#define LED_CHAR_P 0xe6 +#define LED_CHAR_Q 0xce +#define LED_CHAR_R 0xa0 +#define LED_CHAR_S 0xc8 +#define LED_CHAR_T 0x8c +#define LED_CHAR_U 0x7c +#define LED_CHAR_V 0x54 +#define LED_CHAR_W 0xfc +#define LED_CHAR_X 0xec +#define LED_CHAR_Y 0xdc +#define LED_CHAR_Z 0xa4
+#define LED_CHAR_SPACE 0x00 +#define LED_CHAR_DOT 0x01
+#define LED_CHAR_ (LED_CHAR_SPACE)
+/** Macro to translate 4 characters into integer to display led */ +#define LED_C2I(C0, C1, C2, C3) \
(LED_CHAR_##C0 << 24) | \
(LED_CHAR_##C1 << 16) | \
(LED_CHAR_##C2 << 8) | \
(LED_CHAR_##C3) \
+#if defined(CONFIG_SUPPORT_CARD_LED_BASE)
+#define LED_ADDR CONFIG_SUPPORT_CARD_LED_BASE
+#ifdef __ASSEMBLY__
+#define led_write(C0, C1, C2, C3) raw_led_write LED_C2I(C0, C1, C2, C3) +.macro raw_led_write data
- ldr r0, =\data
- ldr r1, =LED_ADDR
- str r0, [r1]
+.endm
+#else /* __ASSEMBLY__ */
+#define led_write(C0, C1, C2, C3) \ +do { \
- raw_led_write(LED_C2I(C0, C1, C2, C3)); \
+} while (0)
+static inline void raw_led_write(u32 data) +{
- writel(data, LED_ADDR);
+#endif /* __ASSEMBLY__ */
+#else /* CONFIG_SUPPORT_CARD_LED_BASE */
+#define led_write(C0, C1, C2, C3) +#define raw_led_write(x)
+#endif /* CONFIG_SUPPORT_CARD_LED_BASE */
+#endif /* ARCH_LED_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sbc-regs.h b/arch/arm/include/asm/arch-uniphier/sbc-regs.h new file mode 100644 index 0000000..397d5b4 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sbc-regs.h @@ -0,0 +1,107 @@ +/*
+#ifndef ARCH_SBC_REGS_H +#define ARCH_SBC_REGS_H
+/* System Bus Controller registers */ +#define SBBASE_BASE 0x58c00100 +#define SBBASE(x) (SBBASE_BASE + (x) * 0x10)
+#define SBBASE0 (SBBASE(0)) +#define SBBASE1 (SBBASE(1)) +#define SBBASE2 (SBBASE(2)) +#define SBBASE3 (SBBASE(3)) +#define SBBASE4 (SBBASE(4)) +#define SBBASE5 (SBBASE(5)) +#define SBBASE6 (SBBASE(6)) +#define SBBASE7 (SBBASE(7))
+#define SBBASE_BANK_ENABLE (0x00000001)
+#define SBCTRL_BASE 0x58c00200 +#define SBCTRL(x, y) (SBCTRL_BASE + (x) * 0x10
- (y) * 4) +
+#define SBCTRL00 SBCTRL(0, 0) +#define SBCTRL01 SBCTRL(0, 1) +#define SBCTRL02 SBCTRL(0, 2) +#define SBCTRL03 SBCTRL(0, 3) +#define SBCTRL04 (SBCTRL_BASE + 0x100)
+#define SBCTRL10 SBCTRL(1, 0) +#define SBCTRL11 SBCTRL(1, 1) +#define SBCTRL12 SBCTRL(1, 2) +#define SBCTRL13 SBCTRL(1, 3) +#define SBCTRL14 (SBCTRL_BASE + 0x110)
+#define SBCTRL20 SBCTRL(2, 0) +#define SBCTRL21 SBCTRL(2, 1) +#define SBCTRL22 SBCTRL(2, 2) +#define SBCTRL23 SBCTRL(2, 3) +#define SBCTRL24 (SBCTRL_BASE + 0x120)
+#define SBCTRL30 SBCTRL(3, 0) +#define SBCTRL31 SBCTRL(3, 1) +#define SBCTRL32 SBCTRL(3, 2) +#define SBCTRL33 SBCTRL(3, 3) +#define SBCTRL34 (SBCTRL_BASE + 0x130)
+#define SBCTRL40 SBCTRL(4, 0) +#define SBCTRL41 SBCTRL(4, 1) +#define SBCTRL42 SBCTRL(4, 2) +#define SBCTRL43 SBCTRL(4, 3) +#define SBCTRL44 (SBCTRL_BASE + 0x140)
+#define SBCTRL50 SBCTRL(5, 0) +#define SBCTRL51 SBCTRL(5, 1) +#define SBCTRL52 SBCTRL(5, 2) +#define SBCTRL53 SBCTRL(5, 3) +#define SBCTRL54 (SBCTRL_BASE + 0x150)
+#define SBCTRL60 SBCTRL(6, 0) +#define SBCTRL61 SBCTRL(6, 1) +#define SBCTRL62 SBCTRL(6, 2) +#define SBCTRL63 SBCTRL(6, 3) +#define SBCTRL64 (SBCTRL_BASE + 0x160)
+#define SBCTRL70 SBCTRL(7, 0) +#define SBCTRL71 SBCTRL(7, 1) +#define SBCTRL72 SBCTRL(7, 2) +#define SBCTRL73 SBCTRL(7, 3) +#define SBCTRL74 (SBCTRL_BASE + 0x170)
+/* slower but LED works */ +#define SBCTRL0_SAVEPIN_PERI_VALUE 0x55450000 +#define SBCTRL1_SAVEPIN_PERI_VALUE 0x07168d00 +#define SBCTRL2_SAVEPIN_PERI_VALUE 0x34000009 +#define SBCTRL4_SAVEPIN_PERI_VALUE 0x02110110
+/* faster but LED does not work */ +#define SBCTRL0_SAVEPIN_MEM_VALUE 0x55450000 +#define SBCTRL1_SAVEPIN_MEM_VALUE 0x06057700 +/* NOR flash needs more wait counts than SRAM */ +#define SBCTRL2_SAVEPIN_MEM_VALUE 0x34000009 +#define SBCTRL4_SAVEPIN_MEM_VALUE 0x02110210
+#define SBCTRL0_ADMULTIPLX_PERI_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_PERI_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_PERI_VALUE 0x14000020
+#define SBCTRL0_ADMULTIPLX_MEM_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_MEM_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_MEM_VALUE 0x14000010
+#define ROM_BOOT_ROMRSV2 0x59801208
+#ifndef __ASSEMBLY__ +#include <asm/io.h> +static inline int boot_is_swapped(void) +{
- return !(readl(SBBASE0) & SBBASE_BANK_ENABLE);
+} +#endif
+#endif /* ARCH_SBC_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sc-regs.h b/arch/arm/include/asm/arch-uniphier/sc-regs.h new file mode 100644 index 0000000..4d4dfdf --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sc-regs.h @@ -0,0 +1,62 @@ +/*
+#ifndef ARCH_SC_REGS_H +#define ARCH_SC_REGS_H
+#define SC_BASE_ADDR 0x61840000
+#define SC_MPLLOSCCTL (SC_BASE_ADDR | 0x1184) +#define SC_MPLLOSCCTL_MPLLEN (0x1 << 0) +#define SC_MPLLOSCCTL_MPLLST (0x1 << 1)
+#define SC_DPLLCTRL (SC_BASE_ADDR | 0x1200) +#define SC_DPLLCTRL_SSC_EN (0x1 << 31) +#define SC_DPLLCTRL_FOUTMODE_MASK (0xf << 16) +#define SC_DPLLCTRL_SSC_RATE (0x1 << 15)
+#define SC_DPLLCTRL2 (SC_BASE_ADDR | 0x1204) +#define SC_DPLLCTRL2_NRSTDS (0x1 << 28)
+#define SC_DPLLCTRL3 (SC_BASE_ADDR | 0x1208) +#define SC_DPLLCTRL3_LPFSEL_COEF2 (0x0 << 31) +#define SC_DPLLCTRL3_LPFSEL_COEF3 (0x1 << 31)
+#define SC_UPLLCTRL (SC_BASE_ADDR | 0x1210)
+#define SC_VPLL27ACTRL (SC_BASE_ADDR | 0x1270) +#define SC_VPLL27ACTRL2 (SC_BASE_ADDR | 0x1274) +#define SC_VPLL27ACTRL3 (SC_BASE_ADDR | 0x1278) + +#define SC_VPLL27BCTRL (SC_BASE_ADDR | 0x1290) +#define SC_VPLL27BCTRL2 (SC_BASE_ADDR | 0x1294) +#define SC_VPLL27BCTRL3 (SC_BASE_ADDR | 0x1298) + +#define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) +#define SC_RSTCTRL_NRST_ETHER (0x1 << 12) +#define SC_RSTCTRL_NRST_UMC1 (0x1 << 5) +#define SC_RSTCTRL_NRST_UMC0 (0x1 << 4) +#define SC_RSTCTRL_NRST_NAND (0x1 << 2)
+#define SC_RSTCTRL2 (SC_BASE_ADDR | 0x2004) +#define SC_RSTCTRL3 (SC_BASE_ADDR | 0x2008)
+#define SC_CLKCTRL (SC_BASE_ADDR | 0x2104) +#define SC_CLKCTRL_CLK_ETHER (0x1 << 12) +#define SC_CLKCTRL_CLK_MIO (0x1 << 11) +#define SC_CLKCTRL_CLK_UMC (0x1 << 4) +#define SC_CLKCTRL_CLK_NAND (0x1 << 2) +#define SC_CLKCTRL_CLK_SBC (0x1 << 1) +#define SC_CLKCTRL_CLK_PERI (0x1 << 0)
+/* System reset control register */ +#define SC_IRQTIMSET (SC_BASE_ADDR | 0x3000) +#define SC_SLFRSTSEL (SC_BASE_ADDR | 0x3010) +#define SC_SLFRSTCTL (SC_BASE_ADDR | 0x3014)
+#endif /* ARCH_SC_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sg-regs.h b/arch/arm/include/asm/arch-uniphier/sg-regs.h new file mode 100644 index 0000000..4136774 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sg-regs.h @@ -0,0 +1,182 @@ +/*
+#ifndef ARCH_SG_REGS_H +#define ARCH_SG_REGS_H
+/* Base Address */ +#define SG_CTRL_BASE 0x5f800000 +#define SG_DBG_BASE 0x5f900000
+/* Revision */ +#define SG_REVISION (SG_CTRL_BASE | 0x0000) +#define SG_REVISION_TYPE_SHIFT 16 +#define SG_REVISION_TYPE_MASK (0xff << SG_REVISION_TYPE_SHIFT) +#define SG_REVISION_MODEL_SHIFT 8 +#define SG_REVISION_MODEL_MASK (0x3 << SG_REVISION_MODEL_SHIFT) +#define SG_REVISION_REV_SHIFT 0 +#define SG_REVISION_REV_MASK (0x1f << SG_REVISION_REV_SHIFT) + +/* Memory Configuration */ +#define SG_MEMCONF (SG_CTRL_BASE | 0x0400) + +#define SG_MEMCONF_CH0_SIZE_64MB ((0x0 << 10) | (0x01 << 0)) +#define SG_MEMCONF_CH0_SIZE_128MB ((0x0 << 10) | (0x02 << 0)) +#define SG_MEMCONF_CH0_SIZE_256MB ((0x0 << 10) | (0x03 << 0)) +#define SG_MEMCONF_CH0_SIZE_512MB ((0x1 << 10) | (0x00 << 0)) +#define SG_MEMCONF_CH0_SIZE_1024MB ((0x1 << 10) | (0x01 << 0)) +#define SG_MEMCONF_CH0_NUM_1 (0x1 << 8) +#define SG_MEMCONF_CH0_NUM_2 (0x0 << 8)
+#define SG_MEMCONF_CH1_SIZE_64MB ((0x0 << 11) | (0x01 << 2)) +#define SG_MEMCONF_CH1_SIZE_128MB ((0x0 << 11) | (0x02 << 2)) +#define SG_MEMCONF_CH1_SIZE_256MB ((0x0 << 11) | (0x03 << 2)) +#define SG_MEMCONF_CH1_SIZE_512MB ((0x1 << 11) | (0x00 << 2)) +#define SG_MEMCONF_CH1_SIZE_1024MB ((0x1 << 11) | (0x01 << 2)) +#define SG_MEMCONF_CH1_NUM_1 (0x1 << 9) +#define SG_MEMCONF_CH1_NUM_2 (0x0 << 9)
+#define SG_MEMCONF_SPARSEMEM (0x1 << 4)
+/* Pin Control */ +#define SG_PINCTRL_BASE (SG_CTRL_BASE | 0x1000) + +#if defined(CONFIG_PH1_PRO4) +# define SG_PINCTRL(n) (SG_PINCTRL_BASE + (n)
- +#elif defined(CONFIG_PH1_LD4) || defined(CONFIG_PH1_SLD8)
- +#endif
+#if defined(CONFIG_PH1_PRO4) +#define SG_PINSELBITS 4 +#elif defined(CONFIG_PH1_LD4) || defined(CONFIG_PH1_SLD8) +#define SG_PINSELBITS 8 +#endif
+#define SG_PINSEL_ADDR(n) (SG_PINCTRL((n) * (SG_PINSELBITS) / 32)) +#define SG_PINSEL_MASK(n) (~(((1 << (SG_PINSELBITS)) - 1) << \
((n) *
(SG_PINSELBITS) % 32))) +#define SG_PINSEL_MODE(n, mode) ((mode) << ((n) * (SG_PINSELBITS) % 32)) + +/* Only for PH1-Pro4 */ +#define SG_LOADPINCTRL (SG_CTRL_BASE | 0x1700)
+/* Input Enable */ +#define SG_IECTRL (SG_CTRL_BASE | 0x1d00)
+/* Pin Monitor */ +#define SG_PINMON0 (SG_DBG_BASE | 0x0100)
+#define SG_PINMON0_CLK_MODE_UPLLSRC_MASK (0x3 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT (0x0 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_VPLL27A (0x2 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_VPLL27B (0x3 << 19)
+#define SG_PINMON0_CLK_MODE_AXOSEL_MASK (0x3 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_24576KHZ (0x0 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ (0x1 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_6144KHZ (0x2 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ (0x3 << 16)
+#define SG_PINMON0_CLK_MODE_AXOSEL_DEFAULT (0x0 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U (0x1 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_20480KHZ (0x2 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A (0x3 << 16)
+#ifndef __ASSEMBLY__ +#include <common.h> +#include <asm/io.h>
+static inline void sg_set_pinsel(int n, int value) +{
- writel((readl(SG_PINSEL_ADDR(n)) & SG_PINSEL_MASK(n))
| SG_PINSEL_MODE(n, value), SG_PINSEL_ADDR(n));
+static inline u32 sg_memconf_val_ch0(unsigned long size, int num) +{
- int size_mb = (size >> 20) / num;
- u32 ret;
- switch (size_mb) {
- case 64:
ret = SG_MEMCONF_CH0_SIZE_64MB;
break;
- case 128:
ret = SG_MEMCONF_CH0_SIZE_128MB;
break;
- case 256:
ret = SG_MEMCONF_CH0_SIZE_256MB;
break;
- case 512:
ret = SG_MEMCONF_CH0_SIZE_512MB;
break;
- case 1024:
ret = SG_MEMCONF_CH0_SIZE_1024MB;
break;
- default:
BUG();
break;
- switch (num) {
- case 1:
ret |= SG_MEMCONF_CH0_NUM_1;
break;
- case 2:
ret |= SG_MEMCONF_CH0_NUM_2;
break;
- default:
BUG();
break;
- return ret;
+static inline u32 sg_memconf_val_ch1(unsigned long size, int num) +{
- u32 ret;
- case 64:
ret = SG_MEMCONF_CH1_SIZE_64MB;
break;
- case 128:
ret = SG_MEMCONF_CH1_SIZE_128MB;
break;
- case 256:
ret = SG_MEMCONF_CH1_SIZE_256MB;
break;
- case 512:
ret = SG_MEMCONF_CH1_SIZE_512MB;
break;
- case 1024:
ret = SG_MEMCONF_CH1_SIZE_1024MB;
break;
- default:
BUG();
break;
- switch (num) {
- case 1:
ret |= SG_MEMCONF_CH1_NUM_1;
break;
- case 2:
ret |= SG_MEMCONF_CH1_NUM_2;
break;
- default:
BUG();
break;
- return ret;
+} +#endif /* __ASSEMBLY__ */
+#endif /* ARCH_SG_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/ssc-regs.h b/arch/arm/include/asm/arch-uniphier/ssc-regs.h new file mode 100644 index 0000000..ae49956 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/ssc-regs.h @@ -0,0 +1,65 @@ +/*
+#ifndef ARCH_SSC_REGS_H +#define ARCH_SSC_REGS_H
+#define SSCC 0x500c0000 +#define SSCC_BST (0x1 << 20) +#define SSCC_ACT (0x1 << 19) +#define SSCC_WTG (0x1 << 18) +#define SSCC_PRD (0x1 << 17) +#define SSCC_WBWA (0x1 << 16) +#define SSCC_EX (0x1 << 13) +#define SSCC_ON (0x1 << 0)
+#define SSCLPDAWCR 0x500c0030
+#define SSCOPE 0x506c0244 +#define SSCOPE_CM_SYNC 0x00000008
+#define SSCOQM 0x506c0248 +#define SSCOQM_TID_MASK (0x3 << 21) +#define SSCOQM_TID_BY_WAY (0x2 << 21) +#define SSCOQM_TID_BY_INST_WAY (0x1 << 21) +#define SSCOQM_TID_BY_DATA_WAY (0x0 << 21) +#define SSCOQM_S_MASK (0x3 << 17) +#define SSCOQM_S_WAY (0x2 << 17) +#define SSCOQM_S_ALL (0x1 << 17) +#define SSCOQM_S_ADDRESS (0x0 << 17) +#define SSCOQM_CE (0x1 << 15) +#define SSCOQM_CW (0x1 << 14) +#define SSCOQM_CM_MASK (0x7) +#define SSCOQM_CM_DIRT_TOUCH (0x7) +#define SSCOQM_CM_ZERO_TOUCH (0x6) +#define SSCOQM_CM_NORM_TOUCH (0x5) +#define SSCOQM_CM_PREF_FETCH (0x4) +#define SSCOQM_CM_SSC_FETCH (0x3) +#define SSCOQM_CM_WB_INV (0x2) +#define SSCOQM_CM_WB (0x1) +#define SSCOQM_CM_INV (0x0)
+#define SSCOQAD 0x506c024c +#define SSCOQSZ 0x506c0250 +#define SSCOQWN 0x506c0258
+#define SSCOPPQSEF 0x506c025c +#define SSCOPPQSEF_FE (0x1 << 1) +#define SSCOPPQSEF_OE (0x1 << 0)
+#define SSCOLPQS 0x506c0260 +#define SSCOLPQS_EF (0x1 << 2) +#define SSCOLPQS_EST (0x1 << 1) +#define SSCOLPQS_QST (0x1 << 0)
+#define SSCOQCE0 0x506c0270
+#define SSC_LINE_SIZE 128 +#define SSC_NUM_ENTRIES 256 +#define SSC_WAY_SIZE ((SSC_LINE_SIZE) * (SSC_NUM_ENTRIES)) +#define SSC_RANGE_OP_MAX_SIZE (0x00400000
- (SSC_LINE_SIZE)) +
+#endif /* ARCH_SSC_REGS_H */
Amicalement,
Hi Albert,
First, I don't like full-quoting as Wolfgang also mentioned before: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/52214/focus=52252
Since this patch is very long, I might miss some of your comments.
If I did not overlook, my comments are below:
On Wed, 20 Aug 2014 11:31:26 +0200 Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Masahiro,
On Fri, 4 Jul 2014 19:19:15 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Subject: [PATCH 3/6] arm: uniphier: add UniPhier SoC suppurt code
Typo in subject -- since you're going to do a v2, please fix this too, thanks!
Oops, thanks for pointing this out. Will fix in v2. I am still holding v2 back because of the patch dependency.
+int board_late_init(void) +{
- puts("MODE: ");
- switch (spl_boot_device()) {
- case BOOT_DEVICE_NAND:
printf("NAND Boot\n");
setenv("bootmode", "nandboot");
nand_denali_wp_disable();
break;
- default:
printf("Unsupported Boot Mode\n");
Please add the mode value (decimal, hex or binary as you prefer, as long as the reader can understand the format) to the output.
BOOT_DEVICE_* is defined by enum in arch/arm/include/spl.h.
I don't see the necessity to display the meaningless value.
SSC_RANGE_OP_MAX_SIZE : size;
__uniphier_cache_maint_range(start, chunk_size,
operation); +
start += chunk_size;
size -= chunk_size;
- writel(SSCOPE_CM_SYNC, SSCOPE); /* drain internal buffers */
- readl(SSCOPE); /* need a read back to confirm */
Does the readback contain some status showing whether the drain is in progress vs. complete? If it does, then shouldn't the line above be a loop waiting for completion?
Not really. I am not familiar enough with this cache block to tell you its detail but the hardware manual clearly says to read back SSCOPE register so I am following it.
+int print_cpuinfo(void) +{
- u32 revision, type, model, rev, required_model = 1,
required_rev = 1; +
- revision = readl(SG_REVISION);
- type = (revision & SG_REVISION_TYPE_MASK) >>
SG_REVISION_TYPE_SHIFT;
- model = (revision & SG_REVISION_MODEL_MASK) >>
SG_REVISION_MODEL_SHIFT;
- rev = (revision & SG_REVISION_REV_MASK) >>
SG_REVISION_REV_SHIFT; +
- puts("CPU: ");
- switch (type) {
- case 0x25:
puts("PH1-sLD3 (MN2WS0220)");
required_model = 2;
break;
- case 0x26:
puts("PH1-LD4 (MN2WS0250)");
required_rev = 2;
break;
- case 0x28:
puts("PH1-Pro4 (MN2WS0230)");
break;
- case 0x29:
puts("PH1-sLD8 (MN2WS0270)");
break;
- default:
printf("Unknown Processor ID (0x%x)\n", revision);
return -1;
Maybe use symbolic constants rather tha magic numbers in switch cases above.
Do you want me to do like this?
#define PH1_SLD3_ID 0x25 #define PH1_LD4_ID 0x26 #define PH1_PRO4_ID 0x28 #define PH1_SLD8_ID 0x29
switch (type) { case PH1_SLD3_ID: puts("PH1-sLD3 (MN2WS0220)"); required_model = 2; break; case PH1_LD4_ID: puts("PH1-LD4 (MN2WS0250)"); required_rev = 2; break; case PH1_PRO4_ID: puts("PH1-Pro4 (MN2WS0230)"); break; case PH1_SLD8_ID: puts("PH1-sLD8 (MN2WS0270)"); break; default: printf("Unknown Processor ID (0x%x)\n", revision); return -1; }
I am not sure if we should be strict to the magic number rule here in this code.
It is true 0x25 is a magic number but its meaning is apparent enough at a glance.
I wish I could, but it is impossible.
UnPhier SoCs have no dedicated SRAM; it is shared with L2 Cache. To turn on L2 Cache, this page table is necessary. At the time, no writable memory is available yet. That is why this table must be computed at the compilation and placed in the .rodata section.
Indeed, this is an unfortunate hardware specification.
- bcu_init();
- sbc_init();
- sg_init();
- pll_init();
- pin_init();
- clkrst_init();
Assume you mentioned led_write(B, 1, , ). This is not a function but a macro. It is impossible to remove the blank arguments.
Best Regards Masahiro Yamada
Configuration headers for Panasonic UniPhier series: PH1-LD4, PH1-Pro4, PH1-sLD8
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
include/configs/ph1_ld4.h | 64 +++++++++ include/configs/ph1_pro4.h | 66 +++++++++ include/configs/ph1_sld8.h | 64 +++++++++ include/configs/uniphier-common.h | 275 ++++++++++++++++++++++++++++++++++++++ 4 files changed, 469 insertions(+) create mode 100644 include/configs/ph1_ld4.h create mode 100644 include/configs/ph1_pro4.h create mode 100644 include/configs/ph1_sld8.h create mode 100644 include/configs/uniphier-common.h
diff --git a/include/configs/ph1_ld4.h b/include/configs/ph1_ld4.h new file mode 100644 index 0000000..50c2f8e --- /dev/null +++ b/include/configs/ph1_ld4.h @@ -0,0 +1,64 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PH1_XXX_H +#define __PH1_XXX_H + +/* + * Support Card Select + * + * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. + * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. + * CPLD is re-programmed for ARIMA board compatibility. + * No define - No support card. + */ + +#if 0 +#define CONFIG_PFC_MICRO_SUPPORT_CARD +#else +#define CONFIG_DCC_MICRO_SUPPORT_CARD +#endif + +/* + * Serial Configuration + * SoC UART : enable CONFIG_UNIPHIER_SERIAL + * On-board UART: enable CONFIG_SYS_NS16550_SERIAL + */ +#if 0 +#define CONFIG_UNIPHIER_SERIAL +#else +#define CONFIG_SYS_NS16550_SERIAL +#endif + +#define CONFIG_SYS_UNIPHIER_UART_CLK 36864000 + +#define CONFIG_SMC911X + +/*----------------------------------------------------------------------- + * Board Type + *----------------------------------------------------------------------*/ +#define CONFIG_PH1_LD4 + +#define CONFIG_DDR_NUM_CH0 1 +#define CONFIG_DDR_NUM_CH1 1 + +#define CONFIG_DDR_FREQ 1600 + +/* + * Memory Size & Mapping + */ +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x10000000 +#define CONFIG_SDRAM1_BASE 0x90000000 +#define CONFIG_SDRAM1_SIZE 0x10000000 + +#define CONFIG_SPL_TEXT_BASE 0x40000 + +#include "uniphier-common.h" + +#endif /* __PH1_XXX_H */ diff --git a/include/configs/ph1_pro4.h b/include/configs/ph1_pro4.h new file mode 100644 index 0000000..6633f7a --- /dev/null +++ b/include/configs/ph1_pro4.h @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PH1_XXX_H +#define __PH1_XXX_H + +/* + * Support Card Select + * + * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. + * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. + * CPLD is re-programmed for ARIMA board compatibility. + * No define - No support card. + */ + +#if 0 +#define CONFIG_PFC_MICRO_SUPPORT_CARD +#else +#define CONFIG_DCC_MICRO_SUPPORT_CARD +#endif + +/* + * Serial Configuration + * SoC UART : enable CONFIG_UNIPHIER_SERIAL + * On-board UART: enable CONFIG_SYS_NS16550_SERIAL + */ +#if 0 +#define CONFIG_UNIPHIER_SERIAL +#else +#define CONFIG_SYS_NS16550_SERIAL +#endif + +#define CONFIG_SYS_UNIPHIER_UART_CLK 73728000 + +#define CONFIG_SMC911X + +/*----------------------------------------------------------------------- + * Board Type + *----------------------------------------------------------------------*/ +#define CONFIG_PH1_PRO4 + +#define CONFIG_DDR_NUM_CH0 2 +#define CONFIG_DDR_NUM_CH1 2 + +#define CONFIG_DDR_FREQ 1600 + +#define CONFIG_UNIPHIER_SMP + +/* + * Memory Size & Mapping + */ +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x20000000 +#define CONFIG_SDRAM1_BASE 0xa0000000 +#define CONFIG_SDRAM1_SIZE 0x20000000 + +#define CONFIG_SPL_TEXT_BASE 0x100000 + +#include "uniphier-common.h" + +#endif /* __PH1_XXX_H */ diff --git a/include/configs/ph1_sld8.h b/include/configs/ph1_sld8.h new file mode 100644 index 0000000..5130adf --- /dev/null +++ b/include/configs/ph1_sld8.h @@ -0,0 +1,64 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PH1_XXX_H +#define __PH1_XXX_H + +/* + * Support Card Select + * + * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. + * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. + * CPLD is re-programmed for ARIMA board compatibility. + * No define - No support card. + */ + +#if 0 +#define CONFIG_PFC_MICRO_SUPPORT_CARD +#else +#define CONFIG_DCC_MICRO_SUPPORT_CARD +#endif + +/* + * Serial Configuration + * SoC UART : enable CONFIG_UNIPHIER_SERIAL + * On-board UART: enable CONFIG_SYS_NS16550_SERIAL + */ +#if 0 +#define CONFIG_UNIPHIER_SERIAL +#else +#define CONFIG_SYS_NS16550_SERIAL +#endif + +#define CONFIG_SYS_UNIPHIER_UART_CLK 80000000 + +#define CONFIG_SMC911X + +/*----------------------------------------------------------------------- + * Board Type + *----------------------------------------------------------------------*/ +#define CONFIG_PH1_SLD8 + +#define CONFIG_DDR_NUM_CH0 1 +#define CONFIG_DDR_NUM_CH1 1 + +#define CONFIG_DDR_FREQ 1333 + +/* + * Memory Size & Mapping + */ +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x10000000 +#define CONFIG_SDRAM1_BASE 0x90000000 +#define CONFIG_SDRAM1_SIZE 0x10000000 + +#define CONFIG_SPL_TEXT_BASE 0x40000 + +#include "uniphier-common.h" + +#endif /* __PH1_XXX_H */ diff --git a/include/configs/uniphier-common.h b/include/configs/uniphier-common.h new file mode 100644 index 0000000..0ee190e --- /dev/null +++ b/include/configs/uniphier-common.h @@ -0,0 +1,275 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* U-boot - Common settings for UniPhier Family */ + +#ifndef __CONFIG_UNIPHIER_COMMON_H__ +#define __CONFIG_UNIPHIER_COMMON_H__ + +#define CONFIG_UNIPHIER + +#define CONFIG_SPL + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) && \ + defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +# error "Both CONFIG_PFC_MICRO_SUPPORT_CARD and CONFIG_DCC_MICRO_SUPPORT_CARD \ +are defined. Select only one of them." +#endif + +/* + * Support card address map + */ +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) +# define CONFIG_SUPPORT_CARD_BASE 0x03f00000 +# define CONFIG_SUPPORT_CARD_ETHER_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00000000) +# define CONFIG_SUPPORT_CARD_LED_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00090000) +# define CONFIG_SUPPORT_CARD_UART_BASE (CONFIG_SUPPORT_CARD_BASE + 0x000b0000) +#endif + +#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +# define CONFIG_SUPPORT_CARD_BASE 0x08000000 +# define CONFIG_SUPPORT_CARD_ETHER_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00000000) +# define CONFIG_SUPPORT_CARD_LED_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00401630) +# define CONFIG_SUPPORT_CARD_UART_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00200000) +#endif + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_COM1 CONFIG_SUPPORT_CARD_UART_BASE +#define CONFIG_SYS_NS16550_CLK 12288000 +#define CONFIG_SYS_NS16550_REG_SIZE -2 + +#define CONFIG_SMC911X_BASE CONFIG_SUPPORT_CARD_ETHER_BASE +#define CONFIG_SMC911X_32_BIT + +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE0 0x54006800 +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE1 0x54006900 +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE2 0x54006a00 +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE3 0x54006b00 + +/*----------------------------------------------------------------------- + * MMU and Cache Setting + *----------------------------------------------------------------------*/ + +/* Comment out the following to enable L1 cache */ +/* #define CONFIG_SYS_ICACHE_OFF */ +/* #define CONFIG_SYS_DCACHE_OFF */ + +/* Comment out the following to enable L2 cache */ +#define CONFIG_UNIPHIER_L2CACHE_ON + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) + +#define CONFIG_TIMESTAMP + +/* FLASH related */ +#define CONFIG_MTD_DEVICE + +/* + * uncomment the following to disable FLASH related code. + */ +/* #define CONFIG_SYS_NO_FLASH */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI + +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_MONITOR_BASE 0 +#define CONFIG_SYS_FLASH_BASE 0 + +/* + * flash_toggle does not work for out supoort card. + * We need to use flash_status_poll. + */ +#define CONFIG_SYS_CFI_FLASH_STATUS_POLL + +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) +# define CONFIG_SYS_MAX_FLASH_BANKS 1 +# define CONFIG_SYS_FLASH_BANKS_LIST {0x00000000} +# define CONFIG_SYS_FLASH_BANKS_SIZES {0x02000000} +#endif + +#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +# define CONFIG_SYS_MAX_FLASH_BANKS 1 +# define CONFIG_SYS_FLASH_BANKS_LIST {0x04000000} +# define CONFIG_SYS_FLASH_BANKS_SIZES {0x04000000} +#endif + +/* serial console configuration */ +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_GENERIC_BOARD + +#if !defined(CONFIG_SPL_BUILD) +#define CONFIG_USE_ARCH_MEMSET +#define CONFIG_USE_ARCH_MEMCPY +#endif + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ + +#define CONFIG_CMDLINE_EDITING /* add command line history */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_CONS_INDEX 1 + +/* + * For NAND booting the environment is embedded in the U-Boot image. Please take + * look at the file board/amcc/canyonlands/u-boot-nand.lds for details. + */ +/* #define CONFIG_ENV_IS_IN_NAND */ +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET 0x0 +/* #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) */ + +/* Time clock 1MHz */ +#define CONFIG_SYS_TIMER_RATE 1000000 + +/* + * By default, ARP timeout is 5 sec. + * The first ARP request does not seem to work. + * So we need to retry ARP request anyway. + * We want to shrink the interval until the second ARP request. + */ +#define CONFIG_ARP_TIMEOUT 500UL /* 0.5 msec */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_TIME +#define CONFIG_CMD_NAND /* NAND flash suppport */ + +#define CONFIG_NAND_DENALI +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_MAX_CHIPS 2 + +/* new : for Altera Driver */ +#define CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES 8 +#define CONFIG_NAND_DENALI_ECC_SIZE 1024 + +#define CONFIG_NAND_DENALI_64BIT + +#define CONFIG_SYS_NAND_REGS_BASE 0x68100000 +#define CONFIG_SYS_NAND_DATA_BASE 0x68000000 + +#define CONFIG_SYS_NAND_BASE (CONFIG_SYS_NAND_DATA_BASE + 0x10) + +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x01000000) + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay +#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_STOP_STR " " + +/* + * Network Configuration + */ +#define CONFIG_ETHADDR 00:21:83:24:00:00 +#define CONFIG_SERVERIP 192.168.11.1 +#define CONFIG_IPADDR 192.168.11.10 +#define CONFIG_GATEWAYIP 192.168.11.1 +#define CONFIG_NETMASK 255.255.255.0 + +#define CONFIG_LOADADDR 0x84000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_BOOTFILE "fit.itb" + +#define CONFIG_CMDLINE_EDITING /* add command line history */ + +#define CONFIG_BOOTCOMMAND "run $bootmode" + +#define CONFIG_ROOTPATH "/nfs/root/path" +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs $bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off;" \ + "tftpboot; bootm;" + +#define CONFIG_BOOTARGS " user_debug=0x1f init=/sbin/init" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "image_offset=0x00080000\0" \ + "image_size=0x00f00000\0" \ + "verify=n\0" \ + "autostart=yes\0" \ + "norboot=run add_default_bootargs;" \ + "bootm $image_offset\0" \ + "nandboot=run add_default_bootargs;" \ + "nand read $loadaddr $image_offset $image_size;" \ + "bootm\0" \ + "add_default_bootargs=setenv bootargs $bootargs" \ + " console=ttyS0,$baudrate\0" \ + +/* FIT support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ + +/* Open Firmware flat tree */ +#define CONFIG_OF_LIBFDT + +#define CONFIG_HAVE_ARM_SECURE + +/* Memory Size & Mapping */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SDRAM0_BASE + +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE >= CONFIG_SDRAM1_BASE +/* Thre is no memory hole */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_SIZE (CONFIG_SDRAM0_SIZE + CONFIG_SDRAM1_SIZE) +#else +#define CONFIG_NR_DRAM_BANKS 2 +#define CONFIG_SYS_SDRAM_SIZE (CONFIG_SDRAM0_SIZE) +#endif + +#define CONFIG_SYS_TEXT_BASE 0x84000000 + +#if defined(CONFIG_SPL_BUILD) +#define CONFIG_BOARD_POSTCLK_INIT +#else +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#define CONFIG_SYS_SPL_MALLOC_START (0x0ff00000) +#define CONFIG_SYS_SPL_MALLOC_SIZE (0x00004000) + +#define CONFIG_SYS_INIT_SP_ADDR (0x0ff08000) + +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_NAND_SUPPORT + +#define CONFIG_SPL_LIBCOMMON_SUPPORT /* for mem_malloc_init */ +#define CONFIG_SPL_LIBGENERIC_SUPPORT + +#define CONFIG_SPL_BOARD_INIT + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x10000 +#define CONFIG_SYS_NAND_PAGE_SIZE 0x1000 /* tmp */ + +#endif /* __CONFIG_UNIPHIER_COMMON_H__ */
Add board entries for Panasonic UniPhier family: PH1-LD4, PH1-Pro4, PH1-sLD8
boards.cfg | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/boards.cfg b/boards.cfg index 8e2db82..cfe4498 100644 --- a/boards.cfg +++ b/boards.cfg @@ -376,6 +376,9 @@ Active arm armv7 sunxi - sunxi Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,SUNXI_GMAC,RGMII - Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org Active arm armv7 u8500 st-ericsson u8500 u8500_href - - +Active arm armv7 uniphier - <none> ph1_ld4 - Masahiro Yamada yamada.m@jp.panasonic.com +Active arm armv7 uniphier - <none> ph1_pro4 - Masahiro Yamada yamada.m@jp.panasonic.com +Active arm armv7 uniphier - <none> ph1_sld8 - Masahiro Yamada yamada.m@jp.panasonic.com Active arm armv7 vf610 freescale vf610twr vf610twr vf610twr:IMX_CONFIG=board/freescale/vf610twr/imximage.cfg Alison Wang b18965@freescale.com Active arm armv7 zynq xilinx zynq zynq_microzed - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7 zynq xilinx zynq zynq_zc70x - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com
doc/git-mailrc | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/doc/git-mailrc b/doc/git-mailrc index e53c888..77f66f9 100644 --- a/doc/git-mailrc +++ b/doc/git-mailrc @@ -26,6 +26,7 @@ alias lukma Lukasz Majewski l.majewski@samsung.com alias macpaul Macpaul Lin macpaul@andestech.com alias marex Marek Vasut marex@denx.de alias monstr Michal Simek monstr@monstr.eu +alias masahiro Masahiro Yamada yamada.m@jp.panasonic.com alias panto Pantelis Antoniou panto@antoniou-consulting.com alias prafulla Prafulla Wadaskar prafulla@marvell.com alias prom Minkyu Kang mk7.kang@samsung.com @@ -59,6 +60,7 @@ alias samsung uboot, prom alias tegra uboot, sjg, Tom Warren twarren@nvidia.com, Stephen Warren swarren@nvidia.com alias tegra2 tegra alias ti uboot, trini +alias uniphier uboot, masahiro
alias avr32 uboot, abiessmann
Albert ARIBAUD
Masahiro Yamada
