[PATCH] clk: scmi: fix invalid clock name references
Fixes clock name references in scmi_clk driver. SCMI clock names are retrieved from the SCMI firmware by invoking SCMI commands using the stack for SCMI response message hence clocks names located in the stack must be duplicated before being registered in the clock framework.
Fixes: 7c33f78983c3 ("clk: scmi: register scmi clocks with CCF") Reported-by: scan-admin@coverity.com Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/clk/clk_scmi.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/clk_scmi.c b/drivers/clk/clk_scmi.c index 57022685e2..5019aacef9 100644 --- a/drivers/clk/clk_scmi.c +++ b/drivers/clk/clk_scmi.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2019-2020 Linaro Limited + * Copyright (C) 2019-2022 Linaro Limited */
#define LOG_CATEGORY UCLASS_CLK @@ -12,6 +12,7 @@ #include <scmi_protocols.h> #include <asm/types.h> #include <linux/clk-provider.h> +#include <linux/string.h>
static int scmi_clk_get_num_clock(struct udevice *dev, size_t *num_clocks) { @@ -53,7 +54,9 @@ static int scmi_clk_get_attibute(struct udevice *dev, int clkid, char **name) if (ret) return ret;
- *name = out.clock_name; + *name = strdup(out.clock_name); + if (*name) + return -ENOMEM;
return 0; }
Etienne Carriere
