[U-Boot] [PATCH] test/py: Fix MMC/SD block write test dependency
Test is using random command which has own Kconfig symbol CMD_RANDOM which already depends on CMD_MEMORY. That's why replace cmd_memory by cmd_random.
Fixes: 09da18deab8b ("test/py: add MMC/SD block write test") Signed-off-by: Michal Simek michal.simek@xilinx.com ---
test/py/tests/test_mmc_wr.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/tests/test_mmc_wr.py b/test/py/tests/test_mmc_wr.py index 601279a6a4a3..7678c3c9c181 100644 --- a/test/py/tests/test_mmc_wr.py +++ b/test/py/tests/test_mmc_wr.py @@ -35,7 +35,7 @@ env__mmc_wr_configs = (
-@pytest.mark.buildconfigspec('cmd_mmc','cmd_memory') +@pytest.mark.buildconfigspec('cmd_mmc','cmd_random') def test_mmc_wr(u_boot_console, env__mmc_wr_config): """Test the "mmc write" command.
Subject: [PATCH] test/py: Fix MMC/SD block write test dependency
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
Applied to mmc/master.
Thanks, Peng
-- 2.17.1
This might not always be true; I think it'd be better to keep the existing dependency list entries and just add CMD_RANDOM:
Can you please tell me when exactly? I didn't see that.
Thanks, Michal
If in the future somebody changes the Kconfig file so that CMD_RANDOM doesn't depend on or select CMD_MEMORY. It may well not be possible right now; I just want to make sure the test doesn't rely on implementation details of CMD_RANDOM/CMD_MEMORY; if it explicitly needs both, it should simply depend on both.
Do you think that we have used this rule in past? Anyway I understand what you mean but it is questionable if make sense to predict all changes which can happen. I would consider if anybody remove this dependency without fixing test suite as bug which should be fixed. Also tests should detect this and report issues to stop this before patch like this is applied.
Thanks, Michal
I hope so; I'd consider it a bug in a test if the test used a command but didn't explicitly depend on that command's CONFIG_ flag. We have had such bugs in the past, and fixed one or two of them.
It's more about the test explicitly specifying exactly what it depends on than predicting changes.
True, but people do forget such things.
I have sent a patch. Feel free to fix commit message if needed.
Thanks, Michal
Michal Simek
Peng Fan
Stephen Warren
