[PATCH v4] cmd: Add pause command
This command is being introduced with the goal of allowing user-friendly "generic use case" U-Boot builds to pause until user input under some situations.
The main use case would be when a boot failure happens, to pause until the user has had time to acknowledge the current state.
Tested using:
make && ./u-boot -v -T -c 'ut lib lib_test_hush_pause'
Signed-off-by: Samuel Dionne-Riel samuel@dionne-riel.com Cc: Simon Glass sjg@chromium.org ---
Hi!
I believe everything is addressed. I took the comment about the sort order being wonky as needing no changes.
Changes for v4 - No functional change in command, mainly code style - Addressed nits - Added missing docs - Wrote test fully in code
Changes for v3 - No functional change in patch - Sent with lines unwrapped - Added changelog
Changes for v2 - Added test, as requested by Tom - Made CMD_PAUSE default n
--- cmd/Kconfig | 6 +++++ cmd/Makefile | 1 + cmd/pause.c | 32 ++++++++++++++++++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + doc/usage/cmd/pause.rst | 53 +++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + test/cmd/Makefile | 3 +++ test/cmd/test_pause.c | 45 +++++++++++++++++++++++++++++++ 9 files changed, 143 insertions(+) create mode 100644 cmd/pause.c create mode 100644 doc/usage/cmd/pause.rst create mode 100644 test/cmd/test_pause.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 3625ff2a50b..e8d1f73cd0d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1961,6 +1961,12 @@ config CMD_GETTIME milliseconds. See also the 'bootstage' command which provides more flexibility for boot timing.
+config CMD_PAUSE + bool "pause command" + help + Delay execution waiting for any user input. + Useful to allow the user to read a failure log. + config CMD_RNG bool "rng command" depends on DM_RNG diff --git a/cmd/Makefile b/cmd/Makefile index 5e43a1e022e..98a6224bdc1 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -102,6 +102,7 @@ obj-$(CONFIG_CMD_MFSL) += mfsl.o obj-$(CONFIG_CMD_MII) += mii.o obj-$(CONFIG_CMD_MISC) += misc.o obj-$(CONFIG_CMD_MDIO) += mdio.o +obj-$(CONFIG_CMD_PAUSE) += pause.o obj-$(CONFIG_CMD_SLEEP) += sleep.o obj-$(CONFIG_CMD_MMC) += mmc.o obj-$(CONFIG_CMD_OPTEE_RPMB) += optee_rpmb.o diff --git a/cmd/pause.c b/cmd/pause.c new file mode 100644 index 00000000000..c97833c0d70 --- /dev/null +++ b/cmd/pause.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021 + * Samuel Dionne-Riel samuel@dionne-riel.com + */ + +#include <command.h> +#include <stdio.h> + +static int do_pause(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + char *message = "Press any key to continue..."; + + if (argc == 2) + message = argv[1]; + + /* No newline, so it sticks to the bottom of the screen */ + printf("%s", message); + + /* Wait on "any" key... */ + (void) getchar(); + + /* Since there was no newline, we need it now */ + printf("\n"); + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD(pause, 2, 1, do_pause, + "delay until user input", + "[prompt] - Wait until users presses any key. [prompt] can be used to customize the message.\n" +); diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 6553568e768..0af582d642d 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -67,6 +67,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y +CONFIG_CMD_PAUSE=y CONFIG_CMD_TIMER=y CONFIG_CMD_SOUND=y CONFIG_CMD_QFW=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index eba7bcbb483..d856d9b0942 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -96,6 +96,7 @@ CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y +CONFIG_CMD_PAUSE=y CONFIG_CMD_TIMER=y CONFIG_CMD_SOUND=y CONFIG_CMD_QFW=y diff --git a/doc/usage/cmd/pause.rst b/doc/usage/cmd/pause.rst new file mode 100644 index 00000000000..c79e399c020 --- /dev/null +++ b/doc/usage/cmd/pause.rst @@ -0,0 +1,53 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later: + +pause command +============= + +Synopsis +-------- + +:: + + pause [prompt] + + +Description +----------- + +The pause command delays execution waiting for any user input. + +It can accept a single parameter to change the prompt message. + +Examples +-------- + +Using with the default prompt: + +:: + + => pause + Press any key to continue... + + +Using with a custom prompt: + +:: + + => pause 'Prompt for pause...' + Prompt for pause... + +Note that complex prompts require proper quoting: + +:: + + => pause Prompt for pause... + pause - delay until user input + + Usage: + pause [prompt] - Wait until users presses any key. [prompt] can be used to customize the message. + +Return value +------------ + +The return value $? is always set to 0 (true), unless invoked in an invalid +manner. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 2ba8733b92c..decfc2cc843 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -51,6 +51,7 @@ Shell commands cmd/mbr cmd/md cmd/mmc + cmd/pause cmd/pinmux cmd/printenv cmd/pstore diff --git a/test/cmd/Makefile b/test/cmd/Makefile index c331757425e..1bb02d93a23 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -5,6 +5,9 @@ ifdef CONFIG_HUSH_PARSER obj-$(CONFIG_CONSOLE_RECORD) += test_echo.o endif +ifdef CONFIG_CONSOLE_RECORD +obj-$(CONFIG_CMD_PAUSE) += test_pause.o +endif obj-y += mem.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_FDT) += fdt.o diff --git a/test/cmd/test_pause.c b/test/cmd/test_pause.c new file mode 100644 index 00000000000..2b85cce3271 --- /dev/null +++ b/test/cmd/test_pause.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Tests for pause command + * + * Copyright 2022, Samuel Dionne-Riel samuel@dionne-riel.com + */ + +#include <common.h> +#include <asm/global_data.h> +#include <test/lib.h> +#include <test/ut.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int lib_test_hush_pause(struct unit_test_state *uts) +{ + /* Test default message */ + console_record_reset_enable(); + /* Cook a newline when the command is expected to pause */ + console_in_puts("\n"); + ut_assertok(run_command("pause", 0)); + console_record_readline(uts->actual_str, sizeof(uts->actual_str)); + ut_asserteq_str("Press any key to continue...", uts->actual_str); + ut_assertok(ut_check_console_end(uts)); + + /* Test provided message */ + console_record_reset_enable(); + /* Cook a newline when the command is expected to pause */ + console_in_puts("\n"); + ut_assertok(run_command("pause 'Prompt for pause...'", 0)); + console_record_readline(uts->actual_str, sizeof(uts->actual_str)); + ut_asserteq_str("Prompt for pause...", uts->actual_str); + ut_assertok(ut_check_console_end(uts)); + + /* Test providing more than one params */ + console_record_reset_enable(); + /* No newline cooked here since the command is expected to fail */ + ut_asserteq(1, run_command("pause a b", 0)); + console_record_readline(uts->actual_str, sizeof(uts->actual_str)); + ut_asserteq_str("pause - delay until user input", uts->actual_str); + ut_asserteq(1, ut_check_console_end(uts)); + + return 0; +} +LIB_TEST(lib_test_hush_pause, 0);
Tested using:
Samuel Dionne-Riel
