[PATCH 0/7] ESM support for TI K3 SoCs
This series introduces ESM (Error Signaling Module) drivers for TI K3 generation of SoCs. These are used to handle SoC internal HW error events from various sources, and they can either trigger an error interrupt for SW to handle, or trigger a HW event which can be routed to e.g. PMIC to trigger full device reset.
In this series, the watchdog expire events are routed to an error event pin, which is handled by PMIC resetting the J721e board. AM65x boards are not handled, as they currently don't support HW routing of the signals.
-Tero
-- Texas Instruments Finland Oy, Porkkalankatu 22, 00180 Helsinki. Y-tunnus/Business ID: 0615521-4. Kotipaikka/Domicile: Helsinki
TPS65941 can have child devices under it (like the ESM support), so probe these once the master pmic node completes probe.
Signed-off-by: Tero Kristo t-kristo@ti.com --- drivers/power/pmic/tps65941.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/pmic/tps65941.c b/drivers/power/pmic/tps65941.c index e8f3c950bd..7b3416ae6e 100644 --- a/drivers/power/pmic/tps65941.c +++ b/drivers/power/pmic/tps65941.c @@ -59,8 +59,8 @@ static int tps65941_bind(struct udevice *dev) if (!children) printf("%s: %s - no child found\n", __func__, dev->name);
- /* Always return success for this device */ - return 0; + /* Probe all the child devices */ + return dm_scan_fdt_dev(dev); }
static struct dm_pmic_ops tps65941_ops = {
The ESM (Error Signaling Module) is used to route error signals within the K3 SoCs somewhat similar to interrupts. The handling for these is different though, and can be routed for hardware error handling, to be handled by safety processor or just as error interrupts handled by the main processor. The u-boot level ESM driver is just used to configure the ESM signals so that they get routed to proper destination.
Signed-off-by: Tero Kristo t-kristo@ti.com --- doc/device-tree-bindings/misc/esm-k3.txt | 25 +++++++ drivers/misc/Kconfig | 5 ++ drivers/misc/Makefile | 1 + drivers/misc/k3_esm.c | 87 ++++++++++++++++++++++++ 4 files changed, 118 insertions(+) create mode 100644 doc/device-tree-bindings/misc/esm-k3.txt create mode 100644 drivers/misc/k3_esm.c
diff --git a/doc/device-tree-bindings/misc/esm-k3.txt b/doc/device-tree-bindings/misc/esm-k3.txt new file mode 100644 index 0000000000..01c8b6b294 --- /dev/null +++ b/doc/device-tree-bindings/misc/esm-k3.txt @@ -0,0 +1,25 @@ +Texas Instruments K3 ESM Binding +====================== + +ESM (Error Signaling Module) is an IP block on TI K3 devices that allows +handling of safety events somewhat similar to what interrupt controller +would do. The safety signals have their separate paths within the SoC, +and they are handled by the ESM, which routes them to the proper +destination, which can be system reset, interrupt controller, etc. In +the simplest configuration the signals are just routed to reset the +SoC. + +Required properties : +- compatible : "ti,j721e-esm" +- ti,esm-pins : integer array of esm events IDs to route to external event + pin which can be used to reset the SoC. The array can + have arbitrary amount of event IDs listed on it. + +Example +======= + + main_esm: esm@700000 { + compatible = "ti,j721e-esm"; + reg = <0x0 0x700000 0x0 0x1000>; + ti,esm-pins = <344>, <345>; + }; diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index f18aa8f7ba..38588b2cbd 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -462,6 +462,11 @@ config IHS_FPGA gdsys devices, which supply the majority of the functionality offered by the devices. This driver supports both CON and CPU variants of the devices, depending on the device tree entry. +config ESM_K3 + bool "Enable K3 ESM driver" + depends on ARCH_K3 + help + Support ESM (Error Signaling Module) on TI K3 SoCs.
config MICROCHIP_FLEXCOM bool "Enable Microchip Flexcom driver" diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 2b843de93c..60406c3e0a 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -72,3 +72,4 @@ obj-$(CONFIG_WINBOND_W83627) += winbond_w83627.o obj-$(CONFIG_JZ4780_EFUSE) += jz4780_efuse.o obj-$(CONFIG_MICROCHIP_FLEXCOM) += microchip_flexcom.o obj-$(CONFIG_K3_AVS0) += k3_avs.o +obj-$(CONFIG_ESM_K3) += k3_esm.o diff --git a/drivers/misc/k3_esm.c b/drivers/misc/k3_esm.c new file mode 100644 index 0000000000..8f270f3b5c --- /dev/null +++ b/drivers/misc/k3_esm.c @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments' K3 Error Signalling Module driver + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * Tero Kristo t-kristo@ti.com + * + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include <dm/device_compat.h> + +#define ESM_SFT_RST 0x0c +#define ESM_SFT_RST_KEY 0x0f + +#define ESM_STS(i) (0x404 + (i) / 32 * 0x20) +#define ESM_PIN_EN_SET_OFFSET(i) (0x414 + (i) / 32 * 0x20) +#define ESM_PIN_MASK(i) BIT((i) & 0x1f) + +static void esm_pin_enable(void __iomem *base, int pin) +{ + /* Enable event */ + writel(ESM_PIN_MASK(pin), base + ESM_PIN_EN_SET_OFFSET(pin)); +} + +/** + * k3_esm_probe: configures ESM based on DT data + * + * Parses ESM info from device tree, and configures the module accordingly. + */ +static int k3_esm_probe(struct udevice *dev) +{ + int ret; + void __iomem *base; + int num_pins; + u32 *pins; + int i; + + base = dev_remap_addr_index(dev, 0); + if (!base) + return -ENODEV; + + num_pins = dev_read_size(dev, "ti,esm-pins"); + if (num_pins < 0) { + dev_err(dev, "ti,esm-pins property missing or invalid: %d\n", + num_pins); + return num_pins; + } + + num_pins /= sizeof(u32); + + pins = kmalloc(num_pins * sizeof(u32), __GFP_ZERO); + if (!pins) + return -ENOMEM; + + ret = dev_read_u32_array(dev, "ti,esm-pins", pins, num_pins); + if (ret < 0) { + dev_err(dev, "failed to read ti,esm-pins property: %d\n", + ret); + goto free_pins; + } + + /* Clear any pending events */ + writel(ESM_SFT_RST_KEY, base + ESM_SFT_RST); + + for (i = 0; i < num_pins; i++) + esm_pin_enable(base, pins[i]); + +free_pins: + kfree(pins); + return ret; +} + +static const struct udevice_id k3_esm_ids[] = { + { .compatible = "ti,j721e-esm" }, + {} +}; + +U_BOOT_DRIVER(k3_esm) = { + .name = "k3_esm", + .of_match = k3_esm_ids, + .id = UCLASS_MISC, + .probe = k3_esm_probe, +};
The ESM (Error Signal Monitor) is used on certain PMIC versions to handle error signals propagating from rest of the system. If these reach the PMIC, it is typically a last resort fatal error which requires a system reset. The ESM driver does the proper configuration for the ESM module to reach this end goal. Initially, only TPS65941 PMIC is supported for this.
Signed-off-by: Tero Kristo t-kristo@ti.com --- doc/device-tree-bindings/misc/esm-pmic.txt | 19 ++++++ drivers/misc/Kconfig | 7 +++ drivers/misc/Makefile | 1 + drivers/misc/esm_pmic.c | 69 ++++++++++++++++++++++ 4 files changed, 96 insertions(+) create mode 100644 doc/device-tree-bindings/misc/esm-pmic.txt create mode 100644 drivers/misc/esm_pmic.c
diff --git a/doc/device-tree-bindings/misc/esm-pmic.txt b/doc/device-tree-bindings/misc/esm-pmic.txt new file mode 100644 index 0000000000..a60ad74679 --- /dev/null +++ b/doc/device-tree-bindings/misc/esm-pmic.txt @@ -0,0 +1,19 @@ +PMIC ESM Binding +====================== + +Certain Power Management ICs contain safety handling logic within them, +allowing automatic reset of the board in case a safety error is signaled. +For this purpose, ESM (Error Signal Monitor) is implemented within +the PMIC running its own state machine. + +Required properties : +- compatible : "ti,tps659413-esm" + +Example +======= + +&tps659413a { + esm: esm { + compatible = "ti,tps659413-esm"; + }; +}; diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 38588b2cbd..766402745d 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -486,4 +486,11 @@ config K3_AVS0 optimized voltage from the efuse, so that it can be programmed to the PMIC on board.
+config ESM_PMIC + bool "Enable PMIC ESM driver" + depends on DM_PMIC + help + Support ESM (Error Signal Monitor) on PMIC devices. ESM is used + typically to reboot the board in error condition. + endmenu diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 60406c3e0a..68e0e7ad17 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -73,3 +73,4 @@ obj-$(CONFIG_JZ4780_EFUSE) += jz4780_efuse.o obj-$(CONFIG_MICROCHIP_FLEXCOM) += microchip_flexcom.o obj-$(CONFIG_K3_AVS0) += k3_avs.o obj-$(CONFIG_ESM_K3) += k3_esm.o +obj-$(CONFIG_ESM_PMIC) += esm_pmic.o diff --git a/drivers/misc/esm_pmic.c b/drivers/misc/esm_pmic.c new file mode 100644 index 0000000000..92c8d68f7c --- /dev/null +++ b/drivers/misc/esm_pmic.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * PMIC Error Signal Monitor driver + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * Tero Kristo t-kristo@ti.com + * + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <power/pmic.h> +#include <dm/device_compat.h> + +#define INT_ESM_REG 0x6c +#define INT_ESM_MASK 0x3f + +#define ESM_MCU_START_REG 0x8f + +#define ESM_MCU_START BIT(0) + +#define ESM_MCU_MODE_CFG_REG 0x92 + +#define ESM_MCU_EN BIT(6) +#define ESM_MCU_ENDRV BIT(5) + +/** + * pmic_esm_probe: configures and enables PMIC ESM functionality + * + * Configures ESM PMIC support and enables it. + */ +static int pmic_esm_probe(struct udevice *dev) +{ + int ret; + + ret = pmic_reg_write(dev->parent, INT_ESM_REG, INT_ESM_MASK); + if (ret) { + dev_err(dev, "clearing ESM irqs failed: %d\n", ret); + return ret; + } + + ret = pmic_reg_write(dev->parent, ESM_MCU_MODE_CFG_REG, + ESM_MCU_EN | ESM_MCU_ENDRV); + if (ret) { + dev_err(dev, "setting ESM mode failed: %d\n", ret); + return ret; + } + + ret = pmic_reg_write(dev->parent, ESM_MCU_START_REG, ESM_MCU_START); + if (ret) { + dev_err(dev, "starting ESM failed: %d\n", ret); + return ret; + } + + return 0; +} + +static const struct udevice_id pmic_esm_ids[] = { + { .compatible = "ti,tps659413-esm" }, + {} +}; + +U_BOOT_DRIVER(pmic_esm) = { + .name = "esm_pmic", + .of_match = pmic_esm_ids, + .id = UCLASS_MISC, + .probe = pmic_esm_probe, +};
Main domain ESM support is needed to configure main domain watchdogs to generate ESM pin events by default. On J7 processor board these propagate to the PMIC to generate a reset when watchdog expires.
Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi | 4 ++++ arch/arm/dts/k3-j721e-main.dtsi | 6 ++++++ arch/arm/dts/k3-j721e.dtsi | 1 + 3 files changed, 11 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index a3a8193216..158598f5a7 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -349,3 +349,7 @@ &exp2 { u-boot,dm-spl; }; + +&main_esm { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-j721e-main.dtsi b/arch/arm/dts/k3-j721e-main.dtsi index 45ac98c47e..ef4282f608 100644 --- a/arch/arm/dts/k3-j721e-main.dtsi +++ b/arch/arm/dts/k3-j721e-main.dtsi @@ -532,4 +532,10 @@ clocks = <&k3_clks 193 0>; power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>; }; + + main_esm: esm@700000 { + compatible = "ti,j721e-esm"; + reg = <0x0 0x700000 0x0 0x1000>; + ti,esm-pins = <344>, <345>; + }; }; diff --git a/arch/arm/dts/k3-j721e.dtsi b/arch/arm/dts/k3-j721e.dtsi index 68ba517e50..e470d3a1b5 100644 --- a/arch/arm/dts/k3-j721e.dtsi +++ b/arch/arm/dts/k3-j721e.dtsi @@ -135,6 +135,7 @@ #size-cells = <2>; ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */ <0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */ + <0x00 0x00700000 0x00 0x00700000 0x00 0x00001000>, /* ESM */ <0x00 0x00900000 0x00 0x00900000 0x00 0x00012000>, /* serdes */ <0x00 0x00A40000 0x00 0x00A40000 0x00 0x00000800>, /* timesync router */ <0x00 0x01000000 0x00 0x01000000 0x00 0x0af02400>, /* Most peripherals */
+&main_esm {
- u-boot,dm-spl;
- main_esm: esm@700000 {
This might never be defined in kernel dts. So it will be a problem when syncing kernel dts. Can you move this to r5 dts?
Thanks and regards, Lokesh
+&main_esm {
- u-boot,dm-spl;
Yeah, I can't see this ever going to be defined in kernel dts.
I can move it to r5 file.
-Tero -- Texas Instruments Finland Oy, Porkkalankatu 22, 00180 Helsinki. Y-tunnus/Business ID: 0615521-4. Kotipaikka/Domicile: Helsinki
The ESM handling on J7 processor board requires routing the MCU_SAFETY_ERROR signal to the PMIC on the board for critical safety error handling. The PMIC itself should then reset the board based on receiving it. Enable the support for the board by adding the esm node in place.
Signed-off-by: Tero Kristo t-kristo@ti.com --- .../arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi new file mode 100644 index 0000000000..c6c60b44ec --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ + */ + +&tps659413a { + esm: esm { + compatible = "ti,tps659413-esm"; + u-boot,dm-spl; + }; +};
Initialize both ESM and ESM_PMIC support if available for the board. If support is not available for either, a warning is printed out.
ESM signals are only properly routed on PM2 version of the J721E SOM, so only probe the drivers on this device.
Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/mach-k3/j721e_init.c | 23 ++++++++++++++++++++++- 1 file changed, 22 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index f7f7398081..2de9583937 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -18,6 +18,7 @@ #include <dm.h> #include <dm/uclass-internal.h> #include <dm/pinctrl.h> +#include "../../../board/ti/common/board_detect.h"
#ifdef CONFIG_SPL_BUILD #ifdef CONFIG_K3_LOAD_SYSFW @@ -114,7 +115,8 @@ static void store_boot_index_from_rom(void)
void board_init_f(ulong dummy) { -#if defined(CONFIG_K3_J721E_DDRSS) || defined(CONFIG_K3_LOAD_SYSFW) +#if defined(CONFIG_K3_J721E_DDRSS) || defined(CONFIG_K3_LOAD_SYSFW) || \ + defined(CONFIG__ESM_K3) || defined(CONFIG_ESM_PMIC) struct udevice *dev; int ret; #endif @@ -181,6 +183,25 @@ void board_init_f(ulong dummy) printf("AVS init failed: %d\n", ret); #endif
+#ifdef CONFIG_ESM_K3 + if (board_ti_k3_is("J721EX-PM2-SOM")) { + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(k3_esm), &dev); + if (ret) + printf("MISC init failed: %d\n", ret); + } +#endif + +#ifdef CONFIG_ESM_PMIC + if (board_ti_k3_is("J721EX-PM2-SOM")) { + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(pmic_esm), + &dev); + if (ret) + printf("ESM PMIC init failed: %d\n", ret); + } +#endif + #if defined(CONFIG_K3_J721E_DDRSS) ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret)
- defined(CONFIG__ESM_K3) || defined(CONFIG_ESM_PMIC) struct udevice *dev; int ret;
- if (board_ti_k3_is("J721EX-PM2-SOM")) {
if (ret)
&dev);
if (ret)
Since this is board specific, can you call this under spl_board_init() and add it in board/ti/j721e ?
- defined(CONFIG__ESM_K3) || defined(CONFIG_ESM_PMIC) struct udevice *dev; int ret; #endif
if (ret)
&dev);
if (ret)
Right, let me try that out.
Enable ESM modules for both PMIC and SoC side for proper watchdog handling on the board.
Signed-off-by: Tero Kristo t-kristo@ti.com --- configs/j721e_evm_r5_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 19fbd450c7..12264ae61d 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -122,3 +122,5 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x6163 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 +CONFIG_ESM_K3=y +CONFIG_ESM_PMIC=y
Lokesh Vutla
Tero Kristo
