[PATCH v2 00/18] Migration to using binman to generate
This series aims to eliminate the use of additional custom repositories such as k3-image-gen (K3 Image Generation) repo that was plumbed into the U-Boot build flow to generate boot images for TI K3 platform devices. And instead, we move towards using binman that aligns better with the community standard build flow.
This series uses binman for all K3 platforms supported on U-Boot currently; both HS (High Security) and GP (General Purpose) devices.
Background on using k3-image-gen: * TI K3 devices require a SYSFW (System Firmware) image consisting of a signed system firmware image and board configuration binaries, this is needed to bring up system firmware during U-Boot R5 SPL startup. * Board configuration data contain board-specific information such as resource management, power management and security.
Series intends to use binman to take over the packaging and signing for the R5 bootloader images tiboot3.bin (and sysfw.itb, for non-combined boot flow) instead of k3-image-gen.
Series also packages the A72/A53 bootloader images (tispl.bin and u-boot.img) using ATF, OPTEE and DM (Device Manager)
Changes in v2: - removed all external scripts - created ti-board-config etype to support generation of board config binaries - created ti-secure and ti-secure-rom etypes to handle signing instead of using external TI_SECURE_DEV_PKG - updated openssl btool to support x509 certificate generation - dropped Makefile changes to obtain external binary components, moving to using BINMAN_INDIRS to achieve the same
Neha Malcom Francis (18): binman: Add support for generating TI Board config binaries binman: ti-secure: Add support for TI signing ti: sysfw: tiboot3: Add support for packaging sysfw.itb and tiboot3.bin j721e: schema: yaml: Add general schema and J721E board config files j721e: dts: binman: Package tiboot3.bin, sysfw.itb, tispl.bin, u-boot.img j7200: yaml: Add J7200 board config files j7200: dts: binman: Package tiboot3.bin, tispl.bin, u-boot.img am65x: yaml: Add AM65x board config files am65: dts: binman: Package tiboot3.bin, sysfw.itb, tispl.bin, u-boot.img config: am64x: Add board config for AM64x am64x: dts: binman: Package tiboot3.bin, tispl.bin u-boot.img j721s2: yaml: Add board config for J721S2 j721s2: dts: binman: Package tiboot3.bin, tispl.bin and u-boot.img am62: yaml: Add board config for AM62 am625: dts: binman: Package tiboot3.bin, tispl.bin and u-boot.img am62a: yaml: Add board config for AM62ax am62a: dts: binman: Package tiboot3.bin, tispl.bin, u-boot.img k3: tools: config.mk: Update makefile and remove scripts
arch/arm/dts/k3-am625-r5-sk.dts | 1 + arch/arm/dts/k3-am625-sk-binman.dtsi | 472 +++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 2 + arch/arm/dts/k3-am62a-sk-binman.dtsi | 472 +++ arch/arm/dts/k3-am62a7-r5-sk.dts | 1 + arch/arm/dts/k3-am62a7-sk.dts | 1 + arch/arm/dts/k3-am642-evm-u-boot.dtsi | 2 + arch/arm/dts/k3-am642-r5-evm.dts | 1 + arch/arm/dts/k3-am64x-binman.dtsi | 521 +++ arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 1 + .../dts/k3-am654-r5-base-board-u-boot.dtsi | 1 + arch/arm/dts/k3-am65x-binman.dtsi | 543 +++ arch/arm/dts/k3-j7200-binman.dtsi | 471 +++ .../k3-j7200-common-proc-board-u-boot.dtsi | 2 + arch/arm/dts/k3-j721e-binman.dtsi | 634 ++++ .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + .../arm/dts/k3-j721e-r5-common-proc-board.dts | 1 + arch/arm/dts/k3-j721s2-binman.dtsi | 474 +++ .../k3-j721s2-common-proc-board-u-boot.dtsi | 2 + .../dts/k3-j721s2-r5-common-proc-board.dts | 1 + arch/arm/mach-k3/config.mk | 126 +- board/ti/am62ax/Kconfig | 2 + board/ti/am62ax/board-cfg.yaml | 36 + board/ti/am62ax/pm-cfg.yaml | 12 + board/ti/am62ax/rm-cfg.yaml | 1151 +++++++ board/ti/am62ax/sec-cfg.yaml | 375 +++ board/ti/am62x/Kconfig | 2 + board/ti/am62x/board-cfg.yaml | 36 + board/ti/am62x/pm-cfg.yaml | 12 + board/ti/am62x/rm-cfg.yaml | 1088 +++++++ board/ti/am62x/sec-cfg.yaml | 375 +++ board/ti/am64x/Kconfig | 2 + board/ti/am64x/board-cfg.yaml | 37 + board/ti/am64x/pm-cfg.yaml | 12 + board/ti/am64x/rm-cfg.yaml | 1400 ++++++++ board/ti/am64x/sec-cfg.yaml | 378 +++ board/ti/am65x/Kconfig | 2 + board/ti/am65x/board-cfg.yaml | 36 + board/ti/am65x/pm-cfg.yaml | 12 + board/ti/am65x/rm-cfg.yaml | 2068 ++++++++++++ board/ti/am65x/sec-cfg.yaml | 375 +++ board/ti/common/schema.yaml | 355 ++ board/ti/j721e/Kconfig | 4 + board/ti/j721e/board-cfg.yaml | 37 + board/ti/j721e/board-cfg_j7200.yaml | 36 + board/ti/j721e/pm-cfg.yaml | 13 + board/ti/j721e/pm-cfg_j7200.yaml | 12 + board/ti/j721e/rm-cfg.yaml | 2757 ++++++++++++++++ board/ti/j721e/rm-cfg_j7200.yaml | 2065 ++++++++++++ board/ti/j721e/sec-cfg.yaml | 379 +++ board/ti/j721e/sec-cfg_j7200.yaml | 378 +++ board/ti/j721s2/Kconfig | 2 + board/ti/j721s2/board-cfg.yaml | 37 + board/ti/j721s2/pm-cfg.yaml | 12 + board/ti/j721s2/rm-cfg.yaml | 2901 +++++++++++++++++ board/ti/j721s2/sec-cfg.yaml | 375 +++ board/ti/keys/custMpk.pem | 51 + board/ti/keys/ti-degenerate-key.pem | 10 + scripts/Makefile.spl | 2 + tools/binman/btool/openssl.py | 244 ++ tools/binman/entries.rst | 75 + tools/binman/etype/ti_board_config.py | 246 ++ tools/binman/etype/ti_secure.py | 83 + tools/binman/etype/ti_secure_rom.py | 233 ++ tools/binman/etype/x509_cert.py | 87 +- tools/binman/ftest.py | 57 + tools/binman/test/277_ti_board_cfg.dts | 11 + .../binman/test/278_ti_board_cfg_combined.dts | 25 + tools/binman/test/279_ti_secure.dts | 17 + tools/binman/test/280_ti_secure_rom.dts | 17 + .../test/281_ti_secure_rom_combined.dts | 25 + tools/binman/test/yaml/config.yaml | 11 + tools/binman/test/yaml/schema.yaml | 26 + tools/k3_fit_atf.sh | 123 - tools/k3_gen_x509_cert.sh | 262 -- 75 files changed, 21634 insertions(+), 475 deletions(-) create mode 100644 arch/arm/dts/k3-am625-sk-binman.dtsi create mode 100644 arch/arm/dts/k3-am62a-sk-binman.dtsi create mode 100644 arch/arm/dts/k3-am64x-binman.dtsi create mode 100644 arch/arm/dts/k3-am65x-binman.dtsi create mode 100644 arch/arm/dts/k3-j7200-binman.dtsi create mode 100644 arch/arm/dts/k3-j721e-binman.dtsi create mode 100644 arch/arm/dts/k3-j721s2-binman.dtsi create mode 100644 board/ti/am62ax/board-cfg.yaml create mode 100644 board/ti/am62ax/pm-cfg.yaml create mode 100644 board/ti/am62ax/rm-cfg.yaml create mode 100644 board/ti/am62ax/sec-cfg.yaml create mode 100644 board/ti/am62x/board-cfg.yaml create mode 100644 board/ti/am62x/pm-cfg.yaml create mode 100644 board/ti/am62x/rm-cfg.yaml create mode 100644 board/ti/am62x/sec-cfg.yaml create mode 100644 board/ti/am64x/board-cfg.yaml create mode 100644 board/ti/am64x/pm-cfg.yaml create mode 100644 board/ti/am64x/rm-cfg.yaml create mode 100644 board/ti/am64x/sec-cfg.yaml create mode 100644 board/ti/am65x/board-cfg.yaml create mode 100644 board/ti/am65x/pm-cfg.yaml create mode 100644 board/ti/am65x/rm-cfg.yaml create mode 100644 board/ti/am65x/sec-cfg.yaml create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/board-cfg.yaml create mode 100644 board/ti/j721e/board-cfg_j7200.yaml create mode 100644 board/ti/j721e/pm-cfg.yaml create mode 100644 board/ti/j721e/pm-cfg_j7200.yaml create mode 100644 board/ti/j721e/rm-cfg.yaml create mode 100644 board/ti/j721e/rm-cfg_j7200.yaml create mode 100644 board/ti/j721e/sec-cfg.yaml create mode 100644 board/ti/j721e/sec-cfg_j7200.yaml create mode 100644 board/ti/j721s2/board-cfg.yaml create mode 100644 board/ti/j721s2/pm-cfg.yaml create mode 100644 board/ti/j721s2/rm-cfg.yaml create mode 100644 board/ti/j721s2/sec-cfg.yaml create mode 100644 board/ti/keys/custMpk.pem create mode 100644 board/ti/keys/ti-degenerate-key.pem create mode 100644 tools/binman/etype/ti_board_config.py create mode 100644 tools/binman/etype/ti_secure.py create mode 100644 tools/binman/etype/ti_secure_rom.py create mode 100644 tools/binman/test/277_ti_board_cfg.dts create mode 100644 tools/binman/test/278_ti_board_cfg_combined.dts create mode 100644 tools/binman/test/279_ti_secure.dts create mode 100644 tools/binman/test/280_ti_secure_rom.dts create mode 100644 tools/binman/test/281_ti_secure_rom_combined.dts create mode 100644 tools/binman/test/yaml/config.yaml create mode 100644 tools/binman/test/yaml/schema.yaml delete mode 100755 tools/k3_fit_atf.sh delete mode 100755 tools/k3_gen_x509_cert.sh
The ti-board-config entry loads and validates a given YAML config file against a given schema, and generates the board config binary. K3 devices require these generated binaries to be packed into the final system firmware images.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/binman/entries.rst | 50 ++++ tools/binman/etype/ti_board_config.py | 246 ++++++++++++++++++ tools/binman/ftest.py | 11 + tools/binman/test/277_ti_board_cfg.dts | 11 + .../binman/test/278_ti_board_cfg_combined.dts | 25 ++ tools/binman/test/yaml/config.yaml | 11 + tools/binman/test/yaml/schema.yaml | 26 ++ 7 files changed, 380 insertions(+) create mode 100644 tools/binman/etype/ti_board_config.py create mode 100644 tools/binman/test/277_ti_board_cfg.dts create mode 100644 tools/binman/test/278_ti_board_cfg_combined.dts create mode 100644 tools/binman/test/yaml/config.yaml create mode 100644 tools/binman/test/yaml/schema.yaml
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index b71af801fd..7cfe61dd09 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -2423,3 +2423,53 @@ may be used instead.
+.. _etype_ti_board_config: + +Entry: ti-board-config: Texas Instruments board config binary +------------------------------------------------------------- + +Support for generation of TI schema validated board configuration +binary +This etype supports generation of two kinds of board configuration +binaries: singular board config binary as well as combined board config +binary. + +Properties / Entry arguments: + - config-file: File containing board configuration data in YAML + - schema-file: File containing board configuration YAML schema against + which the config file is validated + +These above parameters are used only when the generated binary is +intended to be a single board configuration binary. Example:: + +/* generate a my-ti-board-config.bin generated from a YAML configuration +file validated against the schema*/ +my-ti-board-config { + ti-board-config { + config = "board-config.yaml"; + schema = "schema.yaml"; + }; +}; + +To generate a combined board configuration binary, we pack the +needed individual binaries into a ti-board-config binary. In this case, +the available supported subnode names are board-cfg, pm-cfg, sec-cfg and +rm-cfg. For example:: + +/* generate a my-combined-ti-board-config.bin packed with a header +(containing details about the included board config binaries), along +with the YAML schema validated binaries themselves*/ +my-combined-ti-board-config { + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; +}; + + diff --git a/tools/binman/etype/ti_board_config.py b/tools/binman/etype/ti_board_config.py new file mode 100644 index 0000000000..0a9be44afc --- /dev/null +++ b/tools/binman/etype/ti_board_config.py @@ -0,0 +1,246 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# Written by Neha Malcom Francis n-francis@ti.com +# +# Entry-type module for generating schema validated TI board +# configuration binary +# + +import os +import struct +import tempfile +import yaml + +from collections import OrderedDict +from jsonschema import validate +from shutil import copyfileobj +from shutil import rmtree + +from binman.entry import Entry +from binman.etype.section import Entry_section +from binman.etype.blob_ext import Entry_blob_ext +from binman.etype.blob_ext_list import Entry_blob_ext_list +from dtoc import fdt_util +from u_boot_pylib import tools, tout + +BOARDCFG = 0xB +BOARDCFG_SEC = 0xD +BOARDCFG_PM = 0xE +BOARDCFG_RM = 0xC +BOARDCFG_NUM_ELEMS = 4 + +class Entry_ti_board_config(Entry_section): + """ + Support for generation of TI schema validated board configuration + binary + This etype supports generation of two kinds of board configuration + binaries: singular board config binary as well as combined board config + binary. + + Available parameters are: + + config-file + File containing board configuration data in YAML + + schema-file + File containing board configuration YAML schema against which the + config file is validated + + These above parameters are used only when the generated binary is + intended to be a single board configuration binary. Example:: + + /* generate a my-ti-board-config.bin generated from a YAML configuration + file validated against the schema*/ + my-ti-board-config { + ti-board-config { + config = "board-config.yaml"; + schema = "schema.yaml"; + }; + }; + + To generate a combined board configuration binary, we pack the + needed individual binaries into a ti-board-config binary. In this case, + the available supported subnode names are board-cfg, pm-cfg, sec-cfg and + rm-cfg. For example:: + + /* generate a my-combined-ti-board-config.bin packed with a header + (containing details about the included board config binaries), along + with the YAML schema validated binaries themselves*/ + my-combined-ti-board-config { + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + } + } + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + + self.config_file = None + self.schema_file = None + + self._entries = OrderedDict() + self._entries_data = OrderedDict() + self.num_elems = BOARDCFG_NUM_ELEMS + self.fmt = '<HHHBB' + self.index = 0 + self.binary_offset = 0 + self.sw_rev = 1 + self.devgrp = 0 + + def ReadNode(self): + super().ReadNode() + self.config_file = fdt_util.GetString(self._node, 'config') + self.schema_file = fdt_util.GetString(self._node, 'schema') + if self.config_file is None: + self.ReadEntries() + + def ReadEntries(self): + """Read the subnodes to find out what should go in this image""" + num_cfgs = 0 + for node in self._node.subnodes: + if 'type' not in node.props: + num_cfgs += 1 + etype = 'ti-board-config' + entry = Entry.Create(self, node, etype) + entry.ReadNode() + cfg_data = entry.BuildSectionData(True) + self._entries[entry.name] = entry + self._entries_data[entry.name] = cfg_data + self.num_elems = num_cfgs + + def _convert_to_byte_chunk(self, val, data_type): + """Convert value into byte array""" + size = 0 + if (data_type == "#/definitions/u8"): + size = 1 + elif (data_type == "#/definitions/u16"): + size = 2 + elif (data_type == "#/definitions/u32"): + size = 4 + else: + raise Exception("Data type not present in definitions") + if type(val) == int: + br = val.to_bytes(size, byteorder="little") + return br + + def _compile_yaml(self, schema_yaml, file_yaml): + """Convert YAML file into byte array based on YAML schema""" + br = bytearray() + for key in file_yaml.keys(): + node = file_yaml[key] + node_schema = schema_yaml['properties'][key] + node_type = node_schema.get('type') + if not 'type' in node_schema: + br += self._convert_to_byte_chunk(node, + node_schema.get('$ref')) + elif node_type == 'object': + br += self._compile_yaml(node_schema, node) + elif node_type == 'array': + for item in node: + if not isinstance(item, dict): + br += self._convert_to_byte_chunk( + item, schema_yaml['properties'][key]['items']["$ref"]) + else: + br += self._compile_yaml(node_schema.get('items'), item) + return br + + def _generate_binaries(self): + """Generate config binary artifacts from the loaded YAML configuration file""" + try: + cfg_binary = bytearray() + for key in self.file_yaml.keys(): + node = self.file_yaml[key] + node_schema = self.schema_yaml['properties'][key] + br = self._compile_yaml(node_schema, node) + cfg_binary += br + except Exception as e: + tout.warning("Combined board config binary was not generated properly") + cfg_binary = tools.get_bytes(0, 512) + return cfg_binary + + def _add_boardcfg(self, bcfgtype, bcfgdata): + size = len(bcfgdata) + desc = struct.pack(self.fmt, bcfgtype, + self.binary_offset, size, self.devgrp, 0) + with open(self.descfile, "ab+") as desc_fh: + desc_fh.write(desc) + with open(self.bcfgfile, "ab+") as bcfg_fh: + bcfg_fh.write(bcfgdata) + self.binary_offset += size + self.index += 1 + + def _finalize(self): + try: + with open(self.descfile, "rb") as desc_fh: + with open(self.bcfgfile, "rb") as bcfg_fh: + with open(self.fh_file, 'ab+') as fh: + desc_fh.seek(0) + bcfg_fh.seek(0) + copyfileobj(desc_fh, fh) + copyfileobj(bcfg_fh, fh) + data = tools.read_file(self.fh_file) + except Exception as e: + tout.warning("Combined board config binary was not generated properly") + data = tools.get_bytes(0, 512) + rmtree(self.tmpdir) + return data + + def BuildSectionData(self, required): + if self.config_file is None: + self.binary_offset = 0 + self.tmpdir = tempfile.mkdtemp() + self.fh_file = os.path.join(self.tmpdir, "fh") + self.descfile = os.path.join(self.tmpdir, "desc") + self.bcfgfile = os.path.join(self.tmpdir, "bcfg") + try: + with open(self.fh_file, 'wb') as f: + t_bytes = f.write(struct.pack( + '<BB', self.num_elems, self.sw_rev)) + self.binary_offset += t_bytes + self.binary_offset += self.num_elems * struct.calcsize(self.fmt) + except Exception as e: + tout.warning("Combined board config header was not generated properly") + + if 'board-cfg' in self._entries: + self._add_boardcfg(BOARDCFG, self._entries_data['board-cfg']) + + if 'sec-cfg' in self._entries: + self._add_boardcfg(BOARDCFG_SEC, self._entries_data['sec-cfg']) + + if 'pm-cfg' in self._entries: + self._add_boardcfg(BOARDCFG_PM, self._entries_data['pm-cfg']) + + if 'rm-cfg' in self._entries: + self._add_boardcfg(BOARDCFG_RM, self._entries_data['rm-cfg']) + + data = self._finalize() + return data + + else: + with open(self.config_file, 'r') as f: + self.file_yaml = yaml.safe_load(f) + with open(self.schema_file, 'r') as sch: + self.schema_yaml = yaml.safe_load(sch) + try: + validate(self.file_yaml, self.schema_yaml) + except Exception as e: + tout.error(f"Schema validation error: {e}") + + data = self._generate_binaries() + return data + + def SetImagePos(self, image_pos): + Entry.SetImagePos(self, image_pos) + + def SetCalculatedProperties(self): + Entry.SetCalculatedProperties(self) + + def CheckEntries(self): + Entry.CheckEntries(self) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 43b4f850a6..28b5bd19d5 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -97,6 +97,7 @@ ENV_DATA = b'var1=1\nvar2="2"' PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') +TI_BOARD_CONFIG_DATA = b'\x00\x01'
# Subdirectory of the input dir to use to put test FDTs TEST_FDT_SUBDIR = 'fdts' @@ -6676,6 +6677,16 @@ fdt fdtmap Extract the devicetree blob from the fdtmap ['fit']) self.assertIn("Node '/fit': Missing tool: 'mkimage'", str(e.exception))
+ def testTIBoardConfig(self): + """Test that a schema validated board config file can be generated""" + data = self._DoReadFile('277_ti_board_cfg.dts') + self.assertEqual(TI_BOARD_CONFIG_DATA, data) + + def testTIBoardConfig(self): + """Test that a schema validated combined board config file can be generated""" + data = self._DoReadFile('278_ti_board_cfg_combined.dts') + configlen_noheader = TI_BOARD_CONFIG_DATA*4 + self.assertGreater(data, configlen_noheader)
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/277_ti_board_cfg.dts b/tools/binman/test/277_ti_board_cfg.dts new file mode 100644 index 0000000000..8b1b210d9d --- /dev/null +++ b/tools/binman/test/277_ti_board_cfg.dts @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + ti-board-config { + config = "tools/binman/test/yaml/config.yaml"; + schema = "tools/binman/test/yaml/schema.yaml"; + }; + }; +}; diff --git a/tools/binman/test/278_ti_board_cfg_combined.dts b/tools/binman/test/278_ti_board_cfg_combined.dts new file mode 100644 index 0000000000..54cb383d90 --- /dev/null +++ b/tools/binman/test/278_ti_board_cfg_combined.dts @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + ti-board-config { + board-cfg { + config = "tools/binman/test/yaml/config.yaml"; + schema = "tools/binman/test/yaml/schema.yaml"; + }; + sec-cfg { + config = "tools/binman/test/yaml/config.yaml"; + schema = "tools/binman/test/yaml/schema.yaml"; + }; + rm-cfg { + config = "tools/binman/test/yaml/config.yaml"; + schema = "tools/binman/test/yaml/schema.yaml"; + }; + pm-cfg { + config = "tools/binman/test/yaml/config.yaml"; + schema = "tools/binman/test/yaml/schema.yaml"; + }; + }; + }; +}; diff --git a/tools/binman/test/yaml/config.yaml b/tools/binman/test/yaml/config.yaml new file mode 100644 index 0000000000..5b17e78af9 --- /dev/null +++ b/tools/binman/test/yaml/config.yaml @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Test config +# +--- + +main-branch: + small-branch: + a: 0x0 + b: 0x1 diff --git a/tools/binman/test/yaml/schema.yaml b/tools/binman/test/yaml/schema.yaml new file mode 100644 index 0000000000..44f08bb6b0 --- /dev/null +++ b/tools/binman/test/yaml/schema.yaml @@ -0,0 +1,26 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Test schema +# +--- + +definitions: + u8: + type: integer + minimum: 0 + maximum: 0xff + +type: object +properties: + main-branch: + type: object + properties: + small-branch: + type: object + properties: + a: + $ref: "#/definitions/u8" + b: + $ref: "#/definitions/u8" +
Hi Neha,
This looks pretty good. Some things to fix:
The first line of a function comment should fit on that line. Add a blank line afterwards. Add full comments to all functions, describing the purpose / type of each arg (you have done many of them).
Use 'binman entry-docs >tools/binman/entries.rst' to generate the docs rather than hand editing. Try 'make htmldocs' as this fails for your updates.
Some test coverage is missing - use 'binman test -T' to try it. You will need to add tests for failing cases as well as success, perhaps adding new .dts files for your tests.
The jsonschema module is now required. That needs to be added to the 'dependencies' line of tools/binman/pyproject.toml
A few minor nits below
- which the config file is validated
- ti-board-config {
- ti-board-config {
board-cfg {
sec-cfg {
- Support for generation of TI schema validated board configuration
- binary
- This etype supports generation of two kinds of board configuration
- binaries: singular board config binary as well as combined board config
- binary.
- Available parameters are:
- config-file
- schema-file
- These above parameters are used only when the generated binary is
- intended to be a single board configuration binary. Example::
- /* generate a my-ti-board-config.bin generated from a YAML configuration
- file validated against the schema*/
- my-ti-board-config {
ti-board-config {
- To generate a combined board configuration binary, we pack the
- needed individual binaries into a ti-board-config binary. In this case,
- the available supported subnode names are board-cfg, pm-cfg, sec-cfg and
- rm-cfg. For example::
- /* generate a my-combined-ti-board-config.bin packed with a header
- (containing details about the included board config binaries), along
- with the YAML schema validated binaries themselves*/
- my-combined-ti-board-config {
ti-board-config {
board-cfg {
sec-cfg {
- def __init__(self, section, etype, node):
self.fmt = '<HHHBB'
self.index = 0
self.sw_rev = 1
self.devgrp = 0
Better to use a _ prefix with private properties, ie.. self._devgr[
- def ReadNode(self):
super().ReadNode()
self.ReadEntries()
Why is this not done if self.config_file is not None? Please add a comment.
- def ReadEntries(self):
num_cfgs = 0
num_cfgs += 1
Can you drop that and just use the string in the next line?
entry.ReadNode()
You could add your data to the entry if you like?
entry._cfg_data = cfg_data
Isn't that len(self._node.subnodes) ?
- def _convert_to_byte_chunk(self, val, data_type):
size = 0
size = 1
size = 2
size = 4
else:
ValueError()
Please use single quotes where possible except for function docs (please fix throughout)
return br
- def _compile_yaml(self, schema_yaml, file_yaml):
br = bytearray()
for item in node:
else:
return br
- def _generate_binaries(self):
Return:
try:
You can do:
for key, node in self.file_yaml.items():
cfg_binary += br
return cfg_binary
- def _add_boardcfg(self, bcfgtype, bcfgdata):
comment
desc_fh.write(desc)
self.index += 1
- def _finalize(self):
try:
desc_fh.seek(0)
bcfg_fh.seek(0)
But if they are just opened you don't need to seek. Can't you drop those two lines?
You should not catch Exception since this will cause anything to be caught. Here I think you want IOError ?
rmtree(self.tmpdir)
return data
- def BuildSectionData(self, required):
This should use tools.get_output_filename() rather than create a temp dir. We want the output to be visible for debugging, etc.
try:
return data
else:
try:
return data
- def SetImagePos(self, image_pos):
- def SetCalculatedProperties(self):
- def CheckEntries(self):
- def testTIBoardConfig(self):
spaces around *
The ti-secure entry contains certificate for binaries that will be loaded or booted by system firmware whereas the ti-secure-rom entry contains certificate for binaries that will be booted by ROM. Support for both these types of certificates is necessary for booting of K3 devices.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/keys/custMpk.pem | 51 ++++ board/ti/keys/ti-degenerate-key.pem | 10 + tools/binman/btool/openssl.py | 244 ++++++++++++++++++ tools/binman/entries.rst | 25 ++ tools/binman/etype/ti_secure.py | 83 ++++++ tools/binman/etype/ti_secure_rom.py | 233 +++++++++++++++++ tools/binman/etype/x509_cert.py | 87 ++++++- tools/binman/ftest.py | 46 ++++ tools/binman/test/279_ti_secure.dts | 17 ++ tools/binman/test/280_ti_secure_rom.dts | 17 ++ .../test/281_ti_secure_rom_combined.dts | 25 ++ 11 files changed, 830 insertions(+), 8 deletions(-) create mode 100644 board/ti/keys/custMpk.pem create mode 100644 board/ti/keys/ti-degenerate-key.pem create mode 100644 tools/binman/etype/ti_secure.py create mode 100644 tools/binman/etype/ti_secure_rom.py create mode 100644 tools/binman/test/279_ti_secure.dts create mode 100644 tools/binman/test/280_ti_secure_rom.dts create mode 100644 tools/binman/test/281_ti_secure_rom_combined.dts
diff --git a/board/ti/keys/custMpk.pem b/board/ti/keys/custMpk.pem new file mode 100644 index 0000000000..adba378c80 --- /dev/null +++ b/board/ti/keys/custMpk.pem @@ -0,0 +1,51 @@ +-----BEGIN RSA PRIVATE KEY----- +MIIJKQIBAAKCAgEAvxSuSdh/ctNrI83rSA5l3CJN8g5PgvbttfLd23yR+m5Z/9X3 +tt4EHYrM0pXZ0eDEwfhQv/9IDJEiUJpMe4vzlgooJrOk2eCpVUEa+z5bJ2y/ysBx +ry9yIu5GASVirT7HBPaxGLYswBJuD+KbPuWmoKgGRQNBF04WH6l01oRO1nmnELgR +qQ6SHyXdf7Hy0bnyaNgzWUuCfXfM0Zz6I7T7WIjyzerVFvIsdS36YsPBCW7gBnDg +tQcJmWLZ1uTnbG3IggdQk/fi2O3RX+PQns+TVNlf3V3ON2DxqxSKBHtlp7p/30VF +fEuhW65OxpQ9jE6H0pQ8pPOf2vzyNnznDa1aQjfxKoHQbqGnZwMeh+0Au3NKaCgx +ooKaowTB6If/RX6qwZ/UOwXHg/0hcf69fzjJFhlSDuYDM40dHsk2HM1OnYIpiM2b +Kr5sX3uysjp5AGp99a0anR7NWCrPXvROgKs7T9341N40osQg2VkZLYUCXh9osUyN +uREG6S12tViMUKg3bmZ4b4MwRk00n7QYSrm7+nvFrtYyEISEbD+agDM1/E281W5g +VFDPfm2AlwT6jwsg/b2YK6E3vVn9SuxFoQmLF8lyFDO3BV4SXeJaHc4hVPbh6tVV +qifrTQnfGUCCLmaJF2XZbrPWOE6NYRbWdNTeFl9RGdVCuIPSyN5LqWmXto0CAwEA +AQKCAgAzkAwcJ0z1GnId/lJQZno8NhGckRoJuEKbR8dwlCP8VUz6Ca5H7Y9kvXDa +Hs/hn+rYgP6hYOz7XyrIX2rmJ/T6dxEwqGeC1+o59FConcIRWHpE5zuGT6JYJL5F +TuZa48bm4v8VMQvQZOjIZpkIFwao8c6HTwKAnHTB5IN/48I2hCt+Cn3RhfoOZ7Rm +4gkpaSkt+7GXlhXHb82YfujNO+hbktEamhUYlQ9EK70Wa8aqmf3gHxO0JgsEFjW8 +lJaSnultlTW8SDcx3LMUUjCYumECk4oX/VlJfmKYjPlVjkr3QQ+Cm3nNucb4K4hc +c+JL+2ERhSj8RjXL7VgbNgdPnIjvQDJuTNqecTU8xWPYrkOLQpNibbLjnutLkhJz +fMyRtmDtrsey8WiCDuCHkPJ8/f8RjL2zWI9fzTDDIzdlEKouUFGOovaHVnbua6pn +hymcu9d9FV3p2rcbj0ivCs7e8j+vhSxFJEJoAbcQdXCTi/n2uR7pLtoMNiUzsejy +d46Uz+KEU920NTwE2z6JJq8I2vegnxjc7PDDrV3/5rK04B93aXiqvwWseCpxelrI +xaMkRHbXrIXRO6MXQ3N+zNq8Dg3hjGTTvaBKuwgvqLwlXY8+Aa3ooFzEOInIOSsI +XcWqXxt/tgZgsj9RwpC42t8kbA+BkbNk9EIUa+P5kEr2P/fO7QKCAQEA4EtArnOX +D6tQF8uTw8USOZC2P9s/ez1z4jRq3oKP0Kv4tJiuIObJ/dUvGVD7aM5v2xaCfhm8 +xpk09VPUgghfG5jR5qVvQr75kCNToJQudWi4ngk1HwKJzzTO11giFEdybvTUA+Pj +fmxCM0dYYqRWZoj0hLqXlUCwxE74BFIhJVjeYbf+nTQrqpllTLoW7MTZHzGx5SXx +4dNzyVAUH49Yt2D8mgXXCkf5sGLh762wj34b/rR10Kr4O5utGMZrfTRIbuQ1pNjU +m66baPzq+mC0BzqZEW70TgEb7lOr8rcVXLOi3r36omfd9/MHx7iZD6o3K1axSO15 +grD4ZrN7Ac3QJwKCAQEA2heCoBdpvy6YUk8AO2k8qDygTdmPQRuwjjT+Z2fMslBt +D7DkpKwZ6Bl9OclcpiiLHmH+hv65KqYg+tR0RRb7PcogB9El9x7yKkGTPZEYWGky +n8P84rJpKwjnwWQvPQktI1cs3YGvZA9DQTFBavRrwuzgd1oSJq5aPQ2tme0kMvWp +l1/B/cPK+PKCi/Wfisaze1TjijP9qIeUwkdNN6WLrLU3QgsGppcg2I7RQtAIikT6 +GkuiOQAvWMsrJVV6PNrVKz4fJDJ59Rz6jbDHZNi1MEYNxQoB/Pl7QIakbfjWpHLv +8Ey7cB2JKxjQy8tmyl8WNQVbXbE6daPXcMTUmaRAKwKCAQBv1lYMJmq+T2eCVen6 +BbvOpE+bi5EdvEiaFBTtmiBnpjg+pJq+oRU60h/H+c9CNR0lGxY6Fk9An4f+g6xE +ojP6KLsQzJCrsVny+wpp2TlJJcxYULMCIVvhy60PR0zG29E9biqBPhJjKUvhEcQK +e3LxcXyq6fdHXphFajLUxLbuTl+kTgBRFoBnclFGbsubh5PTsA3J+p+fQLZNPPar +veg4l82cZykQYU8pGkUaI3sUMYd3+zd7sqRP5JHs9pMGPRmY4YW2CsAIWIn5UZNB +ARMDP76vKKn8cyUgMuxb+9pU/OVLN2NPs4bEaZQJjAwV+YPEwldny7F47xEM9JVz +EtKlAoIBAQDUt62u3GdGE/p5/ZgqWoDRTyDEDfmN9aYFbmbdEP80xQE7FrxMaZhz +K7laja6SWmUm40nQ/c45bQQp4uLtKHcxU15egX7YRBTLZl5o5IasZR79ebnEm2O8 +l9kEZeU1USf3mmWmP4GExOZCRfqaiYA6BbUCdJXTqKdXeWnkAssV8UrS3JFoJHpq +yo7OWGqefyQ8nRW6jO9SW7uaqtUD+7H6aF5XSk3YWvusfdBZrHNH+fM/hpnZovaL +Us7ogTDS/laA8PyK37jYfMVdQhmZoU1Iomt3zkUWK3gt/aWPpfAlQf4Jka4YspZB +tNiijefaZ1hPqsPs5Joyd/YAhdsfaHc1AoIBAQCn/9j6RRjRaw0ip756oad4AXHz +XBwVB2CrY96qT6Hj9Sq7tGgdskqGkOQkAivBLBizUdcWv0t1yenOsSgasQeMlvlh +B8md9cLvpKXPB3HM3rTDH/xNXe0TpVKLf7SXC8HfDyIweHwMW3QgO2DWrvI4BV/T +ckBatRNQ90HxkqGFhC/Mp529lQlyg3ifxPxJsvZOyPMUnrflAvsKQk5c2ZiQg3nZ +h7I2pjSYgCl+Ib52l8p9bf1kcrVGgPM+auzm496i0RPobFeDBoBvSoznJktHJ7+3 +NnZH+jLiZCODiQPGtQUi+T6eIZUIJF0YASpsCCtUzXCxwW3lYIDNy7UlMivF +-----END RSA PRIVATE KEY----- diff --git a/board/ti/keys/ti-degenerate-key.pem b/board/ti/keys/ti-degenerate-key.pem new file mode 100644 index 0000000000..bd7d3745ad --- /dev/null +++ b/board/ti/keys/ti-degenerate-key.pem @@ -0,0 +1,10 @@ +-----BEGIN RSA PRIVATE KEY----- +MIIBWwIBAAKBgQDRfrnXQaP0k6vRK/gZ+bDflSU6y1JagGeQ/b+QYuiDz14japog +8fRSu5WBsAxaSaySAUwS3L9Ppw+hGMecmyIJ494aMfZTtk1g49gU58joduiRnu7e +QSZHMnehhuNlfD7A2tAAKnxIYuabs8zHYM/SS9Ne7t3kIQMbKfUSzNy6qQIBAQIB +AQJBAOelUA376o6w3HkShXfN+shaOZYqFuTJ9exLMwsLp7DZKXB5F9I4JJ+Vkvho +k6QWs7vkhleLSYUZknXHYm26ZE0CQQDnhTtd4PTBoZPjPXOeYMJFtEdMNy0XP6ey +bcce389ugoY7BEkvASrd8PHgJQHziepgWOG4DGp33c64Hfq4zI3NAgEBAgEBAkA0 +RbK4uqoLciQluesTPU6lBy7Se3Dw0F9xBqlF5SR4KI6q+zQrHpBKyFOofMHZgizR +iCrL55cxEM146zMw3AnF +-----END RSA PRIVATE KEY----- diff --git a/tools/binman/btool/openssl.py b/tools/binman/btool/openssl.py index 3a4dbdd6d7..aad3b61ae2 100644 --- a/tools/binman/btool/openssl.py +++ b/tools/binman/btool/openssl.py @@ -15,6 +15,13 @@ import hashlib from binman import bintool from u_boot_pylib import tools
+ +VALID_SHAS = [256, 384, 512, 224] +SHA_OIDS = {256:'2.16.840.1.101.3.4.2.1', + 384:'2.16.840.1.101.3.4.2.2', + 512:'2.16.840.1.101.3.4.2.3', + 224:'2.16.840.1.101.3.4.2.4'} + class Bintoolopenssl(bintool.Bintool): """openssl tool
@@ -74,6 +81,243 @@ imageSize = INTEGER:{len(indata)} '-sha512'] return self.run_cmd(*args)
+ def x509_cert_sysfw(self, cert_fname, input_fname, key_fname, sw_rev, + config_fname, req_dist_name_dict): + """Create a certificate to be booted by system firmware + + Args: + cert_fname (str): Filename of certificate to create + input_fname (str): Filename containing data to sign + key_fname (str): Filename of .pem file + sw_rev (int): Software revision + config_fname (str): Filename to write fconfig into + req_dist_name_dict (dict): Dictionary containing key-value pairs of + req_distinguished_name section extensions, must contain extensions for + C, ST, L, O, OU, CN and emailAddress + + Returns: + str: Tool output + """ + indata = tools.read_file(input_fname) + hashval = hashlib.sha512(indata).hexdigest() + with open(config_fname, 'w', encoding='utf-8') as outf: + print(f'''[ req ] +distinguished_name = req_distinguished_name +x509_extensions = v3_ca +prompt = no +dirstring_type = nobmp + +[ req_distinguished_name ] +C = {req_dist_name_dict['C']} +ST = {req_dist_name_dict['ST']} +L = {req_dist_name_dict['L']} +O = {req_dist_name_dict['O']} +OU = {req_dist_name_dict['OU']} +CN = {req_dist_name_dict['CN']} +emailAddress = {req_dist_name_dict['emailAddress']} + +[ v3_ca ] +basicConstraints = CA:true +1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv +1.3.6.1.4.1.294.1.34 = ASN1:SEQUENCE:sysfw_image_integrity +1.3.6.1.4.1.294.1.35 = ASN1:SEQUENCE:sysfw_image_load + +[ swrv ] +swrv = INTEGER:{sw_rev} + +[ sysfw_image_integrity ] +shaType = OID:2.16.840.1.101.3.4.2.3 +shaValue = FORMAT:HEX,OCT:{hashval} +imageSize = INTEGER:{len(indata)} + +[ sysfw_image_load ] +destAddr = FORMAT:HEX,OCT:00000000 +authInPlace = INTEGER:2 +''', file=outf) + args = ['req', '-new', '-x509', '-key', key_fname, '-nodes', + '-outform', 'DER', '-out', cert_fname, '-config', config_fname, + '-sha512'] + return self.run_cmd(*args) + + def x509_cert_rom(self, cert_fname, input_fname, key_fname, sw_rev, + config_fname, req_dist_name_dict, cert_type, bootcore, + bootcore_opts, load_addr, sha): + """Create a certificate + + Args: + cert_fname (str): Filename of certificate to create + input_fname (str): Filename containing data to sign + key_fname (str): Filename of .pem file + sw_rev (int): Software revision + config_fname (str): Filename to write fconfig into + req_dist_name_dict (dict): Dictionary containing key-value pairs of + req_distinguished_name section extensions, must contain extensions for + C, ST, L, O, OU, CN and emailAddress + cert_type (int): Certification type + bootcore (int): Booting core + load_addr (int): Load address of image + sha (int): Hash function + + Returns: + str: Tool output + """ + indata = tools.read_file(input_fname) + hashval = hashlib.sha512(indata).hexdigest() + with open(config_fname, 'w', encoding='utf-8') as outf: + print(f''' +[ req ] + distinguished_name = req_distinguished_name + x509_extensions = v3_ca + prompt = no + dirstring_type = nobmp + + [ req_distinguished_name ] +C = {req_dist_name_dict['C']} +ST = {req_dist_name_dict['ST']} +L = {req_dist_name_dict['L']} +O = {req_dist_name_dict['O']} +OU = {req_dist_name_dict['OU']} +CN = {req_dist_name_dict['CN']} +emailAddress = {req_dist_name_dict['emailAddress']} + + [ v3_ca ] + basicConstraints = CA:true + 1.3.6.1.4.1.294.1.1 = ASN1:SEQUENCE:boot_seq + 1.3.6.1.4.1.294.1.2 = ASN1:SEQUENCE:image_integrity + 1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv +# 1.3.6.1.4.1.294.1.4 = ASN1:SEQUENCE:encryption + 1.3.6.1.4.1.294.1.8 = ASN1:SEQUENCE:debug + + [ boot_seq ] + certType = INTEGER:{cert_type} + bootCore = INTEGER:{bootcore} + bootCoreOpts = INTEGER:{bootcore_opts} + destAddr = FORMAT:HEX,OCT:{load_addr:08x} + imageSize = INTEGER:{len(indata)} + + [ image_integrity ] + shaType = OID:{SHA_OIDS[sha]} + shaValue = FORMAT:HEX,OCT:{hashval} + + [ swrv ] + swrv = INTEGER:{sw_rev} + +# [ encryption ] +# initalVector = FORMAT:HEX,OCT:TEST_IMAGE_ENC_IV +# randomString = FORMAT:HEX,OCT:TEST_IMAGE_ENC_RS +# iterationCnt = INTEGER:TEST_IMAGE_KEY_DERIVE_INDEX +# salt = FORMAT:HEX,OCT:TEST_IMAGE_KEY_DERIVE_SALT + + [ debug ] + debugUID = FORMAT:HEX,OCT:0000000000000000000000000000000000000000000000000000000000000000 + debugType = INTEGER:4 + coreDbgEn = INTEGER:0 + coreDbgSecEn = INTEGER:0 +''', file=outf) + args = ['req', '-new', '-x509', '-key', key_fname, '-nodes', + '-outform', 'DER', '-out', cert_fname, '-config', config_fname, + '-sha512'] + return self.run_cmd(*args) + + def x509_cert_rom_combined(self, cert_fname, input_fname, key_fname, sw_rev, + config_fname, req_dist_name_dict, load_addr, sha, total_size, num_comps, + sysfw_inner_cert_ext_boot_sequence_string, dm_data_ext_boot_sequence_string, + imagesize_sbl, hashval_sbl, load_addr_sysfw, imagesize_sysfw, + hashval_sysfw, load_addr_sysfw_data, imagesize_sysfw_data, + hashval_sysfw_data, sysfw_inner_cert_ext_boot_block, + dm_data_ext_boot_block): + """Create a certificate + + Args: + cert_fname (str): Filename of certificate to create + input_fname (str): Filename containing data to sign + key_fname (str): Filename of .pem file + sw_rev (int): Software revision + config_fname (str): Filename to write fconfig into + req_dist_name_dict (dict): Dictionary containing key-value pairs of + req_distinguished_name section extensions, must contain extensions for + C, ST, L, O, OU, CN and emailAddress + cert_type (int): Certification type + bootcore (int): Booting core + load_addr (int): Load address of image + sha (int): Hash function + + Returns: + str: Tool output + """ + indata = tools.read_file(input_fname) + hashval = hashlib.sha512(indata).hexdigest() + sha_type = SHA_OIDS[sha] + with open(config_fname, 'w', encoding='utf-8') as outf: + print(f''' +[ req ] +distinguished_name = req_distinguished_name +x509_extensions = v3_ca +prompt = no +dirstring_type = nobmp + +[ req_distinguished_name ] +C = {req_dist_name_dict['C']} +ST = {req_dist_name_dict['ST']} +L = {req_dist_name_dict['L']} +O = {req_dist_name_dict['O']} +OU = {req_dist_name_dict['OU']} +CN = {req_dist_name_dict['CN']} +emailAddress = {req_dist_name_dict['emailAddress']} + +[ v3_ca ] +basicConstraints = CA:true +1.3.6.1.4.1.294.1.3=ASN1:SEQUENCE:swrv +1.3.6.1.4.1.294.1.9=ASN1:SEQUENCE:ext_boot_info + +[swrv] +swrv=INTEGER:{sw_rev} + +[ext_boot_info] +extImgSize=INTEGER:{total_size} +numComp=INTEGER:{num_comps} +sbl=SEQUENCE:sbl +sysfw=SEQUENCE:sysfw +sysfw_data=SEQUENCE:sysfw_data +{sysfw_inner_cert_ext_boot_sequence_string} +{dm_data_ext_boot_sequence_string} + +[sbl] +compType = INTEGER:1 +bootCore = INTEGER:16 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{load_addr:08x} +compSize = INTEGER:{imagesize_sbl} +shaType = OID:{sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sbl} + +[sysfw] +compType = INTEGER:2 +bootCore = INTEGER:0 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{load_addr_sysfw:08x} +compSize = INTEGER:{imagesize_sysfw} +shaType = OID:{sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sysfw} + +[sysfw_data] +compType = INTEGER:18 +bootCore = INTEGER:0 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{load_addr_sysfw_data:08x} +compSize = INTEGER:{imagesize_sysfw_data} +shaType = OID:{sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sysfw_data} + +{sysfw_inner_cert_ext_boot_block} + +{dm_data_ext_boot_block} + ''', file=outf) + args = ['req', '-new', '-x509', '-key', key_fname, '-nodes', + '-outform', 'DER', '-out', cert_fname, '-config', config_fname, + '-sha512'] + return self.run_cmd(*args) + def fetch(self, method): """Fetch handler for openssl
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 7cfe61dd09..e240d5ce62 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -2473,3 +2473,28 @@ my-combined-ti-board-config { };
+ +.. _etype_ti_secure: + +Entry: ti-secure: Texas Instruments secured binary +------------------------------------------------------------- + +Support for generation of TI secured binary blobs + +Properties / Entry arguments: + - content: List of phandles to entries to sign + - keyfile: Filename of file containing key to sign binary with + - sha: Hash function to be used for signing + +Output files: + - input.<unique_name> - input file passed to openssl + - config.<unique_name> - input file generated for openssl (which is + used as the config file) + - cert.<unique_name> - output file generated by openssl (which is + used as the entry contents) + +openssl signs the provided data, using the TI templated config file and +writes the signature in this entry. This allows verification that the +data is genuine. + + diff --git a/tools/binman/etype/ti_secure.py b/tools/binman/etype/ti_secure.py new file mode 100644 index 0000000000..bf58d359b8 --- /dev/null +++ b/tools/binman/etype/ti_secure.py @@ -0,0 +1,83 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 20 +# Written by Neha Malcom Francis n-francis@ti.com +# + +# Support for generation of TI secured binary blobs + +from collections import OrderedDict +import os + +from binman.entry import EntryArg +from binman.etype.x509_cert import Entry_x509_cert + +import hashlib + +from dtoc import fdt_util +from u_boot_pylib import tools + +class Entry_ti_secure(Entry_x509_cert): + """ + Support for generation of TI secured binary blobs + + Properties / Entry arguments: + - content: List of phandles to entries to sign + - keyfile: Filename of file containing key to sign binary with + - sha: Hash function to be used for signing + + Output files: + - input.<unique_name> - input file passed to openssl + - config.<unique_name> - input file generated for openssl (which is + used as the config file) + - cert.<unique_name> - output file generated by openssl (which is + used as the entry contents) + + openssl signs the provided data, using the TI templated config file and + writes the signature in this entry. This allows verification that the + data is genuine. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.openssl = None + + def ReadNode(self): + super().ReadNode() + self.key_fname = self.GetEntryArgsOrProps([ + EntryArg('keyfile', str)], required=True)[0] + self.sha = fdt_util.GetInt(self._node, 'sha', 512) + self.req_dist_name = {'C': 'US', + 'ST': 'TX', + 'L': 'Dallas', + 'O': 'Texas Instruments Incorporated', + 'OU': 'Processors', + 'CN': 'TI Support', + 'emailAddress': 'support@ti.com'} + + def GetCertificate(self, required): + """Get the contents of this entry + + Args: + required: True if the data must be present, False if it is OK to + return None + + Returns: + bytes content of the entry, which is the signed vblock for the + provided data + """ + return super().GetCertificate(required=required, type='sysfw') + + def ObtainContents(self): + data = self.GetCertificate(False) + if data is None: + return False + self.SetContents(data) + return True + + def ProcessContents(self): + # The blob may have changed due to WriteSymbols() + data = self.GetCertificate(True) + return self.ProcessContentsUpdate(data) + + def AddBintools(self, btools): + super().AddBintools(btools) + self.openssl = self.AddBintool(btools, 'openssl') diff --git a/tools/binman/etype/ti_secure_rom.py b/tools/binman/etype/ti_secure_rom.py new file mode 100644 index 0000000000..1e7bb84aef --- /dev/null +++ b/tools/binman/etype/ti_secure_rom.py @@ -0,0 +1,233 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 20 +# Written by Neha Malcom Francis n-francis@ti.com +# + +# Support for generation of TI secured bootloaders booted by ROM + +from collections import OrderedDict +import os + +from binman.entry import EntryArg +from binman.etype.x509_cert import Entry_x509_cert + +import hashlib + +from dtoc import fdt_util +from u_boot_pylib import tools + +VALID_SHAS = [256, 384, 512, 224] +SHA_OIDS = {256:'2.16.840.1.101.3.4.2.1', + 384:'2.16.840.1.101.3.4.2.2', + 512:'2.16.840.1.101.3.4.2.3', + 224:'2.16.840.1.101.3.4.2.4'} + +class Entry_ti_secure_rom(Entry_x509_cert): + """ + Support for generation of TI secured bootloaders booted by ROM + + Properties / Entry arguments: + - keyfile: Filename of file containing key to sign binary with + - combined: boolean if device follows combined boot flow + - countersign: boolean if device contains countersigned system firmware + - load: load address of SPL + - sw-rev: software revision + - sha: Hash function to be used for signing + - core: core on which bootloader runs, valid cores are 'secure' and 'public' + In case of legacy bootflow: + - content: phandle of SPL + In case of combined bootflow: + - sysfw-inner-cert: boolean if binary contains sysfw inner certificate + - dm-data: boolean if binary contains dm-data binary + - content-sbl: phandle of SPL binary + - content-sysfw: phandle of sysfw binary + - content-sysfw-data: phandle of sysfw-data or tifs-data binary + - content-sysfw-inner-cert (optional): phandle of sysfw inner certificate binary + - content-dm-data (optional): phandle of dm-data binary + - load-sysfw: load address of sysfw binary + - load-sysfw-data: load address of sysfw-data or tifs-data binary + - load-sysfw-inner-cert (optional): load address of sysfw inner certificate binary + - load-dm-data (optional): load address of dm-data binary + + + Output files: + - input.<unique_name> - input file passed to openssl + - config.<unique_name> - input file generated for openssl (which is + used as the config file) + - cert.<unique_name> - output file generated by openssl (which is + used as the entry contents) + + openssl signs the provided data, using the TI templated config file and + writes the signature in this entry. This allows verification that the + data is genuine.""" + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.openssl = None + + def ReadNode(self): + super().ReadNode() + self.combined = fdt_util.GetBool(self._node, 'combined', False) + self.countersign = fdt_util.GetBool(self._node, 'countersign', False) + self.load_addr = fdt_util.GetInt(self._node, 'load', 0x00000000) + self.sw_rev = fdt_util.GetInt(self._node, 'sw-rev', 1) + self.sha = fdt_util.GetInt(self._node, 'sha', 512) + self.core = fdt_util.GetString(self._node, 'core', 'secure') + self.key_fname = self.GetEntryArgsOrProps([ + EntryArg('keyfile', str)], required=True)[0] + if self.combined: + self.sysfw_inner_cert = fdt_util.GetBool(self._node, 'sysfw-inner-cert', False) + self.load_addr_sysfw = fdt_util.GetInt(self._node, 'load-sysfw', 0x00000000) + self.load_addr_sysfw_data = fdt_util.GetInt(self._node, 'load-sysfw-data', 0x00000000) + self.dm_data = fdt_util.GetBool(self._node, 'dm-data', False) + if self.dm_data: + self.load_addr_dm_data = fdt_util.GetInt(self._node, 'load-dm-data', 0x00000000) + self.req_dist_name = {'C': 'US', + 'ST': 'TX', + 'L': 'Dallas', + 'O': 'Texas Instruments Incorporated', + 'OU': 'Processors', + 'CN': 'TI Support', + 'emailAddress': 'support@ti.com'} + + def NonCombinedGetCertificate(self, required): + if self.core == 'secure': + if self.countersign: + self.cert_type = 2 + else: + self.cert_type = 3 + self.bootcore = 0 + self.bootcore_opts = 32 + else: + self.cert_type = 1 + self.bootcore = 16 + if self.combined: + self.bootcore_opts = 32 + else: + self.bootcore_opts = 0 + return super().GetCertificate(required=required, type='rom') + + def CombinedGetCertificate(self, required): + uniq = self.GetUniqueName() + + self.num_comps = 3 + self.sha_type = SHA_OIDS[self.sha] + + # sbl + self.content = fdt_util.GetPhandleList(self._node, 'content-sbl') + input_data_sbl = self.GetContents(required) + if input_data_sbl is None: + return None + + input_fname_sbl = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sbl, input_data_sbl) + + indata_sbl = tools.read_file(input_fname_sbl) + self.hashval_sbl = hashlib.sha512(indata_sbl).hexdigest() + self.imagesize_sbl = len(indata_sbl) + + # sysfw + self.content = fdt_util.GetPhandleList(self._node, 'content-sysfw') + input_data_sysfw = self.GetContents(required) + if input_data_sysfw is None: + return None + + input_fname_sysfw = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sysfw, input_data_sysfw) + + indata_sysfw = tools.read_file(input_fname_sysfw) + self.hashval_sysfw = hashlib.sha512(indata_sysfw).hexdigest() + self.imagesize_sysfw = len(indata_sysfw) + + # sysfw data + self.content = fdt_util.GetPhandleList(self._node, 'content-sysfw-data') + input_data_sysfw_data = self.GetContents(required) + if input_data_sysfw_data is None: + return None + + input_fname_sysfw_data = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sysfw_data, input_data_sysfw_data) + + indata_sysfw_data = tools.read_file(input_fname_sysfw_data) + self.hashval_sysfw_data = hashlib.sha512(indata_sysfw_data).hexdigest() + self.imagesize_sysfw_data = len(indata_sysfw_data) + + # sysfw inner cert + if self.sysfw_inner_cert: + self.content = fdt_util.GetPhandleList(self._node, 'content-sysfw-inner-cert') + input_data_sysfw_inner_cert = self.GetContents(required) + if input_data_sysfw_inner_cert is None: + return None + + input_fname_sysfw_inner_cert = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sysfw_inner_cert, input_data_sysfw_inner_cert) + + indata_sysfw_inner_cert = tools.read_file(input_fname_sysfw_inner_cert) + hashval_sysfw_inner_cert = hashlib.sha512(indata_sysfw_inner_cert).hexdigest() + imagesize_sysfw_inner_cert = len(indata_sysfw_inner_cert) + self.num_comps += 1 + self.sysfw_inner_cert_ext_boot_sequence_string = "sysfw_inner_cert=SEQUENCE:sysfw_inner_cert" + self.sysfw_inner_cert_ext_boot_block = f"""[sysfw_inner_cert] +compType = INTEGER:3 +bootCore = INTEGER:0 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:00000000 +compSize = INTEGER:{imagesize_sysfw_inner_cert} +shaType = OID:{self.sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sysfw_inner_cert}""" + else: + self.sysfw_inner_cert_ext_boot_block = "" + self.sysfw_inner_cert_ext_boot_sequence_string = "" + imagesize_sysfw_inner_cert = 0 + + # dm data + if self.dm_data: + self.content = fdt_util.GetPhandleList(self._node, 'content-dm-data') + input_data_dm_data = self.GetContents(required) + if input_data_dm_data is None: + return None + + input_fname_dm_data = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_dm_data, input_data_dm_data) + + indata_dm_data = tools.read_file(input_fname_dm_data) + hashval_dm_data = hashlib.sha512(indata_dm_data).hexdigest() + imagesize_dm_data = len(indata_dm_data) + self.num_comps += 1 + self.dm_data_ext_boot_sequence_string = "dm_data=SEQUENCE:dm_data" + self.dm_data_ext_boot_block = f"""[dm_data] +compType = INTEGER:17 +bootCore = INTEGER:16 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{self.load_addr_dm_data:08x} +compSize = INTEGER:{imagesize_dm_data} +shaType = OID:{self.sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_dm_data}""" + else: + self.dm_data_ext_boot_sequence_string = "" + self.dm_data_ext_boot_block = "" + imagesize_dm_data = 0 + + self.total_size = self.imagesize_sbl + self.imagesize_sysfw + self.imagesize_sysfw_data + imagesize_sysfw_inner_cert + imagesize_dm_data + return super().GetCertificate(required=required, type='rom-combined') + + def GetCertificate(self, required): + if self.combined: + return self.CombinedGetCertificate(required) + else: + return self.NonCombinedGetCertificate(required) + + def ObtainContents(self): + data = self.GetCertificate(False) + if data is None: + return False + self.SetContents(data) + return True + + def ProcessContents(self): + # The blob may have changed due to WriteSymbols() + data = self.GetCertificate(True) + return self.ProcessContentsUpdate(data) + + def AddBintools(self, btools): + super().AddBintools(btools) + self.openssl = self.AddBintool(btools, 'openssl') diff --git a/tools/binman/etype/x509_cert.py b/tools/binman/etype/x509_cert.py index f80a6ec2d1..d028cfe38c 100644 --- a/tools/binman/etype/x509_cert.py +++ b/tools/binman/etype/x509_cert.py @@ -31,6 +31,26 @@ class Entry_x509_cert(Entry_collection): def __init__(self, section, etype, node): super().__init__(section, etype, node) self.openssl = None + self.req_dist_name = None + self.cert_type = None + self.bootcore = None + self.bootcore_opts = None + self.load_addr = None + self.sha = None + self.total_size = None + self.num_comps = None + self.sysfw_inner_cert_ext_boot_sequence_string = None + self.dm_data_ext_boot_sequence_string = None + self.imagesize_sbl = None + self.hashval_sbl = None + self.load_addr_sysfw = None + self.imagesize_sysfw = None + self.hashval_sysfw = None + self.load_addr_sysfw_data = None + self.imagesize_sysfw_data = None + self.hashval_sysfw_data = None + self.sysfw_inner_cert_ext_boot_block = None + self.dm_data_ext_boot_block = None
def ReadNode(self): super().ReadNode() @@ -38,13 +58,16 @@ class Entry_x509_cert(Entry_collection): self._cert_rev = fdt_util.GetInt(self._node, 'cert-revision-int', 0) self.key_fname = self.GetEntryArgsOrProps([ EntryArg('keyfile', str)], required=True)[0] + self.sw_rev = fdt_util.GetInt(self._node, 'sw-rev', 1)
- def GetCertificate(self, required): + def GetCertificate(self, required, type='generic'): """Get the contents of this entry
Args: required: True if the data must be present, False if it is OK to return None + type: Type of x509 certificate to generate, current supported ones are + 'generic', 'sysfw', 'rom'
Returns: bytes content of the entry, which is the signed vblock for the @@ -60,13 +83,61 @@ class Entry_x509_cert(Entry_collection): input_fname = tools.get_output_filename('input.%s' % uniq) config_fname = tools.get_output_filename('config.%s' % uniq) tools.write_file(input_fname, input_data) - stdout = self.openssl.x509_cert( - cert_fname=output_fname, - input_fname=input_fname, - key_fname=self.key_fname, - cn=self._cert_ca, - revision=self._cert_rev, - config_fname=config_fname) + if type == 'generic': + stdout = self.openssl.x509_cert( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + cn=self._cert_ca, + revision=self._cert_rev, + config_fname=config_fname) + elif type == 'sysfw': + stdout = self.openssl.x509_cert_sysfw( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + config_fname=config_fname, + sw_rev=self.sw_rev, + req_dist_name_dict=self.req_dist_name) + elif type == 'rom': + stdout = self.openssl.x509_cert_rom( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + config_fname=config_fname, + sw_rev=self.sw_rev, + req_dist_name_dict=self.req_dist_name, + cert_type=self.cert_type, + bootcore=self.bootcore, + bootcore_opts=self.bootcore_opts, + load_addr=self.load_addr, + sha=self.sha + ) + elif type == 'rom-combined': + stdout = self.openssl.x509_cert_rom_combined( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + config_fname=config_fname, + sw_rev=self.sw_rev, + req_dist_name_dict=self.req_dist_name, + load_addr=self.load_addr, + sha=self.sha, + total_size=self.total_size, + num_comps=self.num_comps, + sysfw_inner_cert_ext_boot_sequence_string=self.sysfw_inner_cert_ext_boot_sequence_string, + dm_data_ext_boot_sequence_string=self.dm_data_ext_boot_sequence_string, + imagesize_sbl=self.imagesize_sbl, + hashval_sbl=self.hashval_sbl, + load_addr_sysfw=self.load_addr_sysfw, + imagesize_sysfw=self.imagesize_sysfw, + hashval_sysfw=self.hashval_sysfw, + load_addr_sysfw_data=self.load_addr_sysfw_data, + imagesize_sysfw_data=self.imagesize_sysfw_data, + hashval_sysfw_data=self.hashval_sysfw_data, + sysfw_inner_cert_ext_boot_block=self.sysfw_inner_cert_ext_boot_block, + dm_data_ext_boot_block=self.dm_data_ext_boot_block + ) if stdout is not None: data = tools.read_file(output_fname) else: diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 28b5bd19d5..61b71aa87e 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -98,6 +98,7 @@ PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') TI_BOARD_CONFIG_DATA = b'\x00\x01' +TI_UNSECURE_DATA = b'unsecuredata'
# Subdirectory of the input dir to use to put test FDTs TEST_FDT_SUBDIR = 'fdts' @@ -208,6 +209,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) TestFunctional._MakeInputFile('rockchip-tpl.bin', ROCKCHIP_TPL_DATA) + TestFunctional._MakeInputFile('ti_unsecure.bin', TI_UNSECURE_DATA)
# Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR, @@ -6688,5 +6690,49 @@ fdt fdtmap Extract the devicetree blob from the fdtmap configlen_noheader = TI_BOARD_CONFIG_DATA*4 self.assertGreater(data, configlen_noheader)
+ def testPackTiSecure(self): + """Test that an image with a TI secured binary can be created""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + data = self._DoReadFileDtb('279_ti_secure.dts', + entry_args=entry_args)[0] + self.assertGreater(len(data), len(TI_UNSECURE_DATA)) + + def testPackTiSecureMissingTool(self): + """Test that an image with a TI secured binary (non-functional) can be created + when openssl is missing""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + with test_util.capture_sys_output() as (_, stderr): + self._DoTestFile('279_ti_secure.dts', + force_missing_bintools='openssl', + entry_args=entry_args) + err = stderr.getvalue() + self.assertRegex(err, "Image 'image'.*missing bintools.*: openssl") + + def testPackTiSecureROM(self): + """Test that a ROM image with a TI secured binary can be created""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + data = self._DoReadFileDtb('280_ti_secure_rom.dts', + entry_args=entry_args)[0] + self.assertGreater(len(data), len(TI_UNSECURE_DATA)) + + def testPackTiSecureROMCombined(self): + """Test that a ROM image with a TI secured binary can be created""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + data = self._DoReadFileDtb('281_ti_secure_rom_combined.dts', + entry_args=entry_args)[0] + self.assertGreater(len(data), len(TI_UNSECURE_DATA)) + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/279_ti_secure.dts b/tools/binman/test/279_ti_secure.dts new file mode 100644 index 0000000000..941d0ab4ca --- /dev/null +++ b/tools/binman/test/279_ti_secure.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure { + content = <&unsecure_binary>; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +}; diff --git a/tools/binman/test/280_ti_secure_rom.dts b/tools/binman/test/280_ti_secure_rom.dts new file mode 100644 index 0000000000..d1313769f4 --- /dev/null +++ b/tools/binman/test/280_ti_secure_rom.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure-rom { + content = <&unsecure_binary>; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +}; diff --git a/tools/binman/test/281_ti_secure_rom_combined.dts b/tools/binman/test/281_ti_secure_rom_combined.dts new file mode 100644 index 0000000000..bf872739bc --- /dev/null +++ b/tools/binman/test/281_ti_secure_rom_combined.dts @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure-rom { + content = <&unsecure_binary>; + content-sbl = <&unsecure_binary>; + content-sysfw = <&unsecure_binary>; + content-sysfw-data = <&unsecure_binary>; + content-sysfw-inner-cert = <&unsecure_binary>; + content-dm-data = <&unsecure_binary>; + combined; + sysfw-inner-cert; + dm-data; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +};
Looks like this Copyright string got broken, I see this in a couple spots.
Andrew
Hi Andrew,
Andrew
Right, I'll clean those up. Thanks!
kHi Neha,
- def x509_cert_sysfw(self, cert_fname, input_fname, key_fname, sw_rev,
Args:
Returns:
str: Tool output
print(f'''[ req ]
There's a lot of duplication here, but at least it is in one file.
Would it make sense, for example, to have a function like
add_dn(buf, dict)
which adds the req_distinguished_name to a stringio buffer? Then that could be calls from multiple places.
Also, please check test coverage (binman test -T). That should be 100% so you will need to add tests for failing cases as well.
Hi Simon
On 06/04/23 00:07, Simon Glass wrote:
kHi Neha,
- class Bintoolopenssl(bintool.Bintool): """openssl tool
Args:
Returns:
str: Tool output
print(f'''[ req ]
add_dn(buf, dict)
Right that is possible, plus it gives an outline if this etype can be simplified in the future similarly.
I'll take note of these corrections and send v3 soon, thanks!
Board config binary artifacts must be populated in the R5 output directory to be used by binman to package sysfw.itb and tiboot3.bin.
For devices that follow combined flow, these board configuration binaries must again be packaged into a combined board configuration blobs to be used by binman to package tiboot3.bin.
Modify config.mk to generate all the board configuration binaries as well as the combined blob binaries.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/config.mk | 50 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 50 insertions(+)
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index 9306f2627d..b280a6a048 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -39,6 +39,56 @@ $(warning "WARNING: Software revision file not found. Default may not work on HS endif endif
+O ?= . + +# Board config binary artifacts necessary for packaging of tiboot3.bin +# and sysfw.itb by binman, currently for general purpose devices and +# devices that require sysfw.itb in ROM boot image. + +ifdef CONFIG_BINMAN + +ifndef CONFIG_TARGET_J7200_R5_EVM +BOARD_YAML = $(srctree)/board/ti/$(BOARD)/board-cfg.yaml +RM_YAML = $(srctree)/board/ti/$(BOARD)/rm-cfg.yaml +SEC_YAML = $(srctree)/board/ti/$(BOARD)/sec-cfg.yaml +PM_YAML = $(srctree)/board/ti/$(BOARD)/pm-cfg.yaml +else +BOARD_YAML = $(srctree)/board/ti/$(BOARD)/board-cfg_j7200.yaml +RM_YAML = $(srctree)/board/ti/$(BOARD)/rm-cfg_j7200.yaml +SEC_YAML = $(srctree)/board/ti/$(BOARD)/sec-cfg_j7200.yaml +PM_YAML = $(srctree)/board/ti/$(BOARD)/pm-cfg_j7200.yaml +endif + +CUSTOMER_KEY = $(srctree)/board/ti/keys/custMpk.pem +TI_DEGENERATE_KEY = $(srctree)/board/ti/keys/ti-degenerate-key.pem + +SCHEMA_YAML = $(srctree)/board/ti/common/schema.yaml + +board-cfg.yaml: $(BOARD_YAML) + @cp $< $@ +rm-cfg.yaml: $(RM_YAML) + @cp $< $@ +sec-cfg.yaml: $(SEC_YAML) + @cp $< $@ +pm-cfg.yaml: $(PM_YAML) + @cp $< $@ + +schema.yaml: $(SCHEMA_YAML) + @cp $< $@ +custMpk.pem: $(CUSTOMER_KEY) + @cp $< $@ +ti-degenerate-key.pem: $(TI_DEGENERATE_KEY) + @cp $< $@ + +INPUTS-y += board-cfg.yaml +INPUTS-y += rm-cfg.yaml +INPUTS-y += sec-cfg.yaml +INPUTS-y += pm-cfg.yaml +INPUTS-y += schema.yaml +INPUTS-y += custMpk.pem +INPUTS-y += ti-degenerate-key.pem +endif + # tiboot3.bin is mandated by ROM and ROM only supports R5 boot. # So restrict tiboot3.bin creation for CPU_V7R. ifdef CONFIG_CPU_V7R
Schema file in YAML must be provided in board/ti/common for validating input config files and packaging system firmware. The schema includes entries for rm-cfg, board-cfg, pm-cfg and sec-cfg.
Board config file must be provided in board/ti/<devicename> in YAML. These can then be consumed for generation of binaries to package system firmware. Added YAML config for J721E in particular.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/common/schema.yaml | 355 +++++ board/ti/j721e/board-cfg.yaml | 37 + board/ti/j721e/pm-cfg.yaml | 13 + board/ti/j721e/rm-cfg.yaml | 2757 +++++++++++++++++++++++++++++++++ board/ti/j721e/sec-cfg.yaml | 379 +++++ 5 files changed, 3541 insertions(+) create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/board-cfg.yaml create mode 100644 board/ti/j721e/pm-cfg.yaml create mode 100644 board/ti/j721e/rm-cfg.yaml create mode 100644 board/ti/j721e/sec-cfg.yaml
diff --git a/board/ti/common/schema.yaml b/board/ti/common/schema.yaml new file mode 100644 index 0000000000..070ff797e0 --- /dev/null +++ b/board/ti/common/schema.yaml @@ -0,0 +1,355 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Config schema for TI K3 devices +# + +--- + +definitions: + u8: + type: integer + minimum: 0 + maximum: 0xff + u16: + type: integer + minimum: 0 + maximum: 0xffff + u32: + type: integer + minimum: 0 + maximum: 0xffffffff + + + +type: object +properties: + pm-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + board-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + control: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + main_isolation_enable: + $ref: "#/definitions/u8" + main_isolation_hostid: + $ref: "#/definitions/u16" + + + secproxy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + scaling_factor: + $ref: "#/definitions/u8" + scaling_profile: + $ref: "#/definitions/u8" + disable_main_nav_secure_proxy: + $ref: "#/definitions/u8" + + msmc: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + msmc_cache_size: + $ref: "#/definitions/u8" + debug_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + trace_dst_enables: + $ref: "#/definitions/u16" + trace_src_enables: + $ref: "#/definitions/u16" + + sec-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + processor_acl_list: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + proc_acl_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + processor_id: + $ref: "#/definitions/u8" + proc_access_master: + $ref: "#/definitions/u8" + proc_access_secondary: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + host_hierarchy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_hierarchy_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + supervisor_host_id: + $ref: "#/definitions/u8" + + otp_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + otp_entry: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + host_perms: + $ref: "#/definitions/u8" + write_host_id: + $ref: "#/definitions/u8" + + dkek_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allowed_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + allow_dkek_export_tisci: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + + sa2ul_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + rsvd: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + sec_dbg_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allow_jtag_unlock: + $ref: "#/definitions/u8" + allow_wildcard_unlock: + $ref: "#/definitions/u8" + allowed_debug_level_rsvd: + $ref: "#/definitions/u8" + rsvd: + $ref: "#/definitions/u8" + min_cert_rev: + $ref: "#/definitions/u32" + jtag_unlock_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + + sec_handover_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + handover_msg_sender: + $ref: "#/definitions/u8" + handover_to_host_id: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + rm-cfg: + type: object + properties: + rm_boardcfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + host_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_cfg_entries: + type: array + minItems: 0 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + allowed_atype: + $ref: "#/definitions/u8" + allowed_qos: + $ref: "#/definitions/u16" + allowed_orderid: + $ref: "#/definitions/u32" + allowed_priority: + $ref: "#/definitions/u16" + allowed_sched_priority: + $ref: "#/definitions/u8" + resasg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + resasg_entries_size: + $ref: "#/definitions/u16" + reserved: + $ref: "#/definitions/u16" + + resasg_entries: + type: array + minItems: 0 + maxItems: 418 + items: + type: object + properties: + start_resource: + $ref: "#/definitions/u16" + num_resource: + $ref: "#/definitions/u16" + type: + $ref: "#/definitions/u16" + host_id: + $ref: "#/definitions/u8" + reserved: + $ref: "#/definitions/u8" diff --git a/board/ti/j721e/board-cfg.yaml b/board/ti/j721e/board-cfg.yaml new file mode 100644 index 0000000000..9f5e00b3dc --- /dev/null +++ b/board/ti/j721e/board-cfg.yaml @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J721E +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable: 0x5A + main_isolation_hostid: 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor: 0x1 + scaling_profile: 0x1 + disable_main_nav_secure_proxy: 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size: 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables: 0x00 + trace_src_enables: 0x00 + diff --git a/board/ti/j721e/pm-cfg.yaml b/board/ti/j721e/pm-cfg.yaml new file mode 100644 index 0000000000..40a8dfb7af --- /dev/null +++ b/board/ti/j721e/pm-cfg.yaml @@ -0,0 +1,13 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for J721E +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + diff --git a/board/ti/j721e/rm-cfg.yaml b/board/ti/j721e/rm-cfg.yaml new file mode 100644 index 0000000000..2fc41f5e87 --- /dev/null +++ b/board/ti/j721e/rm-cfg.yaml @@ -0,0 +1,2757 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for J721E +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size: 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #2 + host_id: 5 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #3 + host_id: 12 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #4 + host_id: 13 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #5 + host_id: 21 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #6 + host_id: 26 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #7 + host_id: 28 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #8 + host_id: 35 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #9 + host_id: 37 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #10 + host_id: 40 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #11 + host_id: 42 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size: 8 + resasg_entries_size: 3344 + reserved: 0 + resasg_entries: + - + start_resource: 4 + num_resource: 93 + type: 7744 + host_id: 26 + reserved: 0 + - + start_resource: 4 + num_resource: 93 + type: 7808 + host_id: 28 + reserved: 0 + - + start_resource: 0 + num_resource: 32 + type: 7872 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 32 + type: 8192 + host_id: 3 + reserved: 0 + - + start_resource: 32 + num_resource: 32 + type: 8192 + host_id: 5 + reserved: 0 + - + start_resource: 0 + num_resource: 24 + type: 8320 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 24 + type: 8320 + host_id: 5 + reserved: 0 + - + start_resource: 0 + num_resource: 8 + type: 8384 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 8 + type: 8384 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 4 + type: 8384 + host_id: 40 + reserved: 0 + - + start_resource: 20 + num_resource: 4 + type: 8384 + host_id: 42 + reserved: 0 + - + start_resource: 24 + num_resource: 4 + type: 8384 + host_id: 35 + reserved: 0 + - + start_resource: 28 + num_resource: 4 + type: 8384 + host_id: 37 + reserved: 0 + - + start_resource: 32 + num_resource: 4 + type: 8384 + host_id: 26 + reserved: 0 + - + start_resource: 36 + num_resource: 4 + type: 8384 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 12 + type: 8384 + host_id: 12 + reserved: 0 + - + start_resource: 52 + num_resource: 12 + type: 8384 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 128 + type: 8576 + host_id: 35 + reserved: 0 + - + start_resource: 128 + num_resource: 128 + type: 8576 + host_id: 37 + reserved: 0 + - + start_resource: 0 + num_resource: 128 + type: 8640 + host_id: 40 + reserved: 0 + - + start_resource: 128 + num_resource: 128 + type: 8640 + host_id: 42 + reserved: 0 + - + start_resource: 0 + num_resource: 48 + type: 8704 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 8 + type: 8768 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 8 + type: 8768 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 6 + type: 8768 + host_id: 12 + reserved: 0 + - + start_resource: 22 + num_resource: 6 + type: 8768 + host_id: 13 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 8768 + host_id: 35 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 8768 + host_id: 37 + reserved: 0 + - + start_resource: 0 + num_resource: 64 + type: 13258 + host_id: 128 + reserved: 0 + - + start_resource: 20480 + num_resource: 1024 + type: 13261 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 64 + type: 13322 + host_id: 128 + reserved: 0 + - + start_resource: 22528 + num_resource: 1024 + type: 13325 + host_id: 128 + reserved: 0 + - + start_resource: 38 + num_resource: 86 + type: 13386 + host_id: 12 + reserved: 0 + - + start_resource: 124 + num_resource: 32 + type: 13386 + host_id: 13 + reserved: 0 + - + start_resource: 156 + num_resource: 12 + type: 13386 + host_id: 40 + reserved: 0 + - + start_resource: 168 + num_resource: 12 + type: 13386 + host_id: 42 + reserved: 0 + - + start_resource: 180 + num_resource: 12 + type: 13386 + host_id: 21 + reserved: 0 + - + start_resource: 192 + num_resource: 12 + type: 13386 + host_id: 26 + reserved: 0 + - + start_resource: 204 + num_resource: 12 + type: 13386 + host_id: 28 + reserved: 0 + - + start_resource: 216 + num_resource: 28 + type: 13386 + host_id: 35 + reserved: 0 + - + start_resource: 244 + num_resource: 8 + type: 13386 + host_id: 37 + reserved: 0 + - + start_resource: 252 + num_resource: 4 + type: 13386 + host_id: 128 + reserved: 0 + - + start_resource: 38 + num_resource: 1024 + type: 13389 + host_id: 12 + reserved: 0 + - + start_resource: 1062 + num_resource: 512 + type: 13389 + host_id: 13 + reserved: 0 + - + start_resource: 1574 + num_resource: 32 + type: 13389 + host_id: 3 + reserved: 0 + - + start_resource: 1606 + num_resource: 32 + type: 13389 + host_id: 5 + reserved: 0 + - + start_resource: 1638 + num_resource: 256 + type: 13389 + host_id: 40 + reserved: 0 + - + start_resource: 1894 + num_resource: 256 + type: 13389 + host_id: 42 + reserved: 0 + - + start_resource: 2150 + num_resource: 256 + type: 13389 + host_id: 21 + reserved: 0 + - + start_resource: 2406 + num_resource: 256 + type: 13389 + host_id: 26 + reserved: 0 + - + start_resource: 2662 + num_resource: 256 + type: 13389 + host_id: 28 + reserved: 0 + - + start_resource: 2918 + num_resource: 512 + type: 13389 + host_id: 35 + reserved: 0 + - + start_resource: 3430 + num_resource: 256 + type: 13389 + host_id: 37 + reserved: 0 + - + start_resource: 3686 + num_resource: 922 + type: 13389 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 4 + type: 13440 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13440 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 4 + type: 13440 + host_id: 3 + reserved: 0 + - + start_resource: 12 + num_resource: 4 + type: 13440 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 4 + type: 13440 + host_id: 40 + reserved: 0 + - + start_resource: 20 + num_resource: 4 + type: 13440 + host_id: 42 + reserved: 0 + - + start_resource: 24 + num_resource: 4 + type: 13440 + host_id: 21 + reserved: 0 + - + start_resource: 28 + num_resource: 4 + type: 13440 + host_id: 26 + reserved: 0 + - + start_resource: 32 + num_resource: 4 + type: 13440 + host_id: 28 + reserved: 0 + - + start_resource: 36 + num_resource: 12 + type: 13440 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 4 + type: 13440 + host_id: 37 + reserved: 0 + - + start_resource: 52 + num_resource: 12 + type: 13440 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13504 + host_id: 128 + reserved: 0 + - + start_resource: 440 + num_resource: 150 + type: 13505 + host_id: 12 + reserved: 0 + - + start_resource: 590 + num_resource: 40 + type: 13505 + host_id: 13 + reserved: 0 + - + start_resource: 630 + num_resource: 6 + type: 13505 + host_id: 3 + reserved: 0 + - + start_resource: 636 + num_resource: 6 + type: 13505 + host_id: 5 + reserved: 0 + - + start_resource: 642 + num_resource: 10 + type: 13505 + host_id: 40 + reserved: 0 + - + start_resource: 652 + num_resource: 10 + type: 13505 + host_id: 42 + reserved: 0 + - + start_resource: 662 + num_resource: 32 + type: 13505 + host_id: 21 + reserved: 0 + - + start_resource: 694 + num_resource: 38 + type: 13505 + host_id: 26 + reserved: 0 + - + start_resource: 732 + num_resource: 12 + type: 13505 + host_id: 28 + reserved: 0 + - + start_resource: 744 + num_resource: 182 + type: 13505 + host_id: 35 + reserved: 0 + - + start_resource: 926 + num_resource: 40 + type: 13505 + host_id: 37 + reserved: 0 + - + start_resource: 966 + num_resource: 8 + type: 13505 + host_id: 128 + reserved: 0 + - + start_resource: 316 + num_resource: 8 + type: 13506 + host_id: 12 + reserved: 0 + - + start_resource: 324 + num_resource: 2 + type: 13506 + host_id: 3 + reserved: 0 + - + start_resource: 324 + num_resource: 0 + type: 13506 + host_id: 13 + reserved: 0 + - + start_resource: 326 + num_resource: 2 + type: 13506 + host_id: 5 + reserved: 0 + - + start_resource: 328 + num_resource: 2 + type: 13506 + host_id: 40 + reserved: 0 + - + start_resource: 330 + num_resource: 2 + type: 13506 + host_id: 42 + reserved: 0 + - + start_resource: 332 + num_resource: 2 + type: 13506 + host_id: 21 + reserved: 0 + - + start_resource: 334 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + - + start_resource: 342 + num_resource: 2 + type: 13506 + host_id: 28 + reserved: 0 + - + start_resource: 344 + num_resource: 4 + type: 13506 + host_id: 35 + reserved: 0 + - + start_resource: 348 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + - + start_resource: 349 + num_resource: 28 + type: 13506 + host_id: 12 + reserved: 0 + - + start_resource: 377 + num_resource: 20 + type: 13506 + host_id: 13 + reserved: 0 + - + start_resource: 397 + num_resource: 4 + type: 13506 + host_id: 40 + reserved: 0 + - + start_resource: 401 + num_resource: 4 + type: 13506 + host_id: 42 + reserved: 0 + - + start_resource: 405 + num_resource: 4 + type: 13506 + host_id: 21 + reserved: 0 + - + start_resource: 409 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + - + start_resource: 417 + num_resource: 6 + type: 13506 + host_id: 28 + reserved: 0 + - + start_resource: 423 + num_resource: 16 + type: 13506 + host_id: 35 + reserved: 0 + - + start_resource: 439 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13507 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13507 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13507 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13507 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13507 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13507 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13507 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13507 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13507 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13507 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13507 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13507 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13507 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13507 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13507 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13507 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 10 + type: 13507 + host_id: 35 + reserved: 0 + - + start_resource: 133 + num_resource: 6 + type: 13507 + host_id: 37 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13507 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13508 + host_id: 21 + reserved: 0 + - + start_resource: 156 + num_resource: 6 + type: 13508 + host_id: 26 + reserved: 0 + - + start_resource: 162 + num_resource: 6 + type: 13508 + host_id: 28 + reserved: 0 + - + start_resource: 168 + num_resource: 2 + type: 13508 + host_id: 35 + reserved: 0 + - + start_resource: 170 + num_resource: 2 + type: 13508 + host_id: 37 + reserved: 0 + - + start_resource: 172 + num_resource: 96 + type: 13508 + host_id: 35 + reserved: 0 + - + start_resource: 268 + num_resource: 32 + type: 13508 + host_id: 37 + reserved: 0 + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 12 + reserved: 0 + - + start_resource: 304 + num_resource: 4 + type: 13509 + host_id: 12 + reserved: 0 + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 35 + reserved: 0 + - + start_resource: 308 + num_resource: 6 + type: 13509 + host_id: 35 + reserved: 0 + - + start_resource: 314 + num_resource: 2 + type: 13509 + host_id: 128 + reserved: 0 + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 12 + reserved: 0 + - + start_resource: 300 + num_resource: 2 + type: 13510 + host_id: 12 + reserved: 0 + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 35 + reserved: 0 + - + start_resource: 302 + num_resource: 2 + type: 13510 + host_id: 35 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13511 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13511 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13511 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13512 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13512 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 5 + type: 13514 + host_id: 12 + reserved: 0 + - + start_resource: 7 + num_resource: 1 + type: 13514 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 3 + type: 13515 + host_id: 12 + reserved: 0 + - + start_resource: 3 + num_resource: 2 + type: 13515 + host_id: 13 + reserved: 0 + - + start_resource: 5 + num_resource: 1 + type: 13515 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 1 + type: 13515 + host_id: 5 + reserved: 0 + - + start_resource: 7 + num_resource: 3 + type: 13515 + host_id: 40 + reserved: 0 + - + start_resource: 10 + num_resource: 3 + type: 13515 + host_id: 42 + reserved: 0 + - + start_resource: 13 + num_resource: 3 + type: 13515 + host_id: 21 + reserved: 0 + - + start_resource: 16 + num_resource: 3 + type: 13515 + host_id: 26 + reserved: 0 + - + start_resource: 19 + num_resource: 3 + type: 13515 + host_id: 28 + reserved: 0 + - + start_resource: 22 + num_resource: 6 + type: 13515 + host_id: 35 + reserved: 0 + - + start_resource: 28 + num_resource: 3 + type: 13515 + host_id: 37 + reserved: 0 + - + start_resource: 31 + num_resource: 1 + type: 13515 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13568 + host_id: 12 + reserved: 0 + - + start_resource: 156 + num_resource: 16 + type: 13568 + host_id: 13 + reserved: 0 + - + start_resource: 172 + num_resource: 128 + type: 13568 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13569 + host_id: 128 + reserved: 0 + - + start_resource: 49152 + num_resource: 1024 + type: 13570 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13571 + host_id: 128 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13578 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13578 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13578 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13578 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13578 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13578 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13578 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13578 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13578 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13578 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13578 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13578 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13578 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13578 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13578 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 16 + type: 13578 + host_id: 35 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13579 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13579 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13579 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13580 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13580 + host_id: 35 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13581 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13581 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13581 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13581 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13581 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13581 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13581 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13581 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13581 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13581 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13581 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13581 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13581 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13581 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13581 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13581 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 10 + type: 13581 + host_id: 35 + reserved: 0 + - + start_resource: 133 + num_resource: 6 + type: 13581 + host_id: 37 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13581 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13582 + host_id: 21 + reserved: 0 + - + start_resource: 156 + num_resource: 6 + type: 13582 + host_id: 26 + reserved: 0 + - + start_resource: 162 + num_resource: 6 + type: 13582 + host_id: 28 + reserved: 0 + - + start_resource: 168 + num_resource: 2 + type: 13582 + host_id: 35 + reserved: 0 + - + start_resource: 170 + num_resource: 2 + type: 13582 + host_id: 37 + reserved: 0 + - + start_resource: 172 + num_resource: 96 + type: 13582 + host_id: 35 + reserved: 0 + - + start_resource: 268 + num_resource: 32 + type: 13582 + host_id: 37 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13583 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13583 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13583 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13584 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13584 + host_id: 35 + reserved: 0 + - + start_resource: 10 + num_resource: 100 + type: 13632 + host_id: 12 + reserved: 0 + - + start_resource: 110 + num_resource: 32 + type: 13632 + host_id: 13 + reserved: 0 + - + start_resource: 142 + num_resource: 46 + type: 13632 + host_id: 21 + reserved: 0 + - + start_resource: 196 + num_resource: 28 + type: 13632 + host_id: 35 + reserved: 0 + - + start_resource: 228 + num_resource: 28 + type: 13632 + host_id: 37 + reserved: 0 + - + start_resource: 260 + num_resource: 28 + type: 13632 + host_id: 40 + reserved: 0 + - + start_resource: 292 + num_resource: 28 + type: 13632 + host_id: 42 + reserved: 0 + - + start_resource: 320 + num_resource: 24 + type: 13632 + host_id: 26 + reserved: 0 + - + start_resource: 352 + num_resource: 24 + type: 13632 + host_id: 28 + reserved: 0 + - + start_resource: 400 + num_resource: 4 + type: 13632 + host_id: 3 + reserved: 0 + - + start_resource: 404 + num_resource: 4 + type: 13632 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 32 + type: 14922 + host_id: 12 + reserved: 0 + - + start_resource: 48 + num_resource: 16 + type: 14922 + host_id: 13 + reserved: 0 + - + start_resource: 64 + num_resource: 64 + type: 14922 + host_id: 3 + reserved: 0 + - + start_resource: 128 + num_resource: 4 + type: 14922 + host_id: 5 + reserved: 0 + - + start_resource: 132 + num_resource: 16 + type: 14922 + host_id: 40 + reserved: 0 + - + start_resource: 148 + num_resource: 16 + type: 14922 + host_id: 42 + reserved: 0 + - + start_resource: 164 + num_resource: 8 + type: 14922 + host_id: 21 + reserved: 0 + - + start_resource: 172 + num_resource: 8 + type: 14922 + host_id: 26 + reserved: 0 + - + start_resource: 180 + num_resource: 8 + type: 14922 + host_id: 28 + reserved: 0 + - + start_resource: 188 + num_resource: 24 + type: 14922 + host_id: 35 + reserved: 0 + - + start_resource: 212 + num_resource: 8 + type: 14922 + host_id: 37 + reserved: 0 + - + start_resource: 220 + num_resource: 36 + type: 14922 + host_id: 128 + reserved: 0 + - + start_resource: 16400 + num_resource: 128 + type: 14925 + host_id: 12 + reserved: 0 + - + start_resource: 16528 + num_resource: 128 + type: 14925 + host_id: 13 + reserved: 0 + - + start_resource: 16656 + num_resource: 256 + type: 14925 + host_id: 3 + reserved: 0 + - + start_resource: 16912 + num_resource: 64 + type: 14925 + host_id: 5 + reserved: 0 + - + start_resource: 16976 + num_resource: 128 + type: 14925 + host_id: 40 + reserved: 0 + - + start_resource: 17104 + num_resource: 128 + type: 14925 + host_id: 42 + reserved: 0 + - + start_resource: 17232 + num_resource: 64 + type: 14925 + host_id: 21 + reserved: 0 + - + start_resource: 17296 + num_resource: 64 + type: 14925 + host_id: 26 + reserved: 0 + - + start_resource: 17360 + num_resource: 64 + type: 14925 + host_id: 28 + reserved: 0 + - + start_resource: 17424 + num_resource: 128 + type: 14925 + host_id: 35 + reserved: 0 + - + start_resource: 17552 + num_resource: 128 + type: 14925 + host_id: 37 + reserved: 0 + - + start_resource: 17680 + num_resource: 240 + type: 14925 + host_id: 128 + reserved: 0 + - + start_resource: 1 + num_resource: 4 + type: 14976 + host_id: 12 + reserved: 0 + - + start_resource: 5 + num_resource: 4 + type: 14976 + host_id: 13 + reserved: 0 + - + start_resource: 9 + num_resource: 4 + type: 14976 + host_id: 3 + reserved: 0 + - + start_resource: 13 + num_resource: 4 + type: 14976 + host_id: 5 + reserved: 0 + - + start_resource: 17 + num_resource: 4 + type: 14976 + host_id: 40 + reserved: 0 + - + start_resource: 21 + num_resource: 4 + type: 14976 + host_id: 42 + reserved: 0 + - + start_resource: 25 + num_resource: 4 + type: 14976 + host_id: 21 + reserved: 0 + - + start_resource: 29 + num_resource: 4 + type: 14976 + host_id: 26 + reserved: 0 + - + start_resource: 33 + num_resource: 4 + type: 14976 + host_id: 28 + reserved: 0 + - + start_resource: 37 + num_resource: 16 + type: 14976 + host_id: 35 + reserved: 0 + - + start_resource: 53 + num_resource: 4 + type: 14976 + host_id: 37 + reserved: 0 + - + start_resource: 57 + num_resource: 7 + type: 14976 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15040 + host_id: 128 + reserved: 0 + - + start_resource: 96 + num_resource: 20 + type: 15041 + host_id: 12 + reserved: 0 + - + start_resource: 116 + num_resource: 8 + type: 15041 + host_id: 13 + reserved: 0 + - + start_resource: 124 + num_resource: 32 + type: 15041 + host_id: 3 + reserved: 0 + - + start_resource: 156 + num_resource: 12 + type: 15041 + host_id: 5 + reserved: 0 + - + start_resource: 168 + num_resource: 8 + type: 15041 + host_id: 40 + reserved: 0 + - + start_resource: 176 + num_resource: 8 + type: 15041 + host_id: 42 + reserved: 0 + - + start_resource: 184 + num_resource: 8 + type: 15041 + host_id: 21 + reserved: 0 + - + start_resource: 192 + num_resource: 8 + type: 15041 + host_id: 26 + reserved: 0 + - + start_resource: 200 + num_resource: 8 + type: 15041 + host_id: 28 + reserved: 0 + - + start_resource: 208 + num_resource: 16 + type: 15041 + host_id: 35 + reserved: 0 + - + start_resource: 224 + num_resource: 8 + type: 15041 + host_id: 37 + reserved: 0 + - + start_resource: 232 + num_resource: 20 + type: 15041 + host_id: 128 + reserved: 0 + - + start_resource: 50 + num_resource: 4 + type: 15042 + host_id: 12 + reserved: 0 + - + start_resource: 54 + num_resource: 2 + type: 15042 + host_id: 3 + reserved: 0 + - + start_resource: 54 + num_resource: 0 + type: 15042 + host_id: 13 + reserved: 0 + - + start_resource: 56 + num_resource: 0 + type: 15042 + host_id: 5 + reserved: 0 + - + start_resource: 56 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + - + start_resource: 57 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + - + start_resource: 58 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + - + start_resource: 59 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + - + start_resource: 60 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + - + start_resource: 61 + num_resource: 1 + type: 15042 + host_id: 35 + reserved: 0 + - + start_resource: 62 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + - + start_resource: 63 + num_resource: 9 + type: 15042 + host_id: 12 + reserved: 0 + - + start_resource: 72 + num_resource: 6 + type: 15042 + host_id: 13 + reserved: 0 + - + start_resource: 78 + num_resource: 3 + type: 15042 + host_id: 3 + reserved: 0 + - + start_resource: 81 + num_resource: 2 + type: 15042 + host_id: 5 + reserved: 0 + - + start_resource: 83 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + - + start_resource: 84 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + - + start_resource: 85 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + - + start_resource: 86 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + - + start_resource: 87 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + - + start_resource: 88 + num_resource: 2 + type: 15042 + host_id: 35 + reserved: 0 + - + start_resource: 90 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + - + start_resource: 91 + num_resource: 2 + type: 15042 + host_id: 128 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15043 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15043 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15043 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15043 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15043 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15043 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15043 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15043 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15043 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15043 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 3 + type: 15043 + host_id: 128 + reserved: 0 + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 3 + reserved: 0 + - + start_resource: 48 + num_resource: 2 + type: 15045 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15047 + host_id: 3 + reserved: 0 + - + start_resource: 2 + num_resource: 5 + type: 15050 + host_id: 12 + reserved: 0 + - + start_resource: 7 + num_resource: 1 + type: 15050 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 3 + type: 15051 + host_id: 12 + reserved: 0 + - + start_resource: 3 + num_resource: 2 + type: 15051 + host_id: 13 + reserved: 0 + - + start_resource: 5 + num_resource: 3 + type: 15051 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 3 + type: 15051 + host_id: 5 + reserved: 0 + - + start_resource: 11 + num_resource: 3 + type: 15051 + host_id: 40 + reserved: 0 + - + start_resource: 14 + num_resource: 3 + type: 15051 + host_id: 42 + reserved: 0 + - + start_resource: 17 + num_resource: 3 + type: 15051 + host_id: 21 + reserved: 0 + - + start_resource: 20 + num_resource: 3 + type: 15051 + host_id: 26 + reserved: 0 + - + start_resource: 23 + num_resource: 3 + type: 15051 + host_id: 28 + reserved: 0 + - + start_resource: 26 + num_resource: 3 + type: 15051 + host_id: 35 + reserved: 0 + - + start_resource: 29 + num_resource: 3 + type: 15051 + host_id: 37 + reserved: 0 + - + start_resource: 48 + num_resource: 8 + type: 15104 + host_id: 12 + reserved: 0 + - + start_resource: 56 + num_resource: 4 + type: 15104 + host_id: 13 + reserved: 0 + - + start_resource: 60 + num_resource: 8 + type: 15104 + host_id: 3 + reserved: 0 + - + start_resource: 68 + num_resource: 4 + type: 15104 + host_id: 5 + reserved: 0 + - + start_resource: 72 + num_resource: 4 + type: 15104 + host_id: 40 + reserved: 0 + - + start_resource: 76 + num_resource: 4 + type: 15104 + host_id: 42 + reserved: 0 + - + start_resource: 80 + num_resource: 8 + type: 15104 + host_id: 35 + reserved: 0 + - + start_resource: 88 + num_resource: 4 + type: 15104 + host_id: 37 + reserved: 0 + - + start_resource: 92 + num_resource: 4 + type: 15104 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15105 + host_id: 128 + reserved: 0 + - + start_resource: 56320 + num_resource: 256 + type: 15106 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15107 + host_id: 128 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15114 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15114 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15114 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15114 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15114 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15114 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15114 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15114 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15114 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15114 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 2 + type: 15114 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15115 + host_id: 3 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15117 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15117 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15117 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15117 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15117 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15117 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15117 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15117 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15117 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15117 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 3 + type: 15117 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15119 + host_id: 3 + reserved: 0 + - + start_resource: 12 + num_resource: 20 + type: 15168 + host_id: 3 + reserved: 0 + - + start_resource: 36 + num_resource: 28 + type: 15168 + host_id: 5 + reserved: 0 diff --git a/board/ti/j721e/sec-cfg.yaml b/board/ti/j721e/sec-cfg.yaml new file mode 100644 index 0000000000..0f62e51e9f --- /dev/null +++ b/board/ti/j721e/sec-cfg.yaml @@ -0,0 +1,379 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security configuration for J721E +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + write_host_id: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci: 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size: 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock: 0x5A + allow_wildcard_unlock: 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev: 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender: 0 + handover_to_host_id: 0 + rsvd: [0, 0, 0, 0] +
By providing entries in the binman node of the device tree, binman will be able to find and package board config artifacts generated by TIBoardConfig with sysfw.bin and generate the final image sysfw.itb. It will also pick out the R5 SPL and sign it with the help of TI signing entry and generate the final tiboot3.bin.
Entries for A72 build have been added to k3-j721e-binman.dtsi to generate tispl.bin and u-boot.img.
Support has been added for both HS(SR 1.1) and GP images where the encrypted system firmware binary must be signed along with the signed certificate binary.
tiboot3.bin and sysfw-j721e_sr1_1-hs.itb: For HS devices tiboot3.bin_unsigned and sysfw-j721e-gp-evm.itb: For GP devices <filename>.bin/img: For HS devices <filename>.bin_unsigned/img_unsigned: For GP devices
Intention of patch is to move signing and packaging to binman, thus making makefile target only if binman is not enabled.
It is to be noted that the bootflow followed by J721E requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs
sysfw.itb: * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * DM * ATF * OPTEE * A72 SPL * A72 SPL dtbs
u-boot.img: * A72 U-Boot * A72 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-j721e-binman.dtsi | 634 ++++++++++++++++++ .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + .../arm/dts/k3-j721e-r5-common-proc-board.dts | 1 + arch/arm/mach-k3/config.mk | 4 + board/ti/j721e/Kconfig | 2 + scripts/Makefile.spl | 2 + 6 files changed, 644 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-binman.dtsi
diff --git a/arch/arm/dts/k3-j721e-binman.dtsi b/arch/arm/dts/k3-j721e-binman.dtsi new file mode 100644 index 0000000000..fc53b3f119 --- /dev/null +++ b/arch/arm/dts/k3-j721e-binman.dtsi @@ -0,0 +1,634 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +#ifdef CONFIG_TARGET_J721E_R5_EVM + +&binman { + board-cfg { + filename = "board-cfg.bin"; + ti-board-config { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + ti-board-config { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + ti-board-config { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + ti-board-config { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + tiboot3 { + filename = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + keyfile = "custMpk.pem"; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + }; + sysfw { + filename = "sysfw.bin"; + ti-secure-rom { + content = <&ti_fs_cert>; + core = "secure"; + load = <0x40000>; + keyfile = "custMpk.pem"; + countersign; + }; + ti_fs_cert: ti-fs-cert.bin { + filename = "ti-fs-firmware-j721e_sr1_1-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + ti-fs-firmware-j721e_sr1_1-hs-enc.bin { + filename = "ti-fs-firmware-j721e_sr1_1-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + }; + itb { + filename = "sysfw-j721e_sr1_1-hs.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&board_cfg>; + keyfile = "custMpk.pem"; + }; + board_cfg: board-cfg { + filename = "board-cfg.bin"; + type = "blob-ext"; + }; + + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&pm_cfg>; + keyfile = "custMpk.pem"; + }; + pm_cfg: pm-cfg { + filename = "pm-cfg.bin"; + type = "blob-ext"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&rm_cfg>; + keyfile = "custMpk.pem";\ + }; + rm_cfg: rm-cfg { + filename = "rm-cfg.bin"; + type = "blob-ext"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&sec_cfg>; + keyfile = "custMpk.pem"; + }; + sec_cfg: sec-cfg { + filename = "sec-cfg.bin"; + type = "blob-ext"; + }; + }; + }; + }; + }; +}; + +&binman { + tiboot3_unsigned { + filename = "tiboot3.bin_unsigned"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + }; + sysfw_gp { + filename = "sysfw.bin_gp"; + ti-secure-rom { + content = <&ti_fs>; + core = "secure"; + load = <0x40000>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + countersign; + }; + ti_fs: ti-fs.bin { + filename = "ti-fs-firmware-j721e-gp.bin"; + type = "blob-ext"; + optional; + }; + }; + itb_gp { + filename = "sysfw-j721e-gp-evm.itb"; + symlink = "sysfw.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin_gp"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "board-cfg.bin"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "pm-cfg.bin"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "rm-cfg.bin"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sec-cfg.bin"; + }; + }; + }; + }; + }; +}; +#endif + +#ifdef CONFIG_TARGET_J721E_A72_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_J721E_EVM_DTB "spl/dts/k3-j721e-common-proc-board.dtb" +#define SPL_J721E_SK_DTB "spl/dts/k3-j721e-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define J721E_EVM_DTB "arch/arm/dts/k3-j721e-common-proc-board.dtb" +#define J721E_SK_DTB "arch/arm/dts/k3-j721e-sk.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-1 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j721e_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_j721e_evm_dtb: blob-ext { + filename = SPL_J721E_EVM_DTB; + }; + }; + + fdt-2 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j721e_sk_dtb>; + keyfile = "custMpk.pem"; + + }; + spl_j721e_sk_dtb: blob-ext { + filename = SPL_J721E_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j721e-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-2 { + description = "k3-j721e-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-2"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for j721e board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j721e_evm_dtb>; + keyfile = "custMpk.pem"; + + }; + j721e_evm_dtb: blob-ext { + filename = J721E_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-2 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j721e_sk_dtb>; + keyfile = "custMpk.pem"; + + }; + j721e_sk_dtb: blob-ext { + filename = J721E_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721e-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + conf-2 { + description = "k3-j721e-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-2"; + }; + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-1 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J721E_EVM_DTB; + }; + }; + + fdt-2 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J721E_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j721e-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + + conf-2 { + description = "k3-j721e-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-2"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for j721e board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J721E_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-2 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J721E_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j721e-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + + conf-2 { + description = "k3-j721e-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-2"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 867ec2bb1a..540c847eb3 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include <dt-bindings/net/ti-dp83867.h> +#include "k3-j721e-binman.dtsi"
/ { chosen { diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts index e9e50538cb..2913eae4d2 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts @@ -8,6 +8,7 @@ #include "k3-j721e-som-p0.dtsi" #include "k3-j721e-ddr-evm-lp4-4266.dtsi" #include "k3-j721e-ddr.dtsi" +#include "k3-j721e-binman.dtsi" #include <dt-bindings/phy/phy-cadence.h>
/ { diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index b280a6a048..b342a56538 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -91,6 +91,7 @@ endif
# tiboot3.bin is mandated by ROM and ROM only supports R5 boot. # So restrict tiboot3.bin creation for CPU_V7R. +ifndef CONFIG_BINMAN ifdef CONFIG_CPU_V7R image_check: $(obj)/u-boot-spl.bin FORCE @if [ $(IMAGE_SIZE) -gt $(MAX_SIZE) ]; then \ @@ -107,6 +108,7 @@ tiboot3.bin: image_check FORCE
INPUTS-y += tiboot3.bin endif +endif
ifdef CONFIG_ARM64
@@ -114,6 +116,7 @@ ifeq ($(CONFIG_SOC_K3_J721E),) export DM := /dev/null endif
+ifndef CONFIG_BINMAN ifeq ($(CONFIG_TI_SECURE_DEVICE),y) SPL_ITS := u-boot-spl-k3_HS.its $(SPL_ITS): export IS_HS=1 @@ -122,6 +125,7 @@ else SPL_ITS := u-boot-spl-k3.its INPUTS-y += tispl.bin endif +endif
ifeq ($(CONFIG_SPL_OF_LIST),) LIST_OF_DTB := $(CONFIG_DEFAULT_DEVICE_TREE) diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index 84bca32712..4a127c4a10 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -13,6 +13,7 @@ config TARGET_J721E_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J721E_R5_EVM bool "TI K3 based J721E EVM running on R5" @@ -22,6 +23,7 @@ config TARGET_J721E_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 15ac87286d..a7811609bf 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -593,6 +593,8 @@ $(obj)/$(SPL_BIN).multidtb.fit.lzo: $(obj)/$(SPL_BIN).multidtb.fit @lzop -f9 $< > $@
ifdef CONFIG_ARCH_K3 +ifndef CONFIG_BINMAN tispl.bin: $(obj)/u-boot-spl-nodtb.bin $(SHRUNK_ARCH_DTB) $(SPL_ITS) FORCE $(call if_changed,mkfitimage) endif +endif
tiboot3.bin:
- R5 SPL
- R5 SPL dtbs
sysfw.itb:
- TIFS
- board-cfg
- pm-cfg
- sec-cfg
- rm-cfg
tispl.bin:
- DM
- ATF
- OPTEE
- A72 SPL
- A72 SPL dtbs
u-boot.img:
- A72 U-Boot
- A72 U-Boot dtbs
Suggest prefix these with the expected directory name,
filename = "ti-sysfw/ti-fs-firmware-j721e_sr1_1-hs-cert.bin";
that way we only need to do one simple firmware path export:
export BINMAN_INDIRS="<ti-linux-firmware>"
Same below for DM firmware which lives in the same firmware repo but in a directory that depends on the platform, selecting the correct platform directory here in this file makes it so much easier for users.
- filename = "ipc_echo_testb_mcu1_0_release_strip.xer5f";
filename = "ti-dm/j721e/ipc_echo_testb_mcu1_0_release_strip.xer5f";
Do that for all the DM/SYSFW files for all the platforms in this series.
Thanks, Andrew
Hi Andrew
That makes it easier, I'll do that, thanks!
Thanks, Andrew
Added YAML config for J7200
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/j721e/board-cfg_j7200.yaml | 36 + board/ti/j721e/pm-cfg_j7200.yaml | 12 + board/ti/j721e/rm-cfg_j7200.yaml | 2065 +++++++++++++++++++++++++++ board/ti/j721e/sec-cfg_j7200.yaml | 378 +++++ 4 files changed, 2491 insertions(+) create mode 100644 board/ti/j721e/board-cfg_j7200.yaml create mode 100644 board/ti/j721e/pm-cfg_j7200.yaml create mode 100644 board/ti/j721e/rm-cfg_j7200.yaml create mode 100644 board/ti/j721e/sec-cfg_j7200.yaml
diff --git a/board/ti/j721e/board-cfg_j7200.yaml b/board/ti/j721e/board-cfg_j7200.yaml new file mode 100644 index 0000000000..1453317ecb --- /dev/null +++ b/board/ti/j721e/board-cfg_j7200.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J7200 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x10 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/j721e/pm-cfg_j7200.yaml b/board/ti/j721e/pm-cfg_j7200.yaml new file mode 100644 index 0000000000..588a1d530d --- /dev/null +++ b/board/ti/j721e/pm-cfg_j7200.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for J7200 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/j721e/rm-cfg_j7200.yaml b/board/ti/j721e/rm-cfg_j7200.yaml new file mode 100644 index 0000000000..66b589f370 --- /dev/null +++ b/board/ti/j721e/rm-cfg_j7200.yaml @@ -0,0 +1,2065 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for J7200 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 5 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 12 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 13 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 35 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #6 + host_id: 37 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #7 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #8 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #9 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #10 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #11 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 2048 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 32 + type: 8192 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 32 + type: 8192 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 8320 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 24 + type: 8320 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 8384 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 8384 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 8384 + host_id: 35 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 8384 + host_id: 37 + reserved: 0 + + - + start_resource: 32 + num_resource: 16 + type: 8384 + host_id: 12 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 8384 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 48 + type: 8704 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 8768 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 8768 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 8768 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 8768 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 13258 + host_id: 128 + reserved: 0 + + - + start_resource: 20480 + num_resource: 1024 + type: 13261 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 13322 + host_id: 128 + reserved: 0 + + - + start_resource: 22528 + num_resource: 1024 + type: 13325 + host_id: 128 + reserved: 0 + + - + start_resource: 18 + num_resource: 86 + type: 13386 + host_id: 12 + reserved: 0 + + - + start_resource: 104 + num_resource: 32 + type: 13386 + host_id: 13 + reserved: 0 + + - + start_resource: 136 + num_resource: 16 + type: 13386 + host_id: 3 + reserved: 0 + + - + start_resource: 152 + num_resource: 16 + type: 13386 + host_id: 5 + reserved: 0 + + - + start_resource: 168 + num_resource: 32 + type: 13386 + host_id: 35 + reserved: 0 + + - + start_resource: 200 + num_resource: 24 + type: 13386 + host_id: 37 + reserved: 0 + + - + start_resource: 224 + num_resource: 32 + type: 13386 + host_id: 128 + reserved: 0 + + - + start_resource: 18 + num_resource: 1024 + type: 13389 + host_id: 12 + reserved: 0 + + - + start_resource: 1042 + num_resource: 512 + type: 13389 + host_id: 13 + reserved: 0 + + - + start_resource: 1554 + num_resource: 128 + type: 13389 + host_id: 3 + reserved: 0 + + - + start_resource: 1682 + num_resource: 128 + type: 13389 + host_id: 5 + reserved: 0 + + - + start_resource: 1810 + num_resource: 256 + type: 13389 + host_id: 35 + reserved: 0 + + - + start_resource: 2066 + num_resource: 512 + type: 13389 + host_id: 37 + reserved: 0 + + - + start_resource: 2578 + num_resource: 2030 + type: 13389 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 13440 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13440 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 13440 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 13440 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 13440 + host_id: 35 + reserved: 0 + + - + start_resource: 32 + num_resource: 16 + type: 13440 + host_id: 37 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 13440 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13504 + host_id: 128 + reserved: 0 + + - + start_resource: 120 + num_resource: 200 + type: 13505 + host_id: 12 + reserved: 0 + + - + start_resource: 320 + num_resource: 40 + type: 13505 + host_id: 13 + reserved: 0 + + - + start_resource: 360 + num_resource: 32 + type: 13505 + host_id: 3 + reserved: 0 + + - + start_resource: 392 + num_resource: 32 + type: 13505 + host_id: 5 + reserved: 0 + + - + start_resource: 424 + num_resource: 256 + type: 13505 + host_id: 35 + reserved: 0 + + - + start_resource: 680 + num_resource: 256 + type: 13505 + host_id: 37 + reserved: 0 + + - + start_resource: 936 + num_resource: 38 + type: 13505 + host_id: 128 + reserved: 0 + + - + start_resource: 64 + num_resource: 4 + type: 13506 + host_id: 12 + reserved: 0 + + - + start_resource: 68 + num_resource: 2 + type: 13506 + host_id: 13 + reserved: 0 + + - + start_resource: 70 + num_resource: 2 + type: 13506 + host_id: 3 + reserved: 0 + + - + start_resource: 72 + num_resource: 2 + type: 13506 + host_id: 5 + reserved: 0 + + - + start_resource: 74 + num_resource: 2 + type: 13506 + host_id: 35 + reserved: 0 + + - + start_resource: 76 + num_resource: 2 + type: 13506 + host_id: 37 + reserved: 0 + + - + start_resource: 78 + num_resource: 20 + type: 13506 + host_id: 12 + reserved: 0 + + - + start_resource: 98 + num_resource: 4 + type: 13506 + host_id: 13 + reserved: 0 + + - + start_resource: 102 + num_resource: 8 + type: 13506 + host_id: 35 + reserved: 0 + + - + start_resource: 110 + num_resource: 8 + type: 13506 + host_id: 37 + reserved: 0 + + - + start_resource: 118 + num_resource: 2 + type: 13506 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13507 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 13507 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 13507 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 13507 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13507 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 2 + type: 13507 + host_id: 37 + reserved: 0 + + - + start_resource: 18 + num_resource: 20 + type: 13507 + host_id: 12 + reserved: 0 + + - + start_resource: 38 + num_resource: 4 + type: 13507 + host_id: 13 + reserved: 0 + + - + start_resource: 42 + num_resource: 8 + type: 13507 + host_id: 35 + reserved: 0 + + - + start_resource: 50 + num_resource: 8 + type: 13507 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 2 + type: 13507 + host_id: 128 + reserved: 0 + + - + start_resource: 62 + num_resource: 0 + type: 13509 + host_id: 12 + reserved: 0 + + - + start_resource: 62 + num_resource: 1 + type: 13509 + host_id: 12 + reserved: 0 + + - + start_resource: 62 + num_resource: 0 + type: 13509 + host_id: 35 + reserved: 0 + + - + start_resource: 63 + num_resource: 1 + type: 13509 + host_id: 35 + reserved: 0 + + - + start_resource: 60 + num_resource: 0 + type: 13510 + host_id: 37 + reserved: 0 + + - + start_resource: 60 + num_resource: 2 + type: 13510 + host_id: 37 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13511 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13511 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13511 + host_id: 35 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13511 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13512 + host_id: 37 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13514 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13514 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 13515 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 13515 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 1 + type: 13515 + host_id: 3 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 13515 + host_id: 5 + reserved: 0 + + - + start_resource: 7 + num_resource: 16 + type: 13515 + host_id: 35 + reserved: 0 + + - + start_resource: 23 + num_resource: 8 + type: 13515 + host_id: 37 + reserved: 0 + + - + start_resource: 31 + num_resource: 1 + type: 13515 + host_id: 128 + reserved: 0 + + - + start_resource: 60 + num_resource: 8 + type: 13568 + host_id: 12 + reserved: 0 + + - + start_resource: 68 + num_resource: 8 + type: 13568 + host_id: 13 + reserved: 0 + + - + start_resource: 76 + num_resource: 8 + type: 13568 + host_id: 37 + reserved: 0 + + - + start_resource: 84 + num_resource: 66 + type: 13568 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13569 + host_id: 128 + reserved: 0 + + - + start_resource: 49152 + num_resource: 1024 + type: 13570 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13571 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13578 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 13578 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 13578 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 13578 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13578 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 2 + type: 13578 + host_id: 37 + reserved: 0 + + - + start_resource: 18 + num_resource: 20 + type: 13578 + host_id: 12 + reserved: 0 + + - + start_resource: 38 + num_resource: 4 + type: 13578 + host_id: 13 + reserved: 0 + + - + start_resource: 42 + num_resource: 8 + type: 13578 + host_id: 35 + reserved: 0 + + - + start_resource: 50 + num_resource: 8 + type: 13578 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 2 + type: 13578 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13579 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13579 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13579 + host_id: 35 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13579 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13580 + host_id: 37 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13581 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 13581 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 13581 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 13581 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13581 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 2 + type: 13581 + host_id: 37 + reserved: 0 + + - + start_resource: 18 + num_resource: 20 + type: 13581 + host_id: 12 + reserved: 0 + + - + start_resource: 38 + num_resource: 4 + type: 13581 + host_id: 13 + reserved: 0 + + - + start_resource: 42 + num_resource: 8 + type: 13581 + host_id: 35 + reserved: 0 + + - + start_resource: 50 + num_resource: 8 + type: 13581 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 2 + type: 13581 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13583 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13583 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13583 + host_id: 35 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13583 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13584 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 128 + type: 13632 + host_id: 12 + reserved: 0 + + - + start_resource: 138 + num_resource: 54 + type: 13632 + host_id: 13 + reserved: 0 + + - + start_resource: 196 + num_resource: 28 + type: 13632 + host_id: 35 + reserved: 0 + + - + start_resource: 228 + num_resource: 28 + type: 13632 + host_id: 37 + reserved: 0 + + - + start_resource: 400 + num_resource: 4 + type: 13632 + host_id: 3 + reserved: 0 + + - + start_resource: 404 + num_resource: 4 + type: 13632 + host_id: 5 + reserved: 0 + + - + start_resource: 15 + num_resource: 32 + type: 14922 + host_id: 12 + reserved: 0 + + - + start_resource: 47 + num_resource: 16 + type: 14922 + host_id: 13 + reserved: 0 + + - + start_resource: 63 + num_resource: 64 + type: 14922 + host_id: 3 + reserved: 0 + + - + start_resource: 127 + num_resource: 32 + type: 14922 + host_id: 5 + reserved: 0 + + - + start_resource: 159 + num_resource: 16 + type: 14922 + host_id: 35 + reserved: 0 + + - + start_resource: 175 + num_resource: 16 + type: 14922 + host_id: 37 + reserved: 0 + + - + start_resource: 191 + num_resource: 65 + type: 14922 + host_id: 128 + reserved: 0 + + - + start_resource: 16399 + num_resource: 128 + type: 14925 + host_id: 12 + reserved: 0 + + - + start_resource: 16527 + num_resource: 128 + type: 14925 + host_id: 13 + reserved: 0 + + - + start_resource: 16655 + num_resource: 256 + type: 14925 + host_id: 3 + reserved: 0 + + - + start_resource: 16911 + num_resource: 128 + type: 14925 + host_id: 5 + reserved: 0 + + - + start_resource: 17039 + num_resource: 128 + type: 14925 + host_id: 35 + reserved: 0 + + - + start_resource: 17167 + num_resource: 128 + type: 14925 + host_id: 37 + reserved: 0 + + - + start_resource: 17295 + num_resource: 625 + type: 14925 + host_id: 128 + reserved: 0 + + - + start_resource: 1 + num_resource: 8 + type: 14976 + host_id: 12 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 14976 + host_id: 13 + reserved: 0 + + - + start_resource: 13 + num_resource: 16 + type: 14976 + host_id: 3 + reserved: 0 + + - + start_resource: 29 + num_resource: 16 + type: 14976 + host_id: 5 + reserved: 0 + + - + start_resource: 45 + num_resource: 8 + type: 14976 + host_id: 35 + reserved: 0 + + - + start_resource: 53 + num_resource: 8 + type: 14976 + host_id: 37 + reserved: 0 + + - + start_resource: 61 + num_resource: 3 + type: 14976 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15040 + host_id: 128 + reserved: 0 + + - + start_resource: 96 + num_resource: 32 + type: 15041 + host_id: 12 + reserved: 0 + + - + start_resource: 128 + num_resource: 16 + type: 15041 + host_id: 13 + reserved: 0 + + - + start_resource: 144 + num_resource: 32 + type: 15041 + host_id: 3 + reserved: 0 + + - + start_resource: 176 + num_resource: 32 + type: 15041 + host_id: 5 + reserved: 0 + + - + start_resource: 208 + num_resource: 16 + type: 15041 + host_id: 35 + reserved: 0 + + - + start_resource: 224 + num_resource: 16 + type: 15041 + host_id: 37 + reserved: 0 + + - + start_resource: 240 + num_resource: 12 + type: 15041 + host_id: 128 + reserved: 0 + + - + start_resource: 50 + num_resource: 3 + type: 15042 + host_id: 12 + reserved: 0 + + - + start_resource: 53 + num_resource: 2 + type: 15042 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 2 + type: 15042 + host_id: 3 + reserved: 0 + + - + start_resource: 57 + num_resource: 2 + type: 15042 + host_id: 5 + reserved: 0 + + - + start_resource: 59 + num_resource: 2 + type: 15042 + host_id: 35 + reserved: 0 + + - + start_resource: 61 + num_resource: 2 + type: 15042 + host_id: 37 + reserved: 0 + + - + start_resource: 63 + num_resource: 9 + type: 15042 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 4 + type: 15042 + host_id: 13 + reserved: 0 + + - + start_resource: 76 + num_resource: 4 + type: 15042 + host_id: 3 + reserved: 0 + + - + start_resource: 80 + num_resource: 4 + type: 15042 + host_id: 5 + reserved: 0 + + - + start_resource: 84 + num_resource: 4 + type: 15042 + host_id: 35 + reserved: 0 + + - + start_resource: 88 + num_resource: 4 + type: 15042 + host_id: 37 + reserved: 0 + + - + start_resource: 92 + num_resource: 1 + type: 15042 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 3 + type: 15043 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 2 + type: 15043 + host_id: 13 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 15043 + host_id: 3 + reserved: 0 + + - + start_resource: 9 + num_resource: 2 + type: 15043 + host_id: 5 + reserved: 0 + + - + start_resource: 11 + num_resource: 2 + type: 15043 + host_id: 35 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 15043 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15043 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 15043 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 15043 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 15043 + host_id: 5 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 15043 + host_id: 35 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 15043 + host_id: 37 + reserved: 0 + + - + start_resource: 44 + num_resource: 2 + type: 15043 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 12 + reserved: 0 + + - + start_resource: 48 + num_resource: 1 + type: 15045 + host_id: 12 + reserved: 0 + + - + start_resource: 49 + num_resource: 1 + type: 15045 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15047 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 15047 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 15050 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 15050 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 15051 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 15051 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 6 + type: 15051 + host_id: 3 + reserved: 0 + + - + start_resource: 11 + num_resource: 6 + type: 15051 + host_id: 5 + reserved: 0 + + - + start_resource: 17 + num_resource: 5 + type: 15051 + host_id: 35 + reserved: 0 + + - + start_resource: 22 + num_resource: 5 + type: 15051 + host_id: 37 + reserved: 0 + + - + start_resource: 27 + num_resource: 5 + type: 15051 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 8 + type: 15104 + host_id: 12 + reserved: 0 + + - + start_resource: 56 + num_resource: 4 + type: 15104 + host_id: 13 + reserved: 0 + + - + start_resource: 60 + num_resource: 8 + type: 15104 + host_id: 3 + reserved: 0 + + - + start_resource: 68 + num_resource: 4 + type: 15104 + host_id: 5 + reserved: 0 + + - + start_resource: 72 + num_resource: 8 + type: 15104 + host_id: 35 + reserved: 0 + + - + start_resource: 80 + num_resource: 4 + type: 15104 + host_id: 37 + reserved: 0 + + - + start_resource: 84 + num_resource: 12 + type: 15104 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15105 + host_id: 128 + reserved: 0 + + - + start_resource: 56320 + num_resource: 256 + type: 15106 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15107 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 3 + type: 15114 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 2 + type: 15114 + host_id: 13 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 15114 + host_id: 3 + reserved: 0 + + - + start_resource: 9 + num_resource: 2 + type: 15114 + host_id: 5 + reserved: 0 + + - + start_resource: 11 + num_resource: 2 + type: 15114 + host_id: 35 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 15114 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15114 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 15114 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 15114 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 15114 + host_id: 5 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 15114 + host_id: 35 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 15114 + host_id: 37 + reserved: 0 + + - + start_resource: 44 + num_resource: 1 + type: 15114 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15115 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 15115 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 3 + type: 15117 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 2 + type: 15117 + host_id: 13 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 15117 + host_id: 3 + reserved: 0 + + - + start_resource: 9 + num_resource: 2 + type: 15117 + host_id: 5 + reserved: 0 + + - + start_resource: 11 + num_resource: 2 + type: 15117 + host_id: 35 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 15117 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15117 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 15117 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 15117 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 15117 + host_id: 5 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 15117 + host_id: 35 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 15117 + host_id: 37 + reserved: 0 + + - + start_resource: 44 + num_resource: 2 + type: 15117 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15119 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 15119 + host_id: 3 + reserved: 0 + + - + start_resource: 11 + num_resource: 20 + type: 15168 + host_id: 3 + reserved: 0 + + - + start_resource: 36 + num_resource: 28 + type: 15168 + host_id: 5 + reserved: 0 diff --git a/board/ti/j721e/sec-cfg_j7200.yaml b/board/ti/j721e/sec-cfg_j7200.yaml new file mode 100644 index 0000000000..fecf74a352 --- /dev/null +++ b/board/ti/j721e/sec-cfg_j7200.yaml @@ -0,0 +1,378 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for J7200 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd : 0 + rsvd : 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support added for HS and GP boot binaries for J7200.
tiboot3.bin, tispl.bin and u-boot.img: For HS devices tiboot3.bin_unsigned, tispl.bin_unsigned and u-boot.img_unsigned: For GP devices
It is to be noted that the bootflow followed by J7200 requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-j7200-binman.dtsi | 471 ++++++++++++++++++ .../k3-j7200-common-proc-board-u-boot.dtsi | 2 + board/ti/j721e/Kconfig | 2 + 3 files changed, 475 insertions(+) create mode 100644 arch/arm/dts/k3-j7200-binman.dtsi
diff --git a/arch/arm/dts/k3-j7200-binman.dtsi b/arch/arm/dts/k3-j7200-binman.dtsi new file mode 100644 index 0000000000..f4906e2b4e --- /dev/null +++ b/arch/arm/dts/k3-j7200-binman.dtsi @@ -0,0 +1,471 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +#ifdef CONFIG_TARGET_J7200_R5_EVM + +&binman { + board-cfg { + filename = "board-cfg.bin"; + ti-board-config { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + ti-board-config { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + ti-board-config { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + ti-board-config { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + + combined-tifs-cfg { + filename = "combined-tifs-cfg.bin"; + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + }; + combined-dm-cfg { + filename = "combined-dm-cfg.bin"; + ti-board-config { + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + + }; + }; + + tiboot3 { + filename = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x41c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x7f000>; + load-dm-data = <0x41c80000>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-fs-firmware-j7200-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: blob-ext@1 { + filename = "combined-tifs-cfg.bin"; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-fs-firmware-j7200-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + }; +}; + +&binman { + tiboot3_unsigned { + filename = "tiboot3.bin_unsigned"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x41c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x7f000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x41c80000>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-fs-firmware-j7200-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +#endif + +#ifdef CONFIG_TARGET_J7200_A72_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_J7200_EVM_DTB "spl/dts/k3-j7200-common-proc-board.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define J7200_EVM_DTB "arch/arm/dts/k3-j7200-common-proc-board.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j7200_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_j7200_evm_dtb: blob-ext { + filename = SPL_J7200_EVM_DTB; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j7200-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J7200 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j7200_evm_dtb>; + keyfile = "custMpk.pem"; + }; + j7200_evm_dtb: blob-ext { + filename = J7200_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j7200-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = SPL_NODTB; + }; + }; + + fdt-1 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J7200_EVM_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j7200-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J7200 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J7200_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j7200-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index f57c2306ba..f25c7136c9 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-j7200-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index 4a127c4a10..e6cb21f77b 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -33,6 +33,7 @@ config TARGET_J7200_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J7200_R5_EVM bool "TI K3 based J7200 EVM running on R5" @@ -42,6 +43,7 @@ config TARGET_J7200_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML config for AM65x
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am65x/board-cfg.yaml | 36 + board/ti/am65x/pm-cfg.yaml | 12 + board/ti/am65x/rm-cfg.yaml | 2068 +++++++++++++++++++++++++++++++++ board/ti/am65x/sec-cfg.yaml | 375 ++++++ 4 files changed, 2491 insertions(+) create mode 100644 board/ti/am65x/board-cfg.yaml create mode 100644 board/ti/am65x/pm-cfg.yaml create mode 100644 board/ti/am65x/rm-cfg.yaml create mode 100644 board/ti/am65x/sec-cfg.yaml
diff --git a/board/ti/am65x/board-cfg.yaml b/board/ti/am65x/board-cfg.yaml new file mode 100644 index 0000000000..133720ec3e --- /dev/null +++ b/board/ti/am65x/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM65x +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x10 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/am65x/pm-cfg.yaml b/board/ti/am65x/pm-cfg.yaml new file mode 100644 index 0000000000..4b1ce475cd --- /dev/null +++ b/board/ti/am65x/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM65x +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am65x/rm-cfg.yaml b/board/ti/am65x/rm-cfg.yaml new file mode 100644 index 0000000000..501cc464c4 --- /dev/null +++ b/board/ti/am65x/rm-cfg.yaml @@ -0,0 +1,2068 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM65x +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 5 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 13 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #11 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #12 + host_id: 5 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #13 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #14 + host_id: 13 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #22 + host_id: 5 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #23 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #24 + host_id: 13 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #31 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #32 + host_id: 5 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 2080 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 12 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 192 + host_id: 13 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 192 + host_id: 3 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 192 + host_id: 4 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 192 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 32 + type: 9664 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 32 + type: 9664 + host_id: 4 + reserved: 0 + + - + start_resource: 32 + num_resource: 32 + type: 9664 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 9728 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 9728 + host_id: 4 + reserved: 0 + + - + start_resource: 24 + num_resource: 24 + type: 9728 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 20 + type: 16384 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 16384 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 16384 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 16384 + host_id: 4 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 16384 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 20800 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 20800 + host_id: 4 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 20800 + host_id: 5 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 20800 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 21888 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 21888 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 21888 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 21888 + host_id: 4 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 21888 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 80 + type: 24138 + host_id: 12 + reserved: 0 + + - + start_resource: 96 + num_resource: 30 + type: 24138 + host_id: 13 + reserved: 0 + + - + start_resource: 126 + num_resource: 50 + type: 24138 + host_id: 3 + reserved: 0 + + - + start_resource: 126 + num_resource: 50 + type: 24138 + host_id: 4 + reserved: 0 + + - + start_resource: 176 + num_resource: 50 + type: 24138 + host_id: 5 + reserved: 0 + + - + start_resource: 226 + num_resource: 30 + type: 24138 + host_id: 128 + reserved: 0 + + - + start_resource: 16 + num_resource: 1024 + type: 24141 + host_id: 12 + reserved: 0 + + - + start_resource: 1040 + num_resource: 512 + type: 24141 + host_id: 13 + reserved: 0 + + - + start_resource: 1552 + num_resource: 512 + type: 24141 + host_id: 3 + reserved: 0 + + - + start_resource: 1552 + num_resource: 512 + type: 24141 + host_id: 4 + reserved: 0 + + - + start_resource: 2064 + num_resource: 512 + type: 24141 + host_id: 5 + reserved: 0 + + - + start_resource: 2576 + num_resource: 2032 + type: 24141 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 24586 + host_id: 128 + reserved: 0 + + - + start_resource: 20480 + num_resource: 1024 + type: 24589 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 24650 + host_id: 128 + reserved: 0 + + - + start_resource: 22528 + num_resource: 1024 + type: 24653 + host_id: 128 + reserved: 0 + + - + start_resource: 16 + num_resource: 64 + type: 24704 + host_id: 12 + reserved: 0 + + - + start_resource: 80 + num_resource: 40 + type: 24704 + host_id: 13 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 24704 + host_id: 3 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 24704 + host_id: 4 + reserved: 0 + + - + start_resource: 124 + num_resource: 4 + type: 24704 + host_id: 5 + reserved: 0 + + - + start_resource: 128 + num_resource: 24 + type: 24704 + host_id: 128 + reserved: 0 + + - + start_resource: 1 + num_resource: 12 + type: 24896 + host_id: 12 + reserved: 0 + + - + start_resource: 13 + num_resource: 4 + type: 24896 + host_id: 13 + reserved: 0 + + - + start_resource: 17 + num_resource: 16 + type: 24896 + host_id: 3 + reserved: 0 + + - + start_resource: 17 + num_resource: 16 + type: 24896 + host_id: 4 + reserved: 0 + + - + start_resource: 33 + num_resource: 16 + type: 24896 + host_id: 5 + reserved: 0 + + - + start_resource: 49 + num_resource: 15 + type: 24896 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 25024 + host_id: 128 + reserved: 0 + + - + start_resource: 304 + num_resource: 100 + type: 25025 + host_id: 12 + reserved: 0 + + - + start_resource: 404 + num_resource: 50 + type: 25025 + host_id: 13 + reserved: 0 + + - + start_resource: 454 + num_resource: 256 + type: 25025 + host_id: 3 + reserved: 0 + + - + start_resource: 454 + num_resource: 256 + type: 25025 + host_id: 4 + reserved: 0 + + - + start_resource: 710 + num_resource: 32 + type: 25025 + host_id: 5 + reserved: 0 + + - + start_resource: 742 + num_resource: 26 + type: 25025 + host_id: 128 + reserved: 0 + + - + start_resource: 160 + num_resource: 12 + type: 25026 + host_id: 12 + reserved: 0 + + - + start_resource: 172 + num_resource: 4 + type: 25026 + host_id: 3 + reserved: 0 + + - + start_resource: 172 + num_resource: 4 + type: 25026 + host_id: 4 + reserved: 0 + + - + start_resource: 172 + num_resource: 0 + type: 25026 + host_id: 13 + reserved: 0 + + - + start_resource: 176 + num_resource: 2 + type: 25026 + host_id: 5 + reserved: 0 + + - + start_resource: 178 + num_resource: 52 + type: 25026 + host_id: 12 + reserved: 0 + + - + start_resource: 230 + num_resource: 8 + type: 25026 + host_id: 13 + reserved: 0 + + - + start_resource: 238 + num_resource: 32 + type: 25026 + host_id: 3 + reserved: 0 + + - + start_resource: 238 + num_resource: 32 + type: 25026 + host_id: 4 + reserved: 0 + + - + start_resource: 270 + num_resource: 14 + type: 25026 + host_id: 5 + reserved: 0 + + - + start_resource: 284 + num_resource: 18 + type: 25026 + host_id: 128 + reserved: 0 + + - + start_resource: 8 + num_resource: 12 + type: 25027 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 25027 + host_id: 3 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 25027 + host_id: 4 + reserved: 0 + + - + start_resource: 20 + num_resource: 0 + type: 25027 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 25027 + host_id: 5 + reserved: 0 + + - + start_resource: 26 + num_resource: 38 + type: 25027 + host_id: 12 + reserved: 0 + + - + start_resource: 64 + num_resource: 8 + type: 25027 + host_id: 13 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 25027 + host_id: 3 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 25027 + host_id: 4 + reserved: 0 + + - + start_resource: 104 + num_resource: 14 + type: 25027 + host_id: 5 + reserved: 0 + + - + start_resource: 118 + num_resource: 2 + type: 25027 + host_id: 128 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 25028 + host_id: 12 + reserved: 0 + + - + start_resource: 124 + num_resource: 4 + type: 25028 + host_id: 13 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 25028 + host_id: 3 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 25028 + host_id: 4 + reserved: 0 + + - + start_resource: 140 + num_resource: 12 + type: 25028 + host_id: 5 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 25029 + host_id: 3 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 25029 + host_id: 4 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 25029 + host_id: 5 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 25029 + host_id: 12 + reserved: 0 + + - + start_resource: 154 + num_resource: 2 + type: 25029 + host_id: 12 + reserved: 0 + + - + start_resource: 156 + num_resource: 2 + type: 25029 + host_id: 3 + reserved: 0 + + - + start_resource: 156 + num_resource: 2 + type: 25029 + host_id: 4 + reserved: 0 + + - + start_resource: 158 + num_resource: 2 + type: 25029 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25031 + host_id: 3 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25031 + host_id: 4 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25031 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25031 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 3 + type: 25031 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 25031 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 25031 + host_id: 4 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 25031 + host_id: 5 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 25034 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 25034 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 25035 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 25035 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 25035 + host_id: 4 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 25035 + host_id: 5 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 25035 + host_id: 128 + reserved: 0 + + - + start_resource: 150 + num_resource: 64 + type: 25088 + host_id: 12 + reserved: 0 + + - + start_resource: 214 + num_resource: 8 + type: 25088 + host_id: 13 + reserved: 0 + + - + start_resource: 222 + num_resource: 64 + type: 25088 + host_id: 3 + reserved: 0 + + - + start_resource: 222 + num_resource: 64 + type: 25088 + host_id: 4 + reserved: 0 + + - + start_resource: 286 + num_resource: 8 + type: 25088 + host_id: 5 + reserved: 0 + + - + start_resource: 294 + num_resource: 6 + type: 25088 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 25089 + host_id: 128 + reserved: 0 + + - + start_resource: 49152 + num_resource: 1024 + type: 25090 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 25091 + host_id: 128 + reserved: 0 + + - + start_resource: 8 + num_resource: 12 + type: 25098 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 25098 + host_id: 3 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 25098 + host_id: 4 + reserved: 0 + + - + start_resource: 20 + num_resource: 0 + type: 25098 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 25098 + host_id: 5 + reserved: 0 + + - + start_resource: 26 + num_resource: 52 + type: 25098 + host_id: 12 + reserved: 0 + + - + start_resource: 78 + num_resource: 8 + type: 25098 + host_id: 13 + reserved: 0 + + - + start_resource: 86 + num_resource: 32 + type: 25098 + host_id: 3 + reserved: 0 + + - + start_resource: 86 + num_resource: 32 + type: 25098 + host_id: 4 + reserved: 0 + + - + start_resource: 118 + num_resource: 14 + type: 25098 + host_id: 5 + reserved: 0 + + - + start_resource: 132 + num_resource: 18 + type: 25098 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 25099 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 25099 + host_id: 4 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 25099 + host_id: 5 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 25099 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 25099 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 25099 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 25099 + host_id: 4 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 25099 + host_id: 5 + reserved: 0 + + - + start_resource: 8 + num_resource: 12 + type: 25101 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 25101 + host_id: 3 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 25101 + host_id: 4 + reserved: 0 + + - + start_resource: 20 + num_resource: 0 + type: 25101 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 25101 + host_id: 5 + reserved: 0 + + - + start_resource: 26 + num_resource: 38 + type: 25101 + host_id: 12 + reserved: 0 + + - + start_resource: 64 + num_resource: 8 + type: 25101 + host_id: 13 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 25101 + host_id: 3 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 25101 + host_id: 4 + reserved: 0 + + - + start_resource: 104 + num_resource: 14 + type: 25101 + host_id: 5 + reserved: 0 + + - + start_resource: 118 + num_resource: 2 + type: 25101 + host_id: 128 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 25102 + host_id: 12 + reserved: 0 + + - + start_resource: 124 + num_resource: 4 + type: 25102 + host_id: 13 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 25102 + host_id: 3 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 25102 + host_id: 4 + reserved: 0 + + - + start_resource: 140 + num_resource: 12 + type: 25102 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25103 + host_id: 3 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25103 + host_id: 4 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25103 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 25103 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 3 + type: 25103 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 25103 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 25103 + host_id: 4 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 25103 + host_id: 5 + reserved: 0 + + - + start_resource: 8 + num_resource: 80 + type: 25162 + host_id: 12 + reserved: 0 + + - + start_resource: 88 + num_resource: 30 + type: 25162 + host_id: 13 + reserved: 0 + + - + start_resource: 118 + num_resource: 50 + type: 25162 + host_id: 3 + reserved: 0 + + - + start_resource: 118 + num_resource: 50 + type: 25162 + host_id: 4 + reserved: 0 + + - + start_resource: 168 + num_resource: 50 + type: 25162 + host_id: 5 + reserved: 0 + + - + start_resource: 218 + num_resource: 38 + type: 25162 + host_id: 128 + reserved: 0 + + - + start_resource: 16392 + num_resource: 512 + type: 25165 + host_id: 12 + reserved: 0 + + - + start_resource: 16904 + num_resource: 128 + type: 25165 + host_id: 13 + reserved: 0 + + - + start_resource: 17032 + num_resource: 256 + type: 25165 + host_id: 3 + reserved: 0 + + - + start_resource: 17032 + num_resource: 256 + type: 25165 + host_id: 4 + reserved: 0 + + - + start_resource: 17288 + num_resource: 256 + type: 25165 + host_id: 5 + reserved: 0 + + - + start_resource: 17544 + num_resource: 376 + type: 25165 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 28 + type: 25600 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 28 + type: 25600 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 28 + type: 25600 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 25664 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 25664 + host_id: 13 + reserved: 0 + + - + start_resource: 16 + num_resource: 24 + type: 25664 + host_id: 3 + reserved: 0 + + - + start_resource: 16 + num_resource: 24 + type: 25664 + host_id: 4 + reserved: 0 + + - + start_resource: 40 + num_resource: 24 + type: 25664 + host_id: 5 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 25856 + host_id: 12 + reserved: 0 + + - + start_resource: 64 + num_resource: 4 + type: 25856 + host_id: 13 + reserved: 0 + + - + start_resource: 68 + num_resource: 16 + type: 25856 + host_id: 3 + reserved: 0 + + - + start_resource: 68 + num_resource: 16 + type: 25856 + host_id: 4 + reserved: 0 + + - + start_resource: 84 + num_resource: 8 + type: 25856 + host_id: 5 + reserved: 0 + + - + start_resource: 92 + num_resource: 4 + type: 25856 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 25857 + host_id: 128 + reserved: 0 + + - + start_resource: 56320 + num_resource: 256 + type: 25858 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 25859 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 25866 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 25866 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 25866 + host_id: 4 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 25866 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 25866 + host_id: 5 + reserved: 0 + + - + start_resource: 10 + num_resource: 12 + type: 25866 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 4 + type: 25866 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 25866 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 25866 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 12 + type: 25866 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 25867 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 25867 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 25867 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 25867 + host_id: 4 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 25869 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 25869 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 25869 + host_id: 4 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 25869 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 25869 + host_id: 5 + reserved: 0 + + - + start_resource: 10 + num_resource: 12 + type: 25869 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 4 + type: 25869 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 25869 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 25869 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 12 + type: 25869 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 25871 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 25871 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 25871 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 25871 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 25920 + host_id: 128 + reserved: 0 + + - + start_resource: 96 + num_resource: 32 + type: 25921 + host_id: 12 + reserved: 0 + + - + start_resource: 128 + num_resource: 8 + type: 25921 + host_id: 13 + reserved: 0 + + - + start_resource: 136 + num_resource: 60 + type: 25921 + host_id: 3 + reserved: 0 + + - + start_resource: 136 + num_resource: 60 + type: 25921 + host_id: 4 + reserved: 0 + + - + start_resource: 196 + num_resource: 60 + type: 25921 + host_id: 5 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 25922 + host_id: 12 + reserved: 0 + + - + start_resource: 52 + num_resource: 4 + type: 25922 + host_id: 3 + reserved: 0 + + - + start_resource: 52 + num_resource: 4 + type: 25922 + host_id: 4 + reserved: 0 + + - + start_resource: 52 + num_resource: 0 + type: 25922 + host_id: 13 + reserved: 0 + + - + start_resource: 56 + num_resource: 2 + type: 25922 + host_id: 5 + reserved: 0 + + - + start_resource: 58 + num_resource: 12 + type: 25922 + host_id: 12 + reserved: 0 + + - + start_resource: 70 + num_resource: 4 + type: 25922 + host_id: 13 + reserved: 0 + + - + start_resource: 74 + num_resource: 10 + type: 25922 + host_id: 3 + reserved: 0 + + - + start_resource: 74 + num_resource: 10 + type: 25922 + host_id: 4 + reserved: 0 + + - + start_resource: 84 + num_resource: 12 + type: 25922 + host_id: 5 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 25923 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 25923 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 25923 + host_id: 4 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 25923 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 25923 + host_id: 5 + reserved: 0 + + - + start_resource: 10 + num_resource: 12 + type: 25923 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 4 + type: 25923 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 25923 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 25923 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 12 + type: 25923 + host_id: 5 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 25925 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 2 + type: 25925 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 25925 + host_id: 4 + reserved: 0 + + - + start_resource: 48 + num_resource: 2 + type: 25925 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 25927 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 25927 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 25927 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 25927 + host_id: 4 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 25930 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 25930 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 25931 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 25931 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 25931 + host_id: 4 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 25931 + host_id: 5 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 25931 + host_id: 128 + reserved: 0 diff --git a/board/ti/am65x/sec-cfg.yaml b/board/ti/am65x/sec-cfg.yaml new file mode 100644 index 0000000000..72478b4fb5 --- /dev/null +++ b/board/ti/am65x/sec-cfg.yaml @@ -0,0 +1,375 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for AM65x +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support added for HS and GP boot binaries for AM65x.
tiboot3.bin, sysfw.itb, tispl.bin and u-boot.img: For HS devices tiboot3.bin_unsigned, sysfw.itb, tispl.bin_unsigned, u-boot.img_unsigned: For GP devices
Note that the bootflow followed by AM65x requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs sysfw.itb: * sysfw * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * ATF * OPTEE * A53 SPL * A53 SPL dtbs
u-boot.img: * A53 U-Boot * A53 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 1 + .../dts/k3-am654-r5-base-board-u-boot.dtsi | 1 + arch/arm/dts/k3-am65x-binman.dtsi | 543 ++++++++++++++++++ board/ti/am65x/Kconfig | 2 + 4 files changed, 547 insertions(+) create mode 100644 arch/arm/dts/k3-am65x-binman.dtsi
diff --git a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi index 0c1305df7e..e4cbc47c2a 100644 --- a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include "k3-am654-r5-base-board-u-boot.dtsi" +#include "k3-am65x-binman.dtsi"
&pru0_0 { remoteproc-name = "pru0_0"; diff --git a/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi index 4516ab1437..949320c91d 100644 --- a/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi @@ -5,6 +5,7 @@
#include <dt-bindings/pinctrl/k3.h> #include <dt-bindings/net/ti-dp83867.h> +#include "k3-am65x-binman.dtsi"
/ { chosen { diff --git a/arch/arm/dts/k3-am65x-binman.dtsi b/arch/arm/dts/k3-am65x-binman.dtsi new file mode 100644 index 0000000000..890de42ef3 --- /dev/null +++ b/arch/arm/dts/k3-am65x-binman.dtsi @@ -0,0 +1,543 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +#ifdef CONFIG_TARGET_AM654_R5_EVM + +&binman { + board-cfg { + filename = "board-cfg.bin"; + ti-board-config { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + ti-board-config { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + ti-board-config { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + ti-board-config { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + + tiboot3 { + filename = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + keyfile = "custMpk.pem"; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + }; + sysfw { + filename = "sysfw.bin"; + ti-secure-rom { + content = <&ti_sci_cert>; + core = "secure"; + load = <0x40000>; + keyfile = "custMpk.pem"; + countersign; + }; + ti_sci_cert: ti-sci-cert.bin { + filename = "ti-sci-firmware-am65x-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + ti-sci-firmware-am65x-hs-enc.bin { + filename = "ti-sci-firmware-am65x-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + }; + itb { + filename = "sysfw-am65x-hs.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&board_cfg>; + keyfile = "custMpk.pem"; + }; + board_cfg: board-cfg { + filename = "board-cfg.bin"; + type = "blob-ext"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&pm_cfg>; + keyfile = "custMpk.pem"; + }; + pm_cfg: pm-cfg { + filename = "pm-cfg.bin"; + type = "blob-ext"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&rm_cfg>; + keyfile = "custMpk.pem";\ + }; + rm_cfg: rm-cfg { + filename = "rm-cfg.bin"; + type = "blob-ext"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&sec_cfg>; + keyfile = "custMpk.pem"; + }; + sec_cfg: sec-cfg { + filename = "sec-cfg.bin"; + type = "blob-ext"; + }; + }; + }; + }; + }; +}; + +&binman { + tiboot3_unsigned { + filename = "tiboot3.bin_unsigned"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + }; + sysfw_gp { + filename = "sysfw.bin_gp"; + ti-secure-rom { + content = <&ti_sci>; + core = "secure"; + load = <0x40000>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + countersign; + }; + ti_sci: ti-sci.bin { + filename = "ti-sci-firmware-am65x-gp.bin"; + type = "blob-ext"; + optional; + }; + }; + itb_gp { + filename = "sysfw-am65x-gp-evm.itb"; + symlink = "sysfw.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin_gp"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "board-cfg.bin"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "pm-cfg.bin"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "rm-cfg.bin"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sec-cfg.bin"; + }; + }; + }; + }; + }; +}; +#endif + +#ifdef CONFIG_TARGET_AM654_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM654_EVM_DTB "spl/dts/k3-am654-base-board.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM654_EVM_DTB "arch/arm/dts/k3-am654-base-board.dtb" + +&binman { + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am654-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am65x_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am65x_evm_dtb: blob-ext { + filename = SPL_AM654_EVM_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am654-base-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM65 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am654-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am65x_evm_dtb>; + keyfile = "custMpk.pem"; + + }; + am65x_evm_dtb: blob-ext { + filename = AM654_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am654-base-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-1 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM654_EVM_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-am654-base-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM65 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am654-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM654_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-am654-base-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/board/ti/am65x/Kconfig b/board/ti/am65x/Kconfig index 220dd0234c..5fd19d652a 100644 --- a/board/ti/am65x/Kconfig +++ b/board/ti/am65x/Kconfig @@ -12,6 +12,7 @@ config TARGET_AM654_A53_EVM select ARM64 select SYS_DISABLE_DCACHE_OPS select BOARD_LATE_INIT + select BINMAN imply TI_I2C_BOARD_DETECT
config TARGET_AM654_R5_EVM @@ -20,6 +21,7 @@ config TARGET_AM654_R5_EVM select SYS_THUMB_BUILD select K3_LOAD_SYSFW select K3_AM654_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML config for AM64xx
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am64x/board-cfg.yaml | 37 + board/ti/am64x/pm-cfg.yaml | 12 + board/ti/am64x/rm-cfg.yaml | 1400 +++++++++++++++++++++++++++++++++ board/ti/am64x/sec-cfg.yaml | 378 +++++++++ 4 files changed, 1827 insertions(+) create mode 100644 board/ti/am64x/board-cfg.yaml create mode 100644 board/ti/am64x/pm-cfg.yaml create mode 100644 board/ti/am64x/rm-cfg.yaml create mode 100644 board/ti/am64x/sec-cfg.yaml
diff --git a/board/ti/am64x/board-cfg.yaml b/board/ti/am64x/board-cfg.yaml new file mode 100644 index 0000000000..f1f7c68d50 --- /dev/null +++ b/board/ti/am64x/board-cfg.yaml @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM64x +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 + diff --git a/board/ti/am64x/pm-cfg.yaml b/board/ti/am64x/pm-cfg.yaml new file mode 100644 index 0000000000..c97495f482 --- /dev/null +++ b/board/ti/am64x/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM64x +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am64x/rm-cfg.yaml b/board/ti/am64x/rm-cfg.yaml new file mode 100644 index 0000000000..6488c8a9c5 --- /dev/null +++ b/board/ti/am64x/rm-cfg.yaml @@ -0,0 +1,1400 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM64x +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 38 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 41 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #6 + host_id: 43 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #7 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #8 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #9 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #10 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #11 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 1288 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 64 + host_id: 38 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 64 + host_id: 41 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 64 + host_id: 43 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 64 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 192 + host_id: 41 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 192 + host_id: 43 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 41 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 136 + type: 1666 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1667 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1677 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1677 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1677 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1677 + host_id: 38 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 1677 + host_id: 41 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1677 + host_id: 43 + reserved: 0 + + - + start_resource: 26 + num_resource: 1 + type: 1677 + host_id: 30 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1677 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 6 + type: 1678 + host_id: 12 + reserved: 0 + + - + start_resource: 54 + num_resource: 6 + type: 1678 + host_id: 35 + reserved: 0 + + - + start_resource: 54 + num_resource: 6 + type: 1678 + host_id: 36 + reserved: 0 + + - + start_resource: 60 + num_resource: 2 + type: 1678 + host_id: 38 + reserved: 0 + + - + start_resource: 62 + num_resource: 4 + type: 1678 + host_id: 41 + reserved: 0 + + - + start_resource: 66 + num_resource: 2 + type: 1678 + host_id: 43 + reserved: 0 + + - + start_resource: 28 + num_resource: 6 + type: 1679 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 6 + type: 1679 + host_id: 35 + reserved: 0 + + - + start_resource: 34 + num_resource: 6 + type: 1679 + host_id: 36 + reserved: 0 + + - + start_resource: 40 + num_resource: 2 + type: 1679 + host_id: 38 + reserved: 0 + + - + start_resource: 42 + num_resource: 4 + type: 1679 + host_id: 41 + reserved: 0 + + - + start_resource: 46 + num_resource: 2 + type: 1679 + host_id: 43 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1696 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1696 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1696 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1696 + host_id: 38 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 1696 + host_id: 41 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1696 + host_id: 43 + reserved: 0 + + - + start_resource: 26 + num_resource: 1 + type: 1696 + host_id: 30 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1696 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 1697 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1697 + host_id: 35 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1697 + host_id: 36 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 1697 + host_id: 38 + reserved: 0 + + - + start_resource: 14 + num_resource: 4 + type: 1697 + host_id: 41 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1697 + host_id: 43 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 1698 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1698 + host_id: 35 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1698 + host_id: 36 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 1698 + host_id: 38 + reserved: 0 + + - + start_resource: 14 + num_resource: 4 + type: 1698 + host_id: 41 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1698 + host_id: 43 + reserved: 0 + + - + start_resource: 4 + num_resource: 36 + type: 1802 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 14 + type: 1802 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 14 + type: 1802 + host_id: 36 + reserved: 0 + + - + start_resource: 58 + num_resource: 14 + type: 1802 + host_id: 38 + reserved: 0 + + - + start_resource: 92 + num_resource: 14 + type: 1802 + host_id: 41 + reserved: 0 + + - + start_resource: 106 + num_resource: 14 + type: 1802 + host_id: 43 + reserved: 0 + + - + start_resource: 168 + num_resource: 16 + type: 1802 + host_id: 30 + reserved: 0 + + - + start_resource: 15 + num_resource: 512 + type: 1805 + host_id: 12 + reserved: 0 + + - + start_resource: 527 + num_resource: 256 + type: 1805 + host_id: 35 + reserved: 0 + + - + start_resource: 527 + num_resource: 256 + type: 1805 + host_id: 36 + reserved: 0 + + - + start_resource: 783 + num_resource: 192 + type: 1805 + host_id: 38 + reserved: 0 + + - + start_resource: 975 + num_resource: 256 + type: 1805 + host_id: 41 + reserved: 0 + + - + start_resource: 1231 + num_resource: 192 + type: 1805 + host_id: 43 + reserved: 0 + + - + start_resource: 1423 + num_resource: 96 + type: 1805 + host_id: 30 + reserved: 0 + + - + start_resource: 1519 + num_resource: 17 + type: 1805 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 1807 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 42 + type: 1808 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 112 + type: 1809 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 29 + type: 1810 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 176 + type: 1811 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 176 + type: 1812 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 176 + type: 1813 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 28 + type: 1814 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 28 + type: 1815 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 28 + type: 1816 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 20 + type: 1817 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 20 + type: 1818 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 20 + type: 1819 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 20 + type: 1820 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 20 + type: 1821 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 20 + type: 1822 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1923 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1936 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1936 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1936 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1936 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1936 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1936 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1936 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 64 + type: 1937 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 64 + type: 1937 + host_id: 35 + reserved: 0 + + - + start_resource: 88 + num_resource: 8 + type: 1939 + host_id: 12 + reserved: 0 + + - + start_resource: 96 + num_resource: 8 + type: 1940 + host_id: 12 + reserved: 0 + + - + start_resource: 104 + num_resource: 8 + type: 1941 + host_id: 12 + reserved: 0 + + - + start_resource: 112 + num_resource: 4 + type: 1942 + host_id: 12 + reserved: 0 + + - + start_resource: 116 + num_resource: 3 + type: 1942 + host_id: 35 + reserved: 0 + + - + start_resource: 116 + num_resource: 3 + type: 1942 + host_id: 36 + reserved: 0 + + - + start_resource: 119 + num_resource: 2 + type: 1942 + host_id: 38 + reserved: 0 + + - + start_resource: 121 + num_resource: 4 + type: 1942 + host_id: 41 + reserved: 0 + + - + start_resource: 125 + num_resource: 2 + type: 1942 + host_id: 43 + reserved: 0 + + - + start_resource: 127 + num_resource: 1 + type: 1942 + host_id: 30 + reserved: 0 + + - + start_resource: 128 + num_resource: 16 + type: 1943 + host_id: 12 + reserved: 0 + + - + start_resource: 128 + num_resource: 16 + type: 1943 + host_id: 35 + reserved: 0 + + - + start_resource: 144 + num_resource: 8 + type: 1945 + host_id: 128 + reserved: 0 + + - + start_resource: 152 + num_resource: 8 + type: 1946 + host_id: 12 + reserved: 0 + + - + start_resource: 152 + num_resource: 8 + type: 1947 + host_id: 12 + reserved: 0 + + - + start_resource: 160 + num_resource: 64 + type: 1948 + host_id: 12 + reserved: 0 + + - + start_resource: 224 + num_resource: 64 + type: 1949 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1955 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1955 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1955 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1955 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1955 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1955 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1955 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 1956 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 1956 + host_id: 35 + reserved: 0 + + - + start_resource: 25 + num_resource: 1 + type: 1958 + host_id: 12 + reserved: 0 + + - + start_resource: 26 + num_resource: 8 + type: 1959 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 8 + type: 1960 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1961 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1961 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1961 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1961 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1961 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1961 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1961 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1962 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1962 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1962 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1962 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1962 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1962 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1962 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 1 + type: 1963 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 1 + type: 1963 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 1964 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 1964 + host_id: 35 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 1966 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 1968 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1969 + host_id: 12 + reserved: 0 + + - + start_resource: 40 + num_resource: 8 + type: 1970 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 1971 + host_id: 12 + reserved: 0 + + - + start_resource: 40 + num_resource: 8 + type: 1972 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 4 + type: 1973 + host_id: 12 + reserved: 0 + + - + start_resource: 48 + num_resource: 64 + type: 1974 + host_id: 12 + reserved: 0 + + - + start_resource: 25 + num_resource: 4 + type: 1975 + host_id: 12 + reserved: 0 + + - + start_resource: 112 + num_resource: 64 + type: 1976 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2112 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 2122 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 2124 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 2124 + host_id: 36 + reserved: 0 + + - + start_resource: 22 + num_resource: 2 + type: 2124 + host_id: 38 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2124 + host_id: 41 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 2124 + host_id: 43 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 2124 + host_id: 128 + reserved: 0 diff --git a/board/ti/am64x/sec-cfg.yaml b/board/ti/am64x/sec-cfg.yaml new file mode 100644 index 0000000000..f93e9515b2 --- /dev/null +++ b/board/ti/am64x/sec-cfg.yaml @@ -0,0 +1,378 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security configuration for AM64x +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd : 0 + rsvd : 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support added for HS and GP boot binaries for AM64x.
tiboot3.bin, tispl.bin and u-boot.img: For HS devices tiboot3.bin_unsigned, tispl.bin_unsigned, u-boot.img_unsigned: For GP devices
Note that the bootflow followed by AM64x requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * sysfw * board-cfg * pm-cfg * sec-cfg * rm-cfg
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 2 + arch/arm/dts/k3-am642-r5-evm.dts | 1 + arch/arm/dts/k3-am64x-binman.dtsi | 521 ++++++++++++++++++++++++++ board/ti/am64x/Kconfig | 2 + 4 files changed, 526 insertions(+) create mode 100644 arch/arm/dts/k3-am64x-binman.dtsi
diff --git a/arch/arm/dts/k3-am642-evm-u-boot.dtsi b/arch/arm/dts/k3-am642-evm-u-boot.dtsi index 64857b0909..73577e8cfd 100644 --- a/arch/arm/dts/k3-am642-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-evm-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-am64x-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/arch/arm/dts/k3-am642-r5-evm.dts b/arch/arm/dts/k3-am642-r5-evm.dts index ca5ce4a35a..d6b1ec6e58 100644 --- a/arch/arm/dts/k3-am642-r5-evm.dts +++ b/arch/arm/dts/k3-am642-r5-evm.dts @@ -8,6 +8,7 @@ #include "k3-am642.dtsi" #include "k3-am64-evm-ddr4-1600MTs.dtsi" #include "k3-am64-ddr.dtsi" +#include "k3-am64x-binman.dtsi"
/ { chosen { diff --git a/arch/arm/dts/k3-am64x-binman.dtsi b/arch/arm/dts/k3-am64x-binman.dtsi new file mode 100644 index 0000000000..ff746f2565 --- /dev/null +++ b/arch/arm/dts/k3-am64x-binman.dtsi @@ -0,0 +1,521 @@ +// SPDX-License-Identifier: GPL-2.0+ +// Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + +#include <config.h> + +/ { + binman: binman { + multiple-images; + }; +}; + +#ifdef CONFIG_TARGET_AM642_R5_EVM + +&binman { + board-cfg { + filename = "board-cfg.bin"; + ti-board-config { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + ti-board-config { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + ti-board-config { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + ti-board-config { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + combined-sysfw-cfg { + filename = "combined-sysfw-cfg.bin"; + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + }; + tiboot3 { + filename = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_sci_enc>, + <&combined_sysfw_cfg>, <&sysfw_inner_cert>; + combined; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_sci_enc>; + content-sysfw-data = <&combined_sysfw_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + load = <0x70000000>; + load-sysfw = <0x44000>; + load-sysfw-data = <0x7b000>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_sci_enc: ti-fs-enc.bin { + filename = "ti-sci-firmware-am64x_sr2-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_sysfw_cfg: blob-ext@1 { + filename = "combined-sysfw-cfg.bin"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sci-firmware-am64x_sr2-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + + }; +}; + +&binman { + tiboot3_unsigned { + filename = "tiboot3.bin_unsigned"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_sci_gp>, <&combined_sysfw_cfg_gp>; + combined; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x70000000>; + content-sysfw = <&ti_sci_gp>; + load-sysfw = <0x44000>; + content-sysfw-data = <&combined_sysfw_cfg_gp>; + load-sysfw-data = <0x7b000>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_sci_gp: ti-sci-gp.bin { + filename = "ti-sci-firmware-am64x-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_sysfw_cfg_gp: combined-sysfw-cfg-gp.bin { + filename = "combined-sysfw-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +#endif + +#ifdef CONFIG_TARGET_AM642_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM642_EVM_DTB "spl/dts/k3-am642-evm.dtb" +#define SPL_AM642_SK_DTB "spl/dts/k3-am642-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM642_EVM_DTB "arch/arm/dts/k3-am642-evm.dtb" +#define AM642_SK_DTB "arch/arm/dts/k3-am642-sk.dtb" + +&binman { + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am64x_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am64x_evm_dtb: blob-ext { + filename = SPL_AM642_EVM_DTB; + }; + + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am64x_sk_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am64x_sk_dtb: blob-ext { + filename = SPL_AM642_SK_DTB; + }; + + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM64 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am64x_evm_dtb>; + keyfile = "custMpk.pem"; + + }; + am64x_evm_dtb: blob-ext { + filename = AM642_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am64x_sk_dtb>; + keyfile = "custMpk.pem"; + + }; + am64x_sk_dtb: blob-ext { + filename = AM642_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM642_EVM_DTB; + }; + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM642_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM64 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM642_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM642_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/board/ti/am64x/Kconfig b/board/ti/am64x/Kconfig index afb54f8cda..fb596e4adf 100644 --- a/board/ti/am64x/Kconfig +++ b/board/ti/am64x/Kconfig @@ -9,6 +9,7 @@ choice config TARGET_AM642_A53_EVM bool "TI K3 based AM642 EVM running on A53" select ARM64 + select BINMAN imply BOARD imply SPL_BOARD imply TI_I2C_BOARD_DETECT @@ -21,6 +22,7 @@ config TARGET_AM642_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML config for J721S2
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/j721s2/board-cfg.yaml | 37 + board/ti/j721s2/pm-cfg.yaml | 12 + board/ti/j721s2/rm-cfg.yaml | 2901 ++++++++++++++++++++++++++++++++ board/ti/j721s2/sec-cfg.yaml | 375 +++++ 4 files changed, 3325 insertions(+) create mode 100644 board/ti/j721s2/board-cfg.yaml create mode 100644 board/ti/j721s2/pm-cfg.yaml create mode 100644 board/ti/j721s2/rm-cfg.yaml create mode 100644 board/ti/j721s2/sec-cfg.yaml
diff --git a/board/ti/j721s2/board-cfg.yaml b/board/ti/j721s2/board-cfg.yaml new file mode 100644 index 0000000000..d80f308ca6 --- /dev/null +++ b/board/ti/j721s2/board-cfg.yaml @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J721S2 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 + diff --git a/board/ti/j721s2/pm-cfg.yaml b/board/ti/j721s2/pm-cfg.yaml new file mode 100644 index 0000000000..45994e23cc --- /dev/null +++ b/board/ti/j721s2/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for J721S2 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/j721s2/rm-cfg.yaml b/board/ti/j721s2/rm-cfg.yaml new file mode 100644 index 0000000000..d18288ae08 --- /dev/null +++ b/board/ti/j721s2/rm-cfg.yaml @@ -0,0 +1,2901 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for J721S2 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 5 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 13 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 21 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #6 + host_id: 23 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #7 + host_id: 35 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #8 + host_id: 37 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #9 + host_id: 40 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #10 + host_id: 42 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 3032 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 32 + type: 18496 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 24 + type: 18496 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 18560 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 16 + type: 18560 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 48 + type: 18688 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 18752 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 18752 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 6 + type: 18752 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 6 + type: 18752 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 2 + type: 18752 + host_id: 35 + reserved: 0 + + - + start_resource: 30 + num_resource: 2 + type: 18752 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 20992 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 20992 + host_id: 37 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 20992 + host_id: 40 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 20992 + host_id: 42 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 20992 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 20992 + host_id: 5 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 20992 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 12 + type: 20992 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 21504 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 96 + type: 35138 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 35139 + host_id: 128 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 35150 + host_id: 12 + reserved: 0 + + - + start_resource: 32 + num_resource: 16 + type: 35150 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 35151 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 35151 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 35169 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 35169 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 35170 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 35170 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 100 + type: 35264 + host_id: 12 + reserved: 0 + + - + start_resource: 110 + num_resource: 32 + type: 35264 + host_id: 13 + reserved: 0 + + - + start_resource: 142 + num_resource: 21 + type: 35264 + host_id: 21 + reserved: 0 + + - + start_resource: 163 + num_resource: 21 + type: 35264 + host_id: 23 + reserved: 0 + + - + start_resource: 196 + num_resource: 28 + type: 35264 + host_id: 35 + reserved: 0 + + - + start_resource: 228 + num_resource: 28 + type: 35264 + host_id: 37 + reserved: 0 + + - + start_resource: 260 + num_resource: 28 + type: 35264 + host_id: 40 + reserved: 0 + + - + start_resource: 292 + num_resource: 28 + type: 35264 + host_id: 42 + reserved: 0 + + - + start_resource: 400 + num_resource: 4 + type: 35264 + host_id: 3 + reserved: 0 + + - + start_resource: 404 + num_resource: 4 + type: 35264 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 38154 + host_id: 128 + reserved: 0 + + - + start_resource: 20480 + num_resource: 1024 + type: 38157 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 38218 + host_id: 128 + reserved: 0 + + - + start_resource: 22528 + num_resource: 1024 + type: 38221 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 38272 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 38272 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 38272 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 38272 + host_id: 23 + reserved: 0 + + - + start_resource: 16 + num_resource: 12 + type: 38272 + host_id: 35 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 38272 + host_id: 37 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 38272 + host_id: 40 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 38272 + host_id: 42 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 38272 + host_id: 3 + reserved: 0 + + - + start_resource: 44 + num_resource: 4 + type: 38272 + host_id: 5 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 38272 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 38464 + host_id: 128 + reserved: 0 + + - + start_resource: 423 + num_resource: 32 + type: 38465 + host_id: 21 + reserved: 0 + + - + start_resource: 455 + num_resource: 32 + type: 38465 + host_id: 23 + reserved: 0 + + - + start_resource: 487 + num_resource: 182 + type: 38465 + host_id: 35 + reserved: 0 + + - + start_resource: 669 + num_resource: 40 + type: 38465 + host_id: 37 + reserved: 0 + + - + start_resource: 709 + num_resource: 10 + type: 38465 + host_id: 40 + reserved: 0 + + - + start_resource: 719 + num_resource: 10 + type: 38465 + host_id: 42 + reserved: 0 + + - + start_resource: 729 + num_resource: 6 + type: 38465 + host_id: 3 + reserved: 0 + + - + start_resource: 735 + num_resource: 6 + type: 38465 + host_id: 5 + reserved: 0 + + - + start_resource: 878 + num_resource: 128 + type: 38465 + host_id: 12 + reserved: 0 + + - + start_resource: 1006 + num_resource: 10 + type: 38465 + host_id: 13 + reserved: 0 + + - + start_resource: 345 + num_resource: 6 + type: 38466 + host_id: 12 + reserved: 0 + + - + start_resource: 351 + num_resource: 0 + type: 38466 + host_id: 13 + reserved: 0 + + - + start_resource: 351 + num_resource: 2 + type: 38466 + host_id: 21 + reserved: 0 + + - + start_resource: 353 + num_resource: 2 + type: 38466 + host_id: 23 + reserved: 0 + + - + start_resource: 355 + num_resource: 6 + type: 38466 + host_id: 35 + reserved: 0 + + - + start_resource: 361 + num_resource: 1 + type: 38466 + host_id: 37 + reserved: 0 + + - + start_resource: 362 + num_resource: 1 + type: 38466 + host_id: 40 + reserved: 0 + + - + start_resource: 363 + num_resource: 1 + type: 38466 + host_id: 42 + reserved: 0 + + - + start_resource: 364 + num_resource: 2 + type: 38466 + host_id: 3 + reserved: 0 + + - + start_resource: 366 + num_resource: 2 + type: 38466 + host_id: 5 + reserved: 0 + + - + start_resource: 368 + num_resource: 16 + type: 38466 + host_id: 12 + reserved: 0 + + - + start_resource: 384 + num_resource: 12 + type: 38466 + host_id: 13 + reserved: 0 + + - + start_resource: 396 + num_resource: 4 + type: 38466 + host_id: 21 + reserved: 0 + + - + start_resource: 400 + num_resource: 4 + type: 38466 + host_id: 23 + reserved: 0 + + - + start_resource: 404 + num_resource: 12 + type: 38466 + host_id: 35 + reserved: 0 + + - + start_resource: 416 + num_resource: 1 + type: 38466 + host_id: 37 + reserved: 0 + + - + start_resource: 417 + num_resource: 2 + type: 38466 + host_id: 40 + reserved: 0 + + - + start_resource: 419 + num_resource: 2 + type: 38466 + host_id: 42 + reserved: 0 + + - + start_resource: 421 + num_resource: 2 + type: 38466 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 6 + type: 38467 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 0 + type: 38467 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 38467 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 38467 + host_id: 23 + reserved: 0 + + - + start_resource: 14 + num_resource: 6 + type: 38467 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 38467 + host_id: 37 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 38467 + host_id: 40 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 38467 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 2 + type: 38467 + host_id: 3 + reserved: 0 + + - + start_resource: 25 + num_resource: 2 + type: 38467 + host_id: 5 + reserved: 0 + + - + start_resource: 27 + num_resource: 16 + type: 38467 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 12 + type: 38467 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 4 + type: 38467 + host_id: 21 + reserved: 0 + + - + start_resource: 59 + num_resource: 4 + type: 38467 + host_id: 23 + reserved: 0 + + - + start_resource: 63 + num_resource: 12 + type: 38467 + host_id: 35 + reserved: 0 + + - + start_resource: 75 + num_resource: 4 + type: 38467 + host_id: 37 + reserved: 0 + + - + start_resource: 79 + num_resource: 2 + type: 38467 + host_id: 40 + reserved: 0 + + - + start_resource: 81 + num_resource: 2 + type: 38467 + host_id: 42 + reserved: 0 + + - + start_resource: 83 + num_resource: 2 + type: 38467 + host_id: 128 + reserved: 0 + + - + start_resource: 85 + num_resource: 16 + type: 38468 + host_id: 21 + reserved: 0 + + - + start_resource: 101 + num_resource: 12 + type: 38468 + host_id: 23 + reserved: 0 + + - + start_resource: 113 + num_resource: 2 + type: 38468 + host_id: 35 + reserved: 0 + + - + start_resource: 115 + num_resource: 2 + type: 38468 + host_id: 37 + reserved: 0 + + - + start_resource: 117 + num_resource: 192 + type: 38468 + host_id: 35 + reserved: 0 + + - + start_resource: 309 + num_resource: 32 + type: 38468 + host_id: 37 + reserved: 0 + + - + start_resource: 343 + num_resource: 1 + type: 38469 + host_id: 12 + reserved: 0 + + - + start_resource: 344 + num_resource: 1 + type: 38469 + host_id: 35 + reserved: 0 + + - + start_resource: 341 + num_resource: 1 + type: 38470 + host_id: 12 + reserved: 0 + + - + start_resource: 342 + num_resource: 1 + type: 38470 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 38471 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 38471 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 38472 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 38472 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 5 + type: 38474 + host_id: 12 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 38474 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 38475 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 38475 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 3 + type: 38475 + host_id: 21 + reserved: 0 + + - + start_resource: 8 + num_resource: 3 + type: 38475 + host_id: 23 + reserved: 0 + + - + start_resource: 11 + num_resource: 6 + type: 38475 + host_id: 35 + reserved: 0 + + - + start_resource: 17 + num_resource: 3 + type: 38475 + host_id: 37 + reserved: 0 + + - + start_resource: 20 + num_resource: 3 + type: 38475 + host_id: 40 + reserved: 0 + + - + start_resource: 23 + num_resource: 3 + type: 38475 + host_id: 42 + reserved: 0 + + - + start_resource: 26 + num_resource: 1 + type: 38475 + host_id: 3 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 38475 + host_id: 5 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 38475 + host_id: 128 + reserved: 0 + + - + start_resource: 82 + num_resource: 16 + type: 39104 + host_id: 12 + reserved: 0 + + - + start_resource: 98 + num_resource: 16 + type: 39104 + host_id: 13 + reserved: 0 + + - + start_resource: 114 + num_resource: 110 + type: 39104 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 39105 + host_id: 128 + reserved: 0 + + - + start_resource: 49152 + num_resource: 1024 + type: 39106 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 39107 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 6 + type: 39114 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 0 + type: 39114 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 39114 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 39114 + host_id: 23 + reserved: 0 + + - + start_resource: 14 + num_resource: 6 + type: 39114 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 39114 + host_id: 37 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 39114 + host_id: 40 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 39114 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 2 + type: 39114 + host_id: 3 + reserved: 0 + + - + start_resource: 25 + num_resource: 2 + type: 39114 + host_id: 5 + reserved: 0 + + - + start_resource: 27 + num_resource: 16 + type: 39114 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 12 + type: 39114 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 4 + type: 39114 + host_id: 21 + reserved: 0 + + - + start_resource: 59 + num_resource: 4 + type: 39114 + host_id: 23 + reserved: 0 + + - + start_resource: 63 + num_resource: 12 + type: 39114 + host_id: 35 + reserved: 0 + + - + start_resource: 75 + num_resource: 1 + type: 39114 + host_id: 37 + reserved: 0 + + - + start_resource: 76 + num_resource: 2 + type: 39114 + host_id: 40 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 39114 + host_id: 42 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 39114 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 39115 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 39115 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 39116 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 39116 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 6 + type: 39117 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 0 + type: 39117 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 39117 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 39117 + host_id: 23 + reserved: 0 + + - + start_resource: 14 + num_resource: 6 + type: 39117 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 39117 + host_id: 37 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 39117 + host_id: 40 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 39117 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 2 + type: 39117 + host_id: 3 + reserved: 0 + + - + start_resource: 25 + num_resource: 2 + type: 39117 + host_id: 5 + reserved: 0 + + - + start_resource: 27 + num_resource: 16 + type: 39117 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 12 + type: 39117 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 4 + type: 39117 + host_id: 21 + reserved: 0 + + - + start_resource: 59 + num_resource: 4 + type: 39117 + host_id: 23 + reserved: 0 + + - + start_resource: 63 + num_resource: 12 + type: 39117 + host_id: 35 + reserved: 0 + + - + start_resource: 75 + num_resource: 4 + type: 39117 + host_id: 37 + reserved: 0 + + - + start_resource: 79 + num_resource: 2 + type: 39117 + host_id: 40 + reserved: 0 + + - + start_resource: 81 + num_resource: 2 + type: 39117 + host_id: 42 + reserved: 0 + + - + start_resource: 83 + num_resource: 2 + type: 39117 + host_id: 128 + reserved: 0 + + - + start_resource: 85 + num_resource: 16 + type: 39118 + host_id: 21 + reserved: 0 + + - + start_resource: 101 + num_resource: 12 + type: 39118 + host_id: 23 + reserved: 0 + + - + start_resource: 113 + num_resource: 2 + type: 39118 + host_id: 35 + reserved: 0 + + - + start_resource: 115 + num_resource: 2 + type: 39118 + host_id: 37 + reserved: 0 + + - + start_resource: 117 + num_resource: 192 + type: 39118 + host_id: 35 + reserved: 0 + + - + start_resource: 309 + num_resource: 32 + type: 39118 + host_id: 37 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 39119 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 39119 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 39120 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 39120 + host_id: 35 + reserved: 0 + + - + start_resource: 34 + num_resource: 86 + type: 39242 + host_id: 12 + reserved: 0 + + - + start_resource: 120 + num_resource: 32 + type: 39242 + host_id: 13 + reserved: 0 + + - + start_resource: 152 + num_resource: 12 + type: 39242 + host_id: 21 + reserved: 0 + + - + start_resource: 164 + num_resource: 12 + type: 39242 + host_id: 23 + reserved: 0 + + - + start_resource: 176 + num_resource: 28 + type: 39242 + host_id: 35 + reserved: 0 + + - + start_resource: 204 + num_resource: 8 + type: 39242 + host_id: 37 + reserved: 0 + + - + start_resource: 212 + num_resource: 12 + type: 39242 + host_id: 40 + reserved: 0 + + - + start_resource: 224 + num_resource: 12 + type: 39242 + host_id: 42 + reserved: 0 + + - + start_resource: 236 + num_resource: 20 + type: 39242 + host_id: 128 + reserved: 0 + + - + start_resource: 34 + num_resource: 1024 + type: 39245 + host_id: 12 + reserved: 0 + + - + start_resource: 1058 + num_resource: 512 + type: 39245 + host_id: 13 + reserved: 0 + + - + start_resource: 1570 + num_resource: 256 + type: 39245 + host_id: 21 + reserved: 0 + + - + start_resource: 1826 + num_resource: 256 + type: 39245 + host_id: 23 + reserved: 0 + + - + start_resource: 2082 + num_resource: 512 + type: 39245 + host_id: 35 + reserved: 0 + + - + start_resource: 2594 + num_resource: 256 + type: 39245 + host_id: 37 + reserved: 0 + + - + start_resource: 2850 + num_resource: 256 + type: 39245 + host_id: 40 + reserved: 0 + + - + start_resource: 3106 + num_resource: 256 + type: 39245 + host_id: 42 + reserved: 0 + + - + start_resource: 3362 + num_resource: 32 + type: 39245 + host_id: 3 + reserved: 0 + + - + start_resource: 3394 + num_resource: 32 + type: 39245 + host_id: 5 + reserved: 0 + + - + start_resource: 3426 + num_resource: 1182 + type: 39245 + host_id: 128 + reserved: 0 + + - + start_resource: 1536 + num_resource: 16 + type: 39247 + host_id: 128 + reserved: 0 + + - + start_resource: 2048 + num_resource: 16 + type: 39248 + host_id: 128 + reserved: 0 + + - + start_resource: 2560 + num_resource: 16 + type: 39249 + host_id: 128 + reserved: 0 + + - + start_resource: 3072 + num_resource: 32 + type: 39250 + host_id: 128 + reserved: 0 + + - + start_resource: 3584 + num_resource: 32 + type: 39251 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 32 + type: 39252 + host_id: 128 + reserved: 0 + + - + start_resource: 12 + num_resource: 12 + type: 39424 + host_id: 3 + reserved: 0 + + - + start_resource: 36 + num_resource: 20 + type: 39424 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 4 + type: 40000 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 4 + type: 40000 + host_id: 13 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 40000 + host_id: 21 + reserved: 0 + + - + start_resource: 13 + num_resource: 4 + type: 40000 + host_id: 23 + reserved: 0 + + - + start_resource: 17 + num_resource: 16 + type: 40000 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 4 + type: 40000 + host_id: 37 + reserved: 0 + + - + start_resource: 37 + num_resource: 4 + type: 40000 + host_id: 40 + reserved: 0 + + - + start_resource: 41 + num_resource: 4 + type: 40000 + host_id: 42 + reserved: 0 + + - + start_resource: 45 + num_resource: 4 + type: 40000 + host_id: 3 + reserved: 0 + + - + start_resource: 49 + num_resource: 4 + type: 40000 + host_id: 5 + reserved: 0 + + - + start_resource: 53 + num_resource: 11 + type: 40000 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 40064 + host_id: 128 + reserved: 0 + + - + start_resource: 96 + num_resource: 20 + type: 40065 + host_id: 12 + reserved: 0 + + - + start_resource: 116 + num_resource: 8 + type: 40065 + host_id: 13 + reserved: 0 + + - + start_resource: 124 + num_resource: 8 + type: 40065 + host_id: 21 + reserved: 0 + + - + start_resource: 132 + num_resource: 8 + type: 40065 + host_id: 23 + reserved: 0 + + - + start_resource: 140 + num_resource: 16 + type: 40065 + host_id: 35 + reserved: 0 + + - + start_resource: 156 + num_resource: 8 + type: 40065 + host_id: 37 + reserved: 0 + + - + start_resource: 164 + num_resource: 8 + type: 40065 + host_id: 40 + reserved: 0 + + - + start_resource: 172 + num_resource: 8 + type: 40065 + host_id: 42 + reserved: 0 + + - + start_resource: 180 + num_resource: 32 + type: 40065 + host_id: 3 + reserved: 0 + + - + start_resource: 212 + num_resource: 12 + type: 40065 + host_id: 5 + reserved: 0 + + - + start_resource: 224 + num_resource: 28 + type: 40065 + host_id: 128 + reserved: 0 + + - + start_resource: 50 + num_resource: 4 + type: 40066 + host_id: 12 + reserved: 0 + + - + start_resource: 54 + num_resource: 0 + type: 40066 + host_id: 13 + reserved: 0 + + - + start_resource: 54 + num_resource: 1 + type: 40066 + host_id: 21 + reserved: 0 + + - + start_resource: 55 + num_resource: 1 + type: 40066 + host_id: 23 + reserved: 0 + + - + start_resource: 56 + num_resource: 1 + type: 40066 + host_id: 35 + reserved: 0 + + - + start_resource: 57 + num_resource: 1 + type: 40066 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 1 + type: 40066 + host_id: 40 + reserved: 0 + + - + start_resource: 59 + num_resource: 1 + type: 40066 + host_id: 42 + reserved: 0 + + - + start_resource: 60 + num_resource: 2 + type: 40066 + host_id: 3 + reserved: 0 + + - + start_resource: 62 + num_resource: 0 + type: 40066 + host_id: 5 + reserved: 0 + + - + start_resource: 62 + num_resource: 9 + type: 40066 + host_id: 12 + reserved: 0 + + - + start_resource: 71 + num_resource: 6 + type: 40066 + host_id: 13 + reserved: 0 + + - + start_resource: 77 + num_resource: 1 + type: 40066 + host_id: 21 + reserved: 0 + + - + start_resource: 78 + num_resource: 1 + type: 40066 + host_id: 23 + reserved: 0 + + - + start_resource: 79 + num_resource: 2 + type: 40066 + host_id: 35 + reserved: 0 + + - + start_resource: 81 + num_resource: 1 + type: 40066 + host_id: 37 + reserved: 0 + + - + start_resource: 82 + num_resource: 1 + type: 40066 + host_id: 40 + reserved: 0 + + - + start_resource: 83 + num_resource: 1 + type: 40066 + host_id: 42 + reserved: 0 + + - + start_resource: 84 + num_resource: 3 + type: 40066 + host_id: 3 + reserved: 0 + + - + start_resource: 87 + num_resource: 2 + type: 40066 + host_id: 5 + reserved: 0 + + - + start_resource: 89 + num_resource: 4 + type: 40066 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 40067 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 40067 + host_id: 13 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 40067 + host_id: 21 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 40067 + host_id: 23 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 40067 + host_id: 35 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 40067 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 40067 + host_id: 40 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 40067 + host_id: 42 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 40067 + host_id: 3 + reserved: 0 + + - + start_resource: 14 + num_resource: 0 + type: 40067 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 9 + type: 40067 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 6 + type: 40067 + host_id: 13 + reserved: 0 + + - + start_resource: 29 + num_resource: 1 + type: 40067 + host_id: 21 + reserved: 0 + + - + start_resource: 30 + num_resource: 1 + type: 40067 + host_id: 23 + reserved: 0 + + - + start_resource: 31 + num_resource: 2 + type: 40067 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 1 + type: 40067 + host_id: 37 + reserved: 0 + + - + start_resource: 34 + num_resource: 1 + type: 40067 + host_id: 40 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 40067 + host_id: 42 + reserved: 0 + + - + start_resource: 36 + num_resource: 3 + type: 40067 + host_id: 3 + reserved: 0 + + - + start_resource: 39 + num_resource: 2 + type: 40067 + host_id: 5 + reserved: 0 + + - + start_resource: 41 + num_resource: 5 + type: 40067 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 40069 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 2 + type: 40069 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 40071 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 40071 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 5 + type: 40074 + host_id: 12 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 40074 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 40075 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 40075 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 3 + type: 40075 + host_id: 21 + reserved: 0 + + - + start_resource: 8 + num_resource: 3 + type: 40075 + host_id: 23 + reserved: 0 + + - + start_resource: 11 + num_resource: 3 + type: 40075 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 3 + type: 40075 + host_id: 37 + reserved: 0 + + - + start_resource: 17 + num_resource: 3 + type: 40075 + host_id: 40 + reserved: 0 + + - + start_resource: 20 + num_resource: 3 + type: 40075 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 3 + type: 40075 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 3 + type: 40075 + host_id: 5 + reserved: 0 + + - + start_resource: 29 + num_resource: 3 + type: 40075 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 8 + type: 40128 + host_id: 12 + reserved: 0 + + - + start_resource: 56 + num_resource: 4 + type: 40128 + host_id: 13 + reserved: 0 + + - + start_resource: 60 + num_resource: 8 + type: 40128 + host_id: 35 + reserved: 0 + + - + start_resource: 68 + num_resource: 4 + type: 40128 + host_id: 37 + reserved: 0 + + - + start_resource: 72 + num_resource: 4 + type: 40128 + host_id: 40 + reserved: 0 + + - + start_resource: 76 + num_resource: 4 + type: 40128 + host_id: 42 + reserved: 0 + + - + start_resource: 80 + num_resource: 8 + type: 40128 + host_id: 3 + reserved: 0 + + - + start_resource: 88 + num_resource: 4 + type: 40128 + host_id: 5 + reserved: 0 + + - + start_resource: 92 + num_resource: 4 + type: 40128 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 40129 + host_id: 128 + reserved: 0 + + - + start_resource: 56320 + num_resource: 256 + type: 40130 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 40131 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 40138 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 40138 + host_id: 13 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 40138 + host_id: 21 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 40138 + host_id: 23 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 40138 + host_id: 35 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 40138 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 40138 + host_id: 40 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 40138 + host_id: 42 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 40138 + host_id: 3 + reserved: 0 + + - + start_resource: 14 + num_resource: 0 + type: 40138 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 9 + type: 40138 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 6 + type: 40138 + host_id: 13 + reserved: 0 + + - + start_resource: 29 + num_resource: 1 + type: 40138 + host_id: 21 + reserved: 0 + + - + start_resource: 30 + num_resource: 1 + type: 40138 + host_id: 23 + reserved: 0 + + - + start_resource: 31 + num_resource: 2 + type: 40138 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 1 + type: 40138 + host_id: 37 + reserved: 0 + + - + start_resource: 34 + num_resource: 1 + type: 40138 + host_id: 40 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 40138 + host_id: 42 + reserved: 0 + + - + start_resource: 36 + num_resource: 3 + type: 40138 + host_id: 3 + reserved: 0 + + - + start_resource: 39 + num_resource: 2 + type: 40138 + host_id: 5 + reserved: 0 + + - + start_resource: 41 + num_resource: 4 + type: 40138 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 40139 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 40139 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 40141 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 40141 + host_id: 13 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 40141 + host_id: 21 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 40141 + host_id: 23 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 40141 + host_id: 35 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 40141 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 40141 + host_id: 40 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 40141 + host_id: 42 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 40141 + host_id: 3 + reserved: 0 + + - + start_resource: 14 + num_resource: 0 + type: 40141 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 9 + type: 40141 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 6 + type: 40141 + host_id: 13 + reserved: 0 + + - + start_resource: 29 + num_resource: 1 + type: 40141 + host_id: 21 + reserved: 0 + + - + start_resource: 30 + num_resource: 1 + type: 40141 + host_id: 23 + reserved: 0 + + - + start_resource: 31 + num_resource: 2 + type: 40141 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 1 + type: 40141 + host_id: 37 + reserved: 0 + + - + start_resource: 34 + num_resource: 1 + type: 40141 + host_id: 40 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 40141 + host_id: 42 + reserved: 0 + + - + start_resource: 36 + num_resource: 3 + type: 40141 + host_id: 3 + reserved: 0 + + - + start_resource: 39 + num_resource: 2 + type: 40141 + host_id: 5 + reserved: 0 + + - + start_resource: 41 + num_resource: 5 + type: 40141 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 40143 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 40143 + host_id: 3 + reserved: 0 + + - + start_resource: 22 + num_resource: 32 + type: 40266 + host_id: 12 + reserved: 0 + + - + start_resource: 54 + num_resource: 16 + type: 40266 + host_id: 13 + reserved: 0 + + - + start_resource: 70 + num_resource: 8 + type: 40266 + host_id: 21 + reserved: 0 + + - + start_resource: 78 + num_resource: 8 + type: 40266 + host_id: 23 + reserved: 0 + + - + start_resource: 86 + num_resource: 24 + type: 40266 + host_id: 35 + reserved: 0 + + - + start_resource: 110 + num_resource: 8 + type: 40266 + host_id: 37 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 40266 + host_id: 40 + reserved: 0 + + - + start_resource: 134 + num_resource: 16 + type: 40266 + host_id: 42 + reserved: 0 + + - + start_resource: 150 + num_resource: 64 + type: 40266 + host_id: 3 + reserved: 0 + + - + start_resource: 214 + num_resource: 4 + type: 40266 + host_id: 5 + reserved: 0 + + - + start_resource: 218 + num_resource: 38 + type: 40266 + host_id: 128 + reserved: 0 + + - + start_resource: 16406 + num_resource: 128 + type: 40269 + host_id: 12 + reserved: 0 + + - + start_resource: 16534 + num_resource: 128 + type: 40269 + host_id: 13 + reserved: 0 + + - + start_resource: 16662 + num_resource: 64 + type: 40269 + host_id: 21 + reserved: 0 + + - + start_resource: 16726 + num_resource: 64 + type: 40269 + host_id: 23 + reserved: 0 + + - + start_resource: 16790 + num_resource: 128 + type: 40269 + host_id: 35 + reserved: 0 + + - + start_resource: 16918 + num_resource: 128 + type: 40269 + host_id: 37 + reserved: 0 + + - + start_resource: 17046 + num_resource: 128 + type: 40269 + host_id: 40 + reserved: 0 + + - + start_resource: 17174 + num_resource: 128 + type: 40269 + host_id: 42 + reserved: 0 + + - + start_resource: 17302 + num_resource: 256 + type: 40269 + host_id: 3 + reserved: 0 + + - + start_resource: 17558 + num_resource: 64 + type: 40269 + host_id: 5 + reserved: 0 + + - + start_resource: 17622 + num_resource: 298 + type: 40269 + host_id: 128 + reserved: 0 diff --git a/board/ti/j721s2/sec-cfg.yaml b/board/ti/j721s2/sec-cfg.yaml new file mode 100644 index 0000000000..b9a016b760 --- /dev/null +++ b/board/ti/j721s2/sec-cfg.yaml @@ -0,0 +1,375 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for J721S2 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x0 + allow_wildcard_unlock : 0x0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support added for HS and GP boot binaries for J721S2.
It is to be noted that the bootflow followed by J721S2 requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * DM * ATF * OPTEE * A72 SPL * A72 SPL dtbs
u-boot.img: * A72 U-Boot * A72 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-j721s2-binman.dtsi | 474 ++++++++++++++++++ .../k3-j721s2-common-proc-board-u-boot.dtsi | 2 + .../dts/k3-j721s2-r5-common-proc-board.dts | 1 + board/ti/j721s2/Kconfig | 2 + 4 files changed, 479 insertions(+) create mode 100644 arch/arm/dts/k3-j721s2-binman.dtsi
diff --git a/arch/arm/dts/k3-j721s2-binman.dtsi b/arch/arm/dts/k3-j721s2-binman.dtsi new file mode 100644 index 0000000000..0c0cde1df2 --- /dev/null +++ b/arch/arm/dts/k3-j721s2-binman.dtsi @@ -0,0 +1,474 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +#ifdef CONFIG_TARGET_J721S2_R5_EVM + +&binman { + board-cfg { + filename = "board-cfg.bin"; + ti-board-config { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + ti-board-config { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + ti-board-config { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + ti-board-config { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + combined-tifs-cfg { + filename = "combined-tifs-cfg.bin"; + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + }; + combined-dm-cfg { + filename = "combined-dm-cfg.bin"; + ti-board-config { + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + + }; + }; + + tiboot3 { + filename = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x41c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x41c80000>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-fs-firmware-j721s2-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: blob-ext@1 { + filename = "combined-tifs-cfg.bin"; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-fs-firmware-j721s2-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + + }; +}; + +&binman { + tiboot3_unsigned { + filename = "tiboot3.bin_unsigned"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x41c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x41c80000>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-fs-firmware-j721s2-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + + }; +}; + +#endif + +#ifdef CONFIG_TARGET_J721S2_A72_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_J721S2_EVM_DTB "spl/dts/k3-j721s2-common-proc-board.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define J721S2_EVM_DTB "arch/arm/dts/k3-j721s2-common-proc-board.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j721s2_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_j721s2_evm_dtb: blob-ext { + filename = SPL_J721S2_EVM_DTB; + }; + + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721s2-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J721S2 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j721s2_evm_dtb>; + keyfile = "custMpk.pem"; + }; + j721s2_evm_dtb: blob-ext { + filename = J721S2_EVM_DTB; + }; + + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721s2-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-1 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J721S2_EVM_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j721s2-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J721S2 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J721S2_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j721s2-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi index 4fd6d36417..f940ffee87 100644 --- a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-j721s2-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts index bc617022c1..e04cee3d99 100644 --- a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts @@ -8,6 +8,7 @@ #include "k3-j721s2-som-p0.dtsi" #include "k3-j721s2-ddr-evm-lp4-4266.dtsi" #include "k3-j721s2-ddr.dtsi" +#include "k3-j721s2-binman.dtsi"
/ { chosen { diff --git a/board/ti/j721s2/Kconfig b/board/ti/j721s2/Kconfig index a24641f8cf..f6d1cb5765 100644 --- a/board/ti/j721s2/Kconfig +++ b/board/ti/j721s2/Kconfig @@ -13,6 +13,7 @@ config TARGET_J721S2_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J721S2_R5_EVM bool "TI K3 based J721S2 EVM running on R5" @@ -22,6 +23,7 @@ config TARGET_J721S2_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML config for AM62
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am62x/board-cfg.yaml | 36 ++ board/ti/am62x/pm-cfg.yaml | 12 + board/ti/am62x/rm-cfg.yaml | 1088 +++++++++++++++++++++++++++++++++ board/ti/am62x/sec-cfg.yaml | 375 ++++++++++++ board/ti/am65x/rm-cfg.yaml | 144 ++--- 5 files changed, 1583 insertions(+), 72 deletions(-) create mode 100644 board/ti/am62x/board-cfg.yaml create mode 100644 board/ti/am62x/pm-cfg.yaml create mode 100644 board/ti/am62x/rm-cfg.yaml create mode 100644 board/ti/am62x/sec-cfg.yaml
diff --git a/board/ti/am62x/board-cfg.yaml b/board/ti/am62x/board-cfg.yaml new file mode 100644 index 0000000000..a26ef55bd4 --- /dev/null +++ b/board/ti/am62x/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM62 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/am62x/pm-cfg.yaml b/board/ti/am62x/pm-cfg.yaml new file mode 100644 index 0000000000..aa94097e97 --- /dev/null +++ b/board/ti/am62x/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM62 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am62x/rm-cfg.yaml b/board/ti/am62x/rm-cfg.yaml new file mode 100644 index 0000000000..ba82146551 --- /dev/null +++ b/board/ti/am62x/rm-cfg.yaml @@ -0,0 +1,1088 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM62 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 960 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 22 + type: 64 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 2 + type: 192 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 26 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 164 + type: 2434 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2435 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 2445 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2445 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2445 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2445 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 2445 + host_id: 128 + reserved: 0 + + - + start_resource: 54 + num_resource: 18 + type: 2446 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 2446 + host_id: 35 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 2446 + host_id: 36 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 2446 + host_id: 30 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 2446 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 2447 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 2447 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 2447 + host_id: 36 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 2447 + host_id: 30 + reserved: 0 + + - + start_resource: 52 + num_resource: 2 + type: 2447 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 2464 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2464 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2464 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2464 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 2464 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 2465 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2465 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2465 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2465 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 2465 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 2466 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 2466 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 2466 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 2466 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 2466 + host_id: 128 + reserved: 0 + + - + start_resource: 5 + num_resource: 35 + type: 2570 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 2570 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 2570 + host_id: 36 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 2570 + host_id: 30 + reserved: 0 + + - + start_resource: 13 + num_resource: 512 + type: 2573 + host_id: 12 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 2573 + host_id: 35 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 2573 + host_id: 36 + reserved: 0 + + - + start_resource: 781 + num_resource: 128 + type: 2573 + host_id: 30 + reserved: 0 + + - + start_resource: 909 + num_resource: 627 + type: 2573 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 2575 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 29 + type: 2576 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 99 + type: 2577 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 24 + type: 2578 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 51 + type: 2579 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 51 + type: 2580 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 51 + type: 2581 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 32 + type: 2582 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 32 + type: 2583 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 32 + type: 2584 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 22 + type: 2585 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 22 + type: 2586 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 22 + type: 2587 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 28 + type: 2588 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 28 + type: 2589 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 28 + type: 2590 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 3075 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3088 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3088 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3088 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3088 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3088 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 3089 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 3089 + host_id: 36 + reserved: 0 + + - + start_resource: 83 + num_resource: 8 + type: 3090 + host_id: 12 + reserved: 0 + + - + start_resource: 91 + num_resource: 8 + type: 3091 + host_id: 12 + reserved: 0 + + - + start_resource: 99 + num_resource: 10 + type: 3094 + host_id: 12 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 3094 + host_id: 35 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 3094 + host_id: 36 + reserved: 0 + + - + start_resource: 112 + num_resource: 3 + type: 3094 + host_id: 30 + reserved: 0 + + - + start_resource: 115 + num_resource: 3 + type: 3094 + host_id: 128 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 3095 + host_id: 12 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 3095 + host_id: 36 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 3096 + host_id: 12 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 3097 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 3098 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 3099 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3107 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3107 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3107 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3107 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3107 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 3108 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 3108 + host_id: 36 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 3109 + host_id: 12 + reserved: 0 + + - + start_resource: 28 + num_resource: 1 + type: 3110 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3113 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3113 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3113 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3113 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3113 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3114 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3114 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3114 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3114 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3114 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 3115 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 3115 + host_id: 36 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 3116 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 3116 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 3117 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 3118 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 3119 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 3120 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 3121 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 3122 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 1 + type: 3123 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 3124 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 3264 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 3274 + host_id: 12 + reserved: 0 diff --git a/board/ti/am62x/sec-cfg.yaml b/board/ti/am62x/sec-cfg.yaml new file mode 100644 index 0000000000..bb7302dc7e --- /dev/null +++ b/board/ti/am62x/sec-cfg.yaml @@ -0,0 +1,375 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for AM62 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0] diff --git a/board/ti/am65x/rm-cfg.yaml b/board/ti/am65x/rm-cfg.yaml index 501cc464c4..84ec04e1e1 100644 --- a/board/ti/am65x/rm-cfg.yaml +++ b/board/ti/am65x/rm-cfg.yaml @@ -80,40 +80,40 @@ rm-cfg: allowed_priority : 0 allowed_sched_priority : 0 - #10 - host_id: 3 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #11 - host_id: 3 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #12 - host_id: 5 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #13 - host_id: 12 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #14 - host_id: 13 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #15 host_id: 0 allowed_atype : 0 @@ -157,33 +157,33 @@ rm-cfg: allowed_priority : 0 allowed_sched_priority : 0 - #21 - host_id: 3 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #22 - host_id: 5 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #23 - host_id: 12 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #24 - host_id: 13 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #25 host_id: 0 allowed_atype : 0 @@ -220,26 +220,26 @@ rm-cfg: allowed_priority : 0 allowed_sched_priority : 0 - #30 - host_id: 3 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #31 - host_id: 3 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 - #32 - host_id: 5 - allowed_atype : 0x2A - allowed_qos : 0xAAAA - allowed_orderid : 0xAAAAAAAA - allowed_priority : 0xAAAA - allowed_sched_priority : 0xAA + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 resasg: subhdr: magic: 0x7B25
Support added for HS and GP boot binaries for AM62
tiboot3.bin, tispl.bin and u-boot.img: For HS devices tiboot3.bin_unsigned, tispl.bin_unsigned, u-boot.img_unsigned: For GP devices
It is to be noted that the bootflow followed by AM62 requires:
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-am625-r5-sk.dts | 1 + arch/arm/dts/k3-am625-sk-binman.dtsi | 472 +++++++++++++++++++++++++++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 2 + board/ti/am62x/Kconfig | 2 + 4 files changed, 477 insertions(+) create mode 100644 arch/arm/dts/k3-am625-sk-binman.dtsi
diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts index dad46704a2..26ccfa0a4b 100644 --- a/arch/arm/dts/k3-am625-r5-sk.dts +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -9,6 +9,7 @@ #include "k3-am62-ddr.dtsi"
#include "k3-am625-sk-u-boot.dtsi" +#include "k3-am625-sk-binman.dtsi"
/ { aliases { diff --git a/arch/arm/dts/k3-am625-sk-binman.dtsi b/arch/arm/dts/k3-am625-sk-binman.dtsi new file mode 100644 index 0000000000..13c90791b0 --- /dev/null +++ b/arch/arm/dts/k3-am625-sk-binman.dtsi @@ -0,0 +1,472 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +#ifdef CONFIG_TARGET_AM625_R5_EVM + +&binman { + board-cfg { + filename = "board-cfg.bin"; + ti-board-config { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + ti-board-config { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + ti-board-config { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + ti-board-config { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + combined-tifs-cfg { + filename = "combined-tifs-cfg.bin"; + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + }; + combined-dm-cfg { + filename = "combined-dm-cfg.bin"; + ti-board-config { + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + + }; + }; + tiboot3 { + filename = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-fs-firmware-am62x-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: blob-ext@1 { + filename = "combined-tifs-cfg.bin"; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-fs-firmware-am62x-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + + }; +}; + +&binman { + tiboot3_unsigned { + filename = "tiboot3.bin_unsigned"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x43c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x43c3a800>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-fs-firmware-am62x-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + + }; +}; + +#endif + +#ifdef CONFIG_TARGET_AM625_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM625_SK_DTB "spl/dts/k3-am625-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM625_SK_DTB "arch/arm/dts/k3-am625-sk.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am625_sk_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am625_sk_dtb: blob-ext { + filename = SPL_AM625_SK_DTB; + }; + + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM625 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am625_sk_dtb>; + keyfile = "custMpk.pem"; + }; + am625_sk_dtb: blob-ext { + filename = AM625_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-1 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM625_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-am625-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM625 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM625_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-am625-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 249155733a..a60c37f1db 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -4,6 +4,8 @@ * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-am625-sk-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/board/ti/am62x/Kconfig b/board/ti/am62x/Kconfig index 5e8dfa3cc4..cd17e939e5 100644 --- a/board/ti/am62x/Kconfig +++ b/board/ti/am62x/Kconfig @@ -10,6 +10,7 @@ choice config TARGET_AM625_A53_EVM bool "TI K3 based AM625 EVM running on A53" select ARM64 + select BINMAN
config TARGET_AM625_R5_EVM bool "TI K3 based AM625 EVM running on R5" @@ -19,6 +20,7 @@ config TARGET_AM625_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF
endchoice
Added YAML config for AM62ax
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am62ax/board-cfg.yaml | 36 + board/ti/am62ax/pm-cfg.yaml | 12 + board/ti/am62ax/rm-cfg.yaml | 1151 ++++++++++++++++++++++++++++++++ board/ti/am62ax/sec-cfg.yaml | 375 +++++++++++ 4 files changed, 1574 insertions(+) create mode 100644 board/ti/am62ax/board-cfg.yaml create mode 100644 board/ti/am62ax/pm-cfg.yaml create mode 100644 board/ti/am62ax/rm-cfg.yaml create mode 100644 board/ti/am62ax/sec-cfg.yaml
diff --git a/board/ti/am62ax/board-cfg.yaml b/board/ti/am62ax/board-cfg.yaml new file mode 100644 index 0000000000..6e45b494e0 --- /dev/null +++ b/board/ti/am62ax/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM62ax +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x10 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/am62ax/pm-cfg.yaml b/board/ti/am62ax/pm-cfg.yaml new file mode 100644 index 0000000000..a491f11260 --- /dev/null +++ b/board/ti/am62ax/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM62ax +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am62ax/rm-cfg.yaml b/board/ti/am62ax/rm-cfg.yaml new file mode 100644 index 0000000000..f7315dd2b0 --- /dev/null +++ b/board/ti/am62ax/rm-cfg.yaml @@ -0,0 +1,1151 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM62ax +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 1032 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 22 + type: 64 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 2 + type: 192 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 26 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 164 + type: 2434 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2435 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 2445 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2445 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2445 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2445 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 2445 + host_id: 128 + reserved: 0 + + - + start_resource: 54 + num_resource: 18 + type: 2446 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 2446 + host_id: 35 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 2446 + host_id: 36 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 2446 + host_id: 30 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 2446 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 2447 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 2447 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 2447 + host_id: 36 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 2447 + host_id: 30 + reserved: 0 + + - + start_resource: 52 + num_resource: 2 + type: 2447 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 2464 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2464 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2464 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2464 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 2464 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 2465 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2465 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 2465 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2465 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 2465 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 2466 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 2466 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 2466 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 2466 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 2466 + host_id: 128 + reserved: 0 + + - + start_resource: 6 + num_resource: 34 + type: 2570 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 2570 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 2570 + host_id: 36 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 2570 + host_id: 30 + reserved: 0 + + - + start_resource: 14 + num_resource: 512 + type: 2573 + host_id: 12 + reserved: 0 + + - + start_resource: 526 + num_resource: 256 + type: 2573 + host_id: 35 + reserved: 0 + + - + start_resource: 526 + num_resource: 256 + type: 2573 + host_id: 36 + reserved: 0 + + - + start_resource: 782 + num_resource: 128 + type: 2573 + host_id: 30 + reserved: 0 + + - + start_resource: 910 + num_resource: 626 + type: 2573 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 2575 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 29 + type: 2576 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 99 + type: 2577 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 24 + type: 2578 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 51 + type: 2579 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 51 + type: 2580 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 51 + type: 2581 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 32 + type: 2582 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 32 + type: 2583 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 32 + type: 2584 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 22 + type: 2585 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 22 + type: 2586 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 22 + type: 2587 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 28 + type: 2588 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 28 + type: 2589 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 28 + type: 2590 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 3075 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3088 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3088 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3088 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3088 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3088 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 3089 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 3089 + host_id: 30 + reserved: 0 + + - + start_resource: 83 + num_resource: 8 + type: 3090 + host_id: 12 + reserved: 0 + + - + start_resource: 91 + num_resource: 8 + type: 3091 + host_id: 12 + reserved: 0 + + - + start_resource: 99 + num_resource: 10 + type: 3094 + host_id: 12 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 3094 + host_id: 35 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 3094 + host_id: 36 + reserved: 0 + + - + start_resource: 112 + num_resource: 3 + type: 3094 + host_id: 30 + reserved: 0 + + - + start_resource: 115 + num_resource: 3 + type: 3094 + host_id: 128 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 3095 + host_id: 12 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 3095 + host_id: 30 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 3096 + host_id: 12 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 3097 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 3098 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 3099 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3107 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3107 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3107 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3107 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3107 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 3108 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 3108 + host_id: 30 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 3109 + host_id: 12 + reserved: 0 + + - + start_resource: 28 + num_resource: 1 + type: 3110 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3113 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3113 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3113 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3113 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3113 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 3114 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3114 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 3114 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 3114 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 3114 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 3115 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 3115 + host_id: 30 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 3116 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 3116 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 3117 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 3118 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 3119 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 3120 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 3121 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 3122 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 1 + type: 3123 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 3124 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 3264 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 3274 + host_id: 12 + reserved: 0 + + - + start_resource: 51200 + num_resource: 12 + type: 26178 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 26179 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 26190 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 26209 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 32778 + host_id: 12 + reserved: 0 + + - + start_resource: 12288 + num_resource: 128 + type: 32781 + host_id: 12 + reserved: 0 + + - + start_resource: 3072 + num_resource: 6 + type: 32796 + host_id: 128 + reserved: 0 + + - + start_resource: 3584 + num_resource: 6 + type: 32797 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 6 + type: 32798 + host_id: 128 + reserved: 0 diff --git a/board/ti/am62ax/sec-cfg.yaml b/board/ti/am62ax/sec-cfg.yaml new file mode 100644 index 0000000000..95602f2671 --- /dev/null +++ b/board/ti/am62ax/sec-cfg.yaml @@ -0,0 +1,375 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security configuration for AM62ax +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support added for HS and GP boot binaries for AM62ax.
tiboot3.bin, tispl.bin and u-boot.img: For HS devices tiboot3.bin_unsigned, tispl.bin_unsigned and u-boot.img_unsigned: For GP devices
It is to be noted that the bootflow followed by AM62ax requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * DM * ATF * OPTEE * A72 SPL * A72 SPL dtbs
u-boot.img: * A72 U-Boot * A72 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-am62a-sk-binman.dtsi | 472 +++++++++++++++++++++++++++ arch/arm/dts/k3-am62a7-r5-sk.dts | 1 + arch/arm/dts/k3-am62a7-sk.dts | 1 + board/ti/am62ax/Kconfig | 2 + 4 files changed, 476 insertions(+) create mode 100644 arch/arm/dts/k3-am62a-sk-binman.dtsi
diff --git a/arch/arm/dts/k3-am62a-sk-binman.dtsi b/arch/arm/dts/k3-am62a-sk-binman.dtsi new file mode 100644 index 0000000000..d79e4e47af --- /dev/null +++ b/arch/arm/dts/k3-am62a-sk-binman.dtsi @@ -0,0 +1,472 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +#ifdef CONFIG_TARGET_AM62A7_R5_EVM + +&binman { + board-cfg { + filename = "board-cfg.bin"; + ti-board-config { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + ti-board-config { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + ti-board-config { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + ti-board-config { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + combined-tifs-cfg { + filename = "combined-tifs-cfg.bin"; + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + }; + }; + combined-dm-cfg { + filename = "combined-dm-cfg.bin"; + ti-board-config { + pm-cfg { + config = "pm-cfg.yaml"; + schema = "schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "schema.yaml"; + }; + + }; + }; + + tiboot3 { + filename = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-fs-firmware-am62ax-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: blob-ext@1 { + filename = "combined-tifs-cfg.bin"; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-fs-firmware-am62ax-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + + }; +}; + +&binman { + tiboot3_unsigned { + filename = "tiboot3.bin_unsigned"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x43c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x43c3a800>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-fs-firmware-am62ax-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +#endif + +#ifdef CONFIG_TARGET_AM62A7_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM62A7_SK_DTB "spl/dts/k3-am62a7-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM62A7_SK_DTB "arch/arm/dts/k3-am62a7-sk.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am62a7_sk_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am62a7_sk_dtb: blob-ext { + filename = SPL_AM62A7_SK_DTB; + }; + + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am62a7-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM62Ax board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am62a7_sk_dtb>; + keyfile = "custMpk.pem"; + }; + am62a7_sk_dtb: blob-ext { + filename = AM62A7_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am62a7-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-1 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM62A7_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-am62a7-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM62Ax board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM62A7_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-am62a7-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-am62a7-r5-sk.dts b/arch/arm/dts/k3-am62a7-r5-sk.dts index c953a82c7a..0b799a2537 100644 --- a/arch/arm/dts/k3-am62a7-r5-sk.dts +++ b/arch/arm/dts/k3-am62a7-r5-sk.dts @@ -7,6 +7,7 @@ #include "k3-am62a7-sk.dts" #include "k3-am62a-ddr-1866mhz-32bit.dtsi" #include "k3-am62a-ddr.dtsi" +#include "k3-am62a-sk-binman.dtsi"
#include "k3-am62a7-sk-u-boot.dtsi"
diff --git a/arch/arm/dts/k3-am62a7-sk.dts b/arch/arm/dts/k3-am62a7-sk.dts index b08a083d72..270e669f65 100644 --- a/arch/arm/dts/k3-am62a7-sk.dts +++ b/arch/arm/dts/k3-am62a7-sk.dts @@ -10,6 +10,7 @@ #include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/gpio.h> #include "k3-am62a7.dtsi" +#include "k3-am62a-sk-binman.dtsi"
/ { compatible = "ti,am62a7-sk", "ti,am62a7"; diff --git a/board/ti/am62ax/Kconfig b/board/ti/am62ax/Kconfig index 9b868e4553..61f289facc 100644 --- a/board/ti/am62ax/Kconfig +++ b/board/ti/am62ax/Kconfig @@ -10,6 +10,7 @@ choice config TARGET_AM62A7_A53_EVM bool "TI K3 based AM62A7 EVM running on A53" select ARM64 + select BINMAN imply BOARD imply SPL_BOARD imply TI_I2C_BOARD_DETECT @@ -22,6 +23,7 @@ config TARGET_AM62A7_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Since binman is used to package bootloader images for all K3 devices, we do not have to rely on the earlier methods to package them.
config.mk has been edited to only have binman required make commands.
Scripts that were used to generate x509 certificate for tiboot3.bin and generate tispl.bin have also been removed.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/config.mk | 92 ------------- tools/k3_fit_atf.sh | 123 ----------------- tools/k3_gen_x509_cert.sh | 262 ------------------------------------- 3 files changed, 477 deletions(-) delete mode 100755 tools/k3_fit_atf.sh delete mode 100755 tools/k3_gen_x509_cert.sh
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index b342a56538..39767196a7 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -11,34 +11,6 @@ ifeq ($(shell which openssl),) $(error "No openssl in $(PATH), consider installing openssl") endif
-IMAGE_SIZE= $(shell cat $(obj)/u-boot-spl.bin | wc -c) -MAX_SIZE= $(shell printf "%d" $(CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE)) - -ifeq ($(CONFIG_SYS_K3_KEY), "") -KEY="" -# On HS use real key or warn if not available -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -ifneq ($(wildcard $(TI_SECURE_DEV_PKG)/keys/custMpk.pem),) -KEY=$(TI_SECURE_DEV_PKG)/keys/custMpk.pem -else -$(warning "WARNING: signing key not found. Random key will NOT work on HS hardware!") -endif -endif -else -KEY=$(patsubst "%",$(srctree)/%,$(CONFIG_SYS_K3_KEY)) -endif - -# X509 SWRV default -SWRV = $(CONFIG_K3_X509_SWRV) -# On HS use SECDEV provided software revision or warn if not available -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -ifneq ($(wildcard $(TI_SECURE_DEV_PKG)/keys/swrv.txt),) -SWRV= $(shell cat $(TI_SECURE_DEV_PKG)/keys/swrv.txt) -else -$(warning "WARNING: Software revision file not found. Default may not work on HS hardware.") -endif -endif - O ?= .
# Board config binary artifacts necessary for packaging of tiboot3.bin @@ -88,68 +60,4 @@ INPUTS-y += schema.yaml INPUTS-y += custMpk.pem INPUTS-y += ti-degenerate-key.pem endif - -# tiboot3.bin is mandated by ROM and ROM only supports R5 boot. -# So restrict tiboot3.bin creation for CPU_V7R. -ifndef CONFIG_BINMAN -ifdef CONFIG_CPU_V7R -image_check: $(obj)/u-boot-spl.bin FORCE - @if [ $(IMAGE_SIZE) -gt $(MAX_SIZE) ]; then \ - echo "===============================================" >&2; \ - echo "ERROR: Final Image too big. " >&2; \ - echo "$< size = $(IMAGE_SIZE), max size = $(MAX_SIZE)" >&2; \ - echo "===============================================" >&2; \ - exit 1; \ - fi - -tiboot3.bin: image_check FORCE - $(srctree)/tools/k3_gen_x509_cert.sh -c 16 -b $(obj)/u-boot-spl.bin \ - -o $@ -l $(CONFIG_SPL_TEXT_BASE) -r $(SWRV) -k $(KEY) - -INPUTS-y += tiboot3.bin -endif -endif - -ifdef CONFIG_ARM64 - -ifeq ($(CONFIG_SOC_K3_J721E),) -export DM := /dev/null endif - -ifndef CONFIG_BINMAN -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -SPL_ITS := u-boot-spl-k3_HS.its -$(SPL_ITS): export IS_HS=1 -INPUTS-y += tispl.bin_HS -else -SPL_ITS := u-boot-spl-k3.its -INPUTS-y += tispl.bin -endif -endif - -ifeq ($(CONFIG_SPL_OF_LIST),) -LIST_OF_DTB := $(CONFIG_DEFAULT_DEVICE_TREE) -else -LIST_OF_DTB := $(CONFIG_SPL_OF_LIST) -endif - -quiet_cmd_k3_mkits = MKITS $@ -cmd_k3_mkits = \ - $(srctree)/tools/k3_fit_atf.sh \ - $(CONFIG_K3_ATF_LOAD_ADDR) \ - $(patsubst %,$(obj)/dts/%.dtb,$(subst ",,$(LIST_OF_DTB))) > $@ - -$(SPL_ITS): FORCE - $(call cmd,k3_mkits) -endif - -else - -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -INPUTS-y += u-boot.img_HS -else -INPUTS-y += u-boot.img -endif -endif - -include $(srctree)/arch/arm/mach-k3/config_secure.mk diff --git a/tools/k3_fit_atf.sh b/tools/k3_fit_atf.sh deleted file mode 100755 index 7bc07ad074..0000000000 --- a/tools/k3_fit_atf.sh +++ /dev/null @@ -1,123 +0,0 @@ -#!/bin/sh -# SPDX-License-Identifier: GPL-2.0+ -# -# script to generate FIT image source for K3 Family boards with -# ATF, OPTEE, SPL and multiple device trees (given on the command line). -# Inspired from board/sunxi/mksunxi_fit_atf.sh -# -# usage: $0 <atf_load_addr> <dt_name> [<dt_name> [<dt_name] ...] - -[ -z "$ATF" ] && ATF="bl31.bin" - -if [ ! -f $ATF ]; then - echo "WARNING ATF file $ATF NOT found, resulting binary is non-functional" >&2 - ATF=/dev/null -fi - -[ -z "$TEE" ] && TEE="bl32.bin" - -if [ ! -f $TEE ]; then - echo "WARNING OPTEE file $TEE NOT found, resulting might be non-functional" >&2 - TEE=/dev/null -fi - -[ -z "$DM" ] && DM="dm.bin" - -if [ ! -e $DM ]; then - echo "WARNING DM file $DM NOT found, resulting might be non-functional" >&2 - DM=/dev/null -fi - -if [ ! -z "$IS_HS" ]; then - HS_APPEND=_HS -fi - -cat << __HEADER_EOF -/dts-v1/; - -/ { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - - images { - atf { - description = "ARM Trusted Firmware"; - data = /incbin/("$ATF"); - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <$1>; - entry = <$1>; - }; - tee { - description = "OPTEE"; - data = /incbin/("$TEE"); - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - }; - dm { - description = "DM binary"; - data = /incbin/("$DM"); - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; - }; - spl { - description = "SPL (64-bit)"; - data = /incbin/("spl/u-boot-spl-nodtb.bin$HS_APPEND"); - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <0x80080000>; - entry = <0x80080000>; - }; -__HEADER_EOF - -# shift through ATF load address in the command line arguments -shift - -for dtname in $* -do - cat << __FDT_IMAGE_EOF - $(basename $dtname) { - description = "$(basename $dtname .dtb)"; - data = /incbin/("$dtname$HS_APPEND"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; -__FDT_IMAGE_EOF -done - -cat << __CONF_HEADER_EOF - }; - configurations { - default = "$(basename $1)"; - -__CONF_HEADER_EOF - -for dtname in $* -do - cat << __CONF_SECTION_EOF - $(basename $dtname) { - description = "$(basename $dtname .dtb)"; - firmware = "atf"; - loadables = "tee", "dm", "spl"; - fdt = "$(basename $dtname)"; - }; -__CONF_SECTION_EOF -done - -cat << __ITS_EOF - }; -}; -__ITS_EOF diff --git a/tools/k3_gen_x509_cert.sh b/tools/k3_gen_x509_cert.sh deleted file mode 100755 index d9cde07417..0000000000 --- a/tools/k3_gen_x509_cert.sh +++ /dev/null @@ -1,262 +0,0 @@ -#!/bin/bash -# SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -# -# Script to add K3 specific x509 cetificate to a binary. -# - -# Variables -OUTPUT=tiboot3.bin -TEMP_X509=x509-temp.cert -CERT=certificate.bin -RAND_KEY=eckey.pem -LOADADDR=0x41c00000 -BOOTCORE_OPTS=0 -BOOTCORE=16 -DEBUG_TYPE=0 -SWRV=1 - -gen_degen_template() { -cat << 'EOF' > degen-template.txt - -asn1=SEQUENCE:rsa_key - -[rsa_key] -version=INTEGER:0 -modulus=INTEGER:0xDEGEN_MODULUS -pubExp=INTEGER:1 -privExp=INTEGER:1 -p=INTEGER:0xDEGEN_P -q=INTEGER:0xDEGEN_Q -e1=INTEGER:1 -e2=INTEGER:1 -coeff=INTEGER:0xDEGEN_COEFF -EOF -} - -# Generate x509 Template -gen_template() { -cat << 'EOF' > x509-template.txt - [ req ] - distinguished_name = req_distinguished_name - x509_extensions = v3_ca - prompt = no - dirstring_type = nobmp - - [ req_distinguished_name ] - C = US - ST = TX - L = Dallas - O = Texas Instruments Incorporated - OU = Processors - CN = TI support - emailAddress = support@ti.com - - [ v3_ca ] - basicConstraints = CA:true - 1.3.6.1.4.1.294.1.1 = ASN1:SEQUENCE:boot_seq - 1.3.6.1.4.1.294.1.2 = ASN1:SEQUENCE:image_integrity - 1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv -# 1.3.6.1.4.1.294.1.4 = ASN1:SEQUENCE:encryption - 1.3.6.1.4.1.294.1.8 = ASN1:SEQUENCE:debug - - [ boot_seq ] - certType = INTEGER:TEST_CERT_TYPE - bootCore = INTEGER:TEST_BOOT_CORE - bootCoreOpts = INTEGER:TEST_BOOT_CORE_OPTS - destAddr = FORMAT:HEX,OCT:TEST_BOOT_ADDR - imageSize = INTEGER:TEST_IMAGE_LENGTH - - [ image_integrity ] - shaType = OID:2.16.840.1.101.3.4.2.3 - shaValue = FORMAT:HEX,OCT:TEST_IMAGE_SHA_VAL - - [ swrv ] - swrv = INTEGER:TEST_SWRV - -# [ encryption ] -# initalVector = FORMAT:HEX,OCT:TEST_IMAGE_ENC_IV -# randomString = FORMAT:HEX,OCT:TEST_IMAGE_ENC_RS -# iterationCnt = INTEGER:TEST_IMAGE_KEY_DERIVE_INDEX -# salt = FORMAT:HEX,OCT:TEST_IMAGE_KEY_DERIVE_SALT - - [ debug ] - debugUID = FORMAT:HEX,OCT:0000000000000000000000000000000000000000000000000000000000000000 - debugType = INTEGER:TEST_DEBUG_TYPE - coreDbgEn = INTEGER:0 - coreDbgSecEn = INTEGER:0 -EOF -} - -parse_key() { - sed '/ /s/://g' key.txt | \ - awk '!/ / {printf("\n%s\n", $0)}; / / {printf("%s", $0)}' | \ - sed 's/ //g' | \ - awk "/$1:/{getline; print}" -} - -gen_degen_key() { -# Generate a 4096 bit RSA Key - openssl genrsa -out key.pem 1024 >>/dev/null 2>&1 - openssl rsa -in key.pem -text -out key.txt >>/dev/null 2>&1 - DEGEN_MODULUS=$( parse_key 'modulus' ) - DEGEN_P=$( parse_key 'prime1' ) - DEGEN_Q=$( parse_key 'prime2' ) - DEGEN_COEFF=$( parse_key 'coefficient' ) - gen_degen_template - - sed -e "s/DEGEN_MODULUS/$DEGEN_MODULUS/"\ - -e "s/DEGEN_P/$DEGEN_P/" \ - -e "s/DEGEN_Q/$DEGEN_Q/" \ - -e "s/DEGEN_COEFF/$DEGEN_COEFF/" \ - degen-template.txt > degenerateKey.txt - - openssl asn1parse -genconf degenerateKey.txt -out degenerateKey.der >>/dev/null 2>&1 - openssl rsa -in degenerateKey.der -inform DER -outform PEM -out $RAND_KEY >>/dev/null 2>&1 - KEY=$RAND_KEY - rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der -} - -declare -A options_help -usage() { - if [ -n "$*" ]; then - echo "ERROR: $*" - fi - echo -n "Usage: $0 " - for option in "${!options_help[@]}" - do - arg=`echo ${options_help[$option]}|cut -d ':' -f1` - if [ -n "$arg" ]; then - arg=" $arg" - fi - echo -n "[-$option$arg] " - done - echo - echo -e "\nWhere:" - for option in "${!options_help[@]}" - do - arg=`echo ${options_help[$option]}|cut -d ':' -f1` - txt=`echo ${options_help[$option]}|cut -d ':' -f2` - tb="\t\t\t" - if [ -n "$arg" ]; then - arg=" $arg" - tb="\t" - fi - echo -e " -$option$arg:$tb$txt" - done - echo - echo "Examples of usage:-" - echo "# Example of signing the SYSFW binary with rsa degenerate key" - echo " $0 -c 0 -b ti-sci-firmware-am6x.bin -o sysfw.bin -l 0x40000" - echo "# Example of signing the SPL binary with rsa degenerate key" - echo " $0 -c 16 -b spl/u-boot-spl.bin -o tiboot3.bin -l 0x41c00000" -} - -options_help[b]="bin_file:Bin file that needs to be signed" -options_help[k]="key_file:file with key inside it. If not provided script generates a rsa degenerate key." -options_help[o]="output_file:Name of the final output file. default to $OUTPUT" -options_help[c]="core_id:target core id on which the image would be running. Default to $BOOTCORE" -options_help[l]="loadaddr: Target load address of the binary in hex. Default to $LOADADDR" -options_help[d]="debug_type: Debug type, set to 4 to enable early JTAG. Default to $DEBUG_TYPE" -options_help[r]="SWRV: Software Rev for X509 certificate" - -while getopts "b:k:o:c:l:d:h:r:" opt -do - case $opt in - b) - BIN=$OPTARG - ;; - k) - KEY=$OPTARG - ;; - o) - OUTPUT=$OPTARG - ;; - l) - LOADADDR=$OPTARG - ;; - c) - BOOTCORE=$OPTARG - ;; - d) - DEBUG_TYPE=$OPTARG - ;; - r) - SWRV=$OPTARG - ;; - h) - usage - exit 0 - ;; - ?) - usage "Invalid Option '-$OPTARG'" - exit 1 - ;; - :) - usage "Option '-$OPTARG' Needs an argument." - exit 1 - ;; - esac -done - -if [ "$#" -eq 0 ]; then - usage "Arguments missing" - exit 1 -fi - -if [ -z "$BIN" ]; then - usage "Bin file missing in arguments" - exit 1 -fi - -# Generate rsa degenerate key if user doesn't provide a key -if [ -z "$KEY" ]; then - gen_degen_key -fi - -if [ $BOOTCORE == 0 ]; then # BOOTCORE M3, loaded by ROM - CERTTYPE=2 -elif [ $BOOTCORE == 16 ]; then # BOOTCORE R5, loaded by ROM - CERTTYPE=1 -else # Non BOOTCORE, loaded by SYSFW - BOOTCORE_OPTS_VER=$(printf "%01x" 1) - # Add input args option for SET and CLR flags. - BOOTCORE_OPTS_SETFLAG=$(printf "%08x" 0) - BOOTCORE_OPTS_CLRFLAG=$(printf "%08x" 0x100) # Clear FLAG_ARMV8_AARCH32 - BOOTCORE_OPTS="0x$BOOTCORE_OPTS_VER$BOOTCORE_OPTS_SETFLAG$BOOTCORE_OPTS_CLRFLAG" - # Set the cert type to zero. - # We are not using public/private key store now - CERTTYPE=$(printf "0x%08x" 0) -fi - -SHA_VAL=`openssl dgst -sha512 -hex $BIN | sed -e "s/^.*= //g"` -BIN_SIZE=`cat $BIN | wc -c` -ADDR=`printf "%08x" $LOADADDR` - -gen_cert() { - #echo "Certificate being generated :" - #echo " LOADADDR = 0x$ADDR" - #echo " IMAGE_SIZE = $BIN_SIZE" - #echo " CERT_TYPE = $CERTTYPE" - #echo " DEBUG_TYPE = $DEBUG_TYPE" - #echo " SWRV = $SWRV" - sed -e "s/TEST_IMAGE_LENGTH/$BIN_SIZE/" \ - -e "s/TEST_IMAGE_SHA_VAL/$SHA_VAL/" \ - -e "s/TEST_CERT_TYPE/$CERTTYPE/" \ - -e "s/TEST_BOOT_CORE_OPTS/$BOOTCORE_OPTS/" \ - -e "s/TEST_BOOT_CORE/$BOOTCORE/" \ - -e "s/TEST_BOOT_ADDR/$ADDR/" \ - -e "s/TEST_DEBUG_TYPE/$DEBUG_TYPE/" \ - -e "s/TEST_SWRV/$SWRV/" \ - x509-template.txt > $TEMP_X509 - openssl req -new -x509 -key $KEY -nodes -outform DER -out $CERT -config $TEMP_X509 -sha512 -} - -gen_template -gen_cert -cat $CERT $BIN > $OUTPUT - -# Remove all intermediate files -rm $TEMP_X509 $CERT x509-template.txt -if [ "$KEY" == "$RAND_KEY" ]; then - rm $RAND_KEY -fi
On 4/4/23 7:13 AM, Neha Malcom Francis wrote:
This series aims to eliminate the use of additional custom repositories such as k3-image-gen (K3 Image Generation) repo that was plumbed into the U-Boot build flow to generate boot images for TI K3 platform devices. And instead, we move towards using binman that aligns better with the community standard build flow.
This series uses binman for all K3 platforms supported on U-Boot currently; both HS (High Security) and GP (General Purpose) devices.
Background on using k3-image-gen:
- TI K3 devices require a SYSFW (System Firmware) image consisting
of a signed system firmware image and board configuration binaries, this is needed to bring up system firmware during U-Boot R5 SPL startup.
- Board configuration data contain board-specific information
such as resource management, power management and security.
Series intends to use binman to take over the packaging and signing for the R5 bootloader images tiboot3.bin (and sysfw.itb, for non-combined boot flow) instead of k3-image-gen.
Series also packages the A72/A53 bootloader images (tispl.bin and u-boot.img) using ATF, OPTEE and DM (Device Manager)
Changes in v2:
- removed all external scripts
- created ti-board-config etype to support generation of board config binaries
- created ti-secure and ti-secure-rom etypes to handle signing instead of using external TI_SECURE_DEV_PKG
- updated openssl btool to support x509 certificate generation
- dropped Makefile changes to obtain external binary components, moving to using BINMAN_INDIRS to achieve the same
Another thing that got changed is you seem to have dropped the documentation update patch from v1. The documentation change is the best part as it shows how much easier this series makes building U-Boot for K3! :)
I did notice a build error when trying this with am62x_evm_r5_defconfig. I don't think this series caused the issue, but it does expose the issue. Fix sent here[0]. So if anyone has issues building this series try that patch.
Other than the couple minor comments, everything looks good and I'm extremely impressed how well this all turned out. Removing the external tooling and scripts previously needed to build U-Boot for K3 is key to our upstream-first goals and long term support strategy.
Thank you!
For the whole series,
Acked-by: Andrew Davis afd@ti.com
[0] https://lists.denx.de/pipermail/u-boot/2023-April/514400.html
Hi Andrew,
Background on using k3-image-gen: * TI K3 devices require a SYSFW (System Firmware) image consisting of a signed system firmware image and board configuration binaries, this is needed to bring up system firmware during U-Boot R5 SPL startup. * Board configuration data contain board-specific information such as resource management, power management and security.
Changes in v2: - removed all external scripts - created ti-board-config etype to support generation of board config binaries - created ti-secure and ti-secure-rom etypes to handle signing instead of using external TI_SECURE_DEV_PKG - updated openssl btool to support x509 certificate generation - dropped Makefile changes to obtain external binary components, moving to using BINMAN_INDIRS to achieve the same
My bad, I didn't realize that had slipped out while sending v2, I will be sure to add it when sending the next version.
Thank you for noticing, I had included types.h while building and excluded it later, this patch should fix it. Thanks for the patch!
Thank you!
Andrew Davis
Neha Malcom Francis
