[U-Boot-Users] [ ramdisk error ]
I have a somewhat embarassing question
regarding u-boot and loading a ramdisk.
I am trying to boot my board based on SEQUOIA using a kernel and ramdisk.
I know the kernel and ramdisk image are good, since I used the same images for SEQUOIA.
Below is a snippet of my boot sequence,
including the error when trying to mount the ramdisk(initrd)
After my board loads ramdisk, I can't see anything through console.
What's wrong???
Thanks,
Sean
=> printenv
bootargs=root=/dev/ram rw ip=xxx.xxx.xxx.233:xxx.xxx.xxx.216:xxx.xxx.xxx.254:255.255.255.192:sequoia:e th0:off panic=1 console=ttyS0,9600
mem=262120k
=> tftp 0x400000 uImage
Waiting for PHY auto negotiation to complete... done
ENET Speed is 10 Mbps - HALF duplex connection (EMAC0)
Using ppc_4xx_eth0 device
TFTP from server 210.221.148.216; our IP address is 210.221.148.233
Filename 'uImage'.
Load address: 0x400000
Loading: #################################################################
done
Bytes transferred = 1326107 (143c1b hex)
=> tftp 0x1000000 uRamdisk
Filename 'uRamdisk'.
Load address: 0x1000000
done
Bytes transferred = 1728001 (1a5e01 hex)
=> bootm 0x400000 0x1000000
## Booting kernel from Legacy Image at 00400000 ...
Image Name: Linux-2.6.19
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 1326043 Bytes = 1.3 MB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
## Loading init Ramdisk from Legacy Image at 01000000 ...
Image Name: Simple Embedded Linux Framework
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 1727937 Bytes = 1.6 MB
Loading Ramdisk to 0fcb6000, end 0fe5bdc1 ... OK
/* Nothing is appeared */ ??????????????????????????????
The kernel is probably good for the Sequoia board, but if you have some other, custom hardware, you also need a custom port of Linux for it, i. e. another Linux image.
김영순
