[PATCH v3] driver: misc: k3_avs: Add support for thermal shutdown
To avoid thermal burn out, program thermal shutdown value in VTM (Voltage and Thermal Manager) IP.
Part of Linux kernel driver (drivers/thermal/k3_j72xx_bandgap.c) is ported from kernel 6.6-rc1, which sets thermal shutdown values.
Signed-off-by: Udit Kumar u-kumar1@ti.com Signed-off-by: Neha Francis n-francis@ti.com --- Change log:
Changes in v3: - Ported only needed functionality from kernel driver to program tshut - Removed support for temp from u-boot shell - Appended Sign-off list
v2:https://lore.kernel.org/all/20230908172914.436194-2-u-kumar1@ti.com/
Changes in v2: - Trying to merge AVS and kernel driver into 1 - Mark as RFC v1 : https://lore.kernel.org/all/20230901061500.2342452-1-u-kumar1@ti.com/
drivers/misc/k3_avs.c | 104 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 104 insertions(+)
diff --git a/drivers/misc/k3_avs.c b/drivers/misc/k3_avs.c index acfc731845..9a088244dd 100644 --- a/drivers/misc/k3_avs.c +++ b/drivers/misc/k3_avs.c @@ -15,6 +15,7 @@ #include <k3-avs.h> #include <dm/device_compat.h> #include <linux/bitops.h> +#include <linux/delay.h> #include <power/regulator.h>
#define AM6_VTM_DEVINFO(i) (priv->base + 0x100 + 0x20 * (i)) @@ -25,11 +26,28 @@ #define AM6_VTM_OPP_SHIFT(opp) (8 * (opp)) #define AM6_VTM_OPP_MASK 0xff
+#define K3_VTM_DEVINFO_PWR0_OFFSET 0x4 +#define K3_VTM_DEVINFO_PWR0_TEMPSENS_CT_MASK 0xf0 +#define K3_VTM_TMPSENS0_CTRL_OFFSET 0x300 +#define K3_VTM_TMPSENS_STAT_OFFSET 0x8 +#define K3_VTM_ANYMAXT_OUTRG_ALERT_EN 0x1 +#define K3_VTM_LOW_TEMP_OFFSET 0x10 +#define K3_VTM_MISC_CTRL2_OFFSET 0x10 +#define K3_VTM_MISC_CTRL1_OFFSET 0xc +#define K3_VTM_TMPSENS_CTRL1_SOC BIT(5) +#define K3_VTM_TMPSENS_CTRL_CLRZ BIT(6) +#define K3_VTM_TMPSENS_CTRL_MAXT_OUTRG_EN BIT(11) +#define K3_VTM_ADC_COUNT_FOR_123C 0x2f8 +#define K3_VTM_ADC_COUNT_FOR_105C 0x288 +#define K3_VTM_ADC_WA_VALUE 0x2c +#define K3_VTM_FUSE_MASK 0xc0000000 + #define VD_FLAG_INIT_DONE BIT(0)
struct k3_avs_privdata { void *base; struct vd_config *vd_config; + struct udevice *dev; };
struct opp { @@ -237,6 +255,88 @@ static int k3_avs_configure(struct udevice *dev, struct k3_avs_privdata *priv) return 0; }
+/* k3_avs_program_tshut : Program thermal shutdown value for SOC + * set the values corresponding to thresholds to ~123C and 105C + * This is optional feature, Few times OS driver takes care of + * tshut programing. + */ + +static void k3_avs_program_tshut(struct k3_avs_privdata *priv) +{ + int cnt, id, val; + int workaround_needed = 0; + u32 ctrl_offset; + void __iomem *cfg2_base; + void __iomem *fuse_base; + + cfg2_base = (void __iomem *)devfdt_get_addr_index(priv->dev, 1); + if (IS_ERR(cfg2_base)) { + dev_err(priv->dev, "cfg base is not defined\n"); + return; + } + + /* + * Some of TI's J721E SoCs require a software trimming procedure + * for the temperature monitors to function properly. To determine + * if this particular SoC is NOT affected, both bits in the + * WKUP_SPARE_FUSE0[31:30] will be set (0xC0000000) indicating + * when software trimming should NOT be applied. + * + * https://www.ti.com/lit/er/sprz455c/sprz455c.pdf + * This routine checks if workaround_needed to be applied or not + * based upon workaround_needed, adjust fixed value of tshut high and low + */ + + if (device_is_compatible(priv->dev, "ti,j721e-vtm")) { + fuse_base = (void __iomem *)devfdt_get_addr_index(priv->dev, 2); + if (IS_ERR(fuse_base)) { + dev_err(priv->dev, "fuse-base is not defined for J721E Soc\n"); + return; + } + + if (!((readl(fuse_base) & K3_VTM_FUSE_MASK) == K3_VTM_FUSE_MASK)) + workaround_needed = 1; + } + + dev_dbg(priv->dev, "Work around %sneeded\n", workaround_needed ? "" : "not "); + + /* Get the sensor count in the VTM */ + val = readl(priv->base + K3_VTM_DEVINFO_PWR0_OFFSET); + cnt = val & K3_VTM_DEVINFO_PWR0_TEMPSENS_CT_MASK; + cnt >>= __ffs(K3_VTM_DEVINFO_PWR0_TEMPSENS_CT_MASK); + + /* Program the thermal sensors */ + for (id = 0; id < cnt; id++) { + ctrl_offset = K3_VTM_TMPSENS0_CTRL_OFFSET + id * 0x20; + + val = readl(cfg2_base + ctrl_offset); + val |= (K3_VTM_TMPSENS_CTRL_MAXT_OUTRG_EN | + K3_VTM_TMPSENS_CTRL1_SOC | + K3_VTM_TMPSENS_CTRL_CLRZ | BIT(4)); + writel(val, cfg2_base + ctrl_offset); + } + + /* + * Program TSHUT thresholds + * Step 1: set the thresholds to ~123C and 105C WKUP_VTM_MISC_CTRL2 + * Step 2: WKUP_VTM_TMPSENS_CTRL_j set the MAXT_OUTRG_EN bit + * This is already taken care as per of init + * Step 3: WKUP_VTM_MISC_CTRL set the ANYMAXT_OUTRG_ALERT_EN bit + */ + + /* Low thresholds for tshut*/ + val = (K3_VTM_ADC_COUNT_FOR_105C - workaround_needed * K3_VTM_ADC_WA_VALUE) + << K3_VTM_LOW_TEMP_OFFSET; + /* high thresholds */ + val |= K3_VTM_ADC_COUNT_FOR_123C - workaround_needed * K3_VTM_ADC_WA_VALUE; + + writel(val, cfg2_base + K3_VTM_MISC_CTRL2_OFFSET); + /* ramp-up delay from Linux code */ + mdelay(100); + val = readl(cfg2_base + K3_VTM_MISC_CTRL1_OFFSET) | K3_VTM_ANYMAXT_OUTRG_ALERT_EN; + writel(val, cfg2_base + K3_VTM_MISC_CTRL1_OFFSET); +} + /** * k3_avs_probe: parses VD info from VTM, and re-configures the OPP data * @@ -255,6 +355,7 @@ static int k3_avs_probe(struct udevice *dev) int ret;
priv = dev_get_priv(dev); + priv->dev = dev;
k3_avs_priv = priv;
@@ -294,6 +395,9 @@ static int k3_avs_probe(struct udevice *dev) k3_avs_program_voltage(priv, vd, vd->opp); }
+ if (!device_is_compatible(priv->dev, "ti,am654-avs")) + k3_avs_program_tshut(priv); + return 0; }
Udit Kumar
