[PATCH 1/2] net: phy: mscc: make clock-output configurable on vsc85xx
From: Heiko Stuebner heiko.stuebner@theobroma-systems.com
The vsc8530/8531/8540/8541 phys have a configurable clock output that can emit 25, 50 and 125 MHz rates, which in turn may be needed for stable network connections.
This follows a similar change introduced into the Linux kernel at https://lore.kernel.org/netdev/20200609133140.1421109-2-heiko@sntech.de
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- drivers/net/phy/mscc.c | 59 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 59 insertions(+)
diff --git a/drivers/net/phy/mscc.c b/drivers/net/phy/mscc.c index 709979f48c..64e9093827 100644 --- a/drivers/net/phy/mscc.c +++ b/drivers/net/phy/mscc.c @@ -157,6 +157,14 @@ #define INT_MEM_DATA_M GENMASK(7, 0) #define INT_MEM_DATA(x) (INT_MEM_DATA_M & (x))
+/* Extended page GPIO register 13G */ +#define MSCC_CLKOUT_CNTL 13 +#define CLKOUT_ENABLE BIT(15) +#define CLKOUT_FREQ_MASK GENMASK(14, 13) +#define CLKOUT_FREQ_25M (0x0 << 13) +#define CLKOUT_FREQ_50M (0x1 << 13) +#define CLKOUT_FREQ_125M (0x2 << 13) + /* Extended page GPIO register 18G */ #define MSCC_PHY_PROC_CMD 18 #define PROC_CMD_NCOMPLETED BIT(15) @@ -1210,6 +1218,47 @@ static int vsc8531_vsc8541_mac_config(struct phy_device *phydev) return 0; }
+static int vsc8531_vsc8541_clkout_config(struct phy_device *phydev) +{ + struct ofnode_phandle_args phandle_args; + u32 clkout_rate = 0; + u16 reg_val; + int retval; + + retval = dev_read_phandle_with_args(phydev->dev, "phy-handle", NULL, + 0, 0, &phandle_args); + if (!retval) + clkout_rate = ofnode_read_u32_default(phandle_args.node, + "vsc8531,clk-out-frequency", 0); + + switch (clkout_rate) { + case 0: + reg_val = 0; + break; + case 25000000: + reg_val = CLKOUT_FREQ_25M | CLKOUT_ENABLE; + break; + case 50000000: + reg_val = CLKOUT_FREQ_50M | CLKOUT_ENABLE; + break; + case 125000000: + reg_val = CLKOUT_FREQ_125M | CLKOUT_ENABLE; + break; + default: + printf("PHY 8530/31 invalid clkout rate %u\n", + clkout_rate); + return -EINVAL; + } + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_CLKOUT_CNTL, reg_val); + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return 0; +} + static int vsc8531_config(struct phy_device *phydev) { int retval = -EINVAL; @@ -1267,6 +1316,11 @@ static int vsc8531_config(struct phy_device *phydev) phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, MSCC_PHY_PAGE_STD);
+ /* Configure the clk output */ + retval = vsc8531_vsc8541_clkout_config(phydev); + if (retval != 0) + return retval; + return genphy_config_aneg(phydev); }
@@ -1327,6 +1381,11 @@ static int vsc8541_config(struct phy_device *phydev) phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, MSCC_PHY_PAGE_STD);
The Linux kernel does set the clock delays to - 0.2 ns (their default, and lowest, hardware value) if delays should not be enabled - 2.0 ns (which causes the data to be sampled at exactly half way between clock transitions at 1000 Mbps) if delays should be enabled depending on the interface mode
See https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
So instead of using arbitrary delay values like now, mimic this behaviour.
The behaviour is the same for all of vsc8530/8531/8540/8541 so move that to a shared function while at it.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- drivers/net/phy/mscc.c | 70 +++++++++++++++++++++++++++--------------- 1 file changed, 46 insertions(+), 24 deletions(-)
diff --git a/drivers/net/phy/mscc.c b/drivers/net/phy/mscc.c index 64e9093827..d1a643cf5a 100644 --- a/drivers/net/phy/mscc.c +++ b/drivers/net/phy/mscc.c @@ -1176,6 +1176,9 @@ static int vsc8531_vsc8541_mac_config(struct phy_device *phydev) rx_clk_out = RX_CLK_OUT_NORMAL; break;
+ case PHY_INTERFACE_MODE_RGMII_TXID: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_RGMII: /* Set Reg23.12:11=2 */ mac_if = MAC_IF_SELECTION_RGMII; @@ -1259,13 +1262,43 @@ static int vsc8531_vsc8541_clkout_config(struct phy_device *phydev) return 0; }
+static int vsc8531_vsc8541_clk_skew_config(struct phy_device *phydev) +{ + enum vsc_phy_rgmii_skew rx_clk_skew = VSC_PHY_RGMII_DELAY_200_PS; + enum vsc_phy_rgmii_skew tx_clk_skew = VSC_PHY_RGMII_DELAY_200_PS; + u16 reg_val; + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + rx_clk_skew = VSC_PHY_RGMII_DELAY_2000_PS; + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + tx_clk_skew = VSC_PHY_RGMII_DELAY_2000_PS; + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT2); + reg_val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_RGMII_CNTL_REG); + + /* Reg20E2 - Update RGMII RX_Clk Skews. */ + reg_val = bitfield_replace(reg_val, RGMII_RX_CLK_DELAY_POS, + RGMII_RX_CLK_DELAY_WIDTH, rx_clk_skew); + /* Reg20E2 - Update RGMII TX_Clk Skews. */ + reg_val = bitfield_replace(reg_val, RGMII_TX_CLK_DELAY_POS, + RGMII_TX_CLK_DELAY_WIDTH, tx_clk_skew); + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_PHY_RGMII_CNTL_REG, reg_val); + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return 0; +} + static int vsc8531_config(struct phy_device *phydev) { int retval = -EINVAL; u16 reg_val; u16 rmii_clk_out; - enum vsc_phy_rgmii_skew rx_clk_skew = VSC_PHY_RGMII_DELAY_1700_PS; - enum vsc_phy_rgmii_skew tx_clk_skew = VSC_PHY_RGMII_DELAY_800_PS; enum vsc_phy_clk_slew edge_rate = VSC_PHY_CLK_SLEW_RATE_4;
/* For VSC8530/31 and VSC8540/41 the init scripts are the same */ @@ -1275,6 +1308,9 @@ static int vsc8531_config(struct phy_device *phydev) switch (phydev->interface) { case PHY_INTERFACE_MODE_RMII: case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_TXID: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_ID: retval = vsc8531_vsc8541_mac_config(phydev); if (retval != 0) return retval; @@ -1291,19 +1327,12 @@ static int vsc8531_config(struct phy_device *phydev) /* Default RMII Clk Output to 0=OFF/1=ON */ rmii_clk_out = 0;
+ retval = vsc8531_vsc8541_clk_skew_config(phydev); + if (retval != 0) + return retval; + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, MSCC_PHY_PAGE_EXT2); - reg_val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_RGMII_CNTL_REG); - - /* Reg20E2 - Update RGMII RX_Clk Skews. */ - reg_val = bitfield_replace(reg_val, RGMII_RX_CLK_DELAY_POS, - RGMII_RX_CLK_DELAY_WIDTH, rx_clk_skew); - /* Reg20E2 - Update RGMII TX_Clk Skews. */ - reg_val = bitfield_replace(reg_val, RGMII_TX_CLK_DELAY_POS, - RGMII_TX_CLK_DELAY_WIDTH, tx_clk_skew); - - phy_write(phydev, MDIO_DEVAD_NONE, MSCC_PHY_RGMII_CNTL_REG, reg_val); - reg_val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_WOL_MAC_CONTROL); /* Reg27E2 - Update Clk Slew Rate. */ reg_val = bitfield_replace(reg_val, EDGE_RATE_CNTL_POS, @@ -1329,8 +1358,6 @@ static int vsc8541_config(struct phy_device *phydev) int retval = -EINVAL; u16 reg_val; u16 rmii_clk_out; - enum vsc_phy_rgmii_skew rx_clk_skew = VSC_PHY_RGMII_DELAY_1700_PS; - enum vsc_phy_rgmii_skew tx_clk_skew = VSC_PHY_RGMII_DELAY_800_PS; enum vsc_phy_clk_slew edge_rate = VSC_PHY_CLK_SLEW_RATE_4;
/* For VSC8530/31 and VSC8540/41 the init scripts are the same */ @@ -1358,17 +1385,12 @@ static int vsc8541_config(struct phy_device *phydev) /* Default RMII Clk Output to 0=OFF/1=ON */ rmii_clk_out = 0;
+ retval = vsc8531_vsc8541_clk_skew_config(phydev); + if (retval != 0) + return retval; + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, MSCC_PHY_PAGE_EXT2); - reg_val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_RGMII_CNTL_REG); - /* Reg20E2 - Update RGMII RX_Clk Skews. */ - reg_val = bitfield_replace(reg_val, RGMII_RX_CLK_DELAY_POS, - RGMII_RX_CLK_DELAY_WIDTH, rx_clk_skew); - /* Reg20E2 - Update RGMII TX_Clk Skews. */ - reg_val = bitfield_replace(reg_val, RGMII_TX_CLK_DELAY_POS, - RGMII_TX_CLK_DELAY_WIDTH, tx_clk_skew); - phy_write(phydev, MDIO_DEVAD_NONE, MSCC_PHY_RGMII_CNTL_REG, reg_val); - reg_val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_WOL_MAC_CONTROL); /* Reg27E2 - Update Clk Slew Rate. */ reg_val = bitfield_replace(reg_val, EDGE_RATE_CNTL_POS,
not be enabled
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Heiko Stuebner
Philipp Tomsich
