[U-Boot] [PATCH] kbuild: include config.mk when auto.conf is not older than .config
Since the Kconfig conversion, config.mk has been included only when include/config/auto.conf is newer than the .config file.
It causes build error if both files have the same time-stamps. It is actually possible because EXT* file systems have a 1s time-stamp resolution.
The config.mk should be included when include/config/auto.conf is *not older* than the .config file.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reported-by: Tom Rini trini@konsulko.com Reported-by: York Sun yorksun@freescale.com Reported-by: Stephen Warren swarren@nvidia.com Reported-by: Matthew Gerlach mgerlach@opensource.altera.com ---
Makefile | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index f1bce44..53ad450 100644 --- a/Makefile +++ b/Makefile @@ -513,12 +513,16 @@ include/config/%.conf: $(KCONFIG_CONFIG) include/config/auto.conf.cmd # is up-to-date. When we switch to a different board configuration, old CONFIG # macros are still remaining in include/config/auto.conf. Without the following # gimmick, wrong config.mk would be included leading nasty warnings/errors. -autoconf_is_current := $(if $(wildcard $(KCONFIG_CONFIG)),$(shell find . \ - -path ./include/config/auto.conf -newer $(KCONFIG_CONFIG))) -ifneq ($(autoconf_is_current),) +ifneq ($(wildcard $(KCONFIG_CONFIG)),) +ifneq ($(wildcard include/config/auto.conf),) +autoconf_is_old := $(shell find . -path ./$(KCONFIG_CONFIG) -newer \ + include/config/auto.conf) +ifeq ($(autoconf_is_old),) include $(srctree)/config.mk include $(srctree)/arch/$(ARCH)/Makefile endif +endif +endif
# If board code explicitly specified LDSCRIPT or CONFIG_SYS_LDSCRIPT, use # that (or fail if absent). Otherwise, search for a linker script in a
Tested-by: Stephen Warren swarren@nvidia.com
I ran a loop of 941 "MAKEALL rpi_2" during a meeting without issue. I also applied the same patch to a tree that had the timestamps set in a way that triggered the problem, and it immediately solved it there.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reported-by: Tom Rini trini@konsulko.com Reported-by: York Sun yorksun@freescale.com Reported-by: Stephen Warren swarren@nvidia.com Reported-by: Matthew Gerlach mgerlach@opensource.altera.com Tested-by: Stephen Warren swarren@nvidia.com
Great job finally root causing this Stephen and then fixing it Masahiro!
Masahiro Yamada
Stephen Warren
