[PATCH 3/7] net: wget: Add a global struct wget_http_info
Declare and define a global struct wget_http_info. The default values are so that wget works as it used to, but they can be changed by an application before issuing an http request using wget, and restored afterwards. This struct is common to legacy wget and lwip wget.
Signed-off-by: Adriano Cordova adrianox@gmail.com --- include/net-common.h | 2 ++ net/net-common.c | 10 ++++++++++ 2 files changed, 12 insertions(+)
diff --git a/include/net-common.h b/include/net-common.h index 38ba95cf60..3039dfdce7 100644 --- a/include/net-common.h +++ b/include/net-common.h @@ -533,4 +533,6 @@ struct wget_http_info { char *headers; };
+extern struct wget_http_info wget_info; + #endif /* __NET_COMMON_H__ */ diff --git a/net/net-common.c b/net/net-common.c index a7f767d5e9..e969d508cc 100644 --- a/net/net-common.c +++ b/net/net-common.c @@ -1,4 +1,5 @@ // SPDX-License-Identifier: GPL-2.0 +#include <net-common.h>
void copy_filename(char *dst, const char *src, int size) { @@ -11,3 +12,12 @@ void copy_filename(char *dst, const char *src, int size) *dst++ = *src++; *dst = '\0'; } + +struct wget_http_info wget_info = { + .method = WGET_HTTP_METHOD_GET, + .file_size = 0, + .buffer_size = 0, + .set_bootdev = true, + .check_buffer_size = false, + .headers = NULL, +};
- .method = WGET_HTTP_METHOD_GET,
- .file_size = 0,
- .buffer_size = 0,
- .set_bootdev = true,
- .check_buffer_size = false,
- .headers = NULL,
Reviewed-by: Jerome Forissier jerome.forissier@linaro.org
Thanks,
- #endif /* __NET_COMMON_H__ */
- .file_size = 0,
- .buffer_size = 0,
- .headers = NULL,
wget_info is a global symbol. It will be reused in every wget transaction. The values initialized here may be overwritten in a first transaction and the current initialization would have no impact on a second transaction.
Please, move the initialization to the function that starts a new transaction.
For static and global variables only used after relocation it is not necessary to initialize members to 0 in the definition.
Best regards
Heinrich
Thanks,
Adriano Cordova
Jerome Forissier
