[U-Boot] [PATCH] cmd: crosec: Move crosec_decode_region helper to cmd/cros_ec.c
The cros_ec_decode_region() function is only used in combination with the crosec cmds. Move the function to the correct place.
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com Cc: Simon Glass sjg@chromium.org Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: u-boot@lists.denx.de --- cmd/cros_ec.c | 16 ++++++++++++++++ drivers/misc/cros_ec.c | 16 ---------------- include/cros_ec.h | 9 --------- 3 files changed, 16 insertions(+), 25 deletions(-)
diff --git a/cmd/cros_ec.c b/cmd/cros_ec.c index abf11f0..3a45149 100644 --- a/cmd/cros_ec.c +++ b/cmd/cros_ec.c @@ -19,6 +19,22 @@ static const char * const ec_current_image_name[] = {"unknown", "RO", "RW"};
DECLARE_GLOBAL_DATA_PTR;
+int cros_ec_decode_region(int argc, char * const argv[]) +{ + if (argc > 0) { + if (0 == strcmp(*argv, "rw")) + return EC_FLASH_REGION_RW; + else if (0 == strcmp(*argv, "ro")) + return EC_FLASH_REGION_RO; + + debug("%s: Invalid region '%s'\n", __func__, *argv); + } else { + debug("%s: Missing region parameter\n", __func__); + } + + return -1; +} + /** * Perform a flash read or write command * diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index 9159498..cf851ff 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -1070,22 +1070,6 @@ int cros_ec_register(struct udevice *dev) return 0; }
-int cros_ec_decode_region(int argc, char * const argv[]) -{ - if (argc > 0) { - if (0 == strcmp(*argv, "rw")) - return EC_FLASH_REGION_RW; - else if (0 == strcmp(*argv, "ro")) - return EC_FLASH_REGION_RO; - - debug("%s: Invalid region '%s'\n", __func__, *argv); - } else { - debug("%s: Missing region parameter\n", __func__); - } - - return -1; -} - int cros_ec_decode_ec_flash(const void *blob, int node, struct fdt_cros_ec *config) { diff --git a/include/cros_ec.h b/include/cros_ec.h index f280c1d..26b4680 100644 --- a/include/cros_ec.h +++ b/include/cros_ec.h @@ -252,15 +252,6 @@ void cros_ec_dump_data(const char *name, int cmd, const uint8_t *data, int len); */ int cros_ec_calc_checksum(const uint8_t *data, int size);
-/** - * Decode a flash region parameter - * - * @param argc Number of params remaining - * @param argv List of remaining parameters - * @return flash region (EC_FLASH_REGION_...) or -1 on error - */ -int cros_ec_decode_region(int argc, char * const argv[]); - int cros_ec_flash_erase(struct cros_ec_dev *dev, uint32_t offset, uint32_t size);
Hi Moritz,
Can this be static? Also can you please bring in the comment from the header file?
if (argc > 0) {
} else {
return -1;
- Perform a flash read or write command
if (argc > 0) {
} else {
return -1;
- Decode a flash region parameter
- @param argc Number of params remaining
- @param argv List of remaining parameters
- @return flash region (EC_FLASH_REGION_...) or -1 on error
-- 2.7.4
Moritz Fischer
