[U-Boot] [PATCH] cmd_part: fix usage text
Fix the usage info from: part part uuid <interface> <dev>:<part> to part uuid <interface> <dev>:<part>
Signed-off-by: Maxin B. John maxin.john@enea.com --- common/cmd_part.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_part.c b/common/cmd_part.c index d04588e..8483c12 100644 --- a/common/cmd_part.c +++ b/common/cmd_part.c @@ -128,7 +128,7 @@ static int do_part(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( part, CONFIG_SYS_MAXARGS, 1, do_part, "disk partition related commands", - "part uuid <interface> <dev>:<part>\n" + "uuid <interface> <dev>:<part>\n" " - print partition UUID\n" "part uuid <interface> <dev>:<part> <varname>\n" " - set environment variable to partition UUID\n"
Another case of the automatic command prefixing in the long description leading to stuttering :) patch looks good to me
Reviewed-By: Sjoerd Simons <sjoerd.simons@collabora.co.uk
- "uuid <interface> <dev>:<part>\n" " - print partition UUID\n" "part uuid <interface> <dev>:<part> <varname>\n" " - set environment variable to partition UUID\n"
Signed-off-by: Maxin B. John maxin.john@enea.com Reviewed-By: Sjoerd Simons <sjoerd.simons@collabora.co.uk
Maxin B. John
Sjoerd Simons
