[U-Boot] [PATCH 1/3] powerpc/p5040: enable NAND boot support
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- boards.cfg | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/boards.cfg b/boards.cfg index e4b0d44..8cf4936 100644 --- a/boards.cfg +++ b/boards.cfg @@ -855,6 +855,7 @@ P5020DS_SECURE_BOOT powerpc mpc85xx corenet_ds freesca P5020DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 P5020DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P5040DS powerpc mpc85xx corenet_ds freescale +P5040DS_NAND powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa
diff --git a/boards.cfg b/boards.cfg index 8cf4936..314afa2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -856,6 +856,7 @@ P5020DS_SPIFLASH powerpc mpc85xx corenet_ds freescale P5020DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 P5040DS powerpc mpc85xx corenet_ds freescale P5040DS_NAND powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 +P5040DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa
diff --git a/boards.cfg b/boards.cfg index 314afa2..710942f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -857,6 +857,7 @@ P5020DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds free P5040DS powerpc mpc85xx corenet_ds freescale P5040DS_NAND powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 P5040DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 +P5040DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa
These patches only add one line each, and each depends on the previous anyway. They should be merged into one patch.
-----Original Message----- From: Tabi Timur-B04825 Sent: Wednesday, January 16, 2013 10:42 PM To: Xie Shaohui-B21989 Cc: u-boot@lists.denx.de Subject: Re: [u-boot-release] [PATCH 1/3] powerpc/p5040: enable NAND boot support
[S.H] I thought one patch doing one thing even it's simple. I'm fine with the merge if you insist.
Best Regards, Shaohui Xie
Well, it is a matter of opinion. I don't insist, but I think it would be easier for everyone if you did merge these patches. Each one is very short, and they are all very similar.
-----Original Message----- From: Tabi Timur-B04825 Sent: Friday, January 18, 2013 10:27 AM To: Xie Shaohui-B21989 Cc: u-boot@lists.denx.de Subject: Re: [u-boot-release] [PATCH 1/3] powerpc/p5040: enable NAND boot support
[S.H] it's also easier for me. :) I had to separate the three lines to three patches when sending them, I thought Someone may NAC the merged patch because it added three features.
This needs more explanation. What sort of image am I supposed to get when I build "P5040DS_NAND"? Where is the PBI?
What is the long-term plan for fixing the problem of the environment not being available until after relocation? With SPL we could use CONFIG_NAND_ENV_DST (which has some issues, but they're fixable).
It would also be nice to include instructions for configuring the board to boot from NAND in a README (Freescale's user manuals often do not make this clear, especially for soft configuration). Also please provide a built-in command (or script in the default environment) to soft-boot into NAND (or if it already exists, please document it).
-Scott
-----Original Message----- From: Wood Scott-B07421 Sent: Thursday, January 17, 2013 4:29 AM To: Xie Shaohui-B21989 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 1/3] powerpc/p5040: enable NAND boot support
[S.H] there is already a readme for p3041/p5020/p4080 (doc/README.pblimage), With the PBL tool, we will get a ramboot image "u-boot.pbl". and also the PBI, it is shared by P3/P4/P5.
[S.H] this will need export some NAND read APIs (like load ENV stuff from CONFIG_NAND_ENV_DST), then they can be reused before relocation even not using SPL. Please suggest.
[S.H] This exist in the above readme.
[S.H] I was told that when doing ramboot, I should not assume the board has a NOR flash, for ex. on customer's board, they may only have NAND. So I did not do this.
support
get
The question is how is the user to know that something called "pblimage" is relevant to booting from NAND on P5040? Maybe a README.corenet_ds (or board/freescale/corenet_ds/README), that points to README.pblimage?
You don't even update strings like "P3041/P5020" in README.pblimage to include P5040. :-) Why is P4080 excluded, BTW? I realize that P4080DS doesn't have NAND, but the file talks about chips, not boards.
environment not
The full NAND subsystem will not work before relocation. Your options are to either use SPL (note that you'll have no 4K limitation in this case, so you can do SPD DDR init), or make the SPL code available in non-SPL context somehow. I think the former would be easier.
board
I only see hardware switch settings. Is there no way to soft-boot into NAND (similar to using "pixis/qixis altbank" to boot into an alternate NOR bank)? Our e500v2-based boards have been able to do this...
provide a
soft-boot into
I'm not asking you to assume that, just to provide some helpful instructions for people who happen to have both (in addition to the hardware switch instructions that are already there). Actually, these instructions (both soft boot and hardware switches) are board-specific rather than SoC-specific and should go in a board README instead. And once you know we're talking about a corenet_ds board, you know we have NOR.
-Scott
get
[S.H] Yes. A README for corenet_ds board will be more useful, then a ramboot section points to README.pblimage.
[S.H] Thanks for pointing it out. I will update the README.pblimage in next version.
[S.H] there is no P4080DS_NAND entry in boards.cfg...
environment not
The full NAND subsystem will not work before relocation. Your options are to either use SPL (note that you'll have no 4K limitation in this case, so you can do SPD DDR init), or make the SPL code available in non- SPL context somehow. I think the former would be easier.
[S.H] Thanks. I will assess the effort base on my case.
board
[S.H] we do have these soft-boot instructions for corenet_ds board. And yes, they should go in README of corenet_ds board, but seems we don't have such a README.
to
include P5040. :-)
Yes, I said I realize that P4080DS (note the DS) doesn't have NAND. But P4080 the SoC should support NAND boot on custom boards that have NAND, and README.pblimage doesn't appear to be talking about specific boards (except for the hardware switch section).
-Scott
participants (5)
Scott Wood
Shaohui Xie
Tabi Timur-B04825
Timur Tabi
Xie Shaohui-B21989
