[PATCH] configs: defconfig: Load OS via FIT image in Stratix 10 and Agilex NAND boot
Update to load OS via FIT image in Stratix 10 and Agilex NAND boot flow. And, enable FIT signature checking with crc32 algorithm.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- configs/socfpga_agilex_nand_atf_defconfig | 6 +++++- configs/socfpga_stratix10_nand_atf_defconfig | 6 +++++- include/configs/socfpga_soc64_common.h | 4 ++++ 3 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/configs/socfpga_agilex_nand_atf_defconfig b/configs/socfpga_agilex_nand_atf_defconfig index 0beec3d8dd..558dda1a2e 100755 --- a/configs/socfpga_agilex_nand_atf_defconfig +++ b/configs/socfpga_agilex_nand_atf_defconfig @@ -14,6 +14,10 @@ CONFIG_IDENT_STRING="socfpga_agilex" CONFIG_SPL_FS_FAT=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex_socdk_nand" CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_SIGNATURE_MAX_SIZE=0x10000000 +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_CRC32_SUPPORT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x2000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set @@ -22,7 +26,7 @@ CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1" CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run nandload; run linux_qspi_enable; run nandboot" +CONFIG_BOOTCOMMAND="run nandfitload; run linux_qspi_enable; run rsu_status; run nandfitboot" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_CACHE=y diff --git a/configs/socfpga_stratix10_nand_atf_defconfig b/configs/socfpga_stratix10_nand_atf_defconfig index cbb3f88ec2..7eb956733c 100755 --- a/configs/socfpga_stratix10_nand_atf_defconfig +++ b/configs/socfpga_stratix10_nand_atf_defconfig @@ -14,6 +14,10 @@ CONFIG_TARGET_SOCFPGA_STRATIX10_SOCDK=y CONFIG_IDENT_STRING="socfpga_stratix10" CONFIG_SPL_FS_FAT=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_stratix10_socdk_nand" +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_SIGNATURE_MAX_SIZE=0x10000000 +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_CRC32_SUPPORT=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x2000000 @@ -23,7 +27,7 @@ CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1" CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run nandload; run linux_qspi_enable; rsu dtb; run nandboot" +CONFIG_BOOTCOMMAND="run nandfitload; run linux_qspi_enable; run rsu_status; run nandfitboot" CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SPI_LOAD=y diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 8a9f4dc4c9..2343a315b9 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -85,6 +85,10 @@ "scriptfile=u-boot.scr\0" \ "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \ "then source ${scriptaddr}; fi\0" \ + "nandfitboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${nandroot} rw rootwait rootfstype=jffs2; " \ + "bootm ${loadaddr}\0" \ + "nandfitload=nand read ${loadaddr} kernel\0" \ "socfpga_legacy_reset_compat=1\0"
Jit Loon Lim
