[U-Boot] [PATCH v1 0/3] arm, at91: support for the taurus and corvus board
MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit
add support for the two AT91SAM9G20 boards from siemens. For the taurus board, patch 1 from this series add some needed defines.
Heiko Schocher (2): arm, at91: add Siemens board taurus (based on AT91SAM9G20) arm, at91: add siemens corvus board
Roger Meier (1): at91: add defines for reset type
arch/arm/include/asm/arch-at91/at91_rstc.h | 7 + board/siemens/corvus/Makefile | 39 ++++ board/siemens/corvus/board.c | 345 +++++++++++++++++++++++++++++ board/siemens/taurus/Makefile | 38 ++++ board/siemens/taurus/taurus.c | 204 +++++++++++++++++ boards.cfg | 3 + include/configs/corvus.h | 185 ++++++++++++++++ include/configs/taurus.h | 163 ++++++++++++++ 8 files changed, 984 insertions(+) create mode 100644 board/siemens/corvus/Makefile create mode 100644 board/siemens/corvus/board.c create mode 100644 board/siemens/taurus/Makefile create mode 100644 board/siemens/taurus/taurus.c create mode 100644 include/configs/corvus.h create mode 100644 include/configs/taurus.h
Signed-off-by: Roger Meier r.meier@siemens.com Reviewed-by: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com --- arch/arm/include/asm/arch-at91/at91_rstc.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/arch-at91/at91_rstc.h b/arch/arm/include/asm/arch-at91/at91_rstc.h index 423cf51..a942342 100644 --- a/arch/arm/include/asm/arch-at91/at91_rstc.h +++ b/arch/arm/include/asm/arch-at91/at91_rstc.h @@ -38,4 +38,11 @@ typedef struct at91_rstc {
#define AT91_RSTC_SR_NRSTL 0x00010000
+#define AT91_RSTC_RSTTYP (7 << 8) /* Reset Type */ +#define AT91_RSTC_RSTTYP_GENERAL (0 << 8) +#define AT91_RSTC_RSTTYP_WAKEUP (1 << 8) +#define AT91_RSTC_RSTTYP_WATCHDOG (2 << 8) +#define AT91_RSTC_RSTTYP_SOFTWARE (3 << 8) +#define AT91_RSTC_RSTTYP_USER (4 << 8) + #endif
Hi Heiko Schocher,
Acked-by: Bo Shen voice.shen@atmel.com
- #endif
Best Regards, Bo Shen
Signed-off-by: Roger Meier r.meier@siemens.com Reviewed-by: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com --- board/siemens/taurus/Makefile | 38 ++++++++ board/siemens/taurus/taurus.c | 204 ++++++++++++++++++++++++++++++++++++++++++ boards.cfg | 2 + include/configs/taurus.h | 163 +++++++++++++++++++++++++++++++++ 4 files changed, 407 insertions(+) create mode 100644 board/siemens/taurus/Makefile create mode 100644 board/siemens/taurus/taurus.c create mode 100644 include/configs/taurus.h
diff --git a/board/siemens/taurus/Makefile b/board/siemens/taurus/Makefile new file mode 100644 index 0000000..9c288b7 --- /dev/null +++ b/board/siemens/taurus/Makefile @@ -0,0 +1,38 @@ +# +# Makefile for Siemens TAURUS (AT91SAM9G20) based board +# (C) Copyright 2013 Siemens AG +# +# Based on: +# U-Boot file: board/atmel/at91sam9260ek/Makefile +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian@popies.net +# Lead Tech Design <www.leadtechdesign.com> +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += taurus.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c new file mode 100644 index 0000000..debc48e --- /dev/null +++ b/board/siemens/taurus/taurus.c @@ -0,0 +1,204 @@ +/* + * Board functions for Siemens TAURUS (AT91SAM9G20) based boards + * (C) Copyright Siemens AG + * + * Based on: + * U-Boot file: board/atmel/at91sam9260ek/at91sam9260ek.c + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/at91sam9_sdramc.h> +#include <atmel_mci.h> + +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +# include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void taurus_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + /* Assign CS3 to NAND/SmartMedia Interface */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(3), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void taurus_macb_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + /* Enable EMAC clock */ + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + + /* + * Disable pull-up on: + * RXDV (PA17) => PHY normal mode (not Test mode) + * ERX0 (PA14) => PHY ADDR0 + * ERX1 (PA15) => PHY ADDR1 + * ERX2 (PA25) => PHY ADDR2 + * ERX3 (PA26) => PHY ADDR3 + * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + &pioa->pudr); + + /* + * Need to reset PHY ?-> 200us reset + * Bug within Atmel CPU (undefined initial states on io-lines)! + * Startup Ethernet Switch delayed so that hardstrap(Switch Config) + * has defined state after cold start (do not break daisy chain!). + */ + if ((readl(&rstc->sr) & AT91_RSTC_RSTTYP) == AT91_RSTC_RSTTYP_GENERAL) + at91_set_gpio_output(AT91_PIN_PA25, 0); + + + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + + /* Need to reset PHY -> 500ms reset */ + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) + ; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + + at91_set_gpio_input(AT91_PIN_PA25, 1); /* ERST tri-state */ + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + &pioa->puer); + + /* Initialize EMAC=MACB hardware */ + at91_macb_hw_init(); +} +#endif + +#ifdef CONFIG_GENERIC_ATMEL_MCI +int board_mmc_init(bd_t *bd) +{ + at91_mci_hw_init(); + + return atmel_mci_init((void *)ATMEL_BASE_MCI); +} +#endif + +int board_early_init_f(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + /* Enable clocks for all PIOs */ + writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOC), + &pmc->pcer); + + return 0; +} + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of board */ + gd->bd->bi_arch_number = CONFIG_MACH_TYPE; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + at91_seriald_hw_init(); +#ifdef CONFIG_CMD_NAND + taurus_nand_hw_init(); +#endif +#ifdef CONFIG_MACB + taurus_macb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + /* configure ram size based on sdram controller config registers */ + unsigned int sdram_cr_nc; + sdram_cr_nc = readl(AT91_SDRAMC_CR) & AT91_SDRAMC_NC; + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + (32 << 20) << sdram_cr_nc); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x00); +#endif + return rc; +} diff --git a/boards.cfg b/boards.cfg index aa2ee64..e693105 100644 --- a/boards.cfg +++ b/boards.cfg @@ -139,6 +139,8 @@ Active arm arm926ejs at91 ronetix pm9263 Active arm arm926ejs at91 ronetix pm9g45 pm9g45 pm9g45:AT91SAM9G45 Ilko Iliev iliev@ronetix.at Active arm arm926ejs at91 taskit stamp9g20 portuxg20 stamp9g20:AT91SAM9G20,PORTUXG20 Markus Hubig mhubig@imko.de Active arm arm926ejs at91 taskit stamp9g20 stamp9g20 stamp9g20:AT91SAM9G20 Markus Hubig mhubig@imko.de +Active arm arm926ejs at91 siemens taurus axm taurus:AT91SAM9G20,MACH_TYPE=2068 Heiko Schocher hs@denx.de +Active arm arm926ejs at91 siemens taurus taurus taurus:AT91SAM9G20,MACH_TYPE=2067 Heiko Schocher hs@denx.de Active arm arm926ejs davinci ait cam_enc_4xx cam_enc_4xx cam_enc_4xx Heiko Schocher hs@denx.de Active arm arm926ejs davinci Barix ipam390 ipam390 - Heiko Schocher hs@denx.de Active arm arm926ejs davinci davinci da8xxevm da830evm - Nick Thompson nick.thompson@gefanuc.com diff --git a/include/configs/taurus.h b/include/configs/taurus.h new file mode 100644 index 0000000..e4bbb63 --- /dev/null +++ b/include/configs/taurus.h @@ -0,0 +1,163 @@ +/* + * Common board functions for Siemens TAURUS (AT91SAM9G20) based boards + * (C) Copyright 2013 Siemens AG + * + * Based on: + * U-Boot file: include/configs/at91sam9260ek.h + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * SoC must be defined first, before hardware.h is included. + * In this case SoC is defined in boards.cfg. + */ +#include <asm/hardware.h> + +#define MACH_TYPE_TAURUS 2067 +#define MACH_TYPE_AXM 2068 + +/* + * Warning: changing CONFIG_SYS_TEXT_BASE requires + * adapting the initial boot program. + * Since the linker has to swallow that define, we must use a pure + * hex number here! + */ + + +#define CONFIG_SYS_TEXT_BASE 0x23f00000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* main clock xtal */ +#define CONFIG_SYS_HZ 1000 + +/* Misc CPU related */ +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +#define CONFIG_CMD_BOOTZ +#define CONFIG_OF_LIBFDT + +/* general purpose I/O */ +#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ +#define CONFIG_AT91_GPIO +#define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */ + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_BOOTDELAY 3 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND + +/* + * SDRAM: 1 bank, min 32, max 128 MB + * Initialized before u-boot gets started. + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 +/* + * PHYS_SDRAM_SIZE is dynamically detected according to the + * "Number of Column Bits" set within the SDRAM Configuration + * register, see axm.c for further details + */ + +/* + * Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM, + * leaving the correct space for initial global data structure above + * that address while providing maximum stack area below. + */ +# define CONFIG_SYS_INIT_SP_ADDR \ + (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +#define CONFIG_SYS_NAND_DBW_8 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 +#endif + +/* NOR flash - no real flash on this board */ +#define CONFIG_SYS_NO_FLASH 1 + +/* Ethernet */ +#define CONFIG_MACB +#define CONFIG_RMII + +/* USB */ +#if (CONFIG_MACH_TYPE == MACH_TYPE_TAURUS) +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#endif + +/* load address */ +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +/* bootstrap in spi flash , u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_OFFSET_REDUND 0x180000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x300000; bootm" +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk " \ + "mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro," \ + "256k(env),256k(env_redundant),256k(spare)," \ + "512k(dtb),6M(kernel)ro,-(rootfs) " \ + "root=/dev/mtdblock7 rw rootfstype=jffs2" + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN \ + ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) + +#endif
Hi Heiko Schocher,
Please add commit message.
- $(call cmd_link_o_target, $(OBJS) $(SOBJS))
- Board functions for Siemens TAURUS (AT91SAM9G20) based boards
- (C) Copyright Siemens AG
- Based on:
- U-Boot file: board/atmel/at91sam9260ek/at91sam9260ek.c
- (C) Copyright 2007-2008
- Stelian Pop stelian@popies.net
- Lead Tech Design <www.leadtechdesign.com>
- Miscelaneous platform dependent initialisations
I think this comment no meaning here.
- struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC;
- struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- unsigned long csa;
- /* Assign CS3 to NAND/SmartMedia Interface */
- csa = readl(&matrix->ebicsa);
- csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA;
- writel(csa, &matrix->ebicsa);
- /* Configure SMC CS3 for NAND/SmartMedia */
- writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);
- writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(3) |
&smc->cs[3].pulse);
- writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7),
&smc->cs[3].cycle);
- writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE |
&smc->cs[3].mode);
- /* Configure RDY/BSY */
- at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
- /* Enable NandFlash */
- at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1);
+} +#endif
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA;
- struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC;
- unsigned long erstl;
- /* Enable EMAC clock */
- writel(1 << ATMEL_ID_EMAC0, &pmc->pcer);
- writel(pin_to_mask(AT91_PIN_PA14) |
&pioa->pudr);
Call we use GPIO API here?
- if ((readl(&rstc->sr) & AT91_RSTC_RSTTYP) == AT91_RSTC_RSTTYP_GENERAL)
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK;
- /* Need to reset PHY -> 500ms reset */
- writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) |
- writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr);
- /* Wait for end hardware reset */
- while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL))
Add a timeout here.
- /* Restore NRST value */
- writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr);
- at91_set_gpio_input(AT91_PIN_PA25, 1); /* ERST tri-state */
- /* Re-enable pull-up */
&pioa->puer);
- /* Initialize EMAC=MACB hardware */
- at91_macb_hw_init();
+} +#endif
- at91_mci_hw_init();
- return atmel_mci_init((void *)ATMEL_BASE_MCI);
+} +#endif
- /* Enable clocks for all PIOs */
- writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) |
&pmc->pcer);
- /* Enable Ctrlc */
- console_init_f();
This is can be removed.
- /* arch number of board */
- gd->bd->bi_arch_number = CONFIG_MACH_TYPE;
Move to board related configuration file.
- /* adress of boot parameters */
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_seriald_hw_init();
- taurus_nand_hw_init();
- taurus_macb_hw_init();
- /* configure ram size based on sdram controller config registers */
- unsigned int sdram_cr_nc;
- sdram_cr_nc = readl(AT91_SDRAMC_CR) & AT91_SDRAMC_NC;
- gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE,
Would it be possible the same NC, however different NR?
- int rc = 0;
+#ifdef CONFIG_MACB
- rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x00);
- return rc;
Why two boards here?
- Common board functions for Siemens TAURUS (AT91SAM9G20) based boards
- (C) Copyright 2013 Siemens AG
- Based on:
- U-Boot file: include/configs/at91sam9260ek.h
- SoC must be defined first, before hardware.h is included.
- In this case SoC is defined in boards.cfg.
These two type are the same board?
- Warning: changing CONFIG_SYS_TEXT_BASE requires
- adapting the initial boot program.
- Since the linker has to swallow that define, we must use a pure
- hex number here!
This address should be considered (if the memory size is 64MiB) as u-boot is top down map, there is only 1MiB left.
replace tab with black space.
- Command line configuration.
- SDRAM: 1 bank, min 32, max 128 MB
- Initialized before u-boot gets started.
- PHYS_SDRAM_SIZE is dynamically detected according to the
- "Number of Column Bits" set within the SDRAM Configuration
- register, see axm.c for further details
- Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM,
- leaving the correct space for initial global data structure above
- that address while providing maximum stack area below.
- (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE)
discard the unnessacery "1"
- "console=ttyS0,115200 earlyprintk " \
- "mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro," \
- "256k(env),256k(env_redundant),256k(spare)," \
- "512k(dtb),6M(kernel)ro,-(rootfs) " \
- "root=/dev/mtdblock7 rw rootfstype=jffs2"
- (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
- Size of malloc() pool
- ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000)
Hi Heiko,
some additional comments on top of Bo's.
On 10/28/2013 06:24 AM, Bo Shen wrote:
Hi Heiko Schocher,
- Based on:
&smc->cs[3].setup);
&smc->cs[3].pulse);
&smc->cs[3].cycle);
&smc->cs[3].mode);
+} +#endif
&pioa->pudr);
Unfortunately there is no way to set multiple I/O in one go. Beside that this is more PIO API than GPIO API (same as the kernel side discussion about gpio vs pinmux). I would accept this her in that special case, preferably we could add some API to mux multiple pins in one go.
Add a timeout here.
&pioa->puer);
+} +#endif
+} +#endif
&pmc->pcer);
Isn't there some API to do this? To answer myself, I think not. Each AT91 board has this piece of code copied in its board_early_init_f ... we should think about adding a generic function to do that for us.
- console_init_f();
Hasn't the get_ram_size() some feature to detect the real size implemented? Why detect the configured size before?
- int rc = 0;
+#ifdef CONFIG_MACB
- return rc;
- Based on:
Isn't the correct type defined by boards.cfg?
- hex number here!
Could you please remove the empty lines (at least one) here?
As discussed in the Calo USB-A9263 board, please prove that the address works in all cases (with the given setup in this file). IOW check if now code will be clobbered by relocate_code() and write it down in some comment. A reminder for later adoption in the configuration would also considered helpful ;)
Where is this axm.c located?
Ah, got it .. forget the question at beginnign of file.
Use mtdparts also in u-boot?
Best regards
Andreas Bießmann
Hello Andreas,
Am 29.10.2013 10:43, schrieb Andreas Bießmann:
Hi Heiko,
Hi Heiko Schocher,
Signed-off-by: Roger Meierr.meier@siemens.com Reviewed-by: Heiko Schocherhs@denx.de Cc: Andreas Bießmannandreas.devel@googlemail.com
diff --git a/board/siemens/taurus/Makefile b/board/siemens/taurus/Makefile new file mode 100644 index 0000000..9c288b7 --- /dev/null +++ b/board/siemens/taurus/Makefile @@ -0,0 +1,38 @@ +# +# Makefile for Siemens TAURUS (AT91SAM9G20) based board +# (C) Copyright 2013 Siemens AG +# +# Based on: +# U-Boot file: board/atmel/at91sam9260ek/Makefile +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Popstelian@popies.net +# Lead Tech Design<www.leadtechdesign.com> +# +# SPDX-License-Identifier: GPL-2.0+ +#
- Based on:
- Stelian Popstelian@popies.net
- Lead Tech Design<www.leadtechdesign.com>
+#include<common.h> +#include<asm/io.h> +#include<asm/arch/at91sam9260_matrix.h> +#include<asm/arch/at91sam9_smc.h> +#include<asm/arch/at91_common.h> +#include<asm/arch/at91_pmc.h> +#include<asm/arch/at91_rstc.h> +#include<asm/arch/gpio.h> +#include<asm/arch/at91sam9_sdramc.h> +#include<atmel_mci.h>
+#if defined(CONFIG_RESET_PHY_R)&& defined(CONFIG_MACB) +# include<net.h> +#endif +#include<netdev.h>
- writel(csa,&matrix->ebicsa);
+&smc->cs[3].setup);
+&smc->cs[3].pulse);
+&smc->cs[3].cycle);
+&smc->cs[3].mode);
+} +#endif
- writel(1<< ATMEL_ID_EMAC0,&pmc->pcer);
+&pioa->pudr);
I used "at91_set_pio_pullup" in my new version for this ...
- if ((readl(&rstc->sr)& AT91_RSTC_RSTTYP) ==
- erstl = readl(&rstc->mr)& AT91_RSTC_MR_ERSTL_MASK;
AT91_RSTC_MR_URSTEN,&rstc->mr);
- writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST,&rstc->cr);
- while (!(readl(&rstc->sr)& AT91_RSTC_SR_NRSTL))
Add a timeout here.
- writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN,&rstc->mr);
+&pioa->puer);
+} +#endif
+} +#endif
- writel((1<< ATMEL_ID_PIOA) | (1<< ATMEL_ID_PIOB) |
(1<< ATMEL_ID_PIOC),
+&pmc->pcer);
Ok.
- console_init_f();
- sdram_cr_nc = readl(AT91_SDRAMC_CR)& AT91_SDRAMC_NC;
(32<< 20)<< sdram_cr_nc);
I use now get_ram_size() with the may ram size possible, so no need for sdram_cr_nc anymore ...
- int rc = 0;
+#ifdef CONFIG_MACB
- return rc;
+} diff --git a/boards.cfg b/boards.cfg index aa2ee64..e693105 100644 --- a/boards.cfg +++ b/boards.cfg @@ -139,6 +139,8 @@ Active arm arm926ejs at91 ronetix pm9263 Active arm arm926ejs at91 ronetix pm9g45 pm9g45 pm9g45:AT91SAM9G45 Ilko Ilieviliev@ronetix.at Active arm arm926ejs at91 taskit stamp9g20 portuxg20 stamp9g20:AT91SAM9G20,PORTUXG20 Markus Hubigmhubig@imko.de Active arm arm926ejs at91 taskit stamp9g20 stamp9g20 stamp9g20:AT91SAM9G20 Markus Hubigmhubig@imko.de +Active arm arm926ejs at91 siemens taurus axm taurus:AT91SAM9G20,MACH_TYPE=2068 Heiko Schocherhs@denx.de +Active arm arm926ejs at91 siemens taurus taurus taurus:AT91SAM9G20,MACH_TYPE=2067 Heiko Schocherhs@denx.de
Active arm arm926ejs davinci ait cam_enc_4xx cam_enc_4xx cam_enc_4xx Heiko Schocherhs@denx.de Active arm arm926ejs davinci Barix ipam390 ipam390
Heiko Schocherhs@denx.de Active arm arm926ejs davinci davinci da8xxevm da830evm
Nick Thompsonnick.thompson@gefanuc.com diff --git a/include/configs/taurus.h b/include/configs/taurus.h new file mode 100644 index 0000000..e4bbb63 --- /dev/null +++ b/include/configs/taurus.h @@ -0,0 +1,163 @@ +/*
- Based on:
+#include<asm/hardware.h>
removed.
- hex number here!
Yep, done.
Working on it (incl. replace at91bootstrap with U-Boot spl, will take some time ...)
+#include<config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
Removed comment, as ramsize gets detected now with get_ram_size()
+/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +#define CONFIG_SYS_NAND_DBW_8 +#define CONFIG_SYS_NAND_MASK_ALE (1<< 21) +#define CONFIG_SYS_NAND_MASK_CLE (1<< 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 +#endif
Hmm, removed this, and replaced with a BOARD_TAURS or BOARD_AXM define.
Try to find this out ...
bye, Heiko
Signed-off-by: Boris Schmidt boris.schmidt@siemens.com Reviewed-by: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com --- board/siemens/corvus/Makefile | 39 +++++ board/siemens/corvus/board.c | 345 ++++++++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/corvus.h | 185 ++++++++++++++++++++++ 4 files changed, 570 insertions(+) create mode 100644 board/siemens/corvus/Makefile create mode 100644 board/siemens/corvus/board.c create mode 100644 include/configs/corvus.h
diff --git a/board/siemens/corvus/Makefile b/board/siemens/corvus/Makefile new file mode 100644 index 0000000..88981d8 --- /dev/null +++ b/board/siemens/corvus/Makefile @@ -0,0 +1,39 @@ +# +# Makefile for siemens CORVUS (AT91SAM9G45) based board +# (C) Copyright 2013 Siemens AG +# +# Based on: +# U-Boot file: board/atmel/at91sam9m10g45ek/Makefile +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian@popies.net +# Lead Tech Design <www.leadtechdesign.com> +# +# SPDX-License-Identifier: GPL-2.0+ +# + + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += board.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/siemens/corvus/board.c b/board/siemens/corvus/board.c new file mode 100644 index 0000000..1940da7 --- /dev/null +++ b/board/siemens/corvus/board.c @@ -0,0 +1,345 @@ +/* + * Board functions for Siemens CORVUS (AT91SAM9G45) based board + * (C) Copyright 2013 Siemens AG + * + * Based on: + * U-Boot file: board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9g45_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/clk.h> +#include <lcd.h> +#include <atmel_lcdc.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void corvus_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + unsigned long csa; + + /* Enable CS3 */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(3) | AT91_SMC_PULSE_NCS_RD(2), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(4), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_MODE_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_MODE_DBW_8 | +#endif + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); + + writel(1 << ATMEL_ID_PIOC, &pmc->pcer); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_CMD_USB +static void at91sam9m10g45ek_usb_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + writel(1 << ATMEL_ID_PIODE, &pmc->pcer); + + at91_set_gpio_output(AT91_PIN_PD1, 0); + at91_set_gpio_output(AT91_PIN_PD3, 0); +} +#endif + +#ifdef CONFIG_MACB +static void corvus_macb_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + /* Enable clock */ + writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + + /* + * Disable pull-up on: + * RXDV (PA15) => PHY normal mode (not Test mode) + * ERX0 (PA12) => PHY ADDR0 + * ERX1 (PA13) => PHY ADDR1 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA12) | + pin_to_mask(AT91_PIN_PA13), + &pioa->pudr); + + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + + /* Need to reset PHY -> 500ms reset */ + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) + ; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, + &rstc->mr); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA12) | + pin_to_mask(AT91_PIN_PA13), + &pioa->puer); + + /* And the pins. */ + at91_macb_hw_init(); +} +#endif + +#ifdef CONFIG_LCD + +vidinfo_t panel_info = { +vl_col: 480, +vl_row:272, +vl_clk:9000000, +vl_sync : ATMEL_LCDC_INVLINE_NORMAL | + ATMEL_LCDC_INVFRAME_NORMAL, +vl_bpix:3, +vl_tft:1, +vl_hsync_len:45, +vl_left_margin:1, + vl_right_margin:1, +vl_vsync_len:1, + vl_upper_margin:40, + vl_lower_margin:1, + mmio : ATMEL_BASE_LCDC, +}; + + +void lcd_enable(void) +{ + at91_set_A_periph(AT91_PIN_PE6, 1); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_A_periph(AT91_PIN_PE6, 0); /* power down */ +} + +static void corvus_lcd_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_A_periph(AT91_PIN_PE0, 0); /* LCDDPWR */ + at91_set_A_periph(AT91_PIN_PE2, 0); /* LCDCC */ + at91_set_A_periph(AT91_PIN_PE3, 0); /* LCDVSYNC */ + at91_set_A_periph(AT91_PIN_PE4, 0); /* LCDHSYNC */ + at91_set_A_periph(AT91_PIN_PE5, 0); /* LCDDOTCK */ + + at91_set_A_periph(AT91_PIN_PE7, 0); /* LCDD0 */ + at91_set_A_periph(AT91_PIN_PE8, 0); /* LCDD1 */ + at91_set_A_periph(AT91_PIN_PE9, 0); /* LCDD2 */ + at91_set_A_periph(AT91_PIN_PE10, 0); /* LCDD3 */ + at91_set_A_periph(AT91_PIN_PE11, 0); /* LCDD4 */ + at91_set_A_periph(AT91_PIN_PE12, 0); /* LCDD5 */ + at91_set_A_periph(AT91_PIN_PE13, 0); /* LCDD6 */ + at91_set_A_periph(AT91_PIN_PE14, 0); /* LCDD7 */ + at91_set_A_periph(AT91_PIN_PE15, 0); /* LCDD8 */ + at91_set_A_periph(AT91_PIN_PE16, 0); /* LCDD9 */ + at91_set_A_periph(AT91_PIN_PE17, 0); /* LCDD10 */ + at91_set_A_periph(AT91_PIN_PE18, 0); /* LCDD11 */ + at91_set_A_periph(AT91_PIN_PE19, 0); /* LCDD12 */ + at91_set_B_periph(AT91_PIN_PE20, 0); /* LCDD13 */ + at91_set_A_periph(AT91_PIN_PE21, 0); /* LCDD14 */ + at91_set_A_periph(AT91_PIN_PE22, 0); /* LCDD15 */ + at91_set_A_periph(AT91_PIN_PE23, 0); /* LCDD16 */ + at91_set_A_periph(AT91_PIN_PE24, 0); /* LCDD17 */ + at91_set_A_periph(AT91_PIN_PE25, 0); /* LCDD18 */ + at91_set_A_periph(AT91_PIN_PE26, 0); /* LCDD19 */ + at91_set_A_periph(AT91_PIN_PE27, 0); /* LCDD20 */ + at91_set_B_periph(AT91_PIN_PE28, 0); /* LCDD21 */ + at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */ + at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */ + + writel(1 << ATMEL_ID_LCDC, &pmc->pcer); + + gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE; +} + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> + +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf("%s\n", U_BOOT_VERSION); + lcd_printf("(C) 2009 Siemens SBT\n"); + lcd_printf("www.sbt.siemens.com\n"); + lcd_printf("%s CPU at %s MHz\n", + ATMEL_CPU_NAME, + strmhz(temp, get_cpu_clk_rate())); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20); +} +#endif /* CONFIG_LCD_INFO */ +#endif + +int board_early_init_f(void) +{ + at91_seriald_hw_init(); + return 0; +} + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of corvus-Board */ + gd->bd->bi_arch_number = MACH_TYPE_CORVUS; + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + + board_early_init_f(); + +#ifdef CONFIG_CMD_NAND + corvus_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_ATMEL_SPI + at91_spi0_hw_init(1 << 4); +#endif +#ifdef CONFIG_MACB + corvus_macb_hw_init(); +#endif +#ifdef CONFIG_LCD + corvus_lcd_hw_init(); +#endif +#ifdef CONFIG_CMD_USB + at91sam9m10g45ek_usb_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x00); +#endif + return rc; +} + +/* SPI chip select control */ +#ifdef CONFIG_ATMEL_SPI +#include <spi.h> + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs < 2; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 1: + at91_set_gpio_output(AT91_PIN_PB18, 0); + break; + case 0: + default: + at91_set_gpio_output(AT91_PIN_PB3, 0); + break; + } +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 1: + at91_set_gpio_output(AT91_PIN_PB18, 1); + break; + case 0: + default: + at91_set_gpio_output(AT91_PIN_PB3, 1); + break; + } +} +#endif /* CONFIG_ATMEL_SPI */ diff --git a/boards.cfg b/boards.cfg index e693105..72d82b2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -140,6 +140,7 @@ Active arm arm926ejs at91 ronetix pm9g45 Active arm arm926ejs at91 taskit stamp9g20 portuxg20 stamp9g20:AT91SAM9G20,PORTUXG20 Markus Hubig mhubig@imko.de Active arm arm926ejs at91 taskit stamp9g20 stamp9g20 stamp9g20:AT91SAM9G20 Markus Hubig mhubig@imko.de Active arm arm926ejs at91 siemens taurus axm taurus:AT91SAM9G20,MACH_TYPE=2068 Heiko Schocher hs@denx.de +Active arm arm926ejs at91 siemens corvus corvus corvus:AT91SAM9M10G45,SYS_USE_NANDFLASH Heiko Schocher hs@denx.de Active arm arm926ejs at91 siemens taurus taurus taurus:AT91SAM9G20,MACH_TYPE=2067 Heiko Schocher hs@denx.de Active arm arm926ejs davinci ait cam_enc_4xx cam_enc_4xx cam_enc_4xx Heiko Schocher hs@denx.de Active arm arm926ejs davinci Barix ipam390 ipam390 - Heiko Schocher hs@denx.de diff --git a/include/configs/corvus.h b/include/configs/corvus.h new file mode 100644 index 0000000..09513f9 --- /dev/null +++ b/include/configs/corvus.h @@ -0,0 +1,185 @@ +/* + * Common board functions for siemens AT91SAM9G45 based boards + * (C) Copyright 2013 Siemens AG + * + * Based on: + * U-Boot file: include/configs/at91sam9m10g45ek.h + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/hardware.h> + +#define MACH_TYPE_CORVUS 2066 + +/* + * Warning: changing CONFIG_SYS_TEXT_BASE requires + * adapting the initial boot program. + * Since the linker has to swallow that define, we must use a pure + * hex number here! + */ + +#define CONFIG_SYS_TEXT_BASE 0x73f00000 + +#define CONFIG_AT91_LEGACY +#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_AT91SAM9M10G45EK +#define CONFIG_AT91FAMILY + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +#define CONFIG_CMD_BOOTZ +#define CONFIG_OF_LIBFDT + +/* general purpose I/O */ +#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ +#define CONFIG_AT91_GPIO +#define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */ + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS + +/* LCD */ +#define CONFIG_LCD +#define LCD_BPP LCD_COLOR8 +#define CONFIG_LCD_LOGO +#undef LCD_TEST_PATTERN +#define CONFIG_LCD_INFO +#define CONFIG_LCD_INFO_BELOW_LOGO +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_ATMEL_LCD +#define CONFIG_ATMEL_LCD_RGB565 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +/* board specific(not enough SRAM) */ +#define CONFIG_AT91SAM9G45_LCD_BASE 0x73E00000 + +/* LED */ +#define CONFIG_AT91_LED +#define CONFIG_RED_LED AT91_PIN_PD31 /* this is the user1 led */ +#define CONFIG_GREEN_LED AT91_PIN_PD0 /* this is the user2 led */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_CMD_USB + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS6 +#define CONFIG_SYS_SDRAM_SIZE 0x08000000 + +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) + +/* No NOR flash */ +#define CONFIG_SYS_NO_FLASH + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +#define CONFIG_SYS_NAND_DBW_8 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC8 + +#endif + +/* Ethernet */ +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R + +/* USB */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_ATMEL +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 +#define CONFIG_DOS_PARTITION +#define CONFIG_USB_STORAGE + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +/* bootstrap + u-boot + env in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_OFFSET_REDUND 0x180000 +#define CONFIG_ENV_SIZE 0x20000 + +#define CONFIG_BOOTCOMMAND \ + "nand read 0x70000000 0x200000 0x300000;" \ + "bootm 0x70000000" +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk " \ + "mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro," \ + "256k(env),256k(env_redundant),256k(spare)," \ + "512k(dtb),6M(kernel)ro,-(rootfs) " \ + "root=/dev/mtdblock7 rw rootfstype=jffs2" + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + \ + 128*1024, 0x1000) + +#endif
Hi Heiko Schocher, Please add commit message.
+COBJS-y += board.o
- Board functions for Siemens CORVUS (AT91SAM9G45) based board
- Based on:
- U-Boot file: board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c
- /* Enable CS3 */
- csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA;
- writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);
&smc->cs[3].pulse);
- writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(4),
&smc->cs[3].cycle);
&smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOC, &pmc->pcer);
+} +#endif
- writel(1 << ATMEL_ID_PIODE, &pmc->pcer);
- at91_set_gpio_output(AT91_PIN_PD1, 0);
- at91_set_gpio_output(AT91_PIN_PD3, 0);
+} +#endif
- /* Enable clock */
- writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
- writel(pin_to_mask(AT91_PIN_PA15) |
&pioa->pudr);
Can we use GPIO API here?
Add timeout here.
&rstc->mr);
&pioa->puer);
- /* And the pins. */
+} +#endif
+#ifdef CONFIG_LCD
- vl_right_margin:1,
+vl_vsync_len:1,
- vl_upper_margin:40,
- vl_lower_margin:1,
- mmio : ATMEL_BASE_LCDC,
Change to use ".xxx = xxx", e.g: .vl_col = 480.
- at91_set_A_periph(AT91_PIN_PE6, 1); /* power up */
- at91_set_A_periph(AT91_PIN_PE6, 0); /* power down */
- at91_set_A_periph(AT91_PIN_PE0, 0); /* LCDDPWR */
- at91_set_A_periph(AT91_PIN_PE2, 0); /* LCDCC */
- at91_set_A_periph(AT91_PIN_PE3, 0); /* LCDVSYNC */
- at91_set_A_periph(AT91_PIN_PE4, 0); /* LCDHSYNC */
- at91_set_A_periph(AT91_PIN_PE5, 0); /* LCDDOTCK */
- at91_set_A_periph(AT91_PIN_PE7, 0); /* LCDD0 */
- at91_set_A_periph(AT91_PIN_PE8, 0); /* LCDD1 */
- at91_set_A_periph(AT91_PIN_PE9, 0); /* LCDD2 */
- at91_set_A_periph(AT91_PIN_PE10, 0); /* LCDD3 */
- at91_set_A_periph(AT91_PIN_PE11, 0); /* LCDD4 */
- at91_set_A_periph(AT91_PIN_PE12, 0); /* LCDD5 */
- at91_set_A_periph(AT91_PIN_PE13, 0); /* LCDD6 */
- at91_set_A_periph(AT91_PIN_PE14, 0); /* LCDD7 */
- at91_set_A_periph(AT91_PIN_PE15, 0); /* LCDD8 */
- at91_set_A_periph(AT91_PIN_PE16, 0); /* LCDD9 */
- at91_set_A_periph(AT91_PIN_PE17, 0); /* LCDD10 */
- at91_set_A_periph(AT91_PIN_PE18, 0); /* LCDD11 */
- at91_set_A_periph(AT91_PIN_PE19, 0); /* LCDD12 */
- at91_set_B_periph(AT91_PIN_PE20, 0); /* LCDD13 */
There should be A peripheral.
- at91_set_A_periph(AT91_PIN_PE21, 0); /* LCDD14 */
- at91_set_A_periph(AT91_PIN_PE22, 0); /* LCDD15 */
- at91_set_A_periph(AT91_PIN_PE23, 0); /* LCDD16 */
- at91_set_A_periph(AT91_PIN_PE24, 0); /* LCDD17 */
- at91_set_A_periph(AT91_PIN_PE25, 0); /* LCDD18 */
- at91_set_A_periph(AT91_PIN_PE26, 0); /* LCDD19 */
- at91_set_A_periph(AT91_PIN_PE27, 0); /* LCDD20 */
- at91_set_B_periph(AT91_PIN_PE28, 0); /* LCDD21 */
Ditto.
- at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */
- at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */
- writel(1 << ATMEL_ID_LCDC, &pmc->pcer);
- gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE;
- ulong dram_size, nand_size;
- int i;
- char temp[32];
- lcd_printf("%s\n", U_BOOT_VERSION);
- lcd_printf("(C) 2009 Siemens SBT\n");
Remove the "(C)".
- lcd_printf("www.sbt.siemens.com\n");
- lcd_printf("%s CPU at %s MHz\n",
ATMEL_CPU_NAME,
- dram_size = 0;
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++)
- nand_size = 0;
- for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++)
- lcd_printf(" %ld MB SDRAM, %ld MB NAND\n",
dram_size >> 20,
nand_size >> 20);
- console_init_f();
Remove it.
- /* arch number of corvus-Board */
- gd->bd->bi_arch_number = MACH_TYPE_CORVUS;
move to board related configuration file.
s/adress/address
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; +
- board_early_init_f();
- corvus_nand_hw_init();
- at91_spi0_hw_init(1 << 0);
- at91_spi0_hw_init(1 << 4);
- corvus_macb_hw_init();
- corvus_lcd_hw_init();
- at91sam9m10g45ek_usb_hw_init();
- eth_init(gd->bd);
Please remove this, more information: --->8--- commit 6bb46790178d111161a487cbd847dd2dba37ca24 Author: Ben Warren biggerbadderben@gmail.com Date: Tue Jun 1 11:55:42 2010 -0700
Write MAC address automatically on MACB-based boards
Also, remove all calls to eth_init() in boards that use MACB ---8<---
+} +#endif
- int rc = 0;
+#ifdef CONFIG_MACB
- rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x00);
- return rc;
- return bus == 0 && cs < 2;
- switch (slave->cs) {
- case 1:
break;
- case 0:
- default:
break;
- case 1:
break;
- case 0:
- default:
break;
- Common board functions for siemens AT91SAM9G45 based boards
- Based on:
- U-Boot file: include/configs/at91sam9m10g45ek.h
- hex number here!
No need this define.
No where define it, remove it.
- BOOTP options
- (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
Does this work on your board?
Ditto.
- "nand read 0x70000000 0x200000 0x300000;" \
- "bootm 0x70000000"
128*1024, 0x1000)
Hi Heiko,
+COBJS-y += board.o
- Based on:
- /* Enable CS3 */
&smc->cs[3].setup);
&smc->cs[3].pulse);
&smc->cs[3].cycle);
&smc->cs[3].mode);
+} +#endif
+} +#endif
&pioa->pudr);
Add timeout here.
&rstc->mr);
&pioa->puer);
+} +#endif
+#ifdef CONFIG_LCD
+vl_vsync_len:1,
Ditto.
- int i;
- char temp[32];
Remove the "(C)".
ATMEL_CPU_NAME,
- dram_size = 0;
- nand_size = 0;
dram_size >> 20,
nand_size >> 20);
- console_init_f();
Remove it.
s/adress/address
Why call board_early_init_f() here? Isn't it called bby generic board code in the init_sequence_f[] when CONFIG_BOARD_EARLY_INIT_F is defined?
Isn't SPI required for dataflash? Consider rearrange the ifdiffery here.
- eth_init(gd->bd);
Write MAC address automatically on MACB-based boards Also, remove all calls to eth_init() in boards that use MACB
---8<---
+} +#endif
- int rc = 0;
+#ifdef CONFIG_MACB
- return rc;
I think this is not required, should be catched by garbage collector.
+#include <spi.h>
- case 1:
break;
- case 0:
- default:
break;
- case 1:
break;
- case 0:
- default:
break;
- Based on:
remove some of the new lines here.
- hex number here!
Is'nt the RAM placed @0x20000000 for this devices? Ah got it, The sam9m10 has DDR1 @CS0 and DDR0 @CS6
The ATMEL_LEGACY is required for dataflash, please consider using the generic mtd sf stuff instead.
Would you mind to use the generic gpio led stuff instead?
- BOOTP options
;) good catch ...
Ditto.
nand read ${laodaddr} kernel ?
When using mtdparts in u-boot ... just my 2¢
128*1024, 0x1000)
Best regards
Andreas Bießmann
Hello Andreas,
Am 29.10.2013 11:01, schrieb Andreas Bießmann:
Hi Heiko,
Signed-off-by: Boris Schmidtboris.schmidt@siemens.com Reviewed-by: Heiko Schocherhs@denx.de Cc: Andreas Bießmannandreas.devel@googlemail.com
- console_init_f();
Remove it.
s/adress/address
removed.
rearranged.
- int rc = 0;
+#ifdef CONFIG_MACB
- return rc;
removed this ifdef
- Based on:
Done.
- hex number here!
Yep.
Ok, think about that ...
You mean ./drivers/misc/gpio_led.c ?
I check this.
;) good catch ...
Fixed.
Ditto.
You mean: nand read ${loadaddr} kernel ;-)
bye, Heiko
Hello Heiko,
<snip>
This legacy stuff is really a mess ... hopefully I get the gpio thing cleaned up for 2014.01 and completely removed for the follow-up release.
I mean the STATUS_LED thing (first part in README.LED). There is the taskit stamp9g20 board which uses it already (in connection with the at91 specific colour_LED thing)
<snip>
I do ;)
By, Andreas
Andreas Bießmann
Bo Shen
Bo Shen
Heiko Schocher
