[U-Boot] [Uboot][PATCH] drivers: spi: macronix: Add MX66L51235L data
Add support for macronix "MX66L51235L" flash device.
Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- drivers/mtd/spi/macronix.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/macronix.c b/drivers/mtd/spi/macronix.c index 70435eb..5a528c3 100644 --- a/drivers/mtd/spi/macronix.c +++ b/drivers/mtd/spi/macronix.c @@ -61,6 +61,11 @@ static const struct macronix_spi_flash_params macronix_spi_flash_table[] = { .nr_blocks = 256, .name = "MX25L12855E", }, + { + .idcode = 0x201a, + .nr_blocks = 512, + .name = "MX66L51235L", + }, };
struct spi_flash *spi_flash_probe_macronix(struct spi_slave *spi, u8 *idcode)
Hi
.idcode = 0x201a,
.nr_blocks = 512,
Can you check the similar patch http://patchwork.ozlabs.org/patch/262928/
Please confirm about nr_blocks? Also have u tested with latest spi_flash code, since ur part is 64MB must require a BAR to access entire memory.? http://patchwork.ozlabs.org/patch/262929/
Let me know for any concerns.
-- Thanks, Jagan.
Hi Sourav,
Can you test this macronix part w.r.t latest code base on u-boot-spi.git with master-probe branch. Please let me know about any issues/concerns.
On Tue, Aug 27, 2013 at 2:48 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi
.idcode = 0x201a,
.nr_blocks = 512,
-- Thanks, Jagan.
On Thursday 03 October 2013 09:19 PM, Jagan Teki wrote:
Hi Sourav,
Regarding the number of blocks, it should be 1024 only.
I will do other testing asap and let you know. This particular flash is on another SOC so I will send that SOC specific qspi data after testing it with the subject patch.
On Tue, Aug 27, 2013 at 2:48 PM, Jagan Tekijagannadh.teki@gmail.com wrote:
Hi
Signed-off-by: Sourav Poddarsourav.poddar@ti.com
.idcode = 0x201a,
.nr_blocks = 512,
-- Thanks, Jagan.
Hi Sourav,
OK, thanks. Please use u-boot-spi.git master branch.
Hi
.idcode = 0x201a,
.nr_blocks = 512,
-- Thanks, Jagan.
Jagan Teki
Sourav Poddar
