[U-Boot] [PATCH] mmc: uniphier-sd: fix Kconfig dependency
Some MMC drivers describe operations with the DM_MMC_OPS form, but there are still several drivers with older implementation. We can not compile drivers from different groups at the same time because the core framework is shared with #ifdef CONFIG_DM_MMC_OPS.
Every driver should have "depends on DM_MMC_OPS" (or !DM_MMC_OPS) explicitly to express which framework it is based on. This will avoid enabling drivers with incompatible interface at the same time. It is incorrect to make a driver "select DM_MMC_OPS".
While we are here, add "depends on OF_CONTROL" as well because this driver can be configured only by Device Tree.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/mmc/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index ff4344f..75b6ba1 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -107,8 +107,8 @@ config ROCKCHIP_SDHCI config MMC_UNIPHIER bool "UniPhier SD/MMC Host Controller support" depends on ARCH_UNIPHIER - depends on BLK - select DM_MMC_OPS + depends on BLK && DM_MMC_OPS + depends on OF_CONTROL help This selects support for the SD/MMC Host Controller on UniPhier SoCs.
Applied on u-boot-mmc. Thanks!
Best Regards, Jaehoon Chung
- depends on BLK
- select DM_MMC_OPS
- depends on BLK && DM_MMC_OPS
- depends on OF_CONTROL help This selects support for the SD/MMC Host Controller on UniPhier SoCs.
Jaehoon Chung
Masahiro Yamada
