[U-Boot] [PATCH] ppc/85xx: Clean up immap_85xx.h
* Converted all white space to tabs * Converted all types to u8/u16/u32 * Reduce lines to fit in 80 columns * Renamed MPC85xx_{Q,B}MAN -> FSL_CORENET_{Q,B}MAN
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/asm-ppc/immap_85xx.h | 3175 +++++++++++++++++++++--------------------- 1 files changed, 1586 insertions(+), 1589 deletions(-)
diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index 100dfe1..4194295 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -17,197 +17,191 @@ #include <asm/fsl_lbc.h>
typedef struct ccsr_local { - u32 ccsrbarh; /* 0x0 - Control Configuration Status Registers Base Address Register High */ - u32 ccsrbarl; /* 0x4 - Control Configuration Status Registers Base Address Register Low */ - u32 ccsrar; /* 0x8 - Configuration, Control, and Status Attribute Register */ + u32 ccsrbarh; /* CCSR Base Addr High */ + u32 ccsrbarl; /* CCSR Base Addr Low */ + u32 ccsrar; /* CCSR Attr */ #define CCSRAR_C 0x80000000 /* Commit */ u8 res1[4]; - u32 altcbarh; /* 0x10 - Alternate Configuration Base Address Register High */ - u32 altcbarl; /* 0x14 - Alternate Configuration Base Address Register Low */ - u32 altcar; /* 0x18 - Alternate Configuration Attribute Register */ + u32 altcbarh; /* Alternate Configuration Base Addr High */ + u32 altcbarl; /* Alternate Configuration Base Addr Low */ + u32 altcar; /* Alternate Configuration Attr */ u8 res2[4]; - u32 bstrh; /* 0x20 - Boot space translation register high */ - u32 bstrl; /* 0x24 - Boot space translation register Low */ - u32 bstrar; /* 0x28 - Boot space translation attributes register */ + u32 bstrh; /* Boot space translation high */ + u32 bstrl; /* Boot space translation Low */ + u32 bstrar; /* Boot space translation attributes */ u8 res3[0xbd4]; struct { - u32 lawbarh; /* 0xc00 + n * 0x10 - LAW0 base address register high */ - u32 lawbarl; /* 0xc04 + n * 0x10 - LAW0 base address register low */ - u32 lawar; /* 0xc08 + n * 0x10 - LAW0 attributes register */ + u32 lawbarh; /* LAWn base addr high */ + u32 lawbarl; /* LAWn base addr low */ + u32 lawar; /* LAWn attributes */ u8 res4[4]; } law[32]; u8 res35[0x204]; } ccsr_local_t;
-/* - * Local-Access Registers and ECM Registers(0x0000-0x2000) - */ +/* Local-Access Registers & ECM Registers */ typedef struct ccsr_local_ecm { - uint ccsrbar; /* 0x0 - Control Configuration Status Registers Base Address Register */ - char res1[4]; - uint altcbar; /* 0x8 - Alternate Configuration Base Address Register */ - char res2[4]; - uint altcar; /* 0x10 - Alternate Configuration Attribute Register */ - char res3[12]; - uint bptr; /* 0x20 - Boot Page Translation Register */ - char res4[3044]; - uint lawbar0; /* 0xc08 - Local Access Window 0 Base Address Register */ - char res5[4]; - uint lawar0; /* 0xc10 - Local Access Window 0 Attributes Register */ - char res6[20]; - uint lawbar1; /* 0xc28 - Local Access Window 1 Base Address Register */ - char res7[4]; - uint lawar1; /* 0xc30 - Local Access Window 1 Attributes Register */ - char res8[20]; - uint lawbar2; /* 0xc48 - Local Access Window 2 Base Address Register */ - char res9[4]; - uint lawar2; /* 0xc50 - Local Access Window 2 Attributes Register */ - char res10[20]; - uint lawbar3; /* 0xc68 - Local Access Window 3 Base Address Register */ - char res11[4]; - uint lawar3; /* 0xc70 - Local Access Window 3 Attributes Register */ - char res12[20]; - uint lawbar4; /* 0xc88 - Local Access Window 4 Base Address Register */ - char res13[4]; - uint lawar4; /* 0xc90 - Local Access Window 4 Attributes Register */ - char res14[20]; - uint lawbar5; /* 0xca8 - Local Access Window 5 Base Address Register */ - char res15[4]; - uint lawar5; /* 0xcb0 - Local Access Window 5 Attributes Register */ - char res16[20]; - uint lawbar6; /* 0xcc8 - Local Access Window 6 Base Address Register */ - char res17[4]; - uint lawar6; /* 0xcd0 - Local Access Window 6 Attributes Register */ - char res18[20]; - uint lawbar7; /* 0xce8 - Local Access Window 7 Base Address Register */ - char res19[4]; - uint lawar7; /* 0xcf0 - Local Access Window 7 Attributes Register */ - char res19_8a[20]; - uint lawbar8; /* 0xd08 - Local Access Window 8 Base Address Register */ - char res19_8b[4]; - uint lawar8; /* 0xd10 - Local Access Window 8 Attributes Register */ - char res19_9a[20]; - uint lawbar9; /* 0xd28 - Local Access Window 9 Base Address Register */ - char res19_9b[4]; - uint lawar9; /* 0xd30 - Local Access Window 9 Attributes Register */ - char res19_10a[20]; - uint lawbar10; /* 0xd48 - Local Access Window 10 Base Address Register */ - char res19_10b[4]; - uint lawar10; /* 0xd50 - Local Access Window 10 Attributes Register */ - char res19_11a[20]; - uint lawbar11; /* 0xd68 - Local Access Window 11 Base Address Register */ - char res19_11b[4]; - uint lawar11; /* 0xd70 - Local Access Window 11 Attributes Register */ - char res20[652]; - uint eebacr; /* 0x1000 - ECM CCB Address Configuration Register */ - char res21[12]; - uint eebpcr; /* 0x1010 - ECM CCB Port Configuration Register */ - char res22[3564]; - uint eedr; /* 0x1e00 - ECM Error Detect Register */ - char res23[4]; - uint eeer; /* 0x1e08 - ECM Error Enable Register */ - uint eeatr; /* 0x1e0c - ECM Error Attributes Capture Register */ - uint eeadr; /* 0x1e10 - ECM Error Address Capture Register */ - char res24[492]; + u32 ccsrbar; /* CCSR Base Addr */ + u8 res1[4]; + u32 altcbar; /* Alternate Configuration Base Addr */ + u8 res2[4]; + u32 altcar; /* Alternate Configuration Attr */ + u8 res3[12]; + u32 bptr; /* Boot Page Translation */ + u8 res4[3044]; + u32 lawbar0; /* Local Access Window 0 Base Addr */ + u8 res5[4]; + u32 lawar0; /* Local Access Window 0 Attrs */ + u8 res6[20]; + u32 lawbar1; /* Local Access Window 1 Base Addr */ + u8 res7[4]; + u32 lawar1; /* Local Access Window 1 Attrs */ + u8 res8[20]; + u32 lawbar2; /* Local Access Window 2 Base Addr */ + u8 res9[4]; + u32 lawar2; /* Local Access Window 2 Attrs */ + u8 res10[20]; + u32 lawbar3; /* Local Access Window 3 Base Addr */ + u8 res11[4]; + u32 lawar3; /* Local Access Window 3 Attrs */ + u8 res12[20]; + u32 lawbar4; /* Local Access Window 4 Base Addr */ + u8 res13[4]; + u32 lawar4; /* Local Access Window 4 Attrs */ + u8 res14[20]; + u32 lawbar5; /* Local Access Window 5 Base Addr */ + u8 res15[4]; + u32 lawar5; /* Local Access Window 5 Attrs */ + u8 res16[20]; + u32 lawbar6; /* Local Access Window 6 Base Addr */ + u8 res17[4]; + u32 lawar6; /* Local Access Window 6 Attrs */ + u8 res18[20]; + u32 lawbar7; /* Local Access Window 7 Base Addr */ + u8 res19[4]; + u32 lawar7; /* Local Access Window 7 Attrs */ + u8 res19_8a[20]; + u32 lawbar8; /* Local Access Window 8 Base Addr */ + u8 res19_8b[4]; + u32 lawar8; /* Local Access Window 8 Attrs */ + u8 res19_9a[20]; + u32 lawbar9; /* Local Access Window 9 Base Addr */ + u8 res19_9b[4]; + u32 lawar9; /* Local Access Window 9 Attrs */ + u8 res19_10a[20]; + u32 lawbar10; /* Local Access Window 10 Base Addr */ + u8 res19_10b[4]; + u32 lawar10; /* Local Access Window 10 Attrs */ + u8 res19_11a[20]; + u32 lawbar11; /* Local Access Window 11 Base Addr */ + u8 res19_11b[4]; + u32 lawar11; /* Local Access Window 11 Attrs */ + u8 res20[652]; + u32 eebacr; /* ECM CCB Addr Configuration */ + u8 res21[12]; + u32 eebpcr; /* ECM CCB Port Configuration */ + u8 res22[3564]; + u32 eedr; /* ECM Error Detect */ + u8 res23[4]; + u32 eeer; /* ECM Error Enable */ + u32 eeatr; /* ECM Error Attrs Capture */ + u32 eeadr; /* ECM Error Addr Capture */ + u8 res24[492]; } ccsr_local_ecm_t;
-/* - * DDR memory controller registers(0x2000-0x3000) - */ +/* DDR memory controller registers */ typedef struct ccsr_ddr { - uint cs0_bnds; /* 0x2000 - DDR Chip Select 0 Memory Bounds */ - char res1[4]; - uint cs1_bnds; /* 0x2008 - DDR Chip Select 1 Memory Bounds */ - char res2[4]; - uint cs2_bnds; /* 0x2010 - DDR Chip Select 2 Memory Bounds */ - char res3[4]; - uint cs3_bnds; /* 0x2018 - DDR Chip Select 3 Memory Bounds */ - char res4[100]; - uint cs0_config; /* 0x2080 - DDR Chip Select Configuration */ - uint cs1_config; /* 0x2084 - DDR Chip Select Configuration */ - uint cs2_config; /* 0x2088 - DDR Chip Select Configuration */ - uint cs3_config; /* 0x208c - DDR Chip Select Configuration */ - char res4a[48]; - uint cs0_config_2; /* 0x20c0 - DDR Chip Select Configuration 2 */ - uint cs1_config_2; /* 0x20c4 - DDR Chip Select Configuration 2 */ - uint cs2_config_2; /* 0x20c8 - DDR Chip Select Configuration 2 */ - uint cs3_config_2; /* 0x20cc - DDR Chip Select Configuration 2 */ - char res5[48]; - uint timing_cfg_3; /* 0x2100 - DDR SDRAM Timing Configuration Register 3 */ - uint timing_cfg_0; /* 0x2104 - DDR SDRAM Timing Configuration Register 0 */ - uint timing_cfg_1; /* 0x2108 - DDR SDRAM Timing Configuration Register 1 */ - uint timing_cfg_2; /* 0x210c - DDR SDRAM Timing Configuration Register 2 */ - uint sdram_cfg; /* 0x2110 - DDR SDRAM Control Configuration */ - uint sdram_cfg_2; /* 0x2114 - DDR SDRAM Control Configuration 2 */ - uint sdram_mode; /* 0x2118 - DDR SDRAM Mode Configuration */ - uint sdram_mode_2; /* 0x211c - DDR SDRAM Mode Configuration 2*/ - uint sdram_md_cntl; /* 0x2120 - DDR SDRAM Mode Control */ - uint sdram_interval; /* 0x2124 - DDR SDRAM Interval Configuration */ - uint sdram_data_init; /* 0x2128 - DDR SDRAM Data initialization */ - char res6[4]; - uint sdram_clk_cntl; /* 0x2130 - DDR SDRAM Clock Control */ - char res7[20]; - uint init_addr; /* 0x2148 - DDR training initialization address */ - uint init_ext_addr; /* 0x214C - DDR training initialization extended address */ - char res8_1[16]; - uint timing_cfg_4; /* 0x2160 - DDR SDRAM Timing Configuration Register 4 */ - uint timing_cfg_5; /* 0x2164 - DDR SDRAM Timing Configuration Register 5 */ - char reg8_1a[8]; - uint ddr_zq_cntl; /* 0x2170 - DDR ZQ calibration control*/ - uint ddr_wrlvl_cntl; /* 0x2174 - DDR write leveling control*/ - char reg8_1aa[4]; - uint ddr_sr_cntr; /* 0x217C - DDR self refresh counter */ - uint ddr_sdram_rcw_1; /* 0x2180 - DDR Register Control Words 1 */ - uint ddr_sdram_rcw_2; /* 0x2184 - DDR Register Control Words 2 */ - char res8_1b[2456]; - uint ddr_dsr1; /* 0x2B20 - DDR Debug Status Register 1 */ - uint ddr_dsr2; /* 0x2B24 - DDR Debug Status Register 2 */ - uint ddr_cdr1; /* 0x2B28 - DDR Control Driver Register 1 */ - uint ddr_cdr2; /* 0x2B2C - DDR Control Driver Register 2 */ - char res8_1c[200]; - uint ip_rev1; /* 0x2BF8 - DDR IP Block Revision 1 */ - uint ip_rev2; /* 0x2BFC - DDR IP Block Revision 2 */ - char res8_2[512]; - uint data_err_inject_hi; /* 0x2e00 - DDR Memory Data Path Error Injection Mask High */ - uint data_err_inject_lo; /* 0x2e04 - DDR Memory Data Path Error Injection Mask Low */ - uint ecc_err_inject; /* 0x2e08 - DDR Memory Data Path Error Injection Mask ECC */ - char res9[20]; - uint capture_data_hi; /* 0x2e20 - DDR Memory Data Path Read Capture High */ - uint capture_data_lo; /* 0x2e24 - DDR Memory Data Path Read Capture Low */ - uint capture_ecc; /* 0x2e28 - DDR Memory Data Path Read Capture ECC */ - char res10[20]; - uint err_detect; /* 0x2e40 - DDR Memory Error Detect */ - uint err_disable; /* 0x2e44 - DDR Memory Error Disable */ - uint err_int_en; /* 0x2e48 - DDR */ - uint capture_attributes; /* 0x2e4c - DDR Memory Error Attributes Capture */ - uint capture_address; /* 0x2e50 - DDR Memory Error Address Capture */ - uint capture_ext_address; /* 0x2e54 - DDR Memory Error Extended Address Capture */ - uint err_sbe; /* 0x2e58 - DDR Memory Single-Bit ECC Error Management */ - char res11[164]; - uint debug_1; /* 0x2f00 */ - uint debug_2; - uint debug_3; - uint debug_4; - uint debug_5; - uint debug_6; - uint debug_7; - uint debug_8; - uint debug_9; - uint debug_10; - uint debug_11; - uint debug_12; - uint debug_13; /* +0xF30 */ - uint debug_14; - uint debug_15; - uint debug_16; - uint debug_17; - uint debug_18; /* +0xF44 */ - char res12[184]; + u32 cs0_bnds; /* Chip Select 0 Memory Bounds */ + u8 res1[4]; + u32 cs1_bnds; /* Chip Select 1 Memory Bounds */ + u8 res2[4]; + u32 cs2_bnds; /* Chip Select 2 Memory Bounds */ + u8 res3[4]; + u32 cs3_bnds; /* Chip Select 3 Memory Bounds */ + u8 res4[100]; + u32 cs0_config; /* Chip Select Configuration */ + u32 cs1_config; /* Chip Select Configuration */ + u32 cs2_config; /* Chip Select Configuration */ + u32 cs3_config; /* Chip Select Configuration */ + u8 res4a[48]; + u32 cs0_config_2; /* Chip Select Configuration 2 */ + u32 cs1_config_2; /* Chip Select Configuration 2 */ + u32 cs2_config_2; /* Chip Select Configuration 2 */ + u32 cs3_config_2; /* Chip Select Configuration 2 */ + u8 res5[48]; + u32 timing_cfg_3; /* SDRAM Timing Configuration 3 */ + u32 timing_cfg_0; /* SDRAM Timing Configuration 0 */ + u32 timing_cfg_1; /* SDRAM Timing Configuration 1 */ + u32 timing_cfg_2; /* SDRAM Timing Configuration 2 */ + u32 sdram_cfg; /* SDRAM Control Configuration */ + u32 sdram_cfg_2; /* SDRAM Control Configuration 2 */ + u32 sdram_mode; /* SDRAM Mode Configuration */ + u32 sdram_mode_2; /* SDRAM Mode Configuration 2 */ + u32 sdram_md_cntl; /* SDRAM Mode Control */ + u32 sdram_interval; /* SDRAM Interval Configuration */ + u32 sdram_data_init; /* SDRAM Data initialization */ + u8 res6[4]; + u32 sdram_clk_cntl; /* SDRAM Clock Control */ + u8 res7[20]; + u32 init_addr; /* training init addr */ + u32 init_ext_addr; /* training init extended addr */ + u8 res8_1[16]; + u32 timing_cfg_4; /* SDRAM Timing Configuration 4 */ + u32 timing_cfg_5; /* SDRAM Timing Configuration 5 */ + u8 reg8_1a[8]; + u32 ddr_zq_cntl; /* ZQ calibration control*/ + u32 ddr_wrlvl_cntl; /* write leveling control*/ + u8 reg8_1aa[4]; + u32 ddr_sr_cntr; /* self refresh counter */ + u32 ddr_sdram_rcw_1; /* Control Words 1 */ + u32 ddr_sdram_rcw_2; /* Control Words 2 */ + u8 res8_1b[2456]; + u32 ddr_dsr1; /* Debug Status 1 */ + u32 ddr_dsr2; /* Debug Status 2 */ + u32 ddr_cdr1; /* Control Driver 1 */ + u32 ddr_cdr2; /* Control Driver 2 */ + u8 res8_1c[200]; + u32 ip_rev1; /* IP Block Revision 1 */ + u32 ip_rev2; /* IP Block Revision 2 */ + u8 res8_2[512]; + u32 data_err_inject_hi; /* Data Path Err Injection Mask High */ + u32 data_err_inject_lo; /* Data Path Err Injection Mask Low */ + u32 ecc_err_inject; /* Data Path Err Injection Mask ECC */ + u8 res9[20]; + u32 capture_data_hi; /* Data Path Read Capture High */ + u32 capture_data_lo; /* Data Path Read Capture Low */ + u32 capture_ecc; /* Data Path Read Capture ECC */ + u8 res10[20]; + u32 err_detect; /* Error Detect */ + u32 err_disable; /* Error Disable */ + u32 err_int_en; + u32 capture_attributes; /* Error Attrs Capture */ + u32 capture_address; /* Error Addr Capture */ + u32 capture_ext_address; /* Error Extended Addr Capture */ + u32 err_sbe; /* Single-Bit ECC Error Management */ + u8 res11[164]; + u32 debug_1; + u32 debug_2; + u32 debug_3; + u32 debug_4; + u32 debug_5; + u32 debug_6; + u32 debug_7; + u32 debug_8; + u32 debug_9; + u32 debug_10; + u32 debug_11; + u32 debug_12; + u32 debug_13; + u32 debug_14; + u32 debug_15; + u32 debug_16; + u32 debug_17; + u32 debug_18; + u8 res12[184]; } ccsr_ddr_t;
-/* - * I2C Registers(0x3000-0x4000) - */ +/* I2C Registers */ typedef struct ccsr_i2c { struct fsl_i2c i2c[1]; u8 res[4096 - 1 * sizeof(struct fsl_i2c)]; @@ -217,176 +211,167 @@ typedef struct ccsr_i2c { || defined(CONFIG_MPC8541) \ || defined(CONFIG_MPC8548) \ || defined(CONFIG_MPC8555) -/* DUART Registers(0x4000-0x5000) */ +/* DUART Registers */ typedef struct ccsr_duart { - char res1[1280]; - u_char urbr1_uthr1_udlb1;/* 0x4500 - URBR1, UTHR1, UDLB1 with the same address offset of 0x04500 */ - u_char uier1_udmb1; /* 0x4501 - UIER1, UDMB1 with the same address offset of 0x04501 */ - u_char uiir1_ufcr1_uafr1;/* 0x4502 - UIIR1, UFCR1, UAFR1 with the same address offset of 0x04502 */ - u_char ulcr1; /* 0x4503 - UART1 Line Control Register */ - u_char umcr1; /* 0x4504 - UART1 Modem Control Register */ - u_char ulsr1; /* 0x4505 - UART1 Line Status Register */ - u_char umsr1; /* 0x4506 - UART1 Modem Status Register */ - u_char uscr1; /* 0x4507 - UART1 Scratch Register */ - char res2[8]; - u_char udsr1; /* 0x4510 - UART1 DMA Status Register */ - char res3[239]; - u_char urbr2_uthr2_udlb2;/* 0x4600 - URBR2, UTHR2, UDLB2 with the same address offset of 0x04600 */ - u_char uier2_udmb2; /* 0x4601 - UIER2, UDMB2 with the same address offset of 0x04601 */ - u_char uiir2_ufcr2_uafr2;/* 0x4602 - UIIR2, UFCR2, UAFR2 with the same address offset of 0x04602 */ - u_char ulcr2; /* 0x4603 - UART2 Line Control Register */ - u_char umcr2; /* 0x4604 - UART2 Modem Control Register */ - u_char ulsr2; /* 0x4605 - UART2 Line Status Register */ - u_char umsr2; /* 0x4606 - UART2 Modem Status Register */ - u_char uscr2; /* 0x4607 - UART2 Scratch Register */ - char res4[8]; - u_char udsr2; /* 0x4610 - UART2 DMA Status Register */ - char res5[2543]; + u8 res1[1280]; +/* URBR1, UTHR1, UDLB1 with the same addr */ + u8 urbr1_uthr1_udlb1; +/* UIER1, UDMB1 with the same addr01 */ + u8 uier1_udmb1; +/* UIIR1, UFCR1, UAFR1 with the same addr */ + u8 uiir1_ufcr1_uafr1; + u8 ulcr1; /* UART1 Line Control */ + u8 umcr1; /* UART1 Modem Control */ + u8 ulsr1; /* UART1 Line Status */ + u8 umsr1; /* UART1 Modem Status */ + u8 uscr1; /* UART1 Scratch */ + u8 res2[8]; + u8 udsr1; /* UART1 DMA Status */ + u8 res3[239]; +/* URBR2, UTHR2, UDLB2 with the same addr */ + u8 urbr2_uthr2_udlb2; +/* UIER2, UDMB2 with the same addr */ + u8 uier2_udmb2; +/* UIIR2, UFCR2, UAFR2 with the same addr */ + u8 uiir2_ufcr2_uafr2; + u8 ulcr2; /* UART2 Line Control */ + u8 umcr2; /* UART2 Modem Control */ + u8 ulsr2; /* UART2 Line Status */ + u8 umsr2; /* UART2 Modem Status */ + u8 uscr2; /* UART2 Scratch */ + u8 res4[8]; + u8 udsr2; /* UART2 DMA Status */ + u8 res5[2543]; } ccsr_duart_t; #else /* MPC8560 uses UART on its CPM */ typedef struct ccsr_duart { - char res[4096]; + u8 res[4096]; } ccsr_duart_t; #endif
-/* Local Bus Controller Registers(0x5000-0x6000) */ -/* Omitting OCeaN(0x6000) and Reserved(0x7000) block */ - +/* Local Bus Controller Registers */ typedef struct ccsr_lbc { - uint br0; /* 0x5000 - LBC Base Register 0 */ - uint or0; /* 0x5004 - LBC Options Register 0 */ - uint br1; /* 0x5008 - LBC Base Register 1 */ - uint or1; /* 0x500c - LBC Options Register 1 */ - uint br2; /* 0x5010 - LBC Base Register 2 */ - uint or2; /* 0x5014 - LBC Options Register 2 */ - uint br3; /* 0x5018 - LBC Base Register 3 */ - uint or3; /* 0x501c - LBC Options Register 3 */ - uint br4; /* 0x5020 - LBC Base Register 4 */ - uint or4; /* 0x5024 - LBC Options Register 4 */ - uint br5; /* 0x5028 - LBC Base Register 5 */ - uint or5; /* 0x502c - LBC Options Register 5 */ - uint br6; /* 0x5030 - LBC Base Register 6 */ - uint or6; /* 0x5034 - LBC Options Register 6 */ - uint br7; /* 0x5038 - LBC Base Register 7 */ - uint or7; /* 0x503c - LBC Options Register 7 */ - char res1[40]; - uint mar; /* 0x5068 - LBC UPM Address Register */ - char res2[4]; - uint mamr; /* 0x5070 - LBC UPMA Mode Register */ - uint mbmr; /* 0x5074 - LBC UPMB Mode Register */ - uint mcmr; /* 0x5078 - LBC UPMC Mode Register */ - char res3[8]; - uint mrtpr; /* 0x5084 - LBC Memory Refresh Timer Prescaler Register */ - uint mdr; /* 0x5088 - LBC UPM Data Register */ - char res4[8]; - uint lsdmr; /* 0x5094 - LBC SDRAM Mode Register */ - char res5[8]; - uint lurt; /* 0x50a0 - LBC UPM Refresh Timer */ - uint lsrt; /* 0x50a4 - LBC SDRAM Refresh Timer */ - char res6[8]; - uint ltesr; /* 0x50b0 - LBC Transfer Error Status Register */ - uint ltedr; /* 0x50b4 - LBC Transfer Error Disable Register */ - uint lteir; /* 0x50b8 - LBC Transfer Error Interrupt Register */ - uint lteatr; /* 0x50bc - LBC Transfer Error Attributes Register */ - uint ltear; /* 0x50c0 - LBC Transfer Error Address Register */ - char res7[12]; - uint lbcr; /* 0x50d0 - LBC Configuration Register */ - uint lcrr; /* 0x50d4 - LBC Clock Ratio Register */ - char res8[3880]; + u32 br0; /* LBC Base 0 */ + u32 or0; /* LBC Options 0 */ + u32 br1; /* LBC Base 1 */ + u32 or1; /* LBC Options 1 */ + u32 br2; /* LBC Base 2 */ + u32 or2; /* LBC Options 2 */ + u32 br3; /* LBC Base 3 */ + u32 or3; /* LBC Options 3 */ + u32 br4; /* LBC Base 4 */ + u32 or4; /* LBC Options 4 */ + u32 br5; /* LBC Base 5 */ + u32 or5; /* LBC Options 5 */ + u32 br6; /* LBC Base 6 */ + u32 or6; /* LBC Options 6 */ + u32 br7; /* LBC Base 7 */ + u32 or7; /* LBC Options 7 */ + u8 res1[40]; + u32 mar; /* LBC UPM Addr */ + u8 res2[4]; + u32 mamr; /* LBC UPMA Mode */ + u32 mbmr; /* LBC UPMB Mode */ + u32 mcmr; /* LBC UPMC Mode */ + u8 res3[8]; + u32 mrtpr; /* LBC Memory Refresh Timer Prescaler */ + u32 mdr; /* LBC UPM Data */ + u8 res4[8]; + u32 lsdmr; /* LBC SDRAM Mode */ + u8 res5[8]; + u32 lurt; /* LBC UPM Refresh Timer */ + u32 lsrt; /* LBC SDRAM Refresh Timer */ + u8 res6[8]; + u32 ltesr; /* LBC Transfer Error Status */ + u32 ltedr; /* LBC Transfer Error Disable */ + u32 lteir; /* LBC Transfer Error IRQ */ + u32 lteatr; /* LBC Transfer Error Attrs */ + u32 ltear; /* LBC Transfer Error Addr */ + u8 res7[12]; + u32 lbcr; /* LBC Configuration */ + u32 lcrr; /* LBC Clock Ratio */ + u8 res8[3880]; } ccsr_lbc_t;
-/* - * eSPI Registers(0x7000-0x8000) - */ +/* eSPI Registers */ typedef struct ccsr_espi { - uint mode; /* 0x00 - eSPI mode register */ - uint event; /* 0x04 - eSPI event register */ - uint mask; /* 0x08 - eSPI mask register */ - uint com; /* 0x0c - eSPI command register */ - uint tx; /* 0x10 - eSPI transmit FIFO access register */ - uint rx; /* 0x14 - eSPI receive FIFO access register */ - char res1[8]; /* reserved */ - uint csmode[4]; /* 0x20 - 0x2c: sSPI CS0/1/2/3 mode register */ - char res2[4048]; /* fill up to 0x1000 */ + u32 mode; /* eSPI mode */ + u32 event; /* eSPI event */ + u32 mask; /* eSPI mask */ + u32 com; /* eSPI command */ + u32 tx; /* eSPI transmit FIFO access */ + u32 rx; /* eSPI receive FIFO access */ + u8 res1[8]; /* reserved */ + u32 csmode[4]; /* 0x2c: sSPI CS0/1/2/3 mode */ + u8 res2[4048]; /* fill up to 0x1000 */ } ccsr_espi_t;
-/* - * PCI Registers(0x8000-0x9000) - */ +/* PCI Registers */ typedef struct ccsr_pcix { - uint cfg_addr; /* 0x8000 - PCIX Configuration Address Register */ - uint cfg_data; /* 0x8004 - PCIX Configuration Data Register */ - uint int_ack; /* 0x8008 - PCIX Interrupt Acknowledge Register */ - char res1[3060]; - uint potar0; /* 0x8c00 - PCIX Outbound Transaction Address Register 0 */ - uint potear0; /* 0x8c04 - PCIX Outbound Translation Extended Address Register 0 */ - uint powbar0; /* 0x8c08 - PCIX Outbound Window Base Address Register 0 */ - uint powbear0; /* 0x8c0c - PCIX Outbound Window Base Extended Address Register 0 */ - uint powar0; /* 0x8c10 - PCIX Outbound Window Attributes Register 0 */ - char res2[12]; - uint potar1; /* 0x8c20 - PCIX Outbound Transaction Address Register 1 */ - uint potear1; /* 0x8c24 - PCIX Outbound Translation Extended Address Register 1 */ - uint powbar1; /* 0x8c28 - PCIX Outbound Window Base Address Register 1 */ - uint powbear1; /* 0x8c2c - PCIX Outbound Window Base Extended Address Register 1 */ - uint powar1; /* 0x8c30 - PCIX Outbound Window Attributes Register 1 */ - char res3[12]; - uint potar2; /* 0x8c40 - PCIX Outbound Transaction Address Register 2 */ - uint potear2; /* 0x8c44 - PCIX Outbound Translation Extended Address Register 2 */ - uint powbar2; /* 0x8c48 - PCIX Outbound Window Base Address Register 2 */ - uint powbear2; /* 0x8c4c - PCIX Outbound Window Base Extended Address Register 2 */ - uint powar2; /* 0x8c50 - PCIX Outbound Window Attributes Register 2 */ - char res4[12]; - uint potar3; /* 0x8c60 - PCIX Outbound Transaction Address Register 3 */ - uint potear3; /* 0x8c64 - PCIX Outbound Translation Extended Address Register 3 */ - uint powbar3; /* 0x8c68 - PCIX Outbound Window Base Address Register 3 */ - uint powbear3; /* 0x8c6c - PCIX Outbound Window Base Extended Address Register 3 */ - uint powar3; /* 0x8c70 - PCIX Outbound Window Attributes Register 3 */ - char res5[12]; - uint potar4; /* 0x8c80 - PCIX Outbound Transaction Address Register 4 */ - uint potear4; /* 0x8c84 - PCIX Outbound Translation Extended Address Register 4 */ - uint powbar4; /* 0x8c88 - PCIX Outbound Window Base Address Register 4 */ - uint powbear4; /* 0x8c8c - PCIX Outbound Window Base Extended Address Register 4 */ - uint powar4; /* 0x8c90 - PCIX Outbound Window Attributes Register 4 */ - char res6[268]; - uint pitar3; /* 0x8da0 - PCIX Inbound Translation Address Register 3 */ - uint pitear3; /* 0x8da4 - PCIX Inbound Translation Extended Address Register 3 */ - uint piwbar3; /* 0x8da8 - PCIX Inbound Window Base Address Register 3 */ - uint piwbear3; /* 0x8dac - PCIX Inbound Window Base Extended Address Register 3 */ - uint piwar3; /* 0x8db0 - PCIX Inbound Window Attributes Register 3 */ - char res7[12]; - uint pitar2; /* 0x8dc0 - PCIX Inbound Translation Address Register 2 */ - uint pitear2; /* 0x8dc4 - PCIX Inbound Translation Extended Address Register 2 */ - uint piwbar2; /* 0x8dc8 - PCIX Inbound Window Base Address Register 2 */ - uint piwbear2; /* 0x8dcc - PCIX Inbound Window Base Extended Address Register 2 */ - uint piwar2; /* 0x8dd0 - PCIX Inbound Window Attributes Register 2 */ - char res8[12]; - uint pitar1; /* 0x8de0 - PCIX Inbound Translation Address Register 1 */ - uint pitear1; /* 0x8de4 - PCIX Inbound Translation Extended Address Register 1 */ - uint piwbar1; /* 0x8de8 - PCIX Inbound Window Base Address Register 1 */ - char res9[4]; - uint piwar1; /* 0x8df0 - PCIX Inbound Window Attributes Register 1 */ - char res10[12]; - uint pedr; /* 0x8e00 - PCIX Error Detect Register */ - uint pecdr; /* 0x8e04 - PCIX Error Capture Disable Register */ - uint peer; /* 0x8e08 - PCIX Error Enable Register */ - uint peattrcr; /* 0x8e0c - PCIX Error Attributes Capture Register */ - uint peaddrcr; /* 0x8e10 - PCIX Error Address Capture Register */ - uint peextaddrcr; /* 0x8e14 - PCIX Error Extended Address Capture Register */ - uint pedlcr; /* 0x8e18 - PCIX Error Data Low Capture Register */ - uint pedhcr; /* 0x8e1c - PCIX Error Error Data High Capture Register */ - uint gas_timr; /* 0x8e20 - PCIX Gasket Timer Register */ - char res11[476]; + u32 cfg_addr; /* PCIX Configuration Addr */ + u32 cfg_data; /* PCIX Configuration Data */ + u32 int_ack; /* PCIX IRQ Acknowledge */ + u8 res1[3060]; + u32 potar0; /* PCIX Outbound Transaction Addr 0 */ + u32 potear0; /* PCIX Outbound Translation Extended Addr 0 */ + u32 powbar0; /* PCIX Outbound Window Base Addr 0 */ + u32 powbear0; /* PCIX Outbound Window Base Extended Addr 0 */ + u32 powar0; /* PCIX Outbound Window Attrs 0 */ + u8 res2[12]; + u32 potar1; /* PCIX Outbound Transaction Addr 1 */ + u32 potear1; /* PCIX Outbound Translation Extended Addr 1 */ + u32 powbar1; /* PCIX Outbound Window Base Addr 1 */ + u32 powbear1; /* PCIX Outbound Window Base Extended Addr 1 */ + u32 powar1; /* PCIX Outbound Window Attrs 1 */ + u8 res3[12]; + u32 potar2; /* PCIX Outbound Transaction Addr 2 */ + u32 potear2; /* PCIX Outbound Translation Extended Addr 2 */ + u32 powbar2; /* PCIX Outbound Window Base Addr 2 */ + u32 powbear2; /* PCIX Outbound Window Base Extended Addr 2 */ + u32 powar2; /* PCIX Outbound Window Attrs 2 */ + u8 res4[12]; + u32 potar3; /* PCIX Outbound Transaction Addr 3 */ + u32 potear3; /* PCIX Outbound Translation Extended Addr 3 */ + u32 powbar3; /* PCIX Outbound Window Base Addr 3 */ + u32 powbear3; /* PCIX Outbound Window Base Extended Addr 3 */ + u32 powar3; /* PCIX Outbound Window Attrs 3 */ + u8 res5[12]; + u32 potar4; /* PCIX Outbound Transaction Addr 4 */ + u32 potear4; /* PCIX Outbound Translation Extended Addr 4 */ + u32 powbar4; /* PCIX Outbound Window Base Addr 4 */ + u32 powbear4; /* PCIX Outbound Window Base Extended Addr 4 */ + u32 powar4; /* PCIX Outbound Window Attrs 4 */ + u8 res6[268]; + u32 pitar3; /* PCIX Inbound Translation Addr 3 */ + u32 pitear3; /* PCIX Inbound Translation Extended Addr 3 */ + u32 piwbar3; /* PCIX Inbound Window Base Addr 3 */ + u32 piwbear3; /* PCIX Inbound Window Base Extended Addr 3 */ + u32 piwar3; /* PCIX Inbound Window Attrs 3 */ + u8 res7[12]; + u32 pitar2; /* PCIX Inbound Translation Addr 2 */ + u32 pitear2; /* PCIX Inbound Translation Extended Addr 2 */ + u32 piwbar2; /* PCIX Inbound Window Base Addr 2 */ + u32 piwbear2; /* PCIX Inbound Window Base Extended Addr 2 */ + u32 piwar2; /* PCIX Inbound Window Attrs 2 */ + u8 res8[12]; + u32 pitar1; /* PCIX Inbound Translation Addr 1 */ + u32 pitear1; /* PCIX Inbound Translation Extended Addr 1 */ + u32 piwbar1; /* PCIX Inbound Window Base Addr 1 */ + u8 res9[4]; + u32 piwar1; /* PCIX Inbound Window Attrs 1 */ + u8 res10[12]; + u32 pedr; /* PCIX Error Detect */ + u32 pecdr; /* PCIX Error Capture Disable */ + u32 peer; /* PCIX Error Enable */ + u32 peattrcr; /* PCIX Error Attrs Capture */ + u32 peaddrcr; /* PCIX Error Addr Capture */ + u32 peextaddrcr; /* PCIX Error Extended Addr Capture */ + u32 pedlcr; /* PCIX Error Data Low Capture */ + u32 pedhcr; /* PCIX Error Error Data High Capture */ + u32 gas_timr; /* PCIX Gasket Timer */ + u8 res11[476]; } ccsr_pcix_t;
-typedef struct ccsr_gpio { - uint gpdir; - uint gpodr; - uint gpdat; - uint gpier; - uint gpimr; - uint gpicr; -} ccsr_gpio_t; - #define PCIX_COMMAND 0x62 #define POWAR_EN 0x80000000 #define POWAR_IO_READ 0x00080000 @@ -403,49 +388,55 @@ typedef struct ccsr_gpio { #define PIWAR_WRITE_SNOOP 0x00005000 #define PIWAR_MEM_2G 0x0000001e
+typedef struct ccsr_gpio { + u32 gpdir; + u32 gpodr; + u32 gpdat; + u32 gpier; + u32 gpimr; + u32 gpicr; +} ccsr_gpio_t;
-/* - * L2 Cache Registers(0x2_0000-0x2_1000) - */ +/* L2 Cache Registers */ typedef struct ccsr_l2cache { - uint l2ctl; /* 0x20000 - L2 configuration register 0 */ - char res1[12]; - uint l2cewar0; /* 0x20010 - L2 cache external write address register 0 */ - char res2[4]; - uint l2cewcr0; /* 0x20018 - L2 cache external write control register 0 */ - char res3[4]; - uint l2cewar1; /* 0x20020 - L2 cache external write address register 1 */ - char res4[4]; - uint l2cewcr1; /* 0x20028 - L2 cache external write control register 1 */ - char res5[4]; - uint l2cewar2; /* 0x20030 - L2 cache external write address register 2 */ - char res6[4]; - uint l2cewcr2; /* 0x20038 - L2 cache external write control register 2 */ - char res7[4]; - uint l2cewar3; /* 0x20040 - L2 cache external write address register 3 */ - char res8[4]; - uint l2cewcr3; /* 0x20048 - L2 cache external write control register 3 */ - char res9[180]; - uint l2srbar0; /* 0x20100 - L2 memory-mapped SRAM base address register 0 */ - char res10[4]; - uint l2srbar1; /* 0x20108 - L2 memory-mapped SRAM base address register 1 */ - char res11[3316]; - uint l2errinjhi; /* 0x20e00 - L2 error injection mask high register */ - uint l2errinjlo; /* 0x20e04 - L2 error injection mask low register */ - uint l2errinjctl; /* 0x20e08 - L2 error injection tag/ECC control register */ - char res12[20]; - uint l2captdatahi; /* 0x20e20 - L2 error data high capture register */ - uint l2captdatalo; /* 0x20e24 - L2 error data low capture register */ - uint l2captecc; /* 0x20e28 - L2 error ECC capture register */ - char res13[20]; - uint l2errdet; /* 0x20e40 - L2 error detect register */ - uint l2errdis; /* 0x20e44 - L2 error disable register */ - uint l2errinten; /* 0x20e48 - L2 error interrupt enable register */ - uint l2errattr; /* 0x20e4c - L2 error attributes capture register */ - uint l2erraddr; /* 0x20e50 - L2 error address capture register */ - char res14[4]; - uint l2errctl; /* 0x20e58 - L2 error control register */ - char res15[420]; + u32 l2ctl; /* L2 configuration 0 */ + u8 res1[12]; + u32 l2cewar0; /* L2 cache external write addr 0 */ + u8 res2[4]; + u32 l2cewcr0; /* L2 cache external write control 0 */ + u8 res3[4]; + u32 l2cewar1; /* L2 cache external write addr 1 */ + u8 res4[4]; + u32 l2cewcr1; /* L2 cache external write control 1 */ + u8 res5[4]; + u32 l2cewar2; /* L2 cache external write addr 2 */ + u8 res6[4]; + u32 l2cewcr2; /* L2 cache external write control 2 */ + u8 res7[4]; + u32 l2cewar3; /* L2 cache external write addr 3 */ + u8 res8[4]; + u32 l2cewcr3; /* L2 cache external write control 3 */ + u8 res9[180]; + u32 l2srbar0; /* L2 memory-mapped SRAM base addr 0 */ + u8 res10[4]; + u32 l2srbar1; /* L2 memory-mapped SRAM base addr 1 */ + u8 res11[3316]; + u32 l2errinjhi; /* L2 error injection mask high */ + u32 l2errinjlo; /* L2 error injection mask low */ + u32 l2errinjctl; /* L2 error injection tag/ECC control */ + u8 res12[20]; + u32 l2captdatahi; /* L2 error data high capture */ + u32 l2captdatalo; /* L2 error data low capture */ + u32 l2captecc; /* L2 error ECC capture */ + u8 res13[20]; + u32 l2errdet; /* L2 error detect */ + u32 l2errdis; /* L2 error disable */ + u32 l2errinten; /* L2 error interrupt enable */ + u32 l2errattr; /* L2 error attributes capture */ + u32 l2erraddr; /* L2 error addr capture */ + u8 res14[4]; + u32 l2errctl; /* L2 error control */ + u8 res15[420]; } ccsr_l2cache_t;
#define MPC85xx_L2CTL_L2E 0x80000000 @@ -453,919 +444,910 @@ typedef struct ccsr_l2cache { #define MPC85xx_L2ERRDIS_MBECC 0x00000008 #define MPC85xx_L2ERRDIS_SBECC 0x00000004
-/* - * DMA Registers(0x2_1000-0x2_2000) - */ +/* DMA Registers */ typedef struct ccsr_dma { - char res1[256]; + u8 res1[256]; struct fsl_dma dma[4]; - uint dgsr; /* 0x21300 - DMA General Status Register */ - char res2[11516]; + u32 dgsr; /* DMA General Status */ + u8 res2[11516]; } ccsr_dma_t;
-/* - * tsec1 tsec2: 24000-26000 - */ +/* tsec */ typedef struct ccsr_tsec { - char res1[16]; - uint ievent; /* 0x24010 - Interrupt Event Register */ - uint imask; /* 0x24014 - Interrupt Mask Register */ - uint edis; /* 0x24018 - Error Disabled Register */ - char res2[4]; - uint ecntrl; /* 0x24020 - Ethernet Control Register */ - uint minflr; /* 0x24024 - Minimum Frame Length Register */ - uint ptv; /* 0x24028 - Pause Time Value Register */ - uint dmactrl; /* 0x2402c - DMA Control Register */ - uint tbipa; /* 0x24030 - TBI PHY Address Register */ - char res3[88]; - uint fifo_tx_thr; /* 0x2408c - FIFO transmit threshold register */ - char res4[8]; - uint fifo_tx_starve; /* 0x24098 - FIFO transmit starve register */ - uint fifo_tx_starve_shutoff; /* 0x2409c - FIFO transmit starve shutoff register */ - char res5[96]; - uint tctrl; /* 0x24100 - Transmit Control Register */ - uint tstat; /* 0x24104 - Transmit Status Register */ - char res6[4]; - uint tbdlen; /* 0x2410c - Transmit Buffer Descriptor Data Length Register */ - char res7[16]; - uint ctbptrh; /* 0x24120 - Current Transmit Buffer Descriptor Pointer High Register */ - uint ctbptr; /* 0x24124 - Current Transmit Buffer Descriptor Pointer Register */ - char res8[88]; - uint tbptrh; /* 0x24180 - Transmit Buffer Descriptor Pointer High Register */ - uint tbptr; /* 0x24184 - Transmit Buffer Descriptor Pointer Low Register */ - char res9[120]; - uint tbaseh; /* 0x24200 - Transmit Descriptor Base Address High Register */ - uint tbase; /* 0x24204 - Transmit Descriptor Base Address Register */ - char res10[168]; - uint ostbd; /* 0x242b0 - Out-of-Sequence Transmit Buffer Descriptor Register */ - uint ostbdp; /* 0x242b4 - Out-of-Sequence Transmit Data Buffer Pointer Register */ - uint os32tbdp; /* 0x242b8 - Out-of-Sequence 32 Bytes Transmit Data Buffer Pointer Low Register */ - uint os32iptrh; /* 0x242bc - Out-of-Sequence 32 Bytes Transmit Insert Pointer High Register */ - uint os32iptrl; /* 0x242c0 - Out-of-Sequence 32 Bytes Transmit Insert Pointer Low Register */ - uint os32tbdr; /* 0x242c4 - Out-of-Sequence 32 Bytes Transmit Reserved Register */ - uint os32iil; /* 0x242c8 - Out-of-Sequence 32 Bytes Transmit Insert Index/Length Register */ - char res11[52]; - uint rctrl; /* 0x24300 - Receive Control Register */ - uint rstat; /* 0x24304 - Receive Status Register */ - char res12[4]; - uint rbdlen; /* 0x2430c - RxBD Data Length Register */ - char res13[16]; - uint crbptrh; /* 0x24320 - Current Receive Buffer Descriptor Pointer High */ - uint crbptr; /* 0x24324 - Current Receive Buffer Descriptor Pointer */ - char res14[24]; - uint mrblr; /* 0x24340 - Maximum Receive Buffer Length Register */ - uint mrblr2r3; /* 0x24344 - Maximum Receive Buffer Length R2R3 Register */ - char res15[56]; - uint rbptrh; /* 0x24380 - Receive Buffer Descriptor Pointer High 0 */ - uint rbptr; /* 0x24384 - Receive Buffer Descriptor Pointer */ - uint rbptrh1; /* 0x24388 - Receive Buffer Descriptor Pointer High 1 */ - uint rbptrl1; /* 0x2438c - Receive Buffer Descriptor Pointer Low 1 */ - uint rbptrh2; /* 0x24390 - Receive Buffer Descriptor Pointer High 2 */ - uint rbptrl2; /* 0x24394 - Receive Buffer Descriptor Pointer Low 2 */ - uint rbptrh3; /* 0x24398 - Receive Buffer Descriptor Pointer High 3 */ - uint rbptrl3; /* 0x2439c - Receive Buffer Descriptor Pointer Low 3 */ - char res16[96]; - uint rbaseh; /* 0x24400 - Receive Descriptor Base Address High 0 */ - uint rbase; /* 0x24404 - Receive Descriptor Base Address */ - uint rbaseh1; /* 0x24408 - Receive Descriptor Base Address High 1 */ - uint rbasel1; /* 0x2440c - Receive Descriptor Base Address Low 1 */ - uint rbaseh2; /* 0x24410 - Receive Descriptor Base Address High 2 */ - uint rbasel2; /* 0x24414 - Receive Descriptor Base Address Low 2 */ - uint rbaseh3; /* 0x24418 - Receive Descriptor Base Address High 3 */ - uint rbasel3; /* 0x2441c - Receive Descriptor Base Address Low 3 */ - char res17[224]; - uint maccfg1; /* 0x24500 - MAC Configuration 1 Register */ - uint maccfg2; /* 0x24504 - MAC Configuration 2 Register */ - uint ipgifg; /* 0x24508 - Inter Packet Gap/Inter Frame Gap Register */ - uint hafdup; /* 0x2450c - Half Duplex Register */ - uint maxfrm; /* 0x24510 - Maximum Frame Length Register */ - char res18[12]; - uint miimcfg; /* 0x24520 - MII Management Configuration Register */ - uint miimcom; /* 0x24524 - MII Management Command Register */ - uint miimadd; /* 0x24528 - MII Management Address Register */ - uint miimcon; /* 0x2452c - MII Management Control Register */ - uint miimstat; /* 0x24530 - MII Management Status Register */ - uint miimind; /* 0x24534 - MII Management Indicator Register */ - char res19[4]; - uint ifstat; /* 0x2453c - Interface Status Register */ - uint macstnaddr1; /* 0x24540 - Station Address Part 1 Register */ - uint macstnaddr2; /* 0x24544 - Station Address Part 2 Register */ - char res20[312]; - uint tr64; /* 0x24680 - Transmit and Receive 64-byte Frame Counter */ - uint tr127; /* 0x24684 - Transmit and Receive 65-127 byte Frame Counter */ - uint tr255; /* 0x24688 - Transmit and Receive 128-255 byte Frame Counter */ - uint tr511; /* 0x2468c - Transmit and Receive 256-511 byte Frame Counter */ - uint tr1k; /* 0x24690 - Transmit and Receive 512-1023 byte Frame Counter */ - uint trmax; /* 0x24694 - Transmit and Receive 1024-1518 byte Frame Counter */ - uint trmgv; /* 0x24698 - Transmit and Receive 1519-1522 byte Good VLAN Frame */ - uint rbyt; /* 0x2469c - Receive Byte Counter */ - uint rpkt; /* 0x246a0 - Receive Packet Counter */ - uint rfcs; /* 0x246a4 - Receive FCS Error Counter */ - uint rmca; /* 0x246a8 - Receive Multicast Packet Counter */ - uint rbca; /* 0x246ac - Receive Broadcast Packet Counter */ - uint rxcf; /* 0x246b0 - Receive Control Frame Packet Counter */ - uint rxpf; /* 0x246b4 - Receive Pause Frame Packet Counter */ - uint rxuo; /* 0x246b8 - Receive Unknown OP Code Counter */ - uint raln; /* 0x246bc - Receive Alignment Error Counter */ - uint rflr; /* 0x246c0 - Receive Frame Length Error Counter */ - uint rcde; /* 0x246c4 - Receive Code Error Counter */ - uint rcse; /* 0x246c8 - Receive Carrier Sense Error Counter */ - uint rund; /* 0x246cc - Receive Undersize Packet Counter */ - uint rovr; /* 0x246d0 - Receive Oversize Packet Counter */ - uint rfrg; /* 0x246d4 - Receive Fragments Counter */ - uint rjbr; /* 0x246d8 - Receive Jabber Counter */ - uint rdrp; /* 0x246dc - Receive Drop Counter */ - uint tbyt; /* 0x246e0 - Transmit Byte Counter Counter */ - uint tpkt; /* 0x246e4 - Transmit Packet Counter */ - uint tmca; /* 0x246e8 - Transmit Multicast Packet Counter */ - uint tbca; /* 0x246ec - Transmit Broadcast Packet Counter */ - uint txpf; /* 0x246f0 - Transmit Pause Control Frame Counter */ - uint tdfr; /* 0x246f4 - Transmit Deferral Packet Counter */ - uint tedf; /* 0x246f8 - Transmit Excessive Deferral Packet Counter */ - uint tscl; /* 0x246fc - Transmit Single Collision Packet Counter */ - uint tmcl; /* 0x24700 - Transmit Multiple Collision Packet Counter */ - uint tlcl; /* 0x24704 - Transmit Late Collision Packet Counter */ - uint txcl; /* 0x24708 - Transmit Excessive Collision Packet Counter */ - uint tncl; /* 0x2470c - Transmit Total Collision Counter */ - char res21[4]; - uint tdrp; /* 0x24714 - Transmit Drop Frame Counter */ - uint tjbr; /* 0x24718 - Transmit Jabber Frame Counter */ - uint tfcs; /* 0x2471c - Transmit FCS Error Counter */ - uint txcf; /* 0x24720 - Transmit Control Frame Counter */ - uint tovr; /* 0x24724 - Transmit Oversize Frame Counter */ - uint tund; /* 0x24728 - Transmit Undersize Frame Counter */ - uint tfrg; /* 0x2472c - Transmit Fragments Frame Counter */ - uint car1; /* 0x24730 - Carry Register One */ - uint car2; /* 0x24734 - Carry Register Two */ - uint cam1; /* 0x24738 - Carry Mask Register One */ - uint cam2; /* 0x2473c - Carry Mask Register Two */ - char res22[192]; - uint iaddr0; /* 0x24800 - Indivdual address register 0 */ - uint iaddr1; /* 0x24804 - Indivdual address register 1 */ - uint iaddr2; /* 0x24808 - Indivdual address register 2 */ - uint iaddr3; /* 0x2480c - Indivdual address register 3 */ - uint iaddr4; /* 0x24810 - Indivdual address register 4 */ - uint iaddr5; /* 0x24814 - Indivdual address register 5 */ - uint iaddr6; /* 0x24818 - Indivdual address register 6 */ - uint iaddr7; /* 0x2481c - Indivdual address register 7 */ - char res23[96]; - uint gaddr0; /* 0x24880 - Global address register 0 */ - uint gaddr1; /* 0x24884 - Global address register 1 */ - uint gaddr2; /* 0x24888 - Global address register 2 */ - uint gaddr3; /* 0x2488c - Global address register 3 */ - uint gaddr4; /* 0x24890 - Global address register 4 */ - uint gaddr5; /* 0x24894 - Global address register 5 */ - uint gaddr6; /* 0x24898 - Global address register 6 */ - uint gaddr7; /* 0x2489c - Global address register 7 */ - char res24[96]; - uint pmd0; /* 0x24900 - Pattern Match Data Register */ - char res25[4]; - uint pmask0; /* 0x24908 - Pattern Mask Register */ - char res26[4]; - uint pcntrl0; /* 0x24910 - Pattern Match Control Register */ - char res27[4]; - uint pattrb0; /* 0x24918 - Pattern Match Attributes Register */ - uint pattrbeli0; /* 0x2491c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd1; /* 0x24920 - Pattern Match Data Register */ - char res28[4]; - uint pmask1; /* 0x24928 - Pattern Mask Register */ - char res29[4]; - uint pcntrl1; /* 0x24930 - Pattern Match Control Register */ - char res30[4]; - uint pattrb1; /* 0x24938 - Pattern Match Attributes Register */ - uint pattrbeli1; /* 0x2493c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd2; /* 0x24940 - Pattern Match Data Register */ - char res31[4]; - uint pmask2; /* 0x24948 - Pattern Mask Register */ - char res32[4]; - uint pcntrl2; /* 0x24950 - Pattern Match Control Register */ - char res33[4]; - uint pattrb2; /* 0x24958 - Pattern Match Attributes Register */ - uint pattrbeli2; /* 0x2495c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd3; /* 0x24960 - Pattern Match Data Register */ - char res34[4]; - uint pmask3; /* 0x24968 - Pattern Mask Register */ - char res35[4]; - uint pcntrl3; /* 0x24970 - Pattern Match Control Register */ - char res36[4]; - uint pattrb3; /* 0x24978 - Pattern Match Attributes Register */ - uint pattrbeli3; /* 0x2497c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd4; /* 0x24980 - Pattern Match Data Register */ - char res37[4]; - uint pmask4; /* 0x24988 - Pattern Mask Register */ - char res38[4]; - uint pcntrl4; /* 0x24990 - Pattern Match Control Register */ - char res39[4]; - uint pattrb4; /* 0x24998 - Pattern Match Attributes Register */ - uint pattrbeli4; /* 0x2499c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd5; /* 0x249a0 - Pattern Match Data Register */ - char res40[4]; - uint pmask5; /* 0x249a8 - Pattern Mask Register */ - char res41[4]; - uint pcntrl5; /* 0x249b0 - Pattern Match Control Register */ - char res42[4]; - uint pattrb5; /* 0x249b8 - Pattern Match Attributes Register */ - uint pattrbeli5; /* 0x249bc - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd6; /* 0x249c0 - Pattern Match Data Register */ - char res43[4]; - uint pmask6; /* 0x249c8 - Pattern Mask Register */ - char res44[4]; - uint pcntrl6; /* 0x249d0 - Pattern Match Control Register */ - char res45[4]; - uint pattrb6; /* 0x249d8 - Pattern Match Attributes Register */ - uint pattrbeli6; /* 0x249dc - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd7; /* 0x249e0 - Pattern Match Data Register */ - char res46[4]; - uint pmask7; /* 0x249e8 - Pattern Mask Register */ - char res47[4]; - uint pcntrl7; /* 0x249f0 - Pattern Match Control Register */ - char res48[4]; - uint pattrb7; /* 0x249f8 - Pattern Match Attributes Register */ - uint pattrbeli7; /* 0x249fc - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd8; /* 0x24a00 - Pattern Match Data Register */ - char res49[4]; - uint pmask8; /* 0x24a08 - Pattern Mask Register */ - char res50[4]; - uint pcntrl8; /* 0x24a10 - Pattern Match Control Register */ - char res51[4]; - uint pattrb8; /* 0x24a18 - Pattern Match Attributes Register */ - uint pattrbeli8; /* 0x24a1c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd9; /* 0x24a20 - Pattern Match Data Register */ - char res52[4]; - uint pmask9; /* 0x24a28 - Pattern Mask Register */ - char res53[4]; - uint pcntrl9; /* 0x24a30 - Pattern Match Control Register */ - char res54[4]; - uint pattrb9; /* 0x24a38 - Pattern Match Attributes Register */ - uint pattrbeli9; /* 0x24a3c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd10; /* 0x24a40 - Pattern Match Data Register */ - char res55[4]; - uint pmask10; /* 0x24a48 - Pattern Mask Register */ - char res56[4]; - uint pcntrl10; /* 0x24a50 - Pattern Match Control Register */ - char res57[4]; - uint pattrb10; /* 0x24a58 - Pattern Match Attributes Register */ - uint pattrbeli10; /* 0x24a5c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd11; /* 0x24a60 - Pattern Match Data Register */ - char res58[4]; - uint pmask11; /* 0x24a68 - Pattern Mask Register */ - char res59[4]; - uint pcntrl11; /* 0x24a70 - Pattern Match Control Register */ - char res60[4]; - uint pattrb11; /* 0x24a78 - Pattern Match Attributes Register */ - uint pattrbeli11; /* 0x24a7c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd12; /* 0x24a80 - Pattern Match Data Register */ - char res61[4]; - uint pmask12; /* 0x24a88 - Pattern Mask Register */ - char res62[4]; - uint pcntrl12; /* 0x24a90 - Pattern Match Control Register */ - char res63[4]; - uint pattrb12; /* 0x24a98 - Pattern Match Attributes Register */ - uint pattrbeli12; /* 0x24a9c - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd13; /* 0x24aa0 - Pattern Match Data Register */ - char res64[4]; - uint pmask13; /* 0x24aa8 - Pattern Mask Register */ - char res65[4]; - uint pcntrl13; /* 0x24ab0 - Pattern Match Control Register */ - char res66[4]; - uint pattrb13; /* 0x24ab8 - Pattern Match Attributes Register */ - uint pattrbeli13; /* 0x24abc - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd14; /* 0x24ac0 - Pattern Match Data Register */ - char res67[4]; - uint pmask14; /* 0x24ac8 - Pattern Mask Register */ - char res68[4]; - uint pcntrl14; /* 0x24ad0 - Pattern Match Control Register */ - char res69[4]; - uint pattrb14; /* 0x24ad8 - Pattern Match Attributes Register */ - uint pattrbeli14; /* 0x24adc - Pattern Match Attributes Extract Length and Extract Index Register */ - uint pmd15; /* 0x24ae0 - Pattern Match Data Register */ - char res70[4]; - uint pmask15; /* 0x24ae8 - Pattern Mask Register */ - char res71[4]; - uint pcntrl15; /* 0x24af0 - Pattern Match Control Register */ - char res72[4]; - uint pattrb15; /* 0x24af8 - Pattern Match Attributes Register */ - uint pattrbeli15; /* 0x24afc - Pattern Match Attributes Extract Length and Extract Index Register */ - char res73[248]; - uint attr; /* 0x24bf8 - Attributes Register */ - uint attreli; /* 0x24bfc - Attributes Extract Length and Extract Index Register */ - char res74[1024]; + u8 res1[16]; + u32 ievent; /* IRQ Event */ + u32 imask; /* IRQ Mask */ + u32 edis; /* Error Disabled */ + u8 res2[4]; + u32 ecntrl; /* Ethernet Control */ + u32 minflr; /* Minimum Frame Len */ + u32 ptv; /* Pause Time Value */ + u32 dmactrl; /* DMA Control */ + u32 tbipa; /* TBI PHY Addr */ + u8 res3[88]; + u32 fifo_tx_thr; /* FIFO transmit threshold */ + u8 res4[8]; + u32 fifo_tx_starve; /* FIFO transmit starve */ + u32 fifo_tx_starve_shutoff; /* FIFO transmit starve shutoff */ + u8 res5[96]; + u32 tctrl; /* TX Control */ + u32 tstat; /* TX Status */ + u8 res6[4]; + u32 tbdlen; /* TX Buffer Desc Data Len */ + u8 res7[16]; + u32 ctbptrh; /* Current TX Buffer Desc Ptr High */ + u32 ctbptr; /* Current TX Buffer Desc Ptr */ + u8 res8[88]; + u32 tbptrh; /* TX Buffer Desc Ptr High */ + u32 tbptr; /* TX Buffer Desc Ptr Low */ + u8 res9[120]; + u32 tbaseh; /* TX Desc Base Addr High */ + u32 tbase; /* TX Desc Base Addr */ + u8 res10[168]; + u32 ostbd; /* Out-of-Sequence(OOS) TX Buffer Desc */ + u32 ostbdp; /* OOS TX Data Buffer Ptr */ + u32 os32tbdp; /* OOS 32 Bytes TX Data Buffer Ptr Low */ + u32 os32iptrh; /* OOS 32 Bytes TX Insert Ptr High */ + u32 os32iptrl; /* OOS 32 Bytes TX Insert Ptr Low */ + u32 os32tbdr; /* OOS 32 Bytes TX Reserved */ + u32 os32iil; /* OOS 32 Bytes TX Insert Idx/Len */ + u8 res11[52]; + u32 rctrl; /* RX Control */ + u32 rstat; /* RX Status */ + u8 res12[4]; + u32 rbdlen; /* RxBD Data Len */ + u8 res13[16]; + u32 crbptrh; /* Current RX Buffer Desc Ptr High */ + u32 crbptr; /* Current RX Buffer Desc Ptr */ + u8 res14[24]; + u32 mrblr; /* Maximum RX Buffer Len */ + u32 mrblr2r3; /* Maximum RX Buffer Len R2R3 */ + u8 res15[56]; + u32 rbptrh; /* RX Buffer Desc Ptr High 0 */ + u32 rbptr; /* RX Buffer Desc Ptr */ + u32 rbptrh1; /* RX Buffer Desc Ptr High 1 */ + u32 rbptrl1; /* RX Buffer Desc Ptr Low 1 */ + u32 rbptrh2; /* RX Buffer Desc Ptr High 2 */ + u32 rbptrl2; /* RX Buffer Desc Ptr Low 2 */ + u32 rbptrh3; /* RX Buffer Desc Ptr High 3 */ + u32 rbptrl3; /* RX Buffer Desc Ptr Low 3 */ + u8 res16[96]; + u32 rbaseh; /* RX Desc Base Addr High 0 */ + u32 rbase; /* RX Desc Base Addr */ + u32 rbaseh1; /* RX Desc Base Addr High 1 */ + u32 rbasel1; /* RX Desc Base Addr Low 1 */ + u32 rbaseh2; /* RX Desc Base Addr High 2 */ + u32 rbasel2; /* RX Desc Base Addr Low 2 */ + u32 rbaseh3; /* RX Desc Base Addr High 3 */ + u32 rbasel3; /* RX Desc Base Addr Low 3 */ + u8 res17[224]; + u32 maccfg1; /* MAC Configuration 1 */ + u32 maccfg2; /* MAC Configuration 2 */ + u32 ipgifg; /* Inter Packet Gap/Inter Frame Gap */ + u32 hafdup; /* Half Duplex */ + u32 maxfrm; /* Maximum Frame Len */ + u8 res18[12]; + u32 miimcfg; /* MII Management Configuration */ + u32 miimcom; /* MII Management Cmd */ + u32 miimadd; /* MII Management Addr */ + u32 miimcon; /* MII Management Control */ + u32 miimstat; /* MII Management Status */ + u32 miimind; /* MII Management Indicator */ + u8 res19[4]; + u32 ifstat; /* Interface Status */ + u32 macstnaddr1; /* Station Addr Part 1 */ + u32 macstnaddr2; /* Station Addr Part 2 */ + u8 res20[312]; + u32 tr64; /* TX & RX 64-byte Frame Counter */ + u32 tr127; /* TX & RX 65-127 byte Frame Counter */ + u32 tr255; /* TX & RX 128-255 byte Frame Counter */ + u32 tr511; /* TX & RX 256-511 byte Frame Counter */ + u32 tr1k; /* TX & RX 512-1023 byte Frame Counter */ + u32 trmax; /* TX & RX 1024-1518 byte Frame Counter */ + u32 trmgv; /* TX & RX 1519-1522 byte Good VLAN Frame */ + u32 rbyt; /* RX Byte Counter */ + u32 rpkt; /* RX Packet Counter */ + u32 rfcs; /* RX FCS Error Counter */ + u32 rmca; /* RX Multicast Packet Counter */ + u32 rbca; /* RX Broadcast Packet Counter */ + u32 rxcf; /* RX Control Frame Packet Counter */ + u32 rxpf; /* RX Pause Frame Packet Counter */ + u32 rxuo; /* RX Unknown OP Code Counter */ + u32 raln; /* RX Alignment Error Counter */ + u32 rflr; /* RX Frame Len Error Counter */ + u32 rcde; /* RX Code Error Counter */ + u32 rcse; /* RX Carrier Sense Error Counter */ + u32 rund; /* RX Undersize Packet Counter */ + u32 rovr; /* RX Oversize Packet Counter */ + u32 rfrg; /* RX Fragments Counter */ + u32 rjbr; /* RX Jabber Counter */ + u32 rdrp; /* RX Drop Counter */ + u32 tbyt; /* TX Byte Counter Counter */ + u32 tpkt; /* TX Packet Counter */ + u32 tmca; /* TX Multicast Packet Counter */ + u32 tbca; /* TX Broadcast Packet Counter */ + u32 txpf; /* TX Pause Control Frame Counter */ + u32 tdfr; /* TX Deferral Packet Counter */ + u32 tedf; /* TX Excessive Deferral Packet Counter */ + u32 tscl; /* TX Single Collision Packet Counter */ + u32 tmcl; /* TX Multiple Collision Packet Counter */ + u32 tlcl; /* TX Late Collision Packet Counter */ + u32 txcl; /* TX Excessive Collision Packet Counter */ + u32 tncl; /* TX Total Collision Counter */ + u8 res21[4]; + u32 tdrp; /* TX Drop Frame Counter */ + u32 tjbr; /* TX Jabber Frame Counter */ + u32 tfcs; /* TX FCS Error Counter */ + u32 txcf; /* TX Control Frame Counter */ + u32 tovr; /* TX Oversize Frame Counter */ + u32 tund; /* TX Undersize Frame Counter */ + u32 tfrg; /* TX Fragments Frame Counter */ + u32 car1; /* Carry One */ + u32 car2; /* Carry Two */ + u32 cam1; /* Carry Mask One */ + u32 cam2; /* Carry Mask Two */ + u8 res22[192]; + u32 iaddr0; /* Indivdual addr 0 */ + u32 iaddr1; /* Indivdual addr 1 */ + u32 iaddr2; /* Indivdual addr 2 */ + u32 iaddr3; /* Indivdual addr 3 */ + u32 iaddr4; /* Indivdual addr 4 */ + u32 iaddr5; /* Indivdual addr 5 */ + u32 iaddr6; /* Indivdual addr 6 */ + u32 iaddr7; /* Indivdual addr 7 */ + u8 res23[96]; + u32 gaddr0; /* Global addr 0 */ + u32 gaddr1; /* Global addr 1 */ + u32 gaddr2; /* Global addr 2 */ + u32 gaddr3; /* Global addr 3 */ + u32 gaddr4; /* Global addr 4 */ + u32 gaddr5; /* Global addr 5 */ + u32 gaddr6; /* Global addr 6 */ + u32 gaddr7; /* Global addr 7 */ + u8 res24[96]; + u32 pmd0; /* Pattern Match Data */ + u8 res25[4]; + u32 pmask0; /* Pattern Mask */ + u8 res26[4]; + u32 pcntrl0; /* Pattern Match Control */ + u8 res27[4]; + u32 pattrb0; /* Pattern Match Attrs */ + u32 pattrbeli0; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd1; /* Pattern Match Data */ + u8 res28[4]; + u32 pmask1; /* Pattern Mask */ + u8 res29[4]; + u32 pcntrl1; /* Pattern Match Control */ + u8 res30[4]; + u32 pattrb1; /* Pattern Match Attrs */ + u32 pattrbeli1; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd2; /* Pattern Match Data */ + u8 res31[4]; + u32 pmask2; /* Pattern Mask */ + u8 res32[4]; + u32 pcntrl2; /* Pattern Match Control */ + u8 res33[4]; + u32 pattrb2; /* Pattern Match Attrs */ + u32 pattrbeli2; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd3; /* Pattern Match Data */ + u8 res34[4]; + u32 pmask3; /* Pattern Mask */ + u8 res35[4]; + u32 pcntrl3; /* Pattern Match Control */ + u8 res36[4]; + u32 pattrb3; /* Pattern Match Attrs */ + u32 pattrbeli3; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd4; /* Pattern Match Data */ + u8 res37[4]; + u32 pmask4; /* Pattern Mask */ + u8 res38[4]; + u32 pcntrl4; /* Pattern Match Control */ + u8 res39[4]; + u32 pattrb4; /* Pattern Match Attrs */ + u32 pattrbeli4; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd5; /* Pattern Match Data */ + u8 res40[4]; + u32 pmask5; /* Pattern Mask */ + u8 res41[4]; + u32 pcntrl5; /* Pattern Match Control */ + u8 res42[4]; + u32 pattrb5; /* Pattern Match Attrs */ + u32 pattrbeli5; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd6; /* Pattern Match Data */ + u8 res43[4]; + u32 pmask6; /* Pattern Mask */ + u8 res44[4]; + u32 pcntrl6; /* Pattern Match Control */ + u8 res45[4]; + u32 pattrb6; /* Pattern Match Attrs */ + u32 pattrbeli6; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd7; /* Pattern Match Data */ + u8 res46[4]; + u32 pmask7; /* Pattern Mask */ + u8 res47[4]; + u32 pcntrl7; /* Pattern Match Control */ + u8 res48[4]; + u32 pattrb7; /* Pattern Match Attrs */ + u32 pattrbeli7; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd8; /* Pattern Match Data */ + u8 res49[4]; + u32 pmask8; /* Pattern Mask */ + u8 res50[4]; + u32 pcntrl8; /* Pattern Match Control */ + u8 res51[4]; + u32 pattrb8; /* Pattern Match Attrs */ + u32 pattrbeli8; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd9; /* Pattern Match Data */ + u8 res52[4]; + u32 pmask9; /* Pattern Mask */ + u8 res53[4]; + u32 pcntrl9; /* Pattern Match Control */ + u8 res54[4]; + u32 pattrb9; /* Pattern Match Attrs */ + u32 pattrbeli9; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd10; /* Pattern Match Data */ + u8 res55[4]; + u32 pmask10; /* Pattern Mask */ + u8 res56[4]; + u32 pcntrl10; /* Pattern Match Control */ + u8 res57[4]; + u32 pattrb10; /* Pattern Match Attrs */ + u32 pattrbeli10; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd11; /* Pattern Match Data */ + u8 res58[4]; + u32 pmask11; /* Pattern Mask */ + u8 res59[4]; + u32 pcntrl11; /* Pattern Match Control */ + u8 res60[4]; + u32 pattrb11; /* Pattern Match Attrs */ + u32 pattrbeli11; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd12; /* Pattern Match Data */ + u8 res61[4]; + u32 pmask12; /* Pattern Mask */ + u8 res62[4]; + u32 pcntrl12; /* Pattern Match Control */ + u8 res63[4]; + u32 pattrb12; /* Pattern Match Attrs */ + u32 pattrbeli12; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd13; /* Pattern Match Data */ + u8 res64[4]; + u32 pmask13; /* Pattern Mask */ + u8 res65[4]; + u32 pcntrl13; /* Pattern Match Control */ + u8 res66[4]; + u32 pattrb13; /* Pattern Match Attrs */ + u32 pattrbeli13; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd14; /* Pattern Match Data */ + u8 res67[4]; + u32 pmask14; /* Pattern Mask */ + u8 res68[4]; + u32 pcntrl14; /* Pattern Match Control */ + u8 res69[4]; + u32 pattrb14; /* Pattern Match Attrs */ + u32 pattrbeli14; /* Pattern Match Attrs Extract Len & Idx */ + u32 pmd15; /* Pattern Match Data */ + u8 res70[4]; + u32 pmask15; /* Pattern Mask */ + u8 res71[4]; + u32 pcntrl15; /* Pattern Match Control */ + u8 res72[4]; + u32 pattrb15; /* Pattern Match Attrs */ + u32 pattrbeli15; /* Pattern Match Attrs Extract Len & Idx */ + u8 res73[248]; + u32 attr; /* Attrs */ + u32 attreli; /* Attrs Extract Len & Idx */ + u8 res74[1024]; } ccsr_tsec_t;
-/* - * PIC Registers(0x4_0000-0x8_0000) - */ +/* PIC Registers */ typedef struct ccsr_pic { - char res1[64]; /* 0x40000 */ - uint ipidr0; /* 0x40040 - Interprocessor Interrupt Dispatch Register 0 */ - char res2[12]; - uint ipidr1; /* 0x40050 - Interprocessor Interrupt Dispatch Register 1 */ - char res3[12]; - uint ipidr2; /* 0x40060 - Interprocessor Interrupt Dispatch Register 2 */ - char res4[12]; - uint ipidr3; /* 0x40070 - Interprocessor Interrupt Dispatch Register 3 */ - char res5[12]; - uint ctpr; /* 0x40080 - Current Task Priority Register */ - char res6[12]; - uint whoami; /* 0x40090 - Who Am I Register */ - char res7[12]; - uint iack; /* 0x400a0 - Interrupt Acknowledge Register */ - char res8[12]; - uint eoi; /* 0x400b0 - End Of Interrupt Register */ - char res9[3916]; - uint frr; /* 0x41000 - Feature Reporting Register */ - char res10[28]; - uint gcr; /* 0x41020 - Global Configuration Register */ -#define MPC85xx_PICGCR_RST 0x80000000 -#define MPC85xx_PICGCR_M 0x20000000 - char res11[92]; - uint vir; /* 0x41080 - Vendor Identification Register */ - char res12[12]; - uint pir; /* 0x41090 - Processor Initialization Register */ - char res13[12]; - uint ipivpr0; /* 0x410a0 - IPI Vector/Priority Register 0 */ - char res14[12]; - uint ipivpr1; /* 0x410b0 - IPI Vector/Priority Register 1 */ - char res15[12]; - uint ipivpr2; /* 0x410c0 - IPI Vector/Priority Register 2 */ - char res16[12]; - uint ipivpr3; /* 0x410d0 - IPI Vector/Priority Register 3 */ - char res17[12]; - uint svr; /* 0x410e0 - Spurious Vector Register */ - char res18[12]; - uint tfrr; /* 0x410f0 - Timer Frequency Reporting Register */ - char res19[12]; - uint gtccr0; /* 0x41100 - Global Timer Current Count Register 0 */ - char res20[12]; - uint gtbcr0; /* 0x41110 - Global Timer Base Count Register 0 */ - char res21[12]; - uint gtvpr0; /* 0x41120 - Global Timer Vector/Priority Register 0 */ - char res22[12]; - uint gtdr0; /* 0x41130 - Global Timer Destination Register 0 */ - char res23[12]; - uint gtccr1; /* 0x41140 - Global Timer Current Count Register 1 */ - char res24[12]; - uint gtbcr1; /* 0x41150 - Global Timer Base Count Register 1 */ - char res25[12]; - uint gtvpr1; /* 0x41160 - Global Timer Vector/Priority Register 1 */ - char res26[12]; - uint gtdr1; /* 0x41170 - Global Timer Destination Register 1 */ - char res27[12]; - uint gtccr2; /* 0x41180 - Global Timer Current Count Register 2 */ - char res28[12]; - uint gtbcr2; /* 0x41190 - Global Timer Base Count Register 2 */ - char res29[12]; - uint gtvpr2; /* 0x411a0 - Global Timer Vector/Priority Register 2 */ - char res30[12]; - uint gtdr2; /* 0x411b0 - Global Timer Destination Register 2 */ - char res31[12]; - uint gtccr3; /* 0x411c0 - Global Timer Current Count Register 3 */ - char res32[12]; - uint gtbcr3; /* 0x411d0 - Global Timer Base Count Register 3 */ - char res33[12]; - uint gtvpr3; /* 0x411e0 - Global Timer Vector/Priority Register 3 */ - char res34[12]; - uint gtdr3; /* 0x411f0 - Global Timer Destination Register 3 */ - char res35[268]; - uint tcr; /* 0x41300 - Timer Control Register */ - char res36[12]; - uint irqsr0; /* 0x41310 - IRQ_OUT Summary Register 0 */ - char res37[12]; - uint irqsr1; /* 0x41320 - IRQ_OUT Summary Register 1 */ - char res38[12]; - uint cisr0; /* 0x41330 - Critical Interrupt Summary Register 0 */ - char res39[12]; - uint cisr1; /* 0x41340 - Critical Interrupt Summary Register 1 */ - char res40[188]; - uint msgr0; /* 0x41400 - Message Register 0 */ - char res41[12]; - uint msgr1; /* 0x41410 - Message Register 1 */ - char res42[12]; - uint msgr2; /* 0x41420 - Message Register 2 */ - char res43[12]; - uint msgr3; /* 0x41430 - Message Register 3 */ - char res44[204]; - uint mer; /* 0x41500 - Message Enable Register */ - char res45[12]; - uint msr; /* 0x41510 - Message Status Register */ - char res46[60140]; - uint eivpr0; /* 0x50000 - External Interrupt Vector/Priority Register 0 */ - char res47[12]; - uint eidr0; /* 0x50010 - External Interrupt Destination Register 0 */ - char res48[12]; - uint eivpr1; /* 0x50020 - External Interrupt Vector/Priority Register 1 */ - char res49[12]; - uint eidr1; /* 0x50030 - External Interrupt Destination Register 1 */ - char res50[12]; - uint eivpr2; /* 0x50040 - External Interrupt Vector/Priority Register 2 */ - char res51[12]; - uint eidr2; /* 0x50050 - External Interrupt Destination Register 2 */ - char res52[12]; - uint eivpr3; /* 0x50060 - External Interrupt Vector/Priority Register 3 */ - char res53[12]; - uint eidr3; /* 0x50070 - External Interrupt Destination Register 3 */ - char res54[12]; - uint eivpr4; /* 0x50080 - External Interrupt Vector/Priority Register 4 */ - char res55[12]; - uint eidr4; /* 0x50090 - External Interrupt Destination Register 4 */ - char res56[12]; - uint eivpr5; /* 0x500a0 - External Interrupt Vector/Priority Register 5 */ - char res57[12]; - uint eidr5; /* 0x500b0 - External Interrupt Destination Register 5 */ - char res58[12]; - uint eivpr6; /* 0x500c0 - External Interrupt Vector/Priority Register 6 */ - char res59[12]; - uint eidr6; /* 0x500d0 - External Interrupt Destination Register 6 */ - char res60[12]; - uint eivpr7; /* 0x500e0 - External Interrupt Vector/Priority Register 7 */ - char res61[12]; - uint eidr7; /* 0x500f0 - External Interrupt Destination Register 7 */ - char res62[12]; - uint eivpr8; /* 0x50100 - External Interrupt Vector/Priority Register 8 */ - char res63[12]; - uint eidr8; /* 0x50110 - External Interrupt Destination Register 8 */ - char res64[12]; - uint eivpr9; /* 0x50120 - External Interrupt Vector/Priority Register 9 */ - char res65[12]; - uint eidr9; /* 0x50130 - External Interrupt Destination Register 9 */ - char res66[12]; - uint eivpr10; /* 0x50140 - External Interrupt Vector/Priority Register 10 */ - char res67[12]; - uint eidr10; /* 0x50150 - External Interrupt Destination Register 10 */ - char res68[12]; - uint eivpr11; /* 0x50160 - External Interrupt Vector/Priority Register 11 */ - char res69[12]; - uint eidr11; /* 0x50170 - External Interrupt Destination Register 11 */ - char res70[140]; - uint iivpr0; /* 0x50200 - Internal Interrupt Vector/Priority Register 0 */ - char res71[12]; - uint iidr0; /* 0x50210 - Internal Interrupt Destination Register 0 */ - char res72[12]; - uint iivpr1; /* 0x50220 - Internal Interrupt Vector/Priority Register 1 */ - char res73[12]; - uint iidr1; /* 0x50230 - Internal Interrupt Destination Register 1 */ - char res74[12]; - uint iivpr2; /* 0x50240 - Internal Interrupt Vector/Priority Register 2 */ - char res75[12]; - uint iidr2; /* 0x50250 - Internal Interrupt Destination Register 2 */ - char res76[12]; - uint iivpr3; /* 0x50260 - Internal Interrupt Vector/Priority Register 3 */ - char res77[12]; - uint iidr3; /* 0x50270 - Internal Interrupt Destination Register 3 */ - char res78[12]; - uint iivpr4; /* 0x50280 - Internal Interrupt Vector/Priority Register 4 */ - char res79[12]; - uint iidr4; /* 0x50290 - Internal Interrupt Destination Register 4 */ - char res80[12]; - uint iivpr5; /* 0x502a0 - Internal Interrupt Vector/Priority Register 5 */ - char res81[12]; - uint iidr5; /* 0x502b0 - Internal Interrupt Destination Register 5 */ - char res82[12]; - uint iivpr6; /* 0x502c0 - Internal Interrupt Vector/Priority Register 6 */ - char res83[12]; - uint iidr6; /* 0x502d0 - Internal Interrupt Destination Register 6 */ - char res84[12]; - uint iivpr7; /* 0x502e0 - Internal Interrupt Vector/Priority Register 7 */ - char res85[12]; - uint iidr7; /* 0x502f0 - Internal Interrupt Destination Register 7 */ - char res86[12]; - uint iivpr8; /* 0x50300 - Internal Interrupt Vector/Priority Register 8 */ - char res87[12]; - uint iidr8; /* 0x50310 - Internal Interrupt Destination Register 8 */ - char res88[12]; - uint iivpr9; /* 0x50320 - Internal Interrupt Vector/Priority Register 9 */ - char res89[12]; - uint iidr9; /* 0x50330 - Internal Interrupt Destination Register 9 */ - char res90[12]; - uint iivpr10; /* 0x50340 - Internal Interrupt Vector/Priority Register 10 */ - char res91[12]; - uint iidr10; /* 0x50350 - Internal Interrupt Destination Register 10 */ - char res92[12]; - uint iivpr11; /* 0x50360 - Internal Interrupt Vector/Priority Register 11 */ - char res93[12]; - uint iidr11; /* 0x50370 - Internal Interrupt Destination Register 11 */ - char res94[12]; - uint iivpr12; /* 0x50380 - Internal Interrupt Vector/Priority Register 12 */ - char res95[12]; - uint iidr12; /* 0x50390 - Internal Interrupt Destination Register 12 */ - char res96[12]; - uint iivpr13; /* 0x503a0 - Internal Interrupt Vector/Priority Register 13 */ - char res97[12]; - uint iidr13; /* 0x503b0 - Internal Interrupt Destination Register 13 */ - char res98[12]; - uint iivpr14; /* 0x503c0 - Internal Interrupt Vector/Priority Register 14 */ - char res99[12]; - uint iidr14; /* 0x503d0 - Internal Interrupt Destination Register 14 */ - char res100[12]; - uint iivpr15; /* 0x503e0 - Internal Interrupt Vector/Priority Register 15 */ - char res101[12]; - uint iidr15; /* 0x503f0 - Internal Interrupt Destination Register 15 */ - char res102[12]; - uint iivpr16; /* 0x50400 - Internal Interrupt Vector/Priority Register 16 */ - char res103[12]; - uint iidr16; /* 0x50410 - Internal Interrupt Destination Register 16 */ - char res104[12]; - uint iivpr17; /* 0x50420 - Internal Interrupt Vector/Priority Register 17 */ - char res105[12]; - uint iidr17; /* 0x50430 - Internal Interrupt Destination Register 17 */ - char res106[12]; - uint iivpr18; /* 0x50440 - Internal Interrupt Vector/Priority Register 18 */ - char res107[12]; - uint iidr18; /* 0x50450 - Internal Interrupt Destination Register 18 */ - char res108[12]; - uint iivpr19; /* 0x50460 - Internal Interrupt Vector/Priority Register 19 */ - char res109[12]; - uint iidr19; /* 0x50470 - Internal Interrupt Destination Register 19 */ - char res110[12]; - uint iivpr20; /* 0x50480 - Internal Interrupt Vector/Priority Register 20 */ - char res111[12]; - uint iidr20; /* 0x50490 - Internal Interrupt Destination Register 20 */ - char res112[12]; - uint iivpr21; /* 0x504a0 - Internal Interrupt Vector/Priority Register 21 */ - char res113[12]; - uint iidr21; /* 0x504b0 - Internal Interrupt Destination Register 21 */ - char res114[12]; - uint iivpr22; /* 0x504c0 - Internal Interrupt Vector/Priority Register 22 */ - char res115[12]; - uint iidr22; /* 0x504d0 - Internal Interrupt Destination Register 22 */ - char res116[12]; - uint iivpr23; /* 0x504e0 - Internal Interrupt Vector/Priority Register 23 */ - char res117[12]; - uint iidr23; /* 0x504f0 - Internal Interrupt Destination Register 23 */ - char res118[12]; - uint iivpr24; /* 0x50500 - Internal Interrupt Vector/Priority Register 24 */ - char res119[12]; - uint iidr24; /* 0x50510 - Internal Interrupt Destination Register 24 */ - char res120[12]; - uint iivpr25; /* 0x50520 - Internal Interrupt Vector/Priority Register 25 */ - char res121[12]; - uint iidr25; /* 0x50530 - Internal Interrupt Destination Register 25 */ - char res122[12]; - uint iivpr26; /* 0x50540 - Internal Interrupt Vector/Priority Register 26 */ - char res123[12]; - uint iidr26; /* 0x50550 - Internal Interrupt Destination Register 26 */ - char res124[12]; - uint iivpr27; /* 0x50560 - Internal Interrupt Vector/Priority Register 27 */ - char res125[12]; - uint iidr27; /* 0x50570 - Internal Interrupt Destination Register 27 */ - char res126[12]; - uint iivpr28; /* 0x50580 - Internal Interrupt Vector/Priority Register 28 */ - char res127[12]; - uint iidr28; /* 0x50590 - Internal Interrupt Destination Register 28 */ - char res128[12]; - uint iivpr29; /* 0x505a0 - Internal Interrupt Vector/Priority Register 29 */ - char res129[12]; - uint iidr29; /* 0x505b0 - Internal Interrupt Destination Register 29 */ - char res130[12]; - uint iivpr30; /* 0x505c0 - Internal Interrupt Vector/Priority Register 30 */ - char res131[12]; - uint iidr30; /* 0x505d0 - Internal Interrupt Destination Register 30 */ - char res132[12]; - uint iivpr31; /* 0x505e0 - Internal Interrupt Vector/Priority Register 31 */ - char res133[12]; - uint iidr31; /* 0x505f0 - Internal Interrupt Destination Register 31 */ - char res134[4108]; - uint mivpr0; /* 0x51600 - Messaging Interrupt Vector/Priority Register 0 */ - char res135[12]; - uint midr0; /* 0x51610 - Messaging Interrupt Destination Register 0 */ - char res136[12]; - uint mivpr1; /* 0x51620 - Messaging Interrupt Vector/Priority Register 1 */ - char res137[12]; - uint midr1; /* 0x51630 - Messaging Interrupt Destination Register 1 */ - char res138[12]; - uint mivpr2; /* 0x51640 - Messaging Interrupt Vector/Priority Register 2 */ - char res139[12]; - uint midr2; /* 0x51650 - Messaging Interrupt Destination Register 2 */ - char res140[12]; - uint mivpr3; /* 0x51660 - Messaging Interrupt Vector/Priority Register 3 */ - char res141[12]; - uint midr3; /* 0x51670 - Messaging Interrupt Destination Register 3 */ - char res142[59852]; - uint ipi0dr0; /* 0x60040 - Processor 0 Interprocessor Interrupt Dispatch Register 0 */ - char res143[12]; - uint ipi0dr1; /* 0x60050 - Processor 0 Interprocessor Interrupt Dispatch Register 1 */ - char res144[12]; - uint ipi0dr2; /* 0x60060 - Processor 0 Interprocessor Interrupt Dispatch Register 2 */ - char res145[12]; - uint ipi0dr3; /* 0x60070 - Processor 0 Interprocessor Interrupt Dispatch Register 3 */ - char res146[12]; - uint ctpr0; /* 0x60080 - Current Task Priority Register for Processor 0 */ - char res147[12]; - uint whoami0; /* 0x60090 - Who Am I Register for Processor 0 */ - char res148[12]; - uint iack0; /* 0x600a0 - Interrupt Acknowledge Register for Processor 0 */ - char res149[12]; - uint eoi0; /* 0x600b0 - End Of Interrupt Register for Processor 0 */ - char res150[130892]; + u8 res1[64]; + u32 ipidr0; /* Interprocessor IRQ Dispatch 0 */ + u8 res2[12]; + u32 ipidr1; /* Interprocessor IRQ Dispatch 1 */ + u8 res3[12]; + u32 ipidr2; /* Interprocessor IRQ Dispatch 2 */ + u8 res4[12]; + u32 ipidr3; /* Interprocessor IRQ Dispatch 3 */ + u8 res5[12]; + u32 ctpr; /* Current Task Priority */ + u8 res6[12]; + u32 whoami; /* Who Am I */ + u8 res7[12]; + u32 iack; /* IRQ Acknowledge */ + u8 res8[12]; + u32 eoi; /* End Of IRQ */ + u8 res9[3916]; + u32 frr; /* Feature Reporting */ + u8 res10[28]; + u32 gcr; /* Global Configuration */ +#define MPC85xx_PICGCR_RST 0x80000000 +#define MPC85xx_PICGCR_M 0x20000000 + u8 res11[92]; + u32 vir; /* Vendor Identification */ + u8 res12[12]; + u32 pir; /* Processor Initialization */ + u8 res13[12]; + u32 ipivpr0; /* IPI Vector/Priority 0 */ + u8 res14[12]; + u32 ipivpr1; /* IPI Vector/Priority 1 */ + u8 res15[12]; + u32 ipivpr2; /* IPI Vector/Priority 2 */ + u8 res16[12]; + u32 ipivpr3; /* IPI Vector/Priority 3 */ + u8 res17[12]; + u32 svr; /* Spurious Vector */ + u8 res18[12]; + u32 tfrr; /* Timer Frequency Reporting */ + u8 res19[12]; + u32 gtccr0; /* Global Timer Current Count 0 */ + u8 res20[12]; + u32 gtbcr0; /* Global Timer Base Count 0 */ + u8 res21[12]; + u32 gtvpr0; /* Global Timer Vector/Priority 0 */ + u8 res22[12]; + u32 gtdr0; /* Global Timer Destination 0 */ + u8 res23[12]; + u32 gtccr1; /* Global Timer Current Count 1 */ + u8 res24[12]; + u32 gtbcr1; /* Global Timer Base Count 1 */ + u8 res25[12]; + u32 gtvpr1; /* Global Timer Vector/Priority 1 */ + u8 res26[12]; + u32 gtdr1; /* Global Timer Destination 1 */ + u8 res27[12]; + u32 gtccr2; /* Global Timer Current Count 2 */ + u8 res28[12]; + u32 gtbcr2; /* Global Timer Base Count 2 */ + u8 res29[12]; + u32 gtvpr2; /* Global Timer Vector/Priority 2 */ + u8 res30[12]; + u32 gtdr2; /* Global Timer Destination 2 */ + u8 res31[12]; + u32 gtccr3; /* Global Timer Current Count 3 */ + u8 res32[12]; + u32 gtbcr3; /* Global Timer Base Count 3 */ + u8 res33[12]; + u32 gtvpr3; /* Global Timer Vector/Priority 3 */ + u8 res34[12]; + u32 gtdr3; /* Global Timer Destination 3 */ + u8 res35[268]; + u32 tcr; /* Timer Control */ + u8 res36[12]; + u32 irqsr0; /* IRQ_OUT Summary 0 */ + u8 res37[12]; + u32 irqsr1; /* IRQ_OUT Summary 1 */ + u8 res38[12]; + u32 cisr0; /* Critical IRQ Summary 0 */ + u8 res39[12]; + u32 cisr1; /* Critical IRQ Summary 1 */ + u8 res40[188]; + u32 msgr0; /* Message 0 */ + u8 res41[12]; + u32 msgr1; /* Message 1 */ + u8 res42[12]; + u32 msgr2; /* Message 2 */ + u8 res43[12]; + u32 msgr3; /* Message 3 */ + u8 res44[204]; + u32 mer; /* Message Enable */ + u8 res45[12]; + u32 msr; /* Message Status */ + u8 res46[60140]; + u32 eivpr0; /* External IRQ Vector/Priority 0 */ + u8 res47[12]; + u32 eidr0; /* External IRQ Destination 0 */ + u8 res48[12]; + u32 eivpr1; /* External IRQ Vector/Priority 1 */ + u8 res49[12]; + u32 eidr1; /* External IRQ Destination 1 */ + u8 res50[12]; + u32 eivpr2; /* External IRQ Vector/Priority 2 */ + u8 res51[12]; + u32 eidr2; /* External IRQ Destination 2 */ + u8 res52[12]; + u32 eivpr3; /* External IRQ Vector/Priority 3 */ + u8 res53[12]; + u32 eidr3; /* External IRQ Destination 3 */ + u8 res54[12]; + u32 eivpr4; /* External IRQ Vector/Priority 4 */ + u8 res55[12]; + u32 eidr4; /* External IRQ Destination 4 */ + u8 res56[12]; + u32 eivpr5; /* External IRQ Vector/Priority 5 */ + u8 res57[12]; + u32 eidr5; /* External IRQ Destination 5 */ + u8 res58[12]; + u32 eivpr6; /* External IRQ Vector/Priority 6 */ + u8 res59[12]; + u32 eidr6; /* External IRQ Destination 6 */ + u8 res60[12]; + u32 eivpr7; /* External IRQ Vector/Priority 7 */ + u8 res61[12]; + u32 eidr7; /* External IRQ Destination 7 */ + u8 res62[12]; + u32 eivpr8; /* External IRQ Vector/Priority 8 */ + u8 res63[12]; + u32 eidr8; /* External IRQ Destination 8 */ + u8 res64[12]; + u32 eivpr9; /* External IRQ Vector/Priority 9 */ + u8 res65[12]; + u32 eidr9; /* External IRQ Destination 9 */ + u8 res66[12]; + u32 eivpr10; /* External IRQ Vector/Priority 10 */ + u8 res67[12]; + u32 eidr10; /* External IRQ Destination 10 */ + u8 res68[12]; + u32 eivpr11; /* External IRQ Vector/Priority 11 */ + u8 res69[12]; + u32 eidr11; /* External IRQ Destination 11 */ + u8 res70[140]; + u32 iivpr0; /* Internal IRQ Vector/Priority 0 */ + u8 res71[12]; + u32 iidr0; /* Internal IRQ Destination 0 */ + u8 res72[12]; + u32 iivpr1; /* Internal IRQ Vector/Priority 1 */ + u8 res73[12]; + u32 iidr1; /* Internal IRQ Destination 1 */ + u8 res74[12]; + u32 iivpr2; /* Internal IRQ Vector/Priority 2 */ + u8 res75[12]; + u32 iidr2; /* Internal IRQ Destination 2 */ + u8 res76[12]; + u32 iivpr3; /* Internal IRQ Vector/Priority 3 */ + u8 res77[12]; + u32 iidr3; /* Internal IRQ Destination 3 */ + u8 res78[12]; + u32 iivpr4; /* Internal IRQ Vector/Priority 4 */ + u8 res79[12]; + u32 iidr4; /* Internal IRQ Destination 4 */ + u8 res80[12]; + u32 iivpr5; /* Internal IRQ Vector/Priority 5 */ + u8 res81[12]; + u32 iidr5; /* Internal IRQ Destination 5 */ + u8 res82[12]; + u32 iivpr6; /* Internal IRQ Vector/Priority 6 */ + u8 res83[12]; + u32 iidr6; /* Internal IRQ Destination 6 */ + u8 res84[12]; + u32 iivpr7; /* Internal IRQ Vector/Priority 7 */ + u8 res85[12]; + u32 iidr7; /* Internal IRQ Destination 7 */ + u8 res86[12]; + u32 iivpr8; /* Internal IRQ Vector/Priority 8 */ + u8 res87[12]; + u32 iidr8; /* Internal IRQ Destination 8 */ + u8 res88[12]; + u32 iivpr9; /* Internal IRQ Vector/Priority 9 */ + u8 res89[12]; + u32 iidr9; /* Internal IRQ Destination 9 */ + u8 res90[12]; + u32 iivpr10; /* Internal IRQ Vector/Priority 10 */ + u8 res91[12]; + u32 iidr10; /* Internal IRQ Destination 10 */ + u8 res92[12]; + u32 iivpr11; /* Internal IRQ Vector/Priority 11 */ + u8 res93[12]; + u32 iidr11; /* Internal IRQ Destination 11 */ + u8 res94[12]; + u32 iivpr12; /* Internal IRQ Vector/Priority 12 */ + u8 res95[12]; + u32 iidr12; /* Internal IRQ Destination 12 */ + u8 res96[12]; + u32 iivpr13; /* Internal IRQ Vector/Priority 13 */ + u8 res97[12]; + u32 iidr13; /* Internal IRQ Destination 13 */ + u8 res98[12]; + u32 iivpr14; /* Internal IRQ Vector/Priority 14 */ + u8 res99[12]; + u32 iidr14; /* Internal IRQ Destination 14 */ + u8 res100[12]; + u32 iivpr15; /* Internal IRQ Vector/Priority 15 */ + u8 res101[12]; + u32 iidr15; /* Internal IRQ Destination 15 */ + u8 res102[12]; + u32 iivpr16; /* Internal IRQ Vector/Priority 16 */ + u8 res103[12]; + u32 iidr16; /* Internal IRQ Destination 16 */ + u8 res104[12]; + u32 iivpr17; /* Internal IRQ Vector/Priority 17 */ + u8 res105[12]; + u32 iidr17; /* Internal IRQ Destination 17 */ + u8 res106[12]; + u32 iivpr18; /* Internal IRQ Vector/Priority 18 */ + u8 res107[12]; + u32 iidr18; /* Internal IRQ Destination 18 */ + u8 res108[12]; + u32 iivpr19; /* Internal IRQ Vector/Priority 19 */ + u8 res109[12]; + u32 iidr19; /* Internal IRQ Destination 19 */ + u8 res110[12]; + u32 iivpr20; /* Internal IRQ Vector/Priority 20 */ + u8 res111[12]; + u32 iidr20; /* Internal IRQ Destination 20 */ + u8 res112[12]; + u32 iivpr21; /* Internal IRQ Vector/Priority 21 */ + u8 res113[12]; + u32 iidr21; /* Internal IRQ Destination 21 */ + u8 res114[12]; + u32 iivpr22; /* Internal IRQ Vector/Priority 22 */ + u8 res115[12]; + u32 iidr22; /* Internal IRQ Destination 22 */ + u8 res116[12]; + u32 iivpr23; /* Internal IRQ Vector/Priority 23 */ + u8 res117[12]; + u32 iidr23; /* Internal IRQ Destination 23 */ + u8 res118[12]; + u32 iivpr24; /* Internal IRQ Vector/Priority 24 */ + u8 res119[12]; + u32 iidr24; /* Internal IRQ Destination 24 */ + u8 res120[12]; + u32 iivpr25; /* Internal IRQ Vector/Priority 25 */ + u8 res121[12]; + u32 iidr25; /* Internal IRQ Destination 25 */ + u8 res122[12]; + u32 iivpr26; /* Internal IRQ Vector/Priority 26 */ + u8 res123[12]; + u32 iidr26; /* Internal IRQ Destination 26 */ + u8 res124[12]; + u32 iivpr27; /* Internal IRQ Vector/Priority 27 */ + u8 res125[12]; + u32 iidr27; /* Internal IRQ Destination 27 */ + u8 res126[12]; + u32 iivpr28; /* Internal IRQ Vector/Priority 28 */ + u8 res127[12]; + u32 iidr28; /* Internal IRQ Destination 28 */ + u8 res128[12]; + u32 iivpr29; /* Internal IRQ Vector/Priority 29 */ + u8 res129[12]; + u32 iidr29; /* Internal IRQ Destination 29 */ + u8 res130[12]; + u32 iivpr30; /* Internal IRQ Vector/Priority 30 */ + u8 res131[12]; + u32 iidr30; /* Internal IRQ Destination 30 */ + u8 res132[12]; + u32 iivpr31; /* Internal IRQ Vector/Priority 31 */ + u8 res133[12]; + u32 iidr31; /* Internal IRQ Destination 31 */ + u8 res134[4108]; + u32 mivpr0; /* Messaging IRQ Vector/Priority 0 */ + u8 res135[12]; + u32 midr0; /* Messaging IRQ Destination 0 */ + u8 res136[12]; + u32 mivpr1; /* Messaging IRQ Vector/Priority 1 */ + u8 res137[12]; + u32 midr1; /* Messaging IRQ Destination 1 */ + u8 res138[12]; + u32 mivpr2; /* Messaging IRQ Vector/Priority 2 */ + u8 res139[12]; + u32 midr2; /* Messaging IRQ Destination 2 */ + u8 res140[12]; + u32 mivpr3; /* Messaging IRQ Vector/Priority 3 */ + u8 res141[12]; + u32 midr3; /* Messaging IRQ Destination 3 */ + u8 res142[59852]; + u32 ipi0dr0; /* Processor 0 Interprocessor IRQ Dispatch 0 */ + u8 res143[12]; + u32 ipi0dr1; /* Processor 0 Interprocessor IRQ Dispatch 1 */ + u8 res144[12]; + u32 ipi0dr2; /* Processor 0 Interprocessor IRQ Dispatch 2 */ + u8 res145[12]; + u32 ipi0dr3; /* Processor 0 Interprocessor IRQ Dispatch 3 */ + u8 res146[12]; + u32 ctpr0; /* Current Task Priority for Processor 0 */ + u8 res147[12]; + u32 whoami0; /* Who Am I for Processor 0 */ + u8 res148[12]; + u32 iack0; /* IRQ Acknowledge for Processor 0 */ + u8 res149[12]; + u32 eoi0; /* End Of IRQ for Processor 0 */ + u8 res150[130892]; } ccsr_pic_t;
-/* - * CPM Block(0x8_0000-0xc_0000) - */ +/* CPM Block */ #ifndef CONFIG_CPM2 typedef struct ccsr_cpm { - char res[262144]; + u8 res[262144]; } ccsr_cpm_t; #else /* - * 0x8000-0x8ffff:DPARM - * 0x9000-0x90bff: General SIU + * DPARM + * General SIU */ typedef struct ccsr_cpm_siu { - char res1[80]; - uint smaer; - uint smser; - uint smevr; - char res2[4]; - uint lmaer; - uint lmser; - uint lmevr; - char res3[2964]; + u8 res1[80]; + u32 smaer; + u32 smser; + u32 smevr; + u8 res2[4]; + u32 lmaer; + u32 lmser; + u32 lmevr; + u8 res3[2964]; } ccsr_cpm_siu_t;
-/* 0x90c00-0x90cff: Interrupt Controller */ +/* IRQ Controller */ typedef struct ccsr_cpm_intctl { - ushort sicr; - char res1[2]; - uint sivec; - uint sipnrh; - uint sipnrl; - uint siprr; - uint scprrh; - uint scprrl; - uint simrh; - uint simrl; - uint siexr; - char res2[88]; - uint sccr; - char res3[124]; + u16 sicr; + u8 res1[2]; + u32 sivec; + u32 sipnrh; + u32 sipnrl; + u32 siprr; + u32 scprrh; + u32 scprrl; + u32 simrh; + u32 simrl; + u32 siexr; + u8 res2[88]; + u32 sccr; + u8 res3[124]; } ccsr_cpm_intctl_t;
-/* 0x90d00-0x90d7f: input/output port */ +/* input/output port */ typedef struct ccsr_cpm_iop { - uint pdira; - uint ppara; - uint psora; - uint podra; - uint pdata; - char res1[12]; - uint pdirb; - uint pparb; - uint psorb; - uint podrb; - uint pdatb; - char res2[12]; - uint pdirc; - uint pparc; - uint psorc; - uint podrc; - uint pdatc; - char res3[12]; - uint pdird; - uint ppard; - uint psord; - uint podrd; - uint pdatd; - char res4[12]; + u32 pdira; + u32 ppara; + u32 psora; + u32 podra; + u32 pdata; + u8 res1[12]; + u32 pdirb; + u32 pparb; + u32 psorb; + u32 podrb; + u32 pdatb; + u8 res2[12]; + u32 pdirc; + u32 pparc; + u32 psorc; + u32 podrc; + u32 pdatc; + u8 res3[12]; + u32 pdird; + u32 ppard; + u32 psord; + u32 podrd; + u32 pdatd; + u8 res4[12]; } ccsr_cpm_iop_t;
-/* 0x90d80-0x91017: CPM timers */ +/* CPM timers */ typedef struct ccsr_cpm_timer { - u_char tgcr1; - char res1[3]; - u_char tgcr2; - char res2[11]; - ushort tmr1; - ushort tmr2; - ushort trr1; - ushort trr2; - ushort tcr1; - ushort tcr2; - ushort tcn1; - ushort tcn2; - ushort tmr3; - ushort tmr4; - ushort trr3; - ushort trr4; - ushort tcr3; - ushort tcr4; - ushort tcn3; - ushort tcn4; - ushort ter1; - ushort ter2; - ushort ter3; - ushort ter4; - char res3[608]; + u8 tgcr1; + u8 res1[3]; + u8 tgcr2; + u8 res2[11]; + u16 tmr1; + u16 tmr2; + u16 trr1; + u16 trr2; + u16 tcr1; + u16 tcr2; + u16 tcn1; + u16 tcn2; + u16 tmr3; + u16 tmr4; + u16 trr3; + u16 trr4; + u16 tcr3; + u16 tcr4; + u16 tcn3; + u16 tcn4; + u16 ter1; + u16 ter2; + u16 ter3; + u16 ter4; + u8 res3[608]; } ccsr_cpm_timer_t;
-/* 0x91018-0x912ff: SDMA */ +/* SDMA */ typedef struct ccsr_cpm_sdma { - uchar sdsr; - char res1[3]; - uchar sdmr; - char res2[739]; + u8 sdsr; + u8 res1[3]; + u8 sdmr; + u8 res2[739]; } ccsr_cpm_sdma_t;
-/* 0x91300-0x9131f: FCC1 */ +/* FCC1 */ typedef struct ccsr_cpm_fcc1 { - uint gfmr; - uint fpsmr; - ushort ftodr; - char res1[2]; - ushort fdsr; - char res2[2]; - ushort fcce; - char res3[2]; - ushort fccm; - char res4[2]; - u_char fccs; - char res5[3]; - u_char ftirr_phy[4]; + u32 gfmr; + u32 fpsmr; + u16 ftodr; + u8 res1[2]; + u16 fdsr; + u8 res2[2]; + u16 fcce; + u8 res3[2]; + u16 fccm; + u8 res4[2]; + u8 fccs; + u8 res5[3]; + u8 ftirr_phy[4]; } ccsr_cpm_fcc1_t;
-/* 0x91320-0x9133f: FCC2 */ +/* FCC2 */ typedef struct ccsr_cpm_fcc2 { - uint gfmr; - uint fpsmr; - ushort ftodr; - char res1[2]; - ushort fdsr; - char res2[2]; - ushort fcce; - char res3[2]; - ushort fccm; - char res4[2]; - u_char fccs; - char res5[3]; - u_char ftirr_phy[4]; + u32 gfmr; + u32 fpsmr; + u16 ftodr; + u8 res1[2]; + u16 fdsr; + u8 res2[2]; + u16 fcce; + u8 res3[2]; + u16 fccm; + u8 res4[2]; + u8 fccs; + u8 res5[3]; + u8 ftirr_phy[4]; } ccsr_cpm_fcc2_t;
-/* 0x91340-0x9137f: FCC3 */ +/* FCC3 */ typedef struct ccsr_cpm_fcc3 { - uint gfmr; - uint fpsmr; - ushort ftodr; - char res1[2]; - ushort fdsr; - char res2[2]; - ushort fcce; - char res3[2]; - ushort fccm; - char res4[2]; - u_char fccs; - char res5[3]; - char res[36]; + u32 gfmr; + u32 fpsmr; + u16 ftodr; + u8 res1[2]; + u16 fdsr; + u8 res2[2]; + u16 fcce; + u8 res3[2]; + u16 fccm; + u8 res4[2]; + u8 fccs; + u8 res5[3]; + u8 res[36]; } ccsr_cpm_fcc3_t;
-/* 0x91380-0x9139f: FCC1 extended */ +/* FCC1 extended */ typedef struct ccsr_cpm_fcc1_ext { - uint firper; - uint firer; - uint firsr_h; - uint firsr_l; - u_char gfemr; - char res[15]; + u32 firper; + u32 firer; + u32 firsr_h; + u32 firsr_l; + u8 gfemr; + u8 res[15];
} ccsr_cpm_fcc1_ext_t;
-/* 0x913a0-0x913cf: FCC2 extended */ +/* FCC2 extended */ typedef struct ccsr_cpm_fcc2_ext { - uint firper; - uint firer; - uint firsr_h; - uint firsr_l; - u_char gfemr; - char res[31]; + u32 firper; + u32 firer; + u32 firsr_h; + u32 firsr_l; + u8 gfemr; + u8 res[31]; } ccsr_cpm_fcc2_ext_t;
-/* 0x913d0-0x913ff: FCC3 extended */ +/* FCC3 extended */ typedef struct ccsr_cpm_fcc3_ext { - u_char gfemr; - char res[47]; + u8 gfemr; + u8 res[47]; } ccsr_cpm_fcc3_ext_t;
-/* 0x91400-0x915ef: TC layers */ +/* TC layers */ typedef struct ccsr_cpm_tmp1 { - char res[496]; + u8 res[496]; } ccsr_cpm_tmp1_t;
-/* 0x915f0-0x9185f: BRGs:5,6,7,8 */ +/* BRGs:5,6,7,8 */ typedef struct ccsr_cpm_brg2 { - uint brgc5; - uint brgc6; - uint brgc7; - uint brgc8; - char res[608]; + u32 brgc5; + u32 brgc6; + u32 brgc7; + u32 brgc8; + u8 res[608]; } ccsr_cpm_brg2_t;
-/* 0x91860-0x919bf: I2C */ +/* I2C */ typedef struct ccsr_cpm_i2c { - u_char i2mod; - char res1[3]; - u_char i2add; - char res2[3]; - u_char i2brg; - char res3[3]; - u_char i2com; - char res4[3]; - u_char i2cer; - char res5[3]; - u_char i2cmr; - char res6[331]; + u8 i2mod; + u8 res1[3]; + u8 i2add; + u8 res2[3]; + u8 i2brg; + u8 res3[3]; + u8 i2com; + u8 res4[3]; + u8 i2cer; + u8 res5[3]; + u8 i2cmr; + u8 res6[331]; } ccsr_cpm_i2c_t;
-/* 0x919c0-0x919ef: CPM core */ +/* CPM core */ typedef struct ccsr_cpm_cp { - uint cpcr; - uint rccr; - char res1[14]; - ushort rter; - char res2[2]; - ushort rtmr; - ushort rtscr; - char res3[2]; - uint rtsr; - char res4[12]; + u32 cpcr; + u32 rccr; + u8 res1[14]; + u16 rter; + u8 res2[2]; + u16 rtmr; + u16 rtscr; + u8 res3[2]; + u32 rtsr; + u8 res4[12]; } ccsr_cpm_cp_t;
-/* 0x919f0-0x919ff: BRGs:1,2,3,4 */ +/* BRGs:1,2,3,4 */ typedef struct ccsr_cpm_brg1 { - uint brgc1; - uint brgc2; - uint brgc3; - uint brgc4; + u32 brgc1; + u32 brgc2; + u32 brgc3; + u32 brgc4; } ccsr_cpm_brg1_t;
-/* 0x91a00-0x91a9f: SCC1-SCC4 */ +/* SCC1-SCC4 */ typedef struct ccsr_cpm_scc { - uint gsmrl; - uint gsmrh; - ushort psmr; - char res1[2]; - ushort todr; - ushort dsr; - ushort scce; - char res2[2]; - ushort sccm; - char res3; - u_char sccs; - char res4[8]; + u32 gsmrl; + u32 gsmrh; + u16 psmr; + u8 res1[2]; + u16 todr; + u16 dsr; + u16 scce; + u8 res2[2]; + u16 sccm; + u8 res3; + u8 sccs; + u8 res4[8]; } ccsr_cpm_scc_t;
-/* 0x91a80-0x91a9f */ typedef struct ccsr_cpm_tmp2 { - char res[32]; + u8 res[32]; } ccsr_cpm_tmp2_t;
-/* 0x91aa0-0x91aff: SPI */ +/* SPI */ typedef struct ccsr_cpm_spi { - ushort spmode; - char res1[4]; - u_char spie; - char res2[3]; - u_char spim; - char res3[2]; - u_char spcom; - char res4[82]; + u16 spmode; + u8 res1[4]; + u8 spie; + u8 res2[3]; + u8 spim; + u8 res3[2]; + u8 spcom; + u8 res4[82]; } ccsr_cpm_spi_t;
-/* 0x91b00-0x91b1f: CPM MUX */ +/* CPM MUX */ typedef struct ccsr_cpm_mux { - u_char cmxsi1cr; - char res1; - u_char cmxsi2cr; - char res2; - uint cmxfcr; - uint cmxscr; - char res3[2]; - ushort cmxuar; - char res4[16]; + u8 cmxsi1cr; + u8 res1; + u8 cmxsi2cr; + u8 res2; + u32 cmxfcr; + u32 cmxscr; + u8 res3[2]; + u16 cmxuar; + u8 res4[16]; } ccsr_cpm_mux_t;
-/* 0x91b20-0xbffff: SI,MCC,etc */ +/* SI,MCC,etc */ typedef struct ccsr_cpm_tmp3 { - char res[58592]; + u8 res[58592]; } ccsr_cpm_tmp3_t;
typedef struct ccsr_cpm_iram { - unsigned long iram[8192]; - char res[98304]; + u32 iram[8192]; + u8 res[98304]; } ccsr_cpm_iram_t;
typedef struct ccsr_cpm { - /* Some references are into the unique and known dpram spaces, + /* Some references are into the unique & known dpram spaces, * others are from the generic base. */ #define im_dprambase im_dpram1 - u_char im_dpram1[16*1024]; - char res1[16*1024]; - u_char im_dpram2[16*1024]; - char res2[16*1024]; - ccsr_cpm_siu_t im_cpm_siu; /* SIU Configuration */ - ccsr_cpm_intctl_t im_cpm_intctl; /* Interrupt Controller */ - ccsr_cpm_iop_t im_cpm_iop; /* IO Port control/status */ - ccsr_cpm_timer_t im_cpm_timer; /* CPM timers */ - ccsr_cpm_sdma_t im_cpm_sdma; /* SDMA control/status */ + u8 im_dpram1[16*1024]; + u8 res1[16*1024]; + u8 im_dpram2[16*1024]; + u8 res2[16*1024]; + ccsr_cpm_siu_t im_cpm_siu; /* SIU Configuration */ + ccsr_cpm_intctl_t im_cpm_intctl; /* IRQ Controller */ + ccsr_cpm_iop_t im_cpm_iop; /* IO Port control/status */ + ccsr_cpm_timer_t im_cpm_timer; /* CPM timers */ + ccsr_cpm_sdma_t im_cpm_sdma; /* SDMA control/status */ ccsr_cpm_fcc1_t im_cpm_fcc1; ccsr_cpm_fcc2_t im_cpm_fcc2; ccsr_cpm_fcc3_t im_cpm_fcc3; @@ -1386,203 +1368,199 @@ typedef struct ccsr_cpm { } ccsr_cpm_t; #endif
-/* - * RapidIO Registers(0xc_0000-0xe_0000) - */ +/* RapidIO Registers */ typedef struct ccsr_rio { - uint didcar; /* 0xc0000 - Device Identity Capability Register */ - uint dicar; /* 0xc0004 - Device Information Capability Register */ - uint aidcar; /* 0xc0008 - Assembly Identity Capability Register */ - uint aicar; /* 0xc000c - Assembly Information Capability Register */ - uint pefcar; /* 0xc0010 - Processing Element Features Capability Register */ - uint spicar; /* 0xc0014 - Switch Port Information Capability Register */ - uint socar; /* 0xc0018 - Source Operations Capability Register */ - uint docar; /* 0xc001c - Destination Operations Capability Register */ - char res1[32]; - uint msr; /* 0xc0040 - Mailbox Command And Status Register */ - uint pwdcsr; /* 0xc0044 - Port-Write and Doorbell Command And Status Register */ - char res2[4]; - uint pellccsr; /* 0xc004c - Processing Element Logic Layer Control Command and Status Register */ - char res3[12]; - uint lcsbacsr; /* 0xc005c - Local Configuration Space Base Address Command and Status Register */ - uint bdidcsr; /* 0xc0060 - Base Device ID Command and Status Register */ - char res4[4]; - uint hbdidlcsr; /* 0xc0068 - Host Base Device ID Lock Command and Status Register */ - uint ctcsr; /* 0xc006c - Component Tag Command and Status Register */ - char res5[144]; - uint pmbh0csr; /* 0xc0100 - 8/16 LP-LVDS Port Maintenance Block Header 0 Command and Status Register */ - char res6[28]; - uint pltoccsr; /* 0xc0120 - Port Link Time-out Control Command and Status Register */ - uint prtoccsr; /* 0xc0124 - Port Response Time-out Control Command and Status Register */ - char res7[20]; - uint pgccsr; /* 0xc013c - Port General Command and Status Register */ - uint plmreqcsr; /* 0xc0140 - Port Link Maintenance Request Command and Status Register */ - uint plmrespcsr; /* 0xc0144 - Port Link Maintenance Response Command and Status Register */ - uint plascsr; /* 0xc0148 - Port Local Ackid Status Command and Status Register */ - char res8[12]; - uint pescsr; /* 0xc0158 - Port Error and Status Command and Status Register */ - uint pccsr; /* 0xc015c - Port Control Command and Status Register */ - char res9[65184]; - uint cr; /* 0xd0000 - Port Control Command and Status Register */ - char res10[12]; - uint pcr; /* 0xd0010 - Port Configuration Register */ - uint peir; /* 0xd0014 - Port Error Injection Register */ - char res11[3048]; - uint rowtar0; /* 0xd0c00 - RapidIO Outbound Window Translation Address Register 0 */ - char res12[12]; - uint rowar0; /* 0xd0c10 - RapidIO Outbound Attributes Register 0 */ - char res13[12]; - uint rowtar1; /* 0xd0c20 - RapidIO Outbound Window Translation Address Register 1 */ - char res14[4]; - uint rowbar1; /* 0xd0c28 - RapidIO Outbound Window Base Address Register 1 */ - char res15[4]; - uint rowar1; /* 0xd0c30 - RapidIO Outbound Attributes Register 1 */ - char res16[12]; - uint rowtar2; /* 0xd0c40 - RapidIO Outbound Window Translation Address Register 2 */ - char res17[4]; - uint rowbar2; /* 0xd0c48 - RapidIO Outbound Window Base Address Register 2 */ - char res18[4]; - uint rowar2; /* 0xd0c50 - RapidIO Outbound Attributes Register 2 */ - char res19[12]; - uint rowtar3; /* 0xd0c60 - RapidIO Outbound Window Translation Address Register 3 */ - char res20[4]; - uint rowbar3; /* 0xd0c68 - RapidIO Outbound Window Base Address Register 3 */ - char res21[4]; - uint rowar3; /* 0xd0c70 - RapidIO Outbound Attributes Register 3 */ - char res22[12]; - uint rowtar4; /* 0xd0c80 - RapidIO Outbound Window Translation Address Register 4 */ - char res23[4]; - uint rowbar4; /* 0xd0c88 - RapidIO Outbound Window Base Address Register 4 */ - char res24[4]; - uint rowar4; /* 0xd0c90 - RapidIO Outbound Attributes Register 4 */ - char res25[12]; - uint rowtar5; /* 0xd0ca0 - RapidIO Outbound Window Translation Address Register 5 */ - char res26[4]; - uint rowbar5; /* 0xd0ca8 - RapidIO Outbound Window Base Address Register 5 */ - char res27[4]; - uint rowar5; /* 0xd0cb0 - RapidIO Outbound Attributes Register 5 */ - char res28[12]; - uint rowtar6; /* 0xd0cc0 - RapidIO Outbound Window Translation Address Register 6 */ - char res29[4]; - uint rowbar6; /* 0xd0cc8 - RapidIO Outbound Window Base Address Register 6 */ - char res30[4]; - uint rowar6; /* 0xd0cd0 - RapidIO Outbound Attributes Register 6 */ - char res31[12]; - uint rowtar7; /* 0xd0ce0 - RapidIO Outbound Window Translation Address Register 7 */ - char res32[4]; - uint rowbar7; /* 0xd0ce8 - RapidIO Outbound Window Base Address Register 7 */ - char res33[4]; - uint rowar7; /* 0xd0cf0 - RapidIO Outbound Attributes Register 7 */ - char res34[12]; - uint rowtar8; /* 0xd0d00 - RapidIO Outbound Window Translation Address Register 8 */ - char res35[4]; - uint rowbar8; /* 0xd0d08 - RapidIO Outbound Window Base Address Register 8 */ - char res36[4]; - uint rowar8; /* 0xd0d10 - RapidIO Outbound Attributes Register 8 */ - char res37[76]; - uint riwtar4; /* 0xd0d60 - RapidIO Inbound Window Translation Address Register 4 */ - char res38[4]; - uint riwbar4; /* 0xd0d68 - RapidIO Inbound Window Base Address Register 4 */ - char res39[4]; - uint riwar4; /* 0xd0d70 - RapidIO Inbound Attributes Register 4 */ - char res40[12]; - uint riwtar3; /* 0xd0d80 - RapidIO Inbound Window Translation Address Register 3 */ - char res41[4]; - uint riwbar3; /* 0xd0d88 - RapidIO Inbound Window Base Address Register 3 */ - char res42[4]; - uint riwar3; /* 0xd0d90 - RapidIO Inbound Attributes Register 3 */ - char res43[12]; - uint riwtar2; /* 0xd0da0 - RapidIO Inbound Window Translation Address Register 2 */ - char res44[4]; - uint riwbar2; /* 0xd0da8 - RapidIO Inbound Window Base Address Register 2 */ - char res45[4]; - uint riwar2; /* 0xd0db0 - RapidIO Inbound Attributes Register 2 */ - char res46[12]; - uint riwtar1; /* 0xd0dc0 - RapidIO Inbound Window Translation Address Register 1 */ - char res47[4]; - uint riwbar1; /* 0xd0dc8 - RapidIO Inbound Window Base Address Register 1 */ - char res48[4]; - uint riwar1; /* 0xd0dd0 - RapidIO Inbound Attributes Register 1 */ - char res49[12]; - uint riwtar0; /* 0xd0de0 - RapidIO Inbound Window Translation Address Register 0 */ - char res50[12]; - uint riwar0; /* 0xd0df0 - RapidIO Inbound Attributes Register 0 */ - char res51[12]; - uint pnfedr; /* 0xd0e00 - Port Notification/Fatal Error Detect Register */ - uint pnfedir; /* 0xd0e04 - Port Notification/Fatal Error Detect Register */ - uint pnfeier; /* 0xd0e08 - Port Notification/Fatal Error Interrupt Enable Register */ - uint pecr; /* 0xd0e0c - Port Error Control Register */ - uint pepcsr0; /* 0xd0e10 - Port Error Packet/Control Symbol Register 0 */ - uint pepr1; /* 0xd0e14 - Port Error Packet Register 1 */ - uint pepr2; /* 0xd0e18 - Port Error Packet Register 2 */ - char res52[4]; - uint predr; /* 0xd0e20 - Port Recoverable Error Detect Register */ - char res53[4]; - uint pertr; /* 0xd0e28 - Port Error Recovery Threshold Register */ - uint prtr; /* 0xd0e2c - Port Retry Threshold Register */ - char res54[464]; - uint omr; /* 0xd1000 - Outbound Mode Register */ - uint osr; /* 0xd1004 - Outbound Status Register */ - uint eodqtpar; /* 0xd1008 - Extended Outbound Descriptor Queue Tail Pointer Address Register */ - uint odqtpar; /* 0xd100c - Outbound Descriptor Queue Tail Pointer Address Register */ - uint eosar; /* 0xd1010 - Extended Outbound Unit Source Address Register */ - uint osar; /* 0xd1014 - Outbound Unit Source Address Register */ - uint odpr; /* 0xd1018 - Outbound Destination Port Register */ - uint odatr; /* 0xd101c - Outbound Destination Attributes Register */ - uint odcr; /* 0xd1020 - Outbound Doubleword Count Register */ - uint eodqhpar; /* 0xd1024 - Extended Outbound Descriptor Queue Head Pointer Address Register */ - uint odqhpar; /* 0xd1028 - Outbound Descriptor Queue Head Pointer Address Register */ - char res55[52]; - uint imr; /* 0xd1060 - Outbound Mode Register */ - uint isr; /* 0xd1064 - Inbound Status Register */ - uint eidqtpar; /* 0xd1068 - Extended Inbound Descriptor Queue Tail Pointer Address Register */ - uint idqtpar; /* 0xd106c - Inbound Descriptor Queue Tail Pointer Address Register */ - uint eifqhpar; /* 0xd1070 - Extended Inbound Frame Queue Head Pointer Address Register */ - uint ifqhpar; /* 0xd1074 - Inbound Frame Queue Head Pointer Address Register */ - char res56[1000]; - uint dmr; /* 0xd1460 - Doorbell Mode Register */ - uint dsr; /* 0xd1464 - Doorbell Status Register */ - uint edqtpar; /* 0xd1468 - Extended Doorbell Queue Tail Pointer Address Register */ - uint dqtpar; /* 0xd146c - Doorbell Queue Tail Pointer Address Register */ - uint edqhpar; /* 0xd1470 - Extended Doorbell Queue Head Pointer Address Register */ - uint dqhpar; /* 0xd1474 - Doorbell Queue Head Pointer Address Register */ - char res57[104]; - uint pwmr; /* 0xd14e0 - Port-Write Mode Register */ - uint pwsr; /* 0xd14e4 - Port-Write Status Register */ - uint epwqbar; /* 0xd14e8 - Extended Port-Write Queue Base Address Register */ - uint pwqbar; /* 0xd14ec - Port-Write Queue Base Address Register */ - char res58[60176]; + u32 didcar; /* Device Identity Capability */ + u32 dicar; /* Device Information Capability */ + u32 aidcar; /* Assembly Identity Capability */ + u32 aicar; /* Assembly Information Capability */ + u32 pefcar; /* Processing Element Features Capability */ + u32 spicar; /* Switch Port Information Capability */ + u32 socar; /* Source Operations Capability */ + u32 docar; /* Destination Operations Capability */ + u8 res1[32]; + u32 msr; /* Mailbox Cmd And Status */ + u32 pwdcsr; /* Port-Write & Doorbell Cmd And Status */ + u8 res2[4]; + u32 pellccsr; /* Processing Element Logic Layer CCSR */ + u8 res3[12]; + u32 lcsbacsr; /* Local Cfg Space Base Addr Cmd & Status */ + u32 bdidcsr; /* Base Device ID Cmd & Status */ + u8 res4[4]; + u32 hbdidlcsr; /* Host Base Device ID Lock Cmd & Status */ + u32 ctcsr; /* Component Tag Cmd & Status */ + u8 res5[144]; + u32 pmbh0csr; /* Port Maint. Block Hdr 0 Cmd & Status */ + u8 res6[28]; + u32 pltoccsr; /* Port Link Time-out Ctrl Cmd & Status */ + u32 prtoccsr; /* Port Response Time-out Ctrl Cmd & Status */ + u8 res7[20]; + u32 pgccsr; /* Port General Cmd & Status */ + u32 plmreqcsr; /* Port Link Maint. Request Cmd & Status */ + u32 plmrespcsr; /* Port Link Maint. Response Cmd & Status */ + u32 plascsr; /* Port Local Ackid Status Cmd & Status */ + u8 res8[12]; + u32 pescsr; /* Port Error & Status Cmd & Status */ + u32 pccsr; /* Port Control Cmd & Status */ + u8 res9[65184]; + u32 cr; /* Port Control Cmd & Status */ + u8 res10[12]; + u32 pcr; /* Port Configuration */ + u32 peir; /* Port Error Injection */ + u8 res11[3048]; + u32 rowtar0; /* RIO Outbound Window Translation Addr 0 */ + u8 res12[12]; + u32 rowar0; /* RIO Outbound Attrs 0 */ + u8 res13[12]; + u32 rowtar1; /* RIO Outbound Window Translation Addr 1 */ + u8 res14[4]; + u32 rowbar1; /* RIO Outbound Window Base Addr 1 */ + u8 res15[4]; + u32 rowar1; /* RIO Outbound Attrs 1 */ + u8 res16[12]; + u32 rowtar2; /* RIO Outbound Window Translation Addr 2 */ + u8 res17[4]; + u32 rowbar2; /* RIO Outbound Window Base Addr 2 */ + u8 res18[4]; + u32 rowar2; /* RIO Outbound Attrs 2 */ + u8 res19[12]; + u32 rowtar3; /* RIO Outbound Window Translation Addr 3 */ + u8 res20[4]; + u32 rowbar3; /* RIO Outbound Window Base Addr 3 */ + u8 res21[4]; + u32 rowar3; /* RIO Outbound Attrs 3 */ + u8 res22[12]; + u32 rowtar4; /* RIO Outbound Window Translation Addr 4 */ + u8 res23[4]; + u32 rowbar4; /* RIO Outbound Window Base Addr 4 */ + u8 res24[4]; + u32 rowar4; /* RIO Outbound Attrs 4 */ + u8 res25[12]; + u32 rowtar5; /* RIO Outbound Window Translation Addr 5 */ + u8 res26[4]; + u32 rowbar5; /* RIO Outbound Window Base Addr 5 */ + u8 res27[4]; + u32 rowar5; /* RIO Outbound Attrs 5 */ + u8 res28[12]; + u32 rowtar6; /* RIO Outbound Window Translation Addr 6 */ + u8 res29[4]; + u32 rowbar6; /* RIO Outbound Window Base Addr 6 */ + u8 res30[4]; + u32 rowar6; /* RIO Outbound Attrs 6 */ + u8 res31[12]; + u32 rowtar7; /* RIO Outbound Window Translation Addr 7 */ + u8 res32[4]; + u32 rowbar7; /* RIO Outbound Window Base Addr 7 */ + u8 res33[4]; + u32 rowar7; /* RIO Outbound Attrs 7 */ + u8 res34[12]; + u32 rowtar8; /* RIO Outbound Window Translation Addr 8 */ + u8 res35[4]; + u32 rowbar8; /* RIO Outbound Window Base Addr 8 */ + u8 res36[4]; + u32 rowar8; /* RIO Outbound Attrs 8 */ + u8 res37[76]; + u32 riwtar4; /* RIO Inbound Window Translation Addr 4 */ + u8 res38[4]; + u32 riwbar4; /* RIO Inbound Window Base Addr 4 */ + u8 res39[4]; + u32 riwar4; /* RIO Inbound Attrs 4 */ + u8 res40[12]; + u32 riwtar3; /* RIO Inbound Window Translation Addr 3 */ + u8 res41[4]; + u32 riwbar3; /* RIO Inbound Window Base Addr 3 */ + u8 res42[4]; + u32 riwar3; /* RIO Inbound Attrs 3 */ + u8 res43[12]; + u32 riwtar2; /* RIO Inbound Window Translation Addr 2 */ + u8 res44[4]; + u32 riwbar2; /* RIO Inbound Window Base Addr 2 */ + u8 res45[4]; + u32 riwar2; /* RIO Inbound Attrs 2 */ + u8 res46[12]; + u32 riwtar1; /* RIO Inbound Window Translation Addr 1 */ + u8 res47[4]; + u32 riwbar1; /* RIO Inbound Window Base Addr 1 */ + u8 res48[4]; + u32 riwar1; /* RIO Inbound Attrs 1 */ + u8 res49[12]; + u32 riwtar0; /* RIO Inbound Window Translation Addr 0 */ + u8 res50[12]; + u32 riwar0; /* RIO Inbound Attrs 0 */ + u8 res51[12]; + u32 pnfedr; /* Port Notification/Fatal Error Detect */ + u32 pnfedir; /* Port Notification/Fatal Error Detect */ + u32 pnfeier; /* Port Notification/Fatal Error IRQ Enable */ + u32 pecr; /* Port Error Control */ + u32 pepcsr0; /* Port Error Packet/Control Symbol 0 */ + u32 pepr1; /* Port Error Packet 1 */ + u32 pepr2; /* Port Error Packet 2 */ + u8 res52[4]; + u32 predr; /* Port Recoverable Error Detect */ + u8 res53[4]; + u32 pertr; /* Port Error Recovery Threshold */ + u32 prtr; /* Port Retry Threshold */ + u8 res54[464]; + u32 omr; /* Outbound Mode */ + u32 osr; /* Outbound Status */ + u32 eodqtpar; /* Extended Outbound Desc Queue Tail Ptr Addr */ + u32 odqtpar; /* Outbound Desc Queue Tail Ptr Addr */ + u32 eosar; /* Extended Outbound Unit Source Addr */ + u32 osar; /* Outbound Unit Source Addr */ + u32 odpr; /* Outbound Destination Port */ + u32 odatr; /* Outbound Destination Attrs */ + u32 odcr; /* Outbound Doubleword Count */ + u32 eodqhpar; /* Extended Outbound Desc Queue Head Ptr Addr */ + u32 odqhpar; /* Outbound Desc Queue Head Ptr Addr */ + u8 res55[52]; + u32 imr; /* Outbound Mode */ + u32 isr; /* Inbound Status */ + u32 eidqtpar; /* Extended Inbound Desc Queue Tail Ptr Addr */ + u32 idqtpar; /* Inbound Desc Queue Tail Ptr Addr */ + u32 eifqhpar; /* Extended Inbound Frame Queue Head Ptr Addr */ + u32 ifqhpar; /* Inbound Frame Queue Head Ptr Addr */ + u8 res56[1000]; + u32 dmr; /* Doorbell Mode */ + u32 dsr; /* Doorbell Status */ + u32 edqtpar; /* Extended Doorbell Queue Tail Ptr Addr */ + u32 dqtpar; /* Doorbell Queue Tail Ptr Addr */ + u32 edqhpar; /* Extended Doorbell Queue Head Ptr Addr */ + u32 dqhpar; /* Doorbell Queue Head Ptr Addr */ + u8 res57[104]; + u32 pwmr; /* Port-Write Mode */ + u32 pwsr; /* Port-Write Status */ + u32 epwqbar; /* Extended Port-Write Queue Base Addr */ + u32 pwqbar; /* Port-Write Queue Base Addr */ + u8 res58[60176]; } ccsr_rio_t;
-/* Quick Engine Block Pin Muxing Registers (0xe_0100 - 0xe_01bf) */ +/* Quick Engine Block Pin Muxing Registers */ typedef struct par_io { - uint cpodr; /* 0x100 */ - uint cpdat; /* 0x104 */ - uint cpdir1; /* 0x108 */ - uint cpdir2; /* 0x10c */ - uint cppar1; /* 0x110 */ - uint cppar2; /* 0x114 */ - char res[8]; -}par_io_t; + u32 cpodr; + u32 cpdat; + u32 cpdir1; + u32 cpdir2; + u32 cppar1; + u32 cppar2; + u8 res[8]; +} par_io_t;
-/* - * Global Utilities Register Block(0xe_0000-0xf_ffff) - */ +/* Global Utilities Block */ #ifdef CONFIG_FSL_CORENET typedef struct ccsr_gur { - u32 porsr1; /* 0xe0000 - POR status register */ - u8 res1[28]; /* 0xe0004 - 0xe001c Reserved: PORSRn */ - u32 gpporcr1; /* 0xe0020 - General-purpose POR configuration register */ + u32 porsr1; /* POR status */ + u8 res1[28]; + u32 gpporcr1; /* General-purpose POR configuration */ u8 res2[12]; - u32 gpiocr; /* 0xe0030 - GPIO control register */ + u32 gpiocr; /* GPIO control */ u8 res3[12]; - u32 gpoutdr; /* 0xe0040 - General-purpose output data register */ + u32 gpoutdr; /* General-purpose output data */ u8 res4[12]; - u32 gpindr; /* 0xe0050 - General-purpose input data register */ + u32 gpindr; /* General-purpose input data */ u8 res5[12]; - u32 pmuxcr; /* 0xe0060 - Alternate function signal multiplex control */ + u32 pmuxcr; /* Alt function signal multiplex control */ u8 res6[12]; - u32 devdisr; /* 0xe0070 - Device disable control */ + u32 devdisr; /* Device disable control */ #define FSL_CORENET_DEVDISR_PCIE1 0x80000000 #define FSL_CORENET_DEVDISR_PCIE2 0x40000000 #define FSL_CORENET_DEVDISR_PCIE3 0x20000000 @@ -1606,157 +1584,157 @@ typedef struct ccsr_gur { #define FSL_CORENET_DEVDISR_DUART1 0x00000002 #define FSL_CORENET_DEVDISR_DUART2 0x00000001 u8 res7[12]; - u32 powmgtcsr; /* 0xe0080 - Power management status and control register */ + u32 powmgtcsr; /* Power management status & control */ u8 res8[12]; - u32 coredisru; /* 0xe0090 - uppper portion for support of 64 cores */ - u32 coredisrl; /* 0xe0094 - lower portion for support of 64 cores */ + u32 coredisru; /* uppper portion for support of 64 cores */ + u32 coredisrl; /* lower portion for support of 64 cores */ u8 res9[8]; - u32 pvr; /* 0xe00a0 - Processor version register */ - u32 svr; /* 0xe00a4 - System version register */ + u32 pvr; /* Processor version */ + u32 svr; /* System version */ u8 res10[8]; - u32 rstcr; /* 0xe00b0 - Reset control register */ - u32 rstrqpblsr; /* 0xe00b4 - Reset request preboot loader status register */ + u32 rstcr; /* Reset control */ + u32 rstrqpblsr; /* Reset request preboot loader status */ u8 res11[8]; - u32 rstrqmr1; /* 0xe00c0 - Reset request mask register */ - u8 res12[4]; /* Reserved: RSTRQMR2 */ - u32 rstrqsr1; /* 0xe00c8 - Reset request status register */ - u8 res13[4]; /* Reserved: RSTRQSR2 */ - u8 res14[4]; /* Reserved: RSTRQWDTMRU */ - u32 rstrqwdtmrl; /* 0xe00d4 - Reset request WDT mask register */ - u8 res15[4]; /* Reserved: RSTRQWDTSRU */ - u32 rstrqwdtsrl; /* 0xe00dc - Reset request WDT status register */ - u8 res16[4]; /* Reserved: BRRU max total of 2 for up to 64 cores */ - u32 brrl; /* 0xe00e4 Boot release register */ + u32 rstrqmr1; /* Reset request mask */ + u8 res12[4]; + u32 rstrqsr1; /* Reset request status */ + u8 res13[4]; + u8 res14[4]; + u32 rstrqwdtmrl; /* Reset request WDT mask */ + u8 res15[4]; + u32 rstrqwdtsrl; /* Reset request WDT status */ + u8 res16[4]; + u32 brrl; /* Boot release */ u8 res17[24]; - u32 rcwsr[16]; /* 0xe0100 - 0xe013c: Reset control word status register */ + u32 rcwsr[16]; /* Reset control word status */ #define FSL_CORENET_RCWSR4_SRDS_PRTCL 0xfc000000 #define FSL_CORENET_RCWSR5_DDR_SYNC 0x00008000 #define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 15 #define FSL_CORENET_RCWSR7_MCK_TO_PLAT_RAT 0x00400000 #define FSL_CORENET_RCWSR8_HOST_AGT_B1 0x00e00000 #define FSL_CORENET_RCWSR8_HOST_AGT_B2 0x00100000 - u8 res18[192]; /* Reserved: RCWSRn (max total of 64)*/ - u32 scratchrw[4]; /* 0xe0200 - 0xe020c: Scratch Read/Write register */ - u8 res19[240]; /* Reserved: SCRATCHRWn (max total of 64)*/ - u32 scratchw1r[4]; /* 0xe0300 - 0xe030c: Scratch Read register (Write once) */ - u8 res20[240]; /* Reserved: SCRATCHW1Rn (max total of 64)*/ - u32 scrtsr[8]; /* 0xe0400 - 0xe041c: Core reset status register */ - u8 res21[224]; /* Reserved: CRSTSRn (max total of 64 for up to 64 cores)*/ - u32 pex1liodnr; /* 0xe0500 PCI Express 1 Logical I/O Device Number register*/ - u32 pex2liodnr; /* 0xe0504 PCI Express 2 Logical I/O Device Number register*/ - u32 pex3liodnr; /* 0xe0508 PCI Express 3 Logical I/O Device Number register*/ - u32 pex4liodnr; /* 0xe050c PCI Express 4 Logical I/O Device Number register*/ - u32 rio1liodnr; /* 0xe0510 RIO 1 Logical I/O Device Number register*/ - u32 rio2liodnr; /* 0xe0514 RIO 2 Logical I/O Device Number register*/ - u32 rio3liodnr; /* 0xe0518 RIO 3 Logical I/O Device Number register*/ - u32 rio4liodnr; /* 0xe051c RIO 4 Logical I/O Device Number register*/ - u32 usb1liodnr; /* 0xe0520 USB 1 Logical I/O Device Number register*/ - u32 usb2liodnr; /* 0xe0524 USB 2 Logical I/O Device Number register*/ - u32 usb3liodnr; /* 0xe0528 USB 3 Logical I/O Device Number register*/ - u32 usb4liodnr; /* 0xe052c USB 4 Logical I/O Device Number register*/ - u32 sdmmc1liodnr; /* 0xe0530 SD/MMC 1 Logical I/O Device Number register*/ - u32 sdmmc2liodnr; /* 0xe0534 SD/MMC 2 Logical I/O Device Number register*/ - u32 sdmmc3liodnr; /* 0xe0538 SD/MMC 3 Logical I/O Device Number register*/ - u32 sdmmc4liodnr; /* 0xe053c SD/MMC 4 Logical I/O Device Number register*/ - u32 rmuliodnr; /* 0xe0540 RIO Message Unit Logical I/O Device Number register*/ - u32 rduliodnr; /* 0xe0544 RIO Doorbell Unit Logical I/O Device Number register*/ - u32 rpwuliodnr; /* 0xe0548 RIO Port Write Unit Logical I/O Device Number register*/ - u8 res22[52]; /* Reserved: for future LIODN register expansion */ - u32 dma1liodnr; /* 0xe0580 DMA 1 Logical I/O Device Number register*/ - u32 dma2liodnr; /* 0xe0584 DMA 2 Logical I/O Device Number register*/ - u32 dma3liodnr; /* 0xe0588 DMA 3 Logical I/O Device Number register*/ - u32 dma4liodnr; /* 0xe058c DMA 4 Logical I/O Device Number register*/ - u8 res23[48]; /* Reserved: for future LIODN register expansion */ - u8 res24[64]; /* Reserved */ - u32 pblsr; /* 0xe0600 Preboot loader status register*/ - u32 pamubypenr; /* 0xe0604 PAMU bypass enable register*/ - u32 dmacr1; /* 0xe0608 DMA control register*/ - u8 res25[4]; /* Reserved: DMACR2 (max total of 2)*/ - u32 gensr1; /* 0xe0610 General status register*/ - u8 res26[12]; /* Reserved: GENSRn (max total of 4)*/ - u32 gencr1; /* 0xe0620 General control register*/ - u8 res27[12]; /* Reserved: GENCRn (max total of 4)*/ - u8 res28[4]; /* Reserved: CGENSRU (upper portion for support of 64 cores) */ - u32 cgensrl; /* 0xe0634 Core general status register*/ - u8 res29[8]; /* Reserved */ - u8 res30[4]; /* Reserved: CGENCRU (upper portion for support of 64 cores) */ - u32 cgencrl; /* 0xe0634 Core general control register*/ - u8 res31[184]; /* Reserved 0xe0648 - 0xe06fc */ - u32 sriopstecr; /* 0xe0700 SRIO prescaler timer enable control register*/ - u8 res32[2300]; /* Reserved 0xe0704 - 0xe0ffc */ + u8 res18[192]; + u32 scratchrw[4]; /* Scratch Read/Write */ + u8 res19[240]; + u32 scratchw1r[4]; /* Scratch Read (Write once) */ + u8 res20[240]; + u32 scrtsr[8]; /* Core reset status */ + u8 res21[224]; + u32 pex1liodnr; /* PCI Express 1 LIODN */ + u32 pex2liodnr; /* PCI Express 2 LIODN */ + u32 pex3liodnr; /* PCI Express 3 LIODN */ + u32 pex4liodnr; /* PCI Express 4 LIODN */ + u32 rio1liodnr; /* RIO 1 LIODN */ + u32 rio2liodnr; /* RIO 2 LIODN */ + u32 rio3liodnr; /* RIO 3 LIODN */ + u32 rio4liodnr; /* RIO 4 LIODN */ + u32 usb1liodnr; /* USB 1 LIODN */ + u32 usb2liodnr; /* USB 2 LIODN */ + u32 usb3liodnr; /* USB 3 LIODN */ + u32 usb4liodnr; /* USB 4 LIODN */ + u32 sdmmc1liodnr; /* SD/MMC 1 LIODN */ + u32 sdmmc2liodnr; /* SD/MMC 2 LIODN */ + u32 sdmmc3liodnr; /* SD/MMC 3 LIODN */ + u32 sdmmc4liodnr; /* SD/MMC 4 LIODN */ + u32 rmuliodnr; /* RIO Message Unit LIODN */ + u32 rduliodnr; /* RIO Doorbell Unit LIODN */ + u32 rpwuliodnr; /* RIO Port Write Unit LIODN */ + u8 res22[52]; + u32 dma1liodnr; /* DMA 1 LIODN */ + u32 dma2liodnr; /* DMA 2 LIODN */ + u32 dma3liodnr; /* DMA 3 LIODN */ + u32 dma4liodnr; /* DMA 4 LIODN */ + u8 res23[48]; + u8 res24[64]; + u32 pblsr; /* Preboot loader status */ + u32 pamubypenr; /* PAMU bypass enable */ + u32 dmacr1; /* DMA control */ + u8 res25[4]; + u32 gensr1; /* General status */ + u8 res26[12]; + u32 gencr1; /* General control */ + u8 res27[12]; + u8 res28[4]; + u32 cgensrl; /* Core general status */ + u8 res29[8]; + u8 res30[4]; + u32 cgencrl; /* Core general control */ + u8 res31[184]; + u32 sriopstecr; /* SRIO prescaler timer enable control */ + u8 res32[2300]; } ccsr_gur_t;
typedef struct ccsr_clk { - u32 clkc0csr; /* 0xe1000 - Core 0 Clock control/status register */ - u8 res1[0x1c]; - u32 clkc1csr; /* 0xe1020 - Core 1 Clock control/status register */ - u8 res2[0x1c]; - u32 clkc2csr; /* 0xe1040 - Core 2 Clock control/status register */ - u8 res3[0x1c]; - u32 clkc3csr; /* 0xe1060 - Core 3 Clock control/status register */ - u8 res4[0x1c]; - u32 clkc4csr; /* 0xe1080 - Core 4 Clock control/status register */ - u8 res5[0x1c]; - u32 clkc5csr; /* 0xe10a0 - Core 5 Clock control/status register */ - u8 res6[0x1c]; - u32 clkc6csr; /* 0xe10c0 - Core 6 Clock control/status register */ - u8 res7[0x1c]; - u32 clkc7csr; /* 0xe10e0 - Core 7 Clock control/status register */ - u8 res8[0x71c]; - u32 pllc1gsr; /* 0xe1800 - Cluster PLL 1 General Status Register */ - u8 res10[0x1c]; - u32 pllc2gsr; /* 0xe1820 - Cluster PLL 2 General Status Register */ - u8 res11[0x1c]; - u32 pllc3gsr; /* 0xe1840 - Cluster PLL 3 General Status Register */ - u8 res12[0x1c]; - u32 pllc4gsr; /* 0xe1860 - Cluster PLL 4 General Status Register */ - u8 res13[0x39c]; - u32 pllpgsr; /* 0xe1c00 - Platform PLL General Status Register */ - u8 res14[0x1c]; - u32 plldgsr; /* 0xe1c20 - DDR PLL General Status Register */ - u8 res15[0x3dc]; + u32 clkc0csr; /* Core 0 Clock control/status */ + u8 res1[0x1c]; + u32 clkc1csr; /* Core 1 Clock control/status */ + u8 res2[0x1c]; + u32 clkc2csr; /* Core 2 Clock control/status */ + u8 res3[0x1c]; + u32 clkc3csr; /* Core 3 Clock control/status */ + u8 res4[0x1c]; + u32 clkc4csr; /* Core 4 Clock control/status */ + u8 res5[0x1c]; + u32 clkc5csr; /* Core 5 Clock control/status */ + u8 res6[0x1c]; + u32 clkc6csr; /* Core 6 Clock control/status */ + u8 res7[0x1c]; + u32 clkc7csr; /* Core 7 Clock control/status */ + u8 res8[0x71c]; + u32 pllc1gsr; /* Cluster PLL 1 General Status */ + u8 res10[0x1c]; + u32 pllc2gsr; /* Cluster PLL 2 General Status */ + u8 res11[0x1c]; + u32 pllc3gsr; /* Cluster PLL 3 General Status */ + u8 res12[0x1c]; + u32 pllc4gsr; /* Cluster PLL 4 General Status */ + u8 res13[0x39c]; + u32 pllpgsr; /* Platform PLL General Status */ + u8 res14[0x1c]; + u32 plldgsr; /* DDR PLL General Status */ + u8 res15[0x3dc]; } ccsr_clk_t;
typedef struct ccsr_rcpm { - u8 res1[4]; /* 0xe2000 - Reserved */ - u32 cdozsrl; /* 0xe2004 - Core Doze Status Register */ - u8 res2[4]; /* 0xe2008 - Reserved */ - u32 cdozcrl; /* 0xe200c - Core Doze Control Register */ - u8 res3[4]; /* 0xe2010 - Reserved */ - u32 cnapsrl; /* 0xe2014 - Core Nap Status Register */ - u8 res4[4]; /* 0xe2018 - Reserved */ - u32 cnapcrl; /* 0xe201c - Core Nap Control Register */ - u8 res5[4]; /* 0xe2020 - Reserved */ - u32 cdozpsrl; /* 0xe2024 - Core Doze Previous Status Register */ - u8 res6[4]; /* 0xe2028 - Reserved */ - u32 cdozpcrl; /* 0xe202c - Core Doze Previous Control Register */ - u8 res7[4]; /* 0xe2030 - Reserved */ - u32 cwaitsrl; /* 0xe2034 - Core Wait Status Register */ - u8 res8[8]; /* Reserved */ - u32 powmgtcsr; /* 0xe2040 - Power Mangement Control & Status Register */ - u8 res9[12]; /* Reserved */ - u32 ippdexpcr0; /* 0xe2050 - IP Powerdown Exception Control Register 0 */ - u8 res10[12]; /* Reserved */ - u8 res11[4]; /* Reserved */ - u32 cpmimrl; /* 0xe2064 - Core Power Management Interrupt Masking Register */ - u8 res12[4]; /* Reserved */ - u32 cpmcimrl; /* 0xe206c - Core Power Management Critical Interrupt Masking Register */ - u8 res13[4]; /* Reserved */ - u32 cpmmcimrl; /* 0xe2074 - Core Power Management Machine Check Interrupt Masking Register */ - u8 res14[4]; /* Reserved */ - u32 cpmnmimrl; /* 0xe207c - Core Power Management NMI Masking Register */ - u8 res15[4]; /* Reserved */ - u32 ctbenrl; /* 0xe2084 - Core Time Base Enable Register */ - u8 res16[4]; /* Reserved */ - u32 ctbclkselrl; /* 0xe208c - Core Time Base Clock Select Register */ - u8 res17[4]; /* Reserved */ - u32 ctbhltcrl; /* 0xe2094 - Core Time Base Halt Control Register */ + u8 res1[4]; + u32 cdozsrl; /* Core Doze Status */ + u8 res2[4]; + u32 cdozcrl; /* Core Doze Control */ + u8 res3[4]; + u32 cnapsrl; /* Core Nap Status */ + u8 res4[4]; + u32 cnapcrl; /* Core Nap Control */ + u8 res5[4]; + u32 cdozpsrl; /* Core Doze Previous Status */ + u8 res6[4]; + u32 cdozpcrl; /* Core Doze Previous Control */ + u8 res7[4]; + u32 cwaitsrl; /* Core Wait Status */ + u8 res8[8]; + u32 powmgtcsr; /* Power Mangement Control & Status */ + u8 res9[12]; + u32 ippdexpcr0; /* IP Powerdown Exception Control 0 */ + u8 res10[12]; + u8 res11[4]; + u32 cpmimrl; /* Core PM IRQ Masking */ + u8 res12[4]; + u32 cpmcimrl; /* Core PM Critical IRQ Masking */ + u8 res13[4]; + u32 cpmmcimrl; /* Core PM Machine Check IRQ Masking */ + u8 res14[4]; + u32 cpmnmimrl; /* Core PM NMI Masking */ + u8 res15[4]; + u32 ctbenrl; /* Core Time Base Enable */ + u8 res16[4]; + u32 ctbclkselrl; /* Core Time Base Clock Select */ + u8 res17[4]; + u32 ctbhltcrl; /* Core Time Base Halt Control */ u8 res18[0xf68]; } ccsr_rcpm_t;
#else typedef struct ccsr_gur { - uint porpllsr; /* 0xe0000 - POR PLL ratio status register */ + u32 porpllsr; /* POR PLL ratio status */ #ifdef CONFIG_MPC8536 #define MPC85xx_PORPLLSR_DDR_RATIO 0x3e000000 #define MPC85xx_PORPLLSR_DDR_RATIO_SHIFT 25 @@ -1767,17 +1745,17 @@ typedef struct ccsr_gur { #define MPC85xx_PORPLLSR_QE_RATIO 0x3e000000 #define MPC85xx_PORPLLSR_QE_RATIO_SHIFT 25 #define MPC85xx_PORPLLSR_PLAT_RATIO 0x0000003e -#define MPC85xx_PORPLLSR_PLAT_RATIO_SHIFT 1 - uint porbmsr; /* 0xe0004 - POR boot mode status register */ +#define MPC85xx_PORPLLSR_PLAT_RATIO_SHIFT 1 + u32 porbmsr; /* POR boot mode status */ #define MPC85xx_PORBMSR_HA 0x00070000 #define MPC85xx_PORBMSR_HA_SHIFT 16 - uint porimpscr; /* 0xe0008 - POR I/O impedance status and control register */ - uint pordevsr; /* 0xe000c - POR I/O device status regsiter */ + u32 porimpscr; /* POR I/O impedance status & control */ + u32 pordevsr; /* POR I/O device status regsiter */ #define MPC85xx_PORDEVSR_SGMII1_DIS 0x20000000 #define MPC85xx_PORDEVSR_SGMII2_DIS 0x10000000 #define MPC85xx_PORDEVSR_SGMII3_DIS 0x08000000 #define MPC85xx_PORDEVSR_SGMII4_DIS 0x04000000 -#define MPC85xx_PORDEVSR_SRDS2_IO_SEL 0x38000000 +#define MPC85xx_PORDEVSR_SRDS2_IO_SEL 0x38000000 #define MPC85xx_PORDEVSR_PCI1 0x00800000 #define MPC85xx_PORDEVSR_IO_SEL 0x00780000 #define MPC85xx_PORDEVSR_IO_SEL_SHIFT 19 @@ -1789,36 +1767,32 @@ typedef struct ccsr_gur { #define MPC85xx_PORDEVSR_DRAM_RTYPE 0x00000060 #define MPC85xx_PORDEVSR_RIO_CTLS 0x00000008 #define MPC85xx_PORDEVSR_RIO_DEV_ID 0x00000007 - uint pordbgmsr; /* 0xe0010 - POR debug mode status register */ - uint pordevsr2; /* 0xe0014 - POR I/O device status regsiter 2 */ + u32 pordbgmsr; /* POR debug mode status */ + u32 pordevsr2; /* POR I/O device status 2 */ /* The 8544 RM says this is bit 26, but it's really bit 24 */ #define MPC85xx_PORDEVSR2_SEC_CFG 0x00000080 - char res1[8]; - uint gpporcr; /* 0xe0020 - General-purpose POR configuration register */ - char res2[12]; - uint gpiocr; /* 0xe0030 - GPIO control register */ - char res3[12]; + u8 res1[8]; + u32 gpporcr; /* General-purpose POR configuration */ + u8 res2[12]; + u32 gpiocr; /* GPIO control */ + u8 res3[12]; #if defined(CONFIG_MPC8569) - uint plppar1; - /* 0xe0040 - Platform port pin assignment register 1 */ - uint plppar2; - /* 0xe0044 - Platform port pin assignment register 2 */ - uint plpdir1; - /* 0xe0048 - Platform port pin direction register 1 */ - uint plpdir2; - /* 0xe004c - Platform port pin direction register 2 */ + u32 plppar1; /* Platform port pin assignment 1 */ + u32 plppar2; /* Platform port pin assignment 2 */ + u32 plpdir1; /* Platform port pin direction 1 */ + u32 plpdir2; /* Platform port pin direction 2 */ #else - uint gpoutdr; /* 0xe0040 - General-purpose output data register */ - char res4[12]; + u32 gpoutdr; /* General-purpose output data */ + u8 res4[12]; #endif - uint gpindr; /* 0xe0050 - General-purpose input data register */ - char res5[12]; - uint pmuxcr; /* 0xe0060 - Alternate function signal multiplex control */ + u32 gpindr; /* General-purpose input data */ + u8 res5[12]; + u32 pmuxcr; /* Alt. function signal multiplex control */ #define MPC85xx_PMUXCR_SD_DATA 0x80000000 #define MPC85xx_PMUXCR_SDHC_CD 0x40000000 #define MPC85xx_PMUXCR_SDHC_WP 0x20000000 - char res6[12]; - uint devdisr; /* 0xe0070 - Device disable control */ + u8 res6[12]; + u32 devdisr; /* Device disable control */ #define MPC85xx_DEVDISR_PCI1 0x80000000 #define MPC85xx_DEVDISR_PCI2 0x40000000 #define MPC85xx_DEVDISR_PCIE 0x20000000 @@ -1842,34 +1816,34 @@ typedef struct ccsr_gur { #define MPC85xx_DEVDISR_TSEC4 0x00000010 #define MPC85xx_DEVDISR_I2C 0x00000004 #define MPC85xx_DEVDISR_DUART 0x00000002 - char res7[12]; - uint powmgtcsr; /* 0xe0080 - Power management status and control register */ - char res8[12]; - uint mcpsumr; /* 0xe0090 - Machine check summary register */ - char res9[12]; - uint pvr; /* 0xe00a0 - Processor version register */ - uint svr; /* 0xe00a4 - System version register */ - char res10a[8]; - uint rstcr; /* 0xe00b0 - Reset control register */ + u8 res7[12]; + u32 powmgtcsr; /* Power management status & control */ + u8 res8[12]; + u32 mcpsumr; /* Machine check summary */ + u8 res9[12]; + u32 pvr; /* Processor version */ + u32 svr; /* System version */ + u8 res10a[8]; + u32 rstcr; /* Reset control */ #if defined(CONFIG_MPC8568)||defined(CONFIG_MPC8569) - char res10b[76]; - par_io_t qe_par_io[7]; /* 0xe0100 - 0xe01bf */ - char res10c[3136]; + u8 res10b[76]; + par_io_t qe_par_io[7]; + u8 res10c[3136]; #else - char res10b[3404]; + u8 res10b[3404]; #endif - uint clkocr; /* 0xe0e00 - Clock out select register */ - char res11[12]; - uint ddrdllcr; /* 0xe0e10 - DDR DLL control register */ - char res12[12]; - uint lbcdllcr; /* 0xe0e20 - LBC DLL control register */ - char res13[248]; - uint lbiuiplldcr0; /* 0xe0f1c -- LBIU PLL Debug Reg 0 */ - uint lbiuiplldcr1; /* 0xe0f20 -- LBIU PLL Debug Reg 1 */ - uint ddrioovcr; /* 0xe0f24 - DDR IO Override Control */ - uint tsec12ioovcr; /* 0xe0f28 - eTSEC 1/2 IO override control */ - uint tsec34ioovcr; /* 0xe0f2c - eTSEC 3/4 IO override control */ - char res15[61648]; /* 0xe0f30 to 0xefffff */ + u32 clkocr; /* Clock out select */ + u8 res11[12]; + u32 ddrdllcr; /* DDR DLL control */ + u8 res12[12]; + u32 lbcdllcr; /* LBC DLL control */ + u8 res13[248]; + u32 lbiuiplldcr0; /* LBIU PLL Debug Reg 0 */ + u32 lbiuiplldcr1; /* LBIU PLL Debug Reg 1 */ + u32 ddrioovcr; /* DDR IO Override Control */ + u32 tsec12ioovcr; /* eTSEC 1/2 IO override control */ + u32 tsec34ioovcr; /* eTSEC 3/4 IO override control */ + u8 res15[61648]; } ccsr_gur_t; #endif
@@ -1884,8 +1858,8 @@ typedef struct ccsr_gur { #define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x114000 #define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 -#define CONFIG_SYS_MPC85xx_QMAN_OFFSET 0x318000 -#define CONFIG_SYS_MPC85xx_BMAN_OFFSET 0x31a000 +#define CONFIG_SYS_FSL_CORENET_QMAN_OFFSET 0x318000 +#define CONFIG_SYS_FSL_CORENET_BMAN_OFFSET 0x31a000 #else #define CONFIG_SYS_MPC85xx_ECM_OFFSET 0x0000 #define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x2000 @@ -1899,6 +1873,7 @@ typedef struct ccsr_gur { #define CONFIG_SYS_MPC85xx_SATA2_OFFSET 0x19000 #define CONFIG_SYS_MPC85xx_L2_OFFSET 0x20000 #define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x21000 +#define CONFIG_SYS_MPC85xx_USB_OFFSET 0x22000 #define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x2e000 #define CONFIG_SYS_MPC85xx_SERDES2_OFFSET 0xE3100 #define CONFIG_SYS_MPC85xx_SERDES1_OFFSET 0xE3000 @@ -1908,31 +1883,53 @@ typedef struct ccsr_gur { #define CONFIG_SYS_MPC85xx_PIC_OFFSET 0x40000 #define CONFIG_SYS_MPC85xx_GUTS_OFFSET 0xE0000
-#define CONFIG_SYS_MPC85xx_QMAN_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_QMAN_OFFSET) -#define CONFIG_SYS_MPC85xx_BMAN_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_BMAN_OFFSET) -#define CONFIG_SYS_MPC85xx_GUTS_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GUTS_OFFSET) -#define CONFIG_SYS_FSL_CORENET_CCM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_CCM_OFFSET) -#define CONFIG_SYS_FSL_CORENET_CLK_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_CLK_OFFSET) -#define CONFIG_SYS_FSL_CORENET_RCPM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_RCPM_OFFSET) -#define CONFIG_SYS_MPC85xx_ECM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ECM_OFFSET) -#define CONFIG_SYS_MPC85xx_DDR_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DDR_OFFSET) -#define CONFIG_SYS_MPC85xx_DDR2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DDR2_OFFSET) -#define CONFIG_SYS_MPC85xx_LBC_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_LBC_OFFSET) -#define CONFIG_SYS_MPC85xx_ESPI_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ESPI_OFFSET) -#define CONFIG_SYS_MPC85xx_PCIX_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIX_OFFSET) -#define CONFIG_SYS_MPC85xx_PCIX2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIX2_OFFSET) -#define CONFIG_SYS_MPC85xx_GPIO_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GPIO_OFFSET) -#define CONFIG_SYS_MPC85xx_SATA1_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SATA1_OFFSET) -#define CONFIG_SYS_MPC85xx_SATA2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SATA2_OFFSET) -#define CONFIG_SYS_MPC85xx_L2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_L2_OFFSET) -#define CONFIG_SYS_MPC85xx_DMA_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DMA_OFFSET) -#define CONFIG_SYS_MPC85xx_ESDHC_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ESDHC_OFFSET) -#define CONFIG_SYS_MPC85xx_PIC_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PIC_OFFSET) -#define CONFIG_SYS_MPC85xx_CPM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_CPM_OFFSET) -#define CONFIG_SYS_MPC85xx_SERDES1_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES2_OFFSET) -#define CONFIG_SYS_MPC85xx_SERDES2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES2_OFFSET) -#define CONFIG_SYS_MPC85xx_USB_OFFSET 0x22000 +#define CONFIG_SYS_FSL_CORENET_QMAN_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_QMAN_OFFSET) +#define CONFIG_SYS_FSL_CORENET_BMAN_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_BMAN_OFFSET) +#define CONFIG_SYS_MPC85xx_GUTS_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GUTS_OFFSET) +#define CONFIG_SYS_FSL_CORENET_CCM_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_CCM_OFFSET) +#define CONFIG_SYS_FSL_CORENET_CLK_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_CLK_OFFSET) +#define CONFIG_SYS_FSL_CORENET_RCPM_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_RCPM_OFFSET) +#define CONFIG_SYS_MPC85xx_ECM_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ECM_OFFSET) +#define CONFIG_SYS_MPC85xx_DDR_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DDR_OFFSET) +#define CONFIG_SYS_MPC85xx_DDR2_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DDR2_OFFSET) +#define CONFIG_SYS_MPC85xx_LBC_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_LBC_OFFSET) +#define CONFIG_SYS_MPC85xx_ESPI_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ESPI_OFFSET) +#define CONFIG_SYS_MPC85xx_PCIX_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIX_OFFSET) +#define CONFIG_SYS_MPC85xx_PCIX2_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIX2_OFFSET) +#define CONFIG_SYS_MPC85xx_GPIO_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GPIO_OFFSET) +#define CONFIG_SYS_MPC85xx_SATA1_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SATA1_OFFSET) +#define CONFIG_SYS_MPC85xx_SATA2_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SATA2_OFFSET) +#define CONFIG_SYS_MPC85xx_L2_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_L2_OFFSET) +#define CONFIG_SYS_MPC85xx_DMA_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DMA_OFFSET) +#define CONFIG_SYS_MPC85xx_ESDHC_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ESDHC_OFFSET) +#define CONFIG_SYS_MPC85xx_PIC_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PIC_OFFSET) +#define CONFIG_SYS_MPC85xx_CPM_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_CPM_OFFSET) +#define CONFIG_SYS_MPC85xx_SERDES1_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES2_OFFSET) +#define CONFIG_SYS_MPC85xx_SERDES2_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES2_OFFSET) #define CONFIG_SYS_MPC85xx_USB_ADDR \ - (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_USB_OFFSET) + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_USB_OFFSET)
#endif /*__IMMAP_85xx__*/
On Sep 28, 2009, at 10:44 PM, Kumar Gala wrote:
- Converted all white space to tabs
- Converted all types to u8/u16/u32
- Reduce lines to fit in 80 columns
- Renamed MPC85xx_{Q,B}MAN -> FSL_CORENET_{Q,B}MAN
Signed-off-by: Kumar Gala galak@kernel.crashing.org
include/asm-ppc/immap_85xx.h | 3175 ++++++++++++++++++++ +--------------------- 1 files changed, 1586 insertions(+), 1589 deletions(-)
applied to 85xx
- k
Kumar Gala
