RK3399 and RK3568 are use different sdhci controllers. The drivers need to be updated to support these two platforms and it's easy to support new platforms.
Yifeng Zhao (2): mmc: rockchip_sdhci: add phy and clock config for rk3399 mmc: rockchip_sdhci: Add support for RK3568
drivers/mmc/rockchip_sdhci.c | 437 ++++++++++++++++++++++++++++++++--- 1 file changed, 406 insertions(+), 31 deletions(-)
Add clock, phy and other configuration, it is convenient to support new controller. Here a short summary of the changes: - support HS200 and HS400 config by dts - Remove OF_PLATDATA related code - Reorder header inclusion - Add data width config for 1, 4, 8 bits - Add phy ops - add ops set_ios_post to modify the parameters of phy when the clock changes
Signed-off-by: Yifeng Zhao yifeng.zhao@rock-chips.com ---
drivers/mmc/rockchip_sdhci.c | 334 +++++++++++++++++++++++++++++++---- 1 file changed, 303 insertions(+), 31 deletions(-)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index d95f8b2a15..05ed998eca 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -6,33 +6,285 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> +#include <dm/ofnode.h> #include <dt-structs.h> +#include <linux/delay.h> #include <linux/err.h> #include <linux/libfdt.h> #include <malloc.h> #include <mapmem.h> #include <sdhci.h> -#include <clk.h> +#include <syscon.h>
+#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/hardware.h> /* 400KHz is max freq for card ID etc. Use that as min */ #define EMMC_MIN_FREQ 400000 +#define KHz (1000) +#define MHz (1000 * KHz) + +#define PHYCTRL_CALDONE_MASK 0x1 +#define PHYCTRL_CALDONE_SHIFT 0x6 +#define PHYCTRL_CALDONE_DONE 0x1 +#define PHYCTRL_DLLRDY_MASK 0x1 +#define PHYCTRL_DLLRDY_SHIFT 0x5 +#define PHYCTRL_DLLRDY_DONE 0x1 +#define PHYCTRL_FREQSEL_200M 0x0 +#define PHYCTRL_FREQSEL_50M 0x1 +#define PHYCTRL_FREQSEL_100M 0x2 +#define PHYCTRL_FREQSEL_150M 0x3
struct rockchip_sdhc_plat { -#if CONFIG_IS_ENABLED(OF_PLATDATA) - struct dtd_rockchip_rk3399_sdhci_5_1 dtplat; -#endif struct mmc_config cfg; struct mmc mmc; };
+struct rockchip_emmc_phy { + u32 emmcphy_con[7]; + u32 reserved; + u32 emmcphy_status; +}; + struct rockchip_sdhc { struct sdhci_host host; + struct udevice *dev; void *base; + struct rockchip_emmc_phy *phy; + struct clk emmc_clk; +}; + +struct sdhci_data { + int (*emmc_set_clock)(struct sdhci_host *host, unsigned int clock); + int (*emmc_phy_init)(struct udevice *dev); + int (*get_phy)(struct udevice *dev); +}; + +static int rk3399_emmc_phy_init(struct udevice *dev) +{ + return 0; +} + +static void rk3399_emmc_phy_power_on(struct rockchip_emmc_phy *phy, u32 clock) +{ + u32 caldone, dllrdy, freqsel; + uint start; + + writel(RK_CLRSETBITS(7 << 4, 0), &phy->emmcphy_con[6]); + writel(RK_CLRSETBITS(1 << 11, 1 << 11), &phy->emmcphy_con[0]); + writel(RK_CLRSETBITS(0xf << 7, 6 << 7), &phy->emmcphy_con[0]); + + /* + * According to the user manual, calpad calibration + * cycle takes more than 2us without the minimal recommended + * value, so we may need a little margin here + */ + udelay(3); + writel(RK_CLRSETBITS(1, 1), &phy->emmcphy_con[6]); + + /* + * According to the user manual, it asks driver to + * wait 5us for calpad busy trimming. But it seems that + * 5us of caldone isn't enough for all cases. + */ + udelay(500); + caldone = readl(&phy->emmcphy_status); + caldone = (caldone >> PHYCTRL_CALDONE_SHIFT) & PHYCTRL_CALDONE_MASK; + if (caldone != PHYCTRL_CALDONE_DONE) { + printf("%s: caldone timeout.\n", __func__); + return; + } + + /* Set the frequency of the DLL operation */ + if (clock < 75 * MHz) + freqsel = PHYCTRL_FREQSEL_50M; + else if (clock < 125 * MHz) + freqsel = PHYCTRL_FREQSEL_100M; + else if (clock < 175 * MHz) + freqsel = PHYCTRL_FREQSEL_150M; + else + freqsel = PHYCTRL_FREQSEL_200M; + + /* Set the frequency of the DLL operation */ + writel(RK_CLRSETBITS(3 << 12, freqsel << 12), &phy->emmcphy_con[0]); + writel(RK_CLRSETBITS(1 << 1, 1 << 1), &phy->emmcphy_con[6]); + + start = get_timer(0); + + do { + udelay(1); + dllrdy = readl(&phy->emmcphy_status); + dllrdy = (dllrdy >> PHYCTRL_DLLRDY_SHIFT) & PHYCTRL_DLLRDY_MASK; + if (dllrdy == PHYCTRL_DLLRDY_DONE) + break; + } while (get_timer(start) < 50000); + + if (dllrdy != PHYCTRL_DLLRDY_DONE) + printf("%s: dllrdy timeout.\n", __func__); +} + +static void rk3399_emmc_phy_power_off(struct rockchip_emmc_phy *phy) +{ + writel(RK_CLRSETBITS(1, 0), &phy->emmcphy_con[6]); + writel(RK_CLRSETBITS(1 << 1, 0), &phy->emmcphy_con[6]); +} + +static int rockchip_emmc_set_clock(struct sdhci_host *host, unsigned int clock) +{ + unsigned int div, clk = 0, timeout; + unsigned int input_clk; + struct rockchip_sdhc *priv = + container_of(host, struct rockchip_sdhc, host); + + /* Wait max 20 ms */ + timeout = 2000; + while (sdhci_readl(host, SDHCI_PRESENT_STATE) & + (SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT)) { + if (timeout == 0) { + printf("%s: Timeout to wait cmd & data inhibit\n", + __func__); + return -EBUSY; + } + + timeout--; + udelay(10); + } + sdhci_writew(host, 0, SDHCI_CLOCK_CONTROL); + + if (clock == 0) + return 0; + + input_clk = clk_set_rate(&priv->emmc_clk, clock); + if (IS_ERR_VALUE(input_clk)) + input_clk = host->max_clk; + + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { + /* + * Check if the Host Controller supports Programmable Clock + * Mode. + */ + if (host->clk_mul) { + for (div = 1; div <= 1024; div++) { + if ((input_clk / div) <= clock) + break; + } + + /* + * Set Programmable Clock Mode in the Clock + * Control register. + */ + clk = SDHCI_PROG_CLOCK_MODE; + div--; + } else { + /* Version 3.00 divisors must be a multiple of 2. */ + if (input_clk <= clock) { + div = 1; + } else { + for (div = 2; + div < SDHCI_MAX_DIV_SPEC_300; + div += 2) { + if ((input_clk / div) <= clock) + break; + } + } + div >>= 1; + } + } else { + /* Version 2.00 divisors must be a power of 2. */ + for (div = 1; div < SDHCI_MAX_DIV_SPEC_200; div *= 2) { + if ((input_clk / div) <= clock) + break; + } + div >>= 1; + } + + clk |= (div & SDHCI_DIV_MASK) << SDHCI_DIVIDER_SHIFT; + clk |= ((div & SDHCI_DIV_HI_MASK) >> SDHCI_DIV_MASK_LEN) + << SDHCI_DIVIDER_HI_SHIFT; + clk |= SDHCI_CLOCK_INT_EN; + sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL); + + /* Wait max 20 ms */ + timeout = 2000; + while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL)) + & SDHCI_CLOCK_INT_STABLE)) { + if (timeout == 0) { + printf("%s: Internal clock never stabilised.\n", + __func__); + return -EBUSY; + } + timeout--; + udelay(10); + } + clk |= SDHCI_CLOCK_CARD_EN; + sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL); + host->clock = clock; + + return 0; +} + +static int rk3399_emmc_get_phy(struct udevice *dev) +{ + struct rockchip_sdhc *priv = dev_get_priv(dev); + + ofnode phy_node; + void *grf_base; + u32 grf_phy_offset, phandle; + + phandle = dev_read_u32_default(dev, "phys", 0); + phy_node = ofnode_get_by_phandle(phandle); + if (!ofnode_valid(phy_node)) { + debug("Not found emmc phy device\n"); + return -ENODEV; + } + + grf_base = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (grf_base < 0) + printf("%s Get syscon grf failed", __func__); + grf_phy_offset = ofnode_read_u32_default(phy_node, "reg", 0); + + priv->phy = (struct rockchip_emmc_phy *)(grf_base + grf_phy_offset); + + return 0; +} + +static int rk3399_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clock) +{ + struct rockchip_sdhc *priv = + container_of(host, struct rockchip_sdhc, host); + int cycle_phy = host->clock != clock && + clock > EMMC_MIN_FREQ; + + if (cycle_phy) + rk3399_emmc_phy_power_off(priv->phy); + + rockchip_emmc_set_clock(host, clock); + + if (cycle_phy) + rk3399_emmc_phy_power_on(priv->phy, clock); + + return 0; +} + +static int sdhci_set_ios_post(struct sdhci_host *host) +{ + struct mmc *mmc = host->mmc; + struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev); + + data->emmc_set_clock(host, mmc->clock); + + return 0; +} + +static struct sdhci_ops rockchip_sdhci_ops = { + .set_ios_post = sdhci_set_ios_post, };
-static int arasan_sdhci_probe(struct udevice *dev) +static int rockchip_sdhci_probe(struct udevice *dev) { + struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(dev); struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct rockchip_sdhc_plat *plat = dev_get_plat(dev); struct rockchip_sdhc *prv = dev_get_priv(dev); @@ -40,17 +292,22 @@ static int arasan_sdhci_probe(struct udevice *dev) int max_frequency, ret; struct clk clk;
-#if CONFIG_IS_ENABLED(OF_PLATDATA) - struct dtd_rockchip_rk3399_sdhci_5_1 *dtplat = &plat->dtplat; - - host->name = dev->name; - host->ioaddr = map_sysmem(dtplat->reg[0], dtplat->reg[1]); - max_frequency = dtplat->max_frequency; - ret = clk_get_by_driver_info(dev, dtplat->clocks, &clk); -#else max_frequency = dev_read_u32_default(dev, "max-frequency", 0); + switch (dev_read_u32_default(dev, "bus-width", 4)) { + case 8: + host->host_caps |= MMC_MODE_8BIT; + break; + case 4: + host->host_caps |= MMC_MODE_4BIT; + break; + case 1: + break; + default: + printf("Invalid "bus-width" value\n"); + return -EINVAL; + } ret = clk_get_by_index(dev, 0, &clk); -#endif + if (!ret) { ret = clk_set_rate(&clk, max_frequency); if (IS_ERR_VALUE(ret)) @@ -59,16 +316,25 @@ static int arasan_sdhci_probe(struct udevice *dev) printf("%s fail to get clk\n", __func__); }
+ prv->emmc_clk = clk; + prv->dev = dev; + ret = data->get_phy(dev); + if (ret) + return ret; + + ret = data->emmc_phy_init(dev); + if (ret) + return ret; + + host->ops = &rockchip_sdhci_ops; + host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD; host->max_clk = max_frequency; - /* - * The sdhci-driver only supports 4bit and 8bit, as sdhci_setup_cfg - * doesn't allow us to clear MMC_MODE_4BIT. Consequently, we don't - * check for other bus-width values. - */ - if (host->bus_width == 8) - host->host_caps |= MMC_MODE_8BIT;
+ if (dev_read_bool(dev, "mmc-hs200-1_8v")) + host->host_caps |= MMC_MODE_HS200; + else if (dev_read_bool(dev, "mmc-hs400-1_8v")) + host->host_caps |= MMC_MODE_HS400; host->mmc = &plat->mmc; host->mmc->priv = &prv->host; host->mmc->dev = dev; @@ -81,15 +347,12 @@ static int arasan_sdhci_probe(struct udevice *dev) return sdhci_probe(dev); }
-static int arasan_sdhci_of_to_plat(struct udevice *dev) +static int sdhci_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) struct sdhci_host *host = dev_get_priv(dev);
host->name = dev->name; host->ioaddr = dev_read_addr_ptr(dev); - host->bus_width = dev_read_u32_default(dev, "bus-width", 4); -#endif
return 0; } @@ -101,19 +364,28 @@ static int rockchip_sdhci_bind(struct udevice *dev) return sdhci_bind(dev, &plat->mmc, &plat->cfg); }
-static const struct udevice_id arasan_sdhci_ids[] = { - { .compatible = "arasan,sdhci-5.1" }, +static const struct sdhci_data rk3399_data = { + .emmc_set_clock = rk3399_sdhci_emmc_set_clock, + .get_phy = rk3399_emmc_get_phy, + .emmc_phy_init = rk3399_emmc_phy_init, +}; + +static const struct udevice_id sdhci_ids[] = { + { + .compatible = "arasan,sdhci-5.1", + .data = (ulong)&rk3399_data, + }, { } };
U_BOOT_DRIVER(arasan_sdhci_drv) = { - .name = "rockchip_rk3399_sdhci_5_1", + .name = "rockchip_sdhci_5_1", .id = UCLASS_MMC, - .of_match = arasan_sdhci_ids, - .of_to_plat = arasan_sdhci_of_to_plat, + .of_match = sdhci_ids, + .of_to_plat = sdhci_of_to_plat, .ops = &sdhci_ops, .bind = rockchip_sdhci_bind, - .probe = arasan_sdhci_probe, + .probe = rockchip_sdhci_probe, .priv_auto = sizeof(struct rockchip_sdhc), .plat_auto = sizeof(struct rockchip_sdhc_plat), };
Hi Yifeng,
- Add phy ops
Does it impossible to move to phy subsystem about codes relevant to phy?
- u32 emmcphy_con[7];
- u32 reserved;
- u32 emmcphy_status;
- struct udevice *dev; void *base;
- struct rockchip_emmc_phy *phy;
- struct clk emmc_clk;
- int (*emmc_set_clock)(struct sdhci_host *host, unsigned int clock);
- int (*emmc_phy_init)(struct udevice *dev);
- int (*get_phy)(struct udevice *dev);
- u32 caldone, dllrdy, freqsel;
- uint start;
- writel(RK_CLRSETBITS(7 << 4, 0), &phy->emmcphy_con[6]);
- writel(RK_CLRSETBITS(1 << 11, 1 << 11), &phy->emmcphy_con[0]);
- writel(RK_CLRSETBITS(0xf << 7, 6 << 7), &phy->emmcphy_con[0]);
- udelay(3);
- writel(RK_CLRSETBITS(1, 1), &phy->emmcphy_con[6]);
- udelay(500);
- caldone = readl(&phy->emmcphy_status);
- caldone = (caldone >> PHYCTRL_CALDONE_SHIFT) & PHYCTRL_CALDONE_MASK;
- if (caldone != PHYCTRL_CALDONE_DONE) {
return;
- /* Set the frequency of the DLL operation */
- if (clock < 75 * MHz)
- else if (clock < 125 * MHz)
- else if (clock < 175 * MHz)
- else
- writel(RK_CLRSETBITS(3 << 12, freqsel << 12), &phy->emmcphy_con[0]);
- writel(RK_CLRSETBITS(1 << 1, 1 << 1), &phy->emmcphy_con[6]);
- start = get_timer(0);
- do {
udelay(1);
break;
- } while (get_timer(start) < 50000);
- if (dllrdy != PHYCTRL_DLLRDY_DONE)
- writel(RK_CLRSETBITS(1, 0), &phy->emmcphy_con[6]);
- writel(RK_CLRSETBITS(1 << 1, 0), &phy->emmcphy_con[6]);
Does it impossible to reuse sdhci_set_clock()? It's almmost similar, except clk_set_rate().
- unsigned int div, clk = 0, timeout;
- unsigned int input_clk;
- struct rockchip_sdhc *priv =
- /* Wait max 20 ms */
- timeout = 2000;
- while (sdhci_readl(host, SDHCI_PRESENT_STATE) &
if (timeout == 0) {
__func__);
return -EBUSY;
timeout--;
udelay(10);
- sdhci_writew(host, 0, SDHCI_CLOCK_CONTROL);
- if (clock == 0)
- input_clk = clk_set_rate(&priv->emmc_clk, clock);
- if (IS_ERR_VALUE(input_clk))
- if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) {
* Mode.
break;
* Control register.
div--;
} else {
div = 1;
} else {
for (div = 2;
div += 2) {
break;
div >>= 1;
- } else {
break;
div >>= 1;
- clk |= (div & SDHCI_DIV_MASK) << SDHCI_DIVIDER_SHIFT;
- clk |= ((div & SDHCI_DIV_HI_MASK) >> SDHCI_DIV_MASK_LEN)
- clk |= SDHCI_CLOCK_INT_EN;
- sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL);
- timeout = 2000;
- while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL))
if (timeout == 0) {
__func__);
return -EBUSY;
timeout--;
udelay(10);
- clk |= SDHCI_CLOCK_CARD_EN;
- host->clock = clock;
- struct rockchip_sdhc *priv = dev_get_priv(dev);
- ofnode phy_node;
- void *grf_base;
- u32 grf_phy_offset, phandle;
- phandle = dev_read_u32_default(dev, "phys", 0);
- phy_node = ofnode_get_by_phandle(phandle);
- if (!ofnode_valid(phy_node)) {
return -ENODEV;
- grf_base = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- if (grf_base < 0)
- grf_phy_offset = ofnode_read_u32_default(phy_node, "reg", 0);
- priv->phy = (struct rockchip_emmc_phy *)(grf_base + grf_phy_offset);
- int cycle_phy = host->clock != clock &&
- if (cycle_phy)
- rockchip_emmc_set_clock(host, clock);
- if (cycle_phy)
rockchip_sdhci_set_ios_post?
- struct mmc *mmc = host->mmc;
- struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host);
- struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev);
- data->emmc_set_clock(host, mmc->clock);
- .set_ios_post = sdhci_set_ios_post,
- struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(dev); struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct rockchip_sdhc_plat *plat = dev_get_plat(dev); struct rockchip_sdhc *prv = dev_get_priv(dev);
- switch (dev_read_u32_default(dev, "bus-width", 4)) {
- case 8:
break;
- case 4:
break;
- case 1:
break;
- default:
printf("Invalid \"bus-width\" value\n");
return -EINVAL;
Use mmc_of_parse().
- if (!ret) { ret = clk_set_rate(&clk, max_frequency); if (IS_ERR_VALUE(ret))
- prv->emmc_clk = clk;
- prv->dev = dev;
- ret = data->get_phy(dev);
- if (ret)
return ret;
- ret = data->emmc_phy_init(dev);
- if (ret)
return ret;
- host->ops = &rockchip_sdhci_ops;
- host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD; host->max_clk = max_frequency;
- if (dev_read_bool(dev, "mmc-hs200-1_8v"))
- else if (dev_read_bool(dev, "mmc-hs400-1_8v"))
host->mmc = &plat->mmc; host->mmc->priv = &prv->host; host->mmc->dev = dev;host->host_caps |= MMC_MODE_HS400;
-#endif
- .emmc_set_clock = rk3399_sdhci_emmc_set_clock,
- .get_phy = rk3399_emmc_get_phy,
- .emmc_phy_init = rk3399_emmc_phy_init,
- .name = "rockchip_sdhci_5_1", .id = UCLASS_MMC,
- .of_match = sdhci_ids,
- .of_to_plat = sdhci_of_to_plat, .ops = &sdhci_ops, .bind = rockchip_sdhci_bind,
- .probe = rockchip_sdhci_probe, .priv_auto = sizeof(struct rockchip_sdhc), .plat_auto = sizeof(struct rockchip_sdhc_plat),
Hi Jaehoon,
I already check the mmc code, but I didn't find that the sdhci framework supports the PHY interface. It would be troublesome to support it. At present, only the EMMC of rk3399 has PHY, while rk3568 only has some configuration registers for IO.
The other suggestions from you have been modified on V2 and have been mailed. Please check it again.
Thank you.
Yifeng.zhao
Hi Yifeng,
- Add phy ops
- u32 reserved;
void *base;
- uint start;
- According to the user manual, calpad calibration
- cycle takes more than 2us without the minimal recommended
- value, so we may need a little margin here
- udelay(3);
- According to the user manual, it asks driver to
- wait 5us for calpad busy trimming. But it seems that
- 5us of caldone isn't enough for all cases.
- udelay(500);
- printf("%s: caldone timeout.\n", __func__);
- return;
- freqsel = PHYCTRL_FREQSEL_50M;
- freqsel = PHYCTRL_FREQSEL_100M;
- freqsel = PHYCTRL_FREQSEL_150M;
- else
- freqsel = PHYCTRL_FREQSEL_200M;
- do {
- udelay(1);
- dllrdy = readl(&phy->emmcphy_status);
- dllrdy = (dllrdy >> PHYCTRL_DLLRDY_SHIFT) & PHYCTRL_DLLRDY_MASK;
- if (dllrdy == PHYCTRL_DLLRDY_DONE)
- break;
- printf("%s: dllrdy timeout.\n", __func__);
- container_of(host, struct rockchip_sdhc, host);
- timeout = 2000;
- (SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT)) {
- if (timeout == 0) {
- printf("%s: Timeout to wait cmd & data inhibit\n",
__func__);
- return -EBUSY;
- timeout--;
- udelay(10);
- if (clock == 0)
- input_clk = host->max_clk;
- Check if the Host Controller supports Programmable Clock
- Mode.
- if (host->clk_mul) {
- for (div = 1; div <= 1024; div++) {
- if ((input_clk / div) <= clock)
- break;
- Set Programmable Clock Mode in the Clock
- Control register.
- clk = SDHCI_PROG_CLOCK_MODE;
- div--;
- } else {
- /* Version 3.00 divisors must be a multiple of 2. */
- if (input_clk <= clock) {
- div = 1;
- } else {
- for (div = 2;
div += 2) {
- break;
- div >>= 1;
- } else {
- /* Version 2.00 divisors must be a power of 2. */
- for (div = 1; div < SDHCI_MAX_DIV_SPEC_200; div *= 2) {
- break;
- div >>= 1;
- << SDHCI_DIVIDER_HI_SHIFT;
- timeout = 2000;
- & SDHCI_CLOCK_INT_STABLE)) {
- printf("%s: Internal clock never stabilised.\n",
__func__);
- return -EBUSY;
- timeout--;
- udelay(10);
- ofnode phy_node;
- void *grf_base;
- debug("Not found emmc phy device\n");
- return -ENODEV;
- if (grf_base < 0)
- printf("%s Get syscon grf failed", __func__);
- clock > EMMC_MIN_FREQ;
- if (cycle_phy)
- rk3399_emmc_phy_power_off(priv->phy);
- if (cycle_phy)
- rk3399_emmc_phy_power_on(priv->phy, clock);
- case 8:
- break;
- case 4:
- host->host_caps |= MMC_MODE_4BIT;
- break;
- case 1:
- break;
- default:
- printf("Invalid "bus-width" value\n");
- return -EINVAL;
Use mmc_of_parse().
- prv->dev = dev;
- if (ret)
- return ret;
- if (ret)
- return ret;
- The sdhci-driver only supports 4bit and 8bit, as sdhci_setup_cfg
- doesn't allow us to clear MMC_MODE_4BIT. Consequently, we don't
- check for other bus-width values.
- host->host_caps |= MMC_MODE_HS200;
- host->host_caps |= MMC_MODE_HS400;
-#endif
- .compatible = "arasan,sdhci-5.1",
- .data = (ulong)&rk3399_data,
.id = UCLASS_MMC,
This patch adds support for the RK3568 platform to this driver.
drivers/mmc/rockchip_sdhci.c | 103 +++++++++++++++++++++++++++++++++++ 1 file changed, 103 insertions(+)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 05ed998eca..befe48e061 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -36,6 +36,31 @@ #define PHYCTRL_FREQSEL_100M 0x2 #define PHYCTRL_FREQSEL_150M 0x3
+/* Rockchip specific Registers */ +#define DWCMSHC_EMMC_DLL_CTRL 0x800 +#define DWCMSHC_EMMC_DLL_RXCLK 0x804 +#define DWCMSHC_EMMC_DLL_TXCLK 0x808 +#define DWCMSHC_EMMC_DLL_STRBIN 0x80c +#define DWCMSHC_EMMC_DLL_STATUS0 0x840 +#define DWCMSHC_EMMC_DLL_STATUS1 0x844 +#define DWCMSHC_EMMC_DLL_START BIT(0) +#define DWCMSHC_EMMC_DLL_RXCLK_SRCSEL 29 +#define DWCMSHC_EMMC_DLL_START_POINT 16 +#define DWCMSHC_EMMC_DLL_INC 8 +#define DWCMSHC_EMMC_DLL_DLYENA BIT(27) +#define DLL_TXCLK_TAPNUM_DEFAULT 0x10 +#define DLL_STRBIN_TAPNUM_DEFAULT 0x3 +#define DLL_TXCLK_TAPNUM_FROM_SW BIT(24) +#define DWCMSHC_EMMC_DLL_LOCKED BIT(8) +#define DWCMSHC_EMMC_DLL_TIMEOUT BIT(9) +#define DLL_RXCLK_NO_INVERTER 1 +#define DLL_RXCLK_INVERTER 0 +#define DWCMSHC_ENHANCED_STROBE BIT(8) +#define DLL_LOCK_WO_TMOUT(x) \ + ((((x) & DWCMSHC_EMMC_DLL_LOCKED) == DWCMSHC_EMMC_DLL_LOCKED) && \ + (((x) & DWCMSHC_EMMC_DLL_TIMEOUT) == 0)) +#define ROCKCHIP_MAX_CLKS 3 + struct rockchip_sdhc_plat { struct mmc_config cfg; struct mmc mmc; @@ -267,6 +292,74 @@ static int rk3399_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clo return 0; }
+static int rk3568_emmc_phy_init(struct udevice *dev) +{ + struct rockchip_sdhc *prv = dev_get_priv(dev); + struct sdhci_host *host = &prv->host; + u32 extra; + + extra = DLL_RXCLK_NO_INVERTER << DWCMSHC_EMMC_DLL_RXCLK_SRCSEL; + sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_RXCLK); + return 0; +} + +static int rk3568_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clock) +{ + u32 extra; + int timeout = 500, ret; + + ret = rockchip_emmc_set_clock(host, clock); + + if (clock >= 50 * 1000000) { + sdhci_writel(host, BIT(1), DWCMSHC_EMMC_DLL_CTRL); + udelay(1); + sdhci_writel(host, 0, DWCMSHC_EMMC_DLL_CTRL); + /* Init DLL settings */ + extra = 0x5 << DWCMSHC_EMMC_DLL_START_POINT | + 0x2 << DWCMSHC_EMMC_DLL_INC | + DWCMSHC_EMMC_DLL_START; + sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_CTRL); + + while (1) { + if (timeout < 0) + return -ETIMEDOUT; + if (DLL_LOCK_WO_TMOUT((sdhci_readl(host, DWCMSHC_EMMC_DLL_STATUS0)))) + break; + udelay(1); + timeout--; + } + + extra = DWCMSHC_EMMC_DLL_DLYENA | + DLL_RXCLK_NO_INVERTER << DWCMSHC_EMMC_DLL_RXCLK_SRCSEL; + sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_RXCLK); + + extra = DWCMSHC_EMMC_DLL_DLYENA | + DLL_TXCLK_TAPNUM_DEFAULT | + DLL_TXCLK_TAPNUM_FROM_SW; + sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_TXCLK); + + extra = DWCMSHC_EMMC_DLL_DLYENA | + DLL_STRBIN_TAPNUM_DEFAULT; + sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_STRBIN); + udelay(1); + } else { + /* reset the clock phase when the frequency is lower than 52MHz */ + sdhci_writel(host, 0, DWCMSHC_EMMC_DLL_CTRL); + extra = DLL_RXCLK_NO_INVERTER << DWCMSHC_EMMC_DLL_RXCLK_SRCSEL; + sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_RXCLK); + sdhci_writel(host, 0, DWCMSHC_EMMC_DLL_TXCLK); + sdhci_writel(host, 0, DWCMSHC_EMMC_DLL_STRBIN); + udelay(1); + } + + return ret; +} + +static int rk3568_emmc_get_phy(struct udevice *dev) +{ + return 0; +} + static int sdhci_set_ios_post(struct sdhci_host *host) { struct mmc *mmc = host->mmc; @@ -370,11 +463,21 @@ static const struct sdhci_data rk3399_data = { .emmc_phy_init = rk3399_emmc_phy_init, };
+static const struct sdhci_data rk3568_data = { + .emmc_set_clock = rk3568_sdhci_emmc_set_clock, + .get_phy = rk3568_emmc_get_phy, + .emmc_phy_init = rk3568_emmc_phy_init, +}; + static const struct udevice_id sdhci_ids[] = { { .compatible = "arasan,sdhci-5.1", .data = (ulong)&rk3399_data, }, + { + .compatible = "rockchip,rk3568-dwcmshc", + .data = (ulong)&rk3568_data, + }, { } };
- ((((x) & DWCMSHC_EMMC_DLL_LOCKED) == DWCMSHC_EMMC_DLL_LOCKED) && \
- (((x) & DWCMSHC_EMMC_DLL_TIMEOUT) == 0))
- struct rockchip_sdhc *prv = dev_get_priv(dev);
- struct sdhci_host *host = &prv->host;
- u32 extra;
- extra = DLL_RXCLK_NO_INVERTER << DWCMSHC_EMMC_DLL_RXCLK_SRCSEL;
- sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_RXCLK);
- u32 extra;
- int timeout = 500, ret;
- ret = rockchip_emmc_set_clock(host, clock);
If set_clock is failed, is below codes meaningful?
- if (clock >= 50 * 1000000) {> + sdhci_writel(host, BIT(1), DWCMSHC_EMMC_DLL_CTRL);
udelay(1);
Add comment why put udelay(1).
What means 0x5 and 0x2?
while (1) {
if (timeout < 0)
return -ETIMEDOUT;
break;
udelay(1);
timeout--;
use poll_timeout macro.
udelay(1);
ditto.
- } else {
udelay(1);
ditto.
It seems that can be put udelay(1) at here.
Best Regards, Jaehoon Chung
- return ret;
- .emmc_set_clock = rk3568_sdhci_emmc_set_clock,
- .get_phy = rk3568_emmc_get_phy,
- .emmc_phy_init = rk3568_emmc_phy_init,
Jaehoon Chung
Yifeng Zhao
赵仪峰
