[U-Boot] [RFC PATCH] armv8: cache: Switch MMU table without turning off MMU
We don't have to completely turn off MMU and cache to switch to another MMU table as far as the data is coherent before and after the switching. This patch relaxes the procedure.
Signed-off-by: York Sun york.sun@nxp.com CC: Alexander Graf agraf@suse.de --- I found this issue while trying to change MMU table for a SPL boot. The RAM version U-Boot was copied to memory when d-cache was enabled. SPL code never flushed the cache (I will send another patch to fix that). With existing code, U-Boot stops running as soon as the MMU is diabled. With below propsed change, U-Boot continues to run. I have been in contact with ARM support and got very useful information. However, this switching TTBR method is "behavious that should work" but not well verified by ARM. During my debugging, I found other minor issue which convinced me this code wasn't exercised. I don't intend to use this method in long term, but figure it may help others by fixing it.
arch/arm/cpu/armv8/cache.S | 44 +++++++++----------------------------------- 1 file changed, 9 insertions(+), 35 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S index f1deaa7..63fb112 100644 --- a/arch/arm/cpu/armv8/cache.S +++ b/arch/arm/cpu/armv8/cache.S @@ -171,35 +171,10 @@ ENDPROC(__asm_invalidate_l3_icache) /* * void __asm_switch_ttbr(ulong new_ttbr) * - * Safely switches to a new page table. + * Switches to a new page table. Cache coherency must be maintained + * before calling this function. */ ENTRY(__asm_switch_ttbr) - /* x2 = SCTLR (alive throghout the function) */ - switch_el x4, 3f, 2f, 1f -3: mrs x2, sctlr_el3 - b 0f -2: mrs x2, sctlr_el2 - b 0f -1: mrs x2, sctlr_el1 -0: - - /* Unset CR_M | CR_C | CR_I from SCTLR to disable all caches */ - movn x1, #(CR_M | CR_C | CR_I) - and x1, x2, x1 - switch_el x4, 3f, 2f, 1f -3: msr sctlr_el3, x1 - b 0f -2: msr sctlr_el2, x1 - b 0f -1: msr sctlr_el1, x1 -0: isb - - /* This call only clobbers x30 (lr) and x9 (unused) */ - mov x3, x30 - bl __asm_invalidate_tlb_all - - /* From here on we're running safely with caches disabled */ - /* Set TTBR to our first argument */ switch_el x4, 3f, 2f, 1f 3: msr ttbr0_el3, x0 @@ -209,14 +184,13 @@ ENTRY(__asm_switch_ttbr) 1: msr ttbr0_el1, x0 0: isb
- /* Restore original SCTLR and thus enable caches again */ - switch_el x4, 3f, 2f, 1f -3: msr sctlr_el3, x2 - b 0f -2: msr sctlr_el2, x2 - b 0f -1: msr sctlr_el1, x2 -0: isb + /* invalidate i-cache */ + ic ialluis + isb sy + + /* This call only clobbers x30 (lr) and x9 (unused) */ + mov x3, x30 + bl __asm_invalidate_tlb_all
ret x3 ENDPROC(__asm_switch_ttbr)
This seems plausible, but I'm not immersed well enough in the details to really review it. I CC'd a couple of Linux people from ARM who should be able to review.
- void __asm_switch_ttbr(ulong new_ttbr)
- Safely switches to a new page table.
- Switches to a new page table. Cache coherency must be maintained
- before calling this function.
- b 0f
- b 0f
- and x1, x2, x1
- b 0f
- b 0f
- mov x3, x30
- b 0f
- b 0f
ic ialluis
isb sy
mov x3, x30
ret x3
I believe the approach taken in this patch is unsafe.
Even if the resulting translations are identical across the old and new tables, it is not valid to transition from one set of tables to another unless:
(a) the mappings in both cases are non-global, and the ASID is switched, or:
(b) A Break-Before-Make strategy is followed to ensure that the TLBs contain no stale entries for the old tables.
Even if the resulting translations are identical, you can be subject to TLB conflict aborts and/or behaviours resulting from the amalgamation of TLB entries. In Linux, we had to write special code [1] to switch tables by using some trampoline code in the other TTBR.
I believe that in this case, you only need to clean the MMU-off code to the PoC (using DC DVAC), before temporarily turning the MMU off.
Thanks, Mark.
[1] http://lists.infradead.org/pipermail/linux-arm-kernel/2016-January/401434.ht...
- b 0f
- b 0f
- and x1, x2, x1
- b 0f
- b 0f
- mov x3, x30
- b 0f
- b 0f
ic ialluis
isb sy
mov x3, x30
ret x3
2.7.4
Thanks, Mark.
[1] https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.infr...
Thanks, Mark. Let's keep the current code. I will explore other ways to fix my issue.
York
Mark Rutland
Stephen Warren
York Sun
york sun
