[U-Boot] [PATCH] cmd: move CMD_PXE to Kconfig
Currently, CMD_PXE is forcibly enabled in config_distro_defaults.h, so that general purpose distributions can rely on it being defined. This header is included, under conditions or not, by various archs or famillies of archs / SoCs.
However, it is very possible that boards based on those SoCs will not have a physical ethernet connector at all, even if the have a MAC; for example, the Nanopi Neo AIR (sunxi H3) does not. It is also possible that network booting is absolutely not necessary for a device.
However, it is not possible to disable the PXE command, as it is forcibly enabled and is non-configurable.
But it turns out we already have a config option to build a distro-ready image, in the name of DISTRO_DEFAULTS.
Move CMD_PXE out of the hard-coded config_distro_defaults.h into a Kconfig option, that gets selected by DISTRO_DEFAULTS when it is set.
Signed-off-by: "Yann E. MORIN" yann.morin.1998@free.fr Cc: Joe Hershberger joe.hershberger@ni.com --- Kconfig | 1 + cmd/Kconfig | 5 +++++ include/config_distro_defaults.h | 2 -- 3 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/Kconfig b/Kconfig index 1263d0b..5421cd3 100644 --- a/Kconfig +++ b/Kconfig @@ -60,6 +60,7 @@ config DISTRO_DEFAULTS select CMD_BOOTZ if ARM && !ARM64 select CMD_BOOTI if ARM64 select CMD_DHCP + select CMD_PXE select CMD_EXT2 select CMD_EXT4 select CMD_FAT diff --git a/cmd/Kconfig b/cmd/Kconfig index e339d86..95f5ce6 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -496,6 +496,11 @@ config CMD_DHCP help Boot image via network using DHCP/TFTP protocol
+config CMD_PXE + bool "pxe" + help + Boot image via network using PXE protocol + config CMD_NFS bool "nfs" default y diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index b5efab5..01cd6d9 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -20,8 +20,6 @@ #define CONFIG_BOOTP_PXE #define CONFIG_BOOTP_SUBNETMASK
-#define CONFIG_CMD_PXE - #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_LONGHELP
On Sun, Nov 13, 2016 at 2:59 PM, Yann E. MORIN yann.morin.1998@free.fr wrote:
I like this, but do you not also need to run moveconfig.py on this patch?
Thanks, -Joe
Joe, All,
On 2016-11-14 21:15 -0600, Joe Hershberger spake thusly:
Ack. I was not aware of this tool. I will run it and if it does change any defconfig, I'll repost. If nothing is changed, I'll just reply to this thread. OK?
Should the defconfig update be a separate patch, or should it be squashed into this one?
Thanks for the feedback! :-)
Regards, Yann E. MORIN.
On Tue, Nov 15, 2016 at 11:01 AM, Yann E. MORIN yann.morin.1998@free.fr wrote:
Joe, All,
Sure.
I think most that I have seen it is squashed (though I prefer to create a real patch first to run it against and squash later - I know others prefer to run it against a working directory).
-- .-----------------.--------------------.------------------.--------------------. | Yann E. MORIN | Real-Time Embedded | /"\ ASCII RIBBON | Erics' conspiracy: | | +33 662 376 056 | Software Designer | \ / CAMPAIGN | ___ | | +33 223 225 172 `------------.-------: X AGAINST | \e/ There is no | | http://ymorin.is-a-geek.org/ | _/*_ | / \ HTML MAIL | v conspiracy. | '------------------------------^-------^------------------^--------------------'
Joe, All,
Sure.
So I'm stepping in here. I'm close to being able to take the original patch as-is, the main problems with it were what I addressed in a series earlier today, that MENU and CMD_BOOTMENU need to be migrated and a number of platforms that are using config_distro_defaults.h and config_distro_bootcmd.h but were not enabling CONFIG_DISTRO_DEFAULTS so had lost various features. With these two in, and a minor change to this patch to have it select MENU, everything is good, and I'll take it.
On Sun, Nov 13, 2016 at 8:59 PM, Yann E. MORIN yann.morin.1998@free.fr wrote:
So this changes the default expectation on all boards that currently use distro defaults?
+config CMD_PXE
bool "pxe"
help
2.7.4
Peter, All,
On 2016-11-16 14:04 +0000, Peter Robinson spake thusly:
Well, I'm not totally aware of all the implications of such a change, but my analysis is:
- CONFIG_CMD_PXE was in include/config_distro_defaults.h, which to my poor little brain means "we want that as a distro default";
- CONFIG_CMD_PXE is now enabled by CONFIG_DISTRO_DEFAULTS, which means the same (and the help text confirms that).
So, it looks to me that the expected behaviour does not change. In theory! ;-)
Now, I may well have missed something, in which case I always accept being enlighten; just point me to the pieces I missed (totally possible, I'm new in U-Boot land!).
I'm running buildman on all configs right now, on current master (but it takes a lot of time...). Once this is done, I'll re-run it on my change.
From what I understand, buildman should point me to boards which are
affected by the change, right? When we have that list, we can assess whether it is acceptable or not.
Thanks! :-)
+config CMD_PXE
bool "pxe"
help
2.7.4
On Thu, Nov 17, 2016 at 11:04 AM, Yann E. MORIN yann.morin.1998@free.fr wrote:
Peter, All,
I'm running buildman on all configs right now, on current master (but it takes a lot of time...). Once this is done, I'll re-run it on my change. From what I understand, buildman should point me to boards which are affected by the change, right? When we have that list, we can assess whether it is acceptable or not.
The --show-config option on buildman will tell you about boards that have changes configs.
Thanks! :-)
+config CMD_PXE
bool "pxe"
help
2.7.4
-- .-----------------.--------------------.------------------.--------------------. | Yann E. MORIN | Real-Time Embedded | /"\ ASCII RIBBON | Erics' conspiracy: | | +33 662 376 056 | Software Designer | \ / CAMPAIGN | ___ | | +33 223 225 172 `------------.-------: X AGAINST | \e/ There is no | | http://ymorin.is-a-geek.org/ | _/*_ | / \ HTML MAIL | v conspiracy. | '------------------------------^-------^------------------^--------------------' _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Joe Hershberger
Peter Robinson
Yann E. MORIN
